    4. Echarts Presets verschwinden
      Homoran Global Moderator Administrators @Bambulko last edited by
      @bambulko sagte in Echarts Presets verschwinden:
      sollte das' iob debug javascript.0' heissen?
      nein! aber auch da ist was krumm.
      ' diag' kennt mein iobroker nicht
      dann ist das System steinalt und/oder total verbogen!
      iob stop
      iob fix
      iob start
      ...warten...
      iob diag
        Bambulko @Homoran last edited by Homoran
        iob stop ging nicht. Da kam "iobroker controller daemon is not running" Dann habe ich alle Instanzen von Hand gestoppt. Dann lief fix und diag. Hier ist der output:
        Skript v.2023-06-20
        *** BASE SYSTEM ***
        Hardware Vendor : Intel(R) Client Systems
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v6.1.0
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         14:25:30 up 15 days, 15:53,  0 users,  load average: 4.20, 4.95, 5.89
        CPU threads: 2
        *** Time and Time Zones ***
        Thu Sep 21 12:25:30 UTC 2023
        Thu Sep 21 14:25:30 CEST 2023
        CEST +0200
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             15G        6.2G        2.5G        697M        6.4G        8.2G
        Swap:           2.0G        3.0M        2.0G
        Total:           17G        6.2G        4.6G
                15133 M total memory
                 6242 M used memory
                 3832 M active memory
                 7506 M inactive memory
                 2535 M free memory
                 1116 M buffer memory
                 5238 M swap cache
                 2047 M total swap
                    3 M used swap
                 2044 M free swap
        *** FILESYSTEM ***
        Filesystem     Type     Size  Used Avail Use% Mounted on
        overlay        overlay  938G  143G  748G  16% /
        tmpfs          tmpfs     64M     0   64M   0% /dev
        tmpfs          tmpfs    7.4G     0  7.4G   0% /sys/fs/cgroup
        shm            tmpfs     64M     0   64M   0% /dev/shm
        /dev/sda2      ext4     938G  143G  748G  16% /opt/iobroker
        tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/asound
        tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/acpi
        tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/scsi
        tmpfs          tmpfs    7.4G     0  7.4G   0% /sys/firmware
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems (real ones only):
        TARGET           SOURCE        FSTYPE OPTIONS
        /opt/iobroker    /dev/sda2[/docker/iobroker]        ext4   rw,relatime,errors=remount-ro
        /etc/resolv.conf /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/resolv.conf] ext4   rw,relatime,errors=remount-ro
        /etc/hostname    /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/hostname]    ext4   rw,relatime,errors=remount-ro
        /etc/hosts       /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/hosts]       ext4   rw,relatime,errors=remount-ro
        /var:
        33M     /var/
        31M     /var/lib
        18M     /var/lib/apt/lists
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        927M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        345M    /opt/iobroker/iobroker-data/
        294M    /opt/iobroker/iobroker-data/files
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        57M     /opt/iobroker/iobroker-data/files/echarts
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v14.19.1
        /usr/bin/node           v14.19.1
        /usr/bin/npm            6.14.16
        /usr/bin/npx            6.14.16
        nodejs:
          Installed: 14.19.1-deb-1nodesource1
          Candidate: 14.21.3-deb-1nodesource1
          Version table:
             14.21.3-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
         *** 14.19.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  4.0.21
        admin:          6.3.5
        javascript:     7.1.4
        Adapters from github:   1
        Adapter State
          system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.4                  : admin                 : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
          system.adapter.deconz.0                 : deconz                : iobroker                                 - disabled, port: 8080
          system.adapter.devices.0                : devices               : iobroker                                 - disabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
          system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
          system.adapter.history.0                : history               : iobroker                                 - disabled
          system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
          system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
          system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
          system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
          system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
          system.adapter.linktap.0                : linktap               : iobroker                                 - disabled
          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
          system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
          system.adapter.parser.0                 : parser                : iobroker                                 - disabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
          system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
          system.adapter.powerfox2.0              : powerfox2             : iobroker                                 - disabled
          system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
          system.adapter.pushsafer.0              : pushsafer             : iobroker                                 - disabled
          system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
          system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
          system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 - disabled
          system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
          system.adapter.sql.0                    : sql                   : iobroker                                 - disabled
          system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
          system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
          system.adapter.vesync.0                 : vesync                : iobroker                                 - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
          system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 4.0.21 [Updatable]
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
        Adapter    "linktap"      : 0.2.1    , installed 0.2.1
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "parser"       : 1.3.2    , installed 1.3.2
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
        Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
        Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "vesync"       : 0.0.3    , installed 0.0.3
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.9.0  [Updatable]
        Objects and States
        Objects:        3566
        States:         2919
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
        Reading package lists...
        Pending Updates: 106
        *** Listening Ports ***
        tcp        0      0 127.0.0.11:44049        0.0.0.0:*               LISTEN      0          43661      -
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       49897      -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       49882      -
        udp        0      0 127.0.0.11:53377        0.0.0.0:*                           0          43660      -
        2023-09-21 14:21:15.344  - warn: deconz.0 (705912) get state error: DB closed
        2023-09-21 14:21:15.345  - info: host.iobroker stopInstance system.adapter.deconz.0 send kill signal
        2023-09-21 14:21:15.422  - info: host.iobroker instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-21 14:21:15.904  - info: host.iobroker "system.adapter.backitup.0" disabled
        2023-09-21 14:21:15.904  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2023-09-21 14:21:15.912  - info: backitup.0 (705897) Got terminate signal TERMINATE_YOURSELF
        2023-09-21 14:21:15.917  - info: backitup.0 (705897) cleaned everything up...
        2023-09-21 14:21:15.920  - info: backitup.0 (705897) terminating
        2023-09-21 14:21:15.927  - info: backitup.0 (705897) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-09-21 14:21:15.999  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
        2023-09-21 14:21:16.520  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-21 14:22:09.381  - info: admin.0 (705862) Adapter is disabled => stop
        2023-09-21 14:22:09.382  - info: admin.0 (705862) terminating http server on port 8081
        2023-09-21 14:22:09.388  - info: host.iobroker "system.adapter.admin.0" disabled
        2023-09-21 14:22:09.397  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2023-09-21 14:22:09.424  - info: admin.0 (705862) Got terminate signal TERMINATE_YOURSELF
        2023-09-21 14:22:09.428  - info: admin.0 (705862) terminating
        2023-09-21 14:22:09.429  - info: admin.0 (705862) Terminated (NO_ERROR): Without reason
        2023-09-21 14:22:09.458  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
        2023-09-21 14:22:10.086  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2023-09-21 14:24:40.235  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
        2023-09-21 14:24:40.253  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-21 14:24:40.258  - info: host.iobroker hostname: iobroker, node: v14.19.1
        2023-09-21 14:24:40.259  - info: host.iobroker ip addresses: 172.18.0.2
        2023-09-21 14:24:40.352  - error: host.iobroker-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        iob diag has finished.
        Press any key for a summary
          klar, das geht bei
          anders. müsstest du als Docker Nutzer aber wissen.
          wie vermutet
          Viel zu alt.
          Das OS
          verträgt auch mehr Fürsorge!
          Dann dürfte sich auch noch einiges bei iob aktualisieren lassen.
            Ich versuche den js-controller zu updaten, bekomme aber nur das:
            Update js-controller from @4.0.21 to @5.0.12
            Stopped Objects DB
            Stopped States DB
            NPM version: 6.14.16
            Installing iobroker.js-controller@5.0.12... (System call)
            Es kommt keine Fehlermeldung, aber wenn ich dann iobroker starte ist immer noch die alt Version installiert.
              Thomas Braun Most Active @Bambulko last edited by Thomas Braun
              Welches nodejs-Umfeld? Das scheint mir mit npm 6.14.16 zu alt zu sein.
              Edit: nodejs@14 ist zu alt...
              Update den Docker.
                ich schrieb doch
                @homoran sagte in Echarts Presets verschwinden:
                Das OS
                in dem Zustand geht das nicht
                  @homoran Ich hätte niemals den iobroker in docker installieren sollen. Das scheint alles nur unnötig kompliziert zu machen. Vielleicht sollte ich alles nochmal neu ohne docker aufsetzen. Aber kann man dann die Daten irgendwie retten?
                    wenn man sich damit nicht auskennt, kann das schon sein.
                    neu installieren und letztes Backup wieder herstellen
                      @homoran Heute ist so ein Tag, an dem nichts funktioniert. Ich habe jetzt versucht iobroker ohne Docker mit
                      sudo curl -sLf https://iobroker.net/install.sh | bash -
                      zu installieren. Es läuft auch durch, und ich bekomme die Meldung, dass iobroker erfolgreich installiert wurde. Aber bei loccalhost:8081 tut sich gar nichts. Und iobroker status gibt folgendes aus:
                       Cannot read system.config: null (OK when migrating or restoring)
                      Objects type: jsonl
                      States  type: jsonl
                        @bambulko
                        iob diag
                        sagt?
                          zu installieren. E
                          und sonst nichts?
                          auf welchem System?
                          Absolut sauber?
                            Bambulko @Thomas Braun last edited by
                            @thomas-braun Hmm, nodejs is NOT correctly installed, obwohl ich v18.18.0 habe.
                                                 v.2023-06-20
                               Static hostname: Nuc
                                     Icon name: computer-desktop
                                       Chassis: desktop
                                    Machine ID: ad3458d0640e4781a50233d6b3388c72
                                       Boot ID: 0f842b6f9206477d90dac70147d5fedf
                              Operating System: Ubuntu 20.04.6 LTS
                                        Kernel: Linux 5.15.0-84-generic
                                  Architecture: x86-64
                            Installation:           native
                            Kernel:                 x86_64
                            Userland:               amd64
                            Timezone:               Europe/Berlin (CEST, +0200)
                            User-ID:                0
                            X-Server:               true
                            Boot Target:            graphical.target
                            Pending OS-Updates:     2
                            Error: Object "system.config" not found
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                    /usr/bin/node           v18.18.0
                                                    /usr/local/bin/npm              10.1.0
                                                    /usr/local/bin/npx              10.1.0
                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                            *** nodejs is NOT correctly installed ***
                            MEMORY:
                            Mem:            15G        4.2G        6.8G        509M        4.2G         10G
                            Swap:          2.0G          0B        2.0G
                            Total:          17G        4.2G        8.8G
                            Active iob-Instances:   1
                            List is empty
                            ioBroker Core:          js-controller           4.0.24
                                                    admin                   6.3.5
                            ioBroker Status:         Cannot read system.config: null (OK when migrating or restoring)
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                34
                            States:                 27
                            Size of iob-Database:
                            16K     /opt/iobroker/iobroker-data/objects.jsonl
                            16K     /opt/iobroker/iobroker-data/states.jsonl
                            code_text
                              @bambulko
                              npm irgenwie und irgendwarum von Hand reingeklatscht.
                              Und du kasperst als root herum.
                              Und da rumpelt ein Desktop mit.
                                @thomas-braun Da war eine alte Version von node installiert, und damit hat das curl.... nicht funktioniert.
                                  @bambulko
                                  nodejs hat mit curl nix zu tun.
                                  B Homoran 2 Replies Last reply Reply Quote 0
                                    Bambulko @Thomas Braun last edited by Bambulko
                                    @thomas-braun Ja, ich meine die Installation hat mit der alten Version nicht funktioniert. Aber jetzt kann ich das nicht reproduzieren, weil immer v18.18.0 installiert wird.
                                      @thomas-braun sagte in Echarts Presets verschwinden:
                                      @bambulko
                                      nicht so wörtlich nehmen!
                                      curl=installer!
                                      und wenn der ein node findet installiert er nicht v18
                                        @bambulko
                                        Dann lösch den Quark
                                        sudo rm /usr/local/bin/np*
                                        meld den root ab und schalt den Desktop aus.
                                          @thomas-braun Habe es geloescht, und habe jetzt wieder:
                                          npm ERR! code ENOTSUP
                                          npm ERR! notsup Unsupported engine for iobroker.inst@3.0.0: wanted: {"node":">=16.0.0"} (current: {"node":"10.19.0","npm":"6.14.4"})
                                          npm ERR! notsup Not compatible with your version of node/npm: iobroker.inst@3.0.0
                                          npm ERR! notsup Required: {"node":">=16.0.0"}
                                          npm ERR! notsup Actual:   {"npm":"6.14.4","node":"10.19.0"}
                                          Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                            Was zur Hölle treibst du da?
                                            2282
