    • Michael Roling
      Michael Roling Developer @liv-in-sky last edited by
      @liv-in-sky da habe ich gerade keine idee zu
        liv-in-sky @Michael Roling last edited by
        @michael-roling
        ich vergleiche gerade die setting via json file - da stimmt was nicht mehr
        diese instanz macht keinen fehler und sieht so aus: (siehe telegram instanz) - startet aber funktioniert nicht
         "_id": "system.adapter.telegram-menu.0",
         "common": {
           "name": "telegram-menu",
           "version": "0.6.8",
           "authors": [
             "MiRo1310 <michael.roling@gmx.de>"
           "keywords": [
             "telegram",
             "menu"
           "license": "MIT",
           "platform": "Javascript/Node.js",
           "main": "main.js",
           "icon": "telegram-menu.png",
           "enabled": true,
           "messagebox": true,
           "extIcon": "https://raw.githubusercontent.com/MiRo1310/ioBroker.telegram-menu/main/admin/telegram-menu.png",
           "readme": "https://github.com/MiRo1310/ioBroker.telegram-menu/blob/main/README.md",
           "loglevel": "info",
           "mode": "daemon",
           "type": "messaging",
           "compact": true,
           "connectionType": "local",
           "dataSource": "poll",
           "adminUI": {
             "config": "materialize"
           "dependencies": [
               "js-controller": ">=3.3.22"
           "globalDependencies": [
               "admin": ">=5.0.0",
               "telegram": ">=1.15.0"
           "installedFrom": "MiRo1310/ioBroker.telegram-menu",
           "installedVersion": "0.6.8",
           "host": "iobroker59"
         "native": {
           "checkbox": {
             "checkboxNoValueFound": true,
             "resKey": true,
             "oneTiKey": false
           "textNoEntry": "",
           "tokenGrafana": "",
           "directory": "",
           "usersInGroup": {},
           "userListWithChatID": [
               "name": "liv-in-sky",
               "chatID": "989074665"
           "userActiveCheckbox": {},
           "instance": null,
           "data": {
             "nav": {},
             "action": {}
           "users": [],
           "startsides": {}
        die zweite instanz bleibt rot und bringt die fehler wie vorher - das json:
         "_id": "system.adapter.telegram-menu.1",
         "common": {
           "version": "0.6.8",
           "authors": [
           "keywords": [
             "telegram",
             "menu"
           "license": "MIT",
           "main": "main.js",
           "enabled": false,
           "messagebox": true,
           "loglevel": "info",
           "mode": "daemon",
           "compact": true,
           "adminUI": {
           "dependencies": [
               "admin": ">=5.0.0",
         "native": {
           "checkbox": {
             "checkboxNoValueFound": false,
             "resKey": true,
             "oneTiKey": false
           "textNoEntry": "",
           "tokenGrafana": "",
           "directory": "",
           "usersInGroup": {
             "liv-in-sky": [
               "liv-in-sky"
             "liv-in-sky": true
           "instance": null,
           "data": {
             "nav": {
               "liv-in-sky": [
                   "call": "Startseite",
                   "value": "Lüfter5,outSide && getStandort,Melike",
                   "text": "MyMenu "
                   "call": "outSide",
                   "value": "menu:number0-6-1- :aussen:",
                   "text": "Wähle eine Aktion"
             "action": {
               "liv-in-sky": {
                 "get": [
                     "trigger": [
                       "getStandort"
                     "IDs": [
                       "0_userdata.0.CONTROL-OWN.MOTION.Standort"
                     "text": [
                       "Standort ist momentan: &amp;&amp;"
                     "newline_checkbox": [
                       "true"
                 "set": [
                     "trigger": [
                       "Lüfter5"
                     "IDs": [
                       "0_userdata.0.CONTROL-OWN.Luefter5"
                     "values": [
                     "returnText": [
                       "ist jetzt &amp;&amp; ack:true"
                     "confirm": [
                       "true"
                     "switch_checkbox": [
                       "true"
                     "trigger": [
                       "aussen"
                     "IDs": [
                     "values": [
                     "returnText": [
                       "wert ist jetzt &amp;&amp; ack:true"
                     "confirm": [
                       "true"
                       "false"
                     "trigger": [
                       "Melike"
                     "IDs": [
                       "0_userdata.0.CONTROL-OWN.TRACCAR.MelikeSchreiben"
                     "values": [
                     "returnText": [
                     "confirm": [
                       "true"
                       "true"
                 "pic": []
           "users": [
             "liv-in-sky"
           "startsides": {
             "liv-in-sky": "Startseite"
        [/s]
          @michael-roling
          auch wenn ich ein instanz lösche und ohne json lade und definiere, kann ich keine telegram instnz wählen - da kommt keine auswahl
          ich habe über github und dann telegram-menu ausgewählt und installiert
          • Michael Roling
            @liv-in-sky ich habe gerade mein produktiv System von Github installiert. Keine Probleme.
            Was ist denn wenn du wieder die stable Version installierst?
              @michael-roling
              total ausfall
              • cache browser gelöscht
              • verschiedene browser getestet
              • server neugestartet
              • version 0.67. stable installiert
              keine ahnung was da jetzt los ist
              • Michael Roling
                @liv-in-sky Telegram ist aber noch installiert und aktiv ?
                liv-in-sky 4 Replies Last reply Reply Quote 0
                  liv-in-sky @Michael Roling last edited by liv-in-sky
                  @michael-roling ja - 4 instanzen
                  die eine instanz ,die grün blieb, sagte im log telegram gefunden
                  kann den irgendwo ein setting im filesystem liegen, was bei der deinstallation nicht gelöscht wird ?
                    @michael-roling
                    ich hoffe mal, dass der neue js-controller kein thema ist
                      arteck Developer Most Active @liv-in-sky last edited by
                      @liv-in-sky nein den hab ich bei mir auch laufen
                        liv-in-sky @arteck last edited by liv-in-sky
                        @arteck
                        ich weiß langsam nicht mehr, was ich noch ausprobieren soll - weder mit neuer, noch der stable version, kann ich das setting der telegram instanz einstellen
                        wenn ich ein setting importiere, welches mal lief, wird eine grüne instanz angezeigt aber im setting steht auch keine telegram-instanz - im log wird angezeigt: telegram gefunden - öffne ich das instanz setting wieder, ist es wieder leer - wie nie konfiguriert
                        dann: wenn ich json wieder importiere , wird das setting nicht überschrieben sondern doppelt angezeigt - öffne ich das setting dann nochmal, ist es wieder leer
                        admin habe ich auch downgegraded
                        ich habe mal eine neue sonoff instanz installiert und mit dem json import und export getestet - da funktioniert alles
                        bei einer neuinstallation kommen keine fehler
                        $ iobroker add telegram-menu --host iobroker59
                        NPM version: 9.6.7
                        Installing iobroker.telegram-menu@0.6.8... (System call)
                        added 2 packages in 5s325 packages are looking for funding run `npm fund` for details
                        host.iobroker59 install adapter telegram-menu
                        upload [21] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/css/color.css css/color.css text/css
                        upload [20] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/css/scrolling.css css/scrolling.css text/css
                        upload [19] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/css/style.css css/style.css text/css
                        upload [18] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [17] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [16] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [15] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [14] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [13] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [12] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [11] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [10] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [9] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [8] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [7] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/img/info-big.png img/info-big.png image/png
                        upload [6] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/index_m.html index_m.html text/html
                        upload [5] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/js/component.js js/component.js application/javascript
                        upload [4] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/js/emit.js js/emit.js application/javascript
                        upload [3] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/js/global.js js/global.js application/javascript
                        upload [2] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/js/main.js js/main.js application/javascript
                        upload [1] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/telegram-menu.png telegram-menu.png image/png
                        upload [0] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/words.js words.js application/javascript
                        host.iobroker59 object system.adapter.telegram-menu created/updated
                        host.iobroker59 create instance telegram-menu
                        host.iobroker59 object system.adapter.telegram-menu.0.alive created
                        host.iobroker59 object system.adapter.telegram-menu.0.connected created
                        host.iobroker59 object system.adapter.telegram-menu.0.compactMode created
                        host.iobroker59 object system.adapter.telegram-menu.0.cpu created
                        host.iobroker59 object system.adapter.telegram-menu.0.cputime created
                        host.iobroker59 object system.adapter.telegram-menu.0.memHeapTotal created
                        host.iobroker59 object system.adapter.telegram-menu.0.uptime created
                        host.iobroker59 object system.adapter.telegram-menu.0.inputCount created
                        host.iobroker59 Set default value of telegram-menu.0.info.connection: false
                        host.iobroker59 object system.adapter.telegram-menu.0 created
                        Process exited with code 0
                          @michael-roling
                          @arteck
                          noch ein hinweis - ich habe evtl einen fehler gemacht - kann dies eine ursache sein - ich habe beim letzten ersten update nicht über github sondern über benutzer definiert und der github adapter url installiert - kann das was verschossen haben
                            @michael-roling
                            @arteck
                            ok - aus lauter verzwieflung habe ich eine neue instanz von telegram angelegt. und jetzt kann ich die neue instanz plötzlich im setting auswählen - aber nur die
                            die anderen telegram instanzen funktionieren aber, die sind voller meldungen und auch mein postit script arbeitet einwandfrei mit den verschiedenen teleg-instanzen
                            • Michael Roling
                              @liv-in-sky ich installiere auch immer benutzer definiert. Komisch finde ich das du nicht mal eine stable Version installieren kannst.
                              Das Problem tritt erst auf wenn du die config importierst? Oder habe ich das falsch verstanden?
                                @michael-roling nein - die instanz kann ich auch in leerer config nicht setzen - ich kann zwar andere settings eingeben , aber beim nächsten aufruf ist es wieder weg bzw nicht sichtbar
                                ich installiere gerade alle telegram instanzen neu, damit die mal wieder auswählbar sind
                                  @michael-roling
                                  jetzt sind alle 4 instanzen von telegram sichtbar und auswählbar - jetzt bekomme ich das - was mache ich nun wieder falsch 😞
                                  ? Michael Roling 2 Replies Last reply Reply Quote 0
                                    A Former User @liv-in-sky last edited by
                                    erst einmal SORRY, dass ich mit einer Banalität hier reingrätsche und es ist auch total unwichtig im Vergleich zu der anderen Diskussion. Ich erwähne es nur deshalb, um evt. eine offene Sache nicht zu vergessen oder zu lernen.
                                    Schaut bitte meinen Screen. Bei den selbstdefinierten DPen bekomme ich keine Rückmeldung mit Rückgabetext. Bei dem angelegten unter Sonoff klappt es wie erwartet. Fehler bei mir? oder eine offene Thematik?
                                    • Michael Roling
                                      @liv-in-sky ich vermute das irgendwie ein Fehler in der Telegram Instanz ist. Weil dir wird ja kein Benutzer angezeigt.
                                      • Michael Roling
                                        Michael Roling Developer @Guest last edited by
                                          @michael-roling
                                          ja da könntest du recht haben - mittlerweile habe ich auch probleme mit telegram - was'n sch.....
                                            A Former User @Michael Roling last edited by
                                            @michael-roling hi Michael, versteh ich nicht ganz, ich habe doch alle drei auf true und nur der im Sonoff Objektbaum wird bestätigt. Oder muss ich noch was einstellen?
                                            1793
                                            747173
