    4. iob node fix - Skript
      TWD83 @haselchen last edited by
      @haselchen sagte in iob node fix - Skript:
        sudo apt-get update        sudo apt-get install nodejs -y
      Vielen dank! So hat es bei mir geklappt!
        Frank579 @Thomas Braun last edited by Frank579
        So sieht es bei mir aus ... keine 2x Nothing to do ..
        ioBroker nodejs fixer 2023-09-20
        Recommended nodejs-version is: 18.18.0
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                100 /var/lib/dpkg/status
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
        Nothing to do, your installation is using the correct paths.
        You are running nodejs v18.17.1. Do you want to install recommended version 18.1        8.0?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        [sudo] password for frank:
        kvm
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
        Fetched 17.4 kB in 1s (27.2 kB/s)
        Installing the recommended nodejs version now!
        ./iob_node_update: line 308: [: : integer expression expected
        ./iob_node_update: line 323: [: : integer expression expected
        *** You need to manually restart your container now! ***
        We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        nach einem Neustart war laut iob diag immer noch die 18.17.1 drauf, aber 1 OS update fällig. update und upgrade ausgeführt und dann war auch die 18.18.0 drauf
        hier noch die diag Zusammenfassung
                             v.2023-06-20
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm 🖴
              Machine ID: 84546650dea94ae18d0b4591eabfa35d
                 Boot ID: d517d6f1ff9047a7af8b77da764b2425
          Virtualization: kvm
                  Kernel: Linux 6.1.0-12-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     1
        Pending iob updates:    16
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            8.3G        2.7G        5.1G        507K        734M        5.6G
        Swap:           1.0G          0B        1.0G
        Total:          9.3G        2.7G        6.2G
        Active iob-Instances:   21
        Active repo(s): beta
        ioBroker Core:          js-controller           5.0.12
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                19132
        States:                 17041
        Size of iob-Database:
        55M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/states.jsonl
        IOBroker läuft auf Debian 12 Proxmox VM
        Edit:
        Diag nach update / Upgrade
                             v.2023-06-20
                 Chassis: vm 🖴
          Virtualization: kvm
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    2
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                /usr/bin/node           v18.18.0
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
        MEMORY:
        Mem:            8.3G        4.8G        2.7G        507K        1.1G        3.5G
        Swap:           1.0G          0B        1.0G
        Total:          9.3G        4.8G        3.8G
        Active iob-Instances:   44
        Active repo(s): stable
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                19132
        States:                 17041
        64M     /opt/iobroker/iobroker-data/objects.jsonl
        36M     /opt/iobroker/iobroker-data/states.jsonl
          Jan1 @Frank579 last edited by
          @frank579 sagte in iob node fix - Skript:
          Klar, ein Neustart installiert ja auch keine Node, sondern das System Update.
          Das Script bereitet das vor, aber installieren musst das schon selber.
            Frank579 @Jan1 last edited by Frank579
            @jan1 sagte in iob node fix - Skript:
            You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
            Die abfrage habe ich anders verstanden...
            Wenns so ist Okay dann war ja alles Richtig.
            @Thomas-Braun ist das so ?
              DPO99 @Thomas Braun last edited by
              @thomas-braun bei mir war es wie bei @Frank579. Realtiv ähnlich lief das Skript bei mir. Zwischendurch diese Info:
              Bei mir wurde auch nach einem Update auf die neuste Version gefragt:
              You are running nodejs v18.17.1. Do you want to install recommended version in tree 18.x        8.0?
              [sudo] password for iobroker:
              und endete mit dieser CodeZeile
              Im Verlauf der Installation war es auch so, dass er von 18.17.1 ein Downgrade auf 18.17.0 durchgeführt hat und dann wieder ein upgrade auf 18.18.0 inkl. NPM.
              Wie gesagt, sah am Ende dann alles korrekt aus, lief ohne Fehler und iob diag hat auch keine Fehler gemeldet.
                Thomas Braun Most Active @DPO99 last edited by Thomas Braun
                @dpo99 sagte in iob node fix - Skript:
                Das wird gemacht, wenn aus den iob-States keine Recommended Version ausgelesen werden kann (slaves oder Datenbank läuft nicht oder sonst irgendwas).
                Ich hab den Code jetzt umgestellt, die Meldungen sollten jetzt schlüssiger sein.
                  mick70 last edited by
                  Hat hier funktioniert. Ebenfalls nach anfänglichem Downgrade auf 18.17.0 ist jetzt 18.18.0 installiert und erneuter Durchlauf berichtet wie erhofft 2x "nothing to do". Einwandfrei!
                    Thomas Braun Most Active @mick70 last edited by
                    @mick70 sagte in iob node fix - Skript:
                    Ist das ein Slave-Device? Oder warum musste dieser Fallback gemacht werden?
                      mick70 @Thomas Braun last edited by
                      @thomas-braun Nein, ist eigentlich gar nix besonderes. Die Ursache fürs Fallback habe ich leider überlesen, falls sie irgendwo stand.
                        Die genaue Ursache steht nicht da, nur dass keine empfohlene Version gefunden werden konnte und daher der 18er-Zweig angelegt werden wird.
                        teletapi 1 Reply Last reply Reply Quote 1
                        • teletapi
                          teletapi @Thomas Braun last edited by teletapi
                          Funktioniert ganz klasse
                          Hab das heute mal drüber laufen lassen und das Update auf die 18.18.0 gemacht
                          /usr/bin/npm 9.6.7
                          /usr/bin/npx 9.6.7
                          nodejs:
                          Version table:
                          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                          12.22.12~dfsg-1~deb11u4 500
                          500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
                          12.22.12~dfsg-1~deb11u3 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          Nothing to do - Your installation is using the correct paths.
                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                          Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                          Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48 .4 kB]
                          Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          Get:6 https://apt.grafana.com stable InRelease [5984 B]
                          Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB ]
                          Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB ]
                          Fetched 744 kB in 1s (498 kB/s)
                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node _18.x nodistro main
                          Package: nodejs
                          Pin-Priority: 1001
                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:6 https://apt.grafana.com stable InRelease
                          Get:7 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                          Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5262 B]
                          Get:9 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                          Fetched 22.7 kB in 2s (13.8 kB/s)
                          We tried our best to fix your nodejs. Please run iob diag again to verify.
                          *** RESTARTING ioBroker NOW! ***
                          Please refresh or restart your browser in a few moments.
                          pi@iobroker:~ $ sudo apt update && sudo apt upgrade
                          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                          OK:2 http://deb.debian.org/debian bullseye InRelease
                          OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                          OK:5 https://repos.influxdata.com/debian stable InRelease
                          OK:6 https://apt.grafana.com stable InRelease
                          OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                          Paketaktualisierung (Upgrade) wird berechnet… Fertig
                          Die folgenden Pakete werden aktualisiert (Upgrade):
                          nodejs
                          1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 28,7 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 859 kB Plattenplatz zusätzlich benutzt.
                          Möchten Sie fortfahren? [J/n] J
                          Holen:1 https://deb.nodesource.com/node_18.x nodistro/main arm64 nodejs arm64 18 .18.0-1nodesource1 [28,7 MB]
                          Es wurden 28,7 MB in 2 s geholt (11,5 MB/s).
                          Changelogs werden gelesen... Fertig
                          (Lese Datenbank ... 117382 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../nodejs_18.18.0-1nodesource1_arm64.deb ...
                          Detected old npm client, removing...
                          Entpacken von nodejs (18.18.0-1nodesource1) über (18.17.1-deb-1nodesource1) ...
                          nodejs (18.18.0-1nodesource1) wird eingerichtet ...
                          Trigger für man-db (2.9.4-2) werden verarbeitet ...
                          pi@iobroker:~ $ iobroker stop
                          pi@iobroker:~ $ iobroker fix
                          library: loaded
                          Library version=2022-12-09
                          Welcome to the ioBroker installation fixer!
                          Script version: 2023-04-02
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/5)
                          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                          OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          Installed gcc-c++
                          Checking ioBroker user and directory permissions (2/5)
                          Created /etc/sudoers.d/iobroker
                          Fixing directory permissions...
                          Check and cleanup npm temporary directories (3/5)
                          Done.
                          Database maintenance (4/5)
                          Checking for uncompressed JSONL databases... This might take a while!
                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                          Compressed 2 JSONL files. Done
                          Checking autostart (5/5)
                          Enabling autostart...
                          Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                          pi@iobroker:~ $ sudo reboot
                          Und dann mal IOB Diag laufen lassen
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                  Machine ID: a9f1eae0dc5a48ddbf0e2a62c2227673
                                     Boot ID: 30ea7719d00c47c7b8b94d2a5e591316
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                          Model           : Raspberry Pi 4 Model B Rev 1.5
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : arm64
                          Systemuptime and Load:
                           15:14:39 up 5 min,  1 user,  load average: 1.41, 1.78, 0.91
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          Other values than 0x0 hint to temperature/voltage problems
                          temp=46.7'C
                          volt=0.9360V
                          *** Time and Time Zones ***
                                         Local time: Fri 2023-09-22 15:14:39 CEST
                                     Universal time: Fri 2023-09-22 13:14:39 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            7.8G        2.3G        4.0G        1.0M        1.5G        5.4G
                          Swap:            99M          0B         99M
                          Total:          7.9G        2.3G        4.1G
                                   7811 M total memory
                                   2318 M used memory
                                   3162 M active memory
                                    446 M inactive memory
                                   4041 M free memory
                                     71 M buffer memory
                                   1380 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G  9.8G   47G  18% /
                          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                          /dev/sda1      vfat      255M   31M  225M  13% /boot
                          tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                          [Fri Sep 22 15:08:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          [Fri Sep 22 15:08:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Sep 22 15:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Fri Sep 22 15:08:56 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          Show mounted filesystems (real ones only):
                          TARGET  SOURCE    FSTYPE OPTIONS
                          /       /dev/sda2 ext4   rw,noatime
                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          1.9G    /var/
                          1.2G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
                          1.2G    /var/log
                          477M    /var/lib
                          Archived and active journals take up 1.1G in the file system.
                          /opt/iobroker/backups:
                          1.2G    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          334M    /opt/iobroker/iobroker-data/
                          181M    /opt/iobroker/iobroker-data/files
                          71M     /opt/iobroker/iobroker-data/backup-objects
                          62M     /opt/iobroker/iobroker-data/node-red/node_modules
                          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                          14M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                          *** NodeJS-Installation ***
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Installed: 18.18.0-1nodesource1
                            Candidate: 18.18.0-1nodesource1
                            Version table:
                           *** 18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                          No problems detected
                          Errors in npm tree: 0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          No configuration change needed.
                          Multihost discovery server: disabled
                          Discovery authentication:   enabled
                          Persistent activation:      disabled
                          Objects:                    jsonl on 127.0.0.1
                          States:                     jsonl on 127.0.0.1
                          Core adapters versions
                          js-controller:  5.0.12
                          admin:          6.10.2
                          javascript:     7.1.4
                          Adapters from github:   2
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                          + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
                          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
                          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                          + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                          + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker                                 -  enabled
                          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                            system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
                            system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
                          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Installed ioBroker-Instances
                          Used repository: beta
                          Adapter    "admin"        : 6.10.2   , installed 6.10.2
                          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                          Adapter    "discovery"    : 4.0.0    , installed 4.0.0
                          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                          Adapter    "iot"          : 2.0.11   , installed 2.0.11
                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
                          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                          Controller "js-controller": 5.0.12   , installed 5.0.12
                          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                          Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                          Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
                          Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                          Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                          Adapter    "web"          : 6.1.2    , installed 6.1.2
                          Adapter    "ws"           : 2.5.5    , installed 2.5.5
                          Objects and States
                          Objects:        9883
                          States:         9205
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://apt.grafana.com stable InRelease
                          Hit:6 https://repos.influxdata.com/debian stable InRelease
                          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       26915      2000/io.nuki.0
                          tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       15234      1458/io.hm-rpc.3
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13125      576/sshd: /usr/sbin
                          tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       17085      1315/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20213      1851/io.jarvis.0
                          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18734      1558/io.sonoff.0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        12257      561/mosquitto
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17070      1235/node-red
                          tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17212      1359/io.hm-rpc.2
                          tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       17960      1342/io.hm-rpc.1
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13138      538/cupsd
                          tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       23788      2139/io.simple-api.
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15479      654/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16497      654/iobroker.js-con
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13137      538/cupsd
                          tcp6       0      0 :::3000                 :::*                    LISTEN      117        16568      653/grafana
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        13159      548/influxd
                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25135      2161/io.socketio.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21930      1708/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14838      954/io.admin.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13127      576/sshd: /usr/sbin
                          tcp6       0      0 :::1883                 :::*                    LISTEN      116        12258      561/mosquitto
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14601      461/dhcpcd
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13146      617/cups-browsed
                          udp        0      0 0.0.0.0:49885           0.0.0.0:*                           108        13036      402/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13034      402/avahi-daemon: r
                          udp6       0      0 :::56039                :::*                                108        13037      402/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          13201      461/dhcpcd
                          udp6       0      0 :::5353                 :::*                                108        13035      402/avahi-daemon: r
                          2023-09-22 15:14:07.195  - info: admin.0 (954) ==> Connected system.user.admin from ::ffff:192.168.178.63
                          2023-09-22 15:14:09.020  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                          iob diag has finished.
                            Thomas Braun Most Active @teletapi last edited by
                            @teletapi
                            Das schaut gut aus.
                            Von welcher Version bist du denn gekommen? Der Auszug ist ja vermutlich von einem zweiten Durchlauf des Skripts.
                            • teletapi
                              auf dem Produktivsystem hab ich das script nur einmal laufen lassen, danach dann direkt sudo apt update && sudo apt upgrade danach war alles bereits sauber erledigt
                              Zum schluss nochmal dein script drüber laufen lassen und beide "Nothing to do" am Schluss
                              Ich bin von der node.js 18.17.1
                              Nachdem ich per sudo apt update && sudo apt upgrade nicht auf die 18.18.0 kam hab ich dein script mit einer sicherungs Festplatte am RPI getestet nachdem das wunderbar funktioniert hat hab ich das dann auf meinem produktiv System ebenfalls gemacht
                                @teletapi
                                Danke, das hilft!
                                • sissiwup
                                  sissiwup @Thomas Braun last edited by
                                  eine Suche über alle Dateien kann lange dauern ...
                                  Vlt. ist es hier sinnvoller eine positiv-Liste anzugeben? Ich habe mich beholfen mit einen weitern Ausschluss (/mnt)
                                  if [[ "$VERNODE" != "v$NODERECOM" ]] && [[ "$NODERECOM" == [[:digit:]]*.[[:digit:]]*.[[:digit:]]* ]];
                                  then
                                           echo -e "\nYou are running nodejs $VERNODE. Do you want to install recommended version $NODERECOM? ";
                                           echo -e "\nPress <y> to continue or any other key to quit";
                                           read -r -s -n 1 char;
                                           if
                                                   [[ "$char" = "y" ]] || [[ "$char" = "Y" ]]
                                           then
                                                   echo "Trying to fix your installation now. Please be patient."
                                                   # Finding nodesource.gpg or nodesource.key and deleting. Current key is pulled in later.
                                                   $SUDOX rm "$($SUDOX find / \( -path /proc -o -path /dev -o -path /sys -o -path /lost+found -o -path /mnt \) -prune -o -name nodesource.[gk]* -print)";
                                                   # Deleting nodesource.list Will be recreated later.
                                                   $SUDOX rm /etc/apt/sources.list.d/nodesource.lis*;
                                           else
                                                   echo "We are not fixing your installation. Exiting.";
                                           exit;
                                           fi;
                                  fi;
                                  Wer doch als root arbeiten möchte Zeile 82-86 löschen :
                                   77 if [ -f "$DOCKER" ];
                                   78 then
                                   79         echo "Fixing Docker is not supported, please update your Docker Container";
                                   80         unset LC_ALL;
                                   81         exit 1;
                                   82         elif [ "$(id -u)" -eq 0 ];
                                   83                  then
                                   84                          echo -e "This script must not be run as root! \nPlease use your standard user!"
                                   85         unset LC_ALL;
                                   86         exit 1;
                                   87 fi;
                                  Thomas Braun Homoran 3 Replies Last reply Reply Quote -1
                                    Thomas Braun Most Active @sissiwup last edited by
                                    @sissiwup sagte in iob node fix - Skript:
                                    Es gibt keinen Grund dafür.
                                      Homoran Global Moderator Administrators @sissiwup last edited by
                                      die gibt es nicht!
                                        Nein, beide Codepassagen sind genauso richtig und bedürfen keiner Anpassung.
                                        AlexAtHome 1 Reply Last reply Reply Quote 1
                                        • AlexAtHome
                                          AlexAtHome @Thomas Braun last edited by
                                          @thomas-braun Vielen Dank für das Script, es hat mir gerade das Leben sehr einfach gemacht (Upgrade von NodeJS 16.20.2 auf 18.18.0). Worked like a charm 🙂
                                          • ofri2607
                                            ofri2607 last edited by
                                            @Thomas-Braun
                                            auch von meiner Seite einen herzlichen Dank; war wirklich easy und problemlos.
                                            Beide Systeme 1x master und 1x slave (beides Raspi 4 mit bullseye) von v18.17.1 auf 18.18.0
                                            Den master hatte ich vor einiger Zeit entsprechend deinem HowTo gemacht, aber die notwendigen Änderungen (31.08.2023) noch nicht; hier script laufen lassen und danach sudo apt update && sudo apt upgrade.
                                            Der slave ist relativ neu frisch aufgesetzt, hier hatte das script ein downgrade auf 18.17.0 gemacht und anschließend selbstständig die 18.18.0 installiert.
                                            Ich denke, alles genauso, wie von dir geplant und gewollt.
                                            198
                                            38349
