    4. Echarts Presets verschwinden
      Bambulko last edited by Bambulko
      @homoran Welche Informationen fehlen denn noch?
      Irgendwie ist jetzt komplett der Wurm drin. Aus irgendeinem Grund startet der javascript adapter nicht mehr. Wenn ich es versuche, bleibt er rot. Verbunden mit Host ist rot, und Lebenszeichen ist rot. Im Log steht nichts hilfreiches, nur
      admin.0
      	2023-09-21 13:37:25.684	info	<== Disconnect system.user.admin from ::ffff:192.168.179.201 javascript
      Jetzt kamen mehr Meldungen:
      host.iobroker
      	2023-09-21 13:43:59.614	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2023-09-21 13:43:59.614	error	Caught by controller[0]: }
      host.iobroker
      	2023-09-21 13:43:59.614	error	Caught by controller[0]: ]
      host.iobroker
      	2023-09-21 13:43:59.614	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      	2023-09-21 13:43:59.614	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js',
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: requireStack: [
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: {
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iobroker
      	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:65:19)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker
      host.iobroker
      	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js:21:1)
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-09-21 13:43:59.611	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      host.iobroker
      	2023-09-21 13:43:59.611	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      host.iobroker
      	2023-09-21 13:43:59.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      	2023-09-21 13:43:59.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js
      host.iobroker
      	2023-09-21 13:43:59.611	error	Caught by controller[0]: Require stack:
      host.iobroker
      	2023-09-21 13:43:59.611	error	Caught by controller[0]: Error: Cannot find module '@iobroker/types'
      host.iobroker
      	2023-09-21 13:43:59.610	error	Caught by controller[0]: ^
      host.iobroker
      	2023-09-21 13:43:59.610	error	Caught by controller[0]: throw err;
      host.iobroker
      	2023-09-21 13:43:59.610	error	Caught by controller[0]: internal/modules/cj
      • DJMarc75
        DJMarc75 @Bambulko last edited by
        @bambulko sagte in Echarts Presets verschwinden:
        Node.js: v14.19.1
        steinalt !
        Das wird schon einen Grund haben:
        nachdem ich meinen admin.0 aus versehen mit https dichtgemacht habe, und dann einen admin.x erstellt habe
        was ist admin.x ?
        Bitte auch das von @Homoran schon erwähnte lesen und umsetzen:
        zusätzlich keine Beiträge ohne Markierung editieren.
          Homoran Global Moderator Administrators @Bambulko last edited by Homoran
          node/npm zu alt
          Ausgabe von iob diag in der Langfassung in code-tags posten bitte
            Bambulko @Homoran last edited by
            @homoran said in Echarts Presets verschwinden:
            iob diag
            ' diag' kennt mein iobroker nicht. sollte das' iob debug javascript.0' heissen?
            Das ergibt das hier:
            Debugger listening on ws://127.0.0.1:9229/3f305bff-7859-4bf4-bfdd-d9e831503a04
            For help, see: https://nodejs.org/en/docs/inspector
            internal/modules/cjs/loader.js:905
              throw err;
            Require stack:
              requireStack: [
              nein! aber auch da ist was krumm.
              dann ist das System steinalt und/oder total verbogen!
              iob stop
              iob fix
              iob start
              ...warten...
              iob diag
                Bambulko @Homoran last edited by Homoran
                iob stop ging nicht. Da kam "iobroker controller daemon is not running" Dann habe ich alle Instanzen von Hand gestoppt. Dann lief fix und diag. Hier ist der output:
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                Hardware Vendor : Intel(R) Client Systems
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v6.1.0
                Virtualization  : Docker
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 14:25:30 up 15 days, 15:53,  0 users,  load average: 4.20, 4.95, 5.89
                CPU threads: 2
                *** Time and Time Zones ***
                Thu Sep 21 12:25:30 UTC 2023
                Thu Sep 21 14:25:30 CEST 2023
                CEST +0200
                Etc/UTC
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:             15G        6.2G        2.5G        697M        6.4G        8.2G
                Swap:           2.0G        3.0M        2.0G
                Total:           17G        6.2G        4.6G
                        15133 M total memory
                         6242 M used memory
                         3832 M active memory
                         7506 M inactive memory
                         2535 M free memory
                         1116 M buffer memory
                         5238 M swap cache
                         2047 M total swap
                            3 M used swap
                         2044 M free swap
                *** FILESYSTEM ***
                Filesystem     Type     Size  Used Avail Use% Mounted on
                overlay        overlay  938G  143G  748G  16% /
                tmpfs          tmpfs     64M     0   64M   0% /dev
                tmpfs          tmpfs    7.4G     0  7.4G   0% /sys/fs/cgroup
                shm            tmpfs     64M     0   64M   0% /dev/shm
                /dev/sda2      ext4     938G  143G  748G  16% /opt/iobroker
                tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/asound
                tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/acpi
                tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/scsi
                tmpfs          tmpfs    7.4G     0  7.4G   0% /sys/firmware
                dmesg: read kernel buffer failed: Operation not permitted
                Show mounted filesystems (real ones only):
                TARGET           SOURCE        FSTYPE OPTIONS
                /opt/iobroker    /dev/sda2[/docker/iobroker]        ext4   rw,relatime,errors=remount-ro
                /etc/resolv.conf /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/resolv.conf] ext4   rw,relatime,errors=remount-ro
                /etc/hostname    /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/hostname]    ext4   rw,relatime,errors=remount-ro
                /etc/hosts       /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/hosts]       ext4   rw,relatime,errors=remount-ro
                /var:
                33M     /var/
                31M     /var/lib
                18M     /var/lib/apt/lists
                18M     /var/lib/apt
                13M     /var/lib/dpkg
                /opt/iobroker/backups:
                927M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                345M    /opt/iobroker/iobroker-data/
                294M    /opt/iobroker/iobroker-data/files
                88M     /opt/iobroker/iobroker-data/files/echarts.admin
                57M     /opt/iobroker/iobroker-data/files/echarts
                52M     /opt/iobroker/iobroker-data/files/javascript.admin
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v14.19.1
                /usr/bin/node           v14.19.1
                /usr/bin/npm            6.14.16
                /usr/bin/npx            6.14.16
                nodejs:
                  Installed: 14.19.1-deb-1nodesource1
                  Candidate: 14.21.3-deb-1nodesource1
                  Version table:
                     14.21.3-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                 *** 14.19.1-deb-1nodesource1 100
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                No problems detected
                npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                No configuration change needed.
                Multihost discovery server: disabled
                Discovery authentication:   enabled
                Persistent activation:      disabled
                Objects:                    jsonl on 127.0.0.1
                States:                     jsonl on 127.0.0.1
                Core adapters versions
                js-controller:  4.0.21
                admin:          6.3.5
                javascript:     7.1.4
                Adapters from github:   1
                Adapter State
                  system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.admin.4                  : admin                 : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                  system.adapter.deconz.0                 : deconz                : iobroker                                 - disabled, port: 8080
                  system.adapter.devices.0                : devices               : iobroker                                 - disabled
                  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                  system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                  system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
                  system.adapter.history.0                : history               : iobroker                                 - disabled
                  system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
                  system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
                  system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                  system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                  system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
                  system.adapter.linktap.0                : linktap               : iobroker                                 - disabled
                  system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                  system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
                  system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
                  system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                  system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                  system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
                  system.adapter.powerfox2.0              : powerfox2             : iobroker                                 - disabled
                  system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                  system.adapter.pushsafer.0              : pushsafer             : iobroker                                 - disabled
                  system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
                  system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
                  system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
                  system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
                  system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 - disabled
                  system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
                  system.adapter.sql.0                    : sql                   : iobroker                                 - disabled
                  system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                  system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
                  system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
                  system.adapter.vesync.0                 : vesync                : iobroker                                 - disabled
                  system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                  system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
                  system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
                Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                Adapter    "history"      : 2.2.6    , installed 2.2.6
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 4.0.21 [Updatable]
                Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
                Adapter    "linktap"      : 0.2.1    , installed 0.2.1
                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "parser"       : 1.3.2    , installed 1.3.2
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
                Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
                Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
                Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                Adapter    "vesync"       : 0.0.3    , installed 0.0.3
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
                Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.9.0  [Updatable]
                Objects and States
                Objects:        3566
                States:         2919
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                Reading package lists...
                Pending Updates: 106
                *** Listening Ports ***
                tcp        0      0 127.0.0.11:44049        0.0.0.0:*               LISTEN      0          43661      -
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       49897      -
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       49882      -
                udp        0      0 127.0.0.11:53377        0.0.0.0:*                           0          43660      -
                2023-09-21 14:21:15.344  - warn: deconz.0 (705912) get state error: DB closed
                2023-09-21 14:21:15.345  - info: host.iobroker stopInstance system.adapter.deconz.0 send kill signal
                2023-09-21 14:21:15.422  - info: host.iobroker instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-09-21 14:21:15.904  - info: host.iobroker "system.adapter.backitup.0" disabled
                2023-09-21 14:21:15.904  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                2023-09-21 14:21:15.912  - info: backitup.0 (705897) Got terminate signal TERMINATE_YOURSELF
                2023-09-21 14:21:15.917  - info: backitup.0 (705897) cleaned everything up...
                2023-09-21 14:21:15.920  - info: backitup.0 (705897) terminating
                2023-09-21 14:21:15.927  - info: backitup.0 (705897) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-09-21 14:21:15.999  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
                2023-09-21 14:21:16.520  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-09-21 14:22:09.381  - info: admin.0 (705862) Adapter is disabled => stop
                2023-09-21 14:22:09.382  - info: admin.0 (705862) terminating http server on port 8081
                2023-09-21 14:22:09.388  - info: host.iobroker "system.adapter.admin.0" disabled
                2023-09-21 14:22:09.397  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                2023-09-21 14:22:09.424  - info: admin.0 (705862) Got terminate signal TERMINATE_YOURSELF
                2023-09-21 14:22:09.428  - info: admin.0 (705862) terminating
                2023-09-21 14:22:09.429  - info: admin.0 (705862) Terminated (NO_ERROR): Without reason
                2023-09-21 14:22:09.458  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                2023-09-21 14:22:10.086  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                2023-09-21 14:24:40.235  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
                2023-09-21 14:24:40.253  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-09-21 14:24:40.258  - info: host.iobroker hostname: iobroker, node: v14.19.1
                2023-09-21 14:24:40.259  - info: host.iobroker ip addresses: 172.18.0.2
                2023-09-21 14:24:40.352  - error: host.iobroker-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                iob diag has finished.
                Press any key for a summary
                  klar, das geht bei
                  anders. müsstest du als Docker Nutzer aber wissen.
                  wie vermutet
                  Viel zu alt.
                  Das OS
                  verträgt auch mehr Fürsorge!
                  Dann dürfte sich auch noch einiges bei iob aktualisieren lassen.
                    Ich versuche den js-controller zu updaten, bekomme aber nur das:
                    Update js-controller from @4.0.21 to @5.0.12
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 6.14.16
                    Installing iobroker.js-controller@5.0.12... (System call)
                    Es kommt keine Fehlermeldung, aber wenn ich dann iobroker starte ist immer noch die alt Version installiert.
                      Thomas Braun Most Active @Bambulko last edited by Thomas Braun
                      Welches nodejs-Umfeld? Das scheint mir mit npm 6.14.16 zu alt zu sein.
                      Edit: nodejs@14 ist zu alt...
                      Update den Docker.
                        ich schrieb doch
                        @homoran sagte in Echarts Presets verschwinden:
                        Das OS
                        in dem Zustand geht das nicht
                          @homoran Ich hätte niemals den iobroker in docker installieren sollen. Das scheint alles nur unnötig kompliziert zu machen. Vielleicht sollte ich alles nochmal neu ohne docker aufsetzen. Aber kann man dann die Daten irgendwie retten?
                            wenn man sich damit nicht auskennt, kann das schon sein.
                            neu installieren und letztes Backup wieder herstellen
                              @homoran Heute ist so ein Tag, an dem nichts funktioniert. Ich habe jetzt versucht iobroker ohne Docker mit
                              sudo curl -sLf https://iobroker.net/install.sh | bash -
                              zu installieren. Es läuft auch durch, und ich bekomme die Meldung, dass iobroker erfolgreich installiert wurde. Aber bei loccalhost:8081 tut sich gar nichts. Und iobroker status gibt folgendes aus:
                               Cannot read system.config: null (OK when migrating or restoring)
                              Objects type: jsonl
                              States  type: jsonl
                                @bambulko
                                iob diag
                                sagt?
                                  zu installieren. E
                                  und sonst nichts?
                                  auf welchem System?
                                  Absolut sauber?
                                    Bambulko @Thomas Braun last edited by
                                    @thomas-braun Hmm, nodejs is NOT correctly installed, obwohl ich v18.18.0 habe.
                                                         v.2023-06-20
                                       Static hostname: Nuc
                                             Icon name: computer-desktop
                                               Chassis: desktop
                                            Machine ID: ad3458d0640e4781a50233d6b3388c72
                                               Boot ID: 0f842b6f9206477d90dac70147d5fedf
                                      Operating System: Ubuntu 20.04.6 LTS
                                                Kernel: Linux 5.15.0-84-generic
                                          Architecture: x86-64
                                    Installation:           native
                                    Kernel:                 x86_64
                                    Userland:               amd64
                                    Timezone:               Europe/Berlin (CEST, +0200)
                                    User-ID:                0
                                    X-Server:               true
                                    Boot Target:            graphical.target
                                    Pending OS-Updates:     2
                                    Error: Object "system.config" not found
                                    Pending iob updates:    0
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                            /usr/bin/node           v18.18.0
                                                            /usr/local/bin/npm              10.1.0
                                                            /usr/local/bin/npx              10.1.0
                                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                                    *** nodejs is NOT correctly installed ***
                                    MEMORY:
                                    Mem:            15G        4.2G        6.8G        509M        4.2G         10G
                                    Swap:          2.0G          0B        2.0G
                                    Total:          17G        4.2G        8.8G
                                    Active iob-Instances:   1
                                    List is empty
                                    ioBroker Core:          js-controller           4.0.24
                                                            admin                   6.3.5
                                    ioBroker Status:         Cannot read system.config: null (OK when migrating or restoring)
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                34
                                    States:                 27
                                    Size of iob-Database:
                                    16K     /opt/iobroker/iobroker-data/objects.jsonl
                                    16K     /opt/iobroker/iobroker-data/states.jsonl
                                    code_text
                                      @bambulko
                                      npm irgenwie und irgendwarum von Hand reingeklatscht.
                                      Und du kasperst als root herum.
                                      Und da rumpelt ein Desktop mit.
                                        @thomas-braun Da war eine alte Version von node installiert, und damit hat das curl.... nicht funktioniert.
                                          @bambulko
                                          nodejs hat mit curl nix zu tun.
                                          B Homoran 2 Replies Last reply Reply Quote 0
                                            Bambulko @Thomas Braun last edited by Bambulko
                                            @thomas-braun Ja, ich meine die Installation hat mit der alten Version nicht funktioniert. Aber jetzt kann ich das nicht reproduzieren, weil immer v18.18.0 installiert wird.
                                            2282
