    4. Mit conbee2 von deconz zu zigbee Adapter wechseln
      docsnyder7 @Marc Berg last edited by docsnyder7
      @marc-berg
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: evccpi
               Icon name: computer
              Machine ID: 82971e2b59e04cc6823b9b47e5bb8656
                 Boot ID: c0d30cedbf3f4ad28aa5deafb466f56d
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       07:53:17 up  1:02,  3 users,  load average: 0.58, 0.78, 0.61
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=50.1'C
      volt=0.9360V
      *** Time and Time Zones ***
                     Local time: Fri 2023-09-22 07:53:17 CEST
                 Universal time: Fri 2023-09-22 05:53:17 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      docsn
      /home/docsn
      docsn adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        1.9G        4.8G         21M        1.1G        5.7G
      Swap:            99M          0B         99M
      Total:          7.9G        1.9G        4.9G
               7811 M total memory
               1919 M used memory
               2346 M active memory
                497 M inactive memory
               4765 M free memory
                 85 M buffer memory
               1040 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      459G   12G  429G   3% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
      [Fri Sep 22 06:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:98:BE:6A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=5f70fa40-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Fri Sep 22 06:50:48 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Sep 22 06:50:48 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Sep 22 06:50:50 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.2G    /var/
      4.4G    /var/log
      4.1G    /var/log/journal/82971e2b59e04cc6823b9b47e5bb8656
      539M    /var/cache
      Archived and active journals take up 4.0G in the file system.
      /opt/iobroker/backups:
      196M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      319M    /opt/iobroker/iobroker-data/
      254M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      45M     /opt/iobroker/iobroker-data/files/devices.admin/static
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : evccpi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : evccpi                                   -  enabled
      + system.adapter.backitup.0               : backitup              : evccpi                                   -  enabled
      + system.adapter.cloud.0                  : cloud                 : evccpi                                   -  enabled
        system.adapter.daswetter.0              : daswetter             : evccpi                                   -  enabled
        system.adapter.devices.0                : devices               : evccpi                                   -  enabled
      + system.adapter.discovery.0              : discovery             : evccpi                                   -  enabled
      + system.adapter.email.0                  : email                 : evccpi                                   -  enabled
      + system.adapter.evcc.0                   : evcc                  : evccpi                                   -  enabled, port: 7070
      + system.adapter.fritzdect.0              : fritzdect             : evccpi                                   -  enabled
      + system.adapter.geofency.0               : geofency              : evccpi                                   -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.history.0                : history               : evccpi                                   -  enabled
      + system.adapter.homee.0                  : homee                 : evccpi                                   -  enabled
        system.adapter.ical.0                   : ical                  : evccpi                                   -  enabled
        system.adapter.ical.1                   : ical                  : evccpi                                   - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : evccpi                                   -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : evccpi                                   -  enabled
        system.adapter.influxdb.0               : influxdb              : evccpi                                   - disabled, port: 8086
      + system.adapter.iot.0                    : iot                   : evccpi                                   -  enabled
      + system.adapter.javascript.0             : javascript            : evccpi                                   -  enabled
      + system.adapter.modbus.0                 : modbus                : evccpi                                   -  enabled
        system.adapter.mqtt.0                   : mqtt                  : evccpi                                   - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : evccpi                                   - disabled
      + system.adapter.onvif.0                  : onvif                 : evccpi                                   -  enabled
        system.adapter.ping.0                   : ping                  : evccpi                                   - disabled
      + system.adapter.pushover.0               : pushover              : evccpi                                   -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : evccpi                                   -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : evccpi                                   -  enabled
        system.adapter.schoolfree.0             : schoolfree            : evccpi                                   -  enabled
      + system.adapter.shelly.0                 : shelly                : evccpi                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : evccpi                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : evccpi                                   -  enabled
      + system.adapter.time-switch.0            : time-switch           : evccpi                                   -  enabled
      + system.adapter.tr-064.0                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.1                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.2                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.3                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : evccpi                                   -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : evccpi                                   -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : evccpi                                   -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : evccpi                                   -  enabled
        system.adapter.vis-weather.0            : vis-weather           : evccpi                                   -  enabled
        system.adapter.vis.0                    : vis                   : evccpi                                   -  enabled
      + system.adapter.web.0                    : web                   : evccpi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.24.1 [Updatable]
      Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "evcc"         : 0.0.10   , installed 0.0.10
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "homee"        : 1.2.0    , installed 1.2.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "onvif"        : 1.0.5    , installed 1.0.5
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
      Adapter    "schoolfree"   : 1.1.2    , installed 1.1.1  [Updatable]
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Objects and States
      Objects:        8536
      States:         6690
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Get:2 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
      Hit:7 https://phoscon.de/apt/deconz bullseye InRelease
      Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Err:2 https://packages.grafana.com/oss/deb stable InRelease
      Fetched 9713 B in 2s (4265 B/s)
      Reading package lists...
      Pending Updates: 5
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22586      2287/io.shelly.0
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14064      652/vncserver-x11-c
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       22603      2352/sshd: docsn@pt
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       23907      434/deCONZ
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       24720      434/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16390      656/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14055      638/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16013      839/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18756      839/iobroker.js-con
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          14063      652/vncserver-x11-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16392      656/sshd: /usr/sbin
      tcp6       0      0 :::5021                 :::*                    LISTEN      116        27604      4039/evcc
      tcp6       0      0 :::8887                 :::*                    LISTEN      116        28720      4039/evcc
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15485      650/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22968      2747/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19285      1417/io.admin.0
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       22602      2352/sshd: docsn@pt
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14054      638/cupsd
      tcp6       0      0 :::7070                 :::*                    LISTEN      116        31319      4039/evcc
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14107      510/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16411      666/cups-browsed
      udp        0      0 0.0.0.0:58081           0.0.0.0:*                           108        15257      429/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        31317      4039/evcc
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15255      429/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21684      2341/io.shelly.1
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       23910      434/deCONZ
      udp6       0      0 :::56841                :::*                                108        15258      429/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          11177      510/dhcpcd
      udp6       0      0 :::5353                 :::*                                116        31318      4039/evcc
      udp6       0      0 :::5353                 :::*                                108        15256      429/avahi-daemon: r
      2023-09-22 07:47:44.048  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:47:59.069  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:48:44.074  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:48:59.075  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:49:14.074  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:49:29.079  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:49:44.080  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:50:00.046  - debug: shuttercontrol.0 (2814) calculate astrodata ...
      2023-09-22 07:50:00.048  - debug: shuttercontrol.0 (2814) Sun Azimut: 97°
      2023-09-22 07:50:00.049  - debug: shuttercontrol.0 (2814) Sun Elevation: 6.1°
      2023-09-22 07:50:14.094  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:50:29.083  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:50:59.089  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:51:14.094  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:51:29.093  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:51:44.095  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:52:14.093  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:52:29.105  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:52:59.109  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:53:14.119  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:53:29.125  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:53:44.120  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:53:59.127  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:54:14.124  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2023-09-22 07:54:29.128  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      iob diag has finished.
      Copy text starting here
                           v.2023-06-20
               Icon name: computer
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               true
      Boot Target:            graphical.target
      Pending OS-Updates:     5
      Pending iob updates:    3
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        1.9G        4.8G         21M        1.1G        5.8G
      Swap:            99M          0B         99M
      Active iob-Instances:   30
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                8536
      States:                 6690
      Size of iob-Database:
      5.8M    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      docsn@evccpi:/opt/zigbee2mqtt $
      • Marc Berg
        Marc Berg Most Active @docsnyder7 last edited by
        @docsnyder7 sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
        deCONZ ist NICHT beendet.
        Abgesehen davon, achte bitte bei solchen Ausgaben darauf, dass die Code-Tags richtig gesetzt werden. Du siehst ja selbst, dass es nicht richtig formatiert ist.
          @marc-berg
          damit meinst du die Ausgabe hier im Forum?
          Verdammt... ok.. ist jetzt disable
          • Marc Berg
            Marc Berg Most Active @docsnyder7 last edited by Marc Berg
            ja. Am Anfang des Textes EINMAL die drei Backticks "```" und am Ende nochmals. In der Zeile mit den Backticks darf nichts anderes stehen.
              @marc-berg
              OK beherzige ich!
              • Marc Berg
                OK beherzige ich!
                kannst ja oben noch editieren, damit das nicht wie Kraut und Rüben aussieht.
                  A Former User @docsnyder7 last edited by
                  port: >-
                  Moin,
                  da gestern ab 20 Uhr Familienzeit angesagt war, komme ich erst heute dazu alles aufzuholen.
                  Wieso sind diese Zeichen in der Konfiguration >-, das ist mit Sicherheit falsch.
                  VG
                  Bernd
                    @marc-berg
                    docsn@evccpi:~ $ systemctl status zigbee2mqtt.service
                    * zigbee2mqtt.service - zigbee2mqtt
                         Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
                         Active: activating (auto-restart) (Result: exit-code) since Fri 2023-09-22 08:26:36 CEST; 7s ago
                        Process: 2231 ExecStart=/usr/bin/npm start (code=exited, status=217/USER)
                       Main PID: 2231 (code=exited, status=217/USER)
                            CPU: 0
                    npm start ist ohne fehler durchgelaufenn
                    hab jetzt den service in die Autostart gepackt
                    reboot
                    • Marc Berg
                      Marc Berg Most Active @Guest last edited by
                      @dp20eic sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
                      Im Übrigen kann man Z2M mit völlig leerer configuration.yaml starten. Im Default kommt man per Port 8080 drauf, kann über die Oberfläche alles konfigurieren und das wird dann in die configuration.yaml zurückgeschrieben. So kann man sicher sein, keine Fehler reinzubauen.
                        @marc-berg
                        also könnte man bis auf den frontend eintrag alles rausnehmen?
                        ich komme nämlich nicht auf die 8080
                        • Marc Berg
                          Oh dear!
                          • Service beenden
                          • npm start
                          • Ausgabe hier posten
                          • laufen lassen und nochmals iob diag, Langversion
                            @marc-berg
                            Zigbee2MQTT:info  2023-09-22 08:43:52: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-22.08-43-52' filename: log.txt
                            Zigbee2MQTT:info  2023-09-22 08:43:52: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
                            Zigbee2MQTT:info  2023-09-22 08:43:52: Starting zigbee-herdsman (0.18.5)
                            Zigbee2MQTT:info  2023-09-22 08:43:53: zigbee-herdsman started (resumed)
                            Zigbee2MQTT:info  2023-09-22 08:43:53: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
                            Zigbee2MQTT:info  2023-09-22 08:44:02: Currently 0 devices are joined:
                            Zigbee2MQTT:info  2023-09-22 08:44:02: Zigbee: disabling joining new devices.
                            Zigbee2MQTT:info  2023-09-22 08:44:03: Connecting to MQTT server at mqtt://192.168.178.57:1883
                            Zigbee2MQTT:info  2023-09-22 08:44:03: Connected to MQTT server
                            Zigbee2MQTT:info  2023-09-22 08:44:03: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
                            Zigbee2MQTT:info  2023-09-22 08:44:04: Started frontend on port 0.0.0.0:8080
                            Zigbee2MQTT:info  2023-09-22 08:44:04: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"f224ef7","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x412b1dae7bdd8bf3","panID":31839},"permit_join":false,"version":"1.33.0"}'
                            Zigbee2MQTT:info  2023-09-22 08:44:04: Zigbee2MQTT started!
                            das schaut gut aus... in dem zustand geht auch die 8080
                            jetzt STRG C, dann den Service wieder enable
                            dann start zigbee2mqtt.... korrekt
                            • Marc Berg
                              Wenn der Service gestartet ist, kannst du auch unter
                              die logs sehen, falls noch was klemmt. Nach jedem Start wird eine neue Datei angelegt.
                                @marc-berg
                                [Unit]
                                Description=zigbee2mqtt
                                After=network.target
                                [Service]
                                Environment=NODE_ENV=production
                                WorkingDirectory=/opt/zigbee2mqtt
                                StandardOutput=inherit
                                # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
                                StandardError=inherit
                                Restart=always
                                RestartSec=10s
                                User=pi
                                [Install]
                                WantedBy=multi-user.target
                                in die service kommt ja obiger Inhalt rein... ich habe aber keinen user=pi... muss hier mein user rein mit dem ich mich am Pi anmelde?
                                • Marc Berg
                                  Da kann ich nicht helfen.
                                    @marc-berg
                                    so läuft...
                                    hab den user an meinen angepasst...
                                    muss ich jetzt zwigend den Adapter im iobroker installieren, wenn ich Datenpunkte für Blockly und vis benötige ?
                                    Riesiges DANKSCHÖN erstmal bis hierhin...😊
                                    • Marc Berg
                                      Das ist 'ne Glaubensfrage. Z2M liefert die Daten der Sensoren als einzelne Attribute aus, wenn du das so konfigurierst. Wenn du allerdings Geräte wie Plugs hast, dann musst du, um die steuern zu können, den /set-Pfad als MQTT Topic einmalig pro Gerät anlegen. Das macht wohl der Adapter für dich.
                                      Für mich habe ich entschieden, dass ich lieber einmalig die Hand anlege, als ständig einen zusätzlichen Adapter laufen zu lassen. Probier's einfach aus.
                                      @marc-berg sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
                                      Bei Z2M kann man mittlerweile einstellen, ob man die Werte als JSON, aufgedröselt oder beides haben möchte:
                                      Somit benötigt man den Adapter nicht zwingend. Das einzige, was man noch manuell erstellen muss, sind die "set" Zweige, um die Geräte zu steuern.
                                        docsnyder7 last edited by docsnyder7
                                        @marc-berg
                                        ist das ein screen aus der Z2M Oberfläche?
                                        das ist alles noch ziemliches Neuland für mich...
                                        • Marc Berg
                                          Marc Berg Most Active last edited by
                                          ja, unter Einstellungen --> Erweitert
                                            @marc-berg
                                            ok das hab ich gefunden..
                                            und jetzt muss ich mir noch eine separaten DP anlegen? oder den bestehenden in mqtt ändern
                                            9231
