Keine Verbindung zu VIS seit Update js-controller 5.0.x
ioBroker nodejs fixer 2023-09-15 Recommended nodejs-version is: 18.17.1 Checking your installation now. Please be patient! Your current setup is: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 /usr/local/bin/corepack 0.18.0 *** nodejs is NOT correctly installed *** We found these nodejs versions available for installation: nodejs: Installed: 18.17.1-1nodesource1 Candidate: 18.17.1-1nodesource1 Version table: *** 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Your nodejs-Installation seems to be not correct. Shall we try to fix it? Press <y> to continue or any other key to quit Fixing your nodejs setup *** Deleting /usr/local/bin/corepack *** Wrong paths have been fixed. Run 'iob diag' or 'iob node-update' again to check if your installation is fine now Nothing to do, your installed version is the recommended one.
Ah, corepack wird natürlich erst jetzt gefunden.
Dann nochmal Skript laufen lassen. -
@karacho
So habe jetzt noch mal durchlaufen lassen.
2x nothing to doIobroker neu gestartet.
VIS funktioniert nicht
solarlog Adapter startet nicht.Gleiches Bild wie nach dem update js-controller von 4.x. auf 5.x
Stand iob diag
======================= SUMMARY ======================= v.2023-06-20 Static hostname: raspberrypi4-iob Icon name: computer Machine ID: 7520f6fd74454b99bf8a0c3666ca6ae6 Boot ID: cd5e4022480d4ac5b84276a48432878e Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: armhf Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 Recommended versions are nodejs 18.x.y and npm 9.x.y Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.8G 1.3G 2.0G 24M 575M 2.4G Swap: 99M 0B 99M Total: 3.9G 1.3G 2.1G Active iob-Instances: 31 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.12 admin 6.8.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : raspberrypi4-iob - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi4-iob - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 15063 States: 13165 Size of iob-Database: 17M /opt/iobroker/iobroker-data/objects.jsonl 11M /opt/iobroker/iobroker-data/objects.json.migrated 11M /opt/iobroker/iobroker-data/objects.json.bak.migrated 6.6M /opt/iobroker/iobroker-data/states.jsonl 2.5M /opt/iobroker/iobroker-data/states.json.migrated 2.5M /opt/iobroker/iobroker-data/states.json.bak.migrated =================== END OF SUMMARY ====================
@karacho sagte in Keine Verbindung zu VIS seit Update js-controller 5.0.x:
Stand iob diag
da gibt's noch mehr!
Das ist nur die Summary -
Zumindest diese Baustelle ist abgeschlossen.
======== Start marking the full check here ========= Skript v.2023-06-20 *** BASE SYSTEM *** Static hostname: raspberrypi4-iob Icon name: computer Machine ID: 7520f6fd74454b99bf8a0c3666ca6ae6 Boot ID: cd5e4022480d4ac5b84276a48432878e Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.2 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 14:21:54 up 19 min, 1 user, load average: 0.87, 1.68, 1.25 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=48.7'C volt=0.8500V *** Time and Time Zones *** Local time: Mon 2023-09-18 14:21:54 CEST Universal time: Mon 2023-09-18 12:21:54 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g pio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.5G 1.7G 24M 607M 2.1G Swap: 99M 0B 99M Total: 3.9G 1.5G 1.8G 3837 M total memory 1533 M used memory 324 M active memory 1683 M inactive memory 1697 M free memory 110 M buffer memory 497 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 59G 43G 14G 76% / devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 1.9G 25M 1.9G 2% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup /dev/sda1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 384M 0 384M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Sep 18 14:02:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC :A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=t tyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=dead line fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Mon Sep 18 14:02:14 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [Mon Sep 18 14:02:14 2023] VFS: Mounted root (ext4 filesystem) readonly on devic e 8:2. [Mon Sep 18 14:02:15 2023] EXT4-fs (sda2): re-mounted. Opts: (null) Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,io charset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.2G /var/ 1.9G /var/cache/apt 1.9G /var/cache 1.8G /var/cache/apt/archives 117M /var/lib Archived and active journals take up 24.0M in the file system. /opt/iobroker/backups: 194M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 711M /opt/iobroker/iobroker-data/history 261M /opt/iobroker/iobroker-data/files 131M /opt/iobroker/iobroker-data/backup-objects 52M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56. js.map 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m ap 17M /opt/iobroker/iobroker-data/objects.jsonl 11M /opt/iobroker/iobroker-data/objects.json.migrated 11M /opt/iobroker/iobroker-data/objects.json.bak.migrated *** NodeJS-Installation *** /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 nodejs: Installed: 18.17.1-1nodesource1 Candidate: 18.17.1-1nodesource1 Version table: *** 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: 0 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl No configuration change needed. Multihost discovery server: disabled Discovery authentication: enabled Persistent activation: disabled Objects: jsonl on 127.0.0.1 States: jsonl on 127.0.0.1 Core adapters versions js-controller: 5.0.12 admin: 6.8.0 javascript: 7.1.4 Adapters from github: 3 Adapter State + system.adapter.admin.0 : admin : raspberrypi4-iob - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : raspberrypi4-iob - enabled + system.adapter.bmw.0 : bmw : raspberrypi4-iob - enabled + system.adapter.bosch-ebike.0 : bosch-ebike : raspberrypi4-iob - enabled + system.adapter.broadlink2.0 : broadlink2 : raspberrypi4-iob - enabled + system.adapter.cloud.0 : cloud : raspberrypi4-iob - enabled system.adapter.daswetter.0 : daswetter : raspberrypi4-iob - enabled system.adapter.devices.0 : devices : raspberrypi4-iob - disabled + system.adapter.discovery.0 : discovery : raspberrypi4-iob - enabled system.adapter.dwd.0 : dwd : raspberrypi4-iob - enabled + system.adapter.easee.0 : easee : raspberrypi4-iob - enabled + system.adapter.ems-esp.0 : ems-esp : raspberrypi4-iob - enabled system.adapter.flot.0 : flot : raspberrypi4-iob - disabled + system.adapter.harmony.0 : harmony : raspberrypi4-iob - enabled + system.adapter.heatingcontrol.0 : heatingcontrol : raspberrypi4-iob - enabled + system.adapter.history.0 : history : raspberrypi4-iob - enabled + system.adapter.hmip.0 : hmip : raspberrypi4-iob - enabled + system.adapter.homeconnect.0 : homeconnect : raspberrypi4-iob - enabled + system.adapter.hs100.0 : hs100 : raspberrypi4-iob - enabled system.adapter.ical.0 : ical : raspberrypi4-iob - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi4-iob - disabled + system.adapter.info.0 : info : raspberrypi4-iob - enabled + system.adapter.javascript.0 : javascript : raspberrypi4-iob - enabled + system.adapter.meater.0 : meater : raspberrypi4-iob - enabled + system.adapter.mercedesme.0 : mercedesme : raspberrypi4-iob - enabled + system.adapter.mihome-vacuum.0 : mihome-vacuum : raspberrypi4-iob - enabled, port: 54321 + system.adapter.mihome-vacuum.1 : mihome-vacuum : raspberrypi4-iob - enabled, port: 54321 + system.adapter.nuki-extended.0 : nuki-extended : raspberrypi4-iob - enabled + system.adapter.pushover.0 : pushover : raspberrypi4-iob - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi4-iob - enabled + system.adapter.scenes.0 : scenes : raspberrypi4-iob - enabled + system.adapter.smartgarden.0 : smartgarden : raspberrypi4-iob - enabled system.adapter.solarlog.0 : solarlog : raspberrypi4-iob - enabled, port: 80 + system.adapter.trashschedule.0 : trashschedule : raspberrypi4-iob - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi4-iob - disabled system.adapter.vis-justgage.0 : vis-justgage : raspberrypi4-iob - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi4-iob - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi4-iob - disabled system.adapter.vis.0 : vis : raspberrypi4-iob - enabled + system.adapter.web.0 : web : raspberrypi4-iob - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.worx.0 : worx : raspberrypi4-iob - enabled + system.adapter.zigbee.0 : zigbee : raspberrypi4-iob - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi4-iob - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mihome-vacuum.0 : mihome-vacuum : raspberrypi4-iob - enabled, port: 54321 + system.adapter.mihome-vacuum.1 : mihome-vacuum : raspberrypi4-iob - enabled, port: 54321 system.adapter.solarlog.0 : solarlog : raspberrypi4-iob - enabled, port: 80 + system.adapter.web.0 : web : raspberrypi4-iob - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi4-iob - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0 ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.8.0 , installed 6.8.0 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "bmw" : 2.5.7 , installed 2.6.1 Adapter "bosch-ebike" : 0.0.3 , installed 0.1.0 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "daswetter" : 3.1.10 , installed 3.1.10 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "easee" : 1.0.10 , installed 1.0.10 Adapter "ems-esp" : 2.2.0 , installed 2.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "heatingcontrol": 2.11.1 , installed 2.11.1 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hmip" : 1.20.0 , installed 1.20.0 Adapter "homeconnect" : 1.1.1 , installed 1.1.1 Adapter "hs100" : 2.1.2 , installed 2.1.2 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "km200" : 2.0.3 , installed 2.0.3 Adapter "meater" : 1.0.0 , installed 1.0.0 Adapter "mercedesme" : 0.1.1 , installed 0.1.1 Adapter "mihome-vacuum": 3.11.0 , installed 3.11.0 Adapter "nuki-extended": 2.6.5 , installed 2.6.5 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartgarden" : 2.0.0 , installed 2.0.0 Adapter "socketio" : 6.5.5 , installed 6.5.5 Adapter "solarlog" : 2.2.6 , installed 2.2.6 Adapter "trashschedule": 2.2.0 , installed 2.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.1.2 , installed 6.1.2 Adapter "wireguard" : 1.5.11 , installed 1.5.11 Adapter "worx" : 2.3.2 , installed 2.3.2 Adapter "ws" : 2.5.5 , installed 2.5.5 Adapter "zigbee" : 1.8.23 , installed 1.8.23 Objects and States Please stand by - This may take a while Objects: 15063 States: 13134 *** OS-Repositories and Updates *** Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 19896 634/sshd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 13138 390/cupsd tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 20239 624/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 19073 624/iobroker.js-con tcp6 0 0 :::8081 :::* LISTEN 1001 18152 703/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 26159 1291/io.web.0 tcp6 0 0 :::51989 :::* LISTEN 1001 26640 1777/io.nuki-extend tcp6 0 0 :::22 :::* LISTEN 0 19898 634/sshd tcp6 0 0 ::1:3350 :::* LISTEN 0 18692 625/xrdp-sesman tcp6 0 0 ::1:631 :::* LISTEN 0 13137 390/cupsd tcp6 0 0 :::3389 :::* LISTEN 109 20807 646/xrdp tcp6 0 0 :::61991 :::* LISTEN 1001 21278 1090/io.harmony.0 udp 0 0 0.0.0.0:51088 0.0.0.0:* 1001 18420 993/io.broadlink2.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 21279 1090/io.harmony.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16866 618/dhcpcd udp 0 0 0.0.0.0:48730 0.0.0.0:* 1001 18392 993/io.broadlink2.0 udp 0 0 0.0.0.0:631 0.0.0.0:* 0 13145 481/cups-browsed udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 18389 993/io.broadlink2.0 udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 21538 896/io.mihome-vacuu udp 0 0 0.0.0.0:53422 0.0.0.0:* 1001 20461 911/io.mihome-vacuu udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 15754 391/avahi-daemon: r udp 0 0 0.0.0.0:55575 0.0.0.0:* 108 15756 391/avahi-daemon: r udp6 0 0 :::39894 :::* 108 15757 391/avahi-daemon: r udp6 0 0 :::5353 :::* 108 15755 391/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-09-18 14:19:08.125 - debug: daswetter.0 (3046) insert NextHours.Location_1.Day_5.Hour_8.uv_index_value with 0 2023-09-18 14:19:08.142 - debug: daswetter.0 (3046) insert NextHours.Location_1.Day_5.Hour_8.windchill_value with 11 °C 2023-09-18 14:19:08.154 - debug: daswetter.0 (3046) insert NextHours.Location_1.Day_5.sunshineDuration with 1.44 2023-09-18 14:19:08.204 - debug: daswetter.0 (3046) hourly forecast done 2023-09-18 14:19:08.208 - debug: daswetter.0 (3046) exit, all done 2023-09-18 14:19:08.209 - debug: daswetter.0 (3046) timer killed 2023-09-18 14:19:08.210 - debug: daswetter.0 (3046) Plugin sentry destroyed 2023-09-18 14:19:08.211 - info: daswetter.0 (3046) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment 2023-09-18 14:19:08.735 - info: daswetter.0 (3046) cleaned everything up... 2023-09-18 14:19:08.760 - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-18 14:20:00.066 - info: host.raspberrypi4-iob instance system.adapter.dwd.0 started with pid 3854 2023-09-18 14:20:03.586 - info: dwd.0 (3854) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12 2023-09-18 14:20:05.029 - info: dwd.0 (3854) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-09-18 14:20:05.560 - info: host.raspberrypi4-iob instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-18 14:20:14.912 - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin 2023-09-18 14:20:14.919 - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin 2023-09-18 14:20:14.920 - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:20:15.826 - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:20:15.849 - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:20:16.130 - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:21:05.564 - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:22:42.227 - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:22:45.057 - info: host.raspberrypi4-iob Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json" 2023-09-18 14:23:11.735 - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 2023-09-18 14:23:11.740 - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin ============ Mark until here for C&P =============
2 Fragen
Generell node.js mit dem Skript aktualisieren?
Kannst Du mir einen Link schicken, wie ich den Rasp auf das neue OS umstellen kann, was weiter oben beschrieben wurde mit
Dann würde ich das auf Debian 11 'Bullseye' bringen, der Buster dürfte in Kürze auch für Raspbian OS abgekündigt werden. -
und in Kürze muss der Bookworm verfügbar sein.
Dann Backup machen, ganz neue Installation (64bit) und Backup zurückspielen -
solarlog Adapter startet nicht.kann ich erst einmal nichts sehen warum?
steht beim Start der Instanz irgendwas im log?
steht im Tester Thread zu controller v5 etwas passendes? -
Nein, updates für nodejs werden nun über die übliche Systempflege mit
sudo apt update sudo apt full-upgrade
mit laufen. Nur bei einem Wechsel der Empfehlung auf nodejs@20 würde das nochmal ein Thema. Aber ich vermute, bis dahin ist das Skript in ein
iob node-update
(oder ähnlich) Kommando überführt worden.Von Dingern wie
n
,nvm
und wie sie alle heißen also die Finger lassen, die sind für andere Fälle gedacht, nicht für eine Grundinstallation von nodejs (auf Debian-artigen Distributionen). -
Also VIS Startet nicht seit update auf JS-controller 5.x und der Solarlog Adapterhost.raspberrypi4-iob 2023-09-18 14:59:00.339 error instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION) solarlog.0 2023-09-18 14:58:59.618 error undefined is not a valid state value solarlog.0 2023-09-18 14:58:59.618 error Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39) solarlog.0 2023-09-18 14:58:59.612 error unhandled promise rejection: undefined is not a valid state value solarlog.0 2023-09-18 14:58:59.612 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.raspberrypi4-iob 2023-09-18 14:58:26.271 error instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION) solarlog.0 2023-09-18 14:58:25.555 error undefined is not a valid state value solarlog.0 2023-09-18 14:58:25.554 error Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39) solarlog.0 2023-09-18 14:58:25.545 error unhandled promise rejection: undefined is not a valid state value solarlog.0 2023-09-18 14:58:25.543 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
