    4. Echarts Presets verschwinden
      Thomas Braun Most Active @Bambulko last edited by
      @bambulko sagte in Echarts Presets verschwinden:
      per Hand geaendert habe.
      Per Hand heißt konkret was?
      Man fasst das nämlich nicht 'per Hand' an, man verwendet seinen Paketmanager. Der macht das nämlich richtig.
        @thomas-braun Disk morsch und nur noch RO ??
          Thomas Braun Most Active @Homoran last edited by Thomas Braun
          @homoran sagte in Echarts Presets verschwinden:
          Keine Ahnung was da fabriziert wurde. Hört sich aber alles falsch an.
            Bambulko @Thomas Braun last edited by
            ioBroker nodejs fixer 2023-09-20
            No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
            Your current setup is:
            /usr/bin/nodejs 	v10.19.0
            /usr/bin/node 		v10.19.0
            /usr/bin/npm 		6.14.4
            /usr/bin/npx 		6.14.4
            We found these nodejs versions available for installation:
            nodejs:
              Installed: 10.19.0~dfsg-3ubuntu1.1
              Candidate: 10.19.0~dfsg-3ubuntu1.1
              Version table:
             *** 10.19.0~dfsg-3ubuntu1.1 500
                    500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                    500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                    100 /var/lib/dpkg/status
                 10.19.0~dfsg-3ubuntu1 500
                    500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
            Nothing to do - Your installation is using the correct paths.
            You are running nodejs v10.19.0. Do you want to install recommended version v.18 ?
            Press <y> to continue or any other key to quit
            Trying to fix your installation now. Please be patient.
            find: '/run/user/1000/doc': Permission denied
            find: '/run/user/1000/gvfs': Permission denied
            rm: cannot remove '/var/lib/docker/overlay2/4f8b3a7f2e3d57afd657fc6acbbb6fdebf89b855621399d181d3222c414fc29b/diff/usr/share/keyrings/nodesource.gpg'$'\n''/var/lib/docker/overlay2/9b040315e5e2b23c9f7293e95a5435e2ccf7a47dd0bfbfebe945650f6ce108e0/merged/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
            Hit:2 https://phoscon.de/apt/deconz focal InRelease
            Hit:3 http://de.archive.ubuntu.com/ubuntu focal InRelease
            Hit:4 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
            Hit:5 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
            Reading package lists... Done
            N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://phoscon.de/apt/deconz focal InRelease' doesn't support architecture 'i386'
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
            Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
            Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
            Hit:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
            Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
            Hit:6 https://phoscon.de/apt/deconz focal InRelease
            Get:7 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
            Fetched 17.4 kB in 3s (6650 B/s)
            N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' doesn't support architecture 'i386'
            Installing the recommended nodejs version now!
            Exact recommended version unknown, installing a fallback!
            Building dependency tree
            The following packages were automatically installed and are no longer required:
              gir1.2-goa-1.0 gyp javascript-common libc-ares2 libfwupdplugin1 libjs-inherits libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libpython2-stdlib libpython2.7-minimal
              libpython2.7-stdlib libssl-dev libunity-gtk2-parser0 libunity-gtk3-parser0 libuv1-dev libxmlb1 node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex node-ansi-styles
              node-ansistyles node-aproba node-archy node-are-we-there-yet node-asap node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf
              node-bl node-bluebird node-boxen node-brace-expansion node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless node-chalk node-chownr
              node-ci-info node-cli-boxes node-cliui node-clone node-co node-color-convert node-color-name node-colors node-columnify node-combined-stream node-concat-map node-concat-stream
              node-config-chain node-configstore node-console-control-strings node-copy-concurrently node-core-util-is node-cross-spawn node-crypto-random-string node-cyclist node-dashdash
              node-debug node-decamelize node-decompress-response node-deep-extend node-defaults node-define-properties node-delayed-stream node-delegates node-detect-indent
              node-detect-newline node-dot-prop node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream node-err-code node-errno node-es6-promise
              node-escape-string-regexp node-execa node-extend node-extsprintf node-fast-deep-equal node-find-up node-flush-write-stream node-forever-agent node-form-data node-from2
              node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath node-function-bind node-gauge node-genfun node-get-caller-file node-get-stream node-getpass node-glob node-got
              node-graceful-fs node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode node-hosted-git-info node-http-signature
              node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight node-inherits node-ini node-invert-kv node-ip node-ip-regex node-is-npm node-is-obj node-is-object
              node-is-path-inside node-is-plain-obj node-is-retry-allowed node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn
              node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
              node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile node-lodash node-lodash-packages node-lowercase-keys node-lru-cache
              node-make-dir node-mem node-mime node-mime-types node-mimic-fn node-mimic-response node-minimatch node-minimist node-mississippi node-mkdirp node-move-concurrently node-ms
              node-mute-stream node-nopt node-normalize-package-data node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-number-is-nan node-oauth-sign node-object-assign
              node-once node-opener node-os-locale node-os-tmpdir node-osenv node-p-cancelable node-p-finally node-p-is-promise node-p-limit node-p-locate node-p-timeout node-package-json
              node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now node-pify node-prepend-http node-process-nextick-args
              node-promise-inflight node-promise-retry node-promzard node-proto-list node-prr node-pseudomap node-psl node-pump node-pumpify node-punycode node-qs node-qw node-rc node-read
              node-read-package-json node-readable-stream node-registry-auth-token node-registry-url node-request node-require-directory node-require-main-filename node-resolve
              node-resolve-from node-retry node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff node-set-blocking node-sha node-shebang-command node-shebang-regex
              node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
              node-stream-each node-stream-iterate node-stream-shift node-strict-uri-encode node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
              node-supports-color node-tar node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent node-tweetnacl node-typedarray
              node-typedarray-to-buffer node-uid-number node-unique-filename node-unique-string node-unpipe node-uri-js node-url-parse-lax node-url-to-options node-util-deprecate node-uuid
              node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which node-which-module node-wide-align node-widest-line node-wrap-ansi
              node-wrappy node-write-file-atomic node-xdg-basedir node-xtend node-y18n node-yallist node-yargs node-yargs-parser python-pkg-resources python2 python2-minimal python2.7
              python2.7-minimal unity-gtk-module-common
            Use 'sudo apt autoremove' to remove them.
            The following packages will be REMOVED:
              libnode-dev libnode64 node-gyp nodejs-doc npm
            The following packages will be upgraded:
              nodejs
            1 upgraded, 0 newly installed, 5 to remove and 1 not upgraded.
            Need to get 29.4 MB of archives.
            After this operation, 153 MB of additional disk space will be used.
            Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
            Fetched 29.4 MB in 4s (6746 kB/s)
            (Reading database ... 330244 files and directories currently installed.)
            Removing npm (6.14.4+ds-1ubuntu2) ...
            Removing node-gyp (6.1.0-3) ...
            Removing libnode-dev:amd64 (10.19.0~dfsg-3ubuntu1.1) ...
            Removing nodejs-doc (10.19.0~dfsg-3ubuntu1.1) ...
            dpkg: libnode64:amd64: dependency problems, but removing anyway as you requested:
             nodejs depends on libnode64 (= 10.19.0~dfsg-3ubuntu1.1).
            Removing libnode64:amd64 (10.19.0~dfsg-3ubuntu1.1) ...
            (Reading database ... 328802 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
            Unpacking nodejs (18.17.0-1nodesource1) over (10.19.0~dfsg-3ubuntu1.1) ...
            Setting up nodejs (18.17.0-1nodesource1) ...
            Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
            Processing triggers for man-db (2.9.1-1) ...
            Updating fallback to latest nodejs v18 release
            Calculating upgrade... Done
              nodejs ubuntu-advantage-tools
            2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 190 kB/29.7 MB of archives.
            After this operation, 920 kB of additional disk space will be used.
            Get:1 http://de.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 29.4~20.04 [190 kB]
            Fetched 190 kB in 0s (920 kB/s)
            Preconfiguring packages ...
            (Reading database ... 334483 files and directories currently installed.)
            Preparing to unpack .../ubuntu-advantage-tools_29.4~20.04_amd64.deb ...
            Unpacking ubuntu-advantage-tools (29.4~20.04) over (28.1~20.04) ...
            Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
            Detected old npm client, removing...
            Unpacking nodejs (18.18.0-1nodesource1) over (18.17.0-1nodesource1) ...
            Setting up nodejs (18.18.0-1nodesource1) ...
            Setting up ubuntu-advantage-tools (29.4~20.04) ...
            Installing new version of config file /etc/ubuntu-advantage/help_data.yaml ...
            We tried our best to fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
             Please refresh or restart your browser in a few moments.
            Homoran B 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @Bambulko last edited by
              i386
              kein amd64?
                Bambulko @Bambulko last edited by
                @bambulko Ok Fortschritt:
                		     v.2023-06-20
                   Static hostname: Nuc
                         Icon name: computer-desktop
                           Chassis: desktop
                        Machine ID: ad3458d0640e4781a50233d6b3388c72
                           Boot ID: 0f842b6f9206477d90dac70147d5fedf
                  Operating System: Ubuntu 20.04.6 LTS
                            Kernel: Linux 5.15.0-84-generic
                      Architecture: x86-64
                Installation: 		native
                Kernel: 		x86_64
                Userland: 		amd64
                Timezone: 		Europe/Berlin (CEST, +0200)
                User-ID: 		1000
                X-Server: 		true
                Boot Target: 		graphical.target
                Pending OS-Updates: 	0
                Error: Object "system.config" not found
                Pending iob updates: 	0
                Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
                			/usr/bin/node 		v18.18.0
                			/usr/bin/npm 		9.8.1
                			/usr/bin/npx 		9.8.1
                Recommended versions are nodejs 18.x.y and npm 9.x.y
                MEMORY:
                Mem:            15G        4.1G        5.6G        547M        5.4G         10G
                Swap:          2.0G          0B        2.0G
                Total:          17G        4.1G        7.6G
                Active iob-Instances: 	1
                List is empty
                 Cannot read system.config: null (OK when migrating or restoring)
                ioBroker Core: 		js-controller 		4.0.24
                			admin 			6.3.5
                ioBroker Status: 	 Cannot read system.config: null (OK when migrating or restoring)
                Objects type: jsonl
                States  type: jsonl
                Objects: 		33
                States: 		26
                Size of iob-Database:
                36K	/opt/iobroker/iobroker-data/objects.jsonl
                92K	/opt/iobroker/iobroker-data/states.jsonl
                nodejs scheint jetzt zu laufen, aber 'Cannot read system.config: null (OK when migrating or restoring)' kommt immer noch.
                  Irgendwas ganz schräges.
                  @Bambulko
                  Lass das Skript nun noch mal laufen.
                    Bambulko @Thomas Braun last edited by Bambulko
                      @bambulko
                      Da müssen zwei Zeilen mit 'Nothing to do' kommen.
                      Und schmeiß den ganzen anderen node-Krempel raus:
                      sudo apt autoremove
                        @thomas-braun Ich bekomme immer das hier, egal wie oft ich das skript laufen lasse.
                        You are running nodejs v18.18.0. Do you want to install recommended version v.18 ?
                        Das Skript installiert immer 18.17 ueber 18.18, und dann 18.18 ueber 18.17.
                          @bambulko
                          Ja, stimmt. Wenn keine recommended version im ioBroker gefunden werden kann dann kommt das so.
                          cd /opt/iobroker/
                          sudo -H -u iobroker npm install iobroker.js-controller
                            @thomas-braun said in Echarts Presets verschwinden:
                            cd /opt/iobroker/
                            up to date in 2s
                            49 packages are looking for funding
                              run `npm fund` for details
                              @bambulko
                              Bitte immer VOLLSTÄNDIGE Ein- wie Ausgaben posten.
                                Nuc:/opt/iobroker$ cd /opt/iobroker/
                                Nuc:/opt/iobroker$
                                Nuc:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                up to date in 2s
                                  @bambulko
                                  iob update
                                  iob status
                                    Nuc:/opt/iobroker$ iob update
                                    Nuc:/opt/iobroker$ iob status
                                    Objects type: jsonl
                                    States  type: jsonl
                                      @bambulko Hast du die unnützen node-* Pakete rausgeworfen?
                                        @thomas-braun Ja.
                                          @bambulko
                                          iob diag
                                          in der langen Version.
                                            Skript v.2023-06-20
                                            *** BASE SYSTEM ***
                                                       Chassis: desktop
                                            model name	: Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
                                            Docker          : false
                                            Virtualization  : none
                                            Kernel          : x86_64
                                            Userland        : amd64
                                            Systemuptime and Load:
                                             22:30:18 up  2:12,  2 users,  load average: 3.77, 3.16, 2.50
                                            CPU threads: 2
                                            *** Time and Time Zones ***
                                                           Local time: Thu 2023-09-21 22:30:18 CEST
                                                       Universal time: Thu 2023-09-21 20:30:18 UTC
                                                             RTC time: Thu 2023-09-21 20:30:18
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            *** User and Groups ***
                                            user
                                            /home/user
                                            user adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
                                            *** X-Server-Setup ***
                                            X-Server: 	true
                                            Desktop: 	mate
                                            Terminal: 	x11
                                            *** MEMORY ***
                                            Mem:            15G        4.3G        5.2G        577M        5.6G         10G
                                            Swap:          2.0G          0B        2.0G
                                            Total:          17G        4.3G        7.3G
                                                    15133 M total memory
                                                     4343 M used memory
                                                     2232 M active memory
                                                     5909 M inactive memory
                                                     5234 M free memory
                                                      936 M buffer memory
                                                     4619 M swap cache
                                                     2047 M total swap
                                                        0 M used swap
                                                     2047 M free swap
                                            *** FILESYSTEM ***
                                            udev           devtmpfs  7.4G     0  7.4G   0% /dev
                                            tmpfs          tmpfs     1.5G  1.8M  1.5G   1% /run
                                            /dev/sda2      ext4      938G  144G  747G  17% /
                                            tmpfs          tmpfs     7.4G     0  7.4G   0% /dev/shm
                                            tmpfs          tmpfs     7.4G     0  7.4G   0% /sys/fs/cgroup
                                            /dev/loop0     squashfs  128K  128K     0 100% /snap/bare/5
                                            /dev/loop1     squashfs   56M   56M     0 100% /snap/core18/2785
                                            /dev/loop2     squashfs   64M   64M     0 100% /snap/core20/2015
                                            /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
                                            /dev/loop3     squashfs   74M   74M     0 100% /snap/core22/864
                                            /dev/loop6     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                                            /dev/loop8     squashfs  486M  486M     0 100% /snap/gnome-42-2204/120
                                            /dev/loop7     squashfs   82M   82M     0 100% /snap/gtk-common-themes/1534
                                            /dev/loop9     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/140
                                            /dev/loop5     squashfs   74M   74M     0 100% /snap/core22/858
                                            /dev/loop12    squashfs  486M  486M     0 100% /snap/gnome-42-2204/126
                                            /dev/loop13    squashfs   95M   95M     0 100% /snap/noson/579
                                            /dev/loop16    squashfs   41M   41M     0 100% /snap/snapd/20092
                                            /dev/loop15    squashfs   46M   46M     0 100% /snap/snap-store/638
                                            /dev/loop14    squashfs   13M   13M     0 100% /snap/snap-store/959
                                            /dev/loop10    squashfs   56M   56M     0 100% /snap/core18/2790
                                            /dev/loop11    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                                            /dev/loop17    squashfs   41M   41M     0 100% /snap/snapd/19993
                                            /dev/sda1      vfat      511M  6.1M  505M   2% /boot/efi
                                            tmpfs          tmpfs     1.5G   56K  1.5G   1% /run/user/1000
                                            [Thu Sep 21 20:17:22 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                            [Thu Sep 21 20:17:23 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                                            Show mounted filesystems (real ones only):
                                            TARGET                         SOURCE      FSTYPE   OPTIONS
                                            /                              /dev/sda2   ext4     rw,relatime,errors=remount-ro
                                            |-/sys/kernel/tracing          tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
                                            |-/snap/bare/5                 /dev/loop0  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core18/2785            /dev/loop1  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core20/2015            /dev/loop2  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core20/1974            /dev/loop4  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core22/864             /dev/loop3  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/gtk-common-themes/1535 /dev/loop6  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/gnome-42-2204/120      /dev/loop8  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/gtk-common-themes/1534 /dev/loop7  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/gnome-3-38-2004/140    /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core22/858             /dev/loop5  squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/gnome-42-2204/126      /dev/loop12 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/noson/579              /dev/loop13 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/snapd/20092            /dev/loop16 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/snap-store/638         /dev/loop15 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/snap-store/959         /dev/loop14 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core18/2790            /dev/loop10 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/gnome-3-38-2004/143    /dev/loop11 squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/snapd/19993            /dev/loop17 squashfs ro,nodev,relatime,errors=continue
                                            `-/boot/efi                    /dev/sda1   vfat     rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                                            /var:
                                            12G	/var/
                                            6.8G	/var/lib
                                            4.1G	/var/log/journal/ad3458d0640e4781a50233d6b3388c72
                                            4.1G	/var/log
                                            Archived and active journals take up 4.0G in the file system.
                                            /opt/iobroker/backups:
                                            du: cannot access '/opt/iobroker/backups/': No such file or directory
                                            /opt/iobroker/iobroker-data:
                                            15M	/opt/iobroker/iobroker-data/files
                                            13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                            6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                            2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                            1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                            652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                            384K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                            *** NodeJS-Installation ***
                                            /usr/bin/npm 		9.8.1
                                            /usr/bin/npx 		9.8.1
                                            nodejs:
                                              Installed: 18.18.0-1nodesource1
                                              Candidate: 18.18.0-1nodesource1
                                              Version table:
                                             *** 18.18.0-1nodesource1 1001
                                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                                 18.17.1-1nodesource1 1001
                                                 18.17.0-1nodesource1 1001
                                                 18.16.1-1nodesource1 1001
                                                 18.16.0-1nodesource1 1001
                                                 18.15.0-1nodesource1 1001
                                                 18.14.2-1nodesource1 1001
                                                 18.14.1-1nodesource1 1001
                                                 18.14.0-1nodesource1 1001
                                                 18.13.0-1nodesource1 1001
                                                 18.12.0-1nodesource1 1001
                                                 18.11.0-1nodesource1 1001
                                                 18.10.0-1nodesource1 1001
                                                 18.9.1-1nodesource1 1001
                                                 18.9.0-1nodesource1 1001
                                                 18.8.0-1nodesource1 1001
                                                 18.7.0-1nodesource1 1001
                                                 18.6.0-1nodesource1 1001
                                                 18.5.0-1nodesource1 1001
                                                 18.4.0-1nodesource1 1001
                                                 18.3.0-1nodesource1 1001
                                                 18.2.0-1nodesource1 1001
                                                 18.1.0-1nodesource1 1001
                                                 18.0.0-1nodesource1 1001
                                            No problems detected
                                            Errors in npm tree: 0
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            No configuration change needed.
                                            Multihost discovery server: disabled
                                            Discovery authentication:   enabled
                                            Persistent activation:      disabled
                                            Objects:                    jsonl on 127.0.0.1
                                            States:                     jsonl on 127.0.0.1
                                            Core adapters versions
                                            js-controller: 	4.0.24
                                            admin: 		6.3.5
                                            javascript: 	"javascript" not found
                                            Adapters from github: 	0
                                            Adapter State
                                            + instance is alive
                                            ioBroker-Repositories
                                            List is empty
                                            Installed ioBroker-Instances
                                            Objects and States
                                            Objects: 	33
                                            States: 	26
                                            Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
                                            Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                                            Hit:5 https://phoscon.de/apt/deconz focal InRelease
                                            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            Pending Updates: 0
                                            *** Listening Ports ***
                                            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       57763      3637/deCONZ
                                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      130        37850      903/influxd
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38201      931/sshd: /usr/sbin
                                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19537      1/init
                                            tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          38914      743/cupsd
                                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      0          44737      2094/docker-proxy
                                            tcp        0      0 127.0.0.1:39365         0.0.0.0:*               LISTEN      0          39021      912/containerd
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       752286     111136/iobroker.js-
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       753258     111136/iobroker.js-
                                            tcp        0      0 0.0.0.0:8091            0.0.0.0:*               LISTEN      0          43886      1978/docker-proxy
                                            tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          43977      2027/docker-proxy
                                            tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      0          43927      2000/docker-proxy
                                            tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       57617      3637/deCONZ
                                            tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          43999      2048/docker-proxy
                                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        31177      641/systemd-resolve
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          38212      931/sshd: /usr/sbin
                                            tcp6       0      0 :::111                  :::*                    LISTEN      0          19541      1/init
                                            tcp6       0      0 :::631                  :::*                    LISTEN      0          38915      743/cupsd
                                            tcp6       0      0 :::1882                 :::*                    LISTEN      0          44740      2100/docker-proxy
                                            tcp6       0      0 :::8091                 :::*                    LISTEN      0          43892      1983/docker-proxy
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      0          43982      2033/docker-proxy
                                            tcp6       0      0 :::8083                 :::*                    LISTEN      0          44654      2011/docker-proxy
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      0          44004      2055/docker-proxy
                                            tcp6       0      0 :::8086                 :::*                    LISTEN      130        43023      903/influxd
                                            udp        0      0 0.0.0.0:60140           0.0.0.0:*                           115        36343      738/avahi-daemon: r
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        36341      738/avahi-daemon: r
                                            udp        0      0 0.0.0.0:8081            0.0.0.0:*                           0          45073      2071/docker-proxy
                                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        31176      641/systemd-resolve
                                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19538      1/init
                                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          38957      902/cups-browsed
                                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       57796      3637/deCONZ
                                            udp6       0      0 :::5353                 :::*                                115        36342      738/avahi-daemon: r
                                            udp6       0      0 :::55503                :::*                                115        36344      738/avahi-daemon: r
                                            udp6       0      0 :::8081                 :::*                                0          44733      2077/docker-proxy
                                            udp6       0      0 :::111                  :::*                                0          19544      1/init
                                            2023-09-21 22:14:39.108  - error: host.Nuc Cannot find view "system" for search "instance"
                                            2023-09-21 22:14:39.110  - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system"
                                            2023-09-21 22:14:39.111  - error: host.Nuc  _design/system missing - call node iobroker.js setup
                                            2023-09-21 22:14:39.111  - info: host.Nuc  no instances found
                                            2023-09-21 22:14:39.112  - info: host.Nuc no instances found
                                            2023-09-21 22:27:26.562  - info: host.Nuc received SIGTERM
                                            2023-09-21 22:27:26.577  - info: host.Nuc terminated
                                            2023-09-21 22:30:14.056  - info: host.Nuc iobroker.js-controller version 4.0.24 js-controller starting
                                            2023-09-21 22:30:14.059  - info: host.Nuc Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                            2023-09-21 22:30:14.060  - info: host.Nuc hostname: Nuc, node: v18.18.0
                                            2023-09-21 22:30:14.060  - info: host.Nuc ip addresses: 192.168.179.52 fe80::b7b5:ce0f:92af:db16 172.18.0.1 fe80::42:ccff:fe35:673b fe80::5c18:58ff:fe12:6738
                                            2023-09-21 22:30:14.191  - error: host.Nuc Cannot read system.config: null (OK when migrating or restoring)
                                            2023-09-21 22:30:14.242  - error: host.Nuc Cannot find view "system" for search "host"
                                            2023-09-21 22:30:14.432  - info: host.Nuc connected to Objects and States
                                            2023-09-21 22:30:14.464  - info: host.Nuc added notifications configuration of host
                                            2023-09-21 22:30:14.511  - error: host.Nuc Cannot find view "system" for search "instance"
                                            2023-09-21 22:30:14.512  - error: host.Nuc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                            2023-09-21 22:30:14.581  - info: host.Nuc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                            2023-09-21 22:30:14.595  - error: host.Nuc Cannot find view "system" for search "host"
                                            2023-09-21 22:30:14.630  - error: host.Nuc Cannot find view "system" for search "state"
                                            2023-09-21 22:30:14.631  - error: host.Nuc Cannot find view "system" for search "instance"
                                            2023-09-21 22:30:14.632  - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system"
                                            2023-09-21 22:30:14.632  - error: host.Nuc  _design/system missing - call node iobroker.js setup
                                            2023-09-21 22:30:14.637  - info: host.Nuc  no instances found
                                            2288
