    4. iobroker geht nicht nach stromausfall
      Thomas Braun Most Active @Esmax666 last edited by
      @esmax666
      iob update
      iob list adapters
      iob list instances
        Esmax666 @Thomas Braun last edited by Esmax666
        @thomas-braun said in iobroker geht nicht nach stromausfall:
        > iob list instances
        ubuntu@ubuntu:/opt/iobroker$ iob update
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
        Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
        ubuntu@ubuntu:/opt/iobroker$ ^C
        ubuntu@ubuntu:/opt/iobroker$ iobroker start
        ubuntu@ubuntu:/opt/iobroker$ iob list adapters
        system.adapter.admin                   : admin          - v6.10.1
        system.adapter.alexa2                  : alexa2         - v3.25.2
        system.adapter.backitup                : backitup       - v2.6.23
        system.adapter.cloud                   : cloud          - v4.4.1
        system.adapter.discovery               : discovery      - v3.1.0
        system.adapter.flot                    : flot           - v1.12.0
        system.adapter.heatingcontrol          : heatingcontrol - v2.11.1
        system.adapter.history                 : history        - v2.2.6
        system.adapter.ical                    : ical           - v1.13.3
        system.adapter.info                    : info           - v1.9.26
        system.adapter.iot                     : iot            - v1.14.5
        system.adapter.javascript              : javascript     - v7.1.4
        system.adapter.linkeddevices           : linkeddevices  - v1.5.5
        system.adapter.radar2                  : radar2         - v2.0.7
        system.adapter.rpi2                    : rpi2           - v1.3.2
        system.adapter.shuttercontrol          : shuttercontrol - v1.6.1
        system.adapter.simple-api              : simple-api     - v2.7.2
        system.adapter.socketio                : socketio       - v6.5.5
        system.adapter.telegram                : telegram       - v1.16.0
        system.adapter.text2command            : text2command   - v3.0.2
        system.adapter.tr-064                  : tr-064         - v4.2.18
        system.adapter.vis                     : vis            - v1.4.16
        system.adapter.vis-colorpicker         : vis-colorpicker - v2.0.3
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
        system.adapter.vis-metro               : vis-metro      - v1.2.0
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
        system.adapter.web                     : web            - v6.1.2
        system.adapter.zwave2                  : zwave2         - v3.0.5
        ubuntu@ubuntu:/opt/iobroker$ iob list instances
        + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
        + system.adapter.discovery.0              : discovery             : ubuntu                                   -  enabled
        + instance is alive
          @esmax666
          Möglich, dass du die Instanzen manuell hinzufügen musst.
          ls -lAh /opt/iobroker/iobroker-data/backup-objects/
          sagt? Wann war der Stromausfall?
            Stomausfall war am 6 sept.
            ich kann nicht alles zeigen :
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:48 2023-09-19_05-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:48 2023-09-19_05-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:49 2023-09-19_05-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 05:49 2023-09-19_05-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:50 2023-09-19_05-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:50 2023-09-19_05-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:51 2023-09-19_05-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:51 2023-09-19_05-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:52 2023-09-19_05-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 05:52 2023-09-19_05-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:53 2023-09-19_05-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:53 2023-09-19_05-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:54 2023-09-19_05-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:54 2023-09-19_05-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:55 2023-09-19_05-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:55 2023-09-19_05-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:56 2023-09-19_05-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:56 2023-09-19_05-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:57 2023-09-19_05-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:57 2023-09-19_05-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:58 2023-09-19_05-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:58 2023-09-19_05-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:59 2023-09-19_05-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:59 2023-09-19_05-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:00 2023-09-19_06-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:00 2023-09-19_06-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:01 2023-09-19_06-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:01 2023-09-19_06-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:02 2023-09-19_06-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:02 2023-09-19_06-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:03 2023-09-19_06-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:03 2023-09-19_06-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:04 2023-09-19_06-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:04 2023-09-19_06-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:05 2023-09-19_06-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:05 2023-09-19_06-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:06 2023-09-19_06-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 06:06 2023-09-19_06-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:07 2023-09-19_06-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:07 2023-09-19_06-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:08 2023-09-19_06-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:08 2023-09-19_06-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:09 2023-09-19_06-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:09 2023-09-19_06-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:10 2023-09-19_06-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 06:10 2023-09-19_06-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:11 2023-09-19_06-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:11 2023-09-19_06-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:12 2023-09-19_06-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 06:12 2023-09-19_06-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:13 2023-09-19_06-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:13 2023-09-19_06-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:14 2023-09-19_06-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:14 2023-09-19_06-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:15 2023-09-19_06-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:15 2023-09-19_06-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:16 2023-09-19_06-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 06:16 2023-09-19_06-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:17 2023-09-19_06-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:17 2023-09-19_06-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:18 2023-09-19_06-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:18 2023-09-19_06-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:19 2023-09-19_06-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 06:19 2023-09-19_06-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:20 2023-09-19_06-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:20 2023-09-19_06-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:21 2023-09-19_06-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:21 2023-09-19_06-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:22 2023-09-19_06-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:22 2023-09-19_06-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:23 2023-09-19_06-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:23 2023-09-19_06-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:24 2023-09-19_06-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:24 2023-09-19_06-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:25 2023-09-19_06-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:25 2023-09-19_06-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:26 2023-09-19_06-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:26 2023-09-19_06-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:27 2023-09-19_06-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 06:27 2023-09-19_06-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:28 2023-09-19_06-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:28 2023-09-19_06-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:29 2023-09-19_06-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:29 2023-09-19_06-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:30 2023-09-19_06-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:30 2023-09-19_06-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:31 2023-09-19_06-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:31 2023-09-19_06-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:32 2023-09-19_06-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:32 2023-09-19_06-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:33 2023-09-19_06-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:33 2023-09-19_06-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:34 2023-09-19_06-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:34 2023-09-19_06-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:35 2023-09-19_06-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:35 2023-09-19_06-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:36 2023-09-19_06-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:36 2023-09-19_06-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:37 2023-09-19_06-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:37 2023-09-19_06-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:38 2023-09-19_06-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:38 2023-09-19_06-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:39 2023-09-19_06-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:39 2023-09-19_06-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:40 2023-09-19_06-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:40 2023-09-19_06-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:41 2023-09-19_06-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:41 2023-09-19_06-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:42 2023-09-19_06-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:42 2023-09-19_06-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:43 2023-09-19_06-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:43 2023-09-19_06-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:44 2023-09-19_06-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:44 2023-09-19_06-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:45 2023-09-19_06-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:45 2023-09-19_06-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:46 2023-09-19_06-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:46 2023-09-19_06-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:47 2023-09-19_06-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:47 2023-09-19_06-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:48 2023-09-19_06-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:48 2023-09-19_06-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:49 2023-09-19_06-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:49 2023-09-19_06-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:50 2023-09-19_06-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 06:50 2023-09-19_06-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:51 2023-09-19_06-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:51 2023-09-19_06-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:52 2023-09-19_06-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:52 2023-09-19_06-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:53 2023-09-19_06-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:53 2023-09-19_06-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:54 2023-09-19_06-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:54 2023-09-19_06-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:55 2023-09-19_06-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:55 2023-09-19_06-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:56 2023-09-19_06-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:56 2023-09-19_06-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:57 2023-09-19_06-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:57 2023-09-19_06-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:58 2023-09-19_06-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:58 2023-09-19_06-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:59 2023-09-19_06-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:59 2023-09-19_06-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:00 2023-09-19_07-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:00 2023-09-19_07-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:01 2023-09-19_07-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:01 2023-09-19_07-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:02 2023-09-19_07-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:02 2023-09-19_07-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:03 2023-09-19_07-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:03 2023-09-19_07-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:04 2023-09-19_07-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 07:04 2023-09-19_07-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:05 2023-09-19_07-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:05 2023-09-19_07-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:06 2023-09-19_07-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:06 2023-09-19_07-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:07 2023-09-19_07-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:07 2023-09-19_07-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:08 2023-09-19_07-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:08 2023-09-19_07-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:09 2023-09-19_07-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:09 2023-09-19_07-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:10 2023-09-19_07-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:10 2023-09-19_07-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:11 2023-09-19_07-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:11 2023-09-19_07-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:12 2023-09-19_07-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:12 2023-09-19_07-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:13 2023-09-19_07-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:13 2023-09-19_07-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:14 2023-09-19_07-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:14 2023-09-19_07-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:15 2023-09-19_07-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:15 2023-09-19_07-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:16 2023-09-19_07-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 07:16 2023-09-19_07-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:17 2023-09-19_07-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:17 2023-09-19_07-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:18 2023-09-19_07-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:18 2023-09-19_07-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:19 2023-09-19_07-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:19 2023-09-19_07-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:20 2023-09-19_07-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 07:20 2023-09-19_07-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:21 2023-09-19_07-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:21 2023-09-19_07-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:22 2023-09-19_07-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:22 2023-09-19_07-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:23 2023-09-19_07-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:23 2023-09-19_07-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:24 2023-09-19_07-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:24 2023-09-19_07-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:25 2023-09-19_07-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:25 2023-09-19_07-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:26 2023-09-19_07-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:26 2023-09-19_07-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:27 2023-09-19_07-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:27 2023-09-19_07-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:28 2023-09-19_07-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:28 2023-09-19_07-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:29 2023-09-19_07-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:29 2023-09-19_07-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:30 2023-09-19_07-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:30 2023-09-19_07-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:31 2023-09-19_07-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 07:31 2023-09-19_07-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:32 2023-09-19_07-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:32 2023-09-19_07-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:33 2023-09-19_07-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:33 2023-09-19_07-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:34 2023-09-19_07-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:34 2023-09-19_07-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:35 2023-09-19_07-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:35 2023-09-19_07-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:36 2023-09-19_07-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:36 2023-09-19_07-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:37 2023-09-19_07-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:37 2023-09-19_07-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:38 2023-09-19_07-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:38 2023-09-19_07-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:39 2023-09-19_07-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:39 2023-09-19_07-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:40 2023-09-19_07-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:40 2023-09-19_07-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:41 2023-09-19_07-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 07:41 2023-09-19_07-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:42 2023-09-19_07-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:42 2023-09-19_07-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:43 2023-09-19_07-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:43 2023-09-19_07-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:44 2023-09-19_07-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 07:44 2023-09-19_07-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:45 2023-09-19_07-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:45 2023-09-19_07-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:46 2023-09-19_07-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:46 2023-09-19_07-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:47 2023-09-19_07-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:47 2023-09-19_07-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:48 2023-09-19_07-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:48 2023-09-19_07-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:49 2023-09-19_07-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:49 2023-09-19_07-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:50 2023-09-19_07-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:50 2023-09-19_07-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:51 2023-09-19_07-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:51 2023-09-19_07-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:52 2023-09-19_07-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:52 2023-09-19_07-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:53 2023-09-19_07-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:53 2023-09-19_07-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:54 2023-09-19_07-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:54 2023-09-19_07-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:55 2023-09-19_07-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:55 2023-09-19_07-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:56 2023-09-19_07-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:56 2023-09-19_07-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:57 2023-09-19_07-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:57 2023-09-19_07-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:58 2023-09-19_07-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:58 2023-09-19_07-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:59 2023-09-19_07-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:59 2023-09-19_07-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:00 2023-09-19_08-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 08:00 2023-09-19_08-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:01 2023-09-19_08-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:01 2023-09-19_08-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:02 2023-09-19_08-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 08:02 2023-09-19_08-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:03 2023-09-19_08-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:03 2023-09-19_08-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:04 2023-09-19_08-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 08:04 2023-09-19_08-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:05 2023-09-19_08-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:05 2023-09-19_08-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:06 2023-09-19_08-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:06 2023-09-19_08-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:07 2023-09-19_08-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 08:07 2023-09-19_08-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:08 2023-09-19_08-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:08 2023-09-19_08-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:09 2023-09-19_08-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:09 2023-09-19_08-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:10 2023-09-19_08-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:10 2023-09-19_08-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:11 2023-09-19_08-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:11 2023-09-19_08-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:12 2023-09-19_08-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:12 2023-09-19_08-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:13 2023-09-19_08-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:13 2023-09-19_08-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:14 2023-09-19_08-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:14 2023-09-19_08-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:15 2023-09-19_08-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:15 2023-09-19_08-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:16 2023-09-19_08-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 08:16 2023-09-19_08-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:17 2023-09-19_08-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:17 2023-09-19_08-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:18 2023-09-19_08-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:18 2023-09-19_08-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:19 2023-09-19_08-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:19 2023-09-19_08-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:20 2023-09-19_08-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 08:20 2023-09-19_08-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:21 2023-09-19_08-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:21 2023-09-19_08-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:22 2023-09-19_08-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:22 2023-09-19_08-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:23 2023-09-19_08-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:23 2023-09-19_08-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:24 2023-09-19_08-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:24 2023-09-19_08-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:25 2023-09-19_08-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:25 2023-09-19_08-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:26 2023-09-19_08-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:26 2023-09-19_08-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:27 2023-09-19_08-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 08:27 2023-09-19_08-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:28 2023-09-19_08-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:28 2023-09-19_08-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:29 2023-09-19_08-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:29 2023-09-19_08-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:30 2023-09-19_08-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:30 2023-09-19_08-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:31 2023-09-19_08-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:31 2023-09-19_08-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:32 2023-09-19_08-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:32 2023-09-19_08-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:33 2023-09-19_08-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:33 2023-09-19_08-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:34 2023-09-19_08-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:34 2023-09-19_08-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:35 2023-09-19_08-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:35 2023-09-19_08-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:36 2023-09-19_08-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:36 2023-09-19_08-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:37 2023-09-19_08-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:37 2023-09-19_08-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:38 2023-09-19_08-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:38 2023-09-19_08-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:39 2023-09-19_08-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:39 2023-09-19_08-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:40 2023-09-19_08-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:40 2023-09-19_08-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:41 2023-09-19_08-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:41 2023-09-19_08-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:42 2023-09-19_08-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:42 2023-09-19_08-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:43 2023-09-19_08-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:43 2023-09-19_08-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:44 2023-09-19_08-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:44 2023-09-19_08-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:45 2023-09-19_08-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:45 2023-09-19_08-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:46 2023-09-19_08-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:46 2023-09-19_08-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:47 2023-09-19_08-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:47 2023-09-19_08-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:48 2023-09-19_08-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 08:48 2023-09-19_08-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:49 2023-09-19_08-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:49 2023-09-19_08-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:50 2023-09-19_08-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:50 2023-09-19_08-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:51 2023-09-19_08-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:51 2023-09-19_08-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:52 2023-09-19_08-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:52 2023-09-19_08-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:53 2023-09-19_08-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 08:53 2023-09-19_08-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:54 2023-09-19_08-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:54 2023-09-19_08-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:55 2023-09-19_08-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:55 2023-09-19_08-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:56 2023-09-19_08-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 08:56 2023-09-19_08-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:57 2023-09-19_08-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:57 2023-09-19_08-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:58 2023-09-19_08-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:58 2023-09-19_08-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:59 2023-09-19_08-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 08:59 2023-09-19_08-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:00 2023-09-19_09-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:00 2023-09-19_09-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:01 2023-09-19_09-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 09:01 2023-09-19_09-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:02 2023-09-19_09-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:02 2023-09-19_09-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:03 2023-09-19_09-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:03 2023-09-19_09-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:04 2023-09-19_09-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:04 2023-09-19_09-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:05 2023-09-19_09-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:05 2023-09-19_09-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:06 2023-09-19_09-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:06 2023-09-19_09-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:07 2023-09-19_09-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:07 2023-09-19_09-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:08 2023-09-19_09-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 09:08 2023-09-19_09-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:09 2023-09-19_09-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:09 2023-09-19_09-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:10 2023-09-19_09-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:10 2023-09-19_09-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:11 2023-09-19_09-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:11 2023-09-19_09-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:12 2023-09-19_09-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:12 2023-09-19_09-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:13 2023-09-19_09-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 09:13 2023-09-19_09-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:14 2023-09-19_09-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:14 2023-09-19_09-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:15 2023-09-19_09-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:15 2023-09-19_09-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:16 2023-09-19_09-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:16 2023-09-19_09-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:17 2023-09-19_09-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:17 2023-09-19_09-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:18 2023-09-19_09-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 09:18 2023-09-19_09-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:19 2023-09-19_09-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:19 2023-09-19_09-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:20 2023-09-19_09-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  487 Sep 19 09:20 2023-09-19_09-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:21 2023-09-19_09-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:21 2023-09-19_09-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:22 2023-09-19_09-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:22 2023-09-19_09-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:23 2023-09-19_09-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:23 2023-09-19_09-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:24 2023-09-19_09-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 09:24 2023-09-19_09-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:25 2023-09-19_09-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:25 2023-09-19_09-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:26 2023-09-19_09-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:26 2023-09-19_09-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:27 2023-09-19_09-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:27 2023-09-19_09-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:28 2023-09-19_09-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 09:28 2023-09-19_09-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:29 2023-09-19_09-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:29 2023-09-19_09-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:30 2023-09-19_09-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:30 2023-09-19_09-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:31 2023-09-19_09-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:31 2023-09-19_09-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:32 2023-09-19_09-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 09:32 2023-09-19_09-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:33 2023-09-19_09-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:33 2023-09-19_09-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:34 2023-09-19_09-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 09:34 2023-09-19_09-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:35 2023-09-19_09-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:35 2023-09-19_09-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:36 2023-09-19_09-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:36 2023-09-19_09-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:37 2023-09-19_09-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:37 2023-09-19_09-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:38 2023-09-19_09-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:38 2023-09-19_09-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:39 2023-09-19_09-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 09:39 2023-09-19_09-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:40 2023-09-19_09-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:40 2023-09-19_09-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:41 2023-09-19_09-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:41 2023-09-19_09-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:42 2023-09-19_09-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 09:42 2023-09-19_09-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:43 2023-09-19_09-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:43 2023-09-19_09-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:44 2023-09-19_09-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:44 2023-09-19_09-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:45 2023-09-19_09-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:45 2023-09-19_09-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:46 2023-09-19_09-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:46 2023-09-19_09-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:47 2023-09-19_09-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 09:47 2023-09-19_09-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:48 2023-09-19_09-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:48 2023-09-19_09-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:49 2023-09-19_09-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:49 2023-09-19_09-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:50 2023-09-19_09-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:50 2023-09-19_09-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:51 2023-09-19_09-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 09:51 2023-09-19_09-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:52 2023-09-19_09-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:52 2023-09-19_09-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:53 2023-09-19_09-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:53 2023-09-19_09-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:54 2023-09-19_09-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:54 2023-09-19_09-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:55 2023-09-19_09-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:55 2023-09-19_09-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:56 2023-09-19_09-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:56 2023-09-19_09-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:57 2023-09-19_09-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:57 2023-09-19_09-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:58 2023-09-19_09-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:58 2023-09-19_09-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:59 2023-09-19_09-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:59 2023-09-19_09-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:00 2023-09-19_10-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:00 2023-09-19_10-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:01 2023-09-19_10-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:01 2023-09-19_10-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:02 2023-09-19_10-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 10:02 2023-09-19_10-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:03 2023-09-19_10-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:03 2023-09-19_10-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:04 2023-09-19_10-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:04 2023-09-19_10-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:05 2023-09-19_10-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:05 2023-09-19_10-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:06 2023-09-19_10-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:06 2023-09-19_10-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:07 2023-09-19_10-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:07 2023-09-19_10-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:08 2023-09-19_10-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:08 2023-09-19_10-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:09 2023-09-19_10-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:09 2023-09-19_10-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:10 2023-09-19_10-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:10 2023-09-19_10-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:11 2023-09-19_10-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:11 2023-09-19_10-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:12 2023-09-19_10-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:12 2023-09-19_10-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:13 2023-09-19_10-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:13 2023-09-19_10-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:14 2023-09-19_10-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 10:14 2023-09-19_10-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:15 2023-09-19_10-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:15 2023-09-19_10-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:16 2023-09-19_10-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 10:16 2023-09-19_10-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:17 2023-09-19_10-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:17 2023-09-19_10-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:18 2023-09-19_10-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:18 2023-09-19_10-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:19 2023-09-19_10-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:19 2023-09-19_10-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:20 2023-09-19_10-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:20 2023-09-19_10-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:21 2023-09-19_10-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:21 2023-09-19_10-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:22 2023-09-19_10-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:22 2023-09-19_10-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:23 2023-09-19_10-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:23 2023-09-19_10-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:24 2023-09-19_10-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:24 2023-09-19_10-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:25 2023-09-19_10-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:25 2023-09-19_10-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:26 2023-09-19_10-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:26 2023-09-19_10-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:27 2023-09-19_10-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:27 2023-09-19_10-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:28 2023-09-19_10-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:28 2023-09-19_10-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:29 2023-09-19_10-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:29 2023-09-19_10-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:30 2023-09-19_10-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:30 2023-09-19_10-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:31 2023-09-19_10-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:31 2023-09-19_10-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:32 2023-09-19_10-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:32 2023-09-19_10-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:33 2023-09-19_10-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:33 2023-09-19_10-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:34 2023-09-19_10-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:34 2023-09-19_10-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:35 2023-09-19_10-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 10:35 2023-09-19_10-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:36 2023-09-19_10-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:36 2023-09-19_10-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:37 2023-09-19_10-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 10:37 2023-09-19_10-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:38 2023-09-19_10-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:38 2023-09-19_10-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:39 2023-09-19_10-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:39 2023-09-19_10-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:40 2023-09-19_10-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:40 2023-09-19_10-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:41 2023-09-19_10-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:41 2023-09-19_10-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:42 2023-09-19_10-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 10:42 2023-09-19_10-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:43 2023-09-19_10-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:43 2023-09-19_10-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:44 2023-09-19_10-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:44 2023-09-19_10-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:45 2023-09-19_10-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:45 2023-09-19_10-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:46 2023-09-19_10-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:46 2023-09-19_10-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:47 2023-09-19_10-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:47 2023-09-19_10-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:48 2023-09-19_10-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:48 2023-09-19_10-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:49 2023-09-19_10-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:49 2023-09-19_10-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:50 2023-09-19_10-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:50 2023-09-19_10-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:51 2023-09-19_10-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:51 2023-09-19_10-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:52 2023-09-19_10-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:52 2023-09-19_10-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:53 2023-09-19_10-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:53 2023-09-19_10-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:54 2023-09-19_10-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:54 2023-09-19_10-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:55 2023-09-19_10-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:55 2023-09-19_10-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:56 2023-09-19_10-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 10:56 2023-09-19_10-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:57 2023-09-19_10-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:57 2023-09-19_10-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:58 2023-09-19_10-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:58 2023-09-19_10-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:51 2023-09-19_11-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 11:51 2023-09-19_11-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:52 2023-09-19_11-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:52 2023-09-19_11-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:53 2023-09-19_11-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:53 2023-09-19_11-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:54 2023-09-19_11-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 11:54 2023-09-19_11-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:55 2023-09-19_11-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 11:55 2023-09-19_11-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:56 2023-09-19_11-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  440 Sep 19 11:56 2023-09-19_11-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:57 2023-09-19_11-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 11:57 2023-09-19_11-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:58 2023-09-19_11-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 11:58 2023-09-19_11-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:59 2023-09-19_11-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 11:59 2023-09-19_11-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:00 2023-09-19_12-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:00 2023-09-19_12-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:01 2023-09-19_12-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:01 2023-09-19_12-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:02 2023-09-19_12-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:02 2023-09-19_12-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:03 2023-09-19_12-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:03 2023-09-19_12-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:04 2023-09-19_12-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:04 2023-09-19_12-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:05 2023-09-19_12-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:05 2023-09-19_12-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:06 2023-09-19_12-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  433 Sep 19 12:06 2023-09-19_12-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:07 2023-09-19_12-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:07 2023-09-19_12-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:08 2023-09-19_12-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 12:08 2023-09-19_12-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:09 2023-09-19_12-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:09 2023-09-19_12-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:10 2023-09-19_12-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  446 Sep 19 12:10 2023-09-19_12-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:11 2023-09-19_12-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:11 2023-09-19_12-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:12 2023-09-19_12-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:12 2023-09-19_12-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:13 2023-09-19_12-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 12:13 2023-09-19_12-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:14 2023-09-19_12-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:14 2023-09-19_12-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:16 2023-09-19_12-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:16 2023-09-19_12-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:17 2023-09-19_12-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:17 2023-09-19_12-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:18 2023-09-19_12-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:18 2023-09-19_12-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:19 2023-09-19_12-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:19 2023-09-19_12-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:20 2023-09-19_12-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:20 2023-09-19_12-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:21 2023-09-19_12-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:21 2023-09-19_12-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:22 2023-09-19_12-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:22 2023-09-19_12-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:23 2023-09-19_12-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:23 2023-09-19_12-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:24 2023-09-19_12-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:24 2023-09-19_12-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:25 2023-09-19_12-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:25 2023-09-19_12-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:26 2023-09-19_12-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:26 2023-09-19_12-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:27 2023-09-19_12-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:27 2023-09-19_12-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:28 2023-09-19_12-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:28 2023-09-19_12-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:29 2023-09-19_12-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:29 2023-09-19_12-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:30 2023-09-19_12-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:30 2023-09-19_12-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:31 2023-09-19_12-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 12:31 2023-09-19_12-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:32 2023-09-19_12-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:32 2023-09-19_12-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:33 2023-09-19_12-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  442 Sep 19 12:33 2023-09-19_12-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:34 2023-09-19_12-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 12:34 2023-09-19_12-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:35 2023-09-19_12-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:35 2023-09-19_12-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:36 2023-09-19_12-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:36 2023-09-19_12-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:37 2023-09-19_12-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:37 2023-09-19_12-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:38 2023-09-19_12-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:38 2023-09-19_12-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:39 2023-09-19_12-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:39 2023-09-19_12-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:41 2023-09-19_12-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 12:41 2023-09-19_12-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:42 2023-09-19_12-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  450 Sep 19 12:42 2023-09-19_12-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:43 2023-09-19_12-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:43 2023-09-19_12-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:44 2023-09-19_12-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:44 2023-09-19_12-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:45 2023-09-19_12-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:46 2023-09-19_12-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:47 2023-09-19_12-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:48 2023-09-19_12-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:49 2023-09-19_12-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:50 2023-09-19_12-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:51 2023-09-19_12-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:52 2023-09-19_12-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:53 2023-09-19_12-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:54 2023-09-19_12-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:55 2023-09-19_12-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:55 2023-09-19_12-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:56 2023-09-19_12-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:56 2023-09-19_12-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:57 2023-09-19_12-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:57 2023-09-19_12-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:58 2023-09-19_12-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:58 2023-09-19_12-58_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 12:59 2023-09-19_12-59_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 12:59 2023-09-19_12-59_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:00 2023-09-19_13-00_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 13:00 2023-09-19_13-00_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:01 2023-09-19_13-01_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:01 2023-09-19_13-01_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:02 2023-09-19_13-02_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:02 2023-09-19_13-02_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:03 2023-09-19_13-03_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:03 2023-09-19_13-03_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:04 2023-09-19_13-04_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:04 2023-09-19_13-04_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:05 2023-09-19_13-05_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:05 2023-09-19_13-05_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:06 2023-09-19_13-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:06 2023-09-19_13-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:07 2023-09-19_13-07_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:07 2023-09-19_13-07_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:08 2023-09-19_13-08_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:08 2023-09-19_13-08_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:09 2023-09-19_13-09_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:09 2023-09-19_13-09_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:10 2023-09-19_13-10_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:10 2023-09-19_13-10_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:11 2023-09-19_13-11_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:11 2023-09-19_13-11_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:12 2023-09-19_13-12_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:12 2023-09-19_13-12_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:13 2023-09-19_13-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:13 2023-09-19_13-13_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:14 2023-09-19_13-14_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:14 2023-09-19_13-14_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:15 2023-09-19_13-15_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:15 2023-09-19_13-15_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:16 2023-09-19_13-16_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 13:16 2023-09-19_13-16_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:17 2023-09-19_13-17_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:17 2023-09-19_13-17_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:18 2023-09-19_13-18_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:18 2023-09-19_13-18_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:19 2023-09-19_13-19_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  433 Sep 19 13:19 2023-09-19_13-19_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:20 2023-09-19_13-20_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:20 2023-09-19_13-20_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 2.4K Sep 19 13:21 2023-09-19_13-21_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:21 2023-09-19_13-21_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 2.9K Sep 19 13:22 2023-09-19_13-22_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:22 2023-09-19_13-22_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 3.7K Sep 19 13:23 2023-09-19_13-23_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:23 2023-09-19_13-23_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.3K Sep 19 13:24 2023-09-19_13-24_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:24 2023-09-19_13-24_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.4K Sep 19 13:25 2023-09-19_13-25_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:25 2023-09-19_13-25_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:26 2023-09-19_13-26_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:26 2023-09-19_13-26_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:27 2023-09-19_13-27_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:27 2023-09-19_13-27_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:28 2023-09-19_13-28_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:28 2023-09-19_13-28_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:29 2023-09-19_13-29_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:29 2023-09-19_13-29_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:30 2023-09-19_13-30_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:30 2023-09-19_13-30_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:31 2023-09-19_13-31_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:31 2023-09-19_13-31_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:32 2023-09-19_13-32_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  443 Sep 19 13:32 2023-09-19_13-32_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:33 2023-09-19_13-33_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 13:33 2023-09-19_13-33_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:34 2023-09-19_13-34_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 13:34 2023-09-19_13-34_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:35 2023-09-19_13-35_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:35 2023-09-19_13-35_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:36 2023-09-19_13-36_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:36 2023-09-19_13-36_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:37 2023-09-19_13-37_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:37 2023-09-19_13-37_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:38 2023-09-19_13-38_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  474 Sep 19 13:38 2023-09-19_13-38_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:39 2023-09-19_13-39_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:39 2023-09-19_13-39_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:40 2023-09-19_13-40_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 13:40 2023-09-19_13-40_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:41 2023-09-19_13-41_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:41 2023-09-19_13-41_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:42 2023-09-19_13-42_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 13:42 2023-09-19_13-42_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:43 2023-09-19_13-43_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  475 Sep 19 13:43 2023-09-19_13-43_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:44 2023-09-19_13-44_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:44 2023-09-19_13-44_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:45 2023-09-19_13-45_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:45 2023-09-19_13-45_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:46 2023-09-19_13-46_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:46 2023-09-19_13-46_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:47 2023-09-19_13-47_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:47 2023-09-19_13-47_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:48 2023-09-19_13-48_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:48 2023-09-19_13-48_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:49 2023-09-19_13-49_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:49 2023-09-19_13-49_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:50 2023-09-19_13-50_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  466 Sep 19 13:50 2023-09-19_13-50_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:51 2023-09-19_13-51_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:51 2023-09-19_13-51_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:52 2023-09-19_13-52_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 13:52 2023-09-19_13-52_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:53 2023-09-19_13-53_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:53 2023-09-19_13-53_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:54 2023-09-19_13-54_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:54 2023-09-19_13-54_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:55 2023-09-19_13-55_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  468 Sep 19 13:55 2023-09-19_13-55_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:56 2023-09-19_13-56_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:56 2023-09-19_13-56_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:57 2023-09-19_13-57_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:57 2023-09-19_13-57_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:58 2023-09-19_13-58_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:58 2023-09-19_13-58_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:59 2023-09-19_13-59_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:59 2023-09-19_13-59_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:00 2023-09-19_14-00_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:00 2023-09-19_14-00_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:01 2023-09-19_14-01_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:01 2023-09-19_14-01_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:02 2023-09-19_14-02_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:02 2023-09-19_14-02_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:03 2023-09-19_14-03_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:03 2023-09-19_14-03_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:04 2023-09-19_14-04_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:04 2023-09-19_14-04_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:05 2023-09-19_14-05_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:05 2023-09-19_14-05_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:06 2023-09-19_14-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:06 2023-09-19_14-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:07 2023-09-19_14-07_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:07 2023-09-19_14-07_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:08 2023-09-19_14-08_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:08 2023-09-19_14-08_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:09 2023-09-19_14-09_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:09 2023-09-19_14-09_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:10 2023-09-19_14-10_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:10 2023-09-19_14-10_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:11 2023-09-19_14-11_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:11 2023-09-19_14-11_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:12 2023-09-19_14-12_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:12 2023-09-19_14-12_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:13 2023-09-19_14-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 14:13 2023-09-19_14-13_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:14 2023-09-19_14-14_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:14 2023-09-19_14-14_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:15 2023-09-19_14-15_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:15 2023-09-19_14-15_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:16 2023-09-19_14-16_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:16 2023-09-19_14-16_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:17 2023-09-19_14-17_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 14:17 2023-09-19_14-17_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:18 2023-09-19_14-18_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:18 2023-09-19_14-18_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:19 2023-09-19_14-19_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:19 2023-09-19_14-19_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:20 2023-09-19_14-20_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:20 2023-09-19_14-20_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:21 2023-09-19_14-21_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:21 2023-09-19_14-21_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:22 2023-09-19_14-22_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:22 2023-09-19_14-22_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:23 2023-09-19_14-23_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:23 2023-09-19_14-23_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:24 2023-09-19_14-24_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  440 Sep 19 14:24 2023-09-19_14-24_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:25 2023-09-19_14-25_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:25 2023-09-19_14-25_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:26 2023-09-19_14-26_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:26 2023-09-19_14-26_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:27 2023-09-19_14-27_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:27 2023-09-19_14-27_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:28 2023-09-19_14-28_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:28 2023-09-19_14-28_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:29 2023-09-19_14-29_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:29 2023-09-19_14-29_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:30 2023-09-19_14-30_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 14:30 2023-09-19_14-30_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:31 2023-09-19_14-31_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:31 2023-09-19_14-31_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:32 2023-09-19_14-32_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:32 2023-09-19_14-32_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:33 2023-09-19_14-33_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  438 Sep 19 14:33 2023-09-19_14-33_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:34 2023-09-19_14-34_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:34 2023-09-19_14-34_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:35 2023-09-19_14-35_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:35 2023-09-19_14-35_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:36 2023-09-19_14-36_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:36 2023-09-19_14-36_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:37 2023-09-19_14-37_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:37 2023-09-19_14-37_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:38 2023-09-19_14-38_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:38 2023-09-19_14-38_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:39 2023-09-19_14-39_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:39 2023-09-19_14-39_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:40 2023-09-19_14-40_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:40 2023-09-19_14-40_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:41 2023-09-19_14-41_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:41 2023-09-19_14-41_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:42 2023-09-19_14-42_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:42 2023-09-19_14-42_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:43 2023-09-19_14-43_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 14:43 2023-09-19_14-43_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:44 2023-09-19_14-44_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:44 2023-09-19_14-44_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:45 2023-09-19_14-45_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:45 2023-09-19_14-45_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:46 2023-09-19_14-46_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:46 2023-09-19_14-46_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:47 2023-09-19_14-47_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  442 Sep 19 14:47 2023-09-19_14-47_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:48 2023-09-19_14-48_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:48 2023-09-19_14-48_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:49 2023-09-19_14-49_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:49 2023-09-19_14-49_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:50 2023-09-19_14-50_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 14:50 2023-09-19_14-50_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:51 2023-09-19_14-51_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:51 2023-09-19_14-51_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:52 2023-09-19_14-52_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:52 2023-09-19_14-52_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:53 2023-09-19_14-53_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:53 2023-09-19_14-53_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:54 2023-09-19_14-54_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:54 2023-09-19_14-54_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:55 2023-09-19_14-55_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:55 2023-09-19_14-55_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:56 2023-09-19_14-56_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:56 2023-09-19_14-56_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:57 2023-09-19_14-57_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:57 2023-09-19_14-57_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:58 2023-09-19_14-58_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:58 2023-09-19_14-58_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:59 2023-09-19_14-59_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:59 2023-09-19_14-59_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:00 2023-09-19_15-00_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  465 Sep 19 15:00 2023-09-19_15-00_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:01 2023-09-19_15-01_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 15:01 2023-09-19_15-01_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:02 2023-09-19_15-02_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:02 2023-09-19_15-02_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:03 2023-09-19_15-03_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:03 2023-09-19_15-03_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:04 2023-09-19_15-04_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 15:04 2023-09-19_15-04_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:05 2023-09-19_15-05_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:05 2023-09-19_15-05_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:06 2023-09-19_15-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:06 2023-09-19_15-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:07 2023-09-19_15-07_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:07 2023-09-19_15-07_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:08 2023-09-19_15-08_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 15:08 2023-09-19_15-08_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:09 2023-09-19_15-09_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:09 2023-09-19_15-09_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:10 2023-09-19_15-10_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 15:10 2023-09-19_15-10_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:11 2023-09-19_15-11_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:11 2023-09-19_15-11_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:12 2023-09-19_15-12_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 15:12 2023-09-19_15-12_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:13 2023-09-19_15-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:13 2023-09-19_15-13_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:14 2023-09-19_15-14_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:14 2023-09-19_15-14_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:15 2023-09-19_15-15_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:15 2023-09-19_15-15_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:16 2023-09-19_15-16_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:16 2023-09-19_15-16_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:17 2023-09-19_15-17_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:17 2023-09-19_15-17_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:18 2023-09-19_15-18_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:18 2023-09-19_15-18_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:19 2023-09-19_15-19_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 15:19 2023-09-19_15-19_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:20 2023-09-19_15-20_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 15:20 2023-09-19_15-20_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:21 2023-09-19_15-21_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 15:21 2023-09-19_15-21_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:22 2023-09-19_15-22_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:22 2023-09-19_15-22_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:23 2023-09-19_15-23_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:23 2023-09-19_15-23_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:24 2023-09-19_15-24_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 15:24 2023-09-19_15-24_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 6.1K Sep 19 15:25 2023-09-19_15-25_states.json.gz
            ubuntu@ubuntu:/opt/iobroker$
            E Thomas Braun 2 Replies Last reply Reply Quote 0
              Esmax666 @Esmax666 last edited by
              @esmax666 teil 2
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:16 2023-09-18_21-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:17 2023-09-18_21-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:17 2023-09-18_21-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:18 2023-09-18_21-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 21:18 2023-09-18_21-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:19 2023-09-18_21-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 21:19 2023-09-18_21-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:20 2023-09-18_21-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  447 Sep 18 21:20 2023-09-18_21-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:21 2023-09-18_21-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 21:21 2023-09-18_21-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:22 2023-09-18_21-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 21:22 2023-09-18_21-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:23 2023-09-18_21-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:23 2023-09-18_21-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:24 2023-09-18_21-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 18 21:24 2023-09-18_21-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:25 2023-09-18_21-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 18 21:25 2023-09-18_21-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:26 2023-09-18_21-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 21:26 2023-09-18_21-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:27 2023-09-18_21-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 21:27 2023-09-18_21-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:28 2023-09-18_21-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:28 2023-09-18_21-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:29 2023-09-18_21-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 18 21:29 2023-09-18_21-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:30 2023-09-18_21-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 18 21:30 2023-09-18_21-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:31 2023-09-18_21-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 21:31 2023-09-18_21-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:32 2023-09-18_21-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 18 21:32 2023-09-18_21-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:33 2023-09-18_21-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:33 2023-09-18_21-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:34 2023-09-18_21-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 21:34 2023-09-18_21-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:35 2023-09-18_21-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 21:35 2023-09-18_21-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:36 2023-09-18_21-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 21:36 2023-09-18_21-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:37 2023-09-18_21-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 21:37 2023-09-18_21-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:38 2023-09-18_21-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 21:38 2023-09-18_21-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:39 2023-09-18_21-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 21:39 2023-09-18_21-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:40 2023-09-18_21-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 21:40 2023-09-18_21-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:41 2023-09-18_21-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 18 21:41 2023-09-18_21-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:42 2023-09-18_21-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:42 2023-09-18_21-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:43 2023-09-18_21-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 21:43 2023-09-18_21-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:44 2023-09-18_21-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 21:44 2023-09-18_21-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:45 2023-09-18_21-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 21:45 2023-09-18_21-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:46 2023-09-18_21-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 21:46 2023-09-18_21-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:47 2023-09-18_21-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 21:47 2023-09-18_21-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:48 2023-09-18_21-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 21:48 2023-09-18_21-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:49 2023-09-18_21-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 21:49 2023-09-18_21-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:50 2023-09-18_21-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 21:50 2023-09-18_21-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:51 2023-09-18_21-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:51 2023-09-18_21-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:52 2023-09-18_21-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 21:52 2023-09-18_21-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:53 2023-09-18_21-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 18 21:53 2023-09-18_21-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:54 2023-09-18_21-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 18 21:54 2023-09-18_21-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:55 2023-09-18_21-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 21:55 2023-09-18_21-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:56 2023-09-18_21-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 18 21:56 2023-09-18_21-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:57 2023-09-18_21-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 21:57 2023-09-18_21-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:58 2023-09-18_21-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 18 21:58 2023-09-18_21-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:59 2023-09-18_21-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:59 2023-09-18_21-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:00 2023-09-18_22-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:00 2023-09-18_22-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:01 2023-09-18_22-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:01 2023-09-18_22-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:02 2023-09-18_22-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:02 2023-09-18_22-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:03 2023-09-18_22-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:03 2023-09-18_22-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:04 2023-09-18_22-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 18 22:04 2023-09-18_22-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:05 2023-09-18_22-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 18 22:05 2023-09-18_22-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:06 2023-09-18_22-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 22:06 2023-09-18_22-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:07 2023-09-18_22-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:07 2023-09-18_22-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:08 2023-09-18_22-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:08 2023-09-18_22-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:09 2023-09-18_22-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:09 2023-09-18_22-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:10 2023-09-18_22-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:10 2023-09-18_22-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:11 2023-09-18_22-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:11 2023-09-18_22-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:12 2023-09-18_22-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 22:12 2023-09-18_22-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:13 2023-09-18_22-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:13 2023-09-18_22-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:14 2023-09-18_22-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 22:14 2023-09-18_22-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:15 2023-09-18_22-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 18 22:15 2023-09-18_22-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:16 2023-09-18_22-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:16 2023-09-18_22-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:17 2023-09-18_22-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 22:17 2023-09-18_22-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:18 2023-09-18_22-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:18 2023-09-18_22-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:19 2023-09-18_22-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:19 2023-09-18_22-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:20 2023-09-18_22-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  484 Sep 18 22:20 2023-09-18_22-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:21 2023-09-18_22-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:21 2023-09-18_22-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:22 2023-09-18_22-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:22 2023-09-18_22-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:23 2023-09-18_22-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:23 2023-09-18_22-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:24 2023-09-18_22-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 22:24 2023-09-18_22-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:25 2023-09-18_22-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:25 2023-09-18_22-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:26 2023-09-18_22-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 18 22:26 2023-09-18_22-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:27 2023-09-18_22-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:27 2023-09-18_22-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:28 2023-09-18_22-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:28 2023-09-18_22-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:29 2023-09-18_22-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 22:29 2023-09-18_22-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:30 2023-09-18_22-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:30 2023-09-18_22-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:31 2023-09-18_22-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:31 2023-09-18_22-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:32 2023-09-18_22-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:32 2023-09-18_22-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:33 2023-09-18_22-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 22:33 2023-09-18_22-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:34 2023-09-18_22-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:34 2023-09-18_22-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:35 2023-09-18_22-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:35 2023-09-18_22-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:36 2023-09-18_22-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:36 2023-09-18_22-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:37 2023-09-18_22-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:37 2023-09-18_22-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:38 2023-09-18_22-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 22:38 2023-09-18_22-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:39 2023-09-18_22-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:39 2023-09-18_22-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:40 2023-09-18_22-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:40 2023-09-18_22-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:41 2023-09-18_22-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:41 2023-09-18_22-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:42 2023-09-18_22-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:42 2023-09-18_22-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:43 2023-09-18_22-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:43 2023-09-18_22-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:44 2023-09-18_22-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 22:44 2023-09-18_22-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:45 2023-09-18_22-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 18 22:45 2023-09-18_22-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:46 2023-09-18_22-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:46 2023-09-18_22-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:47 2023-09-18_22-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:47 2023-09-18_22-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:48 2023-09-18_22-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  485 Sep 18 22:48 2023-09-18_22-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:49 2023-09-18_22-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 22:49 2023-09-18_22-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:50 2023-09-18_22-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:50 2023-09-18_22-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:51 2023-09-18_22-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:51 2023-09-18_22-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:52 2023-09-18_22-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 22:52 2023-09-18_22-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:53 2023-09-18_22-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:53 2023-09-18_22-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:54 2023-09-18_22-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 22:54 2023-09-18_22-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:55 2023-09-18_22-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 22:55 2023-09-18_22-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:56 2023-09-18_22-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:56 2023-09-18_22-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:57 2023-09-18_22-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 22:57 2023-09-18_22-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:58 2023-09-18_22-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 18 22:58 2023-09-18_22-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:59 2023-09-18_22-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:59 2023-09-18_22-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:00 2023-09-18_23-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 23:00 2023-09-18_23-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:01 2023-09-18_23-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 18 23:01 2023-09-18_23-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:02 2023-09-18_23-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 18 23:02 2023-09-18_23-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:03 2023-09-18_23-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:03 2023-09-18_23-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:04 2023-09-18_23-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:04 2023-09-18_23-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:05 2023-09-18_23-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 23:05 2023-09-18_23-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:06 2023-09-18_23-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 23:06 2023-09-18_23-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:07 2023-09-18_23-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:07 2023-09-18_23-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:08 2023-09-18_23-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:08 2023-09-18_23-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:09 2023-09-18_23-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:09 2023-09-18_23-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:10 2023-09-18_23-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:10 2023-09-18_23-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:11 2023-09-18_23-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 23:11 2023-09-18_23-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:12 2023-09-18_23-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:12 2023-09-18_23-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:13 2023-09-18_23-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 18 23:13 2023-09-18_23-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:14 2023-09-18_23-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  484 Sep 18 23:14 2023-09-18_23-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:15 2023-09-18_23-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:15 2023-09-18_23-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:16 2023-09-18_23-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:16 2023-09-18_23-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:17 2023-09-18_23-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:17 2023-09-18_23-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:18 2023-09-18_23-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 23:18 2023-09-18_23-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:19 2023-09-18_23-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 23:19 2023-09-18_23-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:20 2023-09-18_23-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 23:20 2023-09-18_23-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:21 2023-09-18_23-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 23:21 2023-09-18_23-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:22 2023-09-18_23-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 23:22 2023-09-18_23-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:23 2023-09-18_23-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:23 2023-09-18_23-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:24 2023-09-18_23-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 23:24 2023-09-18_23-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:25 2023-09-18_23-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:25 2023-09-18_23-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:26 2023-09-18_23-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:26 2023-09-18_23-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:27 2023-09-18_23-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 18 23:27 2023-09-18_23-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:28 2023-09-18_23-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  450 Sep 18 23:28 2023-09-18_23-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:29 2023-09-18_23-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:29 2023-09-18_23-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:30 2023-09-18_23-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:30 2023-09-18_23-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:31 2023-09-18_23-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 23:31 2023-09-18_23-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:32 2023-09-18_23-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 23:32 2023-09-18_23-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:33 2023-09-18_23-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  484 Sep 18 23:33 2023-09-18_23-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:34 2023-09-18_23-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 23:34 2023-09-18_23-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:35 2023-09-18_23-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:35 2023-09-18_23-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:36 2023-09-18_23-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 18 23:36 2023-09-18_23-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:37 2023-09-18_23-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:37 2023-09-18_23-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:38 2023-09-18_23-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:38 2023-09-18_23-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:39 2023-09-18_23-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 23:39 2023-09-18_23-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:40 2023-09-18_23-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:40 2023-09-18_23-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:41 2023-09-18_23-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:41 2023-09-18_23-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:42 2023-09-18_23-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:42 2023-09-18_23-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:43 2023-09-18_23-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 23:43 2023-09-18_23-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:44 2023-09-18_23-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:44 2023-09-18_23-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:45 2023-09-18_23-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 18 23:45 2023-09-18_23-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:46 2023-09-18_23-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:46 2023-09-18_23-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:47 2023-09-18_23-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:47 2023-09-18_23-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:48 2023-09-18_23-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 23:48 2023-09-18_23-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:49 2023-09-18_23-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:49 2023-09-18_23-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:50 2023-09-18_23-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:50 2023-09-18_23-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:51 2023-09-18_23-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:51 2023-09-18_23-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:52 2023-09-18_23-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 23:52 2023-09-18_23-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:53 2023-09-18_23-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 18 23:53 2023-09-18_23-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:54 2023-09-18_23-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:54 2023-09-18_23-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:55 2023-09-18_23-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 18 23:55 2023-09-18_23-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:56 2023-09-18_23-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:56 2023-09-18_23-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:57 2023-09-18_23-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:57 2023-09-18_23-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:58 2023-09-18_23-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:58 2023-09-18_23-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:59 2023-09-18_23-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:59 2023-09-18_23-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:00 2023-09-19_00-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 00:00 2023-09-19_00-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:01 2023-09-19_00-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:01 2023-09-19_00-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:02 2023-09-19_00-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:02 2023-09-19_00-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:03 2023-09-19_00-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:03 2023-09-19_00-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:04 2023-09-19_00-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:04 2023-09-19_00-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:05 2023-09-19_00-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 00:05 2023-09-19_00-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:06 2023-09-19_00-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:06 2023-09-19_00-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:07 2023-09-19_00-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:07 2023-09-19_00-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:08 2023-09-19_00-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:08 2023-09-19_00-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:09 2023-09-19_00-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:09 2023-09-19_00-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:10 2023-09-19_00-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 00:10 2023-09-19_00-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:11 2023-09-19_00-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 00:11 2023-09-19_00-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:12 2023-09-19_00-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:12 2023-09-19_00-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:13 2023-09-19_00-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:13 2023-09-19_00-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:14 2023-09-19_00-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 00:14 2023-09-19_00-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:15 2023-09-19_00-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 00:15 2023-09-19_00-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:16 2023-09-19_00-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 00:16 2023-09-19_00-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:17 2023-09-19_00-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 00:17 2023-09-19_00-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:18 2023-09-19_00-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:18 2023-09-19_00-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:19 2023-09-19_00-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 00:19 2023-09-19_00-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:20 2023-09-19_00-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 00:20 2023-09-19_00-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:21 2023-09-19_00-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 00:21 2023-09-19_00-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:22 2023-09-19_00-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:22 2023-09-19_00-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:23 2023-09-19_00-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 00:23 2023-09-19_00-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:24 2023-09-19_00-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:24 2023-09-19_00-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:25 2023-09-19_00-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 00:25 2023-09-19_00-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:26 2023-09-19_00-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:26 2023-09-19_00-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:27 2023-09-19_00-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:27 2023-09-19_00-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:28 2023-09-19_00-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:28 2023-09-19_00-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:29 2023-09-19_00-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 00:29 2023-09-19_00-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:30 2023-09-19_00-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:30 2023-09-19_00-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:31 2023-09-19_00-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 00:31 2023-09-19_00-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:32 2023-09-19_00-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 00:32 2023-09-19_00-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:33 2023-09-19_00-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 00:33 2023-09-19_00-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:34 2023-09-19_00-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 00:34 2023-09-19_00-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:35 2023-09-19_00-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 00:35 2023-09-19_00-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:36 2023-09-19_00-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:36 2023-09-19_00-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:37 2023-09-19_00-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 00:37 2023-09-19_00-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:38 2023-09-19_00-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 00:38 2023-09-19_00-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:39 2023-09-19_00-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 00:39 2023-09-19_00-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:40 2023-09-19_00-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 00:40 2023-09-19_00-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:41 2023-09-19_00-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 00:41 2023-09-19_00-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:42 2023-09-19_00-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 00:42 2023-09-19_00-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:43 2023-09-19_00-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 00:43 2023-09-19_00-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:44 2023-09-19_00-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:44 2023-09-19_00-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:45 2023-09-19_00-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:45 2023-09-19_00-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:46 2023-09-19_00-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:46 2023-09-19_00-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:47 2023-09-19_00-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:47 2023-09-19_00-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:48 2023-09-19_00-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 00:48 2023-09-19_00-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:49 2023-09-19_00-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:49 2023-09-19_00-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:50 2023-09-19_00-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 00:50 2023-09-19_00-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:51 2023-09-19_00-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 00:51 2023-09-19_00-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:52 2023-09-19_00-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:52 2023-09-19_00-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:53 2023-09-19_00-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:53 2023-09-19_00-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:54 2023-09-19_00-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 00:54 2023-09-19_00-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:55 2023-09-19_00-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 00:55 2023-09-19_00-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:56 2023-09-19_00-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 00:56 2023-09-19_00-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:57 2023-09-19_00-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 00:57 2023-09-19_00-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:58 2023-09-19_00-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 00:58 2023-09-19_00-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:59 2023-09-19_00-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 00:59 2023-09-19_00-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:00 2023-09-19_01-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 01:00 2023-09-19_01-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:01 2023-09-19_01-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:01 2023-09-19_01-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:02 2023-09-19_01-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:02 2023-09-19_01-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:03 2023-09-19_01-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 01:03 2023-09-19_01-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:04 2023-09-19_01-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 01:04 2023-09-19_01-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:05 2023-09-19_01-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:05 2023-09-19_01-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:06 2023-09-19_01-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 01:06 2023-09-19_01-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:07 2023-09-19_01-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:07 2023-09-19_01-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:08 2023-09-19_01-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 01:08 2023-09-19_01-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:09 2023-09-19_01-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:09 2023-09-19_01-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:10 2023-09-19_01-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:10 2023-09-19_01-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:11 2023-09-19_01-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:11 2023-09-19_01-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:12 2023-09-19_01-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 01:12 2023-09-19_01-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:13 2023-09-19_01-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 01:13 2023-09-19_01-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:14 2023-09-19_01-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 01:14 2023-09-19_01-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:15 2023-09-19_01-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:15 2023-09-19_01-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:16 2023-09-19_01-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 01:16 2023-09-19_01-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:17 2023-09-19_01-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 01:17 2023-09-19_01-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:18 2023-09-19_01-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:18 2023-09-19_01-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:19 2023-09-19_01-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:19 2023-09-19_01-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:20 2023-09-19_01-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:20 2023-09-19_01-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:21 2023-09-19_01-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:21 2023-09-19_01-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:22 2023-09-19_01-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:22 2023-09-19_01-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:23 2023-09-19_01-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:23 2023-09-19_01-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:24 2023-09-19_01-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 01:24 2023-09-19_01-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:25 2023-09-19_01-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:25 2023-09-19_01-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:26 2023-09-19_01-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:26 2023-09-19_01-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:27 2023-09-19_01-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:27 2023-09-19_01-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:28 2023-09-19_01-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:28 2023-09-19_01-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:29 2023-09-19_01-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:29 2023-09-19_01-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:30 2023-09-19_01-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:30 2023-09-19_01-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:31 2023-09-19_01-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:31 2023-09-19_01-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:32 2023-09-19_01-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 01:32 2023-09-19_01-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:33 2023-09-19_01-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:33 2023-09-19_01-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:34 2023-09-19_01-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 01:34 2023-09-19_01-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:35 2023-09-19_01-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 01:35 2023-09-19_01-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:36 2023-09-19_01-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:36 2023-09-19_01-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:37 2023-09-19_01-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 01:37 2023-09-19_01-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:38 2023-09-19_01-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:38 2023-09-19_01-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:39 2023-09-19_01-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:39 2023-09-19_01-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:40 2023-09-19_01-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:40 2023-09-19_01-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:41 2023-09-19_01-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:41 2023-09-19_01-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:42 2023-09-19_01-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 01:42 2023-09-19_01-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:43 2023-09-19_01-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:43 2023-09-19_01-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:44 2023-09-19_01-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:44 2023-09-19_01-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:45 2023-09-19_01-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:45 2023-09-19_01-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:46 2023-09-19_01-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:46 2023-09-19_01-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:47 2023-09-19_01-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:47 2023-09-19_01-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:48 2023-09-19_01-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 01:48 2023-09-19_01-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:49 2023-09-19_01-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 01:49 2023-09-19_01-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:50 2023-09-19_01-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 01:50 2023-09-19_01-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:51 2023-09-19_01-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 01:51 2023-09-19_01-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:52 2023-09-19_01-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:52 2023-09-19_01-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:53 2023-09-19_01-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 01:53 2023-09-19_01-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:54 2023-09-19_01-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 01:54 2023-09-19_01-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:55 2023-09-19_01-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 01:55 2023-09-19_01-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:56 2023-09-19_01-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:56 2023-09-19_01-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:57 2023-09-19_01-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 01:57 2023-09-19_01-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:58 2023-09-19_01-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 01:58 2023-09-19_01-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:59 2023-09-19_01-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 01:59 2023-09-19_01-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:00 2023-09-19_02-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:00 2023-09-19_02-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:01 2023-09-19_02-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 02:01 2023-09-19_02-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:02 2023-09-19_02-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:02 2023-09-19_02-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:03 2023-09-19_02-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 02:03 2023-09-19_02-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:04 2023-09-19_02-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 02:04 2023-09-19_02-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:05 2023-09-19_02-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 02:05 2023-09-19_02-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:06 2023-09-19_02-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 02:06 2023-09-19_02-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:07 2023-09-19_02-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:07 2023-09-19_02-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:08 2023-09-19_02-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 02:08 2023-09-19_02-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:09 2023-09-19_02-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:09 2023-09-19_02-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:10 2023-09-19_02-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 02:10 2023-09-19_02-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:11 2023-09-19_02-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:11 2023-09-19_02-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:12 2023-09-19_02-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 02:12 2023-09-19_02-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:13 2023-09-19_02-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 02:13 2023-09-19_02-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:14 2023-09-19_02-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 02:14 2023-09-19_02-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:15 2023-09-19_02-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 02:15 2023-09-19_02-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:16 2023-09-19_02-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:16 2023-09-19_02-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:17 2023-09-19_02-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:17 2023-09-19_02-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:18 2023-09-19_02-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:18 2023-09-19_02-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:19 2023-09-19_02-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 02:19 2023-09-19_02-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:20 2023-09-19_02-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:20 2023-09-19_02-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:21 2023-09-19_02-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 02:21 2023-09-19_02-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:22 2023-09-19_02-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 02:22 2023-09-19_02-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:23 2023-09-19_02-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 02:23 2023-09-19_02-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:24 2023-09-19_02-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 02:24 2023-09-19_02-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:25 2023-09-19_02-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 02:25 2023-09-19_02-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:26 2023-09-19_02-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:26 2023-09-19_02-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:27 2023-09-19_02-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  489 Sep 19 02:27 2023-09-19_02-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:28 2023-09-19_02-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:28 2023-09-19_02-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:29 2023-09-19_02-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:29 2023-09-19_02-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:30 2023-09-19_02-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 02:30 2023-09-19_02-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:31 2023-09-19_02-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 02:31 2023-09-19_02-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:32 2023-09-19_02-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 02:32 2023-09-19_02-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:33 2023-09-19_02-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:33 2023-09-19_02-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:34 2023-09-19_02-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 02:34 2023-09-19_02-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:35 2023-09-19_02-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 02:35 2023-09-19_02-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:36 2023-09-19_02-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:36 2023-09-19_02-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:37 2023-09-19_02-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 02:37 2023-09-19_02-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:38 2023-09-19_02-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:38 2023-09-19_02-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:39 2023-09-19_02-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 02:39 2023-09-19_02-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:40 2023-09-19_02-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:40 2023-09-19_02-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:41 2023-09-19_02-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 02:41 2023-09-19_02-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:42 2023-09-19_02-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:42 2023-09-19_02-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:43 2023-09-19_02-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:43 2023-09-19_02-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:44 2023-09-19_02-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:44 2023-09-19_02-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:45 2023-09-19_02-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 02:45 2023-09-19_02-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:46 2023-09-19_02-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 02:46 2023-09-19_02-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:47 2023-09-19_02-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:47 2023-09-19_02-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:48 2023-09-19_02-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 02:48 2023-09-19_02-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:49 2023-09-19_02-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:49 2023-09-19_02-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:50 2023-09-19_02-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 02:50 2023-09-19_02-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:51 2023-09-19_02-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:51 2023-09-19_02-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:52 2023-09-19_02-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:52 2023-09-19_02-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:53 2023-09-19_02-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 02:53 2023-09-19_02-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:54 2023-09-19_02-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:54 2023-09-19_02-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:55 2023-09-19_02-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:55 2023-09-19_02-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:56 2023-09-19_02-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 02:56 2023-09-19_02-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:57 2023-09-19_02-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:57 2023-09-19_02-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:58 2023-09-19_02-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 02:58 2023-09-19_02-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:59 2023-09-19_02-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 02:59 2023-09-19_02-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:00 2023-09-19_03-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  486 Sep 19 03:00 2023-09-19_03-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:01 2023-09-19_03-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:01 2023-09-19_03-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:02 2023-09-19_03-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 03:02 2023-09-19_03-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:03 2023-09-19_03-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 03:03 2023-09-19_03-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:04 2023-09-19_03-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 03:04 2023-09-19_03-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:05 2023-09-19_03-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 03:05 2023-09-19_03-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:06 2023-09-19_03-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:06 2023-09-19_03-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:07 2023-09-19_03-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 03:07 2023-09-19_03-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:08 2023-09-19_03-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 03:08 2023-09-19_03-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:09 2023-09-19_03-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:09 2023-09-19_03-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:10 2023-09-19_03-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 03:10 2023-09-19_03-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:11 2023-09-19_03-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 03:11 2023-09-19_03-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:12 2023-09-19_03-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:12 2023-09-19_03-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:13 2023-09-19_03-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 03:13 2023-09-19_03-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:14 2023-09-19_03-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 03:14 2023-09-19_03-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:15 2023-09-19_03-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 03:15 2023-09-19_03-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:16 2023-09-19_03-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 03:16 2023-09-19_03-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:17 2023-09-19_03-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 03:17 2023-09-19_03-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:18 2023-09-19_03-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 03:18 2023-09-19_03-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:19 2023-09-19_03-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 03:19 2023-09-19_03-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:20 2023-09-19_03-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:20 2023-09-19_03-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:21 2023-09-19_03-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:21 2023-09-19_03-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:22 2023-09-19_03-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 03:22 2023-09-19_03-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:23 2023-09-19_03-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:23 2023-09-19_03-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:24 2023-09-19_03-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:24 2023-09-19_03-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:25 2023-09-19_03-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:25 2023-09-19_03-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:26 2023-09-19_03-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:26 2023-09-19_03-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:27 2023-09-19_03-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 03:27 2023-09-19_03-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:28 2023-09-19_03-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 03:28 2023-09-19_03-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:29 2023-09-19_03-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:29 2023-09-19_03-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:30 2023-09-19_03-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:30 2023-09-19_03-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:31 2023-09-19_03-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 03:31 2023-09-19_03-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:32 2023-09-19_03-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 03:32 2023-09-19_03-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:33 2023-09-19_03-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 03:33 2023-09-19_03-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:34 2023-09-19_03-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:34 2023-09-19_03-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:35 2023-09-19_03-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 03:35 2023-09-19_03-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:36 2023-09-19_03-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 03:36 2023-09-19_03-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:37 2023-09-19_03-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:37 2023-09-19_03-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:38 2023-09-19_03-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 03:38 2023-09-19_03-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:39 2023-09-19_03-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 03:39 2023-09-19_03-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:40 2023-09-19_03-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 03:40 2023-09-19_03-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:41 2023-09-19_03-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 03:41 2023-09-19_03-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:42 2023-09-19_03-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 03:42 2023-09-19_03-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:43 2023-09-19_03-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:43 2023-09-19_03-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:44 2023-09-19_03-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 03:44 2023-09-19_03-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:45 2023-09-19_03-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:45 2023-09-19_03-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:46 2023-09-19_03-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 03:46 2023-09-19_03-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:47 2023-09-19_03-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:47 2023-09-19_03-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:48 2023-09-19_03-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:48 2023-09-19_03-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:49 2023-09-19_03-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 03:49 2023-09-19_03-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:50 2023-09-19_03-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 03:50 2023-09-19_03-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:51 2023-09-19_03-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 03:51 2023-09-19_03-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:52 2023-09-19_03-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:52 2023-09-19_03-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:53 2023-09-19_03-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 03:53 2023-09-19_03-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:54 2023-09-19_03-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 03:54 2023-09-19_03-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:55 2023-09-19_03-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:55 2023-09-19_03-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:56 2023-09-19_03-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 03:56 2023-09-19_03-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:57 2023-09-19_03-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:57 2023-09-19_03-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:58 2023-09-19_03-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 03:58 2023-09-19_03-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:59 2023-09-19_03-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 03:59 2023-09-19_03-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:00 2023-09-19_04-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 04:00 2023-09-19_04-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:01 2023-09-19_04-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:01 2023-09-19_04-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:02 2023-09-19_04-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 04:02 2023-09-19_04-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:03 2023-09-19_04-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 04:03 2023-09-19_04-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:04 2023-09-19_04-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 04:04 2023-09-19_04-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:05 2023-09-19_04-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 04:05 2023-09-19_04-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:06 2023-09-19_04-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:06 2023-09-19_04-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:07 2023-09-19_04-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 04:07 2023-09-19_04-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:08 2023-09-19_04-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:08 2023-09-19_04-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:09 2023-09-19_04-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:09 2023-09-19_04-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:10 2023-09-19_04-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 04:10 2023-09-19_04-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:11 2023-09-19_04-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:11 2023-09-19_04-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:12 2023-09-19_04-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:12 2023-09-19_04-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:13 2023-09-19_04-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 04:13 2023-09-19_04-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:14 2023-09-19_04-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:14 2023-09-19_04-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:15 2023-09-19_04-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 04:15 2023-09-19_04-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:16 2023-09-19_04-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:16 2023-09-19_04-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:17 2023-09-19_04-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 04:17 2023-09-19_04-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:18 2023-09-19_04-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:18 2023-09-19_04-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:19 2023-09-19_04-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 04:19 2023-09-19_04-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:20 2023-09-19_04-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 04:20 2023-09-19_04-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:21 2023-09-19_04-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:21 2023-09-19_04-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:22 2023-09-19_04-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 04:22 2023-09-19_04-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:23 2023-09-19_04-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 04:23 2023-09-19_04-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:24 2023-09-19_04-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:24 2023-09-19_04-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:25 2023-09-19_04-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 04:25 2023-09-19_04-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:26 2023-09-19_04-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 04:26 2023-09-19_04-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:27 2023-09-19_04-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:27 2023-09-19_04-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:28 2023-09-19_04-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 04:28 2023-09-19_04-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:29 2023-09-19_04-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 04:29 2023-09-19_04-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:30 2023-09-19_04-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 04:30 2023-09-19_04-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:31 2023-09-19_04-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:31 2023-09-19_04-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:32 2023-09-19_04-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:32 2023-09-19_04-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:33 2023-09-19_04-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 04:33 2023-09-19_04-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:34 2023-09-19_04-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 04:34 2023-09-19_04-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:35 2023-09-19_04-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:35 2023-09-19_04-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:36 2023-09-19_04-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 04:36 2023-09-19_04-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:37 2023-09-19_04-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:37 2023-09-19_04-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:38 2023-09-19_04-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:38 2023-09-19_04-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:39 2023-09-19_04-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 04:39 2023-09-19_04-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:40 2023-09-19_04-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 04:40 2023-09-19_04-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:41 2023-09-19_04-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 04:41 2023-09-19_04-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:42 2023-09-19_04-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 04:42 2023-09-19_04-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:43 2023-09-19_04-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 04:43 2023-09-19_04-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:44 2023-09-19_04-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 04:44 2023-09-19_04-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:45 2023-09-19_04-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 04:45 2023-09-19_04-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:46 2023-09-19_04-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 04:46 2023-09-19_04-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:47 2023-09-19_04-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 04:47 2023-09-19_04-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:48 2023-09-19_04-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 04:48 2023-09-19_04-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:49 2023-09-19_04-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 04:49 2023-09-19_04-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:50 2023-09-19_04-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 04:50 2023-09-19_04-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:51 2023-09-19_04-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 04:51 2023-09-19_04-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:52 2023-09-19_04-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:52 2023-09-19_04-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:53 2023-09-19_04-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 04:53 2023-09-19_04-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:54 2023-09-19_04-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 04:54 2023-09-19_04-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:55 2023-09-19_04-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 04:55 2023-09-19_04-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:56 2023-09-19_04-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:56 2023-09-19_04-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:57 2023-09-19_04-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 04:57 2023-09-19_04-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:58 2023-09-19_04-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 04:58 2023-09-19_04-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:59 2023-09-19_04-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:59 2023-09-19_04-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:00 2023-09-19_05-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:00 2023-09-19_05-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:01 2023-09-19_05-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:01 2023-09-19_05-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:02 2023-09-19_05-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 05:02 2023-09-19_05-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:03 2023-09-19_05-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:03 2023-09-19_05-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:04 2023-09-19_05-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 05:04 2023-09-19_05-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:05 2023-09-19_05-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:05 2023-09-19_05-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:06 2023-09-19_05-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:06 2023-09-19_05-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:07 2023-09-19_05-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 05:07 2023-09-19_05-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:08 2023-09-19_05-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:08 2023-09-19_05-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:09 2023-09-19_05-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:09 2023-09-19_05-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:10 2023-09-19_05-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:10 2023-09-19_05-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:11 2023-09-19_05-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:11 2023-09-19_05-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:12 2023-09-19_05-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:12 2023-09-19_05-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:13 2023-09-19_05-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:13 2023-09-19_05-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:14 2023-09-19_05-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:14 2023-09-19_05-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:15 2023-09-19_05-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 05:15 2023-09-19_05-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:16 2023-09-19_05-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:16 2023-09-19_05-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:17 2023-09-19_05-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:17 2023-09-19_05-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:18 2023-09-19_05-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:18 2023-09-19_05-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:19 2023-09-19_05-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:19 2023-09-19_05-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:20 2023-09-19_05-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 05:20 2023-09-19_05-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:21 2023-09-19_05-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:21 2023-09-19_05-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:22 2023-09-19_05-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 05:22 2023-09-19_05-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:23 2023-09-19_05-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:23 2023-09-19_05-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:24 2023-09-19_05-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:24 2023-09-19_05-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:25 2023-09-19_05-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:25 2023-09-19_05-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:26 2023-09-19_05-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:26 2023-09-19_05-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:27 2023-09-19_05-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:27 2023-09-19_05-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:28 2023-09-19_05-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:28 2023-09-19_05-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:29 2023-09-19_05-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 05:29 2023-09-19_05-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:30 2023-09-19_05-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:30 2023-09-19_05-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:31 2023-09-19_05-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 05:31 2023-09-19_05-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:32 2023-09-19_05-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 05:32 2023-09-19_05-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:33 2023-09-19_05-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 05:33 2023-09-19_05-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:34 2023-09-19_05-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:34 2023-09-19_05-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:35 2023-09-19_05-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:35 2023-09-19_05-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:36 2023-09-19_05-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:36 2023-09-19_05-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:37 2023-09-19_05-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 05:37 2023-09-19_05-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:38 2023-09-19_05-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:38 2023-09-19_05-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:39 2023-09-19_05-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:39 2023-09-19_05-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:40 2023-09-19_05-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 05:40 2023-09-19_05-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:41 2023-09-19_05-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 05:41 2023-09-19_05-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:42 2023-09-19_05-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 05:42 2023-09-19_05-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:43 2023-09-19_05-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 05:43 2023-09-19_05-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:44 2023-09-19_05-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:44 2023-09-19_05-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:45 2023-09-19_05-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 05:45 2023-09-19_05-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:46 2023-09-19_05-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 05:46 2023-09-19_05-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:47 2023-09-19_05-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:47 2023-09-19_05-47_states.json.gz
                Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
                @esmax666 sagte in iobroker geht nicht nach stromausfall:
                ich kann nicht alles zeigen :
                Warum nicht?
                Scheinen aber keine Daten mehr von vor dem Crash vorhanden zu sein. Dann haste vermutlich Pech gehabt.
                Hast du wenigstens ein ordentliches Backup?
                  Esmax666 @Thomas Braun last edited by
                  putty consolle zeig mir nur das, vielleicht war da zu viel text, und er könnte nicht alles zeigen…
                    Nein, im Terminal Buffer ist Platz 'ohne Ende'.
                      Also hier oben bin ich blokiert, mein verlauf / line command sind weg
                        @esmax666
                        Man kann mit der Maus z.B. nach oben scrollen. In gescheiten Terminalprogrammen jedenfalls. Bei puTTY weiß ich es nicht...
                          @thomas-braun said in iobroker geht nicht nach stromausfall:
                          genau und dann bin ich geblockt
                          weiss für ein Terminalprogram soll ich nehmen ?
                          Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
                            @esmax666
                            Ich verwende die PowerShell.
                              @esmax666
                              Du kannst das auch in einen Pager wie 'less' rüberwerfen. Der kann definitiv große Ausgaben seitenweise anzeigen.
                              ls -lAh /opt/iobroker/iobroker-data/backup-objects/ | less
                                PowerShell
                                da bin ich auch limitiert
                                • OliverIO
                                  OliverIO @Esmax666 last edited by OliverIO
                                  Configure the scrollback buffer
                                  The scrollback buffer is the amount of text that PuTTY's SSH terminal keeps in memory and allows you to scroll back and review. By default, PuTTY sets the scrollback buffer to 200 lines, which may not be enough for some tasks or situations. To increase or decrease the scrollback buffer, open PuTTY and go to the Window category on the left pane. Then, enter the number of lines that you want in the Lines of scrollback box. You can also check the box that says Unlimited scrollback if you want PuTTY to keep all the text that you see on the terminal.
                                  bevor noch mehr verwirrung auch von neuen tools entsteht in die man sich erst reinfuchsen muss
                                    Thomas Braun Most Active @OliverIO last edited by
                                    Ah.
                                    PowerShell hier:
                                      Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                      @thomas-braun sagte in iobroker geht nicht nach stromausfall:
                                      Ah.
                                      PowerShell hier:
                                      nee, 9001 ist der Port für iob
                                        Mit less fängt das an mit
                                        total 150M
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:53 2023-09-17_19-53_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  472 Sep 17 19:53 2023-09-17_19-53_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:54 2023-09-17_19-54_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  465 Sep 17 19:54 2023-09-17_19-54_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:55 2023-09-17_19-55_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  463 Sep 17 19:55 2023-09-17_19-55_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:56 2023-09-17_19-56_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  460 Sep 17 19:56 2023-09-17_19-56_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:57 2023-09-17_19-57_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  447 Sep 17 19:57 2023-09-17_19-57_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:58 2023-09-17_19-58_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  457 Sep 17 19:58 2023-09-17_19-58_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:59 2023-09-17_19-59_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  455 Sep 17 19:59 2023-09-17_19-59_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:00 2023-09-17_20-00_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  468 Sep 17 20:00 2023-09-17_20-00_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:01 2023-09-17_20-01_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  467 Sep 17 20:01 2023-09-17_20-01_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:02 2023-09-17_20-02_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  470 Sep 17 20:02 2023-09-17_20-02_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:03 2023-09-17_20-03_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  470 Sep 17 20:03 2023-09-17_20-03_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:04 2023-09-17_20-04_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  457 Sep 17 20:04 2023-09-17_20-04_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:05 2023-09-17_20-05_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  468 Sep 17 20:05 2023-09-17_20-05_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:06 2023-09-17_20-06_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  461 Sep 17 20:06 2023-09-17_20-06_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:07 2023-09-17_20-07_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  463 Sep 17 20:07 2023-09-17_20-07_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:08 2023-09-17_20-08_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  477 Sep 17 20:08 2023-09-17_20-08_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:09 2023-09-17_20-09_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  467 Sep 17 20:09 2023-09-17_20-09_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:10 2023-09-17_20-10_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  465 Sep 17 20:10 2023-09-17_20-10_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:11 2023-09-17_20-11_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  461 Sep 17 20:11 2023-09-17_20-11_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:12 2023-09-17_20-12_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  466 Sep 17 20:12 2023-09-17_20-12_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:13 2023-09-17_20-13_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  476 Sep 17 20:13 2023-09-17_20-13_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:14 2023-09-17_20-14_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  467 Sep 17 20:14 2023-09-17_20-14_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:15 2023-09-17_20-15_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  457 Sep 17 20:15 2023-09-17_20-15_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:16 2023-09-17_20-16_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  468 Sep 17 20:16 2023-09-17_20-16_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:17 2023-09-17_20-17_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  469 Sep 17 20:17 2023-09-17_20-17_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:18 2023-09-17_20-18_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  469 Sep 17 20:18 2023-09-17_20-18_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:19 2023-09-17_20-19_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker  466 Sep 17 20:19 2023-09-17_20-19_states.json.gz
                                        die Datei die man braucht wäre eher
                                        2023-09-06_10-19_states.json.gz
                                        das wäre perfekt
                                          das wäre perfekt
                                          Die hast du aber nicht mehr. Kein anderweitiges, richtiges Backup?
                                            @thomas-braun ich hab gerade ein backupiobroker.tar backup gefunden
                                            ich wollte die Datei probieren aber ich bekomme
                                            10452
