      TT-Tom @MichaelF last edited by
      @michaelf
      @Armilar
      08:45:33.736 BRY: Exception> 'type_error'
      ist das eine Meldung vom Berry driver. ich würde Vorschlagen den Berry nochmal neu aufsetzen und dann den Flash neu starten.
      Armilar 1 Reply Last reply Reply Quote 1
      • Armilar
        Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
        @tt-tom
        werfe mal alle Dateien weg:
        dann die autoexec.be neu anlegen mit diesem Inhalt:
        https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be
        dann Tasmota neustarten
        und erneut
        FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.3.1.tft
        MichaelF 1 Reply Last reply Reply Quote 0
        • MichaelF
          MichaelF @Armilar last edited by MichaelF
          @armilar said in SONOFF NSPanel mit Lovelace UI:
          @tt-tom
          und erneut
          Gemacht :
          10:59:21.111 CMD: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.3.1.tft
          10:59:21.126 MQT: stat/tasmota_C82F70/RESULT = {"FlashNextion":"Done"}
          10:59:21.167 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v4.3.1.tft
          10:59:23.198 FLH: Something has gone wrong flashing display firmware [bytes('55BB1F006576656E742C736C656570526561636865642C63617264456E746974...')]
          10:59:23.244 MQT: stat/tasmota_C82F70/STATUS = {"Status":{"Module":0,"DeviceName":"NSPanel","FriendlyName":["Panel1",""],"Topic":"tasmota_C82F70","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":0,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
          10:59:23.284 MQT: stat/tasmota_C82F70/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T00:00:28","StartupUTC":"2023-09-24T09:58:55","Sleep":0,"CfgHolder":4617,"BootCount":95,"BCResetTime":"2022-07-07T18:59:33","SaveCount":186}}
          10:59:23.326 MQT: stat/tasmota_C82F70/STATUS2 = {"StatusFWR":{"Version":"13.1.0(nspanel)","BuildDateTime":"2023-08-15T08:01:15","Core":"2_0_11","SDK":"4.4.5.230722","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 rev.3","CR":"450/699"}}
          10:59:23.345 MQT: stat/tasmota_C82F70/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"192.168.178.69","LogPort":514,"SSId":["WLAN 7270",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","0505C80001000600003C5A0A192800000000","00800080","00006000","00004001","00000001"]}}
          10:59:23.385 MQT: stat/tasmota_C82F70/STATUS4 = {"StatusMEM":{"ProgramSize":1870,"Free":1009,"Heap":73,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","010A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"}}
          10:59:23.462 MQT: stat/tasmota_C82F70/STATUS5 = {"StatusNET":{"Hostname":"tasmota-C82F70-3952","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"253.0.0.0","DNSServer2":"32.3.0.223","Mac":"7C:87:CE:C8:2F:70","IP6Global":"2003:df:373f:e00:7e87:ceff:fec8:2f70","IP6Local":"fe80::7e87:ceff:fec8:2f70","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"253.0.0.0","DNSServer2":"32.3.0.223","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0}}
          10:59:23.528 MQT: stat/tasmota_C82F70/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.69","MqttPort":1886,"MqttClientMask":"NS_Panel1","MqttClient":"NS_Panel1","MqttUser":"Mikeldk","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
          10:59:23.557 MQT: stat/tasmota_C82F70/STATUS7 = {"StatusTIM":{"UTC":"2023-09-24T09:59:23","Local":"2023-09-24T10:59:23","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"06:39","Sunset":"18:44"}}
          10:59:23.582 MQT: stat/tasmota_C82F70/STATUS10 = {"StatusSNS":{"Time":"2023-09-24T10:59:23","ANALOG":{"Temperature1":26.6},"ESP32":{"Temperature":56.1},"TempUnit":"C"}}
          10:59:23.607 MQT: stat/tasmota_C82F70/STATUS11 = {"StatusSTS":{"Time":"2023-09-24T10:59:23","Uptime":"0T00:00:28","UptimeSec":28,"Heap":70,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":910,"MqttCount":1,"Berry":{"HeapUsed":33,"Objects":452},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"38:10:D5:13:AB:0E","Channel":1,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:02"}}}
          10:59:23.796 MQT: stat/tasmota_C82F70/RESULT = {"CustomSend":"Done"}
          10:59:23.862 FLH: Send (High Speed) flash start
          10:59:24.214 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
          Kein erfolg, was ich grade in der Berry Console gesehen habe :
          Der Log nach einem Neustart, fehlt da was ?
          00:00:00.002 HDW: ESP32-D0WD-V3
          00:00:00.074 UFS: FlashFS mounted with 272 kB free
          00:00:00.106 CFG: Loaded from File, Count 191
          00:00:00.116 QPC: Count 1
          00:00:00.242 BRY: Berry initialized, RAM used=4470 bytes
          00:00:00.264 TFS: File '.drvset003' not found
          00:00:00.275 Project tasmota - NSPanel Version 13.1.0(nspanel)-2_0_11(2023-08-15T08:01:15)
          00:00:00.328 TAP: Loaded Tasmota App 'Partition_Wizard.tapp'
          00:00:01.654 NXP: Initializing Driver
          00:00:01.661 BRY: Successfully loaded 'autoexec.be'
          • Armilar
            Armilar Most Active Forum Testing @MichaelF last edited by
            @michaelf
            da ist anscheinend auch noch der Partition_Witzard auf dem Tasmota. Da die Partition bereits geändert ist, solltest du den wieder löschen und den Speicher freigeben.
            Danach nochmals versuchen
            • MichaelF
              @michaelf
              Gelöscht, aber gleicher Fehler.
              • Armilar
                Armilar Most Active Forum Testing @MichaelF last edited by Armilar
                @michaelf
                ansonsten nochmals an dieses Issue hängen:
                https://github.com/joBr99/nspanel-lovelace-ui/issues/972
                Ist meiner Auffassung nach der Grund für die BerryDriver Version 9
                Evtl. liest @joBr99 hier mit...
                jacekowski created this issue in joBr99/nspanel-lovelace-ui
                closed [BUG] FlashNextion fails #972
                • icebear
                  icebear last edited by
                  Ansonsten gerne trotzdem auf den BerryDriver 9 wechseln und wie immer den unteren Teil ersetzen.
                  Hab bei mir grad das Update durchgeführt, hat alles super funktioniert und ist ohne Probleme durchgelaufen.
                  • MichaelF
                    @michaelf
                    Soll ich ne neue issues aufmachen, oder einfach hier mit unten reinschreiben?
                    Hilft es vielleicht tasmota über ota neu zu flashen ?
                    Hier nochmal ein Bild wo das Display dann hängt.
                    • Armilar
                      @michaelf
                      würde ein neues aufmachen...
                      • MichaelF
                        @michaelf
                        Hab ich, danke für die Hilfe
                          Gre4t0ne @TT-Tom last edited by
                          @tt-tom heute erst wieder Zeit gehabt - habe diese Config nicht angepasst:
                          mrIcon1ScreensaverEntity:
                          ScreensaverEntity: NSPanel_Path + 'Relay.1',
                          ScreensaverEntityIconOn: 'lightbulb',
                          ScreensaverEntityIconOff: null,
                          ScreensaverEntityValue: null,
                          ScreensaverEntityValueDecimalPlace : 0,
                          ScreensaverEntityValueUnit: null,
                          ScreensaverEntityOnColor: On,
                          ScreensaverEntityOffColor: HMIOff
                          mrIcon2ScreensaverEntity:
                          ScreensaverEntity: 'deconz.0.Sensors.5.open',
                          ScreensaverEntityIconOn: 'heat-wave',
                          ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                          ScreensaverEntityValueDecimalPlace : 1,
                          ScreensaverEntityValueUnit: '°',
                          ScreensaverEntityOnColor: MSRed,
                          ScreensaverEntityOffColor: Yellow
                            @tt-tom Bez. Tasmota Update - habe das Wiki mittlerw. gelesen:
                            -> Auf der Tasmota Seite ist eine Kurzbeschreibung und ihr könnt dort den Wizards downloaden.
                            Direkt Link zum Download Partition Wizard Tool
                            habe jetzt das Partition Wizard Tool downgeloaded, aber wie bekomme ich das jetzt auf das NSPanel?
                            • MichaelF
                              MichaelF @Gre4t0ne last edited by
                              @gre4t0ne said in SONOFF NSPanel mit Lovelace UI:
                              Hi, hochladen über das Filesystem :
                              • Armilar
                                Armilar Most Active Forum Testing last edited by
                                @gre4t0ne
                                Das ist ein Beispiel aus der NSPanelTS...
                                Dir fehlen ja bestimmt die Sensoren aus dem DeConz (sind ja irgendwie meine 😉 ). Kein Wunder mit den Fehlern...
                                Nimm stattdessen die aus der
                                https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs_without_Examples.ts
                                            ScreensaverEntity: NSPanel_Path + 'Relay.2',
                                  TT-Tom @Gre4t0ne last edited by
                                  @gre4t0ne
                                  Beim mrIcon2ScreensaverEntity, sind das deine Datenpunkte?? Sieht mir aus wie das Beispiel aus dem Script. Bitte an deine Umgebung anpassen oder die beiden Parameter auf null setzen.
                                    Danke an alle für die Hilfe!
                                    Muss der Partition Wizard nach der Migration wieder entfernt werden?
                                    • Armilar
                                      Armilar Most Active Forum Testing @Gre4t0ne last edited by
                                      @gre4t0ne
                                      Nach der Umpartitionierung ist er nicht mehr erforderlich... ja - sollte wieder entfernt werden
                                        manylopmy @TT-Tom last edited by manylopmy
                                        @TT-Tom
                                        Hallo Tom,
                                        anbei der Datenpunkt:
                                          "type": "state",
                                          "common": {
                                            "name": "State of Charge",
                                            "desc": "Actual state of charge",
                                            "type": "number",
                                            "role": "value.battery",
                                            "unit": "%",
                                            "read": true,
                                            "write": false,
                                            "custom": {
                                              "influxdb.0": {
                                                "enabled": true,
                                                "storageType": "",
                                                "aliasId": "",
                                                "debounceTime": 0,
                                                "blockTime": 0,
                                                "changesOnly": true,
                                                "changesRelogInterval": 0,
                                                "changesMinDelta": 0,
                                                "ignoreBelowNumber": "",
                                                "disableSkippedValueLogging": false,
                                                "enableDebugLogs": false,
                                                "debounce": 1000
                                          "native": {},
                                          "_id": "plenticore.0.devices.local.battery.SoC",
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                            "owner": "system.user.admin",
                                          "user": "system.user.admin",
                                          "ts": 1693377305117
                                        }code_text
                                        Wäre schön, wenn Du daran etwas ableiten kannst. Die Batterie ist voll, das Icon ist weiß. 😕
                                        Sorry, derzeitig (nach Neustart) ist das Icon leicht rosa. Keine schöne Farbe, aber eine andere. 😊 Der SoC Wert ist aktuell 90%. Ich sehe mal, wie er heute Nacht ist.
                                        Gruß Manfred
                                        Hier als Info und ein Danke an die Hilfe. Die Anzeige geht jetzt, ich habe das Rot noch etwas intensiviert, ist nun besser zu erkennen.
                                        • MichaelF
                                          @michaelf
                                          was steht denn darin?
                                          Wollte nur kurz bescheid geben das es wieder geht der dns war weg.......... Neu eingetragen und sofort ging die Firmware.
                                          Grüsse
                                            Tom_W last edited by
                                            ich habe endlich mal mein Skript geupdatet, leider konnte ich es nicht kompilieren.
                                            Er meckerte, dass ihm "ScreensaverEntityDateFormat:", fehlt.
                                            Hab das nun in allen bottomScreensaverEntity Seiten hinzugefügt, danach konnte ich es ohne Fehler kompilieren.
                                            Hab ich das was falsch gemacht?
                                            lovelace ui nspanel sonoff
                                            271
                                            7728
                                            6657197
