    4. [gelöst] Information for Developer: Binary States are depr..
    • Codierknecht
      Codierknecht Developer Most Active @BlackTigga last edited by
      @blacktigga
      Bisschen wenig Information, findest Du nicht?
      https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
        @codierknecht Ja sorry, recht hast Du.
        node / nodejs: v18.6.1
        npm: 9.5.1
        js-controller 5.0.12
        admin-adapter: v6.10.1
        Debug-Log:
        2023-09-21 20:45:10.641 - info: web.0 (18121) Got terminate signal TERMINATE_YOURSELF
        2023-09-21 20:45:10.773 - debug: web.0 (18121) terminating http server on port 8082
        2023-09-21 20:45:10.799 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.93 vis.0
        2023-09-21 20:45:10.802 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.97 vis.0
        2023-09-21 20:45:10.809 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
        2023-09-21 20:45:10.810 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
        2023-09-21 20:45:10.813 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.97 flot
        2023-09-21 20:45:10.814 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
        2023-09-21 20:45:10.816 - info: web.0 (18121) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
        2023-09-21 20:45:10.828 - info: web.0 (18121) terminated http server on port 8082
        2023-09-21 20:45:10.829 - info: web.0 (18121) terminating
        2023-09-21 20:45:10.833 - debug: web.0 (18121) Plugin sentry destroyed
        2023-09-21 20:45:10.834 - info: web.0 (18121) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-09-21 20:45:11.147 - info: web.0 (18121) terminating
        2023-09-21 20:45:11.489 - info: web.0 (18121) ==> Connected system.user.admin from ::ffff:192.168.178.93
        2023-09-21 20:45:12.031 - info: host.All-In-One-RasPi stopInstance system.adapter.web.0 killing pid 18121
        2023-09-21 20:45:12.531 - info: host.All-In-One-RasPi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-21 20:45:14.060 - info: host.All-In-One-RasPi instance system.adapter.web.0 started with pid 19762
        2023-09-21 20:45:20.879 - info: web.0 (19762) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.1, js-controller: 5.0.12
        2023-09-21 20:45:22.010 - info: web.0 (19762) socket.io server listening on port 8082
        2023-09-21 20:45:22.066 - info: web.0 (19762) http server listening on port 8082
        2023-09-21 20:45:22.148 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:22.910 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
        2023-09-21 20:45:24.135 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
        2023-09-21 20:45:24.198 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:24.572 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
        2023-09-21 20:45:24.689 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.97
        2023-09-21 20:45:26.105 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:26.211 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
        2023-09-21 20:45:28.117 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:30.110 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:30.799 - info: host.All-In-One-RasPi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-21 20:45:30.916 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
        2023-09-21 20:45:31.069 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.97
        2023-09-21 20:45:32.399 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:34.112 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:36.127 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:38.126 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:40.126 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:42.126 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:44.128 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:46.129 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:48.127 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:50.155 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:52.138 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:54.134 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:56.141 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:45:58.138 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:46:00.139 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:46:02.142 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:46:04.137 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
        2023-09-21 20:46:06.219 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
          Homoran Global Moderator Administrators @BlackTigga last edited by
          @blacktigga was öffnest du via web.0?
            BlackTigga @Homoran last edited by
            Ein IPad mit vis. Wenn ich das IPad ausschalte, dann kommt auch die Meldung nicht mehr. Wenn ich wieder einschalte, dann kommt sie entsprechend wieder.
            2023-09-21 22:10:56.260 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:10:58.262 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:00.265 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:02.261 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:04.264 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:05.930 - info: web.0 (19762) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
            2023-09-21 22:11:05.933 - info: web.0 (19762) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
            2023-09-21 22:11:05.958 - info: web.0 (19762) <== Disconnect system.user.admin from ::ffff:192.168.178.93 vis.0
            2023-09-21 22:11:05.961 - info: web.0 (19762) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
            2023-09-21 22:11:05.962 - info: web.0 (19762) <== Disconnect system.user.admin from ::ffff:192.168.178.93 flot
            2023-09-21 22:11:30.572 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
            2023-09-21 22:11:33.669 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:34.263 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
            2023-09-21 22:11:34.277 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
            2023-09-21 22:11:34.278 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
            2023-09-21 22:11:34.280 - info: web.0 (19762) ==> Connected system.user.admin from ::ffff:192.168.178.93
            2023-09-21 22:11:35.497 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:37.574 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:39.599 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:41.516 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
            2023-09-21 22:11:43.471 - info: web.0 (19762) Information for Developer: Binary States are deprecated and will be removed in js-controller 5.1, please migrate to Files
              @blacktigga sagte in Information for Developer: Binary States are deprecated ....:
              Ein IPad mit vis.
              visualisierst du Datenpunkte mit binärem Inhalt?
              • OliverIO
                OliverIO @BlackTigga last edited by
                @blacktigga
                du hast den js-controller bzw. iobroker aktualisiert.
                das stand in den letzten release notes drin, das so eine warnung nun in diesem fall kommt.
                allerdings könnte man zu der warnung noch den datepunktnamen schreiben. so ist es etwas schwierig.
                ich selbst hab noch nie was von binären states gehört, das es die gibt
                  @oliverio hatte @apollon77 im Tester Thread zum controller v5 geschrieben
                  Deprecate binary states, Adapters will change to use Files instead!
                  https://forum.iobroker.net/post/1043425
                  im Spoiler unter breaking changes
                  hier war auch eine Diskussion
                  https://forum.iobroker.net/post/1008147
                  • Codierknecht
                    Codierknecht Developer Most Active @OliverIO last edited by
                    @oliverio
                    Lässt sich das vielleicht auch per Script ermitteln?
                    Einmal über alle DP rauschen und die auswerfen, die als "binär" definiert sind.
                    Scheint mir ein etwas exotischer Adapter zu sein, der hier Ärger macht.
                    Vielleicht einer der nicht mehr oder nur sehr unregelmäßig gepflegt wird.
                    • OliverIO
                      OliverIO @Codierknecht last edited by OliverIO
                      @codierknecht
                      geht wahrscheinlich auch.
                      aber iobroker bemerkt ja bei der verarbeitung das es sich um ein binarystate handelt.
                      dann könne es auch gleich den namen des datenpunkts mit ausgeben,
                      dann wüsste der TE auch gleich um welchen Adapter es sich handelt oder in wenn es ein eigener datenpunkt ist in seinen skripten schauen.
                      die fragen landen doch sonst alle hier im forum (von denen die sich trauen zu fragen)
                      • Codierknecht
                        @oliverio sagte in Information for Developer: Binary States are deprecated ....:
                        Dann müsste der TE bis zu einem kommenden Update warten.
                        Sinnvoll ist es aber allemal.
                        Ich bin an der Ecke leider zu eingeschränkt in meinen Fähigkeiten mit JS und der Kenntnis der Architektur in ioBroker.
                        Ich tippe aber mal ganz dreist, dass solch ein Script keine große Sache wäre.
                        • O
                          oFbEQnpoLKKl6mbY5e13 @BlackTigga last edited by oFbEQnpoLKKl6mbY5e13
                          @blacktigga
                          Verwendest du den Sonos-Adapter und das dazugehörige VIS-Widget in einer deiner Views?
                            @ofbeqnpolkkl6mby5e13
                            ja das tue ich.
                            Sonos Adapter und JS und Vis von https://forum.iobroker.net/topic/24743/vorlage-script-für-sonos-adapter
                            • O
                              @blacktigga
                              Dann liegt die Meldung daran. Das wird gerade gefixt. Du könntest die Version 2.3.3 von Github probieren.
                              B 1 Reply Last reply Reply Quote 2
                                BlackTigga @oFbEQnpoLKKl6mbY5e13 last edited by
                                Habe Version 2.3.3 installiert und Fehlermeldung erscheint nun nicht mehr,
                                Besten Dank.
                                1100
