    4. Mit conbee2 von deconz zu zigbee Adapter wechseln
      docsnyder7 @Guest last edited by
      @dp20eic
      gar nicht WLAN... bis heute über den Deconz Adapter rein für zigbee
      brauch der auch WLAN?
        docsnyder7 @Guest last edited by Homoran
        @dp20eic
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: evccpi
                 Icon name: computer
                Machine ID: 82971e2b59e04cc6823b9b47e5bb8656
                   Boot ID: e4ca9566265a45c2a18449101ce5c4b0
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         20:16:02 up 43 min,  3 users,  load average: 0.75, 0.64, 0.59
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=49.1'C
        volt=0.9360V
        *** Time and Time Zones ***
                       Local time: Thu 2023-09-21 20:16:02 CEST
                   Universal time: Thu 2023-09-21 18:16:02 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        docsn
        /home/docsn
        docsn adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        2.0G        4.6G         21M        1.3G        5.7G
        Swap:            99M          0B         99M
        Total:          7.9G        2.0G        4.7G
                 7811 M total memory
                 1960 M used memory
                 2458 M active memory
                  590 M inactive memory
                 4552 M free memory
                   78 M buffer memory
                 1219 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4      459G   12G  429G   3% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Thu Sep 21 19:32:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:98:BE:6A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=5f70fa40-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Thu Sep 21 19:32:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Sep 21 19:32:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Thu Sep 21 19:32:31 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.1G    /var/
        4.4G    /var/log
        4.2G    /var/log/journal/82971e2b59e04cc6823b9b47e5bb8656
        437M    /var/cache
        Archived and active journals take up 4.1G in the file system.
        /opt/iobroker/backups:
        187M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        313M    /opt/iobroker/iobroker-data/
        254M    /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        45M     /opt/iobroker/iobroker-data/files/devices.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        9.7M    /opt/iobroker/iobroker-data/objects.jsonl
        8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
          Homoran Global Moderator Administrators @docsnyder7 last edited by
          @docsnyder7 der ist noch nicht fertig
            A Former User @docsnyder7 last edited by
            @docsnyder7 sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
            Moin,
            da bin ich raus, ich kenne nur USB-Sticks oder Zigbee Sticks, die WLAN können, was man da für Deconz einstellen muss, kann ich nicht sagen, sorry.
            Serial settings
            Hier hast Du ein Gerät angegeben, das an einem USB Port hängt
            # Serial settings
            serial:
              # Location of CC2531 USB sniffer
              port: /dev/ttyACM0
            Dann passt das nicht, denn z2m versucht das Gerät zu erreichen.
            VG
            Bernd
            P.S.: Sorry, bin schon alt, hatte vorhin schon einmal in einem anderen Thread mit z2m zu tun, da ging es um ein WLAN fähigen Zigbee Stick.
              docsnyder7 @Homoran last edited by
                                   v.2023-06-20
                       Icon name: computer
                    Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               arm64
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1000
              X-Server:               true
              Boot Target:            graphical.target
              Pending OS-Updates:     5
              Pending iob updates:    3
              Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              Recommended versions are nodejs 18.x.y and npm 9.x.y
              MEMORY:
              Mem:            7.8G        1.9G        4.4G         21M        1.5G        5.7G
              Swap:            99M          0B         99M
              Total:          7.9G        1.9G        4.5G
              Active iob-Instances:   31
              Active repo(s): stable
              ioBroker Core:          js-controller           5.0.12
                                      admin                   6.10.1
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : evccpi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.web.0                    : web                   : evccpi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects:                8536
              States:                 6689
              Size of iob-Database:
              9.9M    /opt/iobroker/iobroker-data/objects.jsonl
              8.7M    /opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
                @dp20eic
                homeassistant: false
                frontend:
                  port: 8080
                mqtt:
                  base_topic: zigbee2mqtt
                  server: mqtt://localhost:1883
                serial:
                  adapter: deconz
                  port: /dev/ttyACM0
                advanced:
                  network_key:
                    - 141
                    - 93
                    - 59
                    - 154
                    - 208
                    - 213
                    - 231
                    - 68
                    - 150
                    - 73
                    - 156
                    - 197
                    - 4
                    - 79
                    - 188
                    - 50
                  pan_id: 32585
                  ext_pan_id:
                    - 79
                    - 241
                    - 73
                    - 17
                    - 19
                    - 123
                  @docsnyder7 in der full Ausgabe fehlt noch ne Menge
                  • Marc Berg
                    Marc Berg Most Active @docsnyder7 last edited by Marc Berg
                    Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    Die Fehlermeldung ist ja ziemlich eindeutig. Sicher, dass du da den korrekten Eintrag drin hast? Und sicher, dass alle anderen Adapter, etc. beendet sind?
                      docsnyder7 @Marc Berg last edited by docsnyder7
                      @marc-berg
                      docsn@evccpi:/opt/zigbee2mqtt $ ls -l /dev/serial/by-id
                      insgesamt 0
                      lrwxrwxrwx 1 root root 13 21. Sep 19:32 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2598659-if00 -> ../../ttyACM0
                      lrwxrwxrwx 1 root root 13 21. Sep 19:32 usb-FTDI_FT232R_USB_UART_A10MKTHB-if00-port0 -> ../../ttyUSB0
                      darf ich mich nach dem Reset überhaupt einloggen auf dem conbee
                      • Marc Berg
                        Du musst alles andere, was sonst noch auf den Stick zugreift, beenden.
                          @marc-berg
                          es greift nix mehr zu... die phoscon Oberfläche ist aus, hab nach dem Zurücksetzen noch nichtmal ein neues PW vergeben, DECONZ Adapter ist auch deinstalliert
                          zumindest bekomme ich jetzt die pan und soweiter mit Daten gefüllt
                          • Marc Berg
                            was füllst du wo?
                              @marc-berg
                              habe zu anfang keine Einträge unter pan_id usw bekommen, die kommen jetzt
                              in einigen Foren wird der Porteintrag abgeändert...
                              port: >-
                                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426882-if00
                              Ergebniss
                              > zigbee2mqtt@1.33.0 start
                              > node index.js
                              Zigbee2MQTT:info  2023-09-21 20:52:07: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-21.20-52-07' filename: log.txt
                              Zigbee2MQTT:info  2023-09-21 20:52:07: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
                              Zigbee2MQTT:info  2023-09-21 20:52:07: Starting zigbee-herdsman (0.18.5)
                              Zigbee2MQTT:error 2023-09-21 20:52:08: Error while starting zigbee-herdsman
                              Zigbee2MQTT:error 2023-09-21 20:52:08: Failed to start zigbee
                              Zigbee2MQTT:error 2023-09-21 20:52:08: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                              Zigbee2MQTT:error 2023-09-21 20:52:08: Exiting...
                              Zigbee2MQTT:error 2023-09-21 20:52:08: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426882-if00'
                                  at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:200:28)
                                  at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/dist/index.js:75:22)
                                  at /opt/zigbee2mqtt/node_modules/@serialport/stream/dist/index.js:111:18
                              • Marc Berg
                                vorhin hast du diese ID hier gezeigt:
                                da passt was nicht. DE2426882 oder DE2598659???
                                  @marc-berg
                                  die 2598659 ist meine ID... das Muster war die 2426882... nach der Vorgabe hab ich dann meine angepasst
                                  • Marc Berg
                                    Aber die Fehlermeldung lautet doch, dass er die DE2426882 nicht finden kann. Das ist doch dann die falsche.
                                      @marc-berg
                                      docsn@evccpi:/opt/zigbee2mqtt $ npm start
                                      > node index.js
                                      Zigbee2MQTT:info  2023-09-21 21:11:45: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-21.21-11-45' filename: log.txt
                                      Zigbee2MQTT:info  2023-09-21 21:11:45: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
                                      Zigbee2MQTT:info  2023-09-21 21:11:45: Starting zigbee-herdsman (0.18.5)
                                      Zigbee2MQTT:error 2023-09-21 21:11:46: Error while starting zigbee-herdsman
                                      Zigbee2MQTT:error 2023-09-21 21:11:46: Failed to start zigbee
                                      Zigbee2MQTT:error 2023-09-21 21:11:46: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                                      Zigbee2MQTT:error 2023-09-21 21:11:46: Exiting...
                                      Zigbee2MQTT:error 2023-09-21 21:11:46: Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2598659-if00'
                                      frontend:
                                        port: 8080
                                      mqtt:
                                      serial:
                                        adapter: deconz
                                        port: >-
                                      advanced:
                                        network_key:
                                          - 81
                                          - 57
                                          - 96
                                          - 198
                                          - 234
                                          - 212
                                          - 78
                                          - 33
                                          - 164
                                          - 186
                                          - 34
                                          - 234
                                          - 242
                                          - 153
                                          - 45
                                          - 192
                                        pan_id: 54324
                                        ext_pan_id:
                                          - 107
                                          - 4
                                          - 141
                                          - 94
                                          - 182
                                          - 189
                                          - 222
                                          - 1
                                      D ? 2 Replies Last reply Reply Quote 0
                                        docsnyder7 @docsnyder7 last edited by
                                        Könnte man das alles mit einem anderen Stick vereinfachen... zb Sonoff
                                        • Marc Berg
                                          Das funktioniert unabhängig vom verwendeten Stick. Ich lese aus der Fehlermeldung immer noch, dass der Stick schon in Benutzung ist. Könnte es sein, das du Z2M bereits als Service startest und zusätzlich über „npm start“?
                                            @marc-berg
                                            service ist nicht im autostart, zusätzlich händisch gestopt... Conbee zurückgesetzt.... reboot....
                                            NIX
                                            9264
