    4. device-reminder Adapter
    • mcm1957
      mcm1957 @TimoWald last edited by
      @timowald
      Danke für die Umgebungsinfo. Aber ohne Log / Fehlermeldung kann auch meine Glaskugel nichts erraten. Wird nicht grün ist zu dünn 🙂 . Irgendwas muss / sollte da im log stehen.
      Hast du eine Config speichern können? Ohne Config ist es durchaus wahrscheinlich, dass der Adapter nur "Fehlene Config" loggt. Aber die Aussage stammzt aus meinem Kaffeesud ...
        TimoWald @mcm1957 last edited by
        @mcm57 Der Log sieht beim Starten des Adapters so aus:
        2023-09-23 17:45:55.032 - info: synology.0 (1037) Connecting to Synology 192.168.9.13:5000
        2023-09-23 17:45:58.209 - warn: openknx.0 (896) [warn] "2023-09-23T15:45:58.209Z" 'DPT9.fromBuffer: buf should be 2 bytes long (got %d bytes)' 4
        2023-09-23 17:46:03.782 - info: admin.0 (1770) ==> Connected system.user.admin from ::ffff:192.168.9.50
        2023-09-23 17:46:03.860 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.880 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.902 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.917 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.933 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.951 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.967 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:03.982 - info: device-reminder.0 (2575) {"name":"washing-machine","startVal":30,"endVal":15,"standby":1,"startCount":2,"endCount":50,"id":1,"check":"open"}
        2023-09-23 17:46:03.983 - info: device-reminder.0 (2575) {"name":"washing-machine","startVal":30,"endVal":15,"standby":1,"startCount":2,"endCount":50,"id":1,"check":"open"}
        2023-09-23 17:46:03.983 - info: device-reminder.0 (2575) {"name":"dryer","startVal":120,"endVal":15,"standby":1,"startCount":2,"endCount":20,"id":2,"check":"open"}
        2023-09-23 17:46:03.983 - info: device-reminder.0 (2575) {"name":"dishwasher","startVal":15,"endVal":0.25,"standby":0.5,"startCount":2,"endCount":120,"id":3,"check":"open"}
        2023-09-23 17:46:03.984 - info: device-reminder.0 (2575) {"name":"dishwasher","startVal":15,"endVal":0.25,"standby":0.5,"startCount":2,"endCount":120,"id":3,"check":"open"}
        2023-09-23 17:46:03.984 - info: device-reminder.0 (2575) {"checked":[{"name":"washing-machine","id":1},{"name":"dryer","id":2},{"name":"dishwasher","id":3}],"failed":[]}
        2023-09-23 17:46:03.997 - info: device-reminder.0 (2575) {"name":"custom1","startVal":30,"endVal":5,"standby":1,"startCount":1,"endCount":20,"id":21,"check":"open"}
        2023-09-23 17:46:03.997 - info: device-reminder.0 (2575) {"name":"custom2","startVal":30,"endVal":5,"standby":1,"startCount":1,"endCount":20,"id":22,"check":"open"}
        2023-09-23 17:46:03.998 - info: device-reminder.0 (2575) {"name":"custom3","startVal":30,"endVal":5,"standby":1,"startCount":1,"endCount":20,"id":23,"check":"open"}
        2023-09-23 17:46:03.998 - info: device-reminder.0 (2575) {"name":"custom4","startVal":30,"endVal":5,"standby":1,"startCount":1,"endCount":20,"id":24,"check":"open"}
        2023-09-23 17:46:03.998 - info: device-reminder.0 (2575) {"name":"custom5","startVal":30,"endVal":5,"standby":1,"startCount":1,"endCount":20,"id":25,"check":"open"}
        2023-09-23 17:46:03.999 - info: device-reminder.0 (2575) {"checked":[{"name":"custom1","id":21},{"name":"custom2","id":22},{"name":"custom3","id":23},{"name":"custom4","id":24},{"name":"custom5","id":25}],"failed":[]}
        2023-09-23 17:46:04.005 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:04.053 - info: device-reminder.0 (2575) {"checked":[],"failed":[]}
        2023-09-23 17:46:07.722 - warn: openknx.0 (896) [warn] "2023-09-23T15:46:07.722Z" 'DPT9.fromBuffer: buf should be 2 bytes long (got %d bytes)' 4
        2023-09-23 17:46:08.194 - info: host.iobroker stopInstance system.adapter.device-reminder.0 (force=false, process=true)
        2023-09-23 17:46:08.236 - info: device-reminder.0 (2575) Got terminate signal TERMINATE_YOURSELF
        2023-09-23 17:46:08.238 - info: device-reminder.0 (2575) terminating
        2023-09-23 17:46:08.238 - info: device-reminder.0 (2575) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-09-23 17:46:08.371 - info: host.iobroker stopInstance system.adapter.device-reminder.0 send kill signal
        2023-09-23 17:46:08.740 - info: device-reminder.0 (2575) terminating
        2023-09-23 17:46:08.829 - info: host.iobroker instance system.adapter.device-reminder.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-23 17:46:11.121 - info: admin.0 (1770) <== Disconnect system.user.admin from ::ffff:192.168.9.50
        2023-09-23 17:46:16.262 - info: host.iobroker instance system.adapter.device-reminder.0 started with pid 3026
        2023-09-23 17:46:17.059 - debug: device-reminder.0 (3026) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-09-23 17:46:17.103 - debug: device-reminder.0 (3026) Objects client ready ... initialize now
        2023-09-23 17:46:17.105 - debug: device-reminder.0 (3026) Objects create System PubSub Client
        2023-09-23 17:46:17.105 - debug: device-reminder.0 (3026) Objects create User PubSub Client
        2023-09-23 17:46:17.191 - debug: device-reminder.0 (3026) Objects client initialize lua scripts
        2023-09-23 17:46:17.196 - debug: device-reminder.0 (3026) Objects connected to redis: 127.0.0.1:9001
        2023-09-23 17:46:17.198 - silly: device-reminder.0 (3026) redis psubscribe cfg.o.system.user.*
        2023-09-23 17:46:17.256 - silly: device-reminder.0 (3026) redis psubscribe cfg.o.enum.*
        2023-09-23 17:46:17.258 - silly: device-reminder.0 (3026) objectDB connected
        2023-09-23 17:46:17.261 - debug: device-reminder.0 (3026) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-09-23 17:46:17.348 - debug: device-reminder.0 (3026) States create System PubSub Client
        2023-09-23 17:46:17.349 - debug: device-reminder.0 (3026) States create User PubSub Client
        2023-09-23 17:46:17.437 - debug: device-reminder.0 (3026) States connected to redis: 127.0.0.1:9000
        2023-09-23 17:46:17.438 - silly: device-reminder.0 (3026) statesDB connected
        2023-09-23 17:46:17.773 - warn: openknx.0 (896) [warn] "2023-09-23T15:46:17.773Z" 'DPT9.fromBuffer: buf should be 2 bytes long (got %d bytes)' 4
        2023-09-23 17:46:18.327 - info: device-reminder.0 (3026) starting. Version 2.0.1 (non-npm: xenon-s/ioBroker.device-reminder) in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.17.1, js-controller: 5.0.12
        2023-09-23 17:46:18.357 - silly: device-reminder.0 (3026) States system redis pmessage system.adapter.device-reminder.0.logLevel/system.adapter.device-reminder.0.logLevel:{"val":"silly","ack":true,"ts":1695483978349,"q":0,"from":"system.adapter.device-reminder.0","lc":1695483978349}
        2023-09-23 17:46:27.970 - warn: openknx.0 (896) [warn] "2023-09-23T15:46:27.970Z" 'DPT9.fromBuffer: buf should be 2 bytes long (got %d bytes)' 4
        2023-09-23 17:46:28.570 - info: synology.0 (1037) Connecting to Synology 192.168.9.13:5000
        • mcm1957
          @timowald
          Offensichtlicher Fehler ist da nicht erkennbar. Bitte erstell ein Issue beim Adapter, dass sollte sich wahrscheinlich der Maintainer ansehen.
            @mcm57 was ist ein Issue?
            • mcm1957
              @timowald
              Ein Issue ist eine Fehlermeldung im Adapter Repository.
              https://github.com/Xenon-s/ioBroker.device-reminder/issues
              Dort auf new issue klicken.
              @Thomas-Braun
              Habt ihr hier eine Github / Issue Anleitung im Forum auf die ihr verlinken könntet?
              Bitte - Danke
                Thomas Braun Most Active @mcm1957 last edited by
                @mcm57 sagte in device-reminder Adapter:
                Nicht das ich wüsste.
                • Rene55
                  Rene55 @mcm1957 last edited by
                  @mcm57 Ich habe mir - notwendigerweise - auch die Version 2.0.1 installiert. Was mir aufgefallen ist, dass ich in Edge es kaum schaffe, die Eingaben prüfen zu lassen - in Firefox gehts. Dann scheitere ich an der einfachen Geschichte, einen Telegram Teilnehmer anzulegen. Weiter in Verknüpfte Geräte: hier ist es mir nicht möglich, einen Signalisierungsweg auszuwählen. Da steht irgendwas "ETmealigram" - aber nichts zum auswählen.
                  Speichern lässt sich bei mir auch nichts. Mittlerer Frust!😠
                  • mcm1957
                    mcm1957 @Rene55 last edited by
                    @rene55
                    Ich bin da der falsche Ansprechpartner.
                    Bitte beim dev / im Adapterrepo nachfragen. Ein diesbezügluches Issue exustuert ha wie weitrr oben geschrieben.
                    • da_Woody
                      da_Woody last edited by
                      @mcm57 https://github.com/Xenon-s/ioBroker.device-reminder/issues
                      echt jetzt?
                      • mcm1957
                        mcm1957 @da_Woody last edited by
                        @da_woody said in device-reminder Adapter:
                        echt jetzt?
                        Was willst du mir damit sagen?
                        • Rene55
                          @mcm57 Ich hatte dich nur angetriggert, weil du so schön auf 2.0.1 ist im lates repository hingewiesen hast. Ich dachte, dass der Adapter in diesem Zustand maximal latest wäre.
                          mcm1957 T 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            mcm1957 @Rene55 last edited by mcm1957
                            @rene55
                            Nö leider ist da auch der wurm drin.
                            • da_Woody
                              da_Woody @mcm1957 last edited by
                              sollte eigentlich an @TimoWald gehn. allerdings, wozu brauchst du eine anleitung?
                              • mcm1957
                                Ich hab die Anleitung für TimoWald gesucht. Offensichtlich ist er neu im Umfeld github. Und da wir nicht nur Programmierer als ioBroker User haben wollen, kann ich voll verstehen, dass jemand nicht gleich weiß was ein Issue ist und noch weniger wie er/sie eines erstellt.
                                Anmeldung bei Github ist für alle zumutbar. Aber den Weg dahin werden wir dem einen oder anderen erklären müssen. Zumindest ich finde es nicht gut neue User ev. zu frustieren indem sie nur Schlagwörter vorgesetzt bekommen. Daher hab ich gefragt ob es ev. eine Anleitung (a la gute-foren-beiträge) gibt
                                Das soll allerdings kein Freibrief sein, prinzipiell jede Suche zu vemeiden und googeln zu lassen. Aber ich glaub ihr versteht was ich meine.
                                  A Former User @mcm1957 last edited by
                                  Moin,
                                  meine Devise, immer erst beim Hersteller/Betreiber/Owner nachzuschauen, denn da sollte man am schnellsten, die Informationen bekommen ⇾ https://docs.github.com/de/issues/tracking-your-work-with-issues/creating-an-issue
                                  Vielleicht hilft das ja.
                                  VG
                                  Bernd
                                  • da_Woody
                                    bin ich voll bei dir! irgendwann hat jeder mal angefangen. wie du selbst schreibst, google macht vieles möglich.
                                    ich hab auch ab und an probleme, poste aber erst, wenn ich über andere wege keinen ausweg finde. klar, man kann auch sachen übersehn, wie ich mit meinem echarts install prob. lösung hab ich trotz dem hinweis auf themen hier nicht gefunden. muss ich weiter suchen.
                                    brauchst ja nur manche topic themen lesen "hilfe, funktioniert nicht" sonst keine infos.
                                    nach diversen nachfragen kommt dann immer noch nicht alles.
                                      TimoWald @Rene55 last edited by
                                      @rene55 said in device-reminder Adapter:
                                      Wo finde ich denn dieses?
                                      • Rene55
                                        Rene55 @TimoWald last edited by
                                        @timowald Hier scheint es wohl Irritationen zu geben. Stand von jetzt ist:
                                        Stable: 1.2.9
                                        Latest: 2.0.1
                                        Ich würde dem Entwickler noch ein paar Tage Zeit geben, bist die neue Version testfähig ist.
                                        • mcm1957
                                          2.0.1 stammt schon aus dem August - seither tut sich nicht viel bei dem Adapter.
                                            OK, danke für die infor. Also einfach abwarten.
                                            Xenon 1 Reply Last reply Reply Quote 0
                                            1089
