    4. Sungrow WR SGH10RT MODBUS ioSkripte
    • Carsten Sauermann
      Carsten Sauermann @xpectives last edited by
      @xpectives in der pdf stehen auch die Holding register mit drin. Ich kann die meine Liste als Import für iobroker geben.
      _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
      4999	System Clock Year	Systemzeit Jahr		uint16be	1	1	0		value		true	false	false	false
      5000	System Clock Month	Systemzeit Monat		uint16be	1	1	0		value		true	false	false	false
      5001	System Clock Day	Systemzeit Tag		uint16be	1	1	0		value		true	false	false	false
      5002	System Clock Hour	Systemzeit Stunde		uint16be	1	1	0		value		true	false	false	false
      5003	System Clock Minute	Systemzeit Minute		uint16be	1	1	0		value		true	false	false	false
      12999	Start/Stop	Start/Stop Start(CF) Stop (CF)		uint16be	1	1	0		value		true	false	false	false
      13001	Load Adjustment mode	Energie Management Modus ON/OFF(1) / Energieoptimiert(2)		uint16be	1	1	0		value		true	false	false	false
      13002	Load 1 timing period 1: Start hour		h	uint16be	1	1	0		value		true	false	false	false
      13003	Load 1 timing period 1: Start minute		min	uint16be	1	1	0		value		true	false	false	false
      13004	Load 1 timing period 1: End hour		min	uint16be	1	1	0		value		true	false	false	false
      13005	Load 1 timing period 1: End minute		h	uint16be	1	1	0		value		true	false	false	false
      13006	Load 1 timing period 2: Start hour		h	uint16be	1	1	0		value		true	false	false	false
      13007	Load 1 timing period 2: Start minute		min	uint16be	1	1	0		value		true	false	false	false
      13008	Load 1 timing period 2: End hour		h	uint16be	1	1	0		value		true	false	false	false
      13009	Load 1 timing period 2: End minute		min	uint16be	1	1	0		value		true	false	false	false
      13010	Load 1 ON/OFF mode	Load 1 ON/OFF mode    ON(170/AA)/ OFF (85/55)		uint16be	1	1	0		value		true	false	false	false
      13011	Load 1 power optimized mode: Start hour		h	uint16be	1	1	0		value		true	false	false	false
      13012	Load 1 power optimized mode: Start minute		min	uint16be	1	1	0		value		true	false	false	false
      13013	Load 1 power optimized mode: End hour		h	uint16be	1	1	0		value		true	false	false	false
      13014	Load 1 power optimized mode: End Minute 		min	uint16be	1	1	0		value		true	false	false	false
      13015	Optimized power of load 1	Optimized power of load 1	W	uint16be	1	1	0		value		true	false	false	false
      13049	EMS mode selection 	EMS Modus		uint16be	1	1	0		value		true	false	false	false
      13050	Charge/discharge command	Ext. Sollvorgabe Laden170(AA)/ Stop187(BB)/ Entladen204(CC) 		uint16be	1	1	0		value		true	false	false	false
      13051	Charge/discharge power	Ext. Sollvorgabe Lade/Entladeleistung		uint16be	1	1	0		value		true	false	false	false
      13057	Max. SOC	Max SOC	%	uint16be	1	0.1	0		value		true	false	false	false
      13058	Min. SOC	Min SOC	%	uint16be	1	0.1	0		value		true	false	false	false
      13065	Max. discharge current	Max. Entlade Strom	A	int16be	1	0.001	0		value		true	false	false	false
      13066	Max. charge current	Max. Lade Strom	A	int16be	1	0.001	0		value		true	false	false	false
      13074	Export Power Backup	Backup-Ausgang AN(170/AA) AUS(85/55h)		uint16be	1	1	0		value		true	false	false	false
      13079	External EMS heartbeat			uint16be	1	1	0		value		true	false	false	false
      13083	Start  Charging Power	u.U. Leistung, mit welcher ein Ladevorgang begonnen wird. Klärung erwünscht	W	uint16be	1	1	0		value		true	false	false	false
      13084	Start Discharging Power	u.U. Leistung, mit welcher ein Entladevorgang begonnen wird. Klärung erwünscht	W	uint16be	1	1	0		value		true	false	false	false
      13085	Meter Comm.	Kommunikation mit Energie Meter des WR		uint16be	1	1	0		value		true	false	false	false
      13086	Export Power Limitation	Einspeise Limitierung AN(170/AA) AUS(85/55h)		uint16be	1	1	0		value		true	false	false	false
      13099	SOC Reserve	SOC Reserve	%	uint16be	1	1	0		value		true	false	false	false
      • X
        xpectives @Carsten Sauermann last edited by
        @carsten-sauermann
        Danke Dir 👍
        Jetzt heisst es erstmal studieren 😀
          rali2011 @MRaioBroker last edited by
          @mraiobroker
          Hallo, ich habe gesehen, dass du (genauso wie ich) zwei Dächer seperat mit PV bestückt hast. Ich addiere einfach die Werte 5016 der beiden Wechselrichter und habe dann den aktuellen Gesamtertrag.
          Allerdings finde ich nicht heraus, wie ich den aktuellen Verbrauch auslesen kann. Der unter 13033 ausgelesene Werte ist konstant ca. 200W geringer als die (verzögerte) anzeige in der App.
          Hast du oder alle anderen einen Tipp für mich, wie an den korrekten Wert komme?
          Liebe Grüße und Danke für eure Hilfe
          Ralph
          M Carsten Sauermann 2 Replies Last reply Reply Quote 0
            MRaioBroker @rali2011 last edited by
            @rali2011
            Hi Ralf,
            Ich arbeite nur mit 13007 als Verbrauch des Hauses und separat mit der Ladeleistung der Batterie.
            Mein Tipp ist es, die App einfach nicht zu benutzen. wenn doch dann nicht miteinander vergleichen. Die Modus Daten sind wesentlich genauer.
            Ich habe auch aufgegeben Werte die in Modbus bereits summiert werden (Gesamtverbräuche) durch die Aufaddierung der Einzelwerte nachzuvollziehen, weil das hat nie gestimmt. Es ist alles nicht 100-prozent genau.
            • Carsten Sauermann
              Carsten Sauermann @rali2011 last edited by
              @rali2011 die Werte in der App sind gemittelt Werte über die letzten paar Minuten. Daher weicht die Anzeige immer von der reellen Werten auf dem modbus ab.
                rali2011 @MRaioBroker last edited by rali2011
                @mraiobroker
                Danke für die schnelle Antwort!
                Ja die App ist sicherlich deutlich ungenauer. Aber die Daten aus 13033 sind in meinen Augen (warum auch immer...) zu gering.
                Ich würde mich sehr freuen, wenn du etwas genauer darauf eingehen könntest wie du aus 13007 den Hausverbrauch berechnest. Bzw. wie - ganz allgemein - du deine Daten berechnest. Ich habe mal begonnen mich in den verschiedenen Foren einzulesen und das Thema scheint ja sehr komplex zu sein....
                Liebe Grüße und vielen Dank!
                  MRaioBroker @rali2011 last edited by MRaioBroker
                  @rali2011
                  ja bin aktuell zeitlich echt Land unter...
                  ich versuchs mal in aller Kürze.
                  Also hab den Energiefluss Adapter, der ist so konfigutiert
                  Datenpunkt für Batterie laden oder entladen muss leider per Datenpunkt berechnet werden, Skript siehe hier
                    <variables>
                      <variable id="(ocA``hXb:ASln87_[5i">PV Akku Be- oder Entladung</variable>
                    </variables>
                    <block type="on_ext" id="ehBZF8`0,PKLSMKg__PB" x="-2012" y="-487">
                      <value name="OID0">
                        <shadow type="field_oid" id="0m^saRA]WjVCQ`9A%2n8">
                          <field name="oid">modbus.0.inputRegisters.13007_Load_power_</field>
                        <block type="variables_set" id="F`@4}oyq-b-2|/kYbR$U">
                          <field name="VAR" id="(ocA``hXb:ASln87_[5i">PV Akku Be- oder Entladung</field>
                            <block type="math_arithmetic" id="1Zv4~dL0,_aGpt}7[_kP">
                                <shadow type="math_number" id="d[QgpJU-{V|[)Y8g,,:@">
                                  <field name="NUM">1</field>
                                <block type="math_arithmetic" id="5||kb1lHC-qwY!85c3KH">
                                    <shadow type="math_number" id="lWjzQ^1^A)~nyY4K}k/%">
                                    <block type="get_value" id="v|oqCDrxh=7lS_fPh~*[">
                                      <field name="OID">modbus.0.inputRegisters.5016_Total_DC_Power</field>
                                    <shadow type="math_number" id="hMTHE%-|Fip{Z1M$2d7y">
                                    <block type="get_value" id="pQL:D)uc#*C|yW94;;1U">
                                      <field name="OID">modbus.0.inputRegisters.13007_Load_power_</field>
                                <shadow type="math_number" id="LWB:(CTORxv:`-#$RF=q">
                                <block type="get_value" id="E}0?u4:S)mn)6}@G9fd]">
                                  <field name="OID">modbus.0.inputRegisters.13009_Export_power</field>
                            <block type="update" id="(TMX3NmoY?k,I8B2]p?C">
                              <field name="OID">0_userdata.0.PV_Datenpunkte.Berechnung_Batterieentladung_negativ</field>
                                <block type="variables_get" id="p$a.=$hGsH%AenyyxPI!">
                  dann noch etwas VIS und ein paar kleine einfache Berechnungen, leider alles in Gruppen gebunden und gefixt, kann ich Dir nicht so leicht sagen was ich da alles eingebunden hab.
                  Dachflächenertrag ist berechnet
                  Die Flächen mach ich je Süd- und Nordseite über zwei den zwei gelben Dachlinien mit einem einfachen HTML Widget mit folgendem Inhalt
                  Süd {Voltsuedmppt1:modbus.0.inputRegisters.5010_MPPT_1_Voltage;Amperesuedmppt1:modbus.0.inputRegisters.5011_MPPT_1_Current;(Voltsuedmppt1*Amperesuedmppt1).toFixed(0)} Watt
                  Zweite VIS geht mehr auf historische Daten, zwei echarts und ein paar Monatsdatenpunkte und Tageswerte in Form gepackt
                  Hoffe da kannst Du was rausziehen an Infos
                  Die Lampe unten rechts ist noch ganz witzig, die leuchtet in jeder View sobald Überschussstrom vorhanden ist, den berechne ich per Skript
                  Ich muss nun leider wieder, hoffe das hilft Dir ein wenig
                  R G 2 Replies Last reply Reply Quote 0
                    @mraiobroker
                    Danke für die ausführliche Zusammenfassung! Schaue ich mir Heute abend nochmals genauer an.
                    Aber nochmals zu meiner wegen der 13007. Gestern Abend waren da tatsächlich passende Werte (Herd + Kochfeld mal an / aus --> Werte haben sich passend geändert)
                    Jetzt steht da allerdings eine viel zu große Zahl. Genauso wie Gestern Nachmittag als du zum ersten mal geantwortest hast.
                    Da sind wir ja locker im GigaWatt bereich.... Ich weiß nur nicht, was da nicht passt.....
                    EDIT: Komischerweise passt es ab und zu wie jetzt gerade wieder:
                    ne halbe Minute Später wieder enorm große Werte
                      @rali2011
                      Verrückt, das habe ich noch nicht beobachtet. Ich würde die Geräte neustarten
                        @mraiobroker
                        Kann ich die WR einfach aus und wieder an machen?! Oder muss da etwas besonderes beachtet werden...
                          @rali2011 sagte in Sungrow WR SGH10RT MODBUS ioSkripte:
                          @mraiobroker
                          Ich beschäftige mich mehr mit der Software das muss jemand anderes beantworten. Im Zweifelsfall hätte ich es bei mir so gemacht, oder Sicherung weg für 20sek aber ohne Gewähr
                            @mraiobroker
                            Habe mit dem Chef der Firma gesprochen. Einfach "abschalten" sollte man nicht und es macht auch keinen Sinn. Es gibt da ein genaues Prozedere das eingehalten werden muss und auch einiges an Zeit in Anspruch nimmt.
                            Werde das Morgen testen und dann berichten ob die Werte nun passen.
                            Falls gewünscht kann ich die Schritte zum Neustart auch gerne hier posten!
                              GombersIOB @rali2011 last edited by
                              @rali2011 said in Sungrow WR SGH10RT MODBUS ioSkripte:
                              Sicher, würde mich interessieren.
                              Ich kenne das hier: https://www.photovoltaikforum.com/thread/158136-sungrow-sammelthread-produktmanagement/?pageNo=147
                              Das Runterfahren geht, neben dem iSolarCloud-Zugriff auch über den lokalen WebServer des Wechselrichters.
                              Wobei, der Elektriker, der meine Anlage installiert hat, hat das auch an dem Last-Trenn-Schalter gemacht. Und ich seitdem auch schon zwei oder drei mal.
                              Worin besteht die Gefahr? Sollen Überspannungen vermieden werden.
                                GombersIOB @MRaioBroker last edited by
                                @mraiobroker
                                Hast Du echt eine nach Norden ausgerichtete Panel-Fläche? Ich habe mir das auch mit dem ioBroker-PVForecaster schon mal rechnen lassen und auch mit dem Rechner der EU.
                                Bei dem Rechner der EU komme ich bei Nordausrichtung noch auf knapp 2/3 des Ertrags der Südausrichtung. Das schien mir nicht gerade lohnend. Finanziell ist ja schon die Südausrichtung ein Hoffnungsprojekt.
                                  @gombersiob sagte in Sungrow WR SGH10RT MODBUS ioSkripte:
                                  klar, als Süd kalkuliert war hab ich gefragt was die Erweiterung auf Nord kostet und der Aufschlag war sehr günstig.
                                  Die meisten Fixkosten waren da schon gedeckt, WR blieb bei 10KW
                                  Ich hab meine Anlage für den Winter konstruiert, da will ich viel Strom, weil da bezahl ich nen Haufen Geld für Strombezug.
                                  Also hab ich jetzt viel Dachfläche für den Winter und die zahlt voll in die Amortisationsrechnung ein - außerdem hab ich ein
                                  sehr flaches komplett unbeschattetes Dach, muss ich erwähnen.
                                    casifa29 @MRaioBroker last edited by
                                    @mraiobroker Danke dir für das Skript. Aber wie schon von @kklaus erwähnt, muss dies nicht über die "Runnning States" berechnet werden?
                                      MRaioBroker @casifa29 last edited by MRaioBroker
                                      @casifa29 wir tun uns leichter, wenn wir mit Zitaten arbeiten, sonst weiß ich nicht welches Skript gemeint ist.
                                      Hab oben nachgesehen, geht vermutlich um die Batterieladung.
                                      Du kannst das berechnen wie Du willst, ich mach´s so und es funktioniert, da ich nicht mal ne running states Auflistung hab und es auch für meine Anwendung nicht nötig ist, lass ich es so.
                                      Matthias
                                      G C 2 Replies Last reply Reply Quote 0
                                        @mraiobroker
                                        Das Problem mit den Running-States ist doch, dass man sie nicht zuverlässig hat. Über den WiNet-S-Anschluss (LAN/WLAN) werden sie nicht bereitgestellt. Das ist doch der Grund für das Script-festzustellen ob geladen oder entladen wird.
                                          @mraiobroker vielen Dank für dein Antwort und Hilfe
                                            @casifa29
                                            Gerne wobei ich nicht weiß ob ich wirklich geholfen hab 😃
                                            Aber wenn Fragen zum Skript bestehen gerne melden
                                            akku automatisierung batteriespeicher blockly javaskript photovoltaik skript smarthome sungrow wechselrichter
                                            10
                                            52
                                            8898
