    4. iobroker geht nicht nach stromausfall
      Thomas Braun Most Active @OliverIO last edited by
      @oliverio
      Da hab ich überhaupt keine Aktien drin.
      Damals war glaube ich File/File der Standard?
        Esmax666 @OliverIO last edited by
        @oliverio was soll dann genau machen ?
          Thomas Braun Most Active @Esmax666 last edited by
          @esmax666
          Hast du redis verwendet?
          apt policy redis*
          sagt?
            Esmax666 @Thomas Braun last edited by
            @thomas-braun said in iobroker geht nicht nach stromausfall:
            apt policy redis*
            ubuntu@ubuntu:/opt/iobroker$ apt policy redis*
            redis-server:
              Installed: (none)
              Candidate: 5:6.0.11-1
              Version table:
                 5:6.0.11-1 500
                    500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
            redis-redisearch-doc:
              Installed: (none)
              Candidate: 1:1.2.2-3
              Version table:
                 1:1.2.2-3 500
            redis-sentinel:
              Installed: (none)
              Version table:
                 5:6.0.11-1 500
            redis-tools:
              Installed: (none)
              Version table:
                 5:6.0.11-1 500
            redis-redisearch:
              Installed: (none)
              Version table:
                 1:1.2.2-3 500
            redis:
              Installed: (none)
              Version table:
                 5:6.0.11-1 500
            redis:
              Installed: (none)
              Version table:
                 5:6.0.11-1 500
              @esmax666 sagte in iobroker geht nicht nach stromausfall:
              Demnach kann das nicht direkt über redis gelaufen sein. Sonst müsste da irgendwas aus der Ecke installiert sein.
              cd /opt/iobroker
              npm install iobroker.js-controller@4.0.24
              liefert?
              E 2 Replies Last reply Reply Quote 1
                ubuntu@ubuntu:/opt/iobroker$ cd /opt/iobroker
                ubuntu@ubuntu:/opt/iobroker$ npm install iobroker.js-controller@4.0.24
                added 48 packages, removed 33 packages, and changed 52 packages in 1m
                86 packages are looking for funding
                  run `npm fund` for details
                ubuntu@ubuntu:/opt/iobroker$ ~^C
                redis-server:
                  Installed: (none)
                  Version table:
                     5:6.0.11-1 500
                  Installed: (none)
                  Version table:
                     1:1.2.2-3 500
                redis-sentinel:
                  Installed: (none)
                  Version table:
                     5:6.0.11-1 500
                redis-tools:
                  Installed: (none)
                  Version table:
                     5:6.0.11-1 500
                redis-redisearch:
                  Installed: (none)
                  Version table:
                     1:1.2.2-3 500
                redis:
                  Installed: (none)
                  Version table:
                     5:6.0.11-1 500
                  @esmax666
                  iob restart
                  ...etwas abwarten...
                  iob status
                    iob status
                    ubuntu@ubuntu:/opt/iobroker$ iob restart
                    ubuntu@ubuntu:/opt/iobroker$ iob status
                    Objects type: jsonl
                    States  type: jsonl
                      @esmax666
                      Okay, schaut schon besser aus.
                      iob update
                      iob upgrade all -y
                        iob upgrade all -y
                        ok läuft er braucht noch ein bisschen zeit 😧
                          Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
                          @esmax666
                          Klar, da muss ja jetzt jeder Adapter eine Zeitreise in die Gegenwart antreten.
                          Kannst 'ne Runde spazieren gehen. Das wird länger dauern.
                            @thomas-braun ja klar, und wenn es fertig is soll ich ein ubuntu update nochmachen ?
                            also
                            sudo apt-get update
                            sudo apt-get upgrade
                            sudo reboot
                              Homoran Global Moderator Administrators @OliverIO last edited by
                              @oliverio sagte in iobroker geht nicht nach stromausfall:
                              Die Fehlermeldung scheint auf redis hinzuweisen, das er da die system.* datenpunkte nicht findet.
                              evtl ist die redis db kaputt
                              Error: **Cannot find view "system"**
                                  at ObjectsInMemoryServerClass._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                              hab ich nur noch von hier in Erinnerung
                              https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host
                                Update ist done:
                                ubuntu@ubuntu:/opt/iobroker$ iob update
                                Used repository: stable
                                Adapter    "admin"        : 6.10.1   , installed 5.2.1  [Updatable]
                                Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
                                Adapter    "backitup"     : 2.6.23   , installed 2.2.2  [Updatable]
                                Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
                                Adapter    "discovery"    : 3.1.0    , installed 2.7.0  [Updatable]
                                Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                                Adapter    "heatingcontrol": 2.11.1  , installed 2.7.2  [Updatable]
                                Adapter    "history"      : 2.2.6    , installed 1.9.14 [Updatable]
                                Adapter    "ical"         : 1.13.3   , installed 1.11.4 [Updatable]
                                Adapter    "info"         : 1.9.26   , installed 1.9.8  [Updatable]
                                Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
                                Adapter    "javascript"   : 7.1.4    , installed 5.2.13 [Updatable]
                                Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                                Adapter    "linkeddevices": 1.5.5    , installed 1.4.3  [Updatable]
                                Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
                                Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                                Adapter    "shuttercontrol": 1.6.1   , installed 1.2.1  [Updatable]
                                Adapter    "simple-api"   : 2.7.2    , installed 2.6.2  [Updatable]
                                Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
                                Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
                                Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
                                Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
                                Adapter    "vis"          : 1.4.16   , installed 1.4.5  [Updatable]
                                Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                                Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                                Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                                Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                                Adapter    "web"          : 6.1.2    , installed 3.4.9  [Updatable]
                                Adapter    "zwave2"       : 3.0.5    , installed 2.4.1  [Updatable]
                                ubuntu@ubuntu:/opt/iobroker$ iob upgrade all -y
                                Update zwave2 from @2.4.1 to @3.0.5
                                NPM version: 9.8.1
                                Installing iobroker.zwave2@3.0.5... (System call)
                                added 58 packages, removed 57 packages, and changed 35 packages in 30s
                                107 packages are looking for funding
                                upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                                upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
                                upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
                                upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
                                upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
                                upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
                                upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
                                upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                                upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                                upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                                upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                                upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                                upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                                upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                                upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                                upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                                upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                                upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                                upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                                Cannot check dependencies: Required dependency "vis" not found on this host.
                                Update tr-064 from @4.2.14 to @4.2.18
                                NPM version: 9.8.1
                                Installing iobroker.tr-064@4.2.18... (System call)
                                changed 1 package in 7s
                                upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                Update text2command from @2.1.1 to @3.0.2
                                NPM version: 9.8.1
                                Installing iobroker.text2command@3.0.2... (System call)
                                changed 1 package in 8s
                                upload [131] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/asset-manifest.json asset-manifest.json application/json
                                upload [100] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Corridor.93a742135f2c060ad619.svg static/media/Corridor.93a742135f2c060ad619.svg image/svg+xml
                                upload [90] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Dryer.5ea89bd6dc20a00fb442.svg static/media/Dryer.5ea89bd6dc20a00fb442.svg image/svg+xml
                                upload [80] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Gates.5a8baf2c3d4832ca57e8.svg static/media/Gates.5a8baf2c3d4832ca57e8.svg image/svg+xml
                                upload [70] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Home Theater.1e5f19a0b2a013f153f5.svg static/media/Home Theater.1e5f19a0b2a013f153f5.svg image/svg+xml
                                upload [60] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Lightings.658080eb8c0e347cd152.svg static/media/Lightings.658080eb8c0e347cd152.svg image/svg+xml
                                upload [50] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Outdoor Blinds.37b85a9c060a4af48da9.svg static/media/Outdoor Blinds.37b85a9c060a4af48da9.svg image/svg+xml
                                upload [40] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Sconces.9bf4c2f7a209085207aa.svg static/media/Sconces.9bf4c2f7a209085207aa.svg image/svg+xml
                                upload [30] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Stairway.9b007e08605296110003.svg static/media/Stairway.9b007e08605296110003.svg image/svg+xml
                                upload [20] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                upload [19] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                upload [18] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                upload [17] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                upload [16] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                upload [15] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                upload [14] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                upload [13] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                upload [12] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                upload [11] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                upload [10] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                upload [9] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                upload [8] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                upload [7] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                upload [6] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                upload [5] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                upload [4] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                upload [3] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [2] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/style.css style.css text/css
                                upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/tab.html tab.html text/html
                                upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/text2command.png text2command.png image/png
                                Update simple-api from @2.6.2 to @2.7.2
                                NPM version: 9.8.1
                                Installing iobroker.simple-api@2.7.2... (System call)
                                upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                                upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                                upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
                                upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                                upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                                Update radar2 from @2.0.3 to @2.0.7
                                NPM version: 9.8.1
                                Installing iobroker.radar2@2.0.7... (System call)
                                added 19 packages, removed 3 packages, and changed 16 packages in 34s
                                upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
                                upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
                                upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/network_test.js network_test.js application/javascript
                                upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/node_ble_test.js node_ble_test.js application/javascript
                                upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
                                upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/tools.js tools.js application/javascript
                                upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/vendors.json vendors.json application/json
                                upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
                                upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.json words.json application/json
                                Update heatingcontrol from @2.7.2 to @2.11.1
                                NPM version: 9.8.1
                                Installing iobroker.heatingcontrol@2.11.1... (System call)
                                added 1 package, removed 10 packages, and changed 2 packages in 8s
                                upload [4] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/heatingcontrol.png heatingcontrol.png image/png
                                upload [3] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/img/info-big.png img/info-big.png image/png
                                upload [2] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/index_m.html index_m.html text/html
                                upload [1] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/style.css style.css text/css
                                upload [0] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/words.js words.js application/javascript
                                Update discovery from @2.7.0 to @3.1.0
                                NPM version: 9.8.1
                                Installing iobroker.discovery@3.1.0... (System call)
                                added 1 package, removed 20 packages, and changed 1 package in 7s
                                95 packages are looking for funding
                                Update "system.adapter.discovery.0"
                                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                Update cloud from @4.1.0 to @4.4.1
                                NPM version: 9.8.1
                                Installing iobroker.cloud@4.4.1... (System call)
                                added 9 packages, removed 13 packages, and changed 26 packages in 11s
                                96 packages are looking for funding
                                upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                                upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                                upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                                upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                                upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                                upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                                upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                                Update alexa2 from @3.9.3 to @3.25.2
                                NPM version: 9.8.1
                                Installing iobroker.alexa2@3.25.2... (System call)
                                added 10 packages, removed 13 packages, and changed 42 packages in 14s
                                98 packages are looking for funding
                                upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                                upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                                upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                                upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                                upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                                upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                                upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                                upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                                upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                                upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                                upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                                upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                                upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                                upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                                upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                                Update admin from @5.2.1 to @6.10.1
                                host.ubuntu Adapter "system.adapter.admin.0" is stopped.
                                NPM version: 9.8.1
                                Installing iobroker.admin@6.10.1... (System call)
                                added 52 packages, removed 1 package, and changed 9 packages in 18s
                                Update "system.adapter.admin.0"
                                upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                host.ubuntu Adapter "system.adapter.admin.0" is started
                                Update web from @3.4.9 to @6.1.2
                                NPM version: 9.8.1
                                Installing iobroker.web@6.1.2... (System call)
                                added 13 packages, removed 3 packages, and changed 9 packages in 13s
                                upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                Cannot check dependencies: Required dependency "web" not found on this host.
                                Update telegram from @1.10.0 to @1.16.0
                                NPM version: 9.8.1
                                Installing iobroker.telegram@1.16.0... (System call)
                                added 31 packages, removed 1 package, and changed 21 packages in 13s
                                121 packages are looking for funding
                                upload [68] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                upload [60] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                                upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.ae65be75.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.ae65be75.chunk.js application/javascript
                                upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/de.json i18n/de.json application/json
                                upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/it.json rules/i18n/it.json application/json
                                upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/nl.json rules/i18n/nl.json application/json
                                upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pl.json rules/i18n/pl.json application/json
                                upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pt.json rules/i18n/pt.json application/json
                                upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/ru.json rules/i18n/ru.json application/json
                                upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/uk.json rules/i18n/uk.json application/json
                                upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/zh-cn.json rules/i18n/zh-cn.json application/json
                                upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.7e3dd3e3.js rules/static/js/main.7e3dd3e3.js application/javascript
                                upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.7e3dd3e3.js.map rules/static/js/main.7e3dd3e3.js.map application/json
                                upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-3fbe7d.46a44060.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-3fbe7d.46a44060.chunk.js application/javascript
                                upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-3fbe7d.46a44060.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-3fbe7d.46a44060.chunk.js.map application/json
                                upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.4a6f1268.chunk.js rules/static/js/node_modules_prop-types_index_js.4a6f1268.chunk.js application/javascript
                                upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.4a6f1268.chunk.js.map rules/static/js/node_modules_prop-types_index_js.4a6f1268.chunk.js.map application/json
                                upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.fbeb147f.chunk.js rules/static/js/node_modules_react_index_js.fbeb147f.chunk.js application/javascript
                                upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.fbeb147f.chunk.js.map rules/static/js/node_modules_react_index_js.fbeb147f.chunk.js.map application/json
                                upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.96d464bf.chunk.js rules/static/js/src_ActionTelegram_jsx.96d464bf.chunk.js application/javascript
                                upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.96d464bf.chunk.js.map rules/static/js/src_ActionTelegram_jsx.96d464bf.chunk.js.map application/json
                                upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.dacb0f1b.chunk.js rules/static/js/src_bootstrap_jsx.dacb0f1b.chunk.js application/javascript
                                upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.dacb0f1b.chunk.js.map rules/static/js/src_bootstrap_jsx.dacb0f1b.chunk.js.map application/json
                                upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                Update socketio from @3.1.4 to @6.5.5
                                NPM version: 9.8.1
                                Installing iobroker.socketio@6.5.5... (System call)
                                added 4 packages, removed 4 packages, and changed 1 package in 7s
                                upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                Update shuttercontrol from @1.2.1 to @1.6.1
                                NPM version: 9.8.1
                                Installing iobroker.shuttercontrol@1.6.1... (System call)
                                added 4 packages, and changed 1 package in 8s
                                upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                                upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                                upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                Update rpi2 from @1.3.1 to @1.3.2
                                NPM version: 9.8.1
                                Installing iobroker.rpi2@1.3.2... (System call)
                                upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                                upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                                upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                Update linkeddevices from @1.4.3 to @1.5.5
                                NPM version: 9.8.1
                                Installing iobroker.linkeddevices@1.5.5... (System call)
                                changed 3 packages in 10s
                                122 packages are looking for funding
                                upload [13] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [12] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom.js custom.js application/javascript
                                upload [11] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom_m.html custom_m.html text/html
                                upload [10] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/img/info-big.png img/info-big.png image/png
                                upload [9] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.html index_m.html text/html
                                upload [8] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.js index_m.js application/javascript
                                upload [7] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/jsonCustom.json jsonCustom.json application/json
                                upload [6] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices.png linkeddevices.png image/png
                                upload [5] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_info.png linkeddevices_info.png image/png
                                upload [4] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_missing.png linkeddevices_missing.png image/png
                                upload [3] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_small.png linkeddevices_small.png image/png
                                upload [2] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/style.css style.css text/css
                                upload [1] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/words.js words.js application/javascript
                                upload [0] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/words_material.js words_material.js application/javascript
                                Update javascript from @5.2.13 to @7.1.4
                                NPM version: 9.8.1
                                Installing iobroker.javascript@7.1.4... (System call)
                                added 7 packages, removed 16 packages, and changed 10 packages in 15s
                                upload [275] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                                upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/101.82693fcf.chunk.js.map static/js/101.82693fcf.chunk.js.map application/json
                                upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Anteroom.93a742135f2c060ad619.svg static/media/Anteroom.93a742135f2c060ad619.svg image/svg+xml
                                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Home Theater.1e5f19a0b2a013f153f5.svg static/media/Home Theater.1e5f19a0b2a013f153f5.svg image/svg+xml
                                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Lightings.658080eb8c0e347cd152.svg static/media/Lightings.658080eb8c0e347cd152.svg image/svg+xml
                                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Outdoor Blinds.37b85a9c060a4af48da9.svg static/media/Outdoor Blinds.37b85a9c060a4af48da9.svg image/svg+xml
                                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Sconces.9bf4c2f7a209085207aa.svg static/media/Sconces.9bf4c2f7a209085207aa.svg image/svg+xml
                                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Stairway.9b007e08605296110003.svg static/media/Stairway.9b007e08605296110003.svg image/svg+xml
                                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                Update iot from @1.8.22 to @1.14.5
                                NPM version: 9.8.1
                                Installing iobroker.iot@1.14.5... (System call)
                                added 16 packages, removed 18 packages, and changed 57 packages in 2m
                                124 packages are looking for funding
                                upload [132] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                                upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
                                upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
                                upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
                                upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
                                upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
                                upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
                                upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
                                upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
                                upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
                                upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                Update info from @1.9.8 to @1.9.26
                                NPM version: 9.8.1
                                Installing iobroker.info@1.9.26... (System call)
                                added 2 packages, and changed 2 packages in 8s
                                  run `npm fund` for details
                                upload [91] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/memory.png lib/img/icons/memory.png image/png
                                upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/chartist.min.js lib/js/chartist.min.js application/javascript
                                upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/clock.js lib/js/clock.js application/javascript
                                upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/commons.js lib/js/commons.js application/javascript
                                upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/documentation.js lib/js/documentation.js application/javascript
                                upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
                                upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/format-google-calender.js lib/js/format-google-calender.js application/javascript
                                upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
                                upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
                                upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
                                upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
                                upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
                                upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
                                upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
                                upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
                                upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
                                upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
                                upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                Update ical from @1.11.4 to @1.13.3
                                NPM version: 9.8.1
                                Installing iobroker.ical@1.13.3... (System call)
                                added 5 packages, and changed 6 packages in 9s
                                upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                                upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                                upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                Update history from @1.9.14 to @2.2.6
                                NPM version: 9.8.1
                                Installing iobroker.history@2.2.6... (System call)
                                upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                                upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                                upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                                upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                                Update backitup from @2.2.2 to @2.6.23
                                host.ubuntu Adapter "system.adapter.backitup.0" is stopped.
                                NPM version: 9.8.1
                                Installing iobroker.backitup@2.6.23... (System call)
                                added 22 packages, removed 3 packages, and changed 22 packages in 15s
                                128 packages are looking for funding
                                Update "system.adapter.backitup.0"
                                upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                host.ubuntu Adapter "system.adapter.backitup.0" is started
                                Cannot check dependencies: Required dependency "vis" not found on this host.
                                ubuntu@ubuntu:/opt/iobroker$
                                ich hoffe da ist alles ok
                                Iobrocker startet jetzt wirklich aber es sieht so aus ob ich alles verloren habe:
                                  Thomas Braun Most Active @Esmax666 last edited by
                                  @esmax666
                                  iob update
                                  sagt nun?
                                    Esmax666 @Thomas Braun last edited by
                                    @thomas-braun said in iobroker geht nicht nach stromausfall:
                                    iob update
                                    ubuntu@ubuntu:/opt/iobroker$ iob update
                                    Used repository: stable
                                    Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                                    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                    Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                                    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                                    Adapter    "history"      : 2.2.6    , installed 2.2.6
                                    Adapter    "info"         : 1.9.26   , installed 1.9.26
                                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                                    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                                    Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                    Adapter    "vis"          : 1.4.16   , installed 1.4.5  [Updatable]
                                    Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                                    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                                    Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                                    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                                    Adapter    "web"          : 6.1.2    , installed 6.1.2
                                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                    Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                                      @esmax666
                                      Dann zieh den Rest (bis auf den js-controller) auch auf aktuelle Versionen.
                                      iob upgrade
                                        ich bekomme das
                                        ubuntu@ubuntu:/opt/iobroker$ iob upgrade
                                        aber bekomme ich wieder später mein ioboker config, oder ist da alles verloren ?
                                          @esmax666
                                          iobroker upgrade vis@1.4.16
                                            ok danke das gleich mache für alle ?
                                            warum was das nicht möglich mit "iob upgrade" ?
                                            wie bekomme ich wieder die alte config ?
                                            10426
