    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      firepower75 @firepower75 last edited by firepower75
      Guten Morgen...
      Scheint immer noch nicht korrekt zu funktionieren:
      vw-connect.0 2023-09-14 08:35:12.468	info	Found 1 vehicles
      vw-connect.0 2023-09-14 08:35:12.248	info	{"mandatoryConsentInfo":[{"id":"termsOfUse","status":"VALID"}],"mandatoryFieldsStatus":true,"mbbIdStatus":true,"mbbUserId":"dea**********************","missingMandatoryFields":[],"scopeId":"commonMandatoryFields","spinStatus":true,"ssoId":"7b992493-****-****-88d2-**************"}
      vw-connect.0 2023-09-14 08:35:11.720	info	Login successful
      vw-connect.0 2023-09-14 08:35:09.318	info	Login in with seatcupra2
      vw-connect.0 2023-09-14 08:35:09.141	info	starting. Version 0.1.2 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.17.1, js-controller: 4.0.24
      Unschön... Also weiterhin warten...
      Greetz
      Firepower
        Giermann @firepower75 last edited by
        @firepower75 meine Skoda-App spinnt heute auch rum (ich meine aber, gestern ging sie noch). Aber der Adapter läuft bei mir (noch) fehlerfrei...
          lesiflo Most Active last edited by lesiflo
          Hi, seit dem Update unseres ID.4 auf die SW Version 3.1 kommen jede Menge von diesen Warnings hier. Jemand eine Idee wie ich die weg bekomme.
          vw-connect.0
          2023-09-21 08:49:20.541	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleWakeUpTrigger" is missing the required property "common.type"
          vw-connect.0
          2023-09-21 08:49:20.493	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleLights" is missing the required property "common.type"
          vw-connect.0
          2023-09-21 08:49:20.445	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleHealthWarnings" is missing the required property "common.type"
          vw-connect.0
          2023-09-21 08:49:20.397	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleHealthInspection" is missing the required property "common.type"
          vw-connect.0
          2023-09-21 08:49:20.352	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleHealth" is missing the required property "common.type"
          vw-connect.0
          2023-09-21 08:49:20.277	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.state" is missing the required property "common.type"
          vw-connect.0
          2023-09-21 08:49:20.193	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.poiSearch" is missing the required property "common.type"
          T S 2 Replies Last reply Reply Quote 0
            tombox @lesiflo last edited by
            @lesiflo Hast du mal alle objektgelöschte und adapter neugestartet
              Sneak-L8 @lesiflo last edited by
              @lesiflo Das könnte das Problem sein, dass bei Werte-Paaren im JSON intern daraus Einzelwerte gemacht werden.
              Beispiel:
                  "userCapabilities": {
                      "capabilitiesStatus": {
                          "value": [{
                                  "id": "webApp",
                                  "userDisablingAllowed": false
                                  "id": "automation",
                                  "userDisablingAllowed": true
              Hier wird de id (webApp, automation) als Key und übernommen und darunter der Wert abgelegt.
              Wenn im Array mehr als 2 Einträge vorkommen, dann werdne sie aber anders beahndelt:
                      "value": [{
                              "id": "webApp",
                              "expirationDate": "2052-12-26T23:59:59Z",
                              "id": "automation",
                              "expirationDate": "2023-12-26T00:00:00Z",
              Bei VW kommen aber (meine Erfahrung meist kurz nach Mitternacht) mal zwei und mal drei Werte. Und dadurch kommt es dann zu Fehlern wie
              warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.webApp" is missing the required property "common.type"
              weil webApp bei 2 Werten als state ud nicht mehr als channel betrachtet wird.
              Das könnte hier auch so ein Problem sein. Wenn sich die Struktur aber "nur" aufgrund des Updates, also dauerhaft, geändert hat, dann könnte es wie von @tombox beschrieben reichen, die vorhandenen Objekte zu löschen.
              Aber ich glaube, es ist (da es bei Dir auch um die capabilities geht) eher das oben beschriebene Problem. Ist damit vermutlich in Kürze weg und tritt sporadisch auf, wenn VW gerade mal wieder nicht die Ablaufdaten der Services kennt.
                lesiflo Most Active @tombox last edited by
                @tombox Das hatte das Problem behoben. Danke fürs den Tip.
                  SolarMaxe @lesiflo last edited by SolarMaxe
                  ich habe vom GitHub die Version 0.1.2 installiert.
                  Der Adapter funktioniert soweit auch Problemlos für meinen Audi Hybrid.
                  Allerdings bekomme ich folgende Fehlermeldung:
                  State "vw-connect.0.WAU1234567.remote.climatisationv2" has no existing object, this might lead to an error in future versions
                  das Objekt climatisationv2 ist auch im Objekt Baum nicht vorhanden.
                  Kennt einer von euch das Problem und kann mir helfen?
                    mick70 last edited by
                    Folgende Fehlermeldungen exakt alle 30 Minuten, seit heute morgen 7:40:
                    vw-connect.0
                    2023-09-24 17:40:10.758	error	Refresh Token in 10min
                    vw-connect.0
                    2023-09-24 17:40:10.758	error	{"error":{"errorCode":"gw.error.unknown","description":"Invalid backend error"}}
                    vw-connect.0
                    2023-09-24 17:40:10.757	error	401
                    vw-connect.0
                    2023-09-24 17:40:10.753	error	WVWZZZAUZL89xxxxx
                    Der übliche Server-Schluckauf bei VW oder was anderes? Installiert ist 0.1.2 von Github.
                    M G 2 Replies Last reply Reply Quote 0
                      Schtallone last edited by
                      @mick70
                      Moin,
                      ich schließe mich an. Habe die selben Meldungen seit ca. 2-3 Tagen...
                        mick70 @mick70 last edited by mick70
                        @mick70 Ergänzung: jetzt kommen die Fehlermeldungen (wie angekündigt) im 10 Minuten Abstand alle 20 Minuten.
                        Die Datenpunkte scheinen aktuell zu sein, also ist es wohl nicht das übliche Serverproblem. Remotefunktionen kann ich erst heute Nachmittag ausprobieren, bin dzt. zu weit weg vom Auto.
                        Fzg.: e-Golf.
                        • Hant0r
                          Hant0r last edited by
                          Habe das Problem nicht (Skoda) 🤷‍♂️
                            SolarMaxe @Schtallone last edited by
                            Hab den Fehler seit heute:
                            2023-09-25 15:12:56.358 - error: vw-connect.0 (14492) [{"message":"network timeout at: ","locations":[{"line":10,"column":5}],"path":["userVehicles",0,"userRole"],"extensions":{"code":"INTERNAL_SERVER_ERROR","exception":{"message":"network timeout at: ","type":"request-timeout"}}}]
                            2023-09-25 15:12:56.359 - error: vw-connect.0 (14492) Get Vehicles Failed
                              guitardoc @mick70 last edited by
                              @mick70 said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                              vw-connect.0
                              vw-connect.0
                              vw-connect.0
                              vw-connect.0
                              Ebenso. Bei mir VW Touareg. Das Log ist voll mit dem Fehler...
                                tombox @guitardoc last edited by
                                @guitardoc bitte v0.1.3 testen
                                  guitardoc @tombox last edited by
                                  @tombox said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                  Wo finde ich die Version?
                                    mick70 @guitardoc last edited by
                                    @guitardoc https://github.com/TA2k/ioBroker.vw-connect
                                    @tombox Scheint zu funktionieren, bisher keine Meldungen mehr - vielen Dank!
                                      Bei mir auch - funktioniert. Vielen Dank!
                                        guitardoc @guitardoc last edited by
                                        Es kommen seit heute neue Meldungen:
                                          A Former User @guitardoc last edited by A Former User
                                          @guitardoc sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                          Moin,
                                          VW hatte eine IT Störung, es hieß zwar immer, die Produktion sei betroffen, aber hat vielleicht auch Auswirkungen auf andere Systeme.
                                          Anscheinend läuft es wieder.
                                          https://www.ndr.de/nachrichten/niedersachsen/braunschweig_harz_goettingen/IT-Stoerung-bei-VW-behoben-Produktion-laeuft-weltweit-wieder-an,vw6040.html
                                          VG
                                          Bernd
                                          P.S.: Welche Version vom Adapter und Text bitte nicht als Bild, sondern als Text in Code Tags </>
                                            mick70 @Guest last edited by mick70
                                            @dp20eic Den gleichen Fehler hatte ich - ohne backend timeout - mit v 0.1.3 auch, aber nur einmalig heute Nacht um 0:45.
                                            vw-connect.0
                                            2023-09-28 08:00:45.776	error	{"error":{"errorCode":"VSR.technical.9031","description":"Service [TSS] timed out"}}
                                            vw-connect.0
                                            2023-09-28 08:00:45.775	error	504
                                            Könnte dieses Mal tatsächlich serverbezogen sein.
                                            1.0k
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1599774
