Lupusec Adapter - keine Objekte
@von-cartman
Ohne @Thomas-Braun jetzt vorgreifen zu wollen:
Mit welchem Account gehst Du an die Lupus?
Hat das Kennwort Sonderzeichen? Die mag der Adapter nicht unbedingt.
Ich habe einen separaten Account mit einem Kennwort ohne Sonderzeichen angelegt, damit das funktioniert. -
log aus --watch2023-09-25 11:12:47.847 - info: host.xxx stopInstance system.adapter.lupusec.0 (force=false, process=true) 2023-09-25 11:12:47.855 - info: lupusec.0 (4863) Got terminate signal TERMINATE_YOURSELF 2023-09-25 11:12:47.870 - info: lupusec.0 (4863) terminating 2023-09-25 11:12:47.871 - info: lupusec.0 (4863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-09-25 11:12:47.896 - info: host.xxx stopInstance system.adapter.lupusec.0 send kill signal 2023-09-25 11:12:48.429 - info: host.xxx instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-25 11:12:47.847 - info: host.xxx stopInstance system.adapter.lupusec.0 (force=false, process=true) 2023-09-25 11:12:47.855 - info: lupusec.0 (4863) Got terminate signal TERMINATE_YOURSELF 2023-09-25 11:12:47.870 - info: lupusec.0 (4863) terminating 2023-09-25 11:12:47.871 - info: lupusec.0 (4863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-09-25 11:12:47.896 - info: host.xxx stopInstance system.adapter.lupusec.0 send kill signal 2023-09-25 11:12:48.429 - info: host.xxx instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-25 11:12:50.962 - info: host.xxx instance system.adapter.lupusec.0 started with pid 14146 2023-09-25 11:12:53.578 - info: lupusec.0 (14146) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.lupusec, node: v20.5.1, js-controller: 4.0.24 2023-09-25 11:12:53.605 - info: lupusec.0 (14146) Starting Adapter lupusec.0 in version 1.3.6 2023-09-25 11:12:53.671 - info: lupusec.0 (14146) Lupusec Alarmsystem 192.168.178.xx is alive 2023-09-25 11:12:53.672 - info: lupusec.0 (14146) Checking the ioBroker Lupusec configuration 2023-09-25 11:12:53.751 - info: lupusec.0 (14146) Connecting to Lupusec with http://192.168.178.xx:80 2023-09-25 11:12:53.752 - info: lupusec.0 (14146) Polltime 1 sec. 2023-09-25 11:12:53.578 - info: lupusec.0 (14146) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.lupusec, node: v20.5.1, js-controller: 4.0.24 2023-09-25 11:12:53.605 - info: lupusec.0 (14146) Starting Adapter lupusec.0 in version 1.3.6 2023-09-25 11:12:53.671 - info: lupusec.0 (14146) Lupusec Alarmsystem 192.168.178.xx is alive 2023-09-25 11:12:53.672 - info: lupusec.0 (14146) Checking the ioBroker Lupusec configuration 2023-09-25 11:12:53.751 - info: lupusec.0 (14146) Connecting to Lupusec with http://192.168.178.xx:80 2023-09-25 11:12:53.752 - info: lupusec.0 (14146) Polltime 1 sec.
log aus diag
Skript v.2023-06-20
*** BASE SYSTEM ***
Static hostname: hostname
Icon name: computer
Machine ID: a19d3c104915489fb3373c36082b8984
Boot ID: d9bbd3dae5be4cd691d3b5baa5999441
Operating System: Raspbian GNU/Linux 11 (bullseye)
Kernel: Linux 6.1.21-v8+
Architecture: arm64Model : Raspberry Pi 4 Model B Rev 1.5
Docker : false
Virtualization : none
Kernel : aarch64
Userland : armhfSystemuptime and Load:
11:14:20 up 18 days, 17:46, 1 user, load average: 0.18, 0.20, 0.21
CPU threads: 4Raspberry only:
throttled=0x0
Other values than 0x0 hint to temperature/voltage problems
temp=30.1'C
volt=0.9360V*** Time and Time Zones ***
Local time: Mon 2023-09-25 11:14:20 CEST
Universal time: Mon 2023-09-25 09:14:20 UTC
RTC time: n/a
NTP service: active
RTC in local TZ: no*** User and Groups ***
pi
/home/pi
pi adm dialout cdrom sudo audio www-data video plugdev games users input render netdev gpio i2c spi iobroker*** X-Server-Setup ***
X-Server: false
Desktop:
Terminal: tty
Boot Target: multi-user.target*** MEMORY ***
total used free shared buff/cache available
Mem: 7.8G 557M 6.4G 1.0M 901M 7.1G
Swap: 99M 0B 99M
Total: 7.9G 557M 6.5G7812 M total memory 557 M used memory 640 M active memory 688 M inactive memory 6353 M free memory 66 M buffer memory 834 M swap cache 99 M total swap 0 M used swap 99 M free swap
Raspberry only:
oom events: 0
max time spent in oom handler: 0 ms*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 58G 3.7G 52G 7% /
devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs tmpfs 1.6G 1.1M 1.6G 1% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/mmcblk0p1 vfat 255M 51M 205M 20% /boot
tmpfs tmpfs 782M 0 782M 0% /run/user/1000Messages concerning ext4 filesystem in dmesg:
[Wed Sep 6 17:28:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:25:3E:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=8736cee2-02 rootfstype=ext4 fsck.repair=yes rootwait
[Wed Sep 6 17:28:20 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[Wed Sep 6 17:28:20 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[Wed Sep 6 17:28:21 2023] EXT4-fs (mmcblk0p2): recovery complete
[Wed Sep 6 17:28:21 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[Wed Sep 6 17:28:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[Wed Sep 6 17:28:23 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.Show mounted filesystems (real ones only):
TARGET SOURCE FSTYPE OPTIONS
/ /dev/mmcblk0p2 ext4 rw,noatime
`-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-roFiles in neuralgic directories:
/var:
521M /var/
197M /var/cache
192M /var/cache/apt
130M /var/log
129M /var/log/journal/a19d3c104915489fb3373c36082b8984Archived and active journals take up 128.0M in the file system.
/opt/iobroker/backups:
425M /opt/iobroker/backups//opt/iobroker/iobroker-data:
317M /opt/iobroker/iobroker-data/
282M /opt/iobroker/iobroker-data/files
78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
32M /opt/iobroker/iobroker-data/files/vis.0/visu
32M /opt/iobroker/iobroker-data/files/vis.0The five largest files in iobroker-data are:
21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
7.1M /opt/iobroker/iobroker-data/files/vis.0/visu/20230905_EG3.png
6.5M /opt/iobroker/iobroker-data/files/vis.0/visu/20230905_OG3.png
6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map*** NodeJS-Installation ***
/usr/bin/nodejs v20.5.1
/usr/bin/node v20.5.1
/usr/bin/npm 9.8.0
/usr/bin/npx 9.8.0nodejs:
Installed: 20.5.1-deb-1nodesource1
Candidate: 20.5.1-deb-1nodesource1
Version table:
*** 20.5.1-deb-1nodesource1 500
500 https://deb.nodesource.com/node_20.x bullseye/main armhf Packages
100 /var/lib/dpkg/status
12.22.12~dfsg-1~deb11u4 500
500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf PackagesTemp directories causing npm8 problem: 0
No problems detectedErrors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
iobroker is running on this host.Objects type: jsonl
States type: jsonlNo configuration change needed.
Multihost discovery server: disabled
Discovery authentication: enabled
Persistent activation: disabled
Objects: jsonl on 127.0.0.1
States: jsonl on 127.0.0.1Core adapters versions
admin: 6.8.0
javascript: "javascript" not foundAdapters from github: 0
Adapter State
system.adapter.admin.0 : admin : hostname - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
system.adapter.backitup.0 : backitup : hostname - enabled
system.adapter.discovery.0 : discovery : hostname - enabled
system.adapter.ical.0 : ical : hostname - enabled
system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: hostname - enabled
system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : hostname - enabled
system.adapter.icons-icons8.0 : icons-icons8 : hostname - enabled
system.adapter.icons-material-png.0 : icons-material-png : hostname - enabled
system.adapter.icons-material-svg.0 : icons-material-svg : hostname - enabled
system.adapter.icons-mfd-png.0 : icons-mfd-png : hostname - enabled
system.adapter.icons-mfd-svg.0 : icons-mfd-svg : hostname - enabled
system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: hostname - enabled
system.adapter.icons-ultimate-png.0 : icons-ultimate-png : hostname - enabled
system.adapter.kostal-piko-ba.0 : kostal-piko-ba : hostname - disabled -
system.adapter.lupusec.0 : lupusec : hostname - enabled
system.adapter.openknx.0 : openknx : hostname - enabled
system.adapter.trashschedule.0 : trashschedule : hostname - enabled
system.adapter.vis-bars.0 : vis-bars : hostname - enabled
system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : hostname - enabled
system.adapter.vis-fancyswitch.0 : vis-fancyswitch : hostname - enabled
system.adapter.vis-google-fonts.0 : vis-google-fonts : hostname - enabled
system.adapter.vis-hqwidgets.0 : vis-hqwidgets : hostname - enabled
system.adapter.vis-icontwo.0 : vis-icontwo : hostname - enabled -
system.adapter.vis-inventwo.0 : vis-inventwo : hostname - enabled
system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : hostname - enabled
system.adapter.vis-justgage.0 : vis-justgage : hostname - enabled
system.adapter.vis-keyboard.0 : vis-keyboard : hostname - enabled
system.adapter.vis-rgraph.0 : vis-rgraph : hostname - enabled
system.adapter.vis.0 : vis : hostname - enabled -
system.adapter.web.0 : web : hostname - enabled, port: 8082, bind: 0.0.0.0, run as: admin
instance is alive
- system.adapter.admin.0 : admin : hostname - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
- system.adapter.web.0 : web : hostname - enabled, port: 8082, bind: 0.0.0.0, run as: admin
ioBroker-Repositories
stable : http://download.iobroker.net/sources-dist.json
beta : http://download.iobroker.net/sources-dist-latest.jsonActive repo(s): stable
Installed ioBroker-Instances
Used repository: stable
Adapter "admin" : 6.10.1 , installed 6.8.0 [Updatable]
Adapter "backitup" : 2.8.1 , installed 2.6.23 [Updatable]
Adapter "discovery" : 3.1.0 , installed 3.1.0
Adapter "ical" : 1.13.3 , installed 1.13.3
Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0
Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
Adapter "icons-material-png": 0.1.0, installed 0.1.0
Adapter "icons-material-svg": 0.1.0, installed 0.1.0
Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
Controller "js-controller": 5.0.12 , installed 4.0.24 [Updatable]
Adapter "kostal-piko-ba": 3.0.6 , installed 3.0.3 [Updatable]
Adapter "lupusec" : 1.3.6 , installed 1.3.6
Adapter "openknx" : 0.5.3 , installed 0.5.3
Adapter "simple-api" : 2.7.2 , installed 2.7.2
Adapter "socketio" : 6.5.5 , installed 6.5.2 [Updatable]
Adapter "trashschedule": 2.2.0 , installed 2.2.0
Adapter "vis" : 1.4.16 , installed 1.4.16
Adapter "vis-bars" : 0.1.4 , installed 0.1.4
Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0
Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2
Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
Adapter "web" : 6.1.2 , installed 6.1.0 [Updatable]
Adapter "ws" : 2.5.5 , installed 2.5.3 [Updatable]Objects and States
Objects: 728
States: 580*** OS-Repositories and Updates ***
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Get:3 https://deb.nodesource.com/node_20.x bullseye InRelease [4586 B]
Fetched 4586 B in 1s (6528 B/s)
Reading package lists...
Pending Updates: 8*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 14886 481/iobroker.js-con
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 14881 481/iobroker.js-con
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14833 512/sshd: /usr/sbin
tcp6 0 0 :::8082 :::* LISTEN 1001 14174 1014/io.web.0
tcp6 0 0 :::8081 :::* LISTEN 1001 14120 802/io.admin.0
tcp6 0 0 :::22 :::* LISTEN 0 14843 512/sshd: /usr/sbin
tcp6 0 0 :::21 :::* LISTEN 0 13725 498/vsftpd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11247 393/avahi-daemon: r
udp 0 0 0.0.0.0:50946 0.0.0.0:* 1001 17037 2340/io.openknx.0
udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15736 697/dhcpcd
udp 0 0 0.0.0.0:57474 0.0.0.0:* 108 11249 393/avahi-daemon: r
udp6 0 0 :::5353 :::* 108 11248 393/avahi-daemon: r
udp6 0 0 :::41196 :::* 108 11250 393/avahi-daemon: r
udp6 0 0 :::546 :::* 0 17640 697/dhcpcd*** Log File - Last 25 Lines ***
2023-09-25 10:53:05.385 - info: admin.0 (802) ==> Connected system.user.admin from ::ffff:192.168.178.xxx
2023-09-25 10:53:24.993 - info: admin.0 (802) <== Disconnect system.user.admin from ::ffff:192.168.178.xxx admin
2023-09-25 10:53:25.388 - info: admin.0 (802) <== Disconnect system.user.admin from ::ffff:192.168.178.xxx admin
2023-09-25 11:00:00.026 - info: host.hostname instance system.adapter.ical.0 started with pid 9087
2023-09-25 11:00:02.278 - info: ical.0 (9087) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v20.5.1, js-controller: 4.0.24
2023-09-25 11:00:02.831 - warn: ical.0 (9087) Error reading from URL "https://calendar.google.com/calendar/ical/e2daae7e222895baf6cf02054af6f0566e3cd1a2d929409b9c53a8292153df2f%40group.calendar.google.com/public/basic.ics": 404
2023-09-25 11:00:02.833 - info: ical.0 (9087) Use cached File content for "https://calendar.google.com/calendar/ical/e2daae7e222895baf6cf02054af6f0566e3cd1a2d929409b9c53a8292153df2f%40group.calendar.google.com/public/basic.ics" from Tue Sep 05 2023 17:22:45 GMT+0200 (Central European Summer Time)
2023-09-25 11:00:02.862 - info: ical.0 (9087) processing URL: muell https://calendar.google.com/calendar/ical/e2daae7e222895baf6cf02054af6f0566e3cd1a2d929409b9c53a8292153df2f%40group.calendar.google.com/public/basic.ics
2023-09-25 11:00:08.007 - info: ical.0 (9087) Terminated (NO_ERROR): Without reason
2023-09-25 11:00:08.542 - info: host.hostname instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
2023-09-25 11:08:11.008 - info: admin.0 (802) ==> Connected system.user.admin from ::ffff:192.168.178.xxx
2023-09-25 11:08:13.411 - info: admin.0 (802) ==> Connected system.user.admin from ::ffff:192.168.178.xxx
2023-09-25 11:12:47.847 - info: host.hostname stopInstance system.adapter.lupusec.0 (force=false, process=true)
2023-09-25 11:12:47.896 - info: host.hostname stopInstance system.adapter.lupusec.0 send kill signal
2023-09-25 11:12:48.429 - info: host.hostname instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-09-25 11:12:50.962 - info: host.hostname instance system.adapter.lupusec.0 started with pid 14146
2023-09-25 11:12:53.752 - info: lupusec.0 (14146) Polltime 1 sec.============ Mark until here for C&P =============
Ist kein Vorgreifen. Offenbar hast du ja mehr mit dem Adapter zu tun und stocherst da nicht so ganz im Nebel.
@von-cartman sagte in Lupusec Adapter - keine Objekte:
node: v20.5.1
Zu neu. Geh da auf die Empfehlung nodejs@18.
Dafür könntest du den Rest an Adaptern inkl. dem js-controller auf einen aktuellen Stand bringen. -
@thomas-braun sagte in Lupusec Adapter - keine Objekte:
gibt es anleitung?
mit dem Befehlt:
curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
hat es nicht funktioniert.
gibt es anleitung?
Gibt sogar skript.
Schau in meine Signatur. -
Vielen DANK !
Hat 1a Funktioniert. -
Und der Adapter rennt auch?
JA,
der Downgrade hat 1A funktioniert, und mit Node:18 rennt der Adapter auchNochmals: VIELEN DANK für die geschwindigkeit und fachwissen
Dann kannst du ja jetzt den Rest updaten.
