Echarts Presets verschwinden
Ja, stimmt. Wenn keine recommended version im ioBroker gefunden werden kann dann kommt das so.
cd /opt/iobroker/ sudo -H -u iobroker npm install iobroker.js-controller
@thomas-braun said in Echarts Presets verschwinden:
cd /opt/iobroker/
up to date in 2s 49 packages are looking for funding run `npm fund` for details
Bitte immer VOLLSTÄNDIGE Ein- wie Ausgaben posten.
Nuc:/opt/iobroker$ cd /opt/iobroker/ Nuc:/opt/iobroker$ Nuc:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller up to date in 2s 49 packages are looking for funding run `npm fund` for details
iob update iob status
Nuc:/opt/iobroker$ iob update Cannot read system.config: null (OK when migrating or restoring) Error: Object "system.config" not found Nuc:/opt/iobroker$ iob status Cannot read system.config: null (OK when migrating or restoring) iobroker is running on this host. Objects type: jsonl States type: jsonl
@bambulko Hast du die unnützen node-* Pakete rausgeworfen?
@thomas-braun Ja.
Skript v.2023-06-20 *** BASE SYSTEM *** Static hostname: Nuc Icon name: computer-desktop Chassis: desktop Machine ID: ad3458d0640e4781a50233d6b3388c72 Boot ID: 0f842b6f9206477d90dac70147d5fedf Operating System: Ubuntu 20.04.6 LTS Kernel: Linux 5.15.0-84-generic Architecture: x86-64 model name : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz Docker : false Virtualization : none Kernel : x86_64 Userland : amd64 Systemuptime and Load: 22:30:18 up 2:12, 2 users, load average: 3.77, 3.16, 2.50 CPU threads: 2 *** Time and Time Zones *** Local time: Thu 2023-09-21 22:30:18 CEST Universal time: Thu 2023-09-21 20:30:18 UTC RTC time: Thu 2023-09-21 20:30:18 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** user /home/user user adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare iobroker *** X-Server-Setup *** X-Server: true Desktop: mate Terminal: x11 Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 15G 4.3G 5.2G 577M 5.6G 10G Swap: 2.0G 0B 2.0G Total: 17G 4.3G 7.3G 15133 M total memory 4343 M used memory 2232 M active memory 5909 M inactive memory 5234 M free memory 936 M buffer memory 4619 M swap cache 2047 M total swap 0 M used swap 2047 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 7.4G 0 7.4G 0% /dev tmpfs tmpfs 1.5G 1.8M 1.5G 1% /run /dev/sda2 ext4 938G 144G 747G 17% / tmpfs tmpfs 7.4G 0 7.4G 0% /dev/shm tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 7.4G 0 7.4G 0% /sys/fs/cgroup /dev/loop0 squashfs 128K 128K 0 100% /snap/bare/5 /dev/loop1 squashfs 56M 56M 0 100% /snap/core18/2785 /dev/loop2 squashfs 64M 64M 0 100% /snap/core20/2015 /dev/loop4 squashfs 64M 64M 0 100% /snap/core20/1974 /dev/loop3 squashfs 74M 74M 0 100% /snap/core22/864 /dev/loop6 squashfs 92M 92M 0 100% /snap/gtk-common-themes/1535 /dev/loop8 squashfs 486M 486M 0 100% /snap/gnome-42-2204/120 /dev/loop7 squashfs 82M 82M 0 100% /snap/gtk-common-themes/1534 /dev/loop9 squashfs 350M 350M 0 100% /snap/gnome-3-38-2004/140 /dev/loop5 squashfs 74M 74M 0 100% /snap/core22/858 /dev/loop12 squashfs 486M 486M 0 100% /snap/gnome-42-2204/126 /dev/loop13 squashfs 95M 95M 0 100% /snap/noson/579 /dev/loop16 squashfs 41M 41M 0 100% /snap/snapd/20092 /dev/loop15 squashfs 46M 46M 0 100% /snap/snap-store/638 /dev/loop14 squashfs 13M 13M 0 100% /snap/snap-store/959 /dev/loop10 squashfs 56M 56M 0 100% /snap/core18/2790 /dev/loop11 squashfs 350M 350M 0 100% /snap/gnome-3-38-2004/143 /dev/loop17 squashfs 41M 41M 0 100% /snap/snapd/19993 /dev/sda1 vfat 511M 6.1M 505M 2% /boot/efi tmpfs tmpfs 1.5G 56K 1.5G 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu Sep 21 20:17:22 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Thu Sep 21 20:17:23 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,relatime,errors=remount-ro |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime |-/snap/bare/5 /dev/loop0 squashfs ro,nodev,relatime,errors=continue |-/snap/core18/2785 /dev/loop1 squashfs ro,nodev,relatime,errors=continue |-/snap/core20/2015 /dev/loop2 squashfs ro,nodev,relatime,errors=continue |-/snap/core20/1974 /dev/loop4 squashfs ro,nodev,relatime,errors=continue |-/snap/core22/864 /dev/loop3 squashfs ro,nodev,relatime,errors=continue |-/snap/gtk-common-themes/1535 /dev/loop6 squashfs ro,nodev,relatime,errors=continue |-/snap/gnome-42-2204/120 /dev/loop8 squashfs ro,nodev,relatime,errors=continue |-/snap/gtk-common-themes/1534 /dev/loop7 squashfs ro,nodev,relatime,errors=continue |-/snap/gnome-3-38-2004/140 /dev/loop9 squashfs ro,nodev,relatime,errors=continue |-/snap/core22/858 /dev/loop5 squashfs ro,nodev,relatime,errors=continue |-/snap/gnome-42-2204/126 /dev/loop12 squashfs ro,nodev,relatime,errors=continue |-/snap/noson/579 /dev/loop13 squashfs ro,nodev,relatime,errors=continue |-/snap/snapd/20092 /dev/loop16 squashfs ro,nodev,relatime,errors=continue |-/snap/snap-store/638 /dev/loop15 squashfs ro,nodev,relatime,errors=continue |-/snap/snap-store/959 /dev/loop14 squashfs ro,nodev,relatime,errors=continue |-/snap/core18/2790 /dev/loop10 squashfs ro,nodev,relatime,errors=continue |-/snap/gnome-3-38-2004/143 /dev/loop11 squashfs ro,nodev,relatime,errors=continue |-/snap/snapd/19993 /dev/loop17 squashfs ro,nodev,relatime,errors=continue `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 12G /var/ 6.8G /var/lib 4.1G /var/log/journal/ad3458d0640e4781a50233d6b3388c72 4.1G /var/log/journal 4.1G /var/log Archived and active journals take up 4.0G in the file system. /opt/iobroker/backups: du: cannot access '/opt/iobroker/backups/': No such file or directory /opt/iobroker/iobroker-data: 15M /opt/iobroker/iobroker-data/files 15M /opt/iobroker/iobroker-data/ 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static 13M /opt/iobroker/iobroker-data/files/admin.admin/custom The five largest files in iobroker-data are: 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js 1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map 652K /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map 384K /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js *** NodeJS-Installation *** /usr/bin/nodejs v18.18.0 /usr/bin/node v18.18.0 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 nodejs: Installed: 18.18.0-1nodesource1 Candidate: 18.18.0-1nodesource1 Version table: *** 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 10.19.0~dfsg-3ubuntu1.1 500 500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages 10.19.0~dfsg-3ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: 0 *** ioBroker-Installation *** ioBroker Status Cannot read system.config: null (OK when migrating or restoring) iobroker is running on this host. Objects type: jsonl States type: jsonl Cannot read system.config: null (OK when migrating or restoring) No configuration change needed. Multihost discovery server: disabled Discovery authentication: enabled Persistent activation: disabled Objects: jsonl on 127.0.0.1 States: jsonl on 127.0.0.1 Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: "javascript" not found Adapters from github: 0 Adapter State Cannot read system.config: null (OK when migrating or restoring) + instance is alive Enabled adapters with bindings ioBroker-Repositories Cannot read system.config: null (OK when migrating or restoring) List is empty Installed ioBroker-Instances Cannot read system.config: null (OK when migrating or restoring) Error: Object "system.config" not found Objects and States Please stand by - This may take a while Objects: 33 States: 26 *** OS-Repositories and Updates *** Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease Hit:5 https://phoscon.de/apt/deconz focal InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 57763 3637/deCONZ tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 130 37850 903/influxd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 38201 931/sshd: /usr/sbin tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 19537 1/init tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 0 38914 743/cupsd tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 0 44737 2094/docker-proxy tcp 0 0 127.0.0.1:39365 0.0.0.0:* LISTEN 0 39021 912/containerd tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 752286 111136/iobroker.js- tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 753258 111136/iobroker.js- tcp 0 0 0.0.0.0:8091 0.0.0.0:* LISTEN 0 43886 1978/docker-proxy tcp 0 0 0.0.0.0:8082 0.0.0.0:* LISTEN 0 43977 2027/docker-proxy tcp 0 0 0.0.0.0:8083 0.0.0.0:* LISTEN 0 43927 2000/docker-proxy tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 1000 57617 3637/deCONZ tcp 0 0 0.0.0.0:8081 0.0.0.0:* LISTEN 0 43999 2048/docker-proxy tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 101 31177 641/systemd-resolve tcp6 0 0 :::22 :::* LISTEN 0 38212 931/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 19541 1/init tcp6 0 0 :::631 :::* LISTEN 0 38915 743/cupsd tcp6 0 0 :::1882 :::* LISTEN 0 44740 2100/docker-proxy tcp6 0 0 :::8091 :::* LISTEN 0 43892 1983/docker-proxy tcp6 0 0 :::8082 :::* LISTEN 0 43982 2033/docker-proxy tcp6 0 0 :::8083 :::* LISTEN 0 44654 2011/docker-proxy tcp6 0 0 :::8081 :::* LISTEN 0 44004 2055/docker-proxy tcp6 0 0 :::8086 :::* LISTEN 130 43023 903/influxd udp 0 0 0.0.0.0:60140 0.0.0.0:* 115 36343 738/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 115 36341 738/avahi-daemon: r udp 0 0 0.0.0.0:8081 0.0.0.0:* 0 45073 2071/docker-proxy udp 0 0 127.0.0.53:53 0.0.0.0:* 101 31176 641/systemd-resolve udp 0 0 0.0.0.0:111 0.0.0.0:* 0 19538 1/init udp 0 0 0.0.0.0:631 0.0.0.0:* 0 38957 902/cups-browsed udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 57796 3637/deCONZ udp6 0 0 :::5353 :::* 115 36342 738/avahi-daemon: r udp6 0 0 :::55503 :::* 115 36344 738/avahi-daemon: r udp6 0 0 :::8081 :::* 0 44733 2077/docker-proxy udp6 0 0 :::111 :::* 0 19544 1/init *** Log File - Last 25 Lines *** 2023-09-21 22:14:39.108 - error: host.Nuc Cannot find view "system" for search "instance" 2023-09-21 22:14:39.110 - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system" 2023-09-21 22:14:39.111 - error: host.Nuc _design/system missing - call node iobroker.js setup 2023-09-21 22:14:39.111 - info: host.Nuc no instances found 2023-09-21 22:14:39.112 - info: host.Nuc no instances found 2023-09-21 22:27:26.562 - info: host.Nuc received SIGTERM 2023-09-21 22:27:26.577 - info: host.Nuc terminated 2023-09-21 22:30:14.056 - info: host.Nuc iobroker.js-controller version 4.0.24 js-controller starting 2023-09-21 22:30:14.059 - info: host.Nuc Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker 2023-09-21 22:30:14.060 - info: host.Nuc hostname: Nuc, node: v18.18.0 2023-09-21 22:30:14.060 - info: host.Nuc ip addresses: 192.168.179.52 fe80::b7b5:ce0f:92af:db16 172.18.0.1 fe80::42:ccff:fe35:673b fe80::5c18:58ff:fe12:6738 2023-09-21 22:30:14.191 - error: host.Nuc Cannot read system.config: null (OK when migrating or restoring) 2023-09-21 22:30:14.242 - error: host.Nuc Cannot find view "system" for search "host" 2023-09-21 22:30:14.432 - info: host.Nuc connected to Objects and States 2023-09-21 22:30:14.464 - info: host.Nuc added notifications configuration of host 2023-09-21 22:30:14.511 - error: host.Nuc Cannot find view "system" for search "instance" 2023-09-21 22:30:14.512 - error: host.Nuc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system" 2023-09-21 22:30:14.581 - info: host.Nuc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system 2023-09-21 22:30:14.595 - error: host.Nuc Cannot find view "system" for search "host" 2023-09-21 22:30:14.630 - error: host.Nuc Cannot find view "system" for search "state" 2023-09-21 22:30:14.631 - error: host.Nuc Cannot find view "system" for search "instance" 2023-09-21 22:30:14.632 - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system" 2023-09-21 22:30:14.632 - error: host.Nuc _design/system missing - call node iobroker.js setup 2023-09-21 22:30:14.637 - info: host.Nuc no instances found 2023-09-21 22:30:14.637 - info: host.Nuc no instances found
@bambulko sagte in Echarts Presets verschwinden:
> X-Server: true > Desktop: mate > Terminal: x11 > Boot Target: graphical.target
schalt den Desktop-Quark und alles was damit zusammen angeschleppt wird aus. Server immer ohne GUI.
sudo systemctl set-default multi-user.target sudo systemctl isolate multi-user.target
Dann lass den
iob fix
laufen.
@thomas-braun Vielen Dank erst einmal bis hierher. Ich muss morgen leider frueh raus und jetzt erst mal ins Bett. Keine Ahnung was ich da so verbockt habe, dass nicht einmal die Installation klappt.
