    4. Gelöst: Multihost, Slave geht ständig down
      michihorn @Homoran last edited by
      Homoran DJMarc75 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @michihorn last edited by
        @michihorn bitte alles beantworten!
        @homoran sagte in Multihost, Slave geht ständig down:
        wie? (hast du den Pi getauscht) was? (genau hast du gemacht)
        ein anderer pi hat doch eine andere IP!
        wie hast du Multihost konfiguriert?
          michihorn @Homoran last edited by michihorn
          @homoran Hallöchen
          die beiden Hosts haben einen eigenen Namen.
          Der neue Slave hat die Speicherkarte vom alten Slave erhalten
          Im Slave ist in der Datei iobroker.json die IP des Master vorhanden.
          Im Master ist Multihost auf enable
          Anbei die iobroker.json vom Master:
            "system": {
              "memoryLimitMB": 0,
              "hostname": "",
              "statisticsInterval": 15000,
              "// statisticsInterval": "Interval how often the counters for input/output in adapters and controller will be updated",
              "checkDiskInterval": 300000,
              "// checkDiskInterval": "Interval how often the disk size will be checked",
              "instanceStartInterval": 2000,
              "// noChmod": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
              "compact": false,
              "// compact": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
              "allowShellCommands": false,
              "// allowShellCommands": "Allow execution of \"shell\" sendToHost commands",
              "memLimitWarn": 100,
              "// memLimitWarn": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
              "memLimitError": 50,
              "// memLimitError": "If the available RAM is below this threshold on adapter start, an error will be logged."
            "multihostService": {
              "enabled": true,
              "secure": false,
              "password": "$/aes-192-cbc:1139b4570fcc6f8b285ef7bd2b8cde18:d59d0233246bb259a62b00c19b93cd88"
            "objects": {
              "type": "jsonl",
              "// type": "Possible values: 'file' - [port 9001], 'jsonl' - [port 9001], 'redis' - [port 6379 or 26379 for sentinel].",
              "host": "0.0.0.0",
              "port": 9001,
              "noFileCache": false,
              "maxQueue": 1000,
              "connectTimeout": 5000,
              "writeFileInterval": 5000,
              "dataDir": "",
              "options": {
                "auth_pass": null,
                "retry_max_count": 19,
                "db": 0,
                "family": 0,
                "enableReadyCheck": true,
                "host": "0.0.0.0",
                "port": 9001,
                "password": null,
                "autoResubscribe": false,
                "connectionName": "host.master",
                "retry_max_delay": 5000
              "backup": {
                "disabled": false,
                "files": 24,
                "// files": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
                "hours": 48,
                "// hours": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
                "period": 120,
                "// period": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
                "path": "",
                "// path": "Absolute path to backup directory or empty to backup in data directory"
              "jsonlOptions": {
                "// autoCompress (1)": "The JSONL DB is append-only and will contain unnecessary entries after a while.",
                "// autoCompress (2)": "It will be compressed when the uncompressed size is >= size * sizeFactor AND >= sizeFactorMinimumSize",
                "// autoCompress (3)": "Note that too low values here will cause the DB to be rewritten often.",
                "autoCompress": {
                  "sizeFactor": 2,
                  "sizeFactorMinimumSize": 25000
                "// ignoreReadErrors": "If single lines in the DB are corrupted, they can be ignored without losing the whole DB.",
                "ignoreReadErrors": true,
                "// throttleFS (1)": "By default, the database immediately writes to the database file. Write accesses can be reduced using the throttleFS option.",
                "// throttleFS (2)": "Be aware that buffered changes will be lost in case the process crashes.",
                "throttleFS": {
                  "// intervalMs": "Write to the database file no more than every intervalMs milliseconds.",
                  "intervalMs": 60000,
                  "// maxBufferedCommands": "Force writing after this many changes have been buffered. This reduces memory consumption and data loss in case of a crash.",
                  "maxBufferedCommands": 100
            "states": {
              "type": "jsonl",
              "// type": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
              "host": "0.0.0.0",
              "port": 9000,
              "writeFileInterval": 30000,
              "dataDir": "",
              "options": {
                "auth_pass": null,
                "db": 0,
                "family": 0,
                "host": "0.0.0.0",
                "port": 9000,
                "password": null,
              "backup": {
                "disabled": false,
                "files": 24,
                "hours": 48,
                "// hoursC": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
                "period": 120,
                "path": "",
              "jsonlOptions": {
                "autoCompress": {
                  "sizeFactor": 10,
                  "sizeFactorMinimumSize": 50000
                "throttleFS": {
                  "maxBufferedCommands": 2000
              "maxQueue": 1000
            "log": {
              "level": "info",
              "maxDays": 7,
              "noStdout": true,
              "transport": {
                "file1": {
                  "type": "file",
                  "enabled": true,
                  "filename": "log/iobroker",
                  "fileext": ".log",
                  "maxSize": null,
                  "maxFiles": null
                "syslog1": {
                  "type": "syslog",
                  "enabled": false,
                  "host": "localhost",
                  "// host": "The host running syslogd, defaults to localhost.",
                  "// port": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                  "protocol": "udp4",
                  "// protocolC": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                  "// path": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                  "// facility": "Syslog facility to use (Default: local0).",
                  "localhost": "iobroker",
                  "// localhost": "Host to indicate that log messages are coming from (Default: localhost).",
                  "// sysLogType": "The type of the syslog protocol to use (Default: BSD).",
                  "// app_name": "The name of the application (Default: process.title).",
                  "// eol": "The end of line character to be added to the end of the message (Default: Message without modifications)."
                "seq1": {
                  "type": "seq",
                  "enabled": false,
                  "serverUrl": "http://IP:PORT",
                  "// serverUrl": "The http(s) URL including port of the seq server. If you use HTTPS a real certificate is needed; self signed certs are ot accepted.",
                  "apiKey": "",
                  "// apiKey": "The apiKey of the seq system"
            "// dataDir": "Always relative to iobroker.js-controller/",
            "plugins": {},
            "dataDir": "../../iobroker-data/"
          • DJMarc75
            DJMarc75 @michihorn last edited by
            @michihorn cpu am Master ist verdächtig hoch und der verbrauchte Ram am Slave liegt auch bei knapp 800 MB. Was läuft denn auf dem Slave so alles ?
              @michihorn sagte in Multihost, Slave geht ständig down:
              auch die beiden getauschten PIs?
              und hat vom Router die selbe IP erhalten, wie der alte?
              Zwei verschiedene Boards haben unterschiedliche MAC-Adressen gemäß derer ein Router die IP zuweist.
              Also hat der Router jetzt 2 verschiedene MAC-Adressen im Speicher, die dem selben Hostnamen zugeordnet werden!??
                michihorn @DJMarc75 last edited by michihorn
                @djmarc75 Folgendes läuft auf dem Slave:
                Der Adapter Smartthings für Samung ist der einzige sehr hungrige Adapter auf dem Slave
                  Der neue Slave hat natürlich eine neue IP erhalten. In der Iobroker.json des Master wird aber nach keiner speziellen IP des Slave gefragt. Nur im Slave wird expiliziet die IP des Master angegeben.
                    aber bei putty
                      @homoran Ja klar in Putty habe ich um drauf zu kommen natürlich die neue IP angegeben. Mit dem neuen Slave läuft es zur Zeit seit 1 Stunde ohne probleme, aber gut, der alte Slave hat i.R auch 3 Stunden gemacht
                        Möglicherweise bis der Router über die neue MAC Bindung an den selben Hostnamen stolpert
                        • DJMarc75
                          bei einem RPI3 mit 1GB RAM wundert mich das nicht wenn sich der bei solch vielen Adaptern mal verabschiedet.
                            @michihorn
                            @djmarc75 sagte in Multihost, Slave geht ständig down:
                            Außerdem wird bei richtiger Einrichtung ja alles auf dem Master verwaltet, was ggf. der Grund für die hohe Last dort sein könnte.
                            Näheres dazu würde man mit top auf dem Master sehen.
                            Möglicherweise bremst da auch die (S)SD
                              Möglich wenn Smartthing mal wieder richtig Daten schiebt,
                              aber aktuell, schau mal auf die Auslastung, die geht sowohl bei CPU als auch bei RAM niemals über 30-40%
                                beim MASTER!
                                  beim MASTER!
                                  DJMarc75 und ich schrieben gerade über den Slave.
                                  Natürlich ist der Master zu sehr Busy. Das sehe ich auch so.
                                    liest du nicht alles?
                                    • DJMarc75
                                      das siehst Du falsch. Bei RAM wird hier der verfügbare angezeigt. 22,6% sind also verfügbar.
                                        @homoran Doch ich habe das gelesen, aber Du schreibst ja selbst bei richtiger Einrichtung wird alles über den Master verwaltet. Wo ist also mein Fehler?
                                        Ich werde mir am Wochenende mal meine bei Javascript Instancen anschauen, die haben jede Menge traffic verursacht.
                                          dass ggf. durch den vielen Traffic der zu verwaltenden Daten des Slaves der Master in die Knie geht.
                                            Okay???
                                            Bei der Angabe CPU wird die Auslastung angegeben?
                                            Und bei RAM nur noch der verfügbare Speicher?
                                            Das ist ist mir neu und klingt von der Logik irgendwie widersinnig.
                                            multihost 2 raspberry
                                            1415
