    3. Einsteigerfragen
    4. Installation
    5. Hilfe! js-controller und javascript Problem
      Thomas Braun Most Active @ioNewbie last edited by
      @ionewbie
      NEIN!
      iobroker wird NIE mit sudo angepackt.
      • I
        ioNewbie @Thomas Braun last edited by ioNewbie
        @thomas-braun sorry. Also diese hier:
        iobroker stop
        iobroker update
        iobroker fix oder wenn das nicht funktioniert: curl -sL https://iobroker.net/fix.sh | bash -
        iobroker upgrade self
        iobroker start
          @ionewbie
          Gib mir nochmal die aktuelle Langfassung vom
          iob diag
          • I
            @thomas-braun hier:
            Skript v.2023-06-20
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer
                    Machine ID: 68716f4ecfa5426ea966c195a9cf7def
                       Boot ID: 6aefc086b627460e8ca1c41a04001228
              Operating System: Raspbian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : armhf
            Systemuptime and Load:
             14:34:11 up 10 min,  2 users,  load average: 0.12, 0.48, 0.45
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=42.8'C
            volt=0.8625V
            *** Time and Time Zones ***
                           Local time: Sun 2023-09-17 14:34:11 CEST
                       Universal time: Sun 2023-09-17 12:34:11 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            3.8G        441M        2.8G        0.0K        524M        3.3G
            Swap:            99M          0B         99M
            Total:          3.9G        441M        2.9G
                     3794 M total memory
                      441 M used memory
                      519 M active memory
                      327 M inactive memory
                     2828 M free memory
                       54 M buffer memory
                      470 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4       59G  7.0G   49G  13% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  836K  759M   1% /run
            /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
            /dev/sda1      exfat     118G  9.3M  118G   1% /media/usbstick
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Sun Sep 17 14:23:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F8:36:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f61f07b-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Sep 17 14:23:32 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Sep 17 14:23:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Sep 17 14:23:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems (real ones only):
            TARGET            SOURCE         FSTYPE OPTIONS
            /                 /dev/mmcblk0p2 ext4   rw,noatime,nodiratime
            |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            `-/media/usbstick /dev/sda1      exfat  rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,iocharset=utf8,errors=remount-ro
            /var:
            2.4G    /var/
            1.8G    /var/log/journal/68716f4ecfa5426ea966c195a9cf7def
            1.8G    /var/log
            323M    /var/cache
            Archived and active journals take up 1.7G in the file system.
            /opt/iobroker/backups:
            87M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.9G    /opt/iobroker/iobroker-data/
            1.7G    /opt/iobroker/iobroker-data/history
            126M    /opt/iobroker/iobroker-data/files
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            44M     /opt/iobroker/iobroker-data/backup-objects
            7.1M    /opt/iobroker/iobroker-data/objects.jsonl
            7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
            5.3M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/2.00871907.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.17.1
            /usr/bin/node           v18.17.1
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Installed: 18.17.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
             *** 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            npm ERR! code ELSPROBLEMS
            npm ERR! missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-17T12_34_24_403Z-debug-0.log
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            No configuration change needed.
            Multihost discovery server: disabled
            Discovery authentication:   enabled
            Persistent activation:      disabled
            Objects:                    jsonl on 127.0.0.1
            States:                     jsonl on 127.0.0.1
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     7.1.4
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
              system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
              system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
              system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
              system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.10.190
              system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
              system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
              system.adapter.powerfox2.0              : powerfox2             : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
              system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
              system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
            Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
            Adapter    "daikin-cloud" : 0.3.0    , installed 0.2.3  [Updatable]
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
            Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
            Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
            Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
            Adapter    "knx"          : 2.0.22   , installed 2.0.17 [Updatable]
            Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
            Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
            Adapter    "sonos"        : 2.3.1    , installed 2.3.1
            Adapter    "synology"     : 2.1.13   , installed 2.1.13
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
            Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
            Objects and States
            Objects:        2461
            States:         1869
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1872       482/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13925      482/iobroker.js-con
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       14238      834/io.shelly.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13899      519/sshd: /usr/sbin
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14173      598/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17582      1027/io.web.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13901      519/sshd: /usr/sbin
            udp        0      0 0.0.0.0:46199           0.0.0.0:*                           108        1774       393/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1772       393/avahi-daemon: r
            udp        0      0 192.168.10.190:52781    0.0.0.0:*                           1001       16090      1296/io.knx.0
            udp        0      0 192.168.10.190:56912    0.0.0.0:*                           1001       23788      1296/io.knx.0
            udp        0      0 192.168.10.190:50885    0.0.0.0:*                           1001       16873      1296/io.knx.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15138      701/dhcpcd
            udp6       0      0 :::47730                :::*                                108        1775       393/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        1773       393/avahi-daemon: r
            2023-09-17 14:29:06.350  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            2023-09-17 14:30:00.117  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3666
            2023-09-17 14:30:02.100  - info: powerfox2.0 (3666) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
            2023-09-17 14:30:05.431  - info: powerfox2.0 (3666) Terminated (NO_ERROR): Without reason
            2023-09-17 14:30:05.987  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            2023-09-17 14:31:00.148  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3683
            2023-09-17 14:31:02.155  - info: powerfox2.0 (3683) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
            2023-09-17 14:31:05.186  - info: powerfox2.0 (3683) Terminated (NO_ERROR): Without reason
            2023-09-17 14:31:05.763  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            2023-09-17 14:32:00.093  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3700
            2023-09-17 14:32:02.065  - info: powerfox2.0 (3700) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
            2023-09-17 14:32:05.411  - info: powerfox2.0 (3700) Terminated (NO_ERROR): Without reason
            2023-09-17 14:32:05.943  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            2023-09-17 14:33:00.123  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3715
            2023-09-17 14:33:02.072  - info: powerfox2.0 (3715) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
            2023-09-17 14:33:06.034  - info: powerfox2.0 (3715) Terminated (NO_ERROR): Without reason
            2023-09-17 14:33:06.565  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            2023-09-17 14:34:00.133  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3733
            2023-09-17 14:34:02.101  - info: powerfox2.0 (3733) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
            2023-09-17 14:34:05.015  - info: powerfox2.0 (3733) Terminated (NO_ERROR): Without reason
            2023-09-17 14:34:05.576  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            2023-09-17 14:35:00.112  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 4007
            2023-09-17 14:35:02.218  - info: powerfox2.0 (4007) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
            2023-09-17 14:35:06.498  - info: powerfox2.0 (4007) Terminated (NO_ERROR): Without reason
            2023-09-17 14:35:07.028  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
            • I
              ioNewbie @ioNewbie last edited by
              @ionewbie
              was ist mit den npm Errors, muss das gefixt werden und wie?
                @ionewbie sagte in Hilfe! js-controller und javascript Problem:
                Ja. Ich weiß nur noch nicht wie genau.
                iob update
                iob upgrade all
                sagt?
                • I
                  @thomas-braun iob update bringt das hier.
                  pi@iobroker:~ $ iob update
                  ich gehe gerade den zweiten Befehl durch (upgrade all), muss bei jedem Paket einzeln bestätigen (y).
                  Thomas Braun I 2 Replies Last reply Reply Quote 0
                    So soll das sein.
                    • I
                      @ionewbie ok, die sind jetzt alle durch, ohne Fehler, wenn ich das richtig verfolgt habe.
                      Willst du den kompletten output von Putty dazu?
                        Nö. Lieber nochmal
                        iob diag
                        • I
                          @thomas-braun immer noch die npm Errors. Ist da evtl jetzt erst mal ein Reboot fällig?
                          die ganzen Pakete, welche ich mit [y] zum Update bestätigt habe, werden immer noch als alt anzeigt.
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           14:55:24 up 31 min,  2 users,  load average: 0.20, 0.67, 0.63
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=43.8'C
                          volt=0.8625V
                                         Local time: Sun 2023-09-17 14:55:24 CEST
                                     Universal time: Sun 2023-09-17 12:55:24 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        453M        2.6G        0.0K        754M        3.3G
                          Swap:            99M          0B         99M
                          Total:          3.9G        453M        2.7G
                                   3794 M total memory
                                    453 M used memory
                                    533 M active memory
                                    508 M inactive memory
                                   2586 M free memory
                                     95 M buffer memory
                                    658 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          2.4G    /var/
                          1.8G    /var/log
                          323M    /var/cache
                          7.7M    /opt/iobroker/iobroker-data/objects.jsonl
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-17T12_55_31_632Z-debug-0.log
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
                          Objects and States
                          Objects:        2465
                          States:         1871
                          Pending Updates: 0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32697      5472/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34383      5658/io.web.0
                          udp        0      0 192.168.10.190:54580    0.0.0.0:*                           1001       34727      5712/io.knx.0
                          udp        0      0 192.168.10.190:34551    0.0.0.0:*                           1001       35645      5712/io.knx.0
                          udp        0      0 192.168.10.190:43032    0.0.0.0:*                           1001       34448      5712/io.knx.0
                          udp        0      0 192.168.10.190:57483    0.0.0.0:*                           1001       35376      5712/io.knx.0
                          2023-09-17 14:51:57.852  - info: history.0 (5750) enabled logging of shelly.0.SHSW-1#E89F6D85F71E#1.ext.temperatureC2 (Count=43), Alias=false
                          2023-09-17 14:51:57.852  - info: history.0 (5750) enabled logging of shelly.0.SHSW-1#E89F6D85F71E#1.ext.temperatureC3 (Count=44), Alias=false
                          2023-09-17 14:51:57.853  - info: history.0 (5750) enabled logging of knx.0.Zentral.Daten.Heizkreis_RL (Count=45), Alias=false
                          2023-09-17 14:51:57.853  - info: history.0 (5750) enabled logging of knx.0.Zentral.Daten.Heizkreis_VL (Count=46), Alias=false
                          2023-09-17 14:52:00.030  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5765
                          2023-09-17 14:52:02.163  - info: powerfox2.0 (5765) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                          2023-09-17 14:52:05.873  - info: powerfox2.0 (5765) Terminated (NO_ERROR): Without reason
                          2023-09-17 14:52:06.416  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                          2023-09-17 14:53:00.029  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5806
                          2023-09-17 14:53:01.991  - info: powerfox2.0 (5806) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                          2023-09-17 14:53:04.752  - info: powerfox2.0 (5806) Terminated (NO_ERROR): Without reason
                          2023-09-17 14:53:05.282  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                          2023-09-17 14:54:00.068  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5824
                          2023-09-17 14:54:02.011  - info: powerfox2.0 (5824) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                          2023-09-17 14:54:04.541  - info: powerfox2.0 (5824) Terminated (NO_ERROR): Without reason
                          2023-09-17 14:54:05.073  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                          2023-09-17 14:54:26.285  - info: admin.0 (5472) ==> Connected system.user.admin from ::ffff:192.168.10.67
                          2023-09-17 14:55:00.075  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5842
                          2023-09-17 14:55:02.079  - info: powerfox2.0 (5842) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                          2023-09-17 14:55:06.338  - info: powerfox2.0 (5842) Terminated (NO_ERROR): Without reason
                          2023-09-17 14:55:06.873  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                          2023-09-17 14:56:00.035  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 6097
                          2023-09-17 14:56:02.166  - info: powerfox2.0 (6097) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                          2023-09-17 14:56:06.098  - info: powerfox2.0 (6097) Terminated (NO_ERROR): Without reason
                          2023-09-17 14:56:06.639  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                            Dann schau da mal rein.
                            • I
                              @thomas-braun said in Hilfe! js-controller und javascript Problem:
                              dieses Log finde ich nicht. Es gibt nur diese hier:
                              pi@iobroker:~/.npm/_logs $ ls -ali
                              total 188
                              266656 drwxr-xr-x 2 pi pi   4096 Sep 17 14:55 .
                              266426 drwxr-xr-x 5 pi pi   4096 Sep 17 10:41 ..
                              266657 -rw-r--r-- 1 pi pi   2552 Sep  1  2022 2022-09-01T18_04_03_138Z-debug.log
                              266493 -rw-r--r-- 1 pi pi   1451 Sep 17 10:09 2023-09-17T08_09_18_724Z-debug-0.log
                              266498 -rw-r--r-- 1 pi pi   1491 Sep 17 10:09 2023-09-17T08_09_19_852Z-debug-0.log
                              268272 -rw-r--r-- 1 pi pi 142673 Sep 17 10:42 2023-09-17T08_41_41_026Z-debug-0.log
                              269827 -rw-r--r-- 1 pi pi   1548 Sep 17 10:42 2023-09-17T08_42_11_297Z-debug-0.log
                              270742 -rw-r--r-- 1 pi pi   1679 Sep 17 10:42 2023-09-17T08_42_13_793Z-debug-0.log
                              271160 -rw-r--r-- 1 pi pi   4060 Sep 17 10:43 2023-09-17T08_43_06_662Z-debug-0.log
                              268264 -rw-r--r-- 1 pi pi   1519 Sep 17 11:24 2023-09-17T09_24_42_119Z-debug-0.log
                              271161 -rw-r--r-- 1 pi pi   1557 Sep 17 11:24 2023-09-17T09_24_43_276Z-debug-0.log
                              271163 -rw-r--r-- 1 pi pi   1517 Sep 17 11:24 2023-09-17T09_24_44_442Z-debug-0.log
                              262153 -rw-r--r-- 1 pi pi   1818 Sep 17 14:55 2023-09-17T12_55_50_944Z-debug-0.log
                              • I
                                @ionewbie in dem jüngsten steht das hier drin:
                                pi@iobroker:~/.npm/_logs $ cat 2023-09-17T12_55_50_944Z-debug-0.log
                                0 verbose cli /usr/bin/node /usr/bin/npm
                                1 info using npm@9.6.7
                                2 info using node@v18.17.1
                                3 timing npm:load:whichnode Completed in 4ms
                                4 timing config:load:defaults Completed in 6ms
                                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
                                6 timing config:load:builtin Completed in 6ms
                                7 timing config:load:cli Completed in 6ms
                                8 timing config:load:env Completed in 1ms
                                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
                                10 timing config:load:project Completed in 8ms
                                11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
                                12 timing config:load:user Completed in 2ms
                                13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                                14 timing config:load:global Completed in 1ms
                                15 timing config:load:setEnvs Completed in 3ms
                                16 timing config:load Completed in 34ms
                                17 timing npm:load:configload Completed in 34ms
                                18 timing npm:load:mkdirpcache Completed in 0ms
                                19 timing npm:load:mkdirplogs Completed in 1ms
                                20 verbose title npm ls
                                21 verbose argv "ls"
                                22 timing npm:load:setTitle Completed in 4ms
                                23 timing config:load:flatten Completed in 10ms
                                24 timing npm:load:display Completed in 13ms
                                25 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2023-09-17T12_55_50_944Z-
                                26 verbose logfile /home/pi/.npm/_logs/2023-09-17T12_55_50_944Z-debug-0.log
                                27 timing npm:load:logFile Completed in 30ms
                                28 timing npm:load:timers Completed in 1ms
                                29 timing npm:load:configScope Completed in 0ms
                                30 timing npm:load Completed in 90ms
                                31 timing arborist:ctor Completed in 2ms
                                32 silly logfile start cleaning logs, removing 1 files
                                33 silly logfile done cleaning log files
                                34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.daikin-cloud
                                35 timing command:ls Completed in 4199ms
                                36 verbose exit 0
                                37 timing npm Completed in 4373ms
                                38 info ok
                                  @ionewbie
                                  Das log ist mit Sicherheit länger.
                                  • I
                                    @thomas-braun tatsächlich nein. ist ja auch von heute Mittag, die Upgrades sind höchstens eine Stunde her
                                    hm.
                                      Thomas Braun Most Active @ioNewbie last edited by Thomas Braun
                                      @ionewbie
                                      Dann schau per
                                      cd /opt/iobroker && npm ls -a
                                      an welcher Stelle im Tree die Meldungen auftauchen.
                                      • I
                                        @thomas-braun nicht sicher ob ich jetzt verstanden habe. Geht es um Identifikation des NPM Ordners? das wäre bei execa@5.1.1
                                        pi@iobroker:~ $ cd /opt/iobroker & npm ls -a
                                        [1] 2960
                                        pi@ /home/pi
                                        └─┬ iobroker.js-controller@5.0.12
                                          ├─┬ @alcalzone/esbuild-register@2.5.1-1
                                          │ ├── esbuild@0.11.23
                                          │ └── jsonc-parser@3.2.0
                                          ├─┬ @iobroker/db-objects-file@5.0.12
                                          │ ├─┬ @iobroker/db-base@5.0.12
                                          │ │ ├── @iobroker/js-controller-common@5.0.12 deduped
                                          │ │ ├── deep-clone@3.0.3 deduped
                                          │ │ ├── fs-extra@11.1.1 deduped
                                          │ │ └── respjs@4.2.0
                                          │ ├── @iobroker/db-objects-redis@5.0.12 deduped
                                          │ └── fs-extra@11.1.1 deduped
                                          ├─┬ @iobroker/db-objects-jsonl@5.0.12
                                          │ ├─┬ @alcalzone/jsonl-db@3.1.0
                                          │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                                          │ │ │ ├── graceful-fs@4.2.11 deduped
                                          │ │ │ ├── retry@0.12.0
                                          │ │ │ └── signal-exit@3.0.7
                                          │ │ ├─┬ alcalzone-shared@4.0.8
                                          │ │ │ └── debug@4.3.4 deduped
                                          │ │ └─┬ fs-extra@10.1.0
                                          │ │   ├── jsonfile@6.1.0 deduped
                                          │ │   └── universalify@2.0.0 deduped
                                          │ ├── @iobroker/db-base@5.0.12 deduped
                                          │ ├── @iobroker/db-objects-file@5.0.12 deduped
                                          ├─┬ @iobroker/db-objects-redis@5.0.12
                                          │ ├─┬ ioredis@4.28.5
                                          │ │ ├── cluster-key-slot@1.1.2
                                          │ │ ├── debug@4.3.4 deduped
                                          │ │ ├── denque@1.5.1
                                          │ │ ├── lodash.defaults@4.2.0
                                          │ │ ├── lodash.flatten@4.4.0
                                          │ │ ├── lodash.isarguments@3.1.0
                                          │ │ ├── p-map@2.1.0
                                          │ │ ├── redis-commands@1.7.0
                                          │ │ ├── redis-errors@1.2.0
                                          │ │ ├─┬ redis-parser@3.0.0
                                          │ │ │ └── redis-errors@1.2.0 deduped
                                          │ │ └── standard-as-callback@2.1.0
                                          │ ├─┬ mime-types@2.1.35
                                          │ │ └── mime-db@1.52.0
                                          │ ├─┬ node.extend@2.0.2
                                          │ │ ├─┬ has@1.0.3
                                          │ │ │ └── function-bind@1.1.1
                                          │ │ └── is@3.3.0
                                          │ └── semver@7.5.4 deduped
                                          ├─┬ @iobroker/db-states-file@5.0.12
                                          │ └── @iobroker/db-states-redis@5.0.12 deduped
                                          ├─┬ @iobroker/db-states-jsonl@5.0.12
                                          │ ├── @alcalzone/jsonl-db@3.1.0 deduped
                                          │ ├── @iobroker/db-states-file@5.0.12 deduped
                                          ├─┬ @iobroker/db-states-redis@5.0.12
                                          │ └── ioredis@4.28.5 deduped
                                          ├─┬ @iobroker/js-controller-adapter@5.0.12
                                          │ ├─┬ @alcalzone/pak@0.8.1
                                          │ │ ├─┬ axios@0.26.1
                                          │ │ │ └── follow-redirects@1.15.2 deduped
                                          │ │ ├─┬ execa@5.1.1
                                          │ │ │ ├─┬ cross-spawn@7.0.3
                                          │ │ │ │ ├── path-key@3.1.1
                                          │ │ │ │ ├─┬ shebang-command@2.0.0
                                          │ │ │ │ │ └── shebang-regex@3.0.0
                                          │ │ │ │ └─┬ which@2.0.2
                                          │ │ │ │   └── isexe@2.0.0
                                          │ │ │ ├── get-stream@6.0.1
                                          │ │ │ ├── human-signals@2.1.0
                                          │ │ │ ├── is-stream@2.0.1 deduped
                                          │ │ │ ├── merge-stream@2.0.0
                                          │ │ │ ├─┬ npm-run-path@4.0.1
                                          │ │ │ │ └── path-key@3.1.1 deduped
                                          │ │ │ ├─┬ onetime@5.1.2
                                          │ │ │ │ └── mimic-fn@2.1.0
                                          │ │ │ ├── signal-exit@3.0.7 deduped
                                          │ │ │ └── strip-final-newline@2.0.0
                                          │ ├── @iobroker/db-objects-jsonl@5.0.12 deduped
                                          │ ├── @iobroker/db-states-jsonl@5.0.12 deduped
                                          │ ├── @iobroker/db-states-redis@5.0.12 deduped
                                          │ ├── @iobroker/js-controller-common-db@5.0.12 deduped
                                          │ ├── @iobroker/plugin-base@1.2.1 deduped
                                          │ ├── @iobroker/plugin-sentry@1.2.1 deduped
                                          │ ├── jsonwebtoken@9.0.2 deduped
                                          │ ├── node-schedule@2.1.1 deduped
                                          │ ├── node.extend@2.0.2 deduped
                                          │ ├── pidusage@3.0.2 deduped
                                          │ ├── readline@1.3.0
                                          ├─┬ @iobroker/js-controller-cli@5.0.12
                                          │ ├── axios@1.5.0 deduped
                                          │ ├─┬ chokidar@3.5.3
                                          │ │ ├─┬ anymatch@3.1.3
                                          │ │ │ ├── normalize-path@3.0.0 deduped
                                          │ │ │ └── picomatch@2.3.1
                                          │ │ ├─┬ braces@3.0.2
                                          │ │ │ └─┬ fill-range@7.0.1
                                          │ │ │   └─┬ to-regex-range@5.0.1
                                          │ │ │     └── is-number@7.0.0
                                          │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@~2.3.2
                                          │ │ ├─┬ glob-parent@5.1.2
                                          │ │ │ └── is-glob@4.0.3 deduped
                                          │ │ ├─┬ is-binary-path@2.1.0
                                          │ │ │ └── binary-extensions@2.2.0
                                          │ │ ├─┬ is-glob@4.0.3
                                          │ │ │ └── is-extglob@2.1.1
                                          │ │ └─┬ readdirp@3.6.0
                                          │ │   └── picomatch@2.3.1 deduped
                                          │ ├── daemonize2@0.4.2 deduped
                                          │ ├─┬ event-stream@4.0.1
                                          │ │ ├── duplexer@0.1.2
                                          │ │ ├── from@0.1.7
                                          │ │ ├── map-stream@0.0.7
                                          │ │ ├─┬ pause-stream@0.0.11
                                          │ │ │ └── through@2.3.8 deduped
                                          │ │ ├─┬ split@1.0.1
                                          │ │ ├─┬ stream-combiner@0.2.2
                                          │ │ │ ├── duplexer@0.1.2 deduped
                                          │ ├── mime-types@2.1.35 deduped
                                          │ ├── readline-sync@1.4.10 deduped
                                          │ ├── semver@7.5.4 deduped
                                          │ └─┬ yargs@17.7.2
                                          │   ├─┬ cliui@8.0.1
                                          │   │ ├── string-width@4.2.3 deduped
                                          │   │ ├─┬ strip-ansi@6.0.1
                                          │   │ │ └── ansi-regex@5.0.1
                                          │   │ └─┬ wrap-ansi@7.0.0
                                          │   │   ├─┬ ansi-styles@4.3.0
                                          │   │   │ └─┬ color-convert@2.0.1
                                          │   │   │   └── color-name@1.1.4
                                          │   │   └── strip-ansi@6.0.1 deduped
                                          │   ├── escalade@3.1.1
                                          │   ├── get-caller-file@2.0.5
                                          │   ├── require-directory@2.1.1
                                          │   ├─┬ string-width@4.2.3
                                          │   │ ├── emoji-regex@8.0.0
                                          │   │ ├── is-fullwidth-code-point@3.0.0
                                          │   ├── y18n@5.0.8
                                          │   └── yargs-parser@21.1.1
                                          ├─┬ @iobroker/js-controller-common-db@5.0.12
                                          │ ├─┬ winston-seq-updated@1.0.4
                                          │ │ ├── seq-logging@0.4.6
                                          │ │ └── winston-transport@4.5.0 deduped
                                          │ └─┬ winston-syslog@2.7.0
                                          │   ├── glossy@0.1.7
                                          │   ├─┬ unix-dgram@2.0.6
                                          │   │ ├─┬ bindings@1.5.0
                                          │   │ │ └── file-uri-to-path@1.0.0
                                          │   │ └── nan@2.18.0 deduped
                                          │   └── winston@3.10.0 deduped
                                          ├─┬ @iobroker/js-controller-common@5.0.12
                                          │ ├── @alcalzone/pak@0.8.1 deduped
                                          │ ├─┬ @datalust/winston-seq@1.0.2
                                          │ │ ├── seq-logging@1.1.2
                                          │ │ ├── winston-transport@4.5.0 deduped
                                          │ │ └── winston@3.10.0 deduped
                                          │ ├── ci-info@3.8.0
                                          │ ├─┬ diskusage@1.2.0
                                          │ │ ├── es6-promise@4.2.8
                                          │ │ └── nan@2.18.0
                                          │ ├── event-stream@4.0.1 deduped
                                          │ ├── node-forge@1.3.1
                                          │ ├── promisify-child-process@4.1.2 deduped
                                          │ ├── readline@1.3.0 deduped
                                          │ ├── triple-beam@1.4.1
                                          │ ├─┬ winston-daily-rotate-file@4.7.1
                                          │ │ ├─┬ file-stream-rotator@0.6.1
                                          │ │ │ └── moment@2.29.4
                                          │ │ ├── object-hash@2.2.0
                                          │ │ ├── triple-beam@1.4.1 deduped
                                          │ ├── winston-syslog@2.7.0 deduped
                                          │ ├─┬ winston-transport@4.5.0
                                          │ │ ├─┬ logform@2.5.1
                                          │ │ │ ├── @colors/colors@1.5.0 deduped
                                          │ │ │ ├── @types/triple-beam@1.3.3
                                          │ │ │ ├── fecha@4.2.3
                                          │ │ │ ├── ms@2.1.2 deduped
                                          │ │ │ ├── safe-stable-stringify@2.4.3 deduped
                                          │ │ │ └── triple-beam@1.4.1 deduped
                                          │ │ ├─┬ readable-stream@3.6.2
                                          │ │ │ ├── inherits@2.0.4 deduped
                                          │ │ │ ├── string_decoder@1.1.1 deduped
                                          │ │ │ └── util-deprecate@1.0.2 deduped
                                          │ └─┬ winston@3.10.0
                                          │   ├─┬ @dabh/diagnostics@2.0.3
                                          │   │ ├─┬ colorspace@1.1.4
                                          │   │ │ ├─┬ color@3.2.1
                                          │   │ │ │ ├─┬ color-convert@1.9.3
                                          │   │ │ │ │ └── color-name@1.1.3
                                          │   │ │ │ └─┬ color-string@1.9.1
                                          │   │ │ │   ├── color-name@1.1.3 deduped
                                          │   │ │ │   └─┬ simple-swizzle@0.2.2
                                          │   │ │ │     └── is-arrayish@0.3.2
                                          │   │ │ └── text-hex@1.0.0
                                          │   │ ├── enabled@2.0.0
                                          │   │ └── kuler@2.0.0
                                          │   ├── async@3.2.3 deduped
                                          │   ├── logform@2.5.1 deduped
                                          │   ├─┬ one-time@1.0.0
                                          │   │ └── fn.name@1.1.0
                                          │   ├── stack-trace@0.0.10
                                          ├─┬ @iobroker/plugin-sentry@1.2.1
                                          │ ├─┬ @sentry/integrations@7.69.0
                                          │ │ ├── @sentry/types@7.69.0
                                          │ │ ├─┬ @sentry/utils@7.69.0
                                          │ │ │ ├── @sentry/types@7.69.0 deduped
                                          │ │ │ └── tslib@2.6.2 deduped
                                          │ │ ├─┬ localforage@1.10.0
                                          │ │ │ └─┬ lie@3.1.1
                                          │ │ │   └── immediate@3.0.6 deduped
                                          │ │ └── tslib@2.6.2
                                          │ ├─┬ @sentry/node@7.69.0
                                          │ │ ├─┬ @sentry-internal/tracing@7.69.0
                                          │ │ │ ├── @sentry/core@7.69.0 deduped
                                          │ │ │ ├── @sentry/utils@7.69.0 deduped
                                          │ │ ├─┬ @sentry/core@7.69.0
                                          │ │ ├── cookie@0.4.2
                                          │ │ ├─┬ https-proxy-agent@5.0.1
                                          │ │ │ ├─┬ agent-base@6.0.2
                                          │ │ │ │ └── debug@4.3.4 deduped
                                          │ │ ├── lru_map@0.3.3
                                          │ └─┬ source-map-support@0.5.21
                                          │   ├── buffer-from@1.1.2
                                          │   └── source-map@0.6.1
                                          ├─┬ axios@1.5.0
                                          │ ├── follow-redirects@1.15.2
                                          │ ├─┬ form-data@4.0.0
                                          │ │ ├── asynckit@0.4.0
                                          │ │ ├─┬ combined-stream@1.0.8
                                          │ │ │ └── delayed-stream@1.0.0
                                          │ │ └── mime-types@2.1.35 deduped
                                          │ └── proxy-from-env@1.1.0
                                          ├─┬ debug@4.3.4
                                          │ └── ms@2.1.2
                                          ├─┬ decache@4.6.2
                                          │ └── callsite@1.0.0
                                          ├─┬ fs-extra@11.1.1
                                          │ ├─┬ jsonfile@6.1.0
                                          ├─┬ greenlock-express@4.0.3
                                          │ ├─┬ @root/greenlock-express@4.0.4
                                          │ │ ├── @root/greenlock@4.0.5 deduped
                                          │ │ └── redirect-https@1.3.1 deduped
                                          │ ├─┬ @root/greenlock@4.0.5
                                          │ │ ├── @greenlock/manager@3.1.0 deduped
                                          │ │ ├── @root/acme@3.1.0 deduped
                                          │ │ ├── @root/csr@0.8.1 deduped
                                          │ │ ├─┬ @root/keypairs@0.10.3
                                          │ │ │ ├── @root/encoding@1.0.1 deduped
                                          │ │ │ ├── @root/pem@1.0.4 deduped
                                          │ │ │ └── @root/x509@0.7.2 deduped
                                          │ │ ├── @root/mkdirp@1.0.0 deduped
                                          │ │ ├── @root/request@1.9.2 deduped
                                          │ │ ├── acme-http-01-standalone@3.0.5 deduped
                                          │ │ ├── cert-info@1.5.1 deduped
                                          │ │ ├── greenlock-store-fs@3.2.2 deduped
                                          │ │ └── safe-replace@1.1.0 deduped
                                          │ └─┬ redirect-https@1.3.1
                                          │   └── escape-html@1.0.3
                                          ├─┬ greenlock@4.0.4
                                          │ ├─┬ @greenlock/manager@3.1.0
                                          │ │ └─┬ greenlock-manager-fs@3.1.1
                                          │ ├─┬ @root/acme@3.1.0
                                          │ │ └─┬ @root/x509@0.7.2
                                          │ │   ├── @root/asn1@1.0.0 deduped
                                          │ │   └── @root/encoding@1.0.1 deduped
                                          │ ├─┬ @root/csr@0.8.1
                                          │ │ ├─┬ @root/asn1@1.0.0
                                          │ │ │ └── @root/encoding@1.0.1 deduped
                                          │ ├─┬ @root/keypairs@0.9.0
                                          │ ├─┬ greenlock-store-fs@3.2.2
                                          ├─┬ jsonwebtoken@9.0.2
                                          │ ├─┬ jws@3.2.2
                                          │ │ ├─┬ jwa@1.4.1
                                          │ │ │ ├── buffer-equal-constant-time@1.0.1
                                          │ │ │ ├─┬ ecdsa-sig-formatter@1.0.11
                                          │ │ │ │ └── safe-buffer@5.2.1 deduped
                                          │ ├── lodash.includes@4.3.0
                                          │ ├── lodash.isboolean@3.0.3
                                          │ ├── lodash.isinteger@4.0.4
                                          │ ├── lodash.isnumber@3.0.3
                                          │ ├── lodash.isplainobject@4.0.6
                                          │ ├── lodash.isstring@4.0.1
                                          │ ├── lodash.once@4.1.1
                                          ├─┬ jszip@3.10.1
                                          │ ├─┬ lie@3.3.0
                                          │ ├── pako@1.0.11
                                          │ ├─┬ readable-stream@2.3.8
                                          │ │ ├── core-util-is@1.0.3
                                          │ │ ├── isarray@1.0.0
                                          │ │ ├── process-nextick-args@2.0.1
                                          │ │ ├── safe-buffer@5.1.2
                                          │ │ ├─┬ string_decoder@1.1.1
                                          │ │ │ └── safe-buffer@5.1.2
                                          │ └── setimmediate@1.0.5
                                          ├─┬ le-acme-core@2.1.4
                                          │ ├─┬ request@2.88.2
                                          │ │ ├── aws-sign2@0.7.0
                                          │ │ ├── aws4@1.12.0
                                          │ │ ├── caseless@0.12.0
                                          │ │ ├── combined-stream@1.0.8 deduped
                                          │ │ ├── extend@3.0.2
                                          │ │ ├── forever-agent@0.6.1
                                          │ │ ├─┬ form-data@2.3.3
                                          │ │ │ ├── asynckit@0.4.0 deduped
                                          │ │ │ ├── combined-stream@1.0.8 deduped
                                          │ │ │ └── mime-types@2.1.35 deduped
                                          │ │ ├─┬ har-validator@5.1.5
                                          │ │ │ ├─┬ ajv@6.12.6
                                          │ │ │ │ ├── fast-deep-equal@3.1.3
                                          │ │ │ │ ├── fast-json-stable-stringify@2.1.0
                                          │ │ │ │ ├── json-schema-traverse@0.4.1
                                          │ │ │ │ └─┬ uri-js@4.4.1
                                          │ │ │ │   └── punycode@2.3.0 deduped
                                          │ │ │ └── har-schema@2.0.0
                                          │ │ ├─┬ http-signature@1.2.0
                                          │ │ │ ├── assert-plus@1.0.0
                                          │ │ │ ├─┬ jsprim@1.4.2
                                          │ │ │ │ ├── assert-plus@1.0.0 deduped
                                          │ │ │ │ ├── extsprintf@1.3.0
                                          │ │ │ │ ├── json-schema@0.4.0
                                          │ │ │ │ └─┬ verror@1.10.0
                                          │ │ │ │   ├── core-util-is@1.0.2
                                          │ │ │ │   └── extsprintf@1.3.0 deduped
                                          │ │ │ └─┬ sshpk@1.17.0
                                          │ │ │   ├─┬ asn1@0.2.6
                                          │ │ │   │ └── safer-buffer@2.1.2 deduped
                                          │ │ │   ├─┬ bcrypt-pbkdf@1.0.2
                                          │ │ │   │ └── tweetnacl@0.14.5 deduped
                                          │ │ │   ├─┬ dashdash@1.14.1
                                          │ │ │   │ └── assert-plus@1.0.0 deduped
                                          │ │ │   ├─┬ ecc-jsbn@0.1.2
                                          │ │ │   │ ├── jsbn@0.1.1 deduped
                                          │ │ │   ├─┬ getpass@0.1.7
                                          │ │ │   ├── safer-buffer@2.1.2
                                          │ │ ├── is-typedarray@1.0.0
                                          │ │ ├── isstream@0.1.2
                                          │ │ ├── json-stringify-safe@5.0.1
                                          │ │ ├── mime-types@2.1.35 deduped
                                          │ │ ├── oauth-sign@0.9.0
                                          │ │ ├── performance-now@2.1.0
                                          │ │ ├── qs@6.5.3
                                          │ │ ├── safe-buffer@5.2.1 deduped
                                          │ │ ├─┬ tough-cookie@2.5.0
                                          │ │ │ ├── psl@1.9.0
                                          │ │ ├─┬ tunnel-agent@0.6.0
                                          │ │ └── uuid@3.4.0
                                          │ └─┬ rsa-compat@1.9.4
                                          │   ├─┬ keypairs@1.2.14
                                          │   │ ├── eckles@1.4.1
                                          │   │ └── rasha@1.2.5
                                          │   ├── node-forge@0.7.6
                                          │   └─┬ ursa-optional@0.9.10
                                          │     ├── bindings@1.5.0 deduped
                                          ├─┬ le-challenge-fs@2.0.9
                                          │ └── @root/mkdirp@1.0.0 deduped
                                          ├── le-sni-auto@2.1.9
                                          ├─┬ loadavg-windows@1.1.1
                                          │ └── weak-daemon@1.0.3
                                          ├─┬ node-schedule@2.1.1
                                          │ ├─┬ cron-parser@4.9.0
                                          │ │ └── luxon@3.4.3
                                          │ ├── long-timeout@0.1.1
                                          │ └── sorted-array-functions@1.3.0
                                          ├─┬ pidusage@3.0.2
                                          ├─┬ prompt@1.3.0
                                          │ ├── async@3.2.3
                                          │ ├─┬ read@1.0.7
                                          │ │ └── mute-stream@0.0.8
                                          │ ├── revalidator@0.1.8
                                          │ └─┬ winston@2.4.7
                                          │   ├─┬ async@2.6.4
                                          │   │ └── lodash@4.17.21
                                          │   ├── colors@1.0.3
                                          │   ├── cycle@1.0.3
                                          │   ├── eyes@0.1.8
                                          │   ├── isstream@0.1.2 deduped
                                          │   └── stack-trace@0.0.10 deduped
                                          ├─┬ semver@7.5.4
                                          │ └─┬ lru-cache@6.0.0
                                          │   └── yallist@4.0.0 deduped
                                          └─┬ tar@6.2.0
                                            ├── chownr@2.0.0
                                            ├─┬ fs-minipass@2.1.0
                                            │ └─┬ minipass@3.3.6
                                            ├── minipass@5.0.0
                                            ├─┬ minizlib@2.1.2
                                            │ ├─┬ minipass@3.3.6
                                            │ │ └── yallist@4.0.0 deduped
                                            ├── mkdirp@1.0.4
                                            └── yallist@4.0.0
                                        [1]+  Done                    cd /opt/iobroker
                                          @ionewbie
                                          Sorry, mein Fehler.
                                          Aber dadurch haben wir eine Parallel-Installation in /home/pi gefunden.
                                          Du hast also irendwie da was 'daneben' geworfen.
                                          In den Heimverzeichnissen der user muss das so aussehen (auf meiner Kiste):
                                          echad@chet:~ $ npm ls -a
                                          /home/echad
                                          └── (empty)
                                          echad@chet:~ $ cd /home/iobroker/
                                          echad@chet:/home/iobroker $ npm ls -a
                                          /home/iobroker
                                          └── (empty)
                                          • I
                                            @thomas-braun hm, keine Ahnung, zumindest nicht bewußt.
                                            Was ist jetzt als nächstes dran? der js-controller ist ja immer noch auf altem Stand
                                            5923
