    4. DMP8624 -> iobroker
    DMP8624 -> iobroker
    • Wal
      Wal Developer @Ralla66 last edited by
      @ralla66 ,
      da musst du dich mal durcharbeiten, habe damit noch nichts gemacht. 😉
      Ralla66 1 Reply Last reply Reply Quote 0
      • Ralla66
        Ralla66 Most Active @Wal last edited by Ralla66
        @wal
        ok, dann mal ran an Lehrbrief 1 -> Übung 1 🙂
        Button Websend einfügen, Websend ausführen, Antwort Request in Var schreiben.
        1 und 2 sollte gehen, bei 3 haperts noch 😉
        >D
        ; Ralla
        gw=""
        Vmax=60
        Cmax=24
        v=0
        V=0
        c=0
        C=0
        sw=0
        SW=0
        ; Ralla
        WS=0
        rV="01060000"
        vV=""
        rC="01060001"
        vC=""
        rSW="01060002000"
        vSW=""
        >BS
        +>subscribe V, cmnd/%topic%/tvolt
        +>subscribe C, cmnd/%topic%/tampere
        +>subscribe SW, cmnd/%topic%/tpow
        >B
        smlj=0
        ->sensor53 r
        ; Ralla
        ; Request Status information. The response will trigger the `U` section
        +>status 5
        >R
        smlj=0
        >S
        if upsecs>30
        then
        smlj=1
        endif
        >W
        bu(SW "DPM Ein" "DPM Aus")
        ; Ralla
        bu(WS "WebSend" "Websend")
        nm(0.0 60.0 0.01 V "DPM Ausgang (V)" 200 2)
        nm(0.0 24.0 0.01 C "DPM Ausgang (A)" 200 2)
        >T
        sw=DC#sSwitch
        v=DC#sVolt
        c=DC#sCur
        if ((chg[sw]>0) and (SW!=sw))
        then
          SW=sw
          +>publish stat/%topic%/RESULT {"tpow":%0sw%}
        endif
        if ((chg[v]>0) and (V!=v))
        then
          V=v
          +>publish stat/%topic%/RESULT {"tvolt":%2v%}
        endif
        if ((chg[c]>0) and (C!=c))
        then
          C=c
          +>publish stat/%topic%/RESULT {"tampere":%2c%}
        endif
        if chg[V]>0
        then
          if V>Vmax
          then
            V=Vmax
          endif
          if V<0
          then
            V=0
          endif
          vV=rV+sb(hx((V*100)) 4 4)
          +>publish stat/%topic%/RESULT {"tvolt":%2V%}
          sml(1 3 vV)
        endif
        if chg[C]>0
        then
          if C>Cmax
          then
            C=Cmax
          endif
          if C<0
          then
            C=0
          endif
          vC=rC+sb(hx((C*1000)) 4 4)
          +>publish stat/%topic%/RESULT {"tampere":%2C%}
          sml(1 3 vC)
        endif
        if ((chg[SW]>0)
        then
          vSW=rSW+s(SW)
          +>publish stat/%topic%/RESULT {"tpow":%0SW%}
          sml(1 3 vSW)
        endif
        ; Ralla
        if ((chg[WS]>0)
        then
        =>WebSend [192.168.2.28] /cm?cmnd=status&2010
        ;Org Ralla IO http://192.168.2.28/cm?cmnd=status%2010
        print Ralla websend
        endif
        ; Ralla
        ; Read the status JSON payload
        >U
        gw=StatusNET#Gateway
        ;gw=StatusSNS,MT175,Bezug_aktuell
        print %gw%
        print Ralla gw
        >M 1
        +1,3,m,16,9600,DC,1,2,010300000001,010300010001,010300020001,010310010001,010310020001
        1,010302SSssxxxx@i0:100,Spannung (set),V,sVolt,2
        1,010302SSssxxxx@i1:1000,Strom (set),A,sCur,2
        1,010302SSssxxxx@i2:1,Ausgang (set),,sSwitch,0
        1,010302SSssxxxx@i3:100,Spannung (disp),V,dVolt,2
        1,010302SSssxxxx@i4:1000,Strom (disp),A,vCur,2
        ; Request Status information. The response will trigger the U section
        B
        +>status 5
        Dann sollte ja U print ausgeführt sein, ist aber nicht, dann kann nur WebSend falsch sein
        Wal 2 Replies Last reply Reply Quote 0
        • Wal
          @ralla66 ,
          denk daran das man eine Firmware mit USE_WEBSEND_RESPONSE braucht.
          • Wal
            Wal Developer @Ralla66 last edited by Wal
            @ralla66 ,
            hier für dich falls du es noch nicht kennst.
            edit: Werde ich heute testen ob ich den aktuellen Verbrauch vom hichi holen kann wenn du nicht dazu kommst.
            • Ralla66
              @wal
              heute morgen war um 0:30 Feierabend 🙂
              den Link lese ich heute Abend,
              habe boot error am ESP nach dem flashen / script einfügen, war eventuell schon übermüdet
              meine .bin mit USE_WEBSEND_RESPONSE aktiviert lief nicht sauber.
              kannst du mal bitte die .bin hochladen mit Zeile 471 USE_WEBSEND_RESPONSE aktiviert
              Wäre cool wenn du mit testes, macht das debuggen einfacher.
              • Wal
                @ralla66 ,
                firmware_websend.bin.gz
                Ralla66 2 Replies Last reply Reply Quote 0
                • Ralla66
                  @wal
                  Danke, jetzt weiter
                  • Ralla66
                    @wal
                    erste Antwort, bekomme ein WEbQuery zurück
                    17:35:28.308 SCR: performs "WebSend [192.168.2.28] /cm?cmnd=status&2010"
                    17:35:29.951 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"Status":{"Module":18,"DeviceName":"SMA","FriendlyName":["SMA"],"Topic":"tasmota_D35C9C","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}}
                    17:35:29.955 MQT: stat/tasmota_3CECBB/RESULT = {"WebSend":"Done"}
                    17:35:29.957 Ralla websend
                    >D
                    ; Ralla
                    gw=""
                    Vmax=60
                    Cmax=24
                    v=0
                    V=0
                    c=0
                    C=0
                    sw=0
                    SW=0
                    ; Ralla
                    WS=0
                    rV="01060000"
                    vV=""
                    rC="01060001"
                    vC=""
                    rSW="01060002000"
                    vSW=""
                    >BS
                    >B
                    smlj=0
                    ->sensor53 r
                    ; Ralla
                    +>status 5
                    >R
                    smlj=0
                    >S
                    if upsecs>30
                    then
                    smlj=1
                    endif
                    >W
                    ; Ralla
                    >T
                    sw=DC#sSwitch
                    v=DC#sVolt
                    c=DC#sCur
                    then
                      SW=sw
                    endif
                    then
                      V=v
                    endif
                    then
                      C=c
                    endif
                    if chg[V]>0
                    then
                      if V>Vmax
                      then
                        V=Vmax
                      endif
                      if V<0
                      then
                        V=0
                      endif
                      sml(1 3 vV)
                    endif
                    if chg[C]>0
                    then
                      if C>Cmax
                      then
                        C=Cmax
                      endif
                      if C<0
                      then
                        C=0
                      endif
                      sml(1 3 vC)
                    endif
                    if ((chg[SW]>0)
                    then
                      vSW=rSW+s(SW)
                      sml(1 3 vSW)
                    endif
                    ; Ralla
                    if ((chg[WS]>0)
                    then
                    res=WebSend [192.168.2.28] /cm?cmnd=status&2010
                    print Ralla websend
                    endif
                    ; Ralla
                    >U
                    print %gw%
                    print Ralla gw
                    >M 1
                    • Wal
                      @ralla66 ,
                      • Wal
                        @ralla66 ,
                        Hichi:
                        >D
                        aktuell=0
                        >B
                        ->sensor53 r
                        >T
                        aktuell=MT175#P
                        http("192.168.xxx.xxx" "/cm?cmnd=script>Aktuell="+s(aktuell))
                        >M 1
                        +1,3,s,16,9600,MT175
                        1,77070100010800ff@1000,E_in,kWh,E_in,1
                        1,77070100010801ff@1000,E_in_HT,kWh,E_in_HT,1
                        1,77070100010802ff@1000,E_in_NT,kWh,E_in_NT,1
                        1,77070100020800ff@1000,E_out,kWh,E_out,1
                        1,77070100100700ff@1,P,W,P,18
                        1,77070100000009ff@#,Server_ID,,Server_ID,0
                        DPM8624:
                        >D
                        Aktuell=0
                        >W
                        Aktuelle Leistung{m} %0Aktuell% W
                        • Ralla66
                          @wal
                          Habe die Data, %20 weglassen
                          18:10:08.057 SCR: performs "WebSend [192.168.2.28] /cm?cmnd=status 10"
                          18:10:08.622 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"StatusSNS":{"Time":"2023-09-20T18:10:08","MT175":{"Geräte_ID":"","Verbrauch_Gesamt":37714,"Bezug_Tarif_1":37714.412,"Bezug_Tarif_2":0,"Netzeinspeisung":0,"Lieferung_Tarif_1":0,"Lieferung_Tarif_2":0,"Bezug_aktuell":9,"Phase_L1":17,"Phase_L2":-71,"Phase_L3":62}}}}
                          18:10:08.626 MQT: stat/tasmota_3CECBB/RESULT = {"WebSend":"Done"}
                          18:10:08.628 Ralla websend
                          ; Ralla
                          if ((chg[WS]>0)
                          then
                          ;10 = show connected sensor information (replaces 'Status 8')
                          =>WebSend [192.168.2.28] /cm?cmnd=status 10
                          print Ralla websend
                          endif
                          Yeep 🙂
                          jetzt noch zerlegen, Ideen ? mit U ?
                          Teste mal mit Hichi ob Daten kommen
                          • Wal
                            @ralla66 ,
                            Ätsch war trotzdem erster. 😉
                            • Ralla66
                              @wal
                              ok hast gewonnen 🙂
                              wie machen wir weiter ?
                              Ein DPM Script für alle IR Leseköpfe bauen, also den Status SNS komplett abholen.
                              Dann den Bezugswert Filtern. Habe ja kein Hichi. Dieser Wert kann ja anders benannt sein,
                              Dann Script cleanen und die erste Beta 1.0 bauen.
                              Weiter dann mit der Berechnung Bezug -> DPM setzt V und A ?
                              Gruß Ralla
                              Nachtrag, Leseköpfe ( Status SNS ) Json einlesen, dann würden auch Shelly PM gehen.
                              • Wal
                                @ralla66 ,
                                ja schau mal ob du den Wert rausfiltern kannst.
                                Mit http("192.168.xxx.xxx" "/cm?cmnd=script>Variablename=Wert) kannst du jeder Variable im Script einen Wert verpassen.
                                Mit Variable=http("192.168.xxx.xxx" "/cm?cmnd=script?Variablename) kannst du jeden Wert anfordern.
                                • Ralla66
                                  @wal
                                  Ok ich teste mal mit Bezug Aktuell,
                                  dann brauche ich noch ein Ausgabefenster in der WEB UI mit Wert Bezug Aktuell
                                  Bzw 2, Bezug Zähler und DPM Ausgang Watt
                                  Du kannst das schneller 🙂
                                  Ziel ist ja erreicht, Feierabend ist heute früher.
                                  Lehrbrief 1, Übung 1 mit Sehr Gut bestanden 😉
                                  • Ralla66
                                    @wal
                                    so ?
                                    >D
                                    ; Ralla
                                    Bezug Aktuell=0
                                    >T ; alle 10 sec Telemetrieperiode eingestellt
                                    ; Ralla
                                    ; jeder Variable im Script einen Wert zuweisen
                                    http("192.168.2.28" "/cm?cmnd=script>Bezug Aktuell=Wert)
                                    print Bezug Aktuell %Bezug Aktuell%
                                    • Wal
                                      @ralla66 ,
                                      http("192.168.2.28" "/cm?cmnd=script>Bezug Aktuell=Wert")
                                      mit dem Befehl sendest du den Wert an 192.168.2.28.
                                      Im 192.168.2.28 muss es eine Variable Bezug Aktuell geben.
                                      • Ralla66
                                        @wal
                                        ah ja, so ne Art send to
                                        dann ist ja das hier vom Zähler ESP holen, jezz is klar 🙂
                                        Ne doch nich, der Pfad im Zähler ESP ist doch StatusSNS->MT175.>Bezug Aktuell->Wert.
                                        Ich brauche ne Pause ------------------------->
                                        19:43:19.058 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"StatusSNS":{"Time":"2023-09-20T19:43:16","MT175":{"Geräte_ID":"","Verbrauch_Gesamt":37715,"Bezug_Tarif_1":37714.529,"Bezug_Tarif_2":0,"Netzeinspeisung":0,"Lieferung_Tarif_1":0,"Lieferung_Tarif_2":0,"Bezug_aktuell":93,"Phase_L1":16,"Phase_L2":6,"Phase_L3":70}}}}
                                        >D
                                        ; Ralla
                                        Bezug Aktuell=0
                                        ;Mit Variable=http("192.168.xxx.xxx" "/cm?cmnd=script?Variablename) kannst du ;jeden Wert anfordern
                                        Bezug Aktuell=http("192.168.2.28" "/cm?cmnd=script?Bezug_Aktuell)
                                        • Wal
                                          @ralla66 ,
                                          da musst du machen
                                          T
                                          aktuell= MT175#Bezug Aktuell
                                          Dann kannst du aktuell senden oder anfordern.
                                          Schaue in meiner Lösung von der vorherigen Seite.
                                          • Ralla66
                                            @wal
                                            ok, Danke, heute nicht mehr.
                                            Sackt langsam, das ist im Zähler ESP.
                                            Das war bei mir nicht geplant, immer schwierig für Beginner wenn auf der Tasmota Seite
                                            das SML angepasst werden muß. Einfacher wäre es nur in der DPM Script Var Deklaration
                                            ein Paar Werte einzugeben. Das ist ja für mich schon sehr schwer.
                                            37085
