    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev)
      reutli @Thomas Braun last edited by
      @thomas-braun said in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
      Du solltest beide Pakete in Version 247.3-7+deb11u4 installieren.
      wie konkret?
      Habe ja aktuell on hold gesetzt...
        Thomas Braun Most Active @reutli last edited by Thomas Braun
        @reutli
        sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
        Das hold kannst du lassen.
        R 1 Reply Last reply Reply Quote 2
          Hat funktioniert, danke!
          pi@iobroker2:~ $ sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
          Reading package lists... Done
          Building dependency tree... Done
          The following packages were automatically installed and are no longer required:
            libfuse2 raspinfo
          Use 'sudo apt autoremove' to remove them.
          The following held packages will be changed:
            udev
          The following packages will be upgraded:
            libudev1 udev
          2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 1,602 kB of archives.
          After this operation, 0 B of additional disk space will be used.
          Do you want to continue? [Y/n] Y
          Get:1 http://deb.debian.org/debian bullseye-proposed-updates/main armhf udev armhf 247.3-7+deb11u4 [1,440 kB]
          Get:2 http://deb.debian.org/debian bullseye-proposed-updates/main armhf libudev1 armhf 247.3-7+deb11u4 [162 kB]
          Fetched 1,602 kB in 0s (3,683 kB/s)
          Reading changelogs... Done
          (Reading database ... 113534 files and directories currently installed.)
          Preparing to unpack .../udev_247.3-7+deb11u4_armhf.deb ...
          Unpacking udev (247.3-7+deb11u4) over (247.3-7+deb11u3) ...
          Preparing to unpack .../libudev1_247.3-7+deb11u4_armhf.deb ...
          Unpacking libudev1:armhf (247.3-7+deb11u4) over (247.3-7+deb11u3) ...
          Setting up libudev1:armhf (247.3-7+deb11u4) ...
          Setting up udev (247.3-7+deb11u4) ...
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
          Processing triggers for man-db (2.9.4-2) ...
          Processing triggers for initramfs-tools (0.140) ...
          Das ist ja jetzt ein "manueller" Status - ich gehe davon aus, dass die 32Bit Versionen kein Update mehr erfahren werden, oder?
          Heisst ich warte auf Bookworm auf RPI und mach den Slave dann neu auf 64 Bit....
            @reutli sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
            Das musst du die Raspberry OS-Leute fragen. Die sollten das ordentlich versioniert in ihr Repo packen. Dann müsstest du da nicht so Klimmzüge mit hold usw. machen.
              Dieter_P @Thomas Braun last edited by Dieter_P
              Hi mußte gestern überraschend wegen einem Systemcrash neu installieren und bin dabei von debian 11 auf 12 gewechselt.
              nun startet der zigbee adapter nicht. Liegt bei bookworm (64Bit) ähnliches Problem vor? Die Versionen udev sind höher:
              pi@iobroker:~$ ls -la /dev/serial/by-id/
              ls: Zugriff auf '/dev/serial/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
              pi@iobroker:~$ apt policy udev
              udev:
                Installiert:           252.12-1~deb12u1
                Installationskandidat: 252.12-1~deb12u1
                Versionstabelle:
               *** 252.12-1~deb12u1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      100 /var/lib/dpkg/status
              pi@iobroker:~$
              zigbee.0
              	2023-09-21 07:58:52.780	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4502146a83
              zigbee.0
              	2023-09-21 07:58:52.760	error	Error herdsman start
              zigbee.0
              	2023-09-21 07:58:52.759	error	Failed to start Zigbee
              zigbee.0
              	2023-09-21 07:58:52.755	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_00b847ef8093eb118e34214f3d97b6d1-if00-port0'"
              zigbee.0
              	2023-09-21 07:58:52.707	info	Starting Zigbee npm ...
              zigbee.0
              	2023-09-21 07:58:52.704	info	Try to reconnect. 1 attempts left
              zigbee.0
              	2023-09-21 07:58:42.702	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4502146a83
              zigbee.0
              	2023-09-21 07:58:42.698	error	Error herdsman start
              zigbee.0
              	2023-09-21 07:58:42.696	error	Failed to start Zigbee
              zigbee.0
              	2023-09-21 07:58:42.695	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_00b847ef8093eb118e34214f3d97b6d1-if00-port0'"
              zigbee.0
              	2023-09-21 07:58:42.177	info	Starting Zigbee npm ...
              Thx
                Thomas Braun Most Active @Dieter_P last edited by
                @dieter_p sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                Nein. Schau dir per
                dmesg -wT
                an was passiert wenn der Stick eingesteckt wird.
                  dmesg -wT
                  Danke. Ist dies normal so?
                  [Do Sep 21 08:13:02 2023] usb 1-3: new full-speed USB device number 4 using xhci_hcd
                  [Do Sep 21 08:13:03 2023] usb 1-3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                  [Do Sep 21 08:13:03 2023] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                  [Do Sep 21 08:13:03 2023] usb 1-3: Product: CP2102N USB to UART Bridge Controller
                  [Do Sep 21 08:13:03 2023] usb 1-3: Manufacturer: Silicon Labs
                  [Do Sep 21 08:13:03 2023] usb 1-3: SerialNumber: 00b847ef8093eb118e34214f3d99b6d1
                  [Do Sep 21 08:13:03 2023] cp210x 1-3:1.0: cp210x converter detected
                  [Do Sep 21 08:13:03 2023] usb 1-3: cp210x converter now attached to ttyUSB0
                  [Do Sep 21 08:13:07 2023] usb 1-3: usbfs: interface 0 claimed by cp210x while 'brltty' sets config #1
                  [Do Sep 21 08:13:07 2023] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
                  [Do Sep 21 08:13:07 2023] cp210x 1-3:1.0: device disconnected
                    @dieter_p
                    Da war Mal was, dass die ID von Stick gleich zu einer Braille-Tastatur war.
                    Wer keine solche Tastatur verwendet kann den Treiber dafür entfernen.
                      @dieter_p
                      Versuch es damit:
                      sudo systemctl stop brltty-udev.service
                      sudo systemctl mask brltty-udev.service
                      sudo systemctl stop brltty.service
                      sudo systemctl disable brltty.service
                        @dieter_p
                        Versuch es damit:
                        Ups. Danke da war ich zu flott mit deinem Hinweis.
                        Hab mit
                        sudo apt-get remove brltty
                        deinstalliert. Zigbee Stick aus und wieder eimngesteckt. Adapter neu gestartet und es läuft 🙂
                        DANKE!
                          @dieter_p
                          Ja, das geht auch.
                            Thomas Braun Most Active @Dieter_P last edited by Thomas Braun
                            @dieter_p
                            Wobei brltty in einer Installation ohne GUI soweit ich sehe eh kein Standardpaket ist. Was haste denn da installiert?
                            echad@chet:~ $ apt policy brltty
                            brltty:
                              Installed: (none)
                              Candidate: 6.6-4
                              Version table:
                                 6.6-4 500
                                    500 http://deb.debian.org/debian testing/main arm64 Packages
                              @dieter_p
                              Gute Frage und bin ja happy da Gedanklich auch schon drüber "gestolpert" zu sein :).
                              Du "predigst" ohne Desktop zu installieren und entsprechend nur Debian 12 64Bit mit SSH und Systemwerkzeugen installiert. Den Rest hab ich abgewählt wie Desktop etc.
                              Wozu wäre dann eine Bildschirmtastatur/Eingabehilfe sinnvoll wenn man gar keinen Desktop hat? Ballast und weg damit 🙂
                              Edit:
                              pi@iobroker:~$ apt policy brltty
                              brltty:
                                Installiert:           (keine)
                                Installationskandidat: 6.5-7
                                Versionstabelle:
                                   6.5-7 500
                              pi@iobroker:~$
                              P.S.: Das ist kein RPI bei mir, hab mich nur so an den User etc gewöhnt 🙂
                              Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                @dieter_p
                                Der Hostname ist allerdings auch nicht besonders kreativ...
                                  A Former User @Dieter_P last edited by
                                  Moin,
                                  brltty ist keine Bildschirmtastatur, oder hat auch nichts mit dem Desktop zu tun.
                                  Das ist eine Blindenschriftzeile, da wird Dir der Text in Blindenschrift auf einer Dot Matrik ausgegeben, die dann ein Blinder mit den Fingern lesen kann.
                                  VG
                                  Bernd
                                    SaschaL last edited by
                                    nachdem ich erfolgreich meine ioBroker Installation mit eurer Hilfe aktualisieren und auch ein Upgrade auf bullseye durchführen konnte, habe ich jetzt bemerkt das meine Zigbee Geräte nicht mehr funktionieren. Ich kann zwar auf das Webinterface von Deconz zugreifen aber alle Geräte werden als offline angezeigt.
                                    Nun habe ich diese Anleitung (ab Punkt 2) gefunden und auch schon mehrfach durchgeführt, aber es funktioniert immer noch nicht.
                                    Im einzelnen:
                                    pi@raspberrypi:~ $ apt policy udev
                                    udev:
                                      Installiert:           247.3-7+rpi1+deb11u2
                                      Installationskandidat: 247.3-7+rpi1+deb11u2
                                      Versionstabelle:
                                     *** 247.3-7+rpi1+deb11u2 500
                                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                    Aber naachdem ich die Datei bullseye-proposed-updates.list erstellt habe und den Reboot durchgeführt habe ergibt sich folgendes Bidl:
                                    udev:
                                      Versionstabelle:
                                         252.5-2~bpo11+1 100
                                            100 http://deb.debian.org/debian bullseye-backports/main armhf Packages
                                    Der nächste Schritt war folgender:
                                    pi@raspberrypi:~ $ sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                                    Paketlisten werden gelesen… Fertig
                                    Abhängigkeitsbaum wird aufgebaut… Fertig
                                    Statusinformationen werden eingelesen… Fertig
                                    E: Version »247.3-7+deb11u4« für »udev« konnte nicht gefunden werden.
                                    E: Version »247.3-7+deb11u4« für »libudev1« konnte nicht gefunden werden.
                                    Das Summary der ioBroker Diagnose liefert folgendes, vielleicht hilft das ja:
                                                            v.2023-10-10
                                       Static hostname: raspberrypi
                                             Icon name: computer
                                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 5.10.103-v7l+
                                          Architecture: arm
                                    Installation:           native
                                    Kernel:                 armv7l
                                    Userland:               armhf
                                    Timezone:               Europe/Berlin (CEST, +0200)
                                    User-ID:                1000
                                    X-Server:               false
                                    Boot Target:            graphical.target
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                            /usr/bin/node           v18.18.2
                                                            /usr/bin/npm            9.8.1
                                                            /usr/bin/npx            9.8.1
                                                            /usr/bin/corepack       0.19.0
                                    Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                    MEMORY:
                                    Mem:            3.8G        1.3G        1.7G        0.0K        833M        2.4G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.3G        1.8G
                                    Active iob-Instances:   25
                                    Active repo(s): stable
                                    ioBroker Core:          js-controller           5.0.12
                                                            admin                   6.10.1
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.68, run as: admin
                                    Objects:                5417
                                    States:                 4613
                                    Size of iob-Database:
                                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                                    8.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                                    8.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    5.2M    /opt/iobroker/iobroker-data/states.jsonl
                                    1.1M    /opt/iobroker/iobroker-data/states.json.migrated
                                    1.1M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    Leider habe ich kein Image vor dem Upgrade auf bullseye gemacht, somit bleibt nur die Installation irgendwie zu retten (und hoffentlich etwas hierbei zu lernen) 😬
                                    Es wäre schön wenn ihr mir auch in diesem Falle helfen würdet.
                                    Vielen Dank schonmal,
                                    Gruß,
                                    Sascha
                                      Thomas Braun Most Active @SaschaL last edited by
                                      @saschal sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                                      bullseye-backports
                                      Die sollst du ja auch nicht verwenden, sondern die proposed-updates.
                                      Kannst aber gleich auf Debian 12 'Bookworm' gehen, da ist der Fehler auch nicht mehr vorhanden.
                                        SaschaL @Thomas Braun last edited by
                                        OK, das sehe ich jetzt auch 😕 aber wie kann ich das jetzt umstellen? Da fehlt mir echt leider immer noch der Durchblick, sorry 😥
                                          @thomas-braun sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                                          bullseye-backports
                                          Thomas Braun R 2 Replies Last reply Reply Quote 0
                                            @saschal
                                            Steht das nicht im HowTo von @mickym drin? Mir war so...
                                            conbee 2 usb port zigbee2mqtt
                                            42
                                            361
                                            84818
