    3. Einsteigerfragen
    4. Installation
    5. Hilfe! js-controller und javascript Problem
    • I
      ioNewbie @ioNewbie last edited by
      @ionewbie in dem jüngsten steht das hier drin:
      pi@iobroker:~/.npm/_logs $ cat 2023-09-17T12_55_50_944Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@9.6.7
      2 info using node@v18.17.1
      3 timing npm:load:whichnode Completed in 4ms
      4 timing config:load:defaults Completed in 6ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
      6 timing config:load:builtin Completed in 6ms
      7 timing config:load:cli Completed in 6ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
      10 timing config:load:project Completed in 8ms
      11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 2ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 3ms
      16 timing config:load Completed in 34ms
      17 timing npm:load:configload Completed in 34ms
      18 timing npm:load:mkdirpcache Completed in 0ms
      19 timing npm:load:mkdirplogs Completed in 1ms
      20 verbose title npm ls
      21 verbose argv "ls"
      22 timing npm:load:setTitle Completed in 4ms
      23 timing config:load:flatten Completed in 10ms
      24 timing npm:load:display Completed in 13ms
      25 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2023-09-17T12_55_50_944Z-
      26 verbose logfile /home/pi/.npm/_logs/2023-09-17T12_55_50_944Z-debug-0.log
      27 timing npm:load:logFile Completed in 30ms
      28 timing npm:load:timers Completed in 1ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 90ms
      31 timing arborist:ctor Completed in 2ms
      32 silly logfile start cleaning logs, removing 1 files
      33 silly logfile done cleaning log files
      34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.daikin-cloud
      35 timing command:ls Completed in 4199ms
      36 verbose exit 0
      37 timing npm Completed in 4373ms
      38 info ok
        Thomas Braun Most Active @ioNewbie last edited by
        @ionewbie
        Das log ist mit Sicherheit länger.
        • I
          ioNewbie @Thomas Braun last edited by
          @thomas-braun tatsächlich nein. ist ja auch von heute Mittag, die Upgrades sind höchstens eine Stunde her
          hm.
            Thomas Braun Most Active @ioNewbie last edited by Thomas Braun
            @ionewbie
            Dann schau per
            cd /opt/iobroker && npm ls -a
            an welcher Stelle im Tree die Meldungen auftauchen.
            • I
              @thomas-braun nicht sicher ob ich jetzt verstanden habe. Geht es um Identifikation des NPM Ordners? das wäre bei execa@5.1.1
              pi@iobroker:~ $ cd /opt/iobroker & npm ls -a
              [1] 2960
              pi@ /home/pi
              └─┬ iobroker.js-controller@5.0.12
                ├─┬ @alcalzone/esbuild-register@2.5.1-1
                │ ├── esbuild@0.11.23
                │ └── jsonc-parser@3.2.0
                ├─┬ @iobroker/db-objects-file@5.0.12
                │ ├─┬ @iobroker/db-base@5.0.12
                │ │ ├── @iobroker/js-controller-common@5.0.12 deduped
                │ │ ├── deep-clone@3.0.3 deduped
                │ │ ├── fs-extra@11.1.1 deduped
                │ │ └── respjs@4.2.0
                │ ├── @iobroker/db-objects-redis@5.0.12 deduped
                │ └── fs-extra@11.1.1 deduped
                ├─┬ @iobroker/db-objects-jsonl@5.0.12
                │ ├─┬ @alcalzone/jsonl-db@3.1.0
                │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                │ │ │ ├── graceful-fs@4.2.11 deduped
                │ │ │ ├── retry@0.12.0
                │ │ │ └── signal-exit@3.0.7
                │ │ ├─┬ alcalzone-shared@4.0.8
                │ │ │ └── debug@4.3.4 deduped
                │ │ └─┬ fs-extra@10.1.0
                │ │   ├── jsonfile@6.1.0 deduped
                │ │   └── universalify@2.0.0 deduped
                │ ├── @iobroker/db-base@5.0.12 deduped
                │ ├── @iobroker/db-objects-file@5.0.12 deduped
                ├─┬ @iobroker/db-objects-redis@5.0.12
                │ ├─┬ ioredis@4.28.5
                │ │ ├── cluster-key-slot@1.1.2
                │ │ ├── debug@4.3.4 deduped
                │ │ ├── denque@1.5.1
                │ │ ├── lodash.defaults@4.2.0
                │ │ ├── lodash.flatten@4.4.0
                │ │ ├── lodash.isarguments@3.1.0
                │ │ ├── p-map@2.1.0
                │ │ ├── redis-commands@1.7.0
                │ │ ├── redis-errors@1.2.0
                │ │ ├─┬ redis-parser@3.0.0
                │ │ │ └── redis-errors@1.2.0 deduped
                │ │ └── standard-as-callback@2.1.0
                │ ├─┬ mime-types@2.1.35
                │ │ └── mime-db@1.52.0
                │ ├─┬ node.extend@2.0.2
                │ │ ├─┬ has@1.0.3
                │ │ │ └── function-bind@1.1.1
                │ │ └── is@3.3.0
                │ └── semver@7.5.4 deduped
                ├─┬ @iobroker/db-states-file@5.0.12
                │ └── @iobroker/db-states-redis@5.0.12 deduped
                ├─┬ @iobroker/db-states-jsonl@5.0.12
                │ ├── @alcalzone/jsonl-db@3.1.0 deduped
                │ ├── @iobroker/db-states-file@5.0.12 deduped
                ├─┬ @iobroker/db-states-redis@5.0.12
                │ └── ioredis@4.28.5 deduped
                ├─┬ @iobroker/js-controller-adapter@5.0.12
                │ ├─┬ @alcalzone/pak@0.8.1
                │ │ ├─┬ axios@0.26.1
                │ │ │ └── follow-redirects@1.15.2 deduped
                │ │ ├─┬ execa@5.1.1
                │ │ │ ├─┬ cross-spawn@7.0.3
                │ │ │ │ ├── path-key@3.1.1
                │ │ │ │ ├─┬ shebang-command@2.0.0
                │ │ │ │ │ └── shebang-regex@3.0.0
                │ │ │ │ └─┬ which@2.0.2
                │ │ │ │   └── isexe@2.0.0
                │ │ │ ├── get-stream@6.0.1
                │ │ │ ├── human-signals@2.1.0
                │ │ │ ├── is-stream@2.0.1 deduped
                │ │ │ ├── merge-stream@2.0.0
                │ │ │ ├─┬ npm-run-path@4.0.1
                │ │ │ │ └── path-key@3.1.1 deduped
                │ │ │ ├─┬ onetime@5.1.2
                │ │ │ │ └── mimic-fn@2.1.0
                │ │ │ ├── signal-exit@3.0.7 deduped
                │ │ │ └── strip-final-newline@2.0.0
                │ ├── @iobroker/db-objects-jsonl@5.0.12 deduped
                │ ├── @iobroker/db-states-jsonl@5.0.12 deduped
                │ ├── @iobroker/db-states-redis@5.0.12 deduped
                │ ├── @iobroker/js-controller-common-db@5.0.12 deduped
                │ ├── @iobroker/plugin-base@1.2.1 deduped
                │ ├── @iobroker/plugin-sentry@1.2.1 deduped
                │ ├── jsonwebtoken@9.0.2 deduped
                │ ├── node-schedule@2.1.1 deduped
                │ ├── node.extend@2.0.2 deduped
                │ ├── pidusage@3.0.2 deduped
                │ ├── readline@1.3.0
                ├─┬ @iobroker/js-controller-cli@5.0.12
                │ ├── axios@1.5.0 deduped
                │ ├─┬ chokidar@3.5.3
                │ │ ├─┬ anymatch@3.1.3
                │ │ │ ├── normalize-path@3.0.0 deduped
                │ │ │ └── picomatch@2.3.1
                │ │ ├─┬ braces@3.0.2
                │ │ │ └─┬ fill-range@7.0.1
                │ │ │   └─┬ to-regex-range@5.0.1
                │ │ │     └── is-number@7.0.0
                │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@~2.3.2
                │ │ ├─┬ glob-parent@5.1.2
                │ │ │ └── is-glob@4.0.3 deduped
                │ │ ├─┬ is-binary-path@2.1.0
                │ │ │ └── binary-extensions@2.2.0
                │ │ ├─┬ is-glob@4.0.3
                │ │ │ └── is-extglob@2.1.1
                │ │ └─┬ readdirp@3.6.0
                │ │   └── picomatch@2.3.1 deduped
                │ ├── daemonize2@0.4.2 deduped
                │ ├─┬ event-stream@4.0.1
                │ │ ├── duplexer@0.1.2
                │ │ ├── from@0.1.7
                │ │ ├── map-stream@0.0.7
                │ │ ├─┬ pause-stream@0.0.11
                │ │ │ └── through@2.3.8 deduped
                │ │ ├─┬ split@1.0.1
                │ │ ├─┬ stream-combiner@0.2.2
                │ │ │ ├── duplexer@0.1.2 deduped
                │ ├── mime-types@2.1.35 deduped
                │ ├── readline-sync@1.4.10 deduped
                │ ├── semver@7.5.4 deduped
                │ └─┬ yargs@17.7.2
                │   ├─┬ cliui@8.0.1
                │   │ ├── string-width@4.2.3 deduped
                │   │ ├─┬ strip-ansi@6.0.1
                │   │ │ └── ansi-regex@5.0.1
                │   │ └─┬ wrap-ansi@7.0.0
                │   │   ├─┬ ansi-styles@4.3.0
                │   │   │ └─┬ color-convert@2.0.1
                │   │   │   └── color-name@1.1.4
                │   │   └── strip-ansi@6.0.1 deduped
                │   ├── escalade@3.1.1
                │   ├── get-caller-file@2.0.5
                │   ├── require-directory@2.1.1
                │   ├─┬ string-width@4.2.3
                │   │ ├── emoji-regex@8.0.0
                │   │ ├── is-fullwidth-code-point@3.0.0
                │   ├── y18n@5.0.8
                │   └── yargs-parser@21.1.1
                ├─┬ @iobroker/js-controller-common-db@5.0.12
                │ ├─┬ winston-seq-updated@1.0.4
                │ │ ├── seq-logging@0.4.6
                │ │ └── winston-transport@4.5.0 deduped
                │ └─┬ winston-syslog@2.7.0
                │   ├── glossy@0.1.7
                │   ├─┬ unix-dgram@2.0.6
                │   │ ├─┬ bindings@1.5.0
                │   │ │ └── file-uri-to-path@1.0.0
                │   │ └── nan@2.18.0 deduped
                │   └── winston@3.10.0 deduped
                ├─┬ @iobroker/js-controller-common@5.0.12
                │ ├── @alcalzone/pak@0.8.1 deduped
                │ ├─┬ @datalust/winston-seq@1.0.2
                │ │ ├── seq-logging@1.1.2
                │ │ ├── winston-transport@4.5.0 deduped
                │ │ └── winston@3.10.0 deduped
                │ ├── ci-info@3.8.0
                │ ├─┬ diskusage@1.2.0
                │ │ ├── es6-promise@4.2.8
                │ │ └── nan@2.18.0
                │ ├── event-stream@4.0.1 deduped
                │ ├── node-forge@1.3.1
                │ ├── promisify-child-process@4.1.2 deduped
                │ ├── readline@1.3.0 deduped
                │ ├── triple-beam@1.4.1
                │ ├─┬ winston-daily-rotate-file@4.7.1
                │ │ ├─┬ file-stream-rotator@0.6.1
                │ │ │ └── moment@2.29.4
                │ │ ├── object-hash@2.2.0
                │ │ ├── triple-beam@1.4.1 deduped
                │ ├── winston-syslog@2.7.0 deduped
                │ ├─┬ winston-transport@4.5.0
                │ │ ├─┬ logform@2.5.1
                │ │ │ ├── @colors/colors@1.5.0 deduped
                │ │ │ ├── @types/triple-beam@1.3.3
                │ │ │ ├── fecha@4.2.3
                │ │ │ ├── ms@2.1.2 deduped
                │ │ │ ├── safe-stable-stringify@2.4.3 deduped
                │ │ │ └── triple-beam@1.4.1 deduped
                │ │ ├─┬ readable-stream@3.6.2
                │ │ │ ├── inherits@2.0.4 deduped
                │ │ │ ├── string_decoder@1.1.1 deduped
                │ │ │ └── util-deprecate@1.0.2 deduped
                │ └─┬ winston@3.10.0
                │   ├─┬ @dabh/diagnostics@2.0.3
                │   │ ├─┬ colorspace@1.1.4
                │   │ │ ├─┬ color@3.2.1
                │   │ │ │ ├─┬ color-convert@1.9.3
                │   │ │ │ │ └── color-name@1.1.3
                │   │ │ │ └─┬ color-string@1.9.1
                │   │ │ │   ├── color-name@1.1.3 deduped
                │   │ │ │   └─┬ simple-swizzle@0.2.2
                │   │ │ │     └── is-arrayish@0.3.2
                │   │ │ └── text-hex@1.0.0
                │   │ ├── enabled@2.0.0
                │   │ └── kuler@2.0.0
                │   ├── async@3.2.3 deduped
                │   ├── logform@2.5.1 deduped
                │   ├─┬ one-time@1.0.0
                │   │ └── fn.name@1.1.0
                │   ├── stack-trace@0.0.10
                ├─┬ @iobroker/plugin-sentry@1.2.1
                │ ├─┬ @sentry/integrations@7.69.0
                │ │ ├── @sentry/types@7.69.0
                │ │ ├─┬ @sentry/utils@7.69.0
                │ │ │ ├── @sentry/types@7.69.0 deduped
                │ │ │ └── tslib@2.6.2 deduped
                │ │ ├─┬ localforage@1.10.0
                │ │ │ └─┬ lie@3.1.1
                │ │ │   └── immediate@3.0.6 deduped
                │ │ └── tslib@2.6.2
                │ ├─┬ @sentry/node@7.69.0
                │ │ ├─┬ @sentry-internal/tracing@7.69.0
                │ │ │ ├── @sentry/core@7.69.0 deduped
                │ │ │ ├── @sentry/utils@7.69.0 deduped
                │ │ ├─┬ @sentry/core@7.69.0
                │ │ ├── cookie@0.4.2
                │ │ ├─┬ https-proxy-agent@5.0.1
                │ │ │ ├─┬ agent-base@6.0.2
                │ │ │ │ └── debug@4.3.4 deduped
                │ │ ├── lru_map@0.3.3
                │ └─┬ source-map-support@0.5.21
                │   ├── buffer-from@1.1.2
                │   └── source-map@0.6.1
                ├─┬ axios@1.5.0
                │ ├── follow-redirects@1.15.2
                │ ├─┬ form-data@4.0.0
                │ │ ├── asynckit@0.4.0
                │ │ ├─┬ combined-stream@1.0.8
                │ │ │ └── delayed-stream@1.0.0
                │ │ └── mime-types@2.1.35 deduped
                │ └── proxy-from-env@1.1.0
                ├─┬ debug@4.3.4
                │ └── ms@2.1.2
                ├─┬ decache@4.6.2
                │ └── callsite@1.0.0
                ├─┬ fs-extra@11.1.1
                │ ├─┬ jsonfile@6.1.0
                ├─┬ greenlock-express@4.0.3
                │ ├─┬ @root/greenlock-express@4.0.4
                │ │ ├── @root/greenlock@4.0.5 deduped
                │ │ └── redirect-https@1.3.1 deduped
                │ ├─┬ @root/greenlock@4.0.5
                │ │ ├── @greenlock/manager@3.1.0 deduped
                │ │ ├── @root/acme@3.1.0 deduped
                │ │ ├── @root/csr@0.8.1 deduped
                │ │ ├─┬ @root/keypairs@0.10.3
                │ │ │ ├── @root/encoding@1.0.1 deduped
                │ │ │ ├── @root/pem@1.0.4 deduped
                │ │ │ └── @root/x509@0.7.2 deduped
                │ │ ├── @root/mkdirp@1.0.0 deduped
                │ │ ├── @root/request@1.9.2 deduped
                │ │ ├── acme-http-01-standalone@3.0.5 deduped
                │ │ ├── cert-info@1.5.1 deduped
                │ │ ├── greenlock-store-fs@3.2.2 deduped
                │ │ └── safe-replace@1.1.0 deduped
                │ └─┬ redirect-https@1.3.1
                │   └── escape-html@1.0.3
                ├─┬ greenlock@4.0.4
                │ ├─┬ @greenlock/manager@3.1.0
                │ │ └─┬ greenlock-manager-fs@3.1.1
                │ ├─┬ @root/acme@3.1.0
                │ │ └─┬ @root/x509@0.7.2
                │ │   ├── @root/asn1@1.0.0 deduped
                │ │   └── @root/encoding@1.0.1 deduped
                │ ├─┬ @root/csr@0.8.1
                │ │ ├─┬ @root/asn1@1.0.0
                │ │ │ └── @root/encoding@1.0.1 deduped
                │ ├─┬ @root/keypairs@0.9.0
                │ ├─┬ greenlock-store-fs@3.2.2
                ├─┬ jsonwebtoken@9.0.2
                │ ├─┬ jws@3.2.2
                │ │ ├─┬ jwa@1.4.1
                │ │ │ ├── buffer-equal-constant-time@1.0.1
                │ │ │ ├─┬ ecdsa-sig-formatter@1.0.11
                │ │ │ │ └── safe-buffer@5.2.1 deduped
                │ ├── lodash.includes@4.3.0
                │ ├── lodash.isboolean@3.0.3
                │ ├── lodash.isinteger@4.0.4
                │ ├── lodash.isnumber@3.0.3
                │ ├── lodash.isplainobject@4.0.6
                │ ├── lodash.isstring@4.0.1
                │ ├── lodash.once@4.1.1
                ├─┬ jszip@3.10.1
                │ ├─┬ lie@3.3.0
                │ ├── pako@1.0.11
                │ ├─┬ readable-stream@2.3.8
                │ │ ├── core-util-is@1.0.3
                │ │ ├── isarray@1.0.0
                │ │ ├── process-nextick-args@2.0.1
                │ │ ├── safe-buffer@5.1.2
                │ │ ├─┬ string_decoder@1.1.1
                │ │ │ └── safe-buffer@5.1.2
                │ └── setimmediate@1.0.5
                ├─┬ le-acme-core@2.1.4
                │ ├─┬ request@2.88.2
                │ │ ├── aws-sign2@0.7.0
                │ │ ├── aws4@1.12.0
                │ │ ├── caseless@0.12.0
                │ │ ├── combined-stream@1.0.8 deduped
                │ │ ├── extend@3.0.2
                │ │ ├── forever-agent@0.6.1
                │ │ ├─┬ form-data@2.3.3
                │ │ │ ├── asynckit@0.4.0 deduped
                │ │ │ ├── combined-stream@1.0.8 deduped
                │ │ │ └── mime-types@2.1.35 deduped
                │ │ ├─┬ har-validator@5.1.5
                │ │ │ ├─┬ ajv@6.12.6
                │ │ │ │ ├── fast-deep-equal@3.1.3
                │ │ │ │ ├── fast-json-stable-stringify@2.1.0
                │ │ │ │ ├── json-schema-traverse@0.4.1
                │ │ │ │ └─┬ uri-js@4.4.1
                │ │ │ │   └── punycode@2.3.0 deduped
                │ │ │ └── har-schema@2.0.0
                │ │ ├─┬ http-signature@1.2.0
                │ │ │ ├── assert-plus@1.0.0
                │ │ │ ├─┬ jsprim@1.4.2
                │ │ │ │ ├── assert-plus@1.0.0 deduped
                │ │ │ │ ├── extsprintf@1.3.0
                │ │ │ │ ├── json-schema@0.4.0
                │ │ │ │ └─┬ verror@1.10.0
                │ │ │ │   ├── core-util-is@1.0.2
                │ │ │ │   └── extsprintf@1.3.0 deduped
                │ │ │ └─┬ sshpk@1.17.0
                │ │ │   ├─┬ asn1@0.2.6
                │ │ │   │ └── safer-buffer@2.1.2 deduped
                │ │ │   ├─┬ bcrypt-pbkdf@1.0.2
                │ │ │   │ └── tweetnacl@0.14.5 deduped
                │ │ │   ├─┬ dashdash@1.14.1
                │ │ │   │ └── assert-plus@1.0.0 deduped
                │ │ │   ├─┬ ecc-jsbn@0.1.2
                │ │ │   │ ├── jsbn@0.1.1 deduped
                │ │ │   ├─┬ getpass@0.1.7
                │ │ │   ├── safer-buffer@2.1.2
                │ │ ├── is-typedarray@1.0.0
                │ │ ├── isstream@0.1.2
                │ │ ├── json-stringify-safe@5.0.1
                │ │ ├── mime-types@2.1.35 deduped
                │ │ ├── oauth-sign@0.9.0
                │ │ ├── performance-now@2.1.0
                │ │ ├── qs@6.5.3
                │ │ ├── safe-buffer@5.2.1 deduped
                │ │ ├─┬ tough-cookie@2.5.0
                │ │ │ ├── psl@1.9.0
                │ │ ├─┬ tunnel-agent@0.6.0
                │ │ └── uuid@3.4.0
                │ └─┬ rsa-compat@1.9.4
                │   ├─┬ keypairs@1.2.14
                │   │ ├── eckles@1.4.1
                │   │ └── rasha@1.2.5
                │   ├── node-forge@0.7.6
                │   └─┬ ursa-optional@0.9.10
                │     ├── bindings@1.5.0 deduped
                ├─┬ le-challenge-fs@2.0.9
                │ └── @root/mkdirp@1.0.0 deduped
                ├── le-sni-auto@2.1.9
                ├─┬ loadavg-windows@1.1.1
                │ └── weak-daemon@1.0.3
                ├─┬ node-schedule@2.1.1
                │ ├─┬ cron-parser@4.9.0
                │ │ └── luxon@3.4.3
                │ ├── long-timeout@0.1.1
                │ └── sorted-array-functions@1.3.0
                ├─┬ pidusage@3.0.2
                ├─┬ prompt@1.3.0
                │ ├── async@3.2.3
                │ ├─┬ read@1.0.7
                │ │ └── mute-stream@0.0.8
                │ ├── revalidator@0.1.8
                │ └─┬ winston@2.4.7
                │   ├─┬ async@2.6.4
                │   │ └── lodash@4.17.21
                │   ├── colors@1.0.3
                │   ├── cycle@1.0.3
                │   ├── eyes@0.1.8
                │   ├── isstream@0.1.2 deduped
                │   └── stack-trace@0.0.10 deduped
                ├─┬ semver@7.5.4
                │ └─┬ lru-cache@6.0.0
                │   └── yallist@4.0.0 deduped
                └─┬ tar@6.2.0
                  ├── chownr@2.0.0
                  ├─┬ fs-minipass@2.1.0
                  │ └─┬ minipass@3.3.6
                  ├── minipass@5.0.0
                  ├─┬ minizlib@2.1.2
                  │ ├─┬ minipass@3.3.6
                  │ │ └── yallist@4.0.0 deduped
                  ├── mkdirp@1.0.4
                  └── yallist@4.0.0
              [1]+  Done                    cd /opt/iobroker
                @ionewbie
                Sorry, mein Fehler.
                Aber dadurch haben wir eine Parallel-Installation in /home/pi gefunden.
                Du hast also irendwie da was 'daneben' geworfen.
                In den Heimverzeichnissen der user muss das so aussehen (auf meiner Kiste):
                echad@chet:~ $ npm ls -a
                /home/echad
                └── (empty)
                echad@chet:~ $ cd /home/iobroker/
                echad@chet:/home/iobroker $ npm ls -a
                /home/iobroker
                └── (empty)
                • I
                  ioNewbie @Thomas Braun last edited by ioNewbie
                  @thomas-braun hm, keine Ahnung, zumindest nicht bewußt.
                  Was ist jetzt als nächstes dran? der js-controller ist ja immer noch auf altem Stand
                    @ionewbie
                    Ich würde das Verzeichnis node_modules aus den Homes der user löschen. Schau bei deinem Standarduser und dem iobroker rein.
                    • I
                      @thomas-braun äh... moment.
                      Standarduser / Normaluser?
                      Ich habe den PI nur für IOB und das hab ich wohl mal mit dem pi installiert. da mache ich nichts anderes.
                      Was genau meinst du was ich tun soll?
                      • I
                        ioNewbie @ioNewbie last edited by ioNewbie
                        @ionewbie unter /homes habe ich iobroker und pi.
                        überall klebt das aktuelle Datum dran:
                        pi@iobroker:/home $ ls -ali
                        total 16
                         16385 drwxr-xr-x  4 root     root     4096 Sep  1  2022 .
                             2 drwxr-xr-x 18 root     root     4096 Sep 17 09:55 ..
                        131490 drwxr-xr-x  5 iobroker iobroker 4096 Sep 17 11:24 iobroker
                           873 drwxr-xr-x  9 pi       pi       4096 Sep 17 12:24 pi
                        In iobroker sieht es so aus:
                        pi@iobroker:/home/iobroker $ ls -ali
                        total 76
                        131490 drwxr-xr-x 5 iobroker iobroker  4096 Sep 17 11:24 .
                         16385 drwxr-xr-x 4 root     root      4096 Sep  1  2022 ..
                        131518 -rw-r--r-- 1 iobroker iobroker   220 Jan  3  2021 .bash_logout
                        131520 -rw-r--r-- 1 iobroker iobroker  3523 Apr  4  2022 .bashrc
                        131966 drwxr-xr-x 4 iobroker iobroker  4096 Sep 17 08:54 .cache
                        136594 drwx------ 3 iobroker iobroker  4096 Sep  1  2022 .config
                        140520 -rw-r--r-- 1 iobroker iobroker 13830 Sep 17 14:55 .diag.sh
                        140566 -rw-r--r-- 1 iobroker iobroker 18783 Sep 17 14:56 iob_diag.log
                        131492 -rw-r--r-- 1 iobroker iobroker  1670 Jul 10  2021 .mkshrc
                        131522 drwxr-xr-x 6 iobroker iobroker  4096 Sep 17 10:12 .npm
                        131519 -rw-r--r-- 1 iobroker iobroker   807 Jan  3  2021 .profile
                          @ionewbie
                          cd
                          ls -lAh
                          • I
                            @thomas-braun said in Hilfe! js-controller und javascript Problem:
                            ls -lAh
                            pi@iobroker:/home $ ls -lAh
                            total 8.0K
                            drwxr-xr-x 5 iobroker iobroker 4.0K Sep 17 11:24 iobroker
                            drwxr-xr-x 9 pi       pi       4.0K Sep 17 12:24 pi
                              @ionewbie
                              cd
                              ls -lAh
                              • I
                                pi@iobroker:~ $ ls -lAh
                                total 196K
                                -rw-------   1 pi pi 4.5K Sep 17 15:19 .bash_history
                                -rw-r--r--   1 pi pi  220 Apr  4  2022 .bash_logout
                                -rw-r--r--   1 pi pi 3.7K Sep 17 12:24 .bashrc
                                drwxr-xr-x   4 pi pi 4.0K Sep  1  2022 .cache
                                drwx------   3 pi pi 4.0K Sep  1  2022 .config
                                -rwxr-xr--   1 pi pi  107 Sep 17 10:42 iob
                                drwxr-xr-x   2 pi pi 4.0K Sep  1  2022 .iobroker
                                -rwxr-xr--   1 pi pi  107 Sep 17 10:42 iobroker
                                drwxr-xr-x   2 pi pi 4.0K Sep 17 10:42 iobroker-data
                                drwxr-xr-x   3 pi pi 4.0K Jul 16 16:01 .local
                                drwxr-xr-x 259 pi pi  12K Sep 17 10:42 node_modules
                                drwxr-xr-x   5 pi pi 4.0K Sep 17 10:41 .npm
                                -rw-------   1 pi pi   36 Sep  1  2022 .npmrc
                                -rw-r--r--   1 pi pi   68 Sep 17 10:42 package.json
                                -rw-r--r--   1 pi pi 116K Sep 17 10:42 package-lock.json
                                -rw-r--r--   1 pi pi  807 Apr  4  2022 .profile
                                -rw-r--r--   1 pi pi  140 Jul 16 16:02 readme.txt
                                -rw-r--r--   1 pi pi  104 Jul 16 04:13 sources-dist-hash.json
                                Thomas Braun I 2 Replies Last reply Reply Quote 0
                                  @ionewbie
                                  Das ist eine komplette Installation im falschen Verzeichnis. Wie schafft man das?
                                  rm iob*
                                  rm .io*
                                  rm -rf node_modules
                                  rm package*
                                  rm sources-dist-hash.json
                                  • I
                                    @ionewbie
                                    Anfängerfehler, vermutlich. Ich bin irgendeiner Anleitung damals zur Installation des IOB gefolgt, das weiß ich nicht mehr.
                                    Gibt es absolut adressierte Pfade oder oder ist es letztlich egal, in welchem Ordner das installiert wurde?
                                      @ionewbie sagte in Hilfe! js-controller und javascript Problem:
                                      ok. verstehe ich korrekt, dass ich den Ordner node_modules mit allem was drin ist, in /homes/pi löschen soll, weil es ja noch den Ordner in /node_modules gibt?
                                      Ja, und alles andere auch. Siehe oben.
                                      Die richtige Installation wohnt in /opt/iobroker
                                      kaputt machen wir damit nichts?
                                      Sehn wir dann.
                                      • I
                                        @thomas-braun omg.
                                        Dann komme ich jetzt an den Punkt für folgende Überlegung: lieber Raspi löschen und alles frisch neu installieren oder troubleshooten?
                                        Das Troubleshooting hat mich heute fast schon den ganzen Tag gekostet - und dir sicher auch einiges an Zeit.
                                        Ich verliere dabei als wichtigstes die mitgeschriebenen Daten aus dem KNX Adapter. Aber ich sterbe nicht wenn die auch weg sind. Der Rest an Adaptern und Daten im System sind nice to have.
                                        Der Rest an Customizing ist mir egal und kann ich neu machen. Eine Visu habe ich eh noch nicht auf die Reihe bekommen, weil ich noch keine Zeit für die Einarbeitung gefunden habe.
                                        Management für mein Smarthome geht bisher komplett am IOB vorbei, dafür ist mir der - wie ich jetzt wieder sehe - zu unzuverlässig, das ist eher was zum Basteln.
                                        Wir sind jetzt gerade noch vor Start der nächsten Heizperiode, und die will ich voll mit tracken. Die Daten vom letzten Winterhalbjahr sind dann halt weg.
                                        Das weitere Troubleshooting und Nachfrage/Antwort-Spiel wird mich noch sehr viel weitere Zeit kosten.
                                        Da frag ich lieber mal nach einer aktuellen und korrekten Anleitung für eine Neuinstallation auf dem Raspi 4. Ggfs kann ich dann auch gleich das OS da hin bringen, wohin es für IOB soll.
                                          Das musst du wissen.
                                          Allerdings kann ich
                                          so nicht stehen lassen. Das Ding has DU dir selber verbastelt. Eine unverfummelte 'stable'-Installation ist auch genau das: Stable.
                                            @ionewbie
                                            Mach es danach, dann passt das auch:
                                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                            Backup der wichtigen Daten hat man ja, sonst sind sie auch nicht wichtig.
                                            5923
