    4. iobroker geht nicht nach stromausfall
      Esmax666 @Thomas Braun last edited by
      @thomas-braun said in iobroker geht nicht nach stromausfall:
      Backup
      ok ich versuche heute abend
        ok ist gemacht leider das PRoblem ist immer noch da:
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: ubuntu
                 Icon name: computer
                Machine ID: 551875df55414c0f832b43a896fe8ce5
                   Boot ID: a58fe4cd23274d7e86463c9c059dca8f
          Operating System: Ubuntu 21.04
                    Kernel: Linux 5.11.0-1027-raspi
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         17:04:34 up 1 day,  5:13,  1 user,  load average: 0.23, 0.27, 0.19
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Wed 2023-09-20 17:04:34 CEST
                   Universal time: Wed 2023-09-20 15:04:34 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        ubuntu
        /home/ubuntu
        ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        328M        5.3G        3.0M        2.3G        7.5G
        Swap:            0B          0B          0B
        Total:         7.9G        328M        5.3G
                 7886 M total memory
                  328 M used memory
                  638 M active memory
                 1645 M inactive memory
                 5289 M free memory
                  311 M buffer memory
                 1956 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        tmpfs          tmpfs  789M  4.0M  785M   1% /run
        /dev/sda2      ext4    57G  7.6G   47G  14% /
        tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
        /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
        tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
        [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
        [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET              SOURCE     FSTYPE   OPTIONS
        /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
        |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
        |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
        |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
        |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
        |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
        |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
        |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
        |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
        |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
        |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
        `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.2G    /var/
        1.9G    /var/log
        1.7G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
        1.2G    /var/lib
        Archived and active journals take up 1.6G in the file system.
        /opt/iobroker/backups:
        50M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        369M    /opt/iobroker/iobroker-data/
        193M    /opt/iobroker/iobroker-data/files
        162M    /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.0
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.0-1nodesource1
          Candidate: 18.18.0-1nodesource1
          Version table:
         *** 18.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.21.0~dfsg-3ubuntu1 500
                500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  3.3.22
        hab dann probiert auch backiup auf 2.2.2 zu machen aber laut " list adapters" hat das nicht funktionniert
        ubuntu@ubuntu:/opt/iobroker$ iob stop
        ubuntu@ubuntu:/opt/iobroker$ npm install iobroker.backitup@2.2.2
        up to date in 7s
        124 packages are looking for funding
          run `npm fund` for details
        ubuntu@ubuntu:/opt/iobroker$ iob start
        ubuntu@ubuntu:/opt/iobroker$ iob list adapters
        system.adapter.admin                   : admin          - v6.10.1
        system.adapter.alexa2                  : alexa2         - v3.25.2
        system.adapter.backitup                : backitup       - v2.6.23
        system.adapter.cloud                   : cloud          - v4.4.1
        system.adapter.discovery               : discovery      - v3.1.0
        system.adapter.flot                    : flot           - v1.12.0
        system.adapter.heatingcontrol          : heatingcontrol - v2.11.1
        system.adapter.history                 : history        - v2.2.6
        system.adapter.ical                    : ical           - v1.13.3
        system.adapter.info                    : info           - v1.9.26
        system.adapter.iot                     : iot            - v1.14.5
        system.adapter.javascript              : javascript     - v7.1.4
        system.adapter.linkeddevices           : linkeddevices  - v1.5.5
        system.adapter.radar2                  : radar2         - v2.0.7
        system.adapter.rpi2                    : rpi2           - v1.3.2
        system.adapter.shuttercontrol          : shuttercontrol - v1.6.1
        system.adapter.simple-api              : simple-api     - v2.7.2
        system.adapter.socketio                : socketio       - v6.5.5
        system.adapter.telegram                : telegram       - v1.16.0
        system.adapter.text2command            : text2command   - v3.0.2
        system.adapter.tr-064                  : tr-064         - v4.2.18
        system.adapter.vis                     : vis            - v1.4.16
        system.adapter.vis-colorpicker         : vis-colorpicker - v2.0.3
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
        system.adapter.vis-metro               : vis-metro      - v1.2.0
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
        system.adapter.web                     : web            - v6.1.2
        system.adapter.zwave2                  : zwave2         - v3.0.5
          Thomas Braun Most Active @Esmax666 last edited by
          @esmax666
          Versuch mal
          iobroker restore <BACKUPDATEI>
            iobroker restore
            und wie gebe ich die datei rein ?
              Homoran Global Moderator Administrators @Esmax666 last edited by
              @esmax666 sagte in iobroker geht nicht nach stromausfall:
              iobroker restore
              wo ist die denn?
                @esmax666
                Am besten kopierst du die Datei erstmal nach /opt/iobroker/backup und dann in dem Verzeichnis ausführen.
                  Sagt mal!
                  warum befinden wir uns in der Englischen Sektion des Forums?
                  DJMarc75 E 2 Replies Last reply Reply Quote 0
                  • DJMarc75
                    DJMarc75 @Homoran last edited by
                    @homoran sagte in iobroker geht nicht nach stromausfall:
                    while wers cannen 🤡
                      Esmax666 @Homoran last edited by
                      C:\Users\xxxx\Downloads\iobroker_2022_09_06-02_40_10_backupiobroker.tar.gz
                        das war falsch Sorry 😞
                          Ehrlich??
                          über ein Jahr alt?
                          kopiers erst einmal ins iobroker Verzeichnis /opt/iobroker/backups oder wo auch immer das unter Windows liegt
                            Esmax666 @Homoran last edited by Esmax666
                            @homoran said in iobroker geht nicht nach stromausfall:
                            über ein Jahr alt?
                            ja klar da war nicht mehr geändert
                            @esmax666
                            also ich könnte über SSH ein backup wieder spielen
                            aber jetzt habe ich wieder kein zugriff auf iobroker weboberfläche
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : armhf
                             18:28:19 up 1 day,  6:37,  1 user,  load average: 0.39, 0.94, 0.69
                            CPU threads: 4
                                           Local time: Wed 2023-09-20 18:28:19 CEST
                                       Universal time: Wed 2023-09-20 16:28:19 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            ubuntu
                            /home/ubuntu
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           7.9G        215M        5.3G        3.0M        2.4G        7.6G
                            Swap:            0B          0B          0B
                            Total:         7.9G        215M        5.3G
                                     7886 M total memory
                                      215 M used memory
                                      843 M active memory
                                     1412 M inactive memory
                                     5318 M free memory
                                      312 M buffer memory
                                     2040 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            *** FILESYSTEM ***
                            /var:
                            3.2G    /var/
                            1.9G    /var/log
                            1.2G    /var/lib
                            363M    /opt/iobroker/iobroker-data/
                            151M    /opt/iobroker/iobroker-data/backup-objects
                            11M     /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                            ioBroker Status
                             Cannot read system.config: null (OK when migrating or restoring)
                            iobroker is not running on this host.
                            Objects type: file
                            States  type: file
                            Objects:                    file on 127.0.0.1
                            States:                     file on 127.0.0.1
                            admin:          6.10.1
                            javascript:     7.1.4
                            Adapters from github:   0
                            Adapter State
                             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            + instance is alive
                            ioBroker-Repositories
                            Cannot get list: undefined
                            Installed ioBroker-Instances
                            Error: Object "system.config" not found
                            ^C
                            ubuntu@ubuntu:/opt/iobroker/backups$ cd ..
                              @esmax666
                              Wenn das Backup sitzt würde ich jetzt über den js-controller4 wider nach oben klettern.
                                klettern
                                ok das habe ich gemacht, version ist jetzt aktualiert aber wieder alles ist reseted:
                                und kein instence mehr ... upgrade hat alles gelöscht
                                  @thomas-braun also ich habe nochmal ein downgard probiert und ein andere backup probiert :
                                  ubuntu@ubuntu:/opt/iobroker$ iobroker restore iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
                                  iobroker controller daemon is not running
                                  host.ubuntu OK.
                                  The current version of js-controller differs from the version in the backup.
                                  The js-controller version of the backup can not be restored automatically.
                                  To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.3.18 --production" inside your ioBroker directory
                                  If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                                  ubuntu@ubuntu:/opt/iobroker$ ^C
                                  ubuntu@ubuntu:/opt/iobroker$ npm install iobroker.js-controller@3.3.22
                                  added 33 packages, removed 17 packages, and changed 12 packages in 31s
                                  ubuntu@ubuntu:/opt/iobroker$ cd backups/
                                  ubuntu@ubuntu:/opt/iobroker/backups$ iobroker restore iobroker_2022_09_20-02_40_10_backupiobroker.tar.gz
                                  host.ubuntu OK.
                                  host.ubuntu Clear all objects and states...
                                  clean 142 objects...
                                  Server Objects 127.0.0.1:48528 Error from InMemDB: Error: Object is marked as non deletable
                                  [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                                  [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                                  [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
                                  [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                                  [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
                                  [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
                                  clean 104 states...
                                  host.ubuntu done.
                                  host.ubuntu Processed 0/3050 states
                                  host.ubuntu Processed 200/3050 states
                                  host.ubuntu Processed 400/3050 states
                                  host.ubuntu Processed 600/3050 states
                                  host.ubuntu Processed 800/3050 states
                                  host.ubuntu Processed 1000/3050 states
                                  host.ubuntu Processed 1200/3050 states
                                  host.ubuntu Processed 1400/3050 states
                                  host.ubuntu Processed 1600/3050 states
                                  host.ubuntu Processed 1800/3050 states
                                  host.ubuntu Processed 2000/3050 states
                                  host.ubuntu Processed 2200/3050 states
                                  host.ubuntu Processed 2400/3050 states
                                  host.ubuntu Processed 2600/3050 states
                                  host.ubuntu Processed 2800/3050 states
                                  host.ubuntu Processed 3000/3050 states
                                  3050 states restored.
                                  host.ubuntu Processed 0/4382 objects
                                  host.ubuntu Processed 200/4382 objects
                                  host.ubuntu Processed 400/4382 objects
                                  host.ubuntu Processed 600/4382 objects
                                  host.ubuntu Processed 800/4382 objects
                                  host.ubuntu Processed 1000/4382 objects
                                  host.ubuntu Processed 1200/4382 objects
                                  host.ubuntu Processed 1400/4382 objects
                                  host.ubuntu Processed 1600/4382 objects
                                  host.ubuntu Processed 1800/4382 objects
                                  host.ubuntu Processed 2000/4382 objects
                                  host.ubuntu Processed 2200/4382 objects
                                  host.ubuntu Processed 2400/4382 objects
                                  host.ubuntu Processed 2600/4382 objects
                                  host.ubuntu Processed 2800/4382 objects
                                  host.ubuntu Processed 3000/4382 objects
                                  host.ubuntu Processed 3200/4382 objects
                                  host.ubuntu Processed 3400/4382 objects
                                  host.ubuntu Processed 3600/4382 objects
                                  host.ubuntu Processed 3800/4382 objects
                                  host.ubuntu Processed 4000/4382 objects
                                  host.ubuntu Processed 4200/4382 objects
                                  4382 objects restored.
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular (1).woff
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.eot
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.ttf
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff2
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/edit_copy.svg
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w.svg
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w_open.svg
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/heatingcontrol.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-128x128.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-512x512.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-128x128.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-512x512.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-128x128.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-512x512.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-128x128.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-512x512.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-128x128.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-512x512.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-128x128.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-512x512.png
                                  host.ubuntu Upload user file "vis.0/HeatingControl/images/it_wifi.svg
                                  host.ubuntu Upload user file "vis.0/HeatingControl/vis-user.css
                                  host.ubuntu Upload user file "vis.0/HeatingControl/vis-views.json
                                  host.ubuntu Upload user file "vis.0/main/vis-views.json
                                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map application/json
                                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map application/json
                                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js application/javascript
                                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map application/json
                                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js application/javascript
                                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map application/json
                                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js application/javascript
                                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js.map custom/static/js/main.681927cc.js.map application/json
                                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
                                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/en.json custom/i18n/en.json application/json
                                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
                                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
                                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                  upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                                  upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                                  upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                  upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                  upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                  upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                                  upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                                  upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                                  upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                  upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                  upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                                  upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                                  upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                  upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
                                  upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_cube.png icons/echo_cube.png image/png
                                  upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo4.png icons/echo4.png image/png
                                  upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
                                  upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
                                  upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo-input.png icons/echo-input.png image/png
                                  upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
                                  upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                  upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                                  upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                                  upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                                  upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                                  upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                                  upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                                  upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                                  upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                  upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                  upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                  upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                  upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                  upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
                                  upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
                                  upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
                                  upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
                                  upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
                                  upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
                                  upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
                                  upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
                                  upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
                                  upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
                                  upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
                                  upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
                                  upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
                                  upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
                                  upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
                                  upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
                                  upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
                                  upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
                                  upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
                                  upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
                                  upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
                                  upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                                  host.ubuntu Setup "iobroker.flot" adapter
                                  upload [4] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/words.js words.js application/javascript
                                  upload [3] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/style.css style.css text/css
                                  upload [2] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/index_m.html index_m.html text/html
                                  upload [1] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/img/info-big.png img/info-big.png image/png
                                  upload [0] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/heatingcontrol.png heatingcontrol.png image/png
                                  upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                                  upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                                  upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                                  upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                  upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                                  upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                                  upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                  upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
                                  upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootbox.min.js lib/js/bootbox.min.js application/javascript
                                  upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/redhat.png lib/img/logos/redhat.png image/png
                                  upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/mandriva.png lib/img/logos/mandriva.png image/png
                                  upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/centos.png lib/img/logos/centos.png image/png
                                  upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/graphics.png lib/img/icons/graphics.png image/png
                                  upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                  upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                  upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                  upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                  upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                  upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                  upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                  upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                  upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                  upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                  upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Shutters.db7d7b0d498f40779210.svg static/media/Shutters.db7d7b0d498f40779210.svg image/svg+xml
                                  upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Power Consumption.4faab614c3c788f2d338.svg static/media/Power Consumption.4faab614c3c788f2d338.svg image/svg+xml
                                  upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Louvre.75b84cd3d39d68107807.svg static/media/Louvre.75b84cd3d39d68107807.svg image/svg+xml
                                  upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Irrigation.d5fa30e9c2a519167964.svg static/media/Irrigation.d5fa30e9c2a519167964.svg image/svg+xml
                                  upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Hairdryer.5960b514dac1f04f3c4d.svg static/media/Hairdryer.5960b514dac1f04f3c4d.svg image/svg+xml
                                  upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Front Yard.af9ce2d89aa4d7a9363e.svg static/media/Front Yard.af9ce2d89aa4d7a9363e.svg image/svg+xml
                                  upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Dishwashers.3709566b7214596236b7.svg static/media/Dishwashers.3709566b7214596236b7.svg image/svg+xml
                                  upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Climate.b7e9896e7f103360bb5a.svg static/media/Climate.b7e9896e7f103360bb5a.svg image/svg+xml
                                  upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Basement.fe636968eec9556bfd1f.svg static/media/Basement.fe636968eec9556bfd1f.svg image/svg+xml
                                  upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Barn.5d839e84c80918ce2ef0.svg static/media/Barn.5d839e84c80918ce2ef0.svg image/svg+xml
                                  upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Balcony.2f76ef0877aaa3bd2ff7.svg static/media/Balcony.2f76ef0877aaa3bd2ff7.svg image/svg+xml
                                  upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Awnings.78480df8796f09859b6a.svg static/media/Awnings.78480df8796f09859b6a.svg image/svg+xml
                                  upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Attic.bb5d690a160bb1d4edb2.svg static/media/Attic.bb5d690a160bb1d4edb2.svg image/svg+xml
                                  upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Anteroom.93a742135f2c060ad619.svg static/media/Anteroom.93a742135f2c060ad619.svg image/svg+xml
                                  upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Amplifier.6f5d18048328386033f8.svg static/media/Amplifier.6f5d18048328386033f8.svg image/svg+xml
                                  upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Alarm Systems.857ab9a8f90827777b88.svg static/media/Alarm Systems.857ab9a8f90827777b88.svg image/svg+xml
                                  upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.2975a411.js.map static/js/main.2975a411.js.map application/json
                                  upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.2975a411.js.LICENSE.txt static/js/main.2975a411.js.LICENSE.txt text/plain
                                  upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.2975a411.js static/js/main.2975a411.js application/javascript
                                  upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                  upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                  upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
                                  upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
                                  upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
                                  upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                  upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
                                  upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
                                  upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
                                  upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                                  upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                  upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Power Consumption.4faab614c3c788f2d338.svg static/media/Power Consumption.4faab614c3c788f2d338.svg image/svg+xml
                                  upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Dishwashers.3709566b7214596236b7.svg static/media/Dishwashers.3709566b7214596236b7.svg image/svg+xml
                                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/573.a2bb6bc1.chunk.js.map static/js/573.a2bb6bc1.chunk.js.map application/json
                                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/365.56ad3a5d.chunk.js static/js/365.56ad3a5d.chunk.js application/javascript
                                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/223.baecc237.chunk.js.LICENSE.txt static/js/223.baecc237.chunk.js.LICENSE.txt text/plain
                                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/pin.png pin.png image/png
                                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
                                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
                                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_action.js google-blockly/own/blocks_action.js application/javascript
                                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/es.js google-blockly/msg/js/es.js application/javascript
                                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
                                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
                                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz null
                                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/back.jpg back.jpg image/jpeg
                                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                  host.ubuntu Setup "iobroker.javascript" adapter
                                  upload [13] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/words_material.js words_material.js application/javascript
                                  upload [12] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/words.js words.js application/javascript
                                  upload [11] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/style.css style.css text/css
                                  upload [10] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_small.png linkeddevices_small.png image/png
                                  upload [9] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_missing.png linkeddevices_missing.png image/png
                                  upload [8] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_info.png linkeddevices_info.png image/png
                                  upload [7] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices.png linkeddevices.png image/png
                                  upload [6] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/jsonCustom.json jsonCustom.json application/json
                                  upload [5] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.js index_m.js application/javascript
                                  upload [4] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.html index_m.html text/html
                                  upload [3] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/img/info-big.png img/info-big.png image/png
                                  upload [2] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom_m.html custom_m.html text/html
                                  upload [1] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom.js custom.js application/javascript
                                  upload [0] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [60] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.icons.min.css lib/css/grey/jquery.mobile.icons.min.css text/css
                                  upload [50] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pl/translations.json js/i18n/pl/translations.json application/json
                                  upload [40] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/windowOpened.png img/windowOpened.png image/png
                                  upload [30] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/rgb-red.png img/rgb-red.png image/png
                                  upload [20] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/bulbOff.pdn img/bulbOff.pdn null
                                  upload [19] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind90.png img/blind90.png image/png
                                  upload [18] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind80.png img/blind80.png image/png
                                  upload [17] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind70.png img/blind70.png image/png
                                  upload [16] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind60.png img/blind60.png image/png
                                  upload [15] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind50.png img/blind50.png image/png
                                  upload [14] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind40.png img/blind40.png image/png
                                  upload [13] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind30.png img/blind30.png image/png
                                  upload [12] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind20.png img/blind20.png image/png
                                  upload [11] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind100.png img/blind100.png image/png
                                  upload [10] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind10.png img/blind10.png image/png
                                  upload [9] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind0.png img/blind0.png image/png
                                  upload [8] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/battery.png img/battery.png image/png
                                  upload [7] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/alarmOn.png img/alarmOn.png image/png
                                  upload [6] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/alarmOff.png img/alarmOff.png image/png
                                  upload [5] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/mobile.css css/mobile.css text/css
                                  upload [4] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-Regular.ttf css/OpenSans-Regular.ttf font/ttf
                                  upload [3] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-LICENSE.txt css/OpenSans-LICENSE.txt text/plain
                                  upload [2] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-Italic.ttf css/OpenSans-Italic.ttf font/ttf
                                  upload [1] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-Bold.ttf css/OpenSans-Bold.ttf font/ttf
                                  upload [0] mobile /opt/iobroker/node_modules/iobroker.mobile/www/cache.manifest cache.manifest text/cache-manifest
                                  upload [1] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/mobile.png mobile.png image/png
                                  upload [0] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/index.html index.html text/html
                                  upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.json words.json application/json
                                  upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
                                  upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/vendors.json vendors.json application/json
                                  upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/tools.js tools.js application/javascript
                                  upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
                                  upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/node_ble_test.js node_ble_test.js application/javascript
                                  upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/network_test.js network_test.js application/javascript
                                  upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
                                  upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
                                  upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                  upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                                  upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                                  upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                  upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                  upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                  upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                                  upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                  upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                                  upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                                  upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                                  upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                                  upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                                  upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                  upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [60] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.4a6f1268.chunk.js.map rules/static/js/node_modules_prop-types_index_js.4a6f1268.chunk.js.map application/json
                                  upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pl.json rules/i18n/pl.json application/json
                                  upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                  upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es.json i18n/es.json application/json
                                  upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_prop-types_index_js.bf62a0c5.chunk.js custom/static/js/node_modules_prop-types_index_js.bf62a0c5.chunk.js application/javascript
                                  upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.ae65be75.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.ae65be75.chunk.js.map application/json
                                  upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.ae65be75.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.ae65be75.chunk.js application/javascript
                                  upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.49b95cc9.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.49b95cc9.chunk.js.map application/json
                                  upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.49b95cc9.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.49b95cc9.chunk.js application/javascript
                                  upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/main.bd70094f.js.map custom/static/js/main.bd70094f.js.map application/json
                                  upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/main.bd70094f.js custom/static/js/main.bd70094f.js application/javascript
                                  upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                  upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/uk.json custom/i18n/uk.json application/json
                                  upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                                  upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                  upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                                  upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                                  upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/it.json custom/i18n/it.json application/json
                                  upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                                  upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/es.json custom/i18n/es.json application/json
                                  upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/en.json custom/i18n/en.json application/json
                                  upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/de.json custom/i18n/de.json application/json
                                  upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                  upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/customComponents.js custom/customComponents.js application/javascript
                                  upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                  upload [100] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Speaker.db548379676317470c4f.svg static/media/Speaker.db548379676317470c4f.svg image/svg+xml
                                  upload [90] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
                                  upload [80] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Office.7e6a38218390b655e270.svg static/media/Office.7e6a38218390b655e270.svg image/svg+xml
                                  upload [70] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Light.21f1a5dfcc93f8ba1214.svg static/media/Light.21f1a5dfcc93f8ba1214.svg image/svg+xml
                                  upload [60] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Heater.b53bccc334bbb9238a36.svg static/media/Heater.b53bccc334bbb9238a36.svg image/svg+xml
                                  upload [50] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                                  upload [40] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Driveway.fbd31101c5a80a8bb37a.svg static/media/Driveway.fbd31101c5a80a8bb37a.svg image/svg+xml
                                  upload [30] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Consumption.fecd7a10a13fe4e5f69b.svg static/media/Consumption.fecd7a10a13fe4e5f69b.svg image/svg+xml
                                  upload [20] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Boiler Room.548e785e2f92b45f72b3.svg static/media/Boiler Room.548e785e2f92b45f72b3.svg image/svg+xml
                                  upload [19] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Bedroom.2a16d8d98fafe965fd1b.svg static/media/Bedroom.2a16d8d98fafe965fd1b.svg image/svg+xml
                                  upload [18] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Battery Status.5951e2078ae1e573510e.svg static/media/Battery Status.5951e2078ae1e573510e.svg image/svg+xml
                                  upload [17] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Bathroom.27a777c66183f9f613db.svg static/media/Bathroom.27a777c66183f9f613db.svg image/svg+xml
                                  upload [16] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Basement.fe636968eec9556bfd1f.svg static/media/Basement.fe636968eec9556bfd1f.svg image/svg+xml
                                  upload [15] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Barn.5d839e84c80918ce2ef0.svg static/media/Barn.5d839e84c80918ce2ef0.svg image/svg+xml
                                  upload [14] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Balcony.2f76ef0877aaa3bd2ff7.svg static/media/Balcony.2f76ef0877aaa3bd2ff7.svg image/svg+xml
                                  upload [13] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Awnings.78480df8796f09859b6a.svg static/media/Awnings.78480df8796f09859b6a.svg image/svg+xml
                                  upload [12] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Attic.bb5d690a160bb1d4edb2.svg static/media/Attic.bb5d690a160bb1d4edb2.svg image/svg+xml
                                  upload [11] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Anteroom.93a742135f2c060ad619.svg static/media/Anteroom.93a742135f2c060ad619.svg image/svg+xml
                                  upload [10] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Amplifier.6f5d18048328386033f8.svg static/media/Amplifier.6f5d18048328386033f8.svg image/svg+xml
                                  upload [9] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/media/Alarm Systems.857ab9a8f90827777b88.svg static/media/Alarm Systems.857ab9a8f90827777b88.svg image/svg+xml
                                  upload [8] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/js/main.274a4d8d.js.map static/js/main.274a4d8d.js.map application/json
                                  upload [7] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/js/main.274a4d8d.js.LICENSE.txt static/js/main.274a4d8d.js.LICENSE.txt text/plain
                                  upload [6] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/js/main.274a4d8d.js static/js/main.274a4d8d.js application/javascript
                                  upload [5] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/css/main.9a2887fc.css.map static/css/main.9a2887fc.css.map application/json
                                  upload [4] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/static/css/main.9a2887fc.css static/css/main.9a2887fc.css text/css
                                  upload [3] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/manifest.json manifest.json application/json
                                  upload [2] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/langModel.js langModel.js application/javascript
                                  upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                  upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/asset-manifest.json asset-manifest.json application/json
                                  upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                  upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                  upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                  upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/511-3.png widgets/timeandweather/img/clock/511-3.png image/png
                                  upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/001-3.png widgets/timeandweather/img/clock/001-3.png image/png
                                  upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/light_light_dim_20.png widgets/metro/img/light_light_dim_20.png image/png
                                  upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_100.svg widgets/jqui-mfd/img/sani_valve_100.svg image/svg+xml
                                  upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_1w.png widgets/jqui-mfd/img/fts_window_1w.png image/png
                                  upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerIconDialog.png widgets/jqui/img/Prev_ContainerIconDialog.png image/png
                                  upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/colorpicker/img/mask.png widgets/colorpicker/img/mask.png image/png
                                  upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_TableBody.png widgets/basic/img/Prev_TableBody.png image/png
                                  upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js lib/js/jquery-ui-timepicker-addon-1.6.3.js application/javascript
                                  upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditExt.js js/visEditExt.js application/javascript
                                  upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/back.png js/fm/icon/actions/back.png image/png
                                  upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/img/zip.png img/zip.png image/png
                                  upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                                  upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                                  upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                                  upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                                  upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                                  upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                                  upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                                  upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                                  upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                                  upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                                  upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                                  upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                                  upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                                  upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                                  upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                                  upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                                  upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                                  upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                                  upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                                  upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                                  upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                                  upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                                  upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                                  upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                                  upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                                  upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                                  upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                  upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                  upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                  upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                  upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-colorpicker/www" was not found! Nothing was uploaded or deleted.
                                  upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                  upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                  upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                                  upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                                  upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                                  upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                                  upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                                  upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                                  upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png image/png
                                  upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png image/png
                                  upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png image/png
                                  upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png image/png
                                  upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png image/png
                                  upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png image/png
                                  upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png image/png
                                  upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css text/css
                                  upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png image/png
                                  upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png image/png
                                  upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/jquery-ui.css lib/css/themes/jquery-ui/blitzer/jquery-ui.css text/css
                                  upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png image/png
                                  upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png image/png
                                  upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                                  upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                                  upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                                  upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                                  upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                                  upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                                  upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                                  upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                  upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                                  upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                                  upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                                  upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.pdn lib/css/fancytree/state.pdn null
                                  upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                                  upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                                  upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                                  upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.pdn lib/css/fancytree/device.pdn null
                                  upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                                  upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.pdn lib/css/fancytree/channel.pdn null
                                  upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                  upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                                  upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                  upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Speaker.db548379676317470c4f.svg static/media/Speaker.db548379676317470c4f.svg image/svg+xml
                                  upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
                                  upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Office.7e6a38218390b655e270.svg static/media/Office.7e6a38218390b655e270.svg image/svg+xml
                                  upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Light.21f1a5dfcc93f8ba1214.svg static/media/Light.21f1a5dfcc93f8ba1214.svg image/svg+xml
                                  upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Heater.b53bccc334bbb9238a36.svg static/media/Heater.b53bccc334bbb9238a36.svg image/svg+xml
                                  upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                                  upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Driveway.fbd31101c5a80a8bb37a.svg static/media/Driveway.fbd31101c5a80a8bb37a.svg image/svg+xml
                                  upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Consumption.fecd7a10a13fe4e5f69b.svg static/media/Consumption.fecd7a10a13fe4e5f69b.svg image/svg+xml
                                  upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Boiler Room.548e785e2f92b45f72b3.svg static/media/Boiler Room.548e785e2f92b45f72b3.svg image/svg+xml
                                  upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Bedroom.2a16d8d98fafe965fd1b.svg static/media/Bedroom.2a16d8d98fafe965fd1b.svg image/svg+xml
                                  upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Battery Status.5951e2078ae1e573510e.svg static/media/Battery Status.5951e2078ae1e573510e.svg image/svg+xml
                                  upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Bathroom.27a777c66183f9f613db.svg static/media/Bathroom.27a777c66183f9f613db.svg image/svg+xml
                                  upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Basement.fe636968eec9556bfd1f.svg static/media/Basement.fe636968eec9556bfd1f.svg image/svg+xml
                                  upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Barn.5d839e84c80918ce2ef0.svg static/media/Barn.5d839e84c80918ce2ef0.svg image/svg+xml
                                  upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Balcony.2f76ef0877aaa3bd2ff7.svg static/media/Balcony.2f76ef0877aaa3bd2ff7.svg image/svg+xml
                                  upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Awnings.78480df8796f09859b6a.svg static/media/Awnings.78480df8796f09859b6a.svg image/svg+xml
                                  upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Attic.bb5d690a160bb1d4edb2.svg static/media/Attic.bb5d690a160bb1d4edb2.svg image/svg+xml
                                  upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Anteroom.93a742135f2c060ad619.svg static/media/Anteroom.93a742135f2c060ad619.svg image/svg+xml
                                  upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Amplifier.6f5d18048328386033f8.svg static/media/Amplifier.6f5d18048328386033f8.svg image/svg+xml
                                  upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Alarm Systems.857ab9a8f90827777b88.svg static/media/Alarm Systems.857ab9a8f90827777b88.svg image/svg+xml
                                  upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.edf7552a.js.map static/js/main.edf7552a.js.map application/json
                                  upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.edf7552a.js.LICENSE.txt static/js/main.edf7552a.js.LICENSE.txt text/plain
                                  upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.edf7552a.js static/js/main.edf7552a.js application/javascript
                                  upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                  upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                  upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                  upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                  upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                  upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                  upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
                                  upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                                  upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                                  upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                                  upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                                  upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                                  upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                                  upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                                  upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                                  upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                                  upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                                  upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                                  upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                                  upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
                                  upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
                                  upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
                                  upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
                                  upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
                                  upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
                                  upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                                  System successfully restored!
                                  ubuntu@ubuntu:/opt/iobroker/backups$
                                  Aber iobrocker ist wieder KO
                                    Thomas Braun Most Active @Esmax666 last edited by
                                    @esmax666
                                    Ich kann dir da nicht helfen.
                                    • Marc Berg
                                      Marc Berg Most Active last edited by
                                      @esmax666 sagte in iobroker geht nicht nach stromausfall:
                                      Das sieht doch nicht sooo schlecht aus.
                                      Was sagt denn jetzt
                                      iob status
                                      iob list instances
                                        Esmax666 @Marc Berg last edited by Esmax666
                                        @marc-berg
                                        @marc-berg
                                        ubuntu@ubuntu:/opt/iobroker$ iob status
                                         Cannot read system.config: null (OK when migrating or restoring)
                                        iobroker is not running on this host.
                                        Objects type: file
                                        States  type: file
                                        ubuntu@ubuntu:/opt/iobroker$ iob list instances
                                         Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        + instance is alive
                                        Skript v.2023-06-20
                                        *** BASE SYSTEM ***
                                           Static hostname: ubuntu
                                                 Icon name: computer
                                                Machine ID: 551875df55414c0f832b43a896fe8ce5
                                                   Boot ID: a58fe4cd23274d7e86463c9c059dca8f
                                          Operating System: Ubuntu 21.04
                                                    Kernel: Linux 5.11.0-1027-raspi
                                              Architecture: arm
                                        Model           : Raspberry Pi 4 Model B Rev 1.4
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : armv7l
                                        Userland        : armhf
                                        Systemuptime and Load:
                                         19:58:17 up 1 day,  8:07,  1 user,  load average: 0.81, 0.86, 0.79
                                        CPU threads: 4
                                        *** Time and Time Zones ***
                                                       Local time: Wed 2023-09-20 19:58:17 CEST
                                                   Universal time: Wed 2023-09-20 17:58:17 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        ubuntu
                                        /home/ubuntu
                                        ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:           7.9G        211M        5.3G        3.0M        2.4G        7.6G
                                        Swap:            0B          0B          0B
                                        Total:         7.9G        211M        5.3G
                                                 7886 M total memory
                                                  211 M used memory
                                                  866 M active memory
                                                 1406 M inactive memory
                                                 5304 M free memory
                                                  312 M buffer memory
                                                 2058 M swap cache
                                                    0 M total swap
                                                    0 M used swap
                                                    0 M free swap
                                        *** FILESYSTEM ***
                                        Filesystem     Type   Size  Used Avail Use% Mounted on
                                        tmpfs          tmpfs  789M  4.0M  785M   1% /run
                                        /dev/sda2      ext4    57G  7.6G   47G  14% /
                                        tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
                                        tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
                                        /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
                                        tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
                                        [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
                                        [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
                                        Show mounted filesystems (real ones only):
                                        TARGET              SOURCE     FSTYPE   OPTIONS
                                        /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
                                        |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
                                        |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
                                        |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
                                        |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
                                        |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
                                        |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
                                        |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
                                        |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
                                        |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
                                        |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
                                        `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        3.3G    /var/
                                        2.0G    /var/log
                                        1.8G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
                                        1.2G    /var/lib
                                        Archived and active journals take up 1.7G in the file system.
                                        /opt/iobroker/backups:
                                        50M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        355M    /opt/iobroker/iobroker-data/
                                        193M    /opt/iobroker/iobroker-data/files
                                        151M    /opt/iobroker/iobroker-data/backup-objects
                                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                                        11M     /opt/iobroker/iobroker-data/objects.jsonl
                                        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v18.18.0
                                        /usr/bin/node           v18.18.0
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                                        nodejs:
                                          Installed: 18.18.0-1nodesource1
                                          Candidate: 18.18.0-1nodesource1
                                          Version table:
                                         *** 18.18.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                                100 /var/lib/dpkg/status
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                             12.21.0~dfsg-3ubuntu1 500
                                                500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: file
                                        States  type: file
                                        No configuration change needed.
                                        Multihost discovery server: disabled
                                        Discovery authentication:   enabled
                                        Persistent activation:      disabled
                                        Objects:                    file on 127.0.0.1
                                        States:                     file on 127.0.0.1
                                        Core adapters versions
                                        js-controller:  3.3.22
                                        admin:          6.10.1
                                        javascript:     7.1.4
                                        Adapters from github:   0
                                        Adapter State
                                        + instance is alive
                                        ioBroker-Repositories
                                        Cannot get list: undefined
                                        Installed ioBroker-Instances
                                        Error: Object "system.config" not found
                                        ^C
                                        ubuntu@ubuntu:/opt/iobroker$ ^C
                                        • Marc Berg
                                          @esmax666
                                          Wenn ich den Thread richtig verfolgt habe, hast du ja - von einem defekten System kommend - erst ein Upgrade und danach ein Downgrade bis iobroker.js-controller@3.3.22 gemacht und dann das Restore durchgeführt. Vielleicht bringt es ja etwas, mit einem frischen, neuen System zu starten, dann das Downgrade und Restore.
                                          Ist aber nur ins Blaue geraten.
                                            @marc-berg
                                            oh dann sieht es schon schecht aus 😞
                                            gibt es irgenwo ein ubuntu bild?
                                            10458
