    4. js-controller 5.0.x jetzt für alle User im STABLE!
      ronny130286 @Thomas Braun last edited by ronny130286
      @thomas-braun sorry meinte: Es läuft auch ohne Fehlermeldung durch....
      hier mal die Putty Ausgabe:
      pi@iobroker:~ $ iob stop
      pi@iobroker:~ $ iob update
      Used repository: stable
      Adapter    "accuweather"  : 1.3.1    , installed 1.2.4  [Updatable]
      Adapter    "admin"        : 6.10.1   , installed 6.8.0  [Updatable]
      Adapter    "alexa2"       : 3.25.2   , installed 3.24.1 [Updatable]
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "growatt"      : 3.1.2    , installed 3.1.2
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.1.4    , installed 7.0.3  [Updatable]
      Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
      Adapter    "nibeuplink"   : 1.3.0    , installed 1.3.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "roomba"       : 1.1.4    , installed 1.1.4
      Adapter    "s7"           : 1.3.15   , installed 1.3.15
      Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.4  [Updatable]
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      pi@iobroker:~ $ iob fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
      Holen:3 https://deb.nodesource.com/node_18.x buster InRelease [4.584 B]
      Holen:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,        0 MB]
      Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB        ]
      Es wurden 13,5 MB in 8 s geholt (1.698 kB/s).
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@iobroker:~ $ iob upgrade self
      Update js-controller from @4.0.24 to @5.0.12
      Stopped Objects DB
      Stopped States DB
      NPM version: 9.6.7
      Installing iobroker.js-controller@5.0.12... (System call)
      pi@iobroker:~ $ iob start
      pi@iobroker:~ $ node -v && nodejs -v && npm -v
      v18.17.1
      v18.17.1
      9.6.7
      • mcm1957
        mcm1957 @Letzi last edited by
        @letzi said in js-controller 5.0.x jetzt für alle User im STABLE!:
        Guten Abend.
        Nach dem Update funktioniert der gsmsms Adapter nicht mehr.
        v0.0.4
        Verbunden mit Host -> bleibt rot
        Lebenszeichen -> bleibt rot
        Verbunden mit Gerät oder Dienst -> bleibt rot
        Ist jemanden bekannt, ob es dazu erst ein update des Adapter geben muss?
        Danke.
        Bitte zeig mal ob bzw. was in den logs dazu steht.
        Eine neuere Version als 0.0.4 ist derzeit nicht verfügbar. Offenes Issue seh ich auch nicht.
        @forelleblau ist dir was bekannt bzw. kannst (wenn der log da ist) was dazu sagen?
          Wildbill @foxriver76 last edited by
          @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
          @wildbill hm du sagst er bleibt rot? Weil schaut aus als läuft er laut log.
          Bevor ich oben editiere schreibe ich es nochmal, weil ich grad einen ähnlichen Fall hatte. Ich habe meistens zwei Browser-Tabs offen, wenn ich in iobroker was mache. Bisher war es so, dass die Zustände über die Tabs hinweg eigentlich gleich waren. Wenn ich beispielsweise, warum auch immer, zwei Instanzen-Tabs aufhabe und in einer eine Instanz startete, war sie auch im anderen grün. Seit einem der letzten Updates (js-controller, admin, javascript…) scheint es nun nicht mehr so zu sein. Ich muss im zweiten Tab dann einmal die Seite aktualisieren, damit die Anzeige wieder passt. Heute morgen war es wohl auch irgendwie so, weil ich wohl vom Adapter aus die Instanzen geöffnet habe, die Instanz gestartet und dann gleich auf Log bin. Der zweite Tab mit den Instanzen war dann wohl noch rot, obwohl ja bereits alles lief.
          Ist da was bekannt, dass sich das Synchronisieren von parallel geöffneten Tabs geändert hat? Zumindest beim Umschalten auf Experte hat man ja nun die Möglichkeit auszuwählen, ob das über mehrere Browser-Tabs hinweg gelten soll.
          Gruss, Jürgen
            cfau last edited by
            hab jetzt auch mal auf den neuen js-controller 5.x upgedated. Leider läuft danach (als einziger) mein wichtigster Adapter KNX nicht mehr. Ein Neugenerieren bringt leider nur die Fehlermeldung im iobroker-Protokoll:
            host.IOBroker
            	2023-09-20 20:36:41.140	info	system.adapter.knx.0 will be rebuilt
            host.IOBroker
            	2023-09-20 20:36:41.139	info	Adapter system.adapter.knx.0 needs rebuild and will be restarted afterwards.
            host.IOBroker
            	2023-09-20 20:36:41.139	error	instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.IOBroker
            	2023-09-20 20:36:41.139	error	Caught by controller[0]: Node.js v18.17.1
            host.IOBroker
            	2023-09-20 20:36:41.139	error	Caught by controller[0]: }
            host.IOBroker
            	2023-09-20 20:36:41.139	error	Caught by controller[0]: ]
            host.IOBroker
            	2023-09-20 20:36:41.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.knx/knx.js'
            host.IOBroker
            	2023-09-20 20:36:41.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.knx/lib/utils.js',
            host.IOBroker
            	2023-09-20 20:36:41.138	error	Caught by controller[0]: requireStack: [
            host.IOBroker
            	2023-09-20 20:36:41.138	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.IOBroker
            	2023-09-20 20:36:41.138	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
            host.IOBroker
            	2023-09-20 20:36:41.138	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
            host.IOBroker
            	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
            host.IOBroker
            	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
            host.IOBroker
            	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
            host.IOBroker
            	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/lib/utils.js:67:25)
            host.IOBroker
            	2023-09-20 20:36:41.137	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
            host.IOBroker
            	2023-09-20 20:36:41.137	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
            host.IOBroker
            	2023-09-20 20:36:41.136	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
            host.IOBroker
            	2023-09-20 20:36:41.136	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
            host.IOBroker
            	2023-09-20 20:36:41.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.knx/knx.js
            host.IOBroker
            	2023-09-20 20:36:41.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.knx/lib/utils.js
            host.IOBroker
            	2023-09-20 20:36:41.135	error	Caught by controller[0]: Require stack:
            host.IOBroker
            	2023-09-20 20:36:41.135	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
            host.IOBroker
            	2023-09-20 20:36:41.135	error	Caught by controller[0]: ^
            host.IOBroker
            	2023-09-20 20:36:41.134	error	Caught by controller[0]: throw err;
            host.IOBroker
            	2023-09-20 20:36:41.134	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
            host.IOBroker
            	2023-09-20 20:36:39.134	info	instance system.adapter.knx.0 started with pid 12950
            host.IOBroker
            	2023-09-20 20:36:38.986	info	iobroker npm-rebuild: exit 0
            host.IOBroker
            	2023-09-20 20:36:37.973	info	iobroker npm-rebuild: Rebuilding native modules done
            host.IOBroker
            	2023-09-20 20:36:37.972	info	iobroker npm-rebuild:
            host.IOBroker
            	2023-09-20 20:36:37.923	info	iobroker npm-rebuild: rebuilt dependencies successfully
            host.IOBroker
            	2023-09-20 20:36:17.397	info	iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@5.0.12" in /opt/iobroker/node_modules ...
            host.IOBroker
            	2023-09-20 20:36:15.794	info	iobroker rebuild iobroker.js-controller@5.0.12 --path /opt/iobroker/node_modules
            host.IOBroker
            	2023-09-20 20:36:15.793	warn	adapter "knx" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
            Kann mir da jemand vielleicht weiterhelfen?
            Grüße Christian
            Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @cfau last edited by
              @cfau sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
              Läuft doch noch. Abwarten.
              • foxriver76
                foxriver76 Developer @cfau last edited by
                @cfau welche Version vom KNX ist das denn, das scheint nicht aktuelle stable zu sein
                  cfau @Thomas Braun last edited by
                  Das ging aber schnell - auch die folgenden Versuche schlugen fehl - hatte nur den zweiten Teil rauskopiert.
                    cfau @foxriver76 last edited by
                    @foxriver76 2.0.17 sollte eigentlich der letzte aus dem Stable sein, oder?
                    • foxriver76
                      @cfau 2.0.22
                        cfau @cfau last edited by
                        @cfau
                        Bin jetzt erst mal wieder mithilfe deiner Anleitungen und Scripts auf den alten controller 4.0.24, damit alles wieder funktioniert.
                        Was mir allerdings aufgefallen ist: ich bekomm beim download von json-Dateien von download.iobroker.net immer timeouts nach 10sec. Ist der aktuell nicht erreichbar? Oder spinnt hier nur mein Netz?
                        VG
                        Christian
                        mcm1957 Peoples 2 Replies Last reply Reply Quote 0
                        • ofri2607
                          ofri2607 @foxriver76 last edited by
                          @foxriver76
                          @Wildbill
                          Ich habe auch den Sonos-Adapter am Laufen und nach Lesen der Einträge hier diesen von Github auf v2.3.2 installiert (zuvor war v2.3.1) um vor dem Update vom js-controller nicht in das Backitup-Thema zu Laufen.
                          Aktuell mit node.js v18.17.1, npm 9.6.7, admin v6.10.1, js-controller 4.0.24 auf einem raspi 4 mit bullseye.
                          Update des Adapters war problemlos, nur habe ich jetzt im Datenpunkt „current_cover“ folgenden Eintrag: /files/sonos//opt/iobroker/iobroker-data/sonosCache/f6d5a1c06d8a5c1f0a908f1bdec205c4
                          Ich habe dzt. drei Lautsprecher (1x Sonos und 2x Symfonisk) eingetragen und im Datenpunkt „current_cover“ steht bei allen drei der exakt gleiche, o.a. Eintrag.
                          Irgendwie denke ich, kann das nicht passen, bzw. bekomme ich das jetzt in der vis nicht mehr angezeigt (mit der v2.3.1 des Adapters war es über ein „basic - String img src“-Widget dargestellt).
                          Habe auch mal testweise den Sonos-Lautsprecher aus der Liste gelöscht und dann wieder eingefügt. Der Eintrag im Datenpunkt „current_cover“ war wieder der Gleiche.
                          • foxriver76
                            foxriver76 Developer @ofri2607 last edited by
                            @ofri2607 mach mal bitte ein issue beim sonos adapter, da habe ich wohl was übersehen 😉
                            ofri2607 1 Reply Last reply Reply Quote 0
                            • mcm1957
                              mcm1957 @cfau last edited by
                              @cfau said in js-controller 5.0.x jetzt für alle User im STABLE!:
                              @cfau
                              VG
                              Christian
                              Ev ist das noch aktuell:
                              https://forum.iobroker.net/topic/68397/falsche-ipv6-dns-auflösung-iobroker-net
                              • ofri2607
                                @foxriver76
                                erledigt - https://github.com/ioBroker/ioBroker.sonos/issues/203
                                ofri2607 created this issue in ioBroker/ioBroker.sonos
                                closed v2.3.2 - Eintrag in Datenpunkt „current_cover“ #203
                                • foxriver76
                                  @ofri2607 danke, schaue es mir morgen früh an. Kurze Frage, wie hast du bislang diesen Datenpunkt verwendet?
                                  • ofri2607
                                    @foxriver76
                                    herzlichen Dank 🙂
                                    Als Cover-Anzeige in der vis mit einem „basic - String img src“-Widget
                                    Sieht aktuell jetzt so aus:
                                    • Peoples
                                      Peoples @cfau last edited by
                                      @cfau
                                      VG
                                      Christian
                                      Hi, da ich auch haufenweise Fehler habe, würde ich ebenfalls gerne auf den alten controller zurück, wo finde ich die Anleitung?
                                      • mickym
                                        Es scheint wohl so - dass man mit dem JS-controller mit der iobroker-list Node nun auch keinen Zugriff mehr auf die Enums (Räume und Functions) hat.
                                        https://forum.iobroker.net/topic/67946/gelöst-rollen-und-funktionen-in-iobroker?_=1695225040705
                                        Also für jeden, der das nutzt - sollte eher nicht updaten.
                                        enums fehlen!!!
                                        • foxriver76
                                          @ofri2607 Probier mal bitte die GitHub Version.
                                          • mcm1957
                                            mcm1957 @Peoples last edited by mcm1957
                                            @peoples said in js-controller 5.0.x jetzt für alle User im STABLE!:
                                            @cfau
                                            VG
                                            Christian
                                            a) Bitte Fehler unbedingt melden. Was geht denn bei dir nicht?
                                            b) Downgrade ist im Eröffungsposting unter "vor der Installation" beschrieben
                                            Peoples 1 Reply Last reply Reply Quote 0
                                            js-controller stable upgrade
                                            82
                                            509
                                            131967
