    3. Einsteigerfragen
    4. Installation
    5. ( gelöst ) IOBroker nicht mehr erreichbar
      Homoran Global Moderator Administrators @perladd last edited by
      @perladd nee, ist das dein Ernst?
      hast du das hier so gelesem
      TEXT immer als Text in code-tags
        perladd @Homoran last edited by
        ======= Start marking the full check here =========
        Skript v.2023-06-20
        *** BASE SYSTEM ***
         Static hostname: kali-raspberry-pi
               Icon name: computer
              Machine ID: 8d2228d5638647d99542c33414aa6f26
                 Boot ID: fb5e61b2eb74428aa764012251d98fa0
        Operating System: Kali GNU/Linux Rolling
                  Kernel: Linux 5.15.44-Re4son-v8l+
            Architecture: arm64
        Model           : Raspberry Pi 400 Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         14:16:48 up  2:36,  2 users,  load average: 0.89, 1.57, 1.14
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Wed 2023-09-20 14:16:49 UTC
                   Universal time: Wed 2023-09-20 14:16:49 UTC
                         RTC time: n/a
                        Time zone: Etc/UTC (UTC, +0000)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        Thomas
        /home/Thomas
        Thomas sudo iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:        lightdm-xsession
        Terminal:       x11
        *** MEMORY ***
        Mem:            4.0G        1.5G        1.2G         16M        1.4G        2.5G
        Swap:             0B          0B          0B
        Total:          4.0G        1.5G        1.2G
                 3794 M total memory
                 1385 M used memory
                  585 M active memory
                 1885 M inactive memory
                 1158 M free memory
                   88 M buffer memory
                 1227 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4       29G   17G   11G  63% /
        devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      252M   84M  168M  34% /boot
        tmpfs          tmpfs     380M   76K  380M   1% /run/user/1001
        [Wed Sep 20 11:40:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:F0:55:3D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c2030694-02 rootfstype=ext4 fsck.repair=yes rootwait net.ifnames=0
        [Wed Sep 20 11:40:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Wed Sep 20 11:40:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Sep 20 11:40:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,relatime,errors=remount-ro
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.6G    /var/
        835M    /var/log
        808M    /var/log/journal/8d2228d5638647d99542c33414aa6f26
        527M    /var/lib
        Archived and active journals take up 200.0M in the file system.
        /opt/iobroker/backups:
        56M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        170M    /opt/iobroker/iobroker-data/
        130M    /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        18M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.59233a80.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        8.3M    /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.59233a80.js
        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.13.0
        /usr/bin/node           v18.13.0
        /usr/bin/npm            9.2.0
        /usr/bin/npx            9.2.0
        nodejs:
          Installed: 18.13.0+dfsg1-1
          Candidate: 18.13.0+dfsg1-1
          Version table:
         *** 18.13.0+dfsg1-1 500
                500 http://http.kali.org/kali kali-rolling/main arm64 Packages
                100 /var/lib/dpkg/status
             16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          5.4.9
        javascript:     7.1.4
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : kali-raspberry-pi                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : kali-raspberry-pi                        -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : kali-raspberry-pi                        -  enabled
        + system.adapter.discovergy.0             : discovergy            : kali-raspberry-pi                        -  enabled
        + system.adapter.discovery.0              : discovery             : kali-raspberry-pi                        -  enabled
        + system.adapter.email.0                  : email                 : kali-raspberry-pi                        -  enabled
        + system.adapter.javascript.0             : javascript            : kali-raspberry-pi                        -  enabled
        + system.adapter.melcloud.0               : melcloud              : kali-raspberry-pi                        -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : kali-raspberry-pi                        - disabled, port: 1883
          system.adapter.mqtt.0                   : mqtt                  : kali-raspberry-pi                        - disabled, port: 1883, bind: 192.168.255.235
        + system.adapter.s7.0                     : s7                    : kali-raspberry-pi                        -  enabled
        + system.adapter.synology.0               : synology              : kali-raspberry-pi                        -  enabled, port: 5001
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : kali-raspberry-pi                        -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : kali-raspberry-pi                        -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : kali-raspberry-pi                        -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : kali-raspberry-pi                        -  enabled
          system.adapter.vis.0                    : vis                   : kali-raspberry-pi                        -  enabled
        + system.adapter.web.0                    : web                   : kali-raspberry-pi                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 5.4.9  [Updatable]
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
        Adapter    "s7"           : 1.3.15   , installed 1.3.15
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "synology"     : 2.1.13   , installed 2.1.13
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        806
        States:         675
        Hit:1 https://linux.teamviewer.com/deb stable InRelease
        Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:3 http://ftp.halifax.rwth-aachen.de/kali kali-rolling InRelease
        Hit:4 http://http.re4son-kernel.com/re4son kali-pi InRelease
        Reading package lists...
        Pending Updates: 1098
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14159      815/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       80092      36958/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       79204      36958/iobroker.js-c
        tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          14416      817/teamviewerd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14161      815/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1002       83617      37412/io.web.0
        udp        0      0 0.0.0.0:46583           0.0.0.0:*                           0          158168     817/teamviewerd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          8777       433/dhclient
        2023-09-20 12:59:37.393  - error: host.kali-raspberry-pi Caught by controller[0]: node:internal/modules/cjs/loader:1042
        2023-09-20 12:59:37.393  - error: host.kali-raspberry-pi Caught by controller[0]:   throw err;
        2023-09-20 12:59:37.393  - error: host.kali-raspberry-pi Caught by controller[0]:   ^
        2023-09-20 12:59:37.393  - error: host.kali-raspberry-pi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
        2023-09-20 12:59:37.393  - error: host.kali-raspberry-pi Caught by controller[0]: Require stack:
        2023-09-20 12:59:37.394  - error: host.kali-raspberry-pi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
        2023-09-20 12:59:37.394  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1039:15)
        2023-09-20 12:59:37.394  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:885:27)
        2023-09-20 12:59:37.394  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1105:19)
        2023-09-20 12:59:37.394  - error: host.kali-raspberry-pi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
        2023-09-20 12:59:37.394  - error: host.kali-raspberry-pi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:21:18)
        2023-09-20 12:59:37.395  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1218:14)
        2023-09-20 12:59:37.395  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1272:10)
        2023-09-20 12:59:37.395  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1081:32)
        2023-09-20 12:59:37.395  - error: host.kali-raspberry-pi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:12)
        2023-09-20 12:59:37.395  - error: host.kali-raspberry-pi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
        2023-09-20 12:59:37.395  - error: host.kali-raspberry-pi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2023-09-20 12:59:37.396  - error: host.kali-raspberry-pi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
        2023-09-20 12:59:37.396  - error: host.kali-raspberry-pi Caught by controller[0]: }
        2023-09-20 12:59:37.396  - error: host.kali-raspberry-pi Caught by controller[0]: Node.js v18.13.0
        2023-09-20 12:59:37.396  - error: host.kali-raspberry-pi instance system.adapter.admin.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2023-09-20 12:59:37.396  - info: host.kali-raspberry-pi Rebuild for adapter system.adapter.admin.1 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        2023-09-20 12:59:38.668  - info: s7.0 (46004) starting. Version 1.3.15 in /opt/iobroker/node_modules/iobroker.s7, node: v18.13.0, js-controller: 5.0.12
        2023-09-20 12:59:39.118  - info: s7.0 (46004) Connect in LOGO! mode to 512 / 256
        2023-09-20 12:59:39.148  - info: s7.0 (46004) Successfully connected in LOGO! mode
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
                             v.2023-06-20
               Icon name: computer
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Etc/UTC (UTC, +0000)
        User-ID:                1001
        X-Server:               true
        Boot Target:            graphical.target
        Pending OS-Updates:     1098
        Pending iob updates:    1
        Nodejs-Installation:    /usr/bin/nodejs         v18.13.0
                                /usr/bin/npm            9.2.0
                                /usr/bin/npx            9.2.0
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            4.0G        1.6G        1.1G         16M        1.4G        2.4G
        Swap:             0B          0B          0B
        Total:          4.0G        1.6G        1.1G
        Active iob-Instances:   9
        ioBroker Core:          js-controller           5.0.12
                                admin                   5.4.9
        Objects type: jsonl
        States  type: jsonl
        Objects:                806
        States:                 675
        Size of iob-Database:
        11M     /opt/iobroker/iobroker-data/objects.jsonl
        3.0M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        P Thomas Braun ? Homoran 4 Replies Last reply Reply Quote 0
          perladd @perladd last edited by
          @perladd
          sorry bin relativ neu hier und muss mich erst daran gewöhnen, wie ich was einfügen kann/muss
            @perladd sagte in IOBroker nicht mehr erreichbar:
            @perladd
            Genau dafür gibt es ja
            auf der Startseite für Einsteiger
              Thomas Braun Most Active @perladd last edited by
              Schlechte Wahl für einen Serverbetrieb. Kali ist für anderes gedacht.
              Keine / falsche Zeitzone gesetzt.
              X-Server: true
              Als Server läuft keine Graphische Oberfläche.
              Herzlichen Glückwunsch, das Ding ist komplett versumpft.
              • system.adapter.web.0 : web : kali-raspberry-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Da läuft kein admin.
              iob start admin
                perladd @Thomas Braun last edited by
                iob start admin
                hat leider nicht geholfen, komme immer noch nicht drauf
                Thomas Braun ? 3 Replies Last reply Reply Quote 0
                  @perladd
                  nodejs:
                    Version table:
                  Ist auch die falsche Version von nodejs.
                    A Former User @perladd last edited by
                    iob start admin
                    Moin,
                    noch etwas, was man sich angewöhnen sollte, nicht sagen, sondern zeigen. Am besten von der Eingabezeile mit dem Kommando bis zum Ende mit dem neuen Prompt 😉
                    Oder den passenden Logausschnitt 😉
                    VG
                    Bernd
                      @thomas-braun sagte in IOBroker nicht mehr erreichbar:
                      nodejs
                      wie bekomme ich den die richtige nodejs installiert
                        @perladd
                        Losgelöst von den ganzen schrägen/ungünstig gewählten Einstellungen des Basis-Systems, lass das Skript von hier mal laufen:
                        https://forum.iobroker.net/topic/68035/iob-node-fix-skript
                        Das sollte dir zumindest die richtige Version von nodejs liefern.
                        Hier würde mich allerdings der vollständige Output des Skripts in Textform interessieren.
                          perladd @Thomas Braun last edited by Homoran
                          ioBroker nodejs fixer 2023-09-20
                          No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                          Your current setup is:
                          /usr/bin/npm            9.2.0
                          /usr/bin/npx            9.2.0
                          We found these nodejs versions available for installation:
                          nodejs:
                            Version table:
                          Nothing to do, your installation is using the correct paths.
                          You are running nodejs v18.13.0. Do you want to install recommended version tree 18 ?
                          Press <y> to continue or any other key to quit
                            Das solltest du tun. Also y drücken.
                            P 2 Replies Last reply Reply Quote 0
                              danach kam nichts mehr 🙂
                                /usr/bin/npm            9.2.0
                                /usr/bin/npx            9.2.0
                                nodejs:
                                  Version table:
                                ┌──(Thomas㉿kali-raspberry-pi)-[/opt/iobroker]
                                  @perladd
                                  Skript auch mit den richtigen Rechten versehen?
                                    Sorry, lesende sind klar im Vorteil, hab nicht auf "Y" gedrückt, arbeitet gerade noch
                                      Du bist da in eine Subshell geraten. Ich vermute, dein l33tes HaX0r-Linuks hantiert da mit einer veränderten shell.
                                      Mag ich mich aber wegen 'Exoten-Status' nicht weiter drum kümmern.
                                      Installier da eine gescheite Basis für den Betrieb als Server, z. B. ein reines Debian/Raspberry OS.
                                        Moin,
                                        kannst Du uns auch erklären, warum Du diese Distribution genommen hast?
                                        Das ist ja schon von anderer Seite gesagt worden, dass Kali Linux für etwas ganz anderes genutzt wird und daher eher schlecht als Server Betriebssystem geeignet ist.
                                        Falls du Backups, mittels BackitUp Adapter erstellt hast, wäre es vielleicht an der Zeit das System von Grund auf neu aufzusetzen, dann gleich mit einem passenden Debian light 32/64 je nachdem welchen RasPi Du hast.
                                        VG
                                        Bernd
                                          perladd @Guest last edited by
                                          @dp20eic
                                          ich kenne mich mit Linux halt gar nicht aus, und habe gelesen das der Raspberry mit dem Kali am einfachsten zu installieren wäre, das war der Grund. Wenn ich denn neu installieren sollte/muss, bekomme ich die Einstellungen bzw. meine vorhanden Skripte auf dem neuen System überspielt
                                          Homoran Thomas Braun ? 3 Replies Last reply Reply Quote 0
                                            das ist der Sinn eines korrekt eingerichteten Backups
                                            3776
