    4. Gelöst: Multihost, Slave geht ständig down
      michihorn @Thomas Braun last edited by michihorn
      @thomas-braun sagte in Multihost, Slave geht ständig down:
        npm ERR! missing: chroma-js@^2.4.2, required by iobroker.javascript@7.1.4        npm ERR! missing: moment-duration-format@^2.3.2, required by iobroker.javascript@7.1.4
      Die beiden Java-Erweiterungen habe ich mal nachgetragen. Habe aktuell eine CPU Auslastung um die 60%
      Anbei iob diag vom Slave:
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: slave
               Icon name: computer
              Machine ID: 57ea2664fd064298af71415f0b920b2d
                 Boot ID: 77aad817e3894198ae1a4fc7fd7b1a02
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       15:47:37 up 7 min,  2 users,  load average: 0.29, 0.76, 0.51
      CPU threads: 4
      Raspberry only:
      throttled=0x80000
      Other values than 0x0 hint to temperature/voltage problems
      temp=58.0'C
      volt=1.3813V
      *** Time and Time Zones ***
                     Local time: Fri 2023-09-22 15:47:38 CEST
                 Universal time: Fri 2023-09-22 13:47:38 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            909M        657M         81M        0.0K        170M        194M
      Swap:            99M        0.0K         99M
      Total:          1.0G        657M        181M
                909 M total memory
                657 M used memory
                711 M active memory
                 26 M inactive memory
                 81 M free memory
                  4 M buffer memory
                165 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       57G  3.8G   51G   7% /
      devtmpfs       devtmpfs  325M     0  325M   0% /dev
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     182M  1.1M  181M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Fri Sep 22 15:39:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4f59336e-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Sep 22 15:39:43 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Fri Sep 22 15:39:43 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Fri Sep 22 15:39:44 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Sep 22 15:39:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Sep 22 15:39:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Sep 22 15:39:48 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.1G    /var/
      621M    /var/log
      601M    /var/log/journal/57ea2664fd064298af71415f0b920b2d
      182M    /var/cache
      Archived and active journals take up 600.1M in the file system.
      /opt/iobroker/backups:
      2.6M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      30M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.9M    /opt/iobroker/iobroker-data/states.jsonl
      4.0M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: homebridge-balboa-spa@^2.2.6, required by iobroker.ham@5.3.1
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-22T13_48_13_643Z-debug-0.log
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   disabled
      Persistent activation:      disabled
      Objects:                    jsonl on 192.168.178.144
      States:                     jsonl on 192.168.178.144
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : master                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : master                                   -  enabled
      + system.adapter.backitup.0               : backitup              : master                                   -  enabled
      + system.adapter.blebox.0                 : blebox                : slave                                    -  enabled
        system.adapter.daswetter.0              : daswetter             : master                                   -  enabled
        system.adapter.daswetter.1              : daswetter             : master                                   -  enabled
        system.adapter.dwd.0                    : dwd                   : slave                                    -  enabled
        system.adapter.feiertage.0              : feiertage             : slave                                    -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : slave                                    -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : master                                   -  enabled
      + system.adapter.ham.0                    : ham                   : master                                   -  enabled
      + system.adapter.history.0                : history               : slave                                    -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : master                                   -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : master                                   -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : master                                   -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : master                                   -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : master                                   -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : slave                                    -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : master                                   -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : master                                   -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : master                                   -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : master                                   -  enabled
      + system.adapter.info.0                   : info                  : master                                   -  enabled
      + system.adapter.iot.0                    : iot                   : master                                   -  enabled
      + system.adapter.iot.1                    : iot                   : master                                   -  enabled
      + system.adapter.iot.2                    : iot                   : master                                   -  enabled
      + system.adapter.javascript.0             : javascript            : master                                   -  enabled
      + system.adapter.javascript.1             : javascript            : master                                   -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : master                                   -  enabled, port: 1887
      + system.adapter.mqtt.0                   : mqtt                  : master                                   -  enabled, port: 1883, bind: 192.168.178.23
      + system.adapter.openligadb.0             : openligadb            : master                                   -  enabled
      + system.adapter.parcel.0                 : parcel                : slave                                    -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : slave                                    -  enabled
      + system.adapter.psa.0                    : psa                   : slave                                    -  enabled
      + system.adapter.reolink.0                : reolink               : master                                   -  enabled
      + system.adapter.reolink.1                : reolink               : master                                   -  enabled
      + system.adapter.ring.0                   : ring                  : master                                   -  enabled
      + system.adapter.simple-api.0             : simple-api            : master                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartgarden.0            : smartgarden           : master                                   -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : slave                                    -  enabled
      + system.adapter.smartthings.0            : smartthings           : slave                                    -  enabled
      + system.adapter.tahoma.0                 : tahoma                : master                                   -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : slave                                    -  enabled
      + system.adapter.telegram.0               : telegram              : slave                                    -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : master                                   -  enabled
      + system.adapter.tuya.1                   : tuya                  : master                                   -  enabled
      + system.adapter.vaillant.0               : vaillant              : slave                                    -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : slave                                    -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : master                                   -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : master                                   -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : master                                   -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : master                                   -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : master                                   -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : master                                   -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : slave                                    -  enabled
        system.adapter.vis-metro.0              : vis-metro             : master                                   -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : slave                                    -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : master                                   -  enabled
        system.adapter.vis.0                    : vis                   : master                                   -  enabled
      + system.adapter.web.0                    : web                   : master                                   -  enabled, port: 9082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : master                                   -  enabled
      + system.adapter.ws.0                     : ws                    : master                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : master                                   -  enabled, port: tcp://192.168.178.130:6639
      + system.adapter.zigbee.1                 : zigbee                : master                                   -  enabled, port: tcp://192.168.178.151:6638
      + system.adapter.zigbee.2                 : zigbee                : master                                   -  enabled, port: tcp://192.168.178.111:6639
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "blebox"       : 2.0.1    , installed 2.0.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "hue"          : 3.9.5    , installed 3.9.5
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "psa"          : 0.0.11   , installed 0.0.11
      Adapter    "ring"         : 3.2.2    , installed 3.2.2
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
      Objects and States
      Objects:        31765
      States:         26431
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 30
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14494      523/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14496      523/sshd: /usr/sbin
      udp        0      0 0.0.0.0:44935           0.0.0.0:*                           108        14444      394/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11686      673/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14442      394/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12850      673/dhcpcd
      udp6       0      0 :::46634                :::*                                108        14445      394/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14443      394/avahi-daemon: r
      2023-09-22 15:52:10.057  - info: blebox.0 (1094) setIobStates datapoints: {"tempsensor#device.deviceName":{"path":"device.deviceName","type":"state","common":{"name":"Devicename","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.type":{"path":"device.type","type":"state","common":{"name":"Type","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.product":{"path":"device.product","type":"state","common":{"name":"Product","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.fv":{"path":"device.fv","type":"state","common":{"name":"Firmwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.hv":{"path":"device.hv","type":"state","common":{"name":"Hardwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.apiLevel":{"path":"device.apiLevel","type":"state","common":{"name":"ApiLevel","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.id":{"path":"device.id","type":"state","common":{"name":"ID","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.ip":{"path":"device.ip","type":"state","common":{"name":"IP-Adress","type":"string","role":"text","read":true,"write":true}},"tempsensor#uptimeS":{"path":"uptimeS","type":"state","common":{"name":"Uptime in seconds","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.deviceName":{"path":"settings.deviceName","type":"state","common":{"name":"Device name.","type":"string","role":"text","read":true,"write":true}},"tempsensor#settings.statusLed.enabled":{"path":"settings.statusLed.enabled","type":"state","common":{"name":"Status led enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.tunnel.enabled":{"path":"settings.tunnel.enabled","type":"state","common":{"name":"Tunnel enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].elapsedTimeS":{"path":"tempSensor.sensors.0.elapsedTimeS","type":"state","common":{"name":"Time in seconds that has elapsed since last valid measurement occurred, where -1 = Error, 0 = Fresh data","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].state":{"path":"tempSensor.sensors.0.state","type":"state","common":{"name":"Status of sensor, where 1 = Measure in progress, 2 = Active Mode, 3 = Error","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].trend":{"path":"tempSensor.sensors.0.trend","type":"state","common":{"name":"Trend of measured data, where 0 = no data, 1 = sidewave, 2 = Downward, 3 = Upward","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].value":{"path":"tempSensor.sensors.0.value","factor":0.01,"type":"state","common":{"name":"Value of measured data, where null = Error and Temperature in Celsius degrees.","type":"number","role":"value.temperature","read":true,"write":true,"unit":"°C"}},"tempsensor#tempSensor.sensors[0].type":{"path":"tempSensor.sensors.0.type","type":"state","common":{"name":"Type of measured value","type":"string","role":"text","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].id":{"path":"tempSensor.sensors.0.id","type":"state","common":{"name":"ID of internal sensor","type":"string","role":"text","read":true,"write":true}}}
      2023-09-22 15:52:10.058  - info: blebox.0 (1094) setIobStates path: tempSensor.sensors.0.value
      2023-09-22 15:52:10.059  - info: blebox.0 (1094) setIobStates: "Teichtemp.tempSensor.sensors.0.value" = 1687
      2023-09-22 15:52:10.060  - info: blebox.0 (1094) setIobStates search: tempsensor#tempSensor.sensors[0].trend
      2023-09-22 15:52:10.061  - info: blebox.0 (1094) setIobStates datapoints: {"tempsensor#device.deviceName":{"path":"device.deviceName","type":"state","common":{"name":"Devicename","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.type":{"path":"device.type","type":"state","common":{"name":"Type","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.product":{"path":"device.product","type":"state","common":{"name":"Product","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.fv":{"path":"device.fv","type":"state","common":{"name":"Firmwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.hv":{"path":"device.hv","type":"state","common":{"name":"Hardwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.apiLevel":{"path":"device.apiLevel","type":"state","common":{"name":"ApiLevel","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.id":{"path":"device.id","type":"state","common":{"name":"ID","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.ip":{"path":"device.ip","type":"state","common":{"name":"IP-Adress","type":"string","role":"text","read":true,"write":true}},"tempsensor#uptimeS":{"path":"uptimeS","type":"state","common":{"name":"Uptime in seconds","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.deviceName":{"path":"settings.deviceName","type":"state","common":{"name":"Device name.","type":"string","role":"text","read":true,"write":true}},"tempsensor#settings.statusLed.enabled":{"path":"settings.statusLed.enabled","type":"state","common":{"name":"Status led enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.tunnel.enabled":{"path":"settings.tunnel.enabled","type":"state","common":{"name":"Tunnel enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].elapsedTimeS":{"path":"tempSensor.sensors.0.elapsedTimeS","type":"state","common":{"name":"Time in seconds that has elapsed since last valid measurement occurred, where -1 = Error, 0 = Fresh data","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].state":{"path":"tempSensor.sensors.0.state","type":"state","common":{"name":"Status of sensor, where 1 = Measure in progress, 2 = Active Mode, 3 = Error","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].trend":{"path":"tempSensor.sensors.0.trend","type":"state","common":{"name":"Trend of measured data, where 0 = no data, 1 = sidewave, 2 = Downward, 3 = Upward","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].value":{"path":"tempSensor.sensors.0.value","factor":0.01,"type":"state","common":{"name":"Value of measured data, where null = Error and Temperature in Celsius degrees.","type":"number","role":"value.temperature","read":true,"write":true,"unit":"°C"}},"tempsensor#tempSensor.sensors[0].type":{"path":"tempSensor.sensors.0.type","type":"state","common":{"name":"Type of measured value","type":"string","role":"text","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].id":{"path":"tempSensor.sensors.0.id","type":"state","common":{"name":"ID of internal sensor","type":"string","role":"text","read":true,"write":true}}}
      2023-09-22 15:52:10.062  - info: blebox.0 (1094) setIobStates path: tempSensor.sensors.0.trend
      2023-09-22 15:52:10.063  - info: blebox.0 (1094) setIobStates: "Teichtemp.tempSensor.sensors.0.trend" = 1
      2023-09-22 15:52:10.064  - info: blebox.0 (1094) setIobStates search: tempsensor#tempSensor.sensors[0].state
      2023-09-22 15:52:10.065  - info: blebox.0 (1094) setIobStates datapoints: {"tempsensor#device.deviceName":{"path":"device.deviceName","type":"state","common":{"name":"Devicename","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.type":{"path":"device.type","type":"state","common":{"name":"Type","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.product":{"path":"device.product","type":"state","common":{"name":"Product","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.fv":{"path":"device.fv","type":"state","common":{"name":"Firmwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.hv":{"path":"device.hv","type":"state","common":{"name":"Hardwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.apiLevel":{"path":"device.apiLevel","type":"state","common":{"name":"ApiLevel","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.id":{"path":"device.id","type":"state","common":{"name":"ID","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.ip":{"path":"device.ip","type":"state","common":{"name":"IP-Adress","type":"string","role":"text","read":true,"write":true}},"tempsensor#uptimeS":{"path":"uptimeS","type":"state","common":{"name":"Uptime in seconds","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.deviceName":{"path":"settings.deviceName","type":"state","common":{"name":"Device name.","type":"string","role":"text","read":true,"write":true}},"tempsensor#settings.statusLed.enabled":{"path":"settings.statusLed.enabled","type":"state","common":{"name":"Status led enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.tunnel.enabled":{"path":"settings.tunnel.enabled","type":"state","common":{"name":"Tunnel enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].elapsedTimeS":{"path":"tempSensor.sensors.0.elapsedTimeS","type":"state","common":{"name":"Time in seconds that has elapsed since last valid measurement occurred, where -1 = Error, 0 = Fresh data","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].state":{"path":"tempSensor.sensors.0.state","type":"state","common":{"name":"Status of sensor, where 1 = Measure in progress, 2 = Active Mode, 3 = Error","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].trend":{"path":"tempSensor.sensors.0.trend","type":"state","common":{"name":"Trend of measured data, where 0 = no data, 1 = sidewave, 2 = Downward, 3 = Upward","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].value":{"path":"tempSensor.sensors.0.value","factor":0.01,"type":"state","common":{"name":"Value of measured data, where null = Error and Temperature in Celsius degrees.","type":"number","role":"value.temperature","read":true,"write":true,"unit":"°C"}},"tempsensor#tempSensor.sensors[0].type":{"path":"tempSensor.sensors.0.type","type":"state","common":{"name":"Type of measured value","type":"string","role":"text","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].id":{"path":"tempSensor.sensors.0.id","type":"state","common":{"name":"ID of internal sensor","type":"string","role":"text","read":true,"write":true}}}
      2023-09-22 15:52:10.067  - info: blebox.0 (1094) setIobStates path: tempSensor.sensors.0.state
      2023-09-22 15:52:10.067  - info: blebox.0 (1094) setIobStates: "Teichtemp.tempSensor.sensors.0.state" = 2
      2023-09-22 15:52:10.068  - info: blebox.0 (1094) setIobStates search: tempsensor#tempSensor.sensors[0].elapsedTimeS
      2023-09-22 15:52:10.069  - info: blebox.0 (1094) setIobStates datapoints: {"tempsensor#device.deviceName":{"path":"device.deviceName","type":"state","common":{"name":"Devicename","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.type":{"path":"device.type","type":"state","common":{"name":"Type","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.product":{"path":"device.product","type":"state","common":{"name":"Product","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.fv":{"path":"device.fv","type":"state","common":{"name":"Firmwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.hv":{"path":"device.hv","type":"state","common":{"name":"Hardwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.apiLevel":{"path":"device.apiLevel","type":"state","common":{"name":"ApiLevel","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.id":{"path":"device.id","type":"state","common":{"name":"ID","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.ip":{"path":"device.ip","type":"state","common":{"name":"IP-Adress","type":"string","role":"text","read":true,"write":true}},"tempsensor#uptimeS":{"path":"uptimeS","type":"state","common":{"name":"Uptime in seconds","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.deviceName":{"path":"settings.deviceName","type":"state","common":{"name":"Device name.","type":"string","role":"text","read":true,"write":true}},"tempsensor#settings.statusLed.enabled":{"path":"settings.statusLed.enabled","type":"state","common":{"name":"Status led enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.tunnel.enabled":{"path":"settings.tunnel.enabled","type":"state","common":{"name":"Tunnel enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].elapsedTimeS":{"path":"tempSensor.sensors.0.elapsedTimeS","type":"state","common":{"name":"Time in seconds that has elapsed since last valid measurement occurred, where -1 = Error, 0 = Fresh data","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].state":{"path":"tempSensor.sensors.0.state","type":"state","common":{"name":"Status of sensor, where 1 = Measure in progress, 2 = Active Mode, 3 = Error","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].trend":{"path":"tempSensor.sensors.0.trend","type":"state","common":{"name":"Trend of measured data, where 0 = no data, 1 = sidewave, 2 = Downward, 3 = Upward","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].value":{"path":"tempSensor.sensors.0.value","factor":0.01,"type":"state","common":{"name":"Value of measured data, where null = Error and Temperature in Celsius degrees.","type":"number","role":"value.temperature","read":true,"write":true,"unit":"°C"}},"tempsensor#tempSensor.sensors[0].type":{"path":"tempSensor.sensors.0.type","type":"state","common":{"name":"Type of measured value","type":"string","role":"text","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].id":{"path":"tempSensor.sensors.0.id","type":"state","common":{"name":"ID of internal sensor","type":"string","role":"text","read":true,"write":true}}}
      2023-09-22 15:52:10.070  - info: blebox.0 (1094) setIobStates path: tempSensor.sensors.0.elapsedTimeS
      2023-09-22 15:52:10.074  - info: blebox.0 (1094) setIobStates: "Teichtemp.tempSensor.sensors.0.elapsedTimeS" = 3
      2023-09-22 15:52:10.086  - info: blebox.0 (1094) body:{"uptimeS":57531}
      2023-09-22 15:52:10.087  - info: blebox.0 (1094) data:{"uptimeS":57531}
      2023-09-22 15:52:10.088  - info: blebox.0 (1094) setIobStates device: {"dev_name":"Teichtemp","smart_name":"Teichtemp","dev_ip":"192.168.178.49","dev_port":"80","dev_type":"tempsensor"}
      2023-09-22 15:52:10.089  - info: blebox.0 (1094) setIobStates values: {"uptimeS":57531}
      2023-09-22 15:52:10.090  - info: blebox.0 (1094) setIobStates search: tempsensor#uptimeS
      2023-09-22 15:52:10.090  - info: blebox.0 (1094) setIobStates datapoints: {"tempsensor#device.deviceName":{"path":"device.deviceName","type":"state","common":{"name":"Devicename","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.type":{"path":"device.type","type":"state","common":{"name":"Type","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.product":{"path":"device.product","type":"state","common":{"name":"Product","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.fv":{"path":"device.fv","type":"state","common":{"name":"Firmwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.hv":{"path":"device.hv","type":"state","common":{"name":"Hardwareversion","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.apiLevel":{"path":"device.apiLevel","type":"state","common":{"name":"ApiLevel","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.id":{"path":"device.id","type":"state","common":{"name":"ID","type":"string","role":"text","read":true,"write":true}},"tempsensor#device.ip":{"path":"device.ip","type":"state","common":{"name":"IP-Adress","type":"string","role":"text","read":true,"write":true}},"tempsensor#uptimeS":{"path":"uptimeS","type":"state","common":{"name":"Uptime in seconds","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.deviceName":{"path":"settings.deviceName","type":"state","common":{"name":"Device name.","type":"string","role":"text","read":true,"write":true}},"tempsensor#settings.statusLed.enabled":{"path":"settings.statusLed.enabled","type":"state","common":{"name":"Status led enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#settings.tunnel.enabled":{"path":"settings.tunnel.enabled","type":"state","common":{"name":"Tunnel enabled (0 - disabled, 1 - enabled)","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].elapsedTimeS":{"path":"tempSensor.sensors.0.elapsedTimeS","type":"state","common":{"name":"Time in seconds that has elapsed since last valid measurement occurred, where -1 = Error, 0 = Fresh data","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].state":{"path":"tempSensor.sensors.0.state","type":"state","common":{"name":"Status of sensor, where 1 = Measure in progress, 2 = Active Mode, 3 = Error","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].trend":{"path":"tempSensor.sensors.0.trend","type":"state","common":{"name":"Trend of measured data, where 0 = no data, 1 = sidewave, 2 = Downward, 3 = Upward","type":"number","role":"value","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].value":{"path":"tempSensor.sensors.0.value","factor":0.01,"type":"state","common":{"name":"Value of measured data, where null = Error and Temperature in Celsius degrees.","type":"number","role":"value.temperature","read":true,"write":true,"unit":"°C"}},"tempsensor#tempSensor.sensors[0].type":{"path":"tempSensor.sensors.0.type","type":"state","common":{"name":"Type of measured value","type":"string","role":"text","read":true,"write":true}},"tempsensor#tempSensor.sensors[0].id":{"path":"tempSensor.sensors.0.id","type":"state","common":{"name":"ID of internal sensor","type":"string","role":"text","read":true,"write":true}}}
      2023-09-22 15:52:10.091  - info: blebox.0 (1094) setIobStates path: uptimeS
      2023-09-22 15:52:10.091  - info: blebox.0 (1094) setIobStates: "Teichtemp.uptimeS" = 57531
      2023-09-22 15:52:10.102  - info: blebox.0 (1094) State value to set for "blebox.0.Teichtemp.tempSensor.sensors.0.id" has to be type "string" but received type "number"
      2023-09-22 15:52:10.581  - silly: host.slave States system redis pmessage system.adapter.*.alive/system.adapter.blebox.0.alive:{"val":true,"ack":true,"ts":1695390730576,"q":0,"from":"system.adapter.blebox.0","lc":1695390040942,"expire":true}
      iob diag has finished.
        Homoran Global Moderator Administrators @michihorn last edited by
        @michihorn sagte in Multihost, Slave geht ständig down:
        deine ble box hämmert im Millisekundentakt Daten
          michihorn @Homoran last edited by
          @homoran Da kann ich aber nichts dran einstellen
            michihorn last edited by michihorn
            EDIT: Läuft nun seit 17 Stunden...
            Marc Berg Homoran 2 Replies Last reply Reply Quote 0
            • Marc Berg
              Marc Berg Most Active @michihorn last edited by Marc Berg
              gelöscht, da @michihorn seinen Post nach meiner Antwort geändert hat.
                @michihorn
                da stand doch vorhin
                EDIT: Leider keine Entwarnung....Jetzt nach knapp 10 Stunden ist der Slave wieder down.
                was hat denn jetzt zur Wunderheilung geführt?
                oder besser:
                Wahrscheinlich war das bisher auch so, dass sich das nach einiger Zeit eingerenkt hat/hätte.
                So ist jedenfalls keine Ursachenforschung möglich
                  @homoran Gerstern ist das Gerät 9 Stunden in Betrieb gewesen, gegen 21Uhr war es dann Down. Nochmal nochgestartet und läuft bis jetzt. Wunderheilung??? Ich freue mich das das Gerät aktuell läuft. Melde mich nochmal wenn der Slave wieder abstürtzt
                    @michihorn sagte in Gelöst: Multihost, Slave geht ständig down:
                    das ist aber nicht
                      @homoran sollte neu gestartet heissen, sorry
                        ist doch egal!
                        dann ist er nach 10 Stunden down gewesen und lief dann wieder 7 Stunden.
                        Was bitte willst du mit so gezinkten Daten beweisen?
                          michihorn @Homoran last edited by michihorn
                          @homoran sagte in Gelöst: Multihost, Slave geht ständig down:
                          Häää??? Wie bitte, ich will doch niemanden etwas beweisen.
                          Ich bin doch dankbar das es läuft. Jeder von Euch hat bei der Lösung unterstützt.
                          Resultat ist heute am 24.9.23 um 17:58 Uhr folgendes:
                          Nochmals, Danke an alle, die mich mit Rat und Expertise mich unterstützt haben. 👍
                          Ihr seit SPITZE !
                          multihost 2 raspberry
                          1415
