    4. iobroker geht nicht nach stromausfall
      Esmax666 @Esmax666 last edited by
      und das war für FIX:
      ubuntu@ubuntu:~$ iob fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Ign:1 http://ports.ubuntu.com/ubuntu-ports hirsute InRelease
      Ign:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates InRelease
      Ign:3 http://ports.ubuntu.com/ubuntu-ports hirsute-backports InRelease
      Ign:4 http://ports.ubuntu.com/ubuntu-ports hirsute-security InRelease
      Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute Release
        404  Not Found [IP: 2620:2d:4000:1::16 80]
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
      Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
      Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
      Reading package lists... Done
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute Release' no longer has a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-security Release' no longer has a Release file.
      Installed gcc-c++
      Installed cmake
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      npx: installed 12 in 6.831s
      No path given, using /opt/iobroker/iobroker-data
      No relevant JSONL files found to compress, skip
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      ubuntu@ubuntu:~$
        Thomas Braun Most Active @Esmax666 last edited by
        @esmax666 sagte in iobroker geht nicht nach stromausfall:
        ja aber aber ist doch nicht das Problem oder ? also früher hat das funjtionniert vor "stromausfall"
        Nein, aber abgekündigte, nicht mehr gewartete Versionen sind immer ein Problem. Ja länger die Leiche da rumgammelt, umso schwieriger wird der Umgang mit dem Kadaver. Weg damit.
        Das sind nämlich die Folgen daraus:
        Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
        404 Not Found [IP: 2620:2d:4000:1::19 80]
        Und deswegen funktioniert da auch nix mehr, was Software-Installationen angeht. Ist halt tot...
        sudo apt install nodejs=18.18.0-1nodesource1
        liefert?
          Esmax666 @Thomas Braun last edited by
          ubuntu@ubuntu:~$ sudo apt install nodejs=18.18.0-1nodesource1
          Building dependency tree... Done
          The following packages will be upgraded:
            nodejs
          1 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
          Need to get 0 B/26.8 MB of archives.
          After this operation, 91.4 MB of additional disk space will be used.
          (Reading database ... 116546 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.18.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
          Setting up nodejs (18.18.0-1nodesource1) ...
          Processing triggers for man-db (2.9.4-2) ...
          Scanning processes...
          Scanning processor microcode...
          Scanning linux images...
          Running kernel seems to be up-to-date.
          Failed to check for processor microcode upgrades.
          No services need to be restarted.
          No containers need to be restarted.
          No user sessions are running outdated binaries.
          ubuntu@ubuntu:~$
            @esmax666
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iob restart
                nodejs
              ubuntu@ubuntu:~$ ^C
              ubuntu@ubuntu:~$ cd /opt/iobroker
              ubuntu@ubuntu:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
              npm WARN old lockfile
              npm WARN old lockfile The package-lock.json file was created with an old version of npm,
              npm WARN old lockfile so supplemental metadata must be fetched from the registry.
              npm WARN old lockfile This is a one-time fix-up, please be patient...
              changed 1 package in 9m
              85 packages are looking for funding
                run `npm fund` for details
              ubuntu@ubuntu:/opt/iobroker$ iob restart
              und nochmal diag
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                 Static hostname: ubuntu
                       Icon name: computer
                      Machine ID: 551875df55414c0f832b43a896fe8ce5
                         Boot ID: a58fe4cd23274d7e86463c9c059dca8f
                Operating System: Ubuntu 21.04
                          Kernel: Linux 5.11.0-1027-raspi
                    Architecture: arm
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
               13:34:12 up  1:43,  1 user,  load average: 0.99, 0.93, 1.00
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Tue 2023-09-19 13:34:12 CEST
                         Universal time: Tue 2023-09-19 11:34:12 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              ubuntu
              /home/ubuntu
              ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           7.9G        184M        6.6G        3.0M        1.1G        7.6G
              Swap:            0B          0B          0B
              Total:         7.9G        184M        6.6G
                       7886 M total memory
                        184 M used memory
                        544 M active memory
                        464 M inactive memory
                       6595 M free memory
                        236 M buffer memory
                        870 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              Filesystem     Type   Size  Used Avail Use% Mounted on
              tmpfs          tmpfs  789M  4.0M  785M   1% /run
              /dev/sda2      ext4    57G  7.0G   48G  13% /
              tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
              /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
              tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
              [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
              [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET              SOURCE     FSTYPE   OPTIONS
              /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
              |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
              |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
              |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
              |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
              |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
              |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
              |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
              |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
              |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
              |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
              `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              3.2G    /var/
              1.9G    /var/log
              1.7G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
              1.2G    /var/lib
              Archived and active journals take up 1.6G in the file system.
              /opt/iobroker/backups:
              54M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              149M    /opt/iobroker/iobroker-data/
              129M    /opt/iobroker/iobroker-data/files
              59M     /opt/iobroker/iobroker-data/files/javascript.admin
              44M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
              9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
              9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
              4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
              4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.0
              /usr/bin/node           v18.18.0
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Installed: 18.18.0-1nodesource1
                Candidate: 18.18.0-1nodesource1
                Version table:
               *** 18.18.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                      100 /var/lib/dpkg/status
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.21.0~dfsg-3ubuntu1 500
                      500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
               Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              No connection to databases possible ...
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    file on 127.0.0.1
              States:                     file on 127.0.0.1
              Core adapters versions
              js-controller:  3.3.22
              admin:          5.2.1
              javascript:     5.2.13
              Adapters from github:   0
              Adapter State
              + instance is alive
              ioBroker-Repositories
              latest      : http://download.iobroker.net/sources-dist-latest.json
              stable      : http://download.iobroker.net/sources-dist.json
              Active repo: stable
              Installed ioBroker-Instances
              Used repository: stable
              hash changed or no sources cached => force download of new sources
              Cannot get any information of "_repoInfo". Ignored.
              update done
               Cannot find view "system" for search "instance"
              Error: Cannot find view "system"
                  at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
              Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
              Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
              Adapter    "backitup"      : 2.6.23   , installed 2.2.2 [Updateable]
              Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
              Adapter    "discovery"     : 3.1.0    , installed 2.7.0 [Updateable]
              Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
              Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
              Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
              Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
              Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
              Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
              Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
              Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
              Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
              Adapter    "mobile"        : 1.0.1    , installed 1.0.1
              Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
              Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
              Adapter    "shuttercontrol": 1.6.1    , installed 1.2.1 [Updateable]
              Adapter    "simple-api"    : 2.7.2    , installed 2.6.2 [Updateable]
              Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
              Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
              Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
              Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
              Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
              Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
              Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
              Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
              Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
              Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
              Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
              Adapter    "zwave2"        : 3.0.5    , installed 2.4.1 [Updateable]
              Objects and States
              Objects:        11
              States:         21
              Pending Updates: 22
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287610     4905/iobroker.js-co
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        39620      1926/systemd-resolv
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38625      2046/sshd: /usr/sbi
              tcp6       0      0 :::22                   :::*                    LISTEN      0          38627      2046/sshd: /usr/sbi
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        39619      1926/systemd-resolv
              udp        0      0 192.168.178.51:68       0.0.0.0:*                           100        41269      1924/systemd-networ
              udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                100        40545      1924/systemd-networ
              2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "state"
              2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "instance"
              2023-09-19 13:35:02.368  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Error: Cannot find view "system"
              2023-09-19 13:35:02.369  - error: host.ubuntu _design/system missing - call node iobroker.js setup
              2023-09-19 13:35:02.369  - info: host.ubuntu no instances found
              2023-09-19 13:35:02.384  - error: host.ubuntu uncaught exception: doc.rows is not iterable
              2023-09-19 13:35:02.385  - error: host.ubuntu TypeError: doc.rows is not iterable
                  at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
                  at getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
              2023-09-19 13:35:02.395  - info: host.ubuntu iobroker _restart
              2023-09-19 13:35:02.443  - error: host.ubuntu Cannot write host object:Error: DB closed
              2023-09-19 13:35:02.705  - info: host.ubuntu terminated
              2023-09-19 13:35:03.353  - info: host.ubuntu iobroker Starting node restart.js
              2023-09-19 13:35:05.193  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
              2023-09-19 13:35:05.199  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
              2023-09-19 13:35:05.200  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
              2023-09-19 13:35:05.201  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
              2023-09-19 13:35:05.343  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
              2023-09-19 13:35:35.225  - error: host.ubuntu No connection to databases possible, restart
              2023-09-19 13:35:35.235  - info: host.ubuntu iobroker _restart
              2023-09-19 13:35:40.760  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
              2023-09-19 13:35:40.765  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
              2023-09-19 13:35:40.767  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
              2023-09-19 13:35:40.768  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
              2023-09-19 13:35:41.092  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
              iob diag has finished.
              Press any key for a summary
                Steinalt. Wie der Rest von der Kiste halt auch...
                Versuch es damit
                iob update
                iob upgrade all -y
                iob stop
                iob fix
                iob upgrade self
                iob restart
                E OliverIO 2 Replies Last reply Reply Quote 1
                  @thomas-braun said in iobroker geht nicht nach stromausfall:
                  iob stop
                  ich bekomme schonn hier fehler
                  ubuntu@ubuntu:/opt/iobroker$ iob update
                  hash unchanged, use cached sources
                  update done
                      at ObjectsInMemoryServerClass._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                  ubuntu@ubuntu:/opt/iobroker$ iob upgrade all -y
                  • OliverIO
                    OliverIO @Thomas Braun last edited by
                    @thomas-braun sagte in iobroker geht nicht nach stromausfall:
                    ich glaube mich dunkel daran zu erinnern, das man von so alten installationen nicht in einem rutsch auf aktuell aktualisieren kann.
                    ich musste damals erst auf die letzte 3er version mit npm install den js-controller aktualisieren und dann ging es wieder mit iob upgrade weiter.
                    das ist aber nicht sicher, wie gesagt kann mich nur dunkel daran erinnern.
                    auch das einspielen eines backups könnte von so alten versionen problematisch sein. aber da müssen sich hier noch andere dazu äußern
                    Thomas Braun E 2 Replies Last reply Reply Quote 1
                      Thomas Braun Most Active @OliverIO last edited by
                      @oliverio
                      Ich hatte mich jetzt hieran orientiert:
                      Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt.
                      Eine zwingende Installation von Vorversionen lese ich da nicht heraus.
                      OliverIO 1 Reply Last reply Reply Quote 1
                      • OliverIO
                        OliverIO @Thomas Braun last edited by OliverIO
                        wenn es klappt, dann gut
                        ist gesichert, das sein Datenspeicher noch gut ist?
                        Nach Stromausfall zicken manchmal die SD-Cards rum
                        Thomas Braun 2 Replies Last reply Reply Quote 1
                          @oliverio sagte in iobroker geht nicht nach stromausfall:
                          Offenbar klappt es nicht.
                          Da gab es aber auch schon mal was gegen. Ich hab nur gerade kein Heilmittel parat.
                            Ja, die fressen dann offene files...
                            Ist hier ja auch offenbar passiert.
                            • OliverIO
                              Die Fehlermeldung scheint auf redis hinzuweisen, das er da die system.* datenpunkte nicht findet.
                              evtl ist die redis db kaputt
                              Thomas Braun Homoran 2 Replies Last reply Reply Quote 1
                                @oliverio
                                Da hab ich überhaupt keine Aktien drin.
                                Damals war glaube ich File/File der Standard?
                                  Esmax666 @OliverIO last edited by
                                  @oliverio was soll dann genau machen ?
                                    @esmax666
                                    Hast du redis verwendet?
                                    apt policy redis*
                                    sagt?
                                      apt policy redis*
                                      ubuntu@ubuntu:/opt/iobroker$ apt policy redis*
                                      redis-server:
                                        Installed: (none)
                                        Candidate: 5:6.0.11-1
                                        Version table:
                                           5:6.0.11-1 500
                                      redis-redisearch-doc:
                                        Installed: (none)
                                        Candidate: 1:1.2.2-3
                                        Version table:
                                           1:1.2.2-3 500
                                      redis-sentinel:
                                        Installed: (none)
                                        Version table:
                                           5:6.0.11-1 500
                                      redis-tools:
                                        Installed: (none)
                                        Version table:
                                           5:6.0.11-1 500
                                      redis-redisearch:
                                        Installed: (none)
                                        Version table:
                                           1:1.2.2-3 500
                                      redis:
                                        Installed: (none)
                                        Version table:
                                           5:6.0.11-1 500
                                      redis:
                                        Installed: (none)
                                        Version table:
                                           5:6.0.11-1 500
                                        Demnach kann das nicht direkt über redis gelaufen sein. Sonst müsste da irgendwas aus der Ecke installiert sein.
                                        cd /opt/iobroker
                                        npm install iobroker.js-controller@4.0.24
                                        liefert?
                                          ubuntu@ubuntu:/opt/iobroker$ cd /opt/iobroker
                                          ubuntu@ubuntu:/opt/iobroker$ npm install iobroker.js-controller@4.0.24
                                          added 48 packages, removed 33 packages, and changed 52 packages in 1m
                                          86 packages are looking for funding
                                          ubuntu@ubuntu:/opt/iobroker$ ~^C
                                          redis-server:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                            Installed: (none)
                                            Version table:
                                               1:1.2.2-3 500
                                          redis-sentinel:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                          redis-tools:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                          redis-redisearch:
                                            Installed: (none)
                                            Version table:
                                               1:1.2.2-3 500
                                          redis:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                            @esmax666
                                            iob restart
                                            ...etwas abwarten...
                                            iob status
                                            10395
