    4. Echarts Presets verschwinden
      Bambulko @Thomas Braun last edited by
      ioBroker nodejs fixer 2023-09-20
      No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
      Your current setup is:
      /usr/bin/nodejs 	v10.19.0
      /usr/bin/node 		v10.19.0
      /usr/bin/npm 		6.14.4
      /usr/bin/npx 		6.14.4
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 10.19.0~dfsg-3ubuntu1.1
        Candidate: 10.19.0~dfsg-3ubuntu1.1
        Version table:
       *** 10.19.0~dfsg-3ubuntu1.1 500
              500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
              500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
              100 /var/lib/dpkg/status
           10.19.0~dfsg-3ubuntu1 500
              500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v10.19.0. Do you want to install recommended version v.18 ?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      find: '/run/user/1000/doc': Permission denied
      find: '/run/user/1000/gvfs': Permission denied
      rm: cannot remove '/var/lib/docker/overlay2/4f8b3a7f2e3d57afd657fc6acbbb6fdebf89b855621399d181d3222c414fc29b/diff/usr/share/keyrings/nodesource.gpg'$'\n''/var/lib/docker/overlay2/9b040315e5e2b23c9f7293e95a5435e2ccf7a47dd0bfbfebe945650f6ce108e0/merged/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
      Hit:2 https://phoscon.de/apt/deconz focal InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu focal InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
      Reading package lists... Done
      N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://phoscon.de/apt/deconz focal InRelease' doesn't support architecture 'i386'
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
      Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Hit:6 https://phoscon.de/apt/deconz focal InRelease
      Get:7 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
      Fetched 17.4 kB in 3s (6650 B/s)
      N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' doesn't support architecture 'i386'
      Installing the recommended nodejs version now!
      Exact recommended version unknown, installing a fallback!
      Building dependency tree
      The following packages were automatically installed and are no longer required:
        gir1.2-goa-1.0 gyp javascript-common libc-ares2 libfwupdplugin1 libjs-inherits libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libpython2-stdlib libpython2.7-minimal
        libpython2.7-stdlib libssl-dev libunity-gtk2-parser0 libunity-gtk3-parser0 libuv1-dev libxmlb1 node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex node-ansi-styles
        node-ansistyles node-aproba node-archy node-are-we-there-yet node-asap node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf
        node-bl node-bluebird node-boxen node-brace-expansion node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless node-chalk node-chownr
        node-ci-info node-cli-boxes node-cliui node-clone node-co node-color-convert node-color-name node-colors node-columnify node-combined-stream node-concat-map node-concat-stream
        node-config-chain node-configstore node-console-control-strings node-copy-concurrently node-core-util-is node-cross-spawn node-crypto-random-string node-cyclist node-dashdash
        node-debug node-decamelize node-decompress-response node-deep-extend node-defaults node-define-properties node-delayed-stream node-delegates node-detect-indent
        node-detect-newline node-dot-prop node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream node-err-code node-errno node-es6-promise
        node-escape-string-regexp node-execa node-extend node-extsprintf node-fast-deep-equal node-find-up node-flush-write-stream node-forever-agent node-form-data node-from2
        node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath node-function-bind node-gauge node-genfun node-get-caller-file node-get-stream node-getpass node-glob node-got
        node-graceful-fs node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode node-hosted-git-info node-http-signature
        node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight node-inherits node-ini node-invert-kv node-ip node-ip-regex node-is-npm node-is-obj node-is-object
        node-is-path-inside node-is-plain-obj node-is-retry-allowed node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn
        node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
        node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile node-lodash node-lodash-packages node-lowercase-keys node-lru-cache
        node-make-dir node-mem node-mime node-mime-types node-mimic-fn node-mimic-response node-minimatch node-minimist node-mississippi node-mkdirp node-move-concurrently node-ms
        node-mute-stream node-nopt node-normalize-package-data node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-number-is-nan node-oauth-sign node-object-assign
        node-once node-opener node-os-locale node-os-tmpdir node-osenv node-p-cancelable node-p-finally node-p-is-promise node-p-limit node-p-locate node-p-timeout node-package-json
        node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now node-pify node-prepend-http node-process-nextick-args
        node-promise-inflight node-promise-retry node-promzard node-proto-list node-prr node-pseudomap node-psl node-pump node-pumpify node-punycode node-qs node-qw node-rc node-read
        node-read-package-json node-readable-stream node-registry-auth-token node-registry-url node-request node-require-directory node-require-main-filename node-resolve
        node-resolve-from node-retry node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff node-set-blocking node-sha node-shebang-command node-shebang-regex
        node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
        node-stream-each node-stream-iterate node-stream-shift node-strict-uri-encode node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
        node-supports-color node-tar node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent node-tweetnacl node-typedarray
        node-typedarray-to-buffer node-uid-number node-unique-filename node-unique-string node-unpipe node-uri-js node-url-parse-lax node-url-to-options node-util-deprecate node-uuid
        node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which node-which-module node-wide-align node-widest-line node-wrap-ansi
        node-wrappy node-write-file-atomic node-xdg-basedir node-xtend node-y18n node-yallist node-yargs node-yargs-parser python-pkg-resources python2 python2-minimal python2.7
        python2.7-minimal unity-gtk-module-common
      Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
        libnode-dev libnode64 node-gyp nodejs-doc npm
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 5 to remove and 1 not upgraded.
      Need to get 29.4 MB of archives.
      After this operation, 153 MB of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
      Fetched 29.4 MB in 4s (6746 kB/s)
      (Reading database ... 330244 files and directories currently installed.)
      Removing npm (6.14.4+ds-1ubuntu2) ...
      Removing node-gyp (6.1.0-3) ...
      Removing libnode-dev:amd64 (10.19.0~dfsg-3ubuntu1.1) ...
      Removing nodejs-doc (10.19.0~dfsg-3ubuntu1.1) ...
      dpkg: libnode64:amd64: dependency problems, but removing anyway as you requested:
       nodejs depends on libnode64 (= 10.19.0~dfsg-3ubuntu1.1).
      Removing libnode64:amd64 (10.19.0~dfsg-3ubuntu1.1) ...
      (Reading database ... 328802 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.17.0-1nodesource1) over (10.19.0~dfsg-3ubuntu1.1) ...
      Setting up nodejs (18.17.0-1nodesource1) ...
      Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
      Processing triggers for man-db (2.9.1-1) ...
      Updating fallback to latest nodejs v18 release
      Calculating upgrade... Done
        nodejs ubuntu-advantage-tools
      2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 190 kB/29.7 MB of archives.
      After this operation, 920 kB of additional disk space will be used.
      Get:1 http://de.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 29.4~20.04 [190 kB]
      Fetched 190 kB in 0s (920 kB/s)
      Preconfiguring packages ...
      (Reading database ... 334483 files and directories currently installed.)
      Preparing to unpack .../ubuntu-advantage-tools_29.4~20.04_amd64.deb ...
      Unpacking ubuntu-advantage-tools (29.4~20.04) over (28.1~20.04) ...
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.18.0-1nodesource1) over (18.17.0-1nodesource1) ...
      Setting up nodejs (18.18.0-1nodesource1) ...
      Setting up ubuntu-advantage-tools (29.4~20.04) ...
      Installing new version of config file /etc/ubuntu-advantage/help_data.yaml ...
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      Homoran B 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Bambulko last edited by
        @bambulko sagte in Echarts Presets verschwinden:
        i386
        kein amd64?
          Bambulko @Bambulko last edited by
          @bambulko Ok Fortschritt:
          		     v.2023-06-20
             Static hostname: Nuc
                   Icon name: computer-desktop
                     Chassis: desktop
                  Machine ID: ad3458d0640e4781a50233d6b3388c72
                     Boot ID: 0f842b6f9206477d90dac70147d5fedf
            Operating System: Ubuntu 20.04.6 LTS
                      Kernel: Linux 5.15.0-84-generic
                Architecture: x86-64
          Installation: 		native
          Kernel: 		x86_64
          Userland: 		amd64
          Timezone: 		Europe/Berlin (CEST, +0200)
          User-ID: 		1000
          X-Server: 		true
          Boot Target: 		graphical.target
          Pending OS-Updates: 	0
          Error: Object "system.config" not found
          Pending iob updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
          			/usr/bin/node 		v18.18.0
          			/usr/bin/npm 		9.8.1
          			/usr/bin/npx 		9.8.1
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            15G        4.1G        5.6G        547M        5.4G         10G
          Swap:          2.0G          0B        2.0G
          Total:          17G        4.1G        7.6G
          Active iob-Instances: 	1
          List is empty
           Cannot read system.config: null (OK when migrating or restoring)
          ioBroker Core: 		js-controller 		4.0.24
          			admin 			6.3.5
          ioBroker Status: 	 Cannot read system.config: null (OK when migrating or restoring)
          Objects type: jsonl
          States  type: jsonl
          Objects: 		33
          States: 		26
          Size of iob-Database:
          36K	/opt/iobroker/iobroker-data/objects.jsonl
          92K	/opt/iobroker/iobroker-data/states.jsonl
          nodejs scheint jetzt zu laufen, aber 'Cannot read system.config: null (OK when migrating or restoring)' kommt immer noch.
            Irgendwas ganz schräges.
            @Bambulko
            Lass das Skript nun noch mal laufen.
              Bambulko @Thomas Braun last edited by Bambulko
                Thomas Braun Most Active @Bambulko last edited by
                @bambulko
                Da müssen zwei Zeilen mit 'Nothing to do' kommen.
                Und schmeiß den ganzen anderen node-Krempel raus:
                sudo apt autoremove
                  @thomas-braun Ich bekomme immer das hier, egal wie oft ich das skript laufen lasse.
                  You are running nodejs v18.18.0. Do you want to install recommended version v.18 ?
                  Das Skript installiert immer 18.17 ueber 18.18, und dann 18.18 ueber 18.17.
                    @bambulko
                    Ja, stimmt. Wenn keine recommended version im ioBroker gefunden werden kann dann kommt das so.
                    cd /opt/iobroker/
                    sudo -H -u iobroker npm install iobroker.js-controller
                      @thomas-braun said in Echarts Presets verschwinden:
                      cd /opt/iobroker/
                      up to date in 2s
                      49 packages are looking for funding
                        run `npm fund` for details
                        @bambulko
                        Bitte immer VOLLSTÄNDIGE Ein- wie Ausgaben posten.
                          Nuc:/opt/iobroker$ cd /opt/iobroker/
                          Nuc:/opt/iobroker$
                          Nuc:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                          up to date in 2s
                            @bambulko
                            iob update
                            iob status
                              Nuc:/opt/iobroker$ iob update
                              Nuc:/opt/iobroker$ iob status
                              Objects type: jsonl
                              States  type: jsonl
                                @bambulko Hast du die unnützen node-* Pakete rausgeworfen?
                                  @thomas-braun Ja.
                                    @bambulko
                                    iob diag
                                    in der langen Version.
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                                 Chassis: desktop
                                      model name	: Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Systemuptime and Load:
                                       22:30:18 up  2:12,  2 users,  load average: 3.77, 3.16, 2.50
                                      CPU threads: 2
                                      *** Time and Time Zones ***
                                                     Local time: Thu 2023-09-21 22:30:18 CEST
                                                 Universal time: Thu 2023-09-21 20:30:18 UTC
                                                       RTC time: Thu 2023-09-21 20:30:18
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** User and Groups ***
                                      user
                                      /home/user
                                      user adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
                                      *** X-Server-Setup ***
                                      X-Server: 	true
                                      Desktop: 	mate
                                      Terminal: 	x11
                                      *** MEMORY ***
                                      Mem:            15G        4.3G        5.2G        577M        5.6G         10G
                                      Swap:          2.0G          0B        2.0G
                                      Total:          17G        4.3G        7.3G
                                              15133 M total memory
                                               4343 M used memory
                                               2232 M active memory
                                               5909 M inactive memory
                                               5234 M free memory
                                                936 M buffer memory
                                               4619 M swap cache
                                               2047 M total swap
                                                  0 M used swap
                                               2047 M free swap
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  7.4G     0  7.4G   0% /dev
                                      tmpfs          tmpfs     1.5G  1.8M  1.5G   1% /run
                                      /dev/sda2      ext4      938G  144G  747G  17% /
                                      tmpfs          tmpfs     7.4G     0  7.4G   0% /dev/shm
                                      tmpfs          tmpfs     7.4G     0  7.4G   0% /sys/fs/cgroup
                                      /dev/loop0     squashfs  128K  128K     0 100% /snap/bare/5
                                      /dev/loop1     squashfs   56M   56M     0 100% /snap/core18/2785
                                      /dev/loop2     squashfs   64M   64M     0 100% /snap/core20/2015
                                      /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
                                      /dev/loop3     squashfs   74M   74M     0 100% /snap/core22/864
                                      /dev/loop6     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                                      /dev/loop8     squashfs  486M  486M     0 100% /snap/gnome-42-2204/120
                                      /dev/loop7     squashfs   82M   82M     0 100% /snap/gtk-common-themes/1534
                                      /dev/loop9     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/140
                                      /dev/loop5     squashfs   74M   74M     0 100% /snap/core22/858
                                      /dev/loop12    squashfs  486M  486M     0 100% /snap/gnome-42-2204/126
                                      /dev/loop13    squashfs   95M   95M     0 100% /snap/noson/579
                                      /dev/loop16    squashfs   41M   41M     0 100% /snap/snapd/20092
                                      /dev/loop15    squashfs   46M   46M     0 100% /snap/snap-store/638
                                      /dev/loop14    squashfs   13M   13M     0 100% /snap/snap-store/959
                                      /dev/loop10    squashfs   56M   56M     0 100% /snap/core18/2790
                                      /dev/loop11    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                                      /dev/loop17    squashfs   41M   41M     0 100% /snap/snapd/19993
                                      /dev/sda1      vfat      511M  6.1M  505M   2% /boot/efi
                                      tmpfs          tmpfs     1.5G   56K  1.5G   1% /run/user/1000
                                      [Thu Sep 21 20:17:22 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                      [Thu Sep 21 20:17:23 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                                      Show mounted filesystems (real ones only):
                                      TARGET                         SOURCE      FSTYPE   OPTIONS
                                      /                              /dev/sda2   ext4     rw,relatime,errors=remount-ro
                                      |-/sys/kernel/tracing          tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
                                      |-/snap/bare/5                 /dev/loop0  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/core18/2785            /dev/loop1  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/core20/2015            /dev/loop2  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/core20/1974            /dev/loop4  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/core22/864             /dev/loop3  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/gtk-common-themes/1535 /dev/loop6  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/gnome-42-2204/120      /dev/loop8  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/gtk-common-themes/1534 /dev/loop7  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/gnome-3-38-2004/140    /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/core22/858             /dev/loop5  squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/gnome-42-2204/126      /dev/loop12 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/noson/579              /dev/loop13 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/snapd/20092            /dev/loop16 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/snap-store/638         /dev/loop15 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/snap-store/959         /dev/loop14 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/core18/2790            /dev/loop10 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/gnome-3-38-2004/143    /dev/loop11 squashfs ro,nodev,relatime,errors=continue
                                      |-/snap/snapd/19993            /dev/loop17 squashfs ro,nodev,relatime,errors=continue
                                      `-/boot/efi                    /dev/sda1   vfat     rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                                      /var:
                                      12G	/var/
                                      6.8G	/var/lib
                                      4.1G	/var/log/journal/ad3458d0640e4781a50233d6b3388c72
                                      4.1G	/var/log
                                      Archived and active journals take up 4.0G in the file system.
                                      /opt/iobroker/backups:
                                      du: cannot access '/opt/iobroker/backups/': No such file or directory
                                      /opt/iobroker/iobroker-data:
                                      15M	/opt/iobroker/iobroker-data/files
                                      13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                      6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                      2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                      1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                      652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                      384K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm 		9.8.1
                                      /usr/bin/npx 		9.8.1
                                      nodejs:
                                        Installed: 18.18.0-1nodesource1
                                        Candidate: 18.18.0-1nodesource1
                                        Version table:
                                       *** 18.18.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      No configuration change needed.
                                      Multihost discovery server: disabled
                                      Discovery authentication:   enabled
                                      Persistent activation:      disabled
                                      Objects:                    jsonl on 127.0.0.1
                                      States:                     jsonl on 127.0.0.1
                                      Core adapters versions
                                      js-controller: 	4.0.24
                                      admin: 		6.3.5
                                      javascript: 	"javascript" not found
                                      Adapters from github: 	0
                                      Adapter State
                                      + instance is alive
                                      ioBroker-Repositories
                                      List is empty
                                      Installed ioBroker-Instances
                                      Objects and States
                                      Objects: 	33
                                      States: 	26
                                      Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
                                      Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                                      Hit:5 https://phoscon.de/apt/deconz focal InRelease
                                      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       57763      3637/deCONZ
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      130        37850      903/influxd
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38201      931/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19537      1/init
                                      tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          38914      743/cupsd
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      0          44737      2094/docker-proxy
                                      tcp        0      0 127.0.0.1:39365         0.0.0.0:*               LISTEN      0          39021      912/containerd
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       752286     111136/iobroker.js-
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       753258     111136/iobroker.js-
                                      tcp        0      0 0.0.0.0:8091            0.0.0.0:*               LISTEN      0          43886      1978/docker-proxy
                                      tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          43977      2027/docker-proxy
                                      tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      0          43927      2000/docker-proxy
                                      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       57617      3637/deCONZ
                                      tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          43999      2048/docker-proxy
                                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        31177      641/systemd-resolve
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          38212      931/sshd: /usr/sbin
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          19541      1/init
                                      tcp6       0      0 :::631                  :::*                    LISTEN      0          38915      743/cupsd
                                      tcp6       0      0 :::1882                 :::*                    LISTEN      0          44740      2100/docker-proxy
                                      tcp6       0      0 :::8091                 :::*                    LISTEN      0          43892      1983/docker-proxy
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      0          43982      2033/docker-proxy
                                      tcp6       0      0 :::8083                 :::*                    LISTEN      0          44654      2011/docker-proxy
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      0          44004      2055/docker-proxy
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      130        43023      903/influxd
                                      udp        0      0 0.0.0.0:60140           0.0.0.0:*                           115        36343      738/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        36341      738/avahi-daemon: r
                                      udp        0      0 0.0.0.0:8081            0.0.0.0:*                           0          45073      2071/docker-proxy
                                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        31176      641/systemd-resolve
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19538      1/init
                                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          38957      902/cups-browsed
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       57796      3637/deCONZ
                                      udp6       0      0 :::5353                 :::*                                115        36342      738/avahi-daemon: r
                                      udp6       0      0 :::55503                :::*                                115        36344      738/avahi-daemon: r
                                      udp6       0      0 :::8081                 :::*                                0          44733      2077/docker-proxy
                                      udp6       0      0 :::111                  :::*                                0          19544      1/init
                                      2023-09-21 22:14:39.108  - error: host.Nuc Cannot find view "system" for search "instance"
                                      2023-09-21 22:14:39.110  - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system"
                                      2023-09-21 22:14:39.111  - error: host.Nuc  _design/system missing - call node iobroker.js setup
                                      2023-09-21 22:14:39.111  - info: host.Nuc  no instances found
                                      2023-09-21 22:14:39.112  - info: host.Nuc no instances found
                                      2023-09-21 22:27:26.562  - info: host.Nuc received SIGTERM
                                      2023-09-21 22:27:26.577  - info: host.Nuc terminated
                                      2023-09-21 22:30:14.056  - info: host.Nuc iobroker.js-controller version 4.0.24 js-controller starting
                                      2023-09-21 22:30:14.059  - info: host.Nuc Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                      2023-09-21 22:30:14.060  - info: host.Nuc hostname: Nuc, node: v18.18.0
                                      2023-09-21 22:30:14.060  - info: host.Nuc ip addresses: 192.168.179.52 fe80::b7b5:ce0f:92af:db16 172.18.0.1 fe80::42:ccff:fe35:673b fe80::5c18:58ff:fe12:6738
                                      2023-09-21 22:30:14.191  - error: host.Nuc Cannot read system.config: null (OK when migrating or restoring)
                                      2023-09-21 22:30:14.242  - error: host.Nuc Cannot find view "system" for search "host"
                                      2023-09-21 22:30:14.432  - info: host.Nuc connected to Objects and States
                                      2023-09-21 22:30:14.464  - info: host.Nuc added notifications configuration of host
                                      2023-09-21 22:30:14.511  - error: host.Nuc Cannot find view "system" for search "instance"
                                      2023-09-21 22:30:14.512  - error: host.Nuc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                      2023-09-21 22:30:14.581  - info: host.Nuc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                      2023-09-21 22:30:14.595  - error: host.Nuc Cannot find view "system" for search "host"
                                      2023-09-21 22:30:14.630  - error: host.Nuc Cannot find view "system" for search "state"
                                      2023-09-21 22:30:14.631  - error: host.Nuc Cannot find view "system" for search "instance"
                                      2023-09-21 22:30:14.632  - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system"
                                      2023-09-21 22:30:14.632  - error: host.Nuc  _design/system missing - call node iobroker.js setup
                                      2023-09-21 22:30:14.637  - info: host.Nuc  no instances found
                                        Thomas Braun Most Active @Bambulko last edited by Thomas Braun
                                        > X-Server: 	true
                                        > Desktop: 	mate
                                        > Terminal: 	x11
                                        schalt den Desktop-Quark und alles was damit zusammen angeschleppt wird aus. Server immer ohne GUI.
                                        sudo systemctl set-default multi-user.target
                                        sudo systemctl isolate multi-user.target
                                        Dann lass den
                                        iob fix
                                        laufen.
                                          @thomas-braun Vielen Dank erst einmal bis hierher. Ich muss morgen leider frueh raus und jetzt erst mal ins Bett. Keine Ahnung was ich da so verbockt habe, dass nicht einmal die Installation klappt.
                                          2318
