    3. Off Topic
    4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
      A Former User @Chris76e last edited by
      @chris76e sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
      hmm, bei Proxmox kann ich bei Machienentyp Standart (i440fx) oder q35 auswählen. Habe mir darüber keine gedanken gemacht. Läuft jetzt schon 2 Jahre damit.....
      Moin,
      die Einstellung I440fx oder q35 sagt nur wie der Speichercontroller oder andere Schnittstellen angebunden sind, wobei der q35 wohl der etwas aktuellere ist. Du kannst aber noch, den CPU Typ einstellen
      Hier die Erklärung -> https://deine.proxmox.ip:8006/pve-docs/chapter-qm.html#qm_system_settings
      CPU Type
      QEMU can emulate a number different of CPU types from 486 to the latest Xeon processors.
      Each new processor generation adds new features, like hardware assisted 3d rendering, random number generation,
      memory protection, etc.. Also, a current generation can be upgraded through microcode update with bug or security fixes.
      Usually you should select for your VM a processor type which closely matches the CPU of the host system,
      as it means that the host CPU features (also called CPU flags ) will be available in your VMs.
      If you want an exact match, you can set the CPU type to host in which case the VM will have exactly the
      same CPU flags as your host system.
      This has a downside though. If you want to do a live migration of VMs between different hosts, your VM might
      end up on a new system with a different CPU type or a different microcode version. If the CPU flags passed to
      the guest are missing, the QEMU process will stop. To remedy this QEMU has also its own virtual CPU types,
      that Proxmox VE uses by default.
      The backend default is kvm64 which works on essentially all x86_64 host CPUs and the UI default when creating
      a new VM is x86-64-v2-AES, which requires a host CPU starting from Westmere for Intel or at least a fourth
      generation Opteron for AMD.
      In short:
      If you don’t care about live migration or have a homogeneous cluster where all nodes have the same CPU and same
      microcode version, set the CPU type to host, as in theory this will give your guests maximum performance.
      If you care about live migration and security, and you have only Intel CPUs or only AMD CPUs, choose the lowest
      generation CPU model of your cluster.
      If you care about live migration without security, or have mixed Intel/AMD cluster, choose the lowest
      compatible virtual QEMU CPU type.
      VG
      Bernd
      • Duffy
        Duffy @Thomas Braun last edited by
        "Debian 12 'Bookworm' ist am 10.06.2023 als stabil veröffentlicht worden, allerdings sind einige Repositories von Dritten sind noch nicht richtig umgestellt. Insbesondere die Pakete für Raspberry OS sind noch auf dem Stand von Debian 11 'Bullseye'. Hier würde ich noch etwas abwarten."
        Hallo thomas-Braun,
        seit du hier beschrieben hast wie man auf Bookworm kommt ist ja schon einige Zeit vergangen.
        So weit ich gesehen habe gibt es den Bücherwurm für den Respberry immer noch nicht.
        Würdest du auch weiterhin zum abwaren raten?
        Mein System(chen) ist sonst so weit auf Stand bis auf den Bücherwurm.
        Mich würde dazu deine Expertiese interssieren.
        Viele Grüße Duffy
          Thomas Braun Most Active @Duffy last edited by
          @duffy sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
          Ich rate immer nur zu released versions.
          Alles andere dient lediglich zum Beta-testen.
          • Siggi0904
            Siggi0904 last edited by
            aber man ist wohl seitens Raspbian dran.
            Mein bullseye stable Repo wurde heute zum oldstable umbenannt.
              Thomas Braun Most Active @Siggi0904 last edited by
              @siggi0904 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
              Ja, das ist dann ein recht sicheres Zeichen, dass ein Release unmittelbar bevorsteht.
              Duffy 1 Reply Last reply Reply Quote 1
              • Duffy
                Würdest du dann bitte auch wieder erklären wie man für die installation vorgehen muss? (Wenn es so weit ist)
                  ? Steht doch im ersten Eintrag drin.
                    Homoran Global Moderator Administrators @Duffy last edited by
                    @duffy backup machen
                    neue SD Karte nehmen (alte bleibt für fallback)
                    OS lite 64bit installieren
                    iobroker installieren
                    (vis installieren)
                    Restore zurückspielen
                    warten....warten....warten
                    fertig
                    • Duffy
                      Muss das dann nicht auf eine andere Daten Quelle zugreifen wenn es ein Raspberry os ist?
                      Bei meinem Test Pi hatte ich das schon nach deiner Beschreibung erfogreich durchgeführt 🙂
                      @Homoran
                      Aber dann muss ich doch trotzdem noch Influxdb und grafana extra installieren, oder?
                        wenn du sowas nutzst, ja
                          @duffy
                          Die Repos werden soweit alle richtig umgestellt, wenn du der Anleitung folgst.
                          • Duffy
                            Duffy @Homoran last edited by
                            Oh weh, ich bin froh das es aktuell so weit läuft 😧
                            • 2afs
                              2afs @Thomas Braun last edited by
                              @thomas-braun Hallo, ich nutze seit längerem iobroker auf dem Raspi4 mit Raspbian 10 (buster). Nun möchte ich langsam auf Raspbian 11 oder gleich 12 updaten. Wie ist am besten vorzugehen? Funktioniert gleich auf 12 (gibt es das überhaupt?), oder in zwei Schritten oder eine Neuinstallation?
                              Homoran P 2 Replies Last reply Reply Quote 0
                                Homoran Global Moderator Administrators @2afs last edited by
                                @2afs sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                muss sehr bald herauskommen.
                                wird wohl noch was für den kommenden pi5 dran gefeilt
                                der Raspberry Pi 5 benötigt eine Speicherkarte mit dem aktuellsten Raspberry Pi OS "Bookworm". Dieses ist auch mit älteren Raspberry Pi Boards kompatibel - ältere Images laufen jedoch umgekehrt nicht auf dem Pi 5.
                                2afs M 2 Replies Last reply Reply Quote 1
                                • 2afs
                                  2afs @Homoran last edited by
                                  @homoran Danke. Also lieber warten bis PI OS 12 released ist und dann den Aufwand zur Umstellung. Sollte das in einem Schritt von 10 auf 12 funktionieren?
                                    wenn du damit meinst
                                    • backup erstellen
                                    • neue SD Karte nehmen
                                      • OS 12 installieren
                                      • ioBroker installieren
                                    • Backup zurückspielen
                                    feddisch!
                                    dann, ja!
                                    2afs 1 Reply Last reply Reply Quote 2
                                      Thomas Braun Most Active @2afs last edited by Thomas Braun
                                      Nein, du nimmst 11 mit.
                                      Oder halt direkt auf 12, das ist dann aber eine Neuinstallation (siehe @Homoran )
                                      • 2afs
                                        @thomas-braun @Homoran Danke Euch!
                                          MartyBr @Homoran last edited by
                                          @homoran Gibt es dazu schon ein Release Datum?
                                            Homoran Global Moderator Administrators @MartyBr last edited by
                                            @martybr sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                            Vorbestellungen werden ausschließlich als Komplettlieferungen und voraussichtlich Ende Oktober/Anfang November nach First-Come-First-Serve Prinzip ausgeliefert. Es kann zu Terminverschiebungen kommen.
                                            upgrade bullseye bookworm
                                            51
                                            351
                                            88720
