    4. js-controller 5.0.x jetzt für alle User im STABLE!
    • foxriver76
      foxriver76 Developer @Wildbill last edited by
      @wildbill kannst du mal bitte den Sonos Adapter von GitHub probieren. Der nutzt keine binary states mehr für das Cover png.
        Wildbill @foxriver76 last edited by
        @foxriver76 Leider kein Erfolg Aber aus folgendem Grund. Der Sonos-Adapter startet nicht mehr...
        2023-09-20 07:48:56.137 - info: sonos.0 (63761) starting. Version 2.3.1 (non-npm: ioBroker/ioBroker.sonos) in /opt/iobroker/node_modules/iobroker.sonos, node: v18.17.1, js-controller: 5.0.12
        2023-09-20 07:48:56.909 - error: sonos.0 (63761) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-20 07:48:56.909 - error: sonos.0 (63761) unhandled promise rejection: Cannot read properties of undefined (reading 'name')
        2023-09-20 07:48:56.910 - error: sonos.0 (63761) TypeError: Cannot read properties of undefined (reading 'name')
        at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1483:51)
        at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1671:17)
        at SonosSystem. (/opt/iobroker/node_modules/iobroker.sonos/main.js:2073:17)
        at SonosSystem.emit (node:events:514:28)
        at /opt/iobroker/node_modules/sonos-discovery/lib/models/Player.js:324:30
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        2023-09-20 07:48:56.911 - error: sonos.0 (63761) Cannot read properties of undefined (reading 'name')
        2023-09-20 07:48:56.915 - error: sonos.0 (63761) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-20 07:48:56.916 - error: sonos.0 (63761) unhandled promise rejection: Cannot read properties of undefined (reading 'name')
        2023-09-20 07:48:56.916 - error: sonos.0 (63761) TypeError: Cannot read properties of undefined (reading 'name')
        2023-09-20 07:48:56.916 - error: sonos.0 (63761) Cannot read properties of undefined (reading 'name')
        2023-09-20 07:48:56.920 - info: sonos.0 (63761) terminating
        2023-09-20 07:48:56.928 - info: sonos.0 (63761) terminating
        2023-09-20 07:48:56.929 - warn: sonos.0 (63761) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-09-20 07:48:57.018 - error: sonos.0 (63761) Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
        2023-09-20 07:48:57.023 - error: sonos.0 (63761) Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
        2023-09-20 07:48:57.431 - info: sonos.0 (63761) terminating
        2023-09-20 07:48:57.551 - error: host.iobroker-vm instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-09-20 07:48:57.551 - info: host.iobroker-vm Restart adapter system.adapter.sonos.0 because enabled
        2023-09-20 07:48:57.552 - warn: host.iobroker-vm Do not restart adapter system.adapter.sonos.0 because restart loop detected
        • foxriver76
          @wildbill ok bitte nochmal updaten
            Wildbill @foxriver76 last edited by Wildbill
            @foxriver76 Bleibt leider rot (Lebenszeichen ist grün, verbunden mit Host bleibt rot). Dieses mal aber nur eine einzige Logzeile beim Start, nix weiter:
            2023-09-20 08:08:28.632 - info: sonos.0 (68978) starting. Version 2.3.1 (non-npm: ioBroker/ioBroker.sonos) in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.0, js-controller: 5.0.12
            Ich habe den Loglevel dann auf debug gestellt, aber finde nix Wildes.
            2023-09-20 08:10:40.404 - info: host.iobroker-vm instance system.adapter.sonos.0 started with pid 69025
            2023-09-20 08:10:41.282 - debug: sonos.0 (69025) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2023-09-20 08:10:41.330 - debug: sonos.0 (69025) Objects client ready ... initialize now
            2023-09-20 08:10:41.331 - debug: sonos.0 (69025) Objects create System PubSub Client
            2023-09-20 08:10:41.332 - debug: sonos.0 (69025) Objects create User PubSub Client
            2023-09-20 08:10:41.441 - debug: sonos.0 (69025) Objects client initialize lua scripts
            2023-09-20 08:10:41.445 - debug: sonos.0 (69025) Objects connected to redis: 0.0.0.0:9001
            2023-09-20 08:10:41.507 - debug: sonos.0 (69025) Redis States: Use Redis connection: 0.0.0.0:6379
            2023-09-20 08:10:41.511 - debug: sonos.0 (69025) States create System PubSub Client
            2023-09-20 08:10:41.511 - debug: sonos.0 (69025) States create User PubSub Client
            2023-09-20 08:10:41.518 - debug: sonos.0 (69025) States connected to redis: 0.0.0.0:6379
            2023-09-20 08:10:41.656 - info: sonos.0 (69025) starting. Version 2.3.1 (non-npm: ioBroker/ioBroker.sonos) in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.0, js-controller: 5.0.12
            2023-09-20 08:10:41.688 - debug: sonos.0 (69025) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-09-20 08:10:41.803 - debug: sonos.0 (69025) Initialize known devices: [{"type":"device","common":{"name":"root"},"native":{},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1695190108763,"_id":"sonos.0.root","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
            2023-09-20 08:10:41.861 - debug: sonos.0 (69025) Channels of root: [{"type":"channel","common":{"role":"media.music","name":"Bad"},"native":{"ip":"192.168.20.51"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1695190108876,"_id":"sonos.0.root.192_168_20_51","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},{"type":"channel","common":{"role":"media.music","name":"Wohnzimmer"},"native":{"ip":"192.168.20.54"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1695190109435,"_id":"sonos.0.root.192_168_20_54","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},{"type":"channel","common":{"role":"media.music","name":"Hobbyraum"},"native":{"ip":"192.168.20.47"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1695190109883,"_id":"sonos.0.root.192_168_20_47","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},{"type":"channel","common":{"role":"media.music","name":"Schlafzimmer"},"native":{"ip":"192.168.20.52"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1695190110386,"_id":"sonos.0.root.192_168_20_52","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
            2023-09-20 08:10:41.861 - debug: sonos.0 (69025) Process channel: sonos.0.root.192_168_20_51
            2023-09-20 08:10:41.914 - debug: sonos.0 (69025) Process channel: sonos.0.root.192_168_20_54
            2023-09-20 08:10:41.970 - debug: sonos.0 (69025) Process channel: sonos.0.root.192_168_20_47
            2023-09-20 08:10:42.022 - debug: sonos.0 (69025) Process channel: sonos.0.root.192_168_20_52
            2023-09-20 08:10:42.655 - debug: sonos.0 (69025) > playbackState: STOPPED - Manuel
            2023-09-20 08:10:42.659 - debug: sonos.0 (69025) Cover exists. Try reading from fs
            2023-09-20 08:10:42.690 - debug: sonos.0 (69025) > playbackState: STOPPED -
            2023-09-20 08:10:42.690 - debug: sonos.0 (69025) Cover exists. Try reading from fs
            2023-09-20 08:10:42.692 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.47:1400: false
            2023-09-20 08:10:42.730 - debug: sonos.0 (69025) group_muted: groupMuted for http://192.168.20.47:1400: false
            2023-09-20 08:10:42.738 - debug: sonos.0 (69025) > playbackState: STOPPED - Marooned
            2023-09-20 08:10:42.740 - debug: sonos.0 (69025) Cover exists. Try reading from fs
            2023-09-20 08:10:42.780 - debug: sonos.0 (69025) Update html-queue for 192_168_20_54: current html-queue is
            2023-09-20 08:10:42.780 - debug: sonos.0 (69025) Update html-queue for 192_168_20_54: current track number is 1
            2023-09-20 08:10:42.780 - debug: sonos.0 (69025) Update html-queue for 192_168_20_54: RegEx pattern is
            2023-09-20 08:10:42.781 - debug: sonos.0 (69025) Update html-queue for 192_168_20_54: no RegEx match
            2023-09-20 08:10:42.829 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.54:1400: false
            2023-09-20 08:10:42.830 - debug: sonos.0 (69025) volume: Volume for http://192.168.20.54:1400: 28
            2023-09-20 08:10:42.833 - debug: sonos.0 (69025) Update html-queue for 192_168_20_51: current html-queue is
            2023-09-20 08:10:42.833 - debug: sonos.0 (69025) Update html-queue for 192_168_20_51: current track number is 0
            2023-09-20 08:10:42.833 - debug: sonos.0 (69025) Update html-queue for 192_168_20_51: RegEx pattern is
            2023-09-20 08:10:42.834 - debug: sonos.0 (69025) Update html-queue for 192_168_20_51: no RegEx match
            2023-09-20 08:10:42.840 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.47:1400: false
            2023-09-20 08:10:42.841 - debug: sonos.0 (69025) volume: Volume for http://192.168.20.47:1400: 52
            2023-09-20 08:10:42.843 - debug: sonos.0 (69025) Update html-queue for 192_168_20_52: current html-queue is
            2023-09-20 08:10:42.843 - debug: sonos.0 (69025) Update html-queue for 192_168_20_52: current track number is 1
            2023-09-20 08:10:42.843 - debug: sonos.0 (69025) Update html-queue for 192_168_20_52: RegEx pattern is
            2023-09-20 08:10:42.844 - debug: sonos.0 (69025) Update html-queue for 192_168_20_52: no RegEx match
            2023-09-20 08:10:42.850 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.52:1400: false
            2023-09-20 08:10:42.851 - debug: sonos.0 (69025) volume: Volume for http://192.168.20.52:1400: 43
            2023-09-20 08:10:42.856 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.51:1400: false
            2023-09-20 08:10:42.856 - debug: sonos.0 (69025) volume: Volume for http://192.168.20.51:1400: 58
            2023-09-20 08:10:42.866 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.54:1400: false
            2023-09-20 08:10:42.867 - debug: sonos.0 (69025) group_muted: groupMuted for http://192.168.20.54:1400: false
            2023-09-20 08:10:42.871 - debug: sonos.0 (69025) > playbackState: STOPPED -
            2023-09-20 08:10:42.872 - debug: sonos.0 (69025) Cover exists. Try reading from fs
            2023-09-20 08:10:42.876 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.52:1400: false
            2023-09-20 08:10:42.877 - debug: sonos.0 (69025) group_muted: groupMuted for http://192.168.20.52:1400: false
            2023-09-20 08:10:42.879 - debug: sonos.0 (69025) mute: Mute for http://192.168.20.51:1400: false
            2023-09-20 08:10:42.880 - debug: sonos.0 (69025) group_muted: groupMuted for http://192.168.20.51:1400: false
            2023-09-20 08:10:42.931 - debug: sonos.0 (69025) group-volume: Volume for http://192.168.20.54:1400: 28
            2023-09-20 08:10:42.941 - debug: sonos.0 (69025) group-volume: Volume for http://192.168.20.47:1400: 52
            2023-09-20 08:10:42.951 - debug: sonos.0 (69025) group-volume: Volume for http://192.168.20.52:1400: 43
            2023-09-20 08:10:42.956 - debug: sonos.0 (69025) group-volume: Volume for http://192.168.20.51:1400: 58
            2023-09-20 08:10:43.042 - debug: sonos.0 (69025) Update html-queue for 192_168_20_47: current html-queue is
            2023-09-20 08:10:43.043 - debug: sonos.0 (69025) Update html-queue for 192_168_20_47: current track number is 0
            2023-09-20 08:10:43.043 - debug: sonos.0 (69025) Update html-queue for 192_168_20_47: RegEx pattern is
            2023-09-20 08:10:43.044 - debug: sonos.0 (69025) Update html-queue for 192_168_20_47: no RegEx match
            EDIT: Ach ja, ich hatte vorher alle vorhandenen Datenpunkte des Adapters gelöscht.
            • foxriver76
              @wildbill hm du sagst er bleibt rot? Weil schaut aus als läuft er laut log.
              W ofri2607 3 Replies Last reply Reply Quote 0
                @foxriver76 Ja, er war rot. Lebenszeichen grün, Verbunden mit Host rot.
                ABER: Ich habe eben einfach mal bei einem Lautsprecher mit dem Datenpunkt Play ein Abspielen gestartet. Das ging und komischerweise war die Verbindung mit dem Host danach da und alles grün. Manches muss man nicht verstehen.
                Backitup hat nun auch nur noch komische Zeichen bezüglich sayit.0.tts.mp3 im Log, wo eben wohl auch ein binary dahintersteckt?!
                Danke Dir aber erst einmal. Ein Problem weniger. 👍
                • foxriver76
                  @wildbill sayit nutzt in 3.0.5 eigentlich files statt binary states, vermutlich ist der State nur noch eine Karteileiche und kann gelöscht werden
                  W 1 Reply Last reply Reply Quote 2
                    @foxriver76 Tatsache. Adapter gestoppt, die beiden Datenpunkte gelöscht, Adapter wieder gestartet und sie tauchen nicht mehr auf. Funktionalität weiter gegeben. Perfekt.
                    Dank Dir!
                      stenmic @foxriver76 last edited by
                      @foxriver76
                      sobald ich in Blockly ein Blockly nur bewege springt der Status oben im Dateinamen schon auf nicht gespeichert.
                      Ich hoffe das ist kein neues feature... ist sehr nervig!
                        Wildbill @stenmic last edited by
                        @stenmic Siehe dieser Thread ab HIER.
                          stenmic @Wildbill last edited by
                          @wildbill ups... 😵
                          sorry... ich bin Blind
                            Letzi last edited by
                            Guten Abend.
                            Nach dem Update funktioniert der gsmsms Adapter nicht mehr.
                            v0.0.4
                            Verbunden mit Host -> bleibt rot
                            Lebenszeichen -> bleibt rot
                            Verbunden mit Gerät oder Dienst -> bleibt rot
                            Ist jemanden bekannt, ob es dazu erst ein update des Adapter geben muss?
                            Danke.
                            mcm1957 1 Reply Last reply Reply Quote -1
                              ronny130286 last edited by ronny130286
                              ich wollte heute meine js+controller auf meinem Raspi 4 updaten, dazu habe ich mir eien putty Session geöffnet und folgende Befehle verwendet:
                              iob backup
                              iob stop
                              iob update
                              iob fix
                              iob upgrade self
                              iob start
                              eigentlich genau so wie es in der Beschreibung zum js update stand.
                              Es läuft auch ohne Fehlermeldung durch, nur nach der Neustart ist immer noch der alte js-controller 4.0.24 installiert.
                              Was mache ich nur falsche?
                                Thomas Braun Most Active @ronny130286 last edited by
                                @ronny130286 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                Es läuft auf ohne Fehlermeldung durch
                                Aber mit welchen Meldungen läuft es denn durch?
                                  ronny130286 @Thomas Braun last edited by ronny130286
                                  @thomas-braun sorry meinte: Es läuft auch ohne Fehlermeldung durch....
                                  hier mal die Putty Ausgabe:
                                  pi@iobroker:~ $ iob stop
                                  pi@iobroker:~ $ iob update
                                  Used repository: stable
                                  Adapter    "accuweather"  : 1.3.1    , installed 1.2.4  [Updatable]
                                  Adapter    "admin"        : 6.10.1   , installed 6.8.0  [Updatable]
                                  Adapter    "alexa2"       : 3.25.2   , installed 3.24.1 [Updatable]
                                  Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                  Adapter    "growatt"      : 3.1.2    , installed 3.1.2
                                  Adapter    "history"      : 2.2.6    , installed 2.2.6
                                  Adapter    "info"         : 1.9.26   , installed 1.9.26
                                  Adapter    "javascript"   : 7.1.4    , installed 7.0.3  [Updatable]
                                  Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                                  Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                  Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                  Adapter    "nibeuplink"   : 1.3.0    , installed 1.3.0
                                  Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                  Adapter    "roomba"       : 1.1.4    , installed 1.1.4
                                  Adapter    "s7"           : 1.3.15   , installed 1.3.15
                                  Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
                                  Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                  Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                  Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                  Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "worx"         : 2.3.2    , installed 2.3.2
                                  Adapter    "ws"           : 2.5.5    , installed 2.5.4  [Updatable]
                                  Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                                  pi@iobroker:~ $ iob fix
                                  library: loaded
                                  Library version=2022-12-09
                                      Welcome to the ioBroker installation fixer!
                                      Script version: 2023-04-02
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/5)
                                  Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                  Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                  Holen:3 https://deb.nodesource.com/node_18.x buster InRelease [4.584 B]
                                  Holen:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,        0 MB]
                                  Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB        ]
                                  Es wurden 13,5 MB in 8 s geholt (1.698 kB/s).
                                  Installed gcc-c++
                                      Checking ioBroker user and directory permissions (2/5)
                                  Created /etc/sudoers.d/iobroker
                                  Fixing directory permissions...
                                      Check and cleanup npm temporary directories (3/5)
                                  Done.
                                      Database maintenance (4/5)
                                  Checking for uncompressed JSONL databases... This might take a while!
                                  Compressing /opt/iobroker/iobroker-data/states.jsonl
                                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                  Compressed 2 JSONL files. Done
                                      Checking autostart (5/5)
                                  Enabling autostart...
                                  Autostart enabled!
                                      Your installation was fixed successfully
                                      Run iobroker start to start ioBroker again!
                                  pi@iobroker:~ $ iob upgrade self
                                  Update js-controller from @4.0.24 to @5.0.12
                                  Stopped Objects DB
                                  Stopped States DB
                                  NPM version: 9.6.7
                                  Installing iobroker.js-controller@5.0.12... (System call)
                                  pi@iobroker:~ $ iob start
                                  pi@iobroker:~ $ node -v && nodejs -v && npm -v
                                  v18.17.1
                                  v18.17.1
                                  9.6.7
                                  • mcm1957
                                    mcm1957 @Letzi last edited by
                                    @letzi said in js-controller 5.0.x jetzt für alle User im STABLE!:
                                    Guten Abend.
                                    v0.0.4
                                    Danke.
                                    Bitte zeig mal ob bzw. was in den logs dazu steht.
                                    Eine neuere Version als 0.0.4 ist derzeit nicht verfügbar. Offenes Issue seh ich auch nicht.
                                    @forelleblau ist dir was bekannt bzw. kannst (wenn der log da ist) was dazu sagen?
                                      @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                      Bevor ich oben editiere schreibe ich es nochmal, weil ich grad einen ähnlichen Fall hatte. Ich habe meistens zwei Browser-Tabs offen, wenn ich in iobroker was mache. Bisher war es so, dass die Zustände über die Tabs hinweg eigentlich gleich waren. Wenn ich beispielsweise, warum auch immer, zwei Instanzen-Tabs aufhabe und in einer eine Instanz startete, war sie auch im anderen grün. Seit einem der letzten Updates (js-controller, admin, javascript…) scheint es nun nicht mehr so zu sein. Ich muss im zweiten Tab dann einmal die Seite aktualisieren, damit die Anzeige wieder passt. Heute morgen war es wohl auch irgendwie so, weil ich wohl vom Adapter aus die Instanzen geöffnet habe, die Instanz gestartet und dann gleich auf Log bin. Der zweite Tab mit den Instanzen war dann wohl noch rot, obwohl ja bereits alles lief.
                                      Ist da was bekannt, dass sich das Synchronisieren von parallel geöffneten Tabs geändert hat? Zumindest beim Umschalten auf Experte hat man ja nun die Möglichkeit auszuwählen, ob das über mehrere Browser-Tabs hinweg gelten soll.
                                      Gruss, Jürgen
                                        cfau last edited by
                                        hab jetzt auch mal auf den neuen js-controller 5.x upgedated. Leider läuft danach (als einziger) mein wichtigster Adapter KNX nicht mehr. Ein Neugenerieren bringt leider nur die Fehlermeldung im iobroker-Protokoll:
                                        host.IOBroker
                                        	2023-09-20 20:36:41.140	info	system.adapter.knx.0 will be rebuilt
                                        host.IOBroker
                                        	2023-09-20 20:36:41.139	info	Adapter system.adapter.knx.0 needs rebuild and will be restarted afterwards.
                                        host.IOBroker
                                        	2023-09-20 20:36:41.139	error	instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.139	error	Caught by controller[0]: Node.js v18.17.1
                                        host.IOBroker
                                        	2023-09-20 20:36:41.139	error	Caught by controller[0]: }
                                        host.IOBroker
                                        	2023-09-20 20:36:41.139	error	Caught by controller[0]: ]
                                        host.IOBroker
                                        	2023-09-20 20:36:41.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.knx/knx.js'
                                        host.IOBroker
                                        	2023-09-20 20:36:41.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.knx/lib/utils.js',
                                        host.IOBroker
                                        	2023-09-20 20:36:41.138	error	Caught by controller[0]: requireStack: [
                                        host.IOBroker
                                        	2023-09-20 20:36:41.138	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        host.IOBroker
                                        	2023-09-20 20:36:41.138	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                                        host.IOBroker
                                        	2023-09-20 20:36:41.138	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/lib/utils.js:67:25)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.137	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.136	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.136	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                        host.IOBroker
                                        	2023-09-20 20:36:41.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.knx/knx.js
                                        host.IOBroker
                                        	2023-09-20 20:36:41.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.knx/lib/utils.js
                                        host.IOBroker
                                        	2023-09-20 20:36:41.135	error	Caught by controller[0]: Require stack:
                                        host.IOBroker
                                        	2023-09-20 20:36:41.135	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                                        host.IOBroker
                                        	2023-09-20 20:36:41.135	error	Caught by controller[0]: ^
                                        host.IOBroker
                                        	2023-09-20 20:36:41.134	error	Caught by controller[0]: throw err;
                                        host.IOBroker
                                        	2023-09-20 20:36:41.134	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                                        host.IOBroker
                                        	2023-09-20 20:36:39.134	info	instance system.adapter.knx.0 started with pid 12950
                                        host.IOBroker
                                        	2023-09-20 20:36:38.986	info	iobroker npm-rebuild: exit 0
                                        host.IOBroker
                                        	2023-09-20 20:36:37.973	info	iobroker npm-rebuild: Rebuilding native modules done
                                        host.IOBroker
                                        	2023-09-20 20:36:37.972	info	iobroker npm-rebuild:
                                        host.IOBroker
                                        	2023-09-20 20:36:37.923	info	iobroker npm-rebuild: rebuilt dependencies successfully
                                        host.IOBroker
                                        	2023-09-20 20:36:17.397	info	iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@5.0.12" in /opt/iobroker/node_modules ...
                                        host.IOBroker
                                        	2023-09-20 20:36:15.794	info	iobroker rebuild iobroker.js-controller@5.0.12 --path /opt/iobroker/node_modules
                                        host.IOBroker
                                        	2023-09-20 20:36:15.793	warn	adapter "knx" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                        Kann mir da jemand vielleicht weiterhelfen?
                                        Grüße Christian
                                        Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @cfau last edited by
                                          @cfau sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                          Läuft doch noch. Abwarten.
                                          • foxriver76
                                            foxriver76 Developer @cfau last edited by
                                            @cfau welche Version vom KNX ist das denn, das scheint nicht aktuelle stable zu sein
                                            js-controller stable upgrade
                                            82
                                            509
                                            131907
