    4. Zigbee Geräte fehlen nach Upgrade auf JS-Controller 5.0
      peterredl last edited by
      Ich hoffe, das ist die full Version...
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      Static hostname: q4os-desktop
      Icon name: computer-desktop
      Chassis: desktop
      Machine ID: 163dfadd781c44cd94d7a397cdd870ff
      Boot ID: aec401992f534ee8ad15c09fdff5e2d4
      Operating System: Debian GNU/Linux 11 (bullseye)
      Kernel: Linux 5.10.0-21-amd64
      Architecture: x86-64
      model name : Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
      Docker : false
      Virtualization : none
      Kernel : x86_64
      Userland : amd64
      Systemuptime and Load:
      14:33:42 up 1:41, 1 user, load average: 1.26, 1.06, 1.22
      CPU threads: 4
      *** Time and Time Zones ***
      Local time: Sun 2023-09-17 14:33:42 CEST
      Universal time: Sun 2023-09-17 12:33:42 UTC
      RTC time: Sun 2023-09-17 12:33:42
      Time zone: Europe/Vienna (CEST, +0200)
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      peter
      /home/peter
      peter dialout cdrom floppy sudo audio dip video plugdev users netdev lpadmin bluetooth scanner iobroker
      *** X-Server-Setup ***
      X-Server: true
      Desktop: trinity
      Terminal: x11
      Boot Target: graphical.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 15G 4.3G 9.0G 289M 2.7G 11G
      Swap: 9.2G 0B 9.2G
      Total: 25G 4.3G 18G
          15893 M total memory
           4286 M used memory
            649 M active memory
           5612 M inactive memory
           8956 M free memory
            181 M buffer memory
           2468 M swap cache
           9167 M total swap
              0 M used swap
           9167 M free swap
      *** FILESYSTEM ***
      df: /run/user/1000/doc: Operation not permitted
      Filesystem Type Size Used Avail Use% Mounted on
      udev devtmpfs 7.8G 0 7.8G 0% /dev
      tmpfs tmpfs 1.6G 2.8M 1.6G 1% /run
      /dev/mapper/q4os--desktop--vg-root ext4 91G 25G 62G 29% /
      tmpfs tmpfs 7.8G 56M 7.8G 1% /dev/shm
      tmpfs tmpfs 5.0M 8.0K 5.0M 1% /run/lock
      /dev/nvme0n1p1 ext2 470M 366M 80M 83% /boot
      tmpfs tmpfs 1.6G 36K 1.6G 1% /run/user/1000
      [Sun Sep 17 12:51:57 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Sep 17 12:51:57 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
      [Sun Sep 17 12:51:58 2023] EXT4-fs (nvme0n1p1): mounting ext2 file system using the ext4 subsystem
      [Sun Sep 17 12:51:58 2023] EXT4-fs (nvme0n1p1): mounted filesystem without journal. Opts: (null)
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mapper/q4os--desktop--vg-root ext4 rw,relatime,errors=remount-ro
      |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot /dev/nvme0n1p1 ext2 rw,relatime
      /var:
      6.3G /var/
      4.2G /var/log/journal/163dfadd781c44cd94d7a397cdd870ff
      4.2G /var/log
      1.8G /var/lib
      Archived and active journals take up 160.0M in the file system.
      /opt/iobroker/backups:
      89M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.4G /opt/iobroker/iobroker-data/
      2.0G /opt/iobroker/iobroker-data/history
      202M /opt/iobroker/iobroker-data/files
      167M /opt/iobroker/iobroker-data/backup-objects
      52M /opt/iobroker/iobroker-data/files/javascript.admin
      35M /opt/iobroker/iobroker-data/states.jsonl
      23M /opt/iobroker/iobroker-data/objects.jsonl
      21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      16M /opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs v16.19.1
      /usr/bin/node v16.19.1
      /usr/bin/npm 8.19.3
      /usr/bin/npx 8.19.3
      nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
      16.20.2-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
      *** 16.19.1-deb-1nodesource1 100
      100 /var/lib/dpkg/status
      12.22.12~dfsg-1~deb11u4 500
      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      12.22.12~dfsg-1~deb11u3 500
      500 http://ftp.at.debian.org/debian bullseye/main amd64 Packages
      500 http://ftp.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: homebridge-ewelink@^11.0.2, required by iobroker.ham@5.3.1
      npm ERR! /home/peter/.npm/_logs/2023-09-17T12_33_51_450Z-debug-0.log
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication: enabled
      Persistent activation: disabled
      Objects: jsonl on 127.0.0.1
      States: jsonl on 127.0.0.1
      Core adapters versions
      js-controller: 5.0.12
      admin: 6.8.0
      javascript: 7.1.4
      Adapters from github: 0
      Adapter State
      • system.adapter.admin.0 : admin : q4os-desktop - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.alexa2.0 : alexa2 : q4os-desktop - enabled
      • system.adapter.backitup.0 : backitup : q4os-desktop - enabled
      • system.adapter.bosch-ebike.0 : bosch-ebike : q4os-desktop - enabled
      • system.adapter.broadlink2.0 : broadlink2 : q4os-desktop - enabled
        system.adapter.cloud.0 : cloud : q4os-desktop - disabled
        system.adapter.daswetter.0 : daswetter : q4os-desktop - enabled
      • system.adapter.device-reminder.0 : device-reminder : q4os-desktop - enabled
      • system.adapter.device-watcher.0 : device-watcher : q4os-desktop - enabled
      • system.adapter.discovery.0 : discovery : q4os-desktop - enabled
      • system.adapter.fb-checkpresence.0 : fb-checkpresence : q4os-desktop - enabled
        system.adapter.flot.0 : flot : q4os-desktop - enabled
      • system.adapter.fronius.0 : fronius : q4os-desktop - enabled
        system.adapter.fuelpricemonitor.0 : fuelpricemonitor : q4os-desktop - enabled
      • system.adapter.go-e.0 : go-e : q4os-desktop - enabled
      • system.adapter.ham.0 : ham : q4os-desktop - enabled
      • system.adapter.history.0 : history : q4os-desktop - enabled
      • system.adapter.hmip.0 : hmip : q4os-desktop - enabled
      • system.adapter.hs100.0 : hs100 : q4os-desktop - enabled
        system.adapter.info.0 : info : q4os-desktop - enabled
      • system.adapter.iot.0 : iot : q4os-desktop - enabled
      • system.adapter.javascript.0 : javascript : q4os-desktop - enabled
      • system.adapter.mercedesme.0 : mercedesme : q4os-desktop - enabled
      • system.adapter.mihome.0 : mihome : q4os-desktop - enabled, port: 9898, bind: 0.0.0.0
      • system.adapter.mqtt.0 : mqtt : q4os-desktop - enabled, port: 1886, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0 : netatmo-crawler : q4os-desktop - enabled
      • system.adapter.netatmo.0 : netatmo : q4os-desktop - enabled
      • system.adapter.opendtu.0 : opendtu : q4os-desktop - enabled
      • system.adapter.shelly.0 : shelly : q4os-desktop - enabled, port: 1882, bind: 0.0.0.0
      • system.adapter.sonoff.0 : sonoff : q4os-desktop - enabled, port: 1884, bind: 0.0.0.0
      • system.adapter.sureflap.0 : sureflap : q4os-desktop - enabled
      • system.adapter.telegram.0 : telegram : q4os-desktop - enabled, port: 8443, bind: 0.0.0.0
      • system.adapter.tuya.0 : tuya : q4os-desktop - enabled
        system.adapter.vis-hqwidgets.0 : vis-hqwidgets : q4os-desktop - enabled
      • system.adapter.vis-inventwo.0 : vis-inventwo : q4os-desktop - enabled
        system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : q4os-desktop - enabled
        system.adapter.vis-timeandweather.0 : vis-timeandweather : q4os-desktop - enabled
        system.adapter.vis-weather.0 : vis-weather : q4os-desktop - enabled
        system.adapter.vis.0 : vis : q4os-desktop - enabled
      • system.adapter.web.0 : web : q4os-desktop - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      • system.adapter.zigbee.0 : zigbee : q4os-desktop - enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      • instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter "admin" : 6.8.0 , installed 6.8.0
      Adapter "alexa2" : 3.24.1 , installed 3.24.1
      Adapter "backitup" : 2.6.23 , installed 2.6.23
      Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3
      Adapter "broadlink2" : 2.1.5 , installed 2.1.5
      Adapter "cloud" : 4.4.1 , installed 4.4.1
      Adapter "daswetter" : 3.1.10 , installed 3.1.10
      Adapter "device-reminder": 1.2.9 , installed 1.2.9
      Adapter "device-watcher": 2.9.3 , installed 2.9.3
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter "flot" : 1.12.0 , installed 1.12.0
      Adapter "fronius" : 1.1.3 , installed 1.1.3
      Adapter "fuelpricemonitor": 0.3.6 , installed 0.3.6
      Adapter "go-e" : 1.0.27 , installed 1.0.27
      Adapter "ham" : 5.3.1 , installed 5.3.1
      Adapter "history" : 2.2.6 , installed 2.2.6
      Adapter "hmip" : 1.20.0 , installed 1.20.0
      Adapter "hs100" : 2.1.2 , installed 2.1.2
      Adapter "info" : 1.9.26 , installed 1.9.26
      Adapter "iot" : 1.14.5 , installed 1.14.5
      Adapter "javascript" : 7.1.4 , installed 7.1.4
      Controller "js-controller": 5.0.12 , installed 5.0.12
      Adapter "mercedesme" : 0.1.1 , installed 0.1.1
      Adapter "mihome" : 1.4.0 , installed 1.4.0
      Adapter "mqtt" : 4.1.1 , installed 4.1.1
      Adapter "netatmo" : 3.1.0 , installed 3.1.0
      Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
      Adapter "opendtu" : 0.1.7 , installed 0.1.7
      Adapter "shelly" : 6.4.1 , installed 6.4.1
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.5.5 , installed 6.5.5
      Adapter "sonoff" : 2.5.3 , installed 2.5.3
      Adapter "sureflap" : 1.2.0 , installed 1.2.0
      Adapter "telegram" : 1.16.0 , installed 1.16.0
      Adapter "tuya" : 3.14.2 , installed 3.14.2
      Adapter "vis" : 1.4.16 , installed 1.4.16
      Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
      Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
      Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
      Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
      Adapter "vis-weather" : 2.5.6 , installed 2.5.6
      Adapter "web" : 6.1.2 , installed 6.1.2
      Adapter "ws" : 2.5.5 , installed 2.5.5
      Adapter "zigbee" : 1.8.23 , installed 1.8.23
      Objects and States
      Objects: 27363
      States: 20597
      E: Failed to fetch http://ppa.launchpad.net/morphis/anbox-support/ubuntu/dists/jammy/InRelease 403 Forbidden [IP: 185.125.190.52 80]
      E: The repository 'http://ppa.launchpad.net/morphis/anbox-support/ubuntu jammy InRelease' is not signed.
      E: The repository 'http://security.debian.org bullseye/updates Release' does not have a Release file.
      Pending Updates: 203
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 19753 1264/exim4
      tcp 0 0 127.0.0.1:1883 0.0.0.0:* LISTEN 114 19499 662/mosquitto
      tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 22616 1601/io.sonoff.0
      tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 15224 986/smbd
      tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 24947 2158/io.mqtt.0
      tcp 0 0 127.0.0.1:3551 0.0.0.0:* LISTEN 0 20164 931/apcupsd
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 20811 633/iobroker.js-con
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 20788 633/iobroker.js-con
      tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 15225 986/smbd
      tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 9850 1/init
      tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 20497 632/cupsd
      tcp6 0 0 ::1:25 :::* LISTEN 0 19754 1264/exim4
      tcp6 0 0 ::1:1883 :::* LISTEN 114 19500 662/mosquitto
      tcp6 0 0 :::445 :::* LISTEN 0 15222 986/smbd
      tcp6 0 0 :::139 :::* LISTEN 0 15223 986/smbd
      tcp6 0 0 :::111 :::* LISTEN 0 9854 1/init
      tcp6 0 0 :::8081 :::* LISTEN 1001 20981 1342/io.admin.0
      tcp6 0 0 :::8082 :::* LISTEN 1001 56228 5884/io.web.0
      tcp6 0 0 :::6547 :::* LISTEN 0 19234 668/java
      tcp6 0 0 ::1:631 :::* LISTEN 0 20496 632/cupsd
      udp 0 0 0.0.0.0:45081 0.0.0.0:* 106 18261 566/avahi-daemon: r
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 26664 2102/io.ham.0
      udp 0 0 224.0.0.251:5353 0.0.0.0:* 1000 23241 1657/chrome
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 106 18259 566/avahi-daemon: r
      udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 22575 1586/io.shelly.0
      udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 21162 1616/io.tuya.0
      udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 21163 1616/io.tuya.0
      udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 25907 2417/io.broadlink2.
      udp 0 0 0.0.0.0:56606 0.0.0.0:* 1001 27109 2417/io.broadlink2.
      udp 0 0 0.0.0.0:111 0.0.0.0:* 0 9851 1/init
      udp 0 0 192.168.2.255:137 0.0.0.0:* 0 18964 895/nmbd
      udp 0 0 192.168.2.222:137 0.0.0.0:* 0 18963 895/nmbd
      udp 0 0 0.0.0.0:137 0.0.0.0:* 0 18950 895/nmbd
      udp 0 0 192.168.2.255:138 0.0.0.0:* 0 18966 895/nmbd
      udp 0 0 192.168.2.222:138 0.0.0.0:* 0 18965 895/nmbd
      udp 0 0 0.0.0.0:138 0.0.0.0:* 0 18951 895/nmbd
      udp 0 0 0.0.0.0:631 0.0.0.0:* 0 20516 743/cups-browsed
      udp 0 0 0.0.0.0:9898 0.0.0.0:* 1001 23354 2147/io.mihome.0
      udp 0 0 0.0.0.0:43843 0.0.0.0:* 1001 25293 2417/io.broadlink2.
      udp6 0 0 :::5353 :::* 106 18260 566/avahi-daemon: r
      udp6 0 0 :::46479 :::* 0 19222 668/java
      udp6 0 0 :::111 :::* 0 9857 1/init
      udp6 0 0 :::3052 :::* 0 20869 668/java
      udp6 0 0 :::60662 :::* 106 18262 566/avahi-daemon: r
      2023-09-17 14:30:00.036 - info: host.q4os-desktop instance system.adapter.netatmo-crawler.0 started with pid 8970
      2023-09-17 14:30:01.380 - info: netatmo-crawler.0 (8970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v16.19.1, js-controller: 5.0.12
      2023-09-17 14:30:01.456 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:53:39:f8
      2023-09-17 14:30:01.804 - warn: netatmo-crawler.0 (8970) Could not work with station 1 - Message: Error: undefined is not a valid state value
      2023-09-17 14:30:01.807 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:7f:96:be
      2023-09-17 14:30:02.094 - warn: netatmo-crawler.0 (8970) Could not work with station 2 - Message: Error: undefined is not a valid state value
      2023-09-17 14:30:02.095 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:27:ac:9a
      2023-09-17 14:30:02.394 - warn: netatmo-crawler.0 (8970) Could not work with station 3 - Message: Error: undefined is not a valid state value
      2023-09-17 14:30:02.397 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:96:a4:36
      2023-09-17 14:30:03.866 - info: netatmo-crawler.0 (8970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2023-09-17 14:30:04.399 - info: host.q4os-desktop instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-17 14:33:11.113 - info: ham.0 (2102) stateChange ham.0.Messsteckdose.Messsteckdose-History.S2R1 {"val":"uLYLAAAAAADPcqsqAQ4BAgXADwAAAAAAAAAAAQE=","ack":true,"ts":1694953991111,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991111}
      2023-09-17 14:33:11.154 - info: ham.0 (2102) stateChange ham.0.Device3c65fe-Sonoff-Schalter.Device3c65fe-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD+ENAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.155 - info: ham.0 (2102) stateChange ham.0.S26Hauseingang.S26Hauseingang-History.S2R1 {"val":"IjF+AQAAAABl+DgpAQ4BwA/AD7mTAAAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.157 - info: ham.0 (2102) stateChange ham.0.Abstellraum.Abstellraum-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/AD6CNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.161 - info: ham.0 (2102) stateChange ham.0.Bau-WC-Licht.Bau-WC-Licht-History.S2R1 {"val":"NjGIAgAAAABR+C4oAQ4BwA/ADxoDAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.161 - info: ham.0 (2102) stateChange ham.0.Device4d7fc5-S26-Sonoff-Ham.Device4d7fc5-S26-Sonoff-Ham-History.S2R1 {"val":"aiefAgAAAAAdAhgoAQ4BwA/AD5ANAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.163 - info: ham.0 (2102) stateChange ham.0.Device3be921-S20-Sonoff-1.Device3be921-S20-Sonoff-1-History.S2R1 {"val":"aiefAgAAAAAdAhgoAQ4BwA/AD6QNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.165 - info: ham.0 (2102) stateChange ham.0.Device6aae8d-Sonoff-Schalter.Device6aae8d-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD/AOAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.166 - info: ham.0 (2102) stateChange ham.0.Device4110d0-Sonoff-Schalter.Device4110d0-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD+YNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.168 - info: ham.0 (2102) stateChange ham.0.Christbaum.Christbaum-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/AD4RfAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.170 - info: ham.0 (2102) stateChange ham.0.Vitrine.Vitrine-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD/MNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.172 - info: ham.0 (2102) stateChange ham.0.Garagentor.Garagentor-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/ADzFwAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.173 - info: ham.0 (2102) stateChange ham.0.Toilette.Toilette-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/ADxZ+AQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      2023-09-17 14:33:11.175 - info: ham.0 (2102) stateChange ham.0.Pool.Pool-History.S2R1 {"val":"CdqjAgAAAAB+TxMoAgECDgHAD8APAwkBAAAAAAABAQ==","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @peterredl last edited by
        @peterredl sagte in Zigbee Geräte fehlen nach Upgrade auf JS-Controller 5.0:
        Desktop: trinity
        Denn kannste direkt schon mal ausschalten. Ersatzlos.
          peterredl @Thomas Braun last edited by
          sorry, mit mir ist es nicht leicht....
          was soll ich wo ausschalten?
            @peterredl
            sudo systemctl set-default multi-user.target
            sudo systemctl isolate multi-user.target
              @peterredl
              Deine Distribution ist irgendwie sehr schräg aufgestellt...
                Ich bin wohl der größte Trottel….
                Jetzt habe ich deine Eingaben eingegeben und jetzt verlangt er das Desktop Login von mir. Weiß ich nicht mehr und komme nicht mehr ins System. Auch ein Neustart des Rechners hilft nicht. Jetzt schreibe ich von meinem Tablet. Ich denke, jetzt wird nur mehr eine komplette Neuinstallation des Rechners helfen….
                Verzweiflung pur !!!!
                  Für verbummelte Passworte kann ich ja nun nix.
                    Dann nimm diesmal ein reines Debian Bookworm, ohne Desktop.
                    Das q4-Dingsi scheint mir jedenfalls eh etwas 'komisch'.
                      Sorry, war wirklich nicht böse gemeint. Ich habe den Rechner vor Jahren aufgesetzt und seitdem ist er gelaufen und hat mich nie nach einem Login gefragt….
                      Ich danke dir für deine Bemühungen und hoffe, dass ich nach dem neuaufstzen des Rechners, den IoBroker wieder aufsetzen kann und das letzte Backup wieder einspielen kann. Danke.
                        peterredl @peterredl last edited by
                        @peterredl
                        Ich bin wieder im System. Logindaten gefunden.
                        Alles läuft wieder bis auf den Zigbee Adapter….
                        Hast vielleicht diesbezüglich noch einen Tip für mich ?
                        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          Glasfaser @peterredl last edited by Glasfaser
                          ioBroker Log zeigen !
                          EDIT :
                          Hast du auch mal dein gesamtes Sytem neu gestartet !?
                            @peterredl
                            iob diag
                            sagt?
                            Da hängen auch noch knapp zweihundert Updates in der Pipeline. Die solltest du zunächst mal einspielen.
                            1001
