    4. iobroker geht nicht nach stromausfall
      Esmax666 @Marc Berg last edited by Esmax666
      @marc-berg
      @marc-berg
      ubuntu@ubuntu:/opt/iobroker$ iob status
       Cannot read system.config: null (OK when migrating or restoring)
      iobroker is not running on this host.
      Objects type: file
      States  type: file
      ubuntu@ubuntu:/opt/iobroker$ iob list instances
       Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      + instance is alive
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: ubuntu
               Icon name: computer
              Machine ID: 551875df55414c0f832b43a896fe8ce5
                 Boot ID: a58fe4cd23274d7e86463c9c059dca8f
        Operating System: Ubuntu 21.04
                  Kernel: Linux 5.11.0-1027-raspi
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       19:58:17 up 1 day,  8:07,  1 user,  load average: 0.81, 0.86, 0.79
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2023-09-20 19:58:17 CEST
                 Universal time: Wed 2023-09-20 17:58:17 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      ubuntu
      /home/ubuntu
      ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        211M        5.3G        3.0M        2.4G        7.6G
      Swap:            0B          0B          0B
      Total:         7.9G        211M        5.3G
               7886 M total memory
                211 M used memory
                866 M active memory
               1406 M inactive memory
               5304 M free memory
                312 M buffer memory
               2058 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      tmpfs          tmpfs  789M  4.0M  785M   1% /run
      /dev/sda2      ext4    57G  7.6G   47G  14% /
      tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
      /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
      tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
      [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
      [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET              SOURCE     FSTYPE   OPTIONS
      /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
      |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
      |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
      |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
      |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
      |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
      |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
      |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
      |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
      |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
      |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
      `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.3G    /var/
      2.0G    /var/log
      1.8G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
      1.2G    /var/lib
      Archived and active journals take up 1.7G in the file system.
      /opt/iobroker/backups:
      50M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      355M    /opt/iobroker/iobroker-data/
      193M    /opt/iobroker/iobroker-data/files
      151M    /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.21.0~dfsg-3ubuntu1 500
              500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: file
      States  type: file
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    file on 127.0.0.1
      States:                     file on 127.0.0.1
      Core adapters versions
      js-controller:  3.3.22
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   0
      Adapter State
      + instance is alive
      ioBroker-Repositories
      Cannot get list: undefined
      Installed ioBroker-Instances
      Error: Object "system.config" not found
      ^C
      ubuntu@ubuntu:/opt/iobroker$ ^C
      • Marc Berg
        Marc Berg Most Active last edited by
        @esmax666
        Wenn ich den Thread richtig verfolgt habe, hast du ja - von einem defekten System kommend - erst ein Upgrade und danach ein Downgrade bis iobroker.js-controller@3.3.22 gemacht und dann das Restore durchgeführt. Vielleicht bringt es ja etwas, mit einem frischen, neuen System zu starten, dann das Downgrade und Restore.
        Ist aber nur ins Blaue geraten.
          @marc-berg
          oh dann sieht es schon schecht aus 😞
          gibt es irgenwo ein ubuntu bild?
          • OliverIO
            OliverIO @Esmax666 last edited by
            @esmax666
            ich würde die sd karte auch mal mit fsck prüfen.
            nicht das die mit dem stromausfall einen hau hat.
            E 2 Replies Last reply Reply Quote 0
              Esmax666 @OliverIO last edited by
              @oliverio ist ein USB stick, ist aber auch wahrscheinlich gleich
                Esmax666 @Esmax666 last edited by
                sonst lieber rapberryos oder Ubuntu? ist auch fast gleich oder?
                  Thomas Braun Most Active @Esmax666 last edited by
                  @esmax666 sagte in iobroker geht nicht nach stromausfall:
                  rapberryos
                    Esmax666 @Thomas Braun last edited by
                    @thomas-braun danke aber was wäre das problem mit ubuntu ?
                    • OliverIO
                      OliverIO @Esmax666 last edited by OliverIO
                      @esmax666
                      du solltest mal nachlesen was es mit den distributionen auf sich hat
                      ubuntu, rapsiOS, mint, stammen alle von debian ab
                      raspiOS ist direkt für den raspi abgestimmt und optimiert.
                      der raspi hat nun mal etwas andere hardware als andere rechner mit ARM-Prozessor. Nicht das das grundsätzlich ein Problem ist.
                      Beim Auto kannst du auch entweder die Originalteile verwenden, oder alternative/gleiche teile. meist wird das auch passen, aber manchmal halt dann nicht
                      dennoch kannst du alle pakete installieren und auch meist die Anleitungen zu anderen debian-artigen Betriebssysteme lesen.
                      Gegenfrage: Warum willst du unbedingt ubuntu?
                        @oliverio said in iobroker geht nicht nach stromausfall:
                        ich weiss nicht mehr ich hatte früher RaspiOS und mir hat damals etwas gefehlt ( weiss aber nicht mehr was lol)
                        villeicht war da etwas mit Python lib oder Plex server pihole
                        Weiss gar nicht mehr 😞
                          Thomas Braun Most Active last edited by Thomas Braun
                          Dann nimm die 'Original-Teile'.
                          Gerade im Bereich python ist Debian nämlich exellent aufgestellt.
                          • OliverIO
                            @esmax666
                            wenn was fehlt, dann installierst du es.
                            das ist unter linux wirklich einfach
                            hier mal eine übersicht über die wichtigsten distributionen
                            https://codezentrale.de/linux-stammbaum-linux-distributionen/
                            alle haben den Linux-Kernel gemeinsam (was eigentlich nur Linux ist)
                            Jede distribution entscheidet, dann zum einen welche systemprogramme das ergänzen (evtl ist dir mal was von der systemd-diskussion bei debian untergekommen.
                            https://linuxnews.de/die-unendliche-geschichte-debian-und-systemd/
                            die meist sichtbarste Eigenschaft ist die Wahl der grafischen benutzeroberfläche, was aber ja bei serversystemen nicht relevant ist.
                            Das heißt aber auch, das ich meist auf jeder distribution auch jede andere grafische benutzeroberfläche installieren kann (ob die dann optimiert ist ist dann eine andere frage)
                            auch die wahl der vorinstallierten programme gehört mit zu einer distribution.
                            meist werden die installierten, aber auch über ein repository bereitgestellten pakete softwaretechnisch betreut und für eine gewisse zeit security fixes herausgegeben.
                            weitere unterscheidung ist noch getaktet oder rolling release
                            bei getaktet bleibt die hauptversion einer software innerhalb distributions version gleich. eigentlich gibt es nur bug und security fixes
                            daher gibt es bei debian die verschiedenen versionen buster, bookworm, etc.
                            bei rolling werden laufend auch neue versionen aufgenommen,
                            was dann aber manchmal Auswirkung auf die Stabilität haben kann
                              Thomas Braun Most Active @OliverIO last edited by Thomas Braun
                              @oliverio @Esmax666
                              Ergänzend dann noch der Hinweis auf die Unterschiede im Support.
                              Ubuntu bringt alle zwei Jahre eine sog. LTS = LongTermSupport-Version heraus, die Interims-Releases werden nur zu Testzwecken veröffentlicht und nach 9 Monaten abgekündigt. Also keine Basis für einen Server-Betrieb.
                              Debian veröffentlicht alle zwei Jahre ein neues Release, das wird dann regulär ca. 3 Jahre unterstützt. In im dritten Jahr werden also mehrere Distributionen gepflegt, das ist aber auch der Zeitraum in dem man den Absprung von der auslaufenden Version planen und durchführen muss.
                              E OliverIO 2 Replies Last reply Reply Quote 1
                                @thomas-braun said in iobroker geht nicht nach stromausfall:
                                also das heisst mit ubuntu soll man generell wieder das ganze nach 2 Jahre wieder komplett neue installieren ?
                                wie viele jahre wäre das mit Raspberry Pi OS?
                                  Die hängen in der Regel etwas hinter den Debian-Releases hinterher, haben aber grundsätzlich den gleichen Rhythmus wie Debian.
                                  Also alle ungefähr alle zwei Jahre ein neues Release.
                                  Jein. Wenn die Basis nicht allzusehr umgekrempelt wurde kann man auch von einer zur nächsten Distribution springen. Gibt dann immer mehr oder weniger wilde Anleitungen dazu.
                                    @thomas-braun Sonst Ubuntu Core 22
                                    Ubuntu Core 22 comes with 10 years of support, until 2032.
                                      Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
                                      @esmax666
                                      Das ist auch nicht das was du suchst:
                                      Ubuntu Core ist eine Minimalversion des Ubuntu-Betriebssystems, die speziell für den Einsatz auf eingebetteten Geräten, IoT-Geräten und anderen ähnlichen Anwendungen entwickelt wurde.
                                      Den Kern des Systems bildet eine stark abgespeckte Variante von Ubuntu Linux mit einem eigens für IoT und Edge-Geräte optimierten Kern
                                      Nimm halt ein Debian / Raspberry OS für dein Gerät und gut ist.
                                      • OliverIO
                                        OliverIO @Thomas Braun last edited by
                                        kleine korrektur zu debian
                                        debian LTS wird 5 Jahre gepflegt (zumindest die security bugfixes)
                                        https://wiki.debian.org/LTS
                                        raspian basiert auf dem jeweiligen debian LTS
                                        @Esmax666
                                        du kannst natürlich auch ubuntu nehmen. Deiner Argumentation nach suchst du ja förmlich nach einem Grund ubuntu zu nehmen.
                                        Allerdings find ich, das man nach 5 Jahre schon mal das OS aktualisieren sollte. Wie gesagt, es gibt nach der Regelzeit des Releases nur noch security fixes, also keine besseren performantere Funktionen, falls es da Verbesserungen gibt.
                                        Bei 10 Jahren ist dann schon die Frage, ob die Hardware solange durchhält (Festplatte oder so)
                                        Ich würde immer noch Raspian (oben hab ich es RapsiOS genannt) nehmen. Du hast dann max 5 Jahre LTS.
                                        Das aktuelle Raspian vom Mai basiert auf Bullseye, d.h. du hast noch bis 2026 LTS support. Anfang 2026 baust du dann deine Maschine komplett neu auf.
                                          @oliverio sagte in iobroker geht nicht nach stromausfall:
                                          Wobei das halt schon 'am Tropf' hängt und nicht mehr vollumfänglich gepflegt wird. Würde ich nicht dauerhaft in dem Stage betreiben. Da ist die Zeit zum Absprung bereits überreif.
                                          ELTS wäre sogar noch weitere Jahre. Aber das willst du nicht ohne Not durchschleppen.
                                          OliverIO 1 Reply Last reply Reply Quote 1
                                          • OliverIO
                                            OliverIO @Thomas Braun last edited by OliverIO
                                            na das ist dein Gefühl. für bullseye lts bis 2026 sind noch 3 Jahre.
                                            Welche aktuellen Versionen benötigt er den.
                                            Wichtig sind die security fixes.
                                            Node für iobroker wird eh separat installiert und aktualisiert.
                                            und wenn er auf etwas stößt, dann kann er auch schon früher wechseln.
                                            ok, nochmal zum direkt hier nachlesen
                                            bullseye, Support Ende Mitte 2024
                                            bullseye LTS, Support Ende Mitte 2026
                                            bullseye ELTS, Support Ende Mitte 2029, was aber für unsere Kreise komplett wegfällt, da es definitiv geld kostet und meiner Meinung nach sicherlich noch mehr geld kosten sollte, da sich dann jemand Abhängigkeiten zu einer Version eingebaut hat, die er nicht so einfach wechseln kann.
                                            @Esmax666
                                            Nimm raspian
                                            Thomas bist du anderer Meinung, sonst verwirren wir ihn hier noch mehr und ich könnte hier noch mit meiner docker-variante kommen 🙂
                                            Thomas Braun 3 Replies Last reply Reply Quote 1
                                            10456
