    4. JavaScript
    5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
      sigi234 Forum Testing Most Active @ticaki last edited by
      @ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
      So mal kein grundsätzlicher Fehler im Release Script - Version sollte jetzt bei
      v0.2.1-alpha.0
      bleiben und auch auf der Github Seite angezeigt werden.
      • Latzi
        Latzi @ticaki last edited by
        EDIT2: Nochmal bitte
        Astrein, log ist sauber 👍
        2023-09-25 12:07:24.280 - info: host.ioBroker "system.adapter.weather-warnings.0" enabled
        2023-09-25 12:07:24.384 - info: host.ioBroker instance system.adapter.weather-warnings.0 started with pid 3270054
        2023-09-25 12:07:25.232 - debug: weather-warnings.0 (3270054) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2023-09-25 12:07:25.270 - debug: weather-warnings.0 (3270054) Objects client ready ... initialize now
        2023-09-25 12:07:25.271 - debug: weather-warnings.0 (3270054) Objects create System PubSub Client
        2023-09-25 12:07:25.272 - debug: weather-warnings.0 (3270054) Objects create User PubSub Client
        2023-09-25 12:07:25.373 - debug: weather-warnings.0 (3270054) Objects client initialize lua scripts
        2023-09-25 12:07:25.392 - debug: weather-warnings.0 (3270054) Objects connected to redis: 0.0.0.0:9001
        2023-09-25 12:07:25.466 - debug: weather-warnings.0 (3270054) Redis States: Use Redis connection: 0.0.0.0:9000
        2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create System PubSub Client
        2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create User PubSub Client
        2023-09-25 12:07:25.660 - debug: weather-warnings.0 (3270054) States connected to redis: 0.0.0.0:9000
        2023-09-25 12:07:25.949 - info: weather-warnings.0 (3270054) starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12
        2023-09-25 12:07:25.975 - info: weather-warnings.0 (3270054) Refresh Interval: 15 minutes
        2023-09-25 12:07:30.132 - info: weather-warnings.0 (3270054) ZAMG activated. Retrieve data.
        2023-09-25 12:07:30.139 - info: weather-warnings.0 (3270054) UWZ activated. Retrieve data.
        2023-09-25 12:07:30.340 - debug: weather-warnings.0 (3270054) [zamg-48.333444483766975,14.6258983209036] Got 0 warnings from server
        2023-09-25 12:07:30.973 - debug: weather-warnings.0 (3270054) [uwz-UWZAT00754] Got 0 warnings from server
        2023-09-25 12:07:31.474 - debug: weather-warnings.0 (3270054) [Provider Controller] send 0 messages.
          sigi234 Forum Testing Most Active @Latzi last edited by
          @latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
          Jupp, Testmode:
          weather-warnings.0
          2023-09-25 12:09:05.816	debug	[Provider Controller] send 4 messages.
          weather-warnings.0
          2023-09-25 12:09:05.314	debug	[uwz-UWZUWZAT00XXX] Got 2 warnings from server
          weather-warnings.0
          2023-09-25 12:09:04.310	debug	[zamg-XX.XXXXXX,XX.XXXXXX] Got 2 warnings from server
          weather-warnings.0
          2023-09-25 12:09:04.308	info	UWZ activated. Retrieve data.
          weather-warnings.0
          2023-09-25 12:09:04.305	info	ZAMG activated. Retrieve data.
          weather-warnings.0
          2023-09-25 12:09:00.283	info	Refresh Interval: 5 minutes
          weather-warnings.0
          2023-09-25 12:09:00.272	info	starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in C:/SmartHome/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12
            Cool
            Wenn ihr mal ne Zamg Warnung habt würde ich mich über ne PM mit den coordinaten freuen, hab da nur 1 und die hab ich dann halt kopiert um fehler mit mehreren Meldungen zu finden, aber echte Unterschiedliche zu haben wäre schon besser.
            Latzi 1 Reply Last reply Reply Quote 0
            • Latzi
              @ticaki
              Wenn ich den "testmode" aktiviere, werden die DP´s erzeugt, Adapter wird jedoch gelb ohne Auffälligkeiten im debug-log, nehme ich ihn wieder raus bleibt der Adapter grün
                @ticaki
                Dito
                  ticaki @ticaki last edited by ticaki
                  Zum Adapter:
                  Liste der aktuellen Funktionen:
                  • Es gibt einen Testmodus - dabei ist der Adapter "offline" und wird so auch angezeigt.
                  Gelb bedeutet keine Verbindung zum Server. Bzw. Es wurden beim letzten Verbindungsversuch keine Daten geliefert. Der Testmodus umgeht das alles und da keine Daten geliefert wurden geht der Adapter auf gelb. Im Testmodus werden nicht Daten vom Server geladen, sondern aus einer lokalen Datei.
                  Damit ihr direkt erkennt, dass der nicht im Online Modus ist.
                  Dachte das wäre sinnvoll das man nicht aus versehen den Testmodus an hat und sich über den Warnungsspam wundert. Die Testwarnungen werden mit zufälligen start und endzeiten versehen und wenn sie abgelaufen sind wieder erneuert.
                  EDIT: Soweit ich das verstanden habe: Rot kommt vom controller, Gelb bedeutet der Adapter hat info.connection im root auf false gesetzt.
                  sigi234 Latzi 2 Replies Last reply Reply Quote 0
                    @ticaki
                    So OK für mich
                      Noch zusätzlich anzumerken ist, dass wenn kein Dienst daten liefert, geht der Adapter ebenfalls auf Gelb. Also alle Server down (unwahrscheinlich) oder keine Internetverbindung.
                      • Latzi
                        @ticaki
                        Achso, feature not a bug 😉
                        Klingt vernünftig und einleuchtend - hab deine Einleitung dazu zu ungenau gelesen - sorry! 🤦‍♂️
                        • Latzi
                          @ticaki
                          kleine Anregung: wäre es vielleicht sinnvoll einen eigenen Thread zu eröffnen, damit die Adapterentwicklung losgelöst vom script ist?
                            ticaki @Latzi last edited by
                            @ticaki
                            Ja schon, jedoch bis gestern hatte ich nur nen verbuggten Vorentwurf. Heute sieht der dann doch schon etwas funktionaler aus. Denkste er wäre schon soweit das man dazu nen Thread aufmachen?
                              @ticaki
                              Ja unter Kategorie Tester
                              • Latzi
                                Latzi @sigi234 last edited by
                                @sigi234 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                @ticaki 👍 halte ich für sehr gut, liegt bei dir, du bist der Entwickler und hast den Überblick!
                                  https://forum.iobroker.net/topic/68595/test-adapter-weather-warnings
                                  1.4k
                                  1521
                                  562564
