    4. iobroker geht nicht nach stromausfall
    • Marc Berg
      Marc Berg Most Active last edited by
      @esmax666 sagte in iobroker geht nicht nach stromausfall:
      System successfully restored!
      Das sieht doch nicht sooo schlecht aus.
      Was sagt denn jetzt
      iob status
      iob list instances
        Esmax666 @Marc Berg last edited by Esmax666
        @marc-berg
        @marc-berg
        ubuntu@ubuntu:/opt/iobroker$ iob status
         Cannot read system.config: null (OK when migrating or restoring)
        iobroker is not running on this host.
        Objects type: file
        States  type: file
        ubuntu@ubuntu:/opt/iobroker$ iob list instances
         Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        + instance is alive
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: ubuntu
                 Icon name: computer
                Machine ID: 551875df55414c0f832b43a896fe8ce5
                   Boot ID: a58fe4cd23274d7e86463c9c059dca8f
          Operating System: Ubuntu 21.04
                    Kernel: Linux 5.11.0-1027-raspi
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         19:58:17 up 1 day,  8:07,  1 user,  load average: 0.81, 0.86, 0.79
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Wed 2023-09-20 19:58:17 CEST
                   Universal time: Wed 2023-09-20 17:58:17 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        ubuntu
        /home/ubuntu
        ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        211M        5.3G        3.0M        2.4G        7.6G
        Swap:            0B          0B          0B
        Total:         7.9G        211M        5.3G
                 7886 M total memory
                  211 M used memory
                  866 M active memory
                 1406 M inactive memory
                 5304 M free memory
                  312 M buffer memory
                 2058 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        tmpfs          tmpfs  789M  4.0M  785M   1% /run
        /dev/sda2      ext4    57G  7.6G   47G  14% /
        tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
        /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
        tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
        [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
        [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET              SOURCE     FSTYPE   OPTIONS
        /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
        |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
        |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
        |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
        |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
        |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
        |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
        |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
        |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
        |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
        |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
        `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.3G    /var/
        2.0G    /var/log
        1.8G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
        1.2G    /var/lib
        Archived and active journals take up 1.7G in the file system.
        /opt/iobroker/backups:
        50M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        355M    /opt/iobroker/iobroker-data/
        193M    /opt/iobroker/iobroker-data/files
        151M    /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        11M     /opt/iobroker/iobroker-data/objects.jsonl
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.0
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.0-1nodesource1
          Candidate: 18.18.0-1nodesource1
          Version table:
         *** 18.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.21.0~dfsg-3ubuntu1 500
                500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: file
        States  type: file
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    file on 127.0.0.1
        States:                     file on 127.0.0.1
        Core adapters versions
        js-controller:  3.3.22
        admin:          6.10.1
        javascript:     7.1.4
        Adapters from github:   0
        Adapter State
        + instance is alive
        ioBroker-Repositories
        Cannot get list: undefined
        Installed ioBroker-Instances
        Error: Object "system.config" not found
        ^C
        ubuntu@ubuntu:/opt/iobroker$ ^C
        • Marc Berg
          @esmax666
          Wenn ich den Thread richtig verfolgt habe, hast du ja - von einem defekten System kommend - erst ein Upgrade und danach ein Downgrade bis iobroker.js-controller@3.3.22 gemacht und dann das Restore durchgeführt. Vielleicht bringt es ja etwas, mit einem frischen, neuen System zu starten, dann das Downgrade und Restore.
          Ist aber nur ins Blaue geraten.
            @marc-berg
            oh dann sieht es schon schecht aus 😞
            gibt es irgenwo ein ubuntu bild?
            • OliverIO
              OliverIO @Esmax666 last edited by
              @esmax666
              ich würde die sd karte auch mal mit fsck prüfen.
              nicht das die mit dem stromausfall einen hau hat.
              E 2 Replies Last reply Reply Quote 0
                Esmax666 @OliverIO last edited by
                @oliverio ist ein USB stick, ist aber auch wahrscheinlich gleich
                  Esmax666 @Esmax666 last edited by
                  sonst lieber rapberryos oder Ubuntu? ist auch fast gleich oder?
                    Thomas Braun Most Active @Esmax666 last edited by
                    rapberryos
                      Esmax666 @Thomas Braun last edited by
                      @thomas-braun danke aber was wäre das problem mit ubuntu ?
                      • OliverIO
                        OliverIO @Esmax666 last edited by OliverIO
                        @esmax666
                        du solltest mal nachlesen was es mit den distributionen auf sich hat
                        ubuntu, rapsiOS, mint, stammen alle von debian ab
                        raspiOS ist direkt für den raspi abgestimmt und optimiert.
                        der raspi hat nun mal etwas andere hardware als andere rechner mit ARM-Prozessor. Nicht das das grundsätzlich ein Problem ist.
                        Beim Auto kannst du auch entweder die Originalteile verwenden, oder alternative/gleiche teile. meist wird das auch passen, aber manchmal halt dann nicht
                        dennoch kannst du alle pakete installieren und auch meist die Anleitungen zu anderen debian-artigen Betriebssysteme lesen.
                        Gegenfrage: Warum willst du unbedingt ubuntu?
                          @oliverio said in iobroker geht nicht nach stromausfall:
                          ich weiss nicht mehr ich hatte früher RaspiOS und mir hat damals etwas gefehlt ( weiss aber nicht mehr was lol)
                          villeicht war da etwas mit Python lib oder Plex server pihole
                          Weiss gar nicht mehr 😞
                            Thomas Braun Most Active last edited by Thomas Braun
                            Dann nimm die 'Original-Teile'.
                            Gerade im Bereich python ist Debian nämlich exellent aufgestellt.
                            • OliverIO
                              @esmax666
                              wenn was fehlt, dann installierst du es.
                              das ist unter linux wirklich einfach
                              hier mal eine übersicht über die wichtigsten distributionen
                              https://codezentrale.de/linux-stammbaum-linux-distributionen/
                              alle haben den Linux-Kernel gemeinsam (was eigentlich nur Linux ist)
                              Jede distribution entscheidet, dann zum einen welche systemprogramme das ergänzen (evtl ist dir mal was von der systemd-diskussion bei debian untergekommen.
                              https://linuxnews.de/die-unendliche-geschichte-debian-und-systemd/
                              die meist sichtbarste Eigenschaft ist die Wahl der grafischen benutzeroberfläche, was aber ja bei serversystemen nicht relevant ist.
                              Das heißt aber auch, das ich meist auf jeder distribution auch jede andere grafische benutzeroberfläche installieren kann (ob die dann optimiert ist ist dann eine andere frage)
                              auch die wahl der vorinstallierten programme gehört mit zu einer distribution.
                              meist werden die installierten, aber auch über ein repository bereitgestellten pakete softwaretechnisch betreut und für eine gewisse zeit security fixes herausgegeben.
                              weitere unterscheidung ist noch getaktet oder rolling release
                              bei getaktet bleibt die hauptversion einer software innerhalb distributions version gleich. eigentlich gibt es nur bug und security fixes
                              daher gibt es bei debian die verschiedenen versionen buster, bookworm, etc.
                              bei rolling werden laufend auch neue versionen aufgenommen,
                              was dann aber manchmal Auswirkung auf die Stabilität haben kann
                                Thomas Braun Most Active @OliverIO last edited by Thomas Braun
                                @oliverio @Esmax666
                                Ergänzend dann noch der Hinweis auf die Unterschiede im Support.
                                Ubuntu bringt alle zwei Jahre eine sog. LTS = LongTermSupport-Version heraus, die Interims-Releases werden nur zu Testzwecken veröffentlicht und nach 9 Monaten abgekündigt. Also keine Basis für einen Server-Betrieb.
                                Debian veröffentlicht alle zwei Jahre ein neues Release, das wird dann regulär ca. 3 Jahre unterstützt. In im dritten Jahr werden also mehrere Distributionen gepflegt, das ist aber auch der Zeitraum in dem man den Absprung von der auslaufenden Version planen und durchführen muss.
                                E OliverIO 2 Replies Last reply Reply Quote 1
                                  @thomas-braun said in iobroker geht nicht nach stromausfall:
                                  also das heisst mit ubuntu soll man generell wieder das ganze nach 2 Jahre wieder komplett neue installieren ?
                                  wie viele jahre wäre das mit Raspberry Pi OS?
                                    Die hängen in der Regel etwas hinter den Debian-Releases hinterher, haben aber grundsätzlich den gleichen Rhythmus wie Debian.
                                    Also alle ungefähr alle zwei Jahre ein neues Release.
                                    Jein. Wenn die Basis nicht allzusehr umgekrempelt wurde kann man auch von einer zur nächsten Distribution springen. Gibt dann immer mehr oder weniger wilde Anleitungen dazu.
                                      @thomas-braun Sonst Ubuntu Core 22
                                      Ubuntu Core 22 comes with 10 years of support, until 2032.
                                        Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
                                        @esmax666
                                        Das ist auch nicht das was du suchst:
                                        Ubuntu Core ist eine Minimalversion des Ubuntu-Betriebssystems, die speziell für den Einsatz auf eingebetteten Geräten, IoT-Geräten und anderen ähnlichen Anwendungen entwickelt wurde.
                                        Den Kern des Systems bildet eine stark abgespeckte Variante von Ubuntu Linux mit einem eigens für IoT und Edge-Geräte optimierten Kern
                                        Nimm halt ein Debian / Raspberry OS für dein Gerät und gut ist.
                                        • OliverIO
                                          OliverIO @Thomas Braun last edited by
                                          kleine korrektur zu debian
                                          debian LTS wird 5 Jahre gepflegt (zumindest die security bugfixes)
                                          https://wiki.debian.org/LTS
                                          raspian basiert auf dem jeweiligen debian LTS
                                          @Esmax666
                                          du kannst natürlich auch ubuntu nehmen. Deiner Argumentation nach suchst du ja förmlich nach einem Grund ubuntu zu nehmen.
                                          Allerdings find ich, das man nach 5 Jahre schon mal das OS aktualisieren sollte. Wie gesagt, es gibt nach der Regelzeit des Releases nur noch security fixes, also keine besseren performantere Funktionen, falls es da Verbesserungen gibt.
                                          Bei 10 Jahren ist dann schon die Frage, ob die Hardware solange durchhält (Festplatte oder so)
                                          Ich würde immer noch Raspian (oben hab ich es RapsiOS genannt) nehmen. Du hast dann max 5 Jahre LTS.
                                          Das aktuelle Raspian vom Mai basiert auf Bullseye, d.h. du hast noch bis 2026 LTS support. Anfang 2026 baust du dann deine Maschine komplett neu auf.
                                            @oliverio sagte in iobroker geht nicht nach stromausfall:
                                            Wobei das halt schon 'am Tropf' hängt und nicht mehr vollumfänglich gepflegt wird. Würde ich nicht dauerhaft in dem Stage betreiben. Da ist die Zeit zum Absprung bereits überreif.
                                            ELTS wäre sogar noch weitere Jahre. Aber das willst du nicht ohne Not durchschleppen.
                                            OliverIO 1 Reply Last reply Reply Quote 1
                                            10456
