    4. iobroker geht nicht nach stromausfall
      Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
      @esmax666 sagte in iobroker geht nicht nach stromausfall:
      kann mir jemand klären was ich genau mache sollte?
      Zu nächst (mal wieder...) NIE NIE NIE sudo vor iobroker setzen. Nie!
      Und dann bitte keine schiefen Bilder von deinem Monitor. So hübsch ist der nicht.
      Per SSH aufschalten und dann den Text in CodeTags eingebettet hier rein.
      iob diag
      sagt?
        Esmax666 @Thomas Braun last edited by
        Das:
        ubuntu@ubuntu:~$ iob diag
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start                                               Starts the js-con        troller
          iobroker stop                                                stops the js-cont        roller
          iobroker restart                                             Restarts js-contr        oller
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
          iobroker info                                                Shows the host in        fo
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter
          iobroker install <adapter>                                   Installs a specif        ied adapter
          iobroker rebuild <adapter>|self                              Rebuilds a specif        ied adapter
          iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter fr        om system
          iobroker del <adapter>.<instance>                            Remove adapter in        stance
          iobroker update [<repositoryUrl>]                            Update repository        and list adapters
          iobroker upgrade                                             Upgrade managemen        t
          iobroker upload                                              Upload management
          iobroker object                                              Object management
          iobroker state                                               State management
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
          iobroker list <type> [<filter>]                              List all entries,        like objects
          iobroker chmod <mode> <file>                                 Change file right        s
          iobroker chown <user> <group> <file>                         Change file owner        ship
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given        hostname
          iobroker set <adapter>.<instance>                            Change settings o        f adapter config
          iobroker license <license.file or license.text>              Update license by        given file
          iobroker cert                                                Certificate manag        ement
          iobroker clean <yes>                                         Clears all object        s and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specifi        ed backup
          iobroker validate <backup name or path>                      Validate a specif        ied backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance
          iobroker repo [<name>]                                       Show repo informa        tion
          iobroker uuid                                                Show uuid of the        installation
          iobroker unsetup                                             Reset license, in        stallation secret and language
          iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
          iobroker multihost                                           Multihost managem        ent
          iobroker compact                                             compact group man        agement
          iobroker plugin                                              Plugin management
          iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter
        Options:
              --help     Show help  [boolean]
          -v, --version  Show version  [boolean]
          @esmax666
          Dann
          iob stop
          iob fix
          iob start
          ...ABWARTEN...
          iob diag
            @thomas-braun said in iobroker geht nicht nach stromausfall:
            iob diag
            Skript v.2023-06-20
            *** BASE SYSTEM ***
               Static hostname: ubuntu
                     Icon name: computer
                    Machine ID: 551875df55414c0f832b43a896fe8ce5
                       Boot ID: a58fe4cd23274d7e86463c9c059dca8f
              Operating System: Ubuntu 21.04
                        Kernel: Linux 5.11.0-1027-raspi
                  Architecture: arm
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : armhf
            Systemuptime and Load:
             12:19:36 up 28 min,  1 user,  load average: 1.46, 1.33, 1.15
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Tue 2023-09-19 12:19:36 CEST
                       Universal time: Tue 2023-09-19 10:19:36 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            ubuntu
            /home/ubuntu
            ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           7.9G        175M        7.1G        3.0M        625M        7.6G
            Swap:            0B          0B          0B
            Total:         7.9G        175M        7.1G
                     7886 M total memory
                      176 M used memory
                      252 M active memory
                      327 M inactive memory
                     7084 M free memory
                      102 M buffer memory
                      522 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            Filesystem     Type   Size  Used Avail Use% Mounted on
            tmpfs          tmpfs  789M  4.0M  785M   1% /run
            /dev/sda2      ext4    57G  6.9G   48G  13% /
            tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
            /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
            tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
            [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
            [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
            Show mounted filesystems (real ones only):
            TARGET              SOURCE     FSTYPE   OPTIONS
            /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
            |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
            |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
            |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
            |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
            |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
            |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
            |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
            |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
            |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
            |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
            `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            3.2G    /var/
            1.9G    /var/log
            1.7G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
            1.2G    /var/lib
            Archived and active journals take up 1.6G in the file system.
            /opt/iobroker/backups:
            54M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            148M    /opt/iobroker/iobroker-data/
            129M    /opt/iobroker/iobroker-data/files
            59M     /opt/iobroker/iobroker-data/files/javascript.admin
            44M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
            9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
            9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
            4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
            4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v12.22.7
            /usr/bin/node           v12.22.7
            /usr/bin/npm            6.14.15
            /usr/bin/npx            6.14.15
            nodejs:
              Installed: 12.22.7-deb-1nodesource1
              Candidate: 12.22.12-deb-1nodesource1
              Version table:
                 12.22.12-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x hirsute/main armhf Packages
             *** 12.22.7-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 12.21.0~dfsg-3ubuntu1 500
                    500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
            No problems detected
              Ubuntu 21.04
              Zu alt, abgekündigt. Installier da was lebendiges, für einen Raspberry würde ich aber Raspberry OS in der 64Bit-Version 'Lite' empfehlen.
              VIEL zu alt. Bring das auf nodejs@18. Evtl. mit diesem Skript:
              https://forum.iobroker.net/topic/68035/iob-node-fix-skript
              Und die Ausgabe von iob diag ist nicht vollständig.
              Mach es nochmal, nachdem die nodejs-Version auf Stand ist.
                Zu alt, abgekündigt. Installier da was lebendiges, für einen Raspberry würde ich aber Raspberry OS in der 64Bit-Version empfehlen.
                ja aber aber ist doch nicht das Problem oder ? also früher hat das funjtionniert vor "stromausfall"
                Siehe code + Diag nochmal
                ioBroker nodejs fixer 2023-09-15
                Recommended nodejs-version is:  Cannot read system.config: null (OK when migrating or restoring)
                Checking your installation now. Please be patient!
                Your current setup is:
                We found these nodejs versions available for installation:
                nodejs:
                  Version table:
                Nothing to do, your installation is using the correct paths.
                You are running nodejs v12.22.7. Do you want to install recommended version  Cannot read system.config: null (OK when migrating or restoring)?
                Press <y> to continue or any other key to quit
                Trying to fix your installation now. Please be patient.
                Waiting for ioBroker to shut down - Give me a minute...
                *** These repos are active on your system:
                Ign:1 http://ports.ubuntu.com/ubuntu-ports hirsute InRelease
                Ign:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates InRelease
                Ign:3 http://ports.ubuntu.com/ubuntu-ports hirsute-backports InRelease
                Ign:4 http://ports.ubuntu.com/ubuntu-ports hirsute-security InRelease
                Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute Release
                  404  Not Found [IP: 2620:2d:4000:1::19 80]
                Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
                Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
                Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
                Reading package lists... Done
                E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute Release' no longer has a Release file.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release' no longer has a Release file.
                E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release' no longer has a Release file.
                E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-security Release' no longer has a Release file.
                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                Package: nodejs
                Pin: origin deb.nodesource.com
                Pin-Priority: 1001
                *** These repos are active after the adjustments:
                  404  Not Found [IP: 2620:2d:4000:1::16 80]
                Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
                Get:10 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                Installing the recommended nodejs version now!
                Building dependency tree... Done
                E: Version ' Cannot read system.config: null (OK when migrating or restoring)-1nodesource1' for 'nodejs' was not found
                Calculating upgrade... Done
                The following packages will be upgraded:
                  alsa-ucm-conf cloud-init command-not-found libasound2 libasound2-data libnetplan0 libssl1.1 linux-base linux-firmware netplan.io nodejs openssh-client openssh-server openssh-sftp-server openssl
                  python3-commandnotfound python3-software-properties software-properties-common sosreport ubuntu-advantage-tools ufw update-notifier-common usrmerge
                23 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 190 MB of archives.
                After this operation, 93.2 MB of additional disk space will be used.
                Do you want to continue? [Y/n] Y
                Err:1 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf update-notifier-common all 3.192.40.4
                Err:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libssl1.1 armhf 1.1.1j-1ubuntu3.6
                Err:3 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf usrmerge all 24ubuntu3.1
                Err:4 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libnetplan0 armhf 0.103-0ubuntu5~21.04.4
                Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf netplan.io armhf 0.103-0ubuntu5~21.04.4
                Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssl armhf 1.1.1j-1ubuntu3.6
                Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf ubuntu-advantage-tools armhf 27.5~21.04.1
                Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf command-not-found all 20.10.2
                Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf python3-commandnotfound all 20.10.2
                Err:10 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-sftp-server armhf 1:8.4p1-5ubuntu1.2
                Err:11 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-server armhf 1:8.4p1-5ubuntu1.2
                Err:12 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-client armhf 1:8.4p1-5ubuntu1.2
                Err:13 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf ufw all 0.36-7.1ubuntu1
                Err:14 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libasound2 armhf 1.2.4-1.1ubuntu2.1
                Err:15 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libasound2-data all 1.2.4-1.1ubuntu2.1
                Err:16 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf alsa-ucm-conf all 1.2.4-2ubuntu1.4
                Err:17 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf linux-base all 4.5ubuntu5.4
                Err:18 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf linux-firmware all 1.197.5
                Err:19 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf software-properties-common all 0.99.10.2
                Err:20 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf python3-software-properties all 0.99.10.2
                Err:21 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf sosreport armhf 4.2-1ubuntu0.21.04.1
                Err:22 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf cloud-init all 21.4-0ubuntu1~21.04.1
                Get:23 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.18.0-1nodesource1 [26.8 MB]
                Fetched 26.8 MB in 3s (7858 kB/s)
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/update-notifier/update-notifier-common_3.192.40.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssl/libssl1.1_1.1.1j-1ubuntu3.6_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/usrmerge/usrmerge_24ubuntu3.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/netplan.io/libnetplan0_0.103-0ubuntu5%7e21.04.4_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/netplan.io/netplan.io_0.103-0ubuntu5%7e21.04.4_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssl/openssl_1.1.1j-1ubuntu3.6_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.5%7e21.04.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/command-not-found/command-not-found_20.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/command-not-found/python3-commandnotfound_20.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-sftp-server_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-server_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-client_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/ufw/ufw_0.36-7.1ubuntu1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-lib/libasound2_1.2.4-1.1ubuntu2.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-lib/libasound2-data_1.2.4-1.1ubuntu2.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-ucm-conf/alsa-ucm-conf_1.2.4-2ubuntu1.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-base/linux-base_4.5ubuntu5.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-firmware/linux-firmware_1.197.5_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/software-properties/software-properties-common_0.99.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/software-properties/python3-software-properties_0.99.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/sosreport/sosreport_4.2-1ubuntu0.21.04.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/cloud-init/cloud-init_21.4-0ubuntu1%7e21.04.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
                E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                We tried our best to fix your nodejs. Please run iob diag again to verify.
                *** RESTARTING ioBroker NOW! ***
                 Please refresh or restart your browser in a few moments.
                Diag: ( am ende war das blokiert mit " Cannot read system.config: null (OK when migrating or restoring)" )
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                 12:43:23 up 52 min,  1 user,  load average: 1.20, 1.21, 1.24
                CPU threads: 4
                               Local time: Tue 2023-09-19 12:43:24 CEST
                           Universal time: Tue 2023-09-19 10:43:24 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                ubuntu
                /home/ubuntu
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           7.9G        188M        6.9G        3.0M        832M        7.6G
                Swap:            0B          0B          0B
                Total:         7.9G        188M        6.9G
                         7886 M total memory
                          188 M used memory
                          484 M active memory
                          274 M inactive memory
                         6865 M free memory
                          226 M buffer memory
                          606 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /var:
                3.2G    /var/
                1.9G    /var/log
                1.2G    /var/lib
                149M    /opt/iobroker/iobroker-data/
                nodejs:
                  Candidate: 18.18.0-1nodesource1
                  Version table:
                     18.18.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                iobroker is not running on this host.
                Objects type: file
                States  type: file
                No configuration change needed.
                Multihost discovery server: disabled
                Discovery authentication:   enabled
                Persistent activation:      disabled
                Objects:                    file on 127.0.0.1
                States:                     file on 127.0.0.1
                Core adapters versions
                js-controller:  3.3.18
                admin:          5.2.1
                javascript:     5.2.13
                Adapters from github:   2
                Adapter State
                + instance is alive
                ioBroker-Repositories
                Cannot get list: undefined
                Installed ioBroker-Instances
                Error: Object "system.config" not found
                E Thomas Braun 2 Replies Last reply Reply Quote 0
                  Esmax666 @Esmax666 last edited by
                  und das war für FIX:
                  ubuntu@ubuntu:~$ iob fix
                  library: loaded
                  Library version=2022-12-09
                      Welcome to the ioBroker installation fixer!
                      Script version: 2023-04-02
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/5)
                  Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
                  Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
                  Installed gcc-c++
                  Installed cmake
                      Checking ioBroker user and directory permissions (2/5)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Check and cleanup npm temporary directories (3/5)
                  Done.
                      Database maintenance (4/5)
                  Checking for uncompressed JSONL databases... This might take a while!
                  npx: installed 12 in 6.831s
                  No path given, using /opt/iobroker/iobroker-data
                  No relevant JSONL files found to compress, skip
                      Checking autostart (5/5)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  ubuntu@ubuntu:~$
                    Nein, aber abgekündigte, nicht mehr gewartete Versionen sind immer ein Problem. Ja länger die Leiche da rumgammelt, umso schwieriger wird der Umgang mit dem Kadaver. Weg damit.
                    Das sind nämlich die Folgen daraus:
                    Und deswegen funktioniert da auch nix mehr, was Software-Installationen angeht. Ist halt tot...
                    sudo apt install nodejs=18.18.0-1nodesource1
                    liefert?
                      ubuntu@ubuntu:~$ sudo apt install nodejs=18.18.0-1nodesource1
                        nodejs
                      1 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
                      Need to get 0 B/26.8 MB of archives.
                      After this operation, 91.4 MB of additional disk space will be used.
                      (Reading database ... 116546 files and directories currently installed.)
                      Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
                      Detected old npm client, removing...
                      Unpacking nodejs (18.18.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
                      Setting up nodejs (18.18.0-1nodesource1) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      Scanning processes...
                      Scanning processor microcode...
                      Scanning linux images...
                      Running kernel seems to be up-to-date.
                      Failed to check for processor microcode upgrades.
                      No services need to be restarted.
                      No containers need to be restarted.
                      No user sessions are running outdated binaries.
                      ubuntu@ubuntu:~$
                        @esmax666
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                        iob restart
                            nodejs
                          ubuntu@ubuntu:~$ ^C
                          ubuntu@ubuntu:~$ cd /opt/iobroker
                          ubuntu@ubuntu:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                          npm WARN old lockfile
                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                          changed 1 package in 9m
                          85 packages are looking for funding
                            run `npm fund` for details
                          ubuntu@ubuntu:/opt/iobroker$ iob restart
                          und nochmal diag
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : armhf
                           13:34:12 up  1:43,  1 user,  load average: 0.99, 0.93, 1.00
                          CPU threads: 4
                                         Local time: Tue 2023-09-19 13:34:12 CEST
                                     Universal time: Tue 2023-09-19 11:34:12 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          ubuntu
                          /home/ubuntu
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           7.9G        184M        6.6G        3.0M        1.1G        7.6G
                          Swap:            0B          0B          0B
                          Total:         7.9G        184M        6.6G
                                   7886 M total memory
                                    184 M used memory
                                    544 M active memory
                                    464 M inactive memory
                                   6595 M free memory
                                    236 M buffer memory
                                    870 M swap cache
                                      0 M total swap
                                      0 M used swap
                                      0 M free swap
                          *** FILESYSTEM ***
                          /dev/sda2      ext4    57G  7.0G   48G  13% /
                          /var:
                          3.2G    /var/
                          1.9G    /var/log
                          1.2G    /var/lib
                          /usr/bin/nodejs         v18.18.0
                          /usr/bin/node           v18.18.0
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Installed: 18.18.0-1nodesource1
                            Version table:
                           *** 18.18.0-1nodesource1 1001
                          ioBroker Status
                           Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          No connection to databases possible ...
                          js-controller:  3.3.22
                          admin:          5.2.1
                          javascript:     5.2.13
                          Adapters from github:   0
                          Adapter State
                          + instance is alive
                          latest      : http://download.iobroker.net/sources-dist-latest.json
                          stable      : http://download.iobroker.net/sources-dist.json
                          Active repo: stable
                          Used repository: stable
                          hash changed or no sources cached => force download of new sources
                          Cannot get any information of "_repoInfo". Ignored.
                          update done
                           Cannot find view "system" for search "instance"
                          Error: Cannot find view "system"
                              at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                          Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
                          Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
                          Adapter    "backitup"      : 2.6.23   , installed 2.2.2 [Updateable]
                          Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                          Adapter    "discovery"     : 3.1.0    , installed 2.7.0 [Updateable]
                          Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                          Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
                          Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
                          Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
                          Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
                          Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
                          Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
                          Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
                          Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
                          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                          Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
                          Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
                          Adapter    "shuttercontrol": 1.6.1    , installed 1.2.1 [Updateable]
                          Adapter    "simple-api"    : 2.7.2    , installed 2.6.2 [Updateable]
                          Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
                          Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
                          Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
                          Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
                          Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
                          Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
                          Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
                          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                          Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
                          Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                          Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
                          Adapter    "zwave2"        : 3.0.5    , installed 2.4.1 [Updateable]
                          Objects and States
                          Objects:        11
                          States:         21
                          Pending Updates: 22
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287610     4905/iobroker.js-co
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        39620      1926/systemd-resolv
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38625      2046/sshd: /usr/sbi
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          38627      2046/sshd: /usr/sbi
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        39619      1926/systemd-resolv
                          udp        0      0 192.168.178.51:68       0.0.0.0:*                           100        41269      1924/systemd-networ
                          udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                100        40545      1924/systemd-networ
                          2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "state"
                          2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "instance"
                          2023-09-19 13:35:02.368  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Error: Cannot find view "system"
                          2023-09-19 13:35:02.369  - error: host.ubuntu _design/system missing - call node iobroker.js setup
                          2023-09-19 13:35:02.369  - info: host.ubuntu no instances found
                          2023-09-19 13:35:02.384  - error: host.ubuntu uncaught exception: doc.rows is not iterable
                          2023-09-19 13:35:02.385  - error: host.ubuntu TypeError: doc.rows is not iterable
                              at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
                              at getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
                          2023-09-19 13:35:02.395  - info: host.ubuntu iobroker _restart
                          2023-09-19 13:35:02.443  - error: host.ubuntu Cannot write host object:Error: DB closed
                          2023-09-19 13:35:02.705  - info: host.ubuntu terminated
                          2023-09-19 13:35:03.353  - info: host.ubuntu iobroker Starting node restart.js
                          2023-09-19 13:35:05.193  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
                          2023-09-19 13:35:05.199  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                          2023-09-19 13:35:05.200  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
                          2023-09-19 13:35:05.201  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
                          2023-09-19 13:35:05.343  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
                          2023-09-19 13:35:35.225  - error: host.ubuntu No connection to databases possible, restart
                          2023-09-19 13:35:35.235  - info: host.ubuntu iobroker _restart
                          2023-09-19 13:35:40.760  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
                          2023-09-19 13:35:40.765  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                          2023-09-19 13:35:40.767  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
                          2023-09-19 13:35:40.768  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
                          2023-09-19 13:35:41.092  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
                          iob diag has finished.
                          Press any key for a summary
                            Steinalt. Wie der Rest von der Kiste halt auch...
                            Versuch es damit
                            iob update
                            iob upgrade all -y
                            iob stop
                            iob fix
                            iob upgrade self
                            iob restart
                            E OliverIO 2 Replies Last reply Reply Quote 1
                              iob stop
                              ich bekomme schonn hier fehler
                              ubuntu@ubuntu:/opt/iobroker$ iob update
                              hash unchanged, use cached sources
                              update done
                                  at ObjectsInMemoryServerClass._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                              ubuntu@ubuntu:/opt/iobroker$ iob upgrade all -y
                              • OliverIO
                                OliverIO @Thomas Braun last edited by
                                @thomas-braun sagte in iobroker geht nicht nach stromausfall:
                                ich glaube mich dunkel daran zu erinnern, das man von so alten installationen nicht in einem rutsch auf aktuell aktualisieren kann.
                                ich musste damals erst auf die letzte 3er version mit npm install den js-controller aktualisieren und dann ging es wieder mit iob upgrade weiter.
                                das ist aber nicht sicher, wie gesagt kann mich nur dunkel daran erinnern.
                                auch das einspielen eines backups könnte von so alten versionen problematisch sein. aber da müssen sich hier noch andere dazu äußern
                                Thomas Braun E 2 Replies Last reply Reply Quote 1
                                  Thomas Braun Most Active @OliverIO last edited by
                                  @oliverio
                                  Ich hatte mich jetzt hieran orientiert:
                                  Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt.
                                  Eine zwingende Installation von Vorversionen lese ich da nicht heraus.
                                  OliverIO 1 Reply Last reply Reply Quote 1
                                  • OliverIO
                                    OliverIO @Thomas Braun last edited by OliverIO
                                    wenn es klappt, dann gut
                                    ist gesichert, das sein Datenspeicher noch gut ist?
                                    Nach Stromausfall zicken manchmal die SD-Cards rum
                                    Thomas Braun 2 Replies Last reply Reply Quote 1
                                      @oliverio sagte in iobroker geht nicht nach stromausfall:
                                      Offenbar klappt es nicht.
                                      Da gab es aber auch schon mal was gegen. Ich hab nur gerade kein Heilmittel parat.
                                        Ja, die fressen dann offene files...
                                        Ist hier ja auch offenbar passiert.
                                        • OliverIO
                                          Die Fehlermeldung scheint auf redis hinzuweisen, das er da die system.* datenpunkte nicht findet.
                                          evtl ist die redis db kaputt
                                          Thomas Braun Homoran 2 Replies Last reply Reply Quote 1
                                            @oliverio
                                            Da hab ich überhaupt keine Aktien drin.
                                            Damals war glaube ich File/File der Standard?
                                            10396
