    4. Zigbee Geräte fehlen nach Upgrade auf JS-Controller 5.0
      peterredl @Thomas Braun last edited by
      2023-09-17 14:09:33.772  - error: zigbee.0 (8209) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/ttyS0'"
      2023-09-17 14:09:33.776  - error: zigbee.0 (8209) Failed to start Zigbee
      2023-09-17 14:09:33.777  - error: zigbee.0 (8209) Error herdsman start
      2023-09-17 14:09:33.786  - info: zigbee.0 (8209) Installed Version: iobroker.zigbee@1.8.23
      2023-09-17 14:09:33.356  - info: zigbee.0 (8209) starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 5.0.12
      2023-09-17 14:09:33.441  - info: zigbee.0 (8209) delete old Backup files. keep only last 10
      2023-09-17 14:09:33.442  - info: zigbee.0 (8209) Starting Zigbee  npm ...
      2023-09-17 14:09:43.780  - info: zigbee.0 (8209) Try to reconnect. 1 attempts left
      2023-09-17 14:09:43.781  - info: zigbee.0 (8209) Starting Zigbee  npm ...
      2023-09-17 14:09:43.807  - error: zigbee.0 (8209) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/ttyS0'"
      2023-09-17 14:09:43.808  - error: zigbee.0 (8209) Failed to start Zigbee
      2023-09-17 14:09:43.811  - error: zigbee.0 (8209) Error herdsman start
      2023-09-17 14:09:43.817  - info: zigbee.0 (8209) Installed Version: iobroker.zigbee@1.8.23
      2023-09-17 14:10:26.405  - info: ham.0 (2102) stateChange ham.0.Pool.Temperature-Sensor.Current-Temperature {"val":22.7,"ack":true,"ts":1694952626403,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694952626403}
        Thomas Braun Most Active @peterredl last edited by
        @peterredl sagte in Zigbee Geräte fehlen nach Upgrade auf JS-Controller 5.0:
        /dev/serial/ttyS0
        Den Pfad gibt es nicht und deswegen kann das Gerät auch nicht gefunden werden.
        find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
        spuckt dir valide Pfade aus. Den zum Stick trägst du dann im Adapter unter com-Ports ein.
          peter@q4os-desktop:~$ find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
          /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          Die Zeile 2 habe ich kopiert und als com port eingetragen. Geht leider auch nicht.
            Geht nicht ist keine Fehlermeldung.
            Adapter Neustart schaut nun wie im LogFile aus?
              das sind die Meldungen nach dem Neustart des Adapters:
              2023-09-17 14:28:30.974  - info: host.q4os-desktop stopInstance system.adapter.z
              igbee.0 (force=false, process=true)
              2023-09-17 14:28:31.003  - info: zigbee.0 (8560) Got terminate signal TERMINATE_
              YOURSELF
              2023-09-17 14:28:31.234  - info: host.q4os-desktop stopInstance system.adapter.z
              igbee.0 send kill signal
              2023-09-17 14:28:31.007  - info: zigbee.0 (8560) cleaned everything up...
              2023-09-17 14:28:31.411  - info: zigbee.0 (8560) Zigbee: disabling joining new d
              evices.
              2023-09-17 14:28:31.437  - warn: zigbee.0 (8560) Failed to stop zigbee during st
              artup
              2023-09-17 14:28:31.438  - info: zigbee.0 (8560) terminating
              2023-09-17 14:28:31.439  - info: zigbee.0 (8560) Terminated (ADAPTER_REQUESTED_T
              ERMINATION): Without reason
              2023-09-17 14:28:31.508  - info: zigbee.0 (8560) terminating
              2023-09-17 14:28:31.551  - info: zigbee.0 (8560) debug devices set to []
              2023-09-17 14:28:32.037  - info: host.q4os-desktop instance system.adapter.zigbe
              e.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-17 14:28:32.536  - info: admin.0 (1342) <== Disconnect system.user.admin
              YOURSELF
              evices.
              artup
              2023-09-17 14:28:32.037  - info: host.q4os-desktop instance system.adapter.zigbe        e.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-17 14:28:32.536  - info: admin.0 (1342) <== Disconnect system.user.admin        from ::ffff:192.168.2.222
              2023-09-17 14:28:34.346  - info: host.q4os-desktop instance system.adapter.zigbe        e.0 started with pid 8926
              2023-09-17 14:28:37.102  - info: zigbee.0 (8926) starting. Version 1.8.23 in /op        t/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 5.0.12
              2023-09-17 14:28:37.152  - info: zigbee.0 (8926) delete old Backup files. keep o        nly last 10
              2023-09-17 14:28:37.153  - info: zigbee.0 (8926) Starting Zigbee  npm ...
              2023-09-17 14:28:37.285  - info: zigbee.0 (8926) Installed Version: iobroker.zig        bee@1.8.23
              2023-09-17 14:28:57.509  - error: zigbee.0 (8926) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              2023-09-17 14:28:57.509  - error: zigbee.0 (8926) Failed to start Zigbee
              2023-09-17 14:28:57.509  - error: zigbee.0 (8926) Error herdsman start
              2023-09-17 14:29:07.512  - info: zigbee.0 (8926) Try to reconnect. 1 attempts left
              2023-09-17 14:29:07.514  - info: zigbee.0 (8926) Starting Zigbee  npm ...
              2023-09-17 14:29:07.539  - info: zigbee.0 (8926) Installed Version: iobroker.zigbee@1.8.23
              2023-09-17 14:29:07.662  - error: zigbee.0 (8926) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2023-09-17 14:29:07.663  - error: zigbee.0 (8926) Failed to start Zigbee
              2023-09-17 14:29:07.663  - error: zigbee.0 (8926) Error herdsman start
              • Glasfaser
                Glasfaser @peterredl last edited by
                q4os
                Zeige mal
                iob diag
                aber die Full Version
                  Ich hoffe, das ist die full Version...
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                  Static hostname: q4os-desktop
                  Icon name: computer-desktop
                  Chassis: desktop
                  Machine ID: 163dfadd781c44cd94d7a397cdd870ff
                  Boot ID: aec401992f534ee8ad15c09fdff5e2d4
                  Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-21-amd64
                  Architecture: x86-64
                  model name : Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
                  Docker : false
                  Virtualization : none
                  Kernel : x86_64
                  Userland : amd64
                  Systemuptime and Load:
                  14:33:42 up 1:41, 1 user, load average: 1.26, 1.06, 1.22
                  CPU threads: 4
                  *** Time and Time Zones ***
                  Local time: Sun 2023-09-17 14:33:42 CEST
                  Universal time: Sun 2023-09-17 12:33:42 UTC
                  RTC time: Sun 2023-09-17 12:33:42
                  Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
                  RTC in local TZ: no
                  *** User and Groups ***
                  peter
                  /home/peter
                  peter dialout cdrom floppy sudo audio dip video plugdev users netdev lpadmin bluetooth scanner iobroker
                  *** X-Server-Setup ***
                  X-Server: true
                  Desktop: trinity
                  Terminal: x11
                  Boot Target: graphical.target
                  *** MEMORY ***
                  total used free shared buff/cache available
                  Mem: 15G 4.3G 9.0G 289M 2.7G 11G
                  Swap: 9.2G 0B 9.2G
                  Total: 25G 4.3G 18G
                      15893 M total memory
                       4286 M used memory
                        649 M active memory
                       5612 M inactive memory
                       8956 M free memory
                        181 M buffer memory
                       2468 M swap cache
                       9167 M total swap
                          0 M used swap
                       9167 M free swap
                  *** FILESYSTEM ***
                  df: /run/user/1000/doc: Operation not permitted
                  Filesystem Type Size Used Avail Use% Mounted on
                  udev devtmpfs 7.8G 0 7.8G 0% /dev
                  tmpfs tmpfs 1.6G 2.8M 1.6G 1% /run
                  /dev/mapper/q4os--desktop--vg-root ext4 91G 25G 62G 29% /
                  tmpfs tmpfs 7.8G 56M 7.8G 1% /dev/shm
                  tmpfs tmpfs 5.0M 8.0K 5.0M 1% /run/lock
                  /dev/nvme0n1p1 ext2 470M 366M 80M 83% /boot
                  tmpfs tmpfs 1.6G 36K 1.6G 1% /run/user/1000
                  [Sun Sep 17 12:51:57 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
                  [Sun Sep 17 12:51:57 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
                  [Sun Sep 17 12:51:58 2023] EXT4-fs (nvme0n1p1): mounting ext2 file system using the ext4 subsystem
                  [Sun Sep 17 12:51:58 2023] EXT4-fs (nvme0n1p1): mounted filesystem without journal. Opts: (null)
                  Show mounted filesystems (real ones only):
                  TARGET SOURCE FSTYPE OPTIONS
                  / /dev/mapper/q4os--desktop--vg-root ext4 rw,relatime,errors=remount-ro
                  |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot /dev/nvme0n1p1 ext2 rw,relatime
                  /var:
                  6.3G /var/
                  4.2G /var/log/journal/163dfadd781c44cd94d7a397cdd870ff
                  4.2G /var/log
                  1.8G /var/lib
                  Archived and active journals take up 160.0M in the file system.
                  /opt/iobroker/backups:
                  89M /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  2.4G /opt/iobroker/iobroker-data/
                  2.0G /opt/iobroker/iobroker-data/history
                  202M /opt/iobroker/iobroker-data/files
                  167M /opt/iobroker/iobroker-data/backup-objects
                  52M /opt/iobroker/iobroker-data/files/javascript.admin
                  35M /opt/iobroker/iobroker-data/states.jsonl
                  23M /opt/iobroker/iobroker-data/objects.jsonl
                  21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                  19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                  16M /opt/iobroker/iobroker-data/objects.json.migrated
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs v16.19.1
                  /usr/bin/node v16.19.1
                  /usr/bin/npm 8.19.3
                  /usr/bin/npx 8.19.3
                  nodejs:
                  Installed: 16.19.1-deb-1nodesource1
                  Candidate: 16.20.2-deb-1nodesource1
                  Version table:
                  16.20.2-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                  *** 16.19.1-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
                  12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                  12.22.12~dfsg-1~deb11u3 500
                  500 http://ftp.at.debian.org/debian bullseye/main amd64 Packages
                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                  No problems detected
                  npm ERR! code ELSPROBLEMS
                  npm ERR! missing: homebridge-ewelink@^11.0.2, required by iobroker.ham@5.3.1
                  npm ERR! /home/peter/.npm/_logs/2023-09-17T12_33_51_450Z-debug-0.log
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States type: jsonl
                  No configuration change needed.
                  Multihost discovery server: disabled
                  Discovery authentication: enabled
                  Persistent activation: disabled
                  Objects: jsonl on 127.0.0.1
                  States: jsonl on 127.0.0.1
                  Core adapters versions
                  admin: 6.8.0
                  javascript: 7.1.4
                  Adapters from github: 0
                  Adapter State
                  • system.adapter.admin.0 : admin : q4os-desktop - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  • system.adapter.alexa2.0 : alexa2 : q4os-desktop - enabled
                  • system.adapter.backitup.0 : backitup : q4os-desktop - enabled
                  • system.adapter.bosch-ebike.0 : bosch-ebike : q4os-desktop - enabled
                  • system.adapter.broadlink2.0 : broadlink2 : q4os-desktop - enabled
                    system.adapter.cloud.0 : cloud : q4os-desktop - disabled
                    system.adapter.daswetter.0 : daswetter : q4os-desktop - enabled
                  • system.adapter.device-reminder.0 : device-reminder : q4os-desktop - enabled
                  • system.adapter.device-watcher.0 : device-watcher : q4os-desktop - enabled
                  • system.adapter.discovery.0 : discovery : q4os-desktop - enabled
                  • system.adapter.fb-checkpresence.0 : fb-checkpresence : q4os-desktop - enabled
                    system.adapter.flot.0 : flot : q4os-desktop - enabled
                  • system.adapter.fronius.0 : fronius : q4os-desktop - enabled
                    system.adapter.fuelpricemonitor.0 : fuelpricemonitor : q4os-desktop - enabled
                  • system.adapter.go-e.0 : go-e : q4os-desktop - enabled
                  • system.adapter.ham.0 : ham : q4os-desktop - enabled
                  • system.adapter.history.0 : history : q4os-desktop - enabled
                  • system.adapter.hmip.0 : hmip : q4os-desktop - enabled
                  • system.adapter.hs100.0 : hs100 : q4os-desktop - enabled
                    system.adapter.info.0 : info : q4os-desktop - enabled
                  • system.adapter.iot.0 : iot : q4os-desktop - enabled
                  • system.adapter.javascript.0 : javascript : q4os-desktop - enabled
                  • system.adapter.mercedesme.0 : mercedesme : q4os-desktop - enabled
                  • system.adapter.mihome.0 : mihome : q4os-desktop - enabled, port: 9898, bind: 0.0.0.0
                  • system.adapter.mqtt.0 : mqtt : q4os-desktop - enabled, port: 1886, bind: 0.0.0.0
                    system.adapter.netatmo-crawler.0 : netatmo-crawler : q4os-desktop - enabled
                  • system.adapter.netatmo.0 : netatmo : q4os-desktop - enabled
                  • system.adapter.opendtu.0 : opendtu : q4os-desktop - enabled
                  • system.adapter.shelly.0 : shelly : q4os-desktop - enabled, port: 1882, bind: 0.0.0.0
                  • system.adapter.sonoff.0 : sonoff : q4os-desktop - enabled, port: 1884, bind: 0.0.0.0
                  • system.adapter.sureflap.0 : sureflap : q4os-desktop - enabled
                  • system.adapter.telegram.0 : telegram : q4os-desktop - enabled, port: 8443, bind: 0.0.0.0
                  • system.adapter.tuya.0 : tuya : q4os-desktop - enabled
                    system.adapter.vis-hqwidgets.0 : vis-hqwidgets : q4os-desktop - enabled
                  • system.adapter.vis-inventwo.0 : vis-inventwo : q4os-desktop - enabled
                    system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : q4os-desktop - enabled
                    system.adapter.vis-timeandweather.0 : vis-timeandweather : q4os-desktop - enabled
                    system.adapter.vis-weather.0 : vis-weather : q4os-desktop - enabled
                    system.adapter.vis.0 : vis : q4os-desktop - enabled
                  • system.adapter.web.0 : web : q4os-desktop - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  • system.adapter.zigbee.0 : zigbee : q4os-desktop - enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                  • instance is alive
                  ioBroker-Repositories
                  Stable (default): http://download.iobroker.net/sources-dist.json
                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                  Active repo(s): Stable (default)
                  Installed ioBroker-Instances
                  Used repository: Stable (default)
                  Adapter "admin" : 6.8.0 , installed 6.8.0
                  Adapter "alexa2" : 3.24.1 , installed 3.24.1
                  Adapter "backitup" : 2.6.23 , installed 2.6.23
                  Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3
                  Adapter "broadlink2" : 2.1.5 , installed 2.1.5
                  Adapter "cloud" : 4.4.1 , installed 4.4.1
                  Adapter "daswetter" : 3.1.10 , installed 3.1.10
                  Adapter "device-reminder": 1.2.9 , installed 1.2.9
                  Adapter "device-watcher": 2.9.3 , installed 2.9.3
                  Adapter "discovery" : 3.1.0 , installed 3.1.0
                  Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2
                  Adapter "flot" : 1.12.0 , installed 1.12.0
                  Adapter "fronius" : 1.1.3 , installed 1.1.3
                  Adapter "fuelpricemonitor": 0.3.6 , installed 0.3.6
                  Adapter "go-e" : 1.0.27 , installed 1.0.27
                  Adapter "ham" : 5.3.1 , installed 5.3.1
                  Adapter "history" : 2.2.6 , installed 2.2.6
                  Adapter "hmip" : 1.20.0 , installed 1.20.0
                  Adapter "hs100" : 2.1.2 , installed 2.1.2
                  Adapter "info" : 1.9.26 , installed 1.9.26
                  Adapter "iot" : 1.14.5 , installed 1.14.5
                  Adapter "javascript" : 7.1.4 , installed 7.1.4
                  Controller "js-controller": 5.0.12 , installed 5.0.12
                  Adapter "mercedesme" : 0.1.1 , installed 0.1.1
                  Adapter "mihome" : 1.4.0 , installed 1.4.0
                  Adapter "mqtt" : 4.1.1 , installed 4.1.1
                  Adapter "netatmo" : 3.1.0 , installed 3.1.0
                  Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
                  Adapter "opendtu" : 0.1.7 , installed 0.1.7
                  Adapter "shelly" : 6.4.1 , installed 6.4.1
                  Adapter "simple-api" : 2.7.2 , installed 2.7.2
                  Adapter "socketio" : 6.5.5 , installed 6.5.5
                  Adapter "sonoff" : 2.5.3 , installed 2.5.3
                  Adapter "sureflap" : 1.2.0 , installed 1.2.0
                  Adapter "telegram" : 1.16.0 , installed 1.16.0
                  Adapter "tuya" : 3.14.2 , installed 3.14.2
                  Adapter "vis" : 1.4.16 , installed 1.4.16
                  Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
                  Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
                  Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
                  Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
                  Adapter "vis-weather" : 2.5.6 , installed 2.5.6
                  Adapter "web" : 6.1.2 , installed 6.1.2
                  Adapter "ws" : 2.5.5 , installed 2.5.5
                  Adapter "zigbee" : 1.8.23 , installed 1.8.23
                  Objects and States
                  Objects: 27363
                  States: 20597
                  E: Failed to fetch http://ppa.launchpad.net/morphis/anbox-support/ubuntu/dists/jammy/InRelease 403 Forbidden [IP: 185.125.190.52 80]
                  E: The repository 'http://ppa.launchpad.net/morphis/anbox-support/ubuntu jammy InRelease' is not signed.
                  E: The repository 'http://security.debian.org bullseye/updates Release' does not have a Release file.
                  Pending Updates: 203
                  *** Listening Ports ***
                  Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                  tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 19753 1264/exim4
                  tcp 0 0 127.0.0.1:1883 0.0.0.0:* LISTEN 114 19499 662/mosquitto
                  tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 22616 1601/io.sonoff.0
                  tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 15224 986/smbd
                  tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 24947 2158/io.mqtt.0
                  tcp 0 0 127.0.0.1:3551 0.0.0.0:* LISTEN 0 20164 931/apcupsd
                  tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 20811 633/iobroker.js-con
                  tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 20788 633/iobroker.js-con
                  tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 15225 986/smbd
                  tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 9850 1/init
                  tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 20497 632/cupsd
                  tcp6 0 0 ::1:25 :::* LISTEN 0 19754 1264/exim4
                  tcp6 0 0 ::1:1883 :::* LISTEN 114 19500 662/mosquitto
                  tcp6 0 0 :::445 :::* LISTEN 0 15222 986/smbd
                  tcp6 0 0 :::139 :::* LISTEN 0 15223 986/smbd
                  tcp6 0 0 :::111 :::* LISTEN 0 9854 1/init
                  tcp6 0 0 :::8081 :::* LISTEN 1001 20981 1342/io.admin.0
                  tcp6 0 0 :::8082 :::* LISTEN 1001 56228 5884/io.web.0
                  tcp6 0 0 :::6547 :::* LISTEN 0 19234 668/java
                  tcp6 0 0 ::1:631 :::* LISTEN 0 20496 632/cupsd
                  udp 0 0 0.0.0.0:45081 0.0.0.0:* 106 18261 566/avahi-daemon: r
                  udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 26664 2102/io.ham.0
                  udp 0 0 224.0.0.251:5353 0.0.0.0:* 1000 23241 1657/chrome
                  udp 0 0 0.0.0.0:5353 0.0.0.0:* 106 18259 566/avahi-daemon: r
                  udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 22575 1586/io.shelly.0
                  udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 21162 1616/io.tuya.0
                  udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 21163 1616/io.tuya.0
                  udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 25907 2417/io.broadlink2.
                  udp 0 0 0.0.0.0:56606 0.0.0.0:* 1001 27109 2417/io.broadlink2.
                  udp 0 0 0.0.0.0:111 0.0.0.0:* 0 9851 1/init
                  udp 0 0 192.168.2.255:137 0.0.0.0:* 0 18964 895/nmbd
                  udp 0 0 192.168.2.222:137 0.0.0.0:* 0 18963 895/nmbd
                  udp 0 0 0.0.0.0:137 0.0.0.0:* 0 18950 895/nmbd
                  udp 0 0 192.168.2.255:138 0.0.0.0:* 0 18966 895/nmbd
                  udp 0 0 192.168.2.222:138 0.0.0.0:* 0 18965 895/nmbd
                  udp 0 0 0.0.0.0:138 0.0.0.0:* 0 18951 895/nmbd
                  udp 0 0 0.0.0.0:631 0.0.0.0:* 0 20516 743/cups-browsed
                  udp 0 0 0.0.0.0:9898 0.0.0.0:* 1001 23354 2147/io.mihome.0
                  udp 0 0 0.0.0.0:43843 0.0.0.0:* 1001 25293 2417/io.broadlink2.
                  udp6 0 0 :::5353 :::* 106 18260 566/avahi-daemon: r
                  udp6 0 0 :::46479 :::* 0 19222 668/java
                  udp6 0 0 :::111 :::* 0 9857 1/init
                  udp6 0 0 :::3052 :::* 0 20869 668/java
                  udp6 0 0 :::60662 :::* 106 18262 566/avahi-daemon: r
                  2023-09-17 14:30:00.036 - info: host.q4os-desktop instance system.adapter.netatmo-crawler.0 started with pid 8970
                  2023-09-17 14:30:01.380 - info: netatmo-crawler.0 (8970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v16.19.1, js-controller: 5.0.12
                  2023-09-17 14:30:01.456 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:53:39:f8
                  2023-09-17 14:30:01.804 - warn: netatmo-crawler.0 (8970) Could not work with station 1 - Message: Error: undefined is not a valid state value
                  2023-09-17 14:30:01.807 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:7f:96:be
                  2023-09-17 14:30:02.094 - warn: netatmo-crawler.0 (8970) Could not work with station 2 - Message: Error: undefined is not a valid state value
                  2023-09-17 14:30:02.095 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:27:ac:9a
                  2023-09-17 14:30:02.394 - warn: netatmo-crawler.0 (8970) Could not work with station 3 - Message: Error: undefined is not a valid state value
                  2023-09-17 14:30:02.397 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:96:a4:36
                  2023-09-17 14:30:03.866 - info: netatmo-crawler.0 (8970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-09-17 14:30:04.399 - info: host.q4os-desktop instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-09-17 14:33:11.113 - info: ham.0 (2102) stateChange ham.0.Messsteckdose.Messsteckdose-History.S2R1 {"val":"uLYLAAAAAADPcqsqAQ4BAgXADwAAAAAAAAAAAQE=","ack":true,"ts":1694953991111,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991111}
                  2023-09-17 14:33:11.154 - info: ham.0 (2102) stateChange ham.0.Device3c65fe-Sonoff-Schalter.Device3c65fe-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD+ENAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.155 - info: ham.0 (2102) stateChange ham.0.S26Hauseingang.S26Hauseingang-History.S2R1 {"val":"IjF+AQAAAABl+DgpAQ4BwA/AD7mTAAAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.157 - info: ham.0 (2102) stateChange ham.0.Abstellraum.Abstellraum-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/AD6CNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.161 - info: ham.0 (2102) stateChange ham.0.Bau-WC-Licht.Bau-WC-Licht-History.S2R1 {"val":"NjGIAgAAAABR+C4oAQ4BwA/ADxoDAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.161 - info: ham.0 (2102) stateChange ham.0.Device4d7fc5-S26-Sonoff-Ham.Device4d7fc5-S26-Sonoff-Ham-History.S2R1 {"val":"aiefAgAAAAAdAhgoAQ4BwA/AD5ANAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.163 - info: ham.0 (2102) stateChange ham.0.Device3be921-S20-Sonoff-1.Device3be921-S20-Sonoff-1-History.S2R1 {"val":"aiefAgAAAAAdAhgoAQ4BwA/AD6QNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.165 - info: ham.0 (2102) stateChange ham.0.Device6aae8d-Sonoff-Schalter.Device6aae8d-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD/AOAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.166 - info: ham.0 (2102) stateChange ham.0.Device4110d0-Sonoff-Schalter.Device4110d0-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD+YNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.168 - info: ham.0 (2102) stateChange ham.0.Christbaum.Christbaum-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/AD4RfAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.170 - info: ham.0 (2102) stateChange ham.0.Vitrine.Vitrine-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD/MNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.172 - info: ham.0 (2102) stateChange ham.0.Garagentor.Garagentor-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/ADzFwAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.173 - info: ham.0 (2102) stateChange ham.0.Toilette.Toilette-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/ADxZ+AQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  2023-09-17 14:33:11.175 - info: ham.0 (2102) stateChange ham.0.Pool.Pool-History.S2R1 {"val":"CdqjAgAAAAB+TxMoAgECDgHAD8APAwkBAAAAAAABAQ==","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
                  iob diag has finished.
                  Press any key for a summary
                    Desktop: trinity
                    Denn kannste direkt schon mal ausschalten. Ersatzlos.
                      sorry, mit mir ist es nicht leicht....
                      was soll ich wo ausschalten?
                        @peterredl
                        sudo systemctl set-default multi-user.target
                        sudo systemctl isolate multi-user.target
                          @peterredl
                          Deine Distribution ist irgendwie sehr schräg aufgestellt...
                            Ich bin wohl der größte Trottel….
                            Jetzt habe ich deine Eingaben eingegeben und jetzt verlangt er das Desktop Login von mir. Weiß ich nicht mehr und komme nicht mehr ins System. Auch ein Neustart des Rechners hilft nicht. Jetzt schreibe ich von meinem Tablet. Ich denke, jetzt wird nur mehr eine komplette Neuinstallation des Rechners helfen….
                            Verzweiflung pur !!!!
                              Für verbummelte Passworte kann ich ja nun nix.
                                Dann nimm diesmal ein reines Debian Bookworm, ohne Desktop.
                                Das q4-Dingsi scheint mir jedenfalls eh etwas 'komisch'.
                                  Sorry, war wirklich nicht böse gemeint. Ich habe den Rechner vor Jahren aufgesetzt und seitdem ist er gelaufen und hat mich nie nach einem Login gefragt….
                                  Ich danke dir für deine Bemühungen und hoffe, dass ich nach dem neuaufstzen des Rechners, den IoBroker wieder aufsetzen kann und das letzte Backup wieder einspielen kann. Danke.
                                    peterredl @peterredl last edited by
                                    @peterredl
                                    Ich bin wieder im System. Logindaten gefunden.
                                    Alles läuft wieder bis auf den Zigbee Adapter….
                                    Hast vielleicht diesbezüglich noch einen Tip für mich ?
                                    Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      Glasfaser @peterredl last edited by Glasfaser
                                      ioBroker Log zeigen !
                                      EDIT :
                                      Hast du auch mal dein gesamtes Sytem neu gestartet !?
                                        @peterredl
                                        iob diag
                                        sagt?
                                        Da hängen auch noch knapp zweihundert Updates in der Pipeline. Die solltest du zunächst mal einspielen.
                                        998
