    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
    • Jey Cee
      Jey Cee Developer @Stoni last edited by
      @stoni du hast sicher auch deConz geupdated oder?
      Im Phoscon Forum findet sich der Fehler 951 auch: https://forum.phoscon.de/t/authenticated-request-resulting-in-internal-error-951/2943
        dos1973 @Jey Cee last edited by dos1973
        Hallo zusammen ich wollte um etwas Hilfe bitten.
        wollte mal alles auf Stand bringen, komme aber nicht weiter.
        iobroker läuft in Proxmox und hat Backups.
        Debian GNU/Linux 10 (buster)
        nodejs: v14.21.3
        js Controller: 4.0.23
        wenn ich dieseen Befehl ausführe
        curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                   SCRIPT DEPRECATION WARNING
          This script, located at https://deb.nodesource.com/setup_X, used to
          install Node.js is deprecated now and will eventually be made inactive.
          Please visit the NodeSource distributions Github and follow the
          instructions to migrate your repo.
          https://github.com/nodesource/distributions
          The NodeSource Node.js Linux distributions GitHub repository contains
          information about which versions of Node.js and which Linux distributions
          are supported and how to install it.
        TO AVOID THIS WAIT MIGRATE THE SCRIPT
        Continuing in 60 seconds (press Ctrl-C to abort) ...
        ## Installing the NodeSource Node.js 18.x repo...
        ## Populating apt-get cache...
        + apt-get update
        OK:1 http://security.debian.org/debian-security buster/updates InRelease
        OK:2 http://deb.debian.org/debian buster InRelease
        OK:3 http://deb.debian.org/debian buster-updates InRelease
        OK:4 https://deb.nodesource.com/node_14.x buster InRelease
        Ign:5 https://ookla.bintray.com/debian generic InRelease
        Fehl:6 https://ookla.bintray.com/debian generic Release
          Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 52.5.94.237 443]
        E: Das Depot »https://ookla.bintray.com/debian generic Release« enthält keine Release-Datei mehr.
        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
        Error executing command, exiting
        ich komme leider nicht weiter aufgrund der Certificate Meldung.
        Wäre für Hilfestellung dankbar
          Thomas Braun Most Active @dos1973 last edited by Thomas Braun
          @dos1973 sagte in Troubleshooting NodeJS update:
          Ja, versuch es mit:
          https://forum.iobroker.net/topic/68035/iob-node-fix-skript
          Und bring dein 'Buster' auf eine lebendige Version. Wir sind bei Debian 12 'Bookworm'.
          Die .list-Datei zu ookla-Speedtest musst du löschen, die wird nun so installiert:
          curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
          sudo apt update
          sudo apt install speedtest
            dos1973 @Thomas Braun last edited by
            Danke Dir für die Antwort.
            Ja das Buster läuft. Ewig… mir grauts etwas vor dem update. Kann ich direkt auf 12 gehen, oder muss ich erst auf die 11. anders gefragt, hast du ein Tipp/ Vorgehensweise?
              Ewig…
              Nichts läuft ewig. Buster ist schon seit einem Jahr tot:
              Beerdige das. Ich hab mal, als das Thema aktuell war, ein HowTo dazu geschrieben. Schau durch meine Themen durch. Ein direkter Sprung auf Bookworm ist nicht zu empfehlen, nimm Bullseye mit.
                Danke Dir für die Update Hilfe.
                PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                NAME="Debian GNU/Linux"
                VERSION_ID="12"
                VERSION="12 (bookworm)"
                VERSION_CODENAME=bookworm
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                  @dos1973
                  Und war es so grauenvoll wie befürchtet?
                    dos1973 @Thomas Braun last edited by dos1973
                    nein, deiner Beschreibung gefolgt (1A) und alles lief Perfekt.
                      austrogaucho last edited by
                      "curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -" hat funktioniert und hat mich von von 16.20.1 (nur) auf 18.7.1 gehoben (18.8.0 ist empfohlen)
                      es kam aber folgende Meldung:
                      nach 1min gehts dann weiter mit:
                      + apt-get update
                      OK:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
                      OK:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                      OK:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                      OK:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
                      OK:5 https://deb.nodesource.com/node_18.x focal InRelease
                      ## Confirming "focal" is supported...
                      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/focal/Release'
                      ## Adding the NodeSource signing key to your keyring...
                      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                      ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x focal main' > /etc/apt/sources.list.d/nodesource.list
                      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x focal main' >> /etc/apt/sources.list.d/nodesource.list
                      ## Running `apt-get update` for you...
                      + apt-get update
                      ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                      ## You may also need development tools to build native addons:
                           sudo apt-get install gcc g++ make
                      ## To install the Yarn package manager, run:
                           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                           echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                           sudo apt-get update && sudo apt-get install yarn
                      Ich hab dann gemäß der Anleitung mit "sudo apt install -y nodejs" weitergemacht
                      dann kam
                      Die folgenden NEUEN Pakete werden installiert:
                        nodejs
                      0 aktualisiert, 1 neu installiert, 0 zu entfernen und 14 nicht aktualisiert.
                      Es müssen 28,9 MB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 188 MB Plattenplatz zusätzlich benutzt.
                      Holen:1 https://deb.nodesource.com/node_18.x focal/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28,9 MB]
                      Es wurden 28,9 MB in 5 s geholt (5.334 kB/s).
                      Vormals nicht ausgewähltes Paket nodejs wird gewählt.
                      (Lese Datenbank ... 121482 Dateien und Verzeichnisse sind derzeit installiert.)
                      Vorbereitung zum Entpacken von .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
                      Entpacken von nodejs (18.17.1-deb-1nodesource1) ...
                      nodejs (18.17.1-deb-1nodesource1) wird eingerichtet ...
                      Trigger für man-db (2.9.1-1) werden verarbeitet ...
                      ? wie komm ich nun auf die 18.8.0 ?
                        Thomas Braun Most Active @austrogaucho last edited by
                        @austrogaucho
                        Mit dem Skript aus meiner Signatur.
                        Pedder007 1 Reply Last reply Reply Quote 0
                        • Pedder007
                          Pedder007 @Thomas Braun last edited by Pedder007
                          @thomas-braun sagte in Troubleshooting NodeJS update:
                          Klasse Script! Hatte 'gefühlt' alle Zustände bzgl. des 18.18.0 er Updates:
                          • 1x iOMaster, dediziert auf Raspi4B, mit in Info angezeigtem Update, allerdings keine Anzeige/Update per 'sudo apt update'.
                          • 4x vermeintlich gleiche iOSlaves unter Proxmox, allerdings manchmal mit angezeigtem Update in Info und manchmal nicht und dann wiederum manchmal möglichem 'sudo apt update' per Konsole, allerdings auch nicht jeweils gleich bzgl. der in Info angezeigten Updates.
                          Also eine bunte Mischung, wobei Ausgangslage überall der letzte Stand mit Node 18.17.1 inkl. passendem NPM war und ich auch im Glauben war, dass ich alle Instanzen immer gleich behandelt hatte.
                          Mit dem Script habe ich sie alle 'gerade' bekommen. Danke @thomas-braun
                            Happyuser20 last edited by Happyuser20
                            Hallo zusammen.
                            Ich wollte auf meinem IOB Slave (Raspi 3+) NodeJS von 16 auf 18 updaten.
                            Ich fürchte ich habe das Teil komplett abgeschossen. Habe jetzt einen Raspi mit IOB ohne NodeJS.
                            Es lässt sich auch das erstellte Backup nicht mehr zurückspielen.
                            @Thomas-Braun Dein Script knackt meine vermurkste Installation auch nicht 😞
                            *** nodejs is NOT correctly installed ***
                            We found these nodejs versions available for installation:
                            nodejs:
                              Installed: (none)
                              Candidate: 18.18.2-1nodesource1
                              Version table:
                                 18.18.2-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                            Press <y> to continue or any other key to quit
                            Fixing your nodejs setup
                            *** Deleting  ***
                            rm: cannot remove '': No such file or directory
                            *** Deleting  ***
                            *** Deleting  ***
                            Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
                            ./iob_node_update: line 248: node: command not found
                            You are running nodejs . Do you want to install latest version from nodejs v.18 branch?
                            Trying to fix your installation now. Please be patient.
                            Waiting for ioBroker to shut down - Give me a minute...
                            *** Removing previous installations of nodejs
                            E: Unable to locate package nodejs
                            E: Unable to locate package libnode*
                            E: Couldn't find any package by glob 'libnode*'
                            E: Couldn't find any package by regex 'libnode*'
                            E: Unable to locate package node-*
                            E: Couldn't find any package by glob 'node-*'
                            E: Couldn't find any package by regex 'node-*'
                            *** These repos are active on your system:
                            Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                            Ign:2 http://raspbian.raspberrypi.org/raspbian stretch Release
                            Ign:3 http://raspbian.raspberrypi.org/raspbian stretch/main all Packages
                            Ign:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                            Ign:5 http://raspbian.raspberrypi.org/raspbian stretch/main Translation-en
                            Ign:6 http://raspbian.raspberrypi.org/raspbian stretch/contrib all Packages
                            Ign:7 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
                            Ign:8 http://raspbian.raspberrypi.org/raspbian stretch/contrib Translation-en
                            Ign:9 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
                            Ign:10 http://raspbian.raspberrypi.org/raspbian stretch/non-free all Packages
                            Ign:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free Translation-en
                            Ign:12 http://raspbian.raspberrypi.org/raspbian stretch/rpi all Packages
                            Ign:13 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages
                            Ign:14 http://raspbian.raspberrypi.org/raspbian stretch/rpi Translation-en
                            Err:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                              404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
                            Reading package lists... Done
                            W: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does not have a Release file.
                            N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
                            N: See apt-secure(8) manpage for repository creation and user configuration details.
                            E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/main/binary-armhf/Packages  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
                            E: Some index files failed to download. They have been ignored, or old ones used instead.
                            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                            Package: nodejs
                            Pin: origin deb.nodesource.com
                            Pin-Priority: 1001
                            *** These repos are active after the adjustments:
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Ign:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                            Ign:6 http://raspbian.raspberrypi.org/raspbian stretch/main Translation-en
                            Ign:7 http://raspbian.raspberrypi.org/raspbian stretch/contrib all Packages
                            Ign:8 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
                            Ign:9 http://raspbian.raspberrypi.org/raspbian stretch/contrib Translation-en
                            Ign:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
                            Ign:12 http://raspbian.raspberrypi.org/raspbian stretch/non-free Translation-en
                            Ign:14 http://raspbian.raspberrypi.org/raspbian stretch/rpi all Packages
                            Ign:15 http://raspbian.raspberrypi.org/raspbian stretch/rpi Translation-en
                            Err:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                            Installing the recommended nodejs version now!
                            ./iob_node_update: line 336: [: : integer expression expected
                            Exact recommended version unknown, installing a fallback!
                            E: Unable to correct problems, you have held broken packages.
                            Updating fallback to latest nodejs v18 release
                            E: Broken packages
                            ./iob_node_update: line 349: node: command not found
                             has been installed! You are using the latest version now!
                            ./iob_node_update: line 353: [: : integer expression expected
                            Installing the recommended nodejs version!
                            E: Broken packages
                            We tried our best to fix your nodejs. Please run iob diag again to verify.
                            *** RESTARTING ioBroker NOW! ***
                             Please refresh or restart your browser in a few moments.
                            Gibt es noch eine Möglichkeit das ding zu retten?
                            Danke für eure Hilfe schon mal im voraus.
                              Thomas Braun Most Active @Happyuser20 last edited by
                              @happyuser20
                              Dein 'stretch' ist so tot, das stinkt nicht mal mehr. Installier da zunächst ein lebendes Betriebssystem.
                                Happyuser20 @Thomas Braun last edited by
                                Komplett neu aufsetzten, richtig?
                                Sorry für die doofe Frage.
                                  @happyuser20
                                  Röchtösch!
                                    Dann weis ich schon was ich am Feiertag mache 😉
                                      Baki074 last edited by
                                      ich habe mit dem Befehl sudo apt install -y nodejs Probleme.
                                      Und zwar erhalte ich die Meldung "Fehlschlag beim Holen von...".
                                      sudo apt-get update habe ich schon versucht. Hat für die Installation nichts gebracht - derselbe Fehler wird angezeigt.
                                      Was genau muss ich machen, damit die Installation klappt?
                                      Danke schonmal!
                                      pi@phoscon-iob:~ $ sudo apt install -y nodejs
                                        nodejs
                                      0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                      Es müssen 25,9 MB an Archiven heruntergeladen werden.
                                      Nach dieser Operation werden 177 MB Plattenplatz zusätzlich benutzt.
                                      Fehl:1 https://deb.nodesource.com/node_18.x buster/main armhf nodejs armhf 18.17.1-deb-1nodesource1
                                        404  Not Found [IP: 172.67.10.205 443]
                                      E: Fehlschlag beim Holen von https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.17.1-deb-1nodesource1_armhf.deb 404  Not Found [IP: 172.67.10.205 443]
                                      E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                                      pi@phoscon-iob:~ $ sudo apt-get update
                                      OK:1 http://phoscon.de/apt/deconz buster InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                      OK:4 https://deb.nodesource.com/node_18.x buster InRelease
                                        Thomas Braun Most Active @Baki074 last edited by
                                        @baki074
                                        Buster ist tot. Muss ersetzt werden.
                                        Und das Update von nodejs geht über
                                        iob nodejs-update
                                        (Ggfls. zuvor iob fix ausführen).
                                          Baki074 @Thomas Braun last edited by
                                          @thomas-braun Super, hat funktioniert - danke!
                                          Blöde Frage: Kann ich Debian 10 easy durch 11 ersetzen bzw. gibt es vielleicht eine Schritt für Schritt Anleitung hierfür?
                                            Thomas Braun Most Active @Baki074 last edited by Thomas Braun
                                            @baki074
                                            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                            Aktuell ist allerdings Debian 12 'Bookworm'.
                                            https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143266
