    4. JavaScript
    5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
    • Latzi
      Latzi @ticaki last edited by
      @ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
      EDIT2: Nochmal bitte
      Astrein, log ist sauber 👍
      2023-09-25 12:07:24.280 - info: host.ioBroker "system.adapter.weather-warnings.0" enabled
      2023-09-25 12:07:24.384 - info: host.ioBroker instance system.adapter.weather-warnings.0 started with pid 3270054
      2023-09-25 12:07:25.232 - debug: weather-warnings.0 (3270054) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2023-09-25 12:07:25.270 - debug: weather-warnings.0 (3270054) Objects client ready ... initialize now
      2023-09-25 12:07:25.271 - debug: weather-warnings.0 (3270054) Objects create System PubSub Client
      2023-09-25 12:07:25.272 - debug: weather-warnings.0 (3270054) Objects create User PubSub Client
      2023-09-25 12:07:25.373 - debug: weather-warnings.0 (3270054) Objects client initialize lua scripts
      2023-09-25 12:07:25.392 - debug: weather-warnings.0 (3270054) Objects connected to redis: 0.0.0.0:9001
      2023-09-25 12:07:25.466 - debug: weather-warnings.0 (3270054) Redis States: Use Redis connection: 0.0.0.0:9000
      2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create System PubSub Client
      2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create User PubSub Client
      2023-09-25 12:07:25.660 - debug: weather-warnings.0 (3270054) States connected to redis: 0.0.0.0:9000
      2023-09-25 12:07:25.949 - info: weather-warnings.0 (3270054) starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12
      2023-09-25 12:07:25.975 - info: weather-warnings.0 (3270054) Refresh Interval: 15 minutes
      2023-09-25 12:07:30.132 - info: weather-warnings.0 (3270054) ZAMG activated. Retrieve data.
      2023-09-25 12:07:30.139 - info: weather-warnings.0 (3270054) UWZ activated. Retrieve data.
      2023-09-25 12:07:30.340 - debug: weather-warnings.0 (3270054) [zamg-48.333444483766975,14.6258983209036] Got 0 warnings from server
      2023-09-25 12:07:30.973 - debug: weather-warnings.0 (3270054) [uwz-UWZAT00754] Got 0 warnings from server
      2023-09-25 12:07:31.474 - debug: weather-warnings.0 (3270054) [Provider Controller] send 0 messages.
        sigi234 Forum Testing Most Active @Latzi last edited by
        @latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
        Jupp, Testmode:
        weather-warnings.0
        2023-09-25 12:09:05.816	debug	[Provider Controller] send 4 messages.
        weather-warnings.0
        2023-09-25 12:09:05.314	debug	[uwz-UWZUWZAT00XXX] Got 2 warnings from server
        weather-warnings.0
        2023-09-25 12:09:04.310	debug	[zamg-XX.XXXXXX,XX.XXXXXX] Got 2 warnings from server
        weather-warnings.0
        2023-09-25 12:09:04.308	info	UWZ activated. Retrieve data.
        weather-warnings.0
        2023-09-25 12:09:04.305	info	ZAMG activated. Retrieve data.
        weather-warnings.0
        2023-09-25 12:09:00.283	info	Refresh Interval: 5 minutes
        weather-warnings.0
        2023-09-25 12:09:00.272	info	starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in C:/SmartHome/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12
          Cool
          Wenn ihr mal ne Zamg Warnung habt würde ich mich über ne PM mit den coordinaten freuen, hab da nur 1 und die hab ich dann halt kopiert um fehler mit mehreren Meldungen zu finden, aber echte Unterschiedliche zu haben wäre schon besser.
          Latzi 1 Reply Last reply Reply Quote 0
          • Latzi
            @ticaki
            Wenn ich den "testmode" aktiviere, werden die DP´s erzeugt, Adapter wird jedoch gelb ohne Auffälligkeiten im debug-log, nehme ich ihn wieder raus bleibt der Adapter grün
              @ticaki
              Dito
                ticaki @ticaki last edited by ticaki
                Zum Adapter:
                Liste der aktuellen Funktionen:
                • Es gibt einen Testmodus - dabei ist der Adapter "offline" und wird so auch angezeigt.
                Gelb bedeutet keine Verbindung zum Server. Bzw. Es wurden beim letzten Verbindungsversuch keine Daten geliefert. Der Testmodus umgeht das alles und da keine Daten geliefert wurden geht der Adapter auf gelb. Im Testmodus werden nicht Daten vom Server geladen, sondern aus einer lokalen Datei.
                Damit ihr direkt erkennt, dass der nicht im Online Modus ist.
                Dachte das wäre sinnvoll das man nicht aus versehen den Testmodus an hat und sich über den Warnungsspam wundert. Die Testwarnungen werden mit zufälligen start und endzeiten versehen und wenn sie abgelaufen sind wieder erneuert.
                EDIT: Soweit ich das verstanden habe: Rot kommt vom controller, Gelb bedeutet der Adapter hat info.connection im root auf false gesetzt.
                sigi234 Latzi 2 Replies Last reply Reply Quote 0
                  sigi234 Forum Testing Most Active @ticaki last edited by
                  @ticaki
                  So OK für mich
                    Noch zusätzlich anzumerken ist, dass wenn kein Dienst daten liefert, geht der Adapter ebenfalls auf Gelb. Also alle Server down (unwahrscheinlich) oder keine Internetverbindung.
                    • Latzi
                      @ticaki
                      Achso, feature not a bug 😉
                      Klingt vernünftig und einleuchtend - hab deine Einleitung dazu zu ungenau gelesen - sorry! 🤦‍♂️
                      • Latzi
                        @ticaki
                        kleine Anregung: wäre es vielleicht sinnvoll einen eigenen Thread zu eröffnen, damit die Adapterentwicklung losgelöst vom script ist?
                          ticaki @Latzi last edited by
                          @ticaki
                          Ja schon, jedoch bis gestern hatte ich nur nen verbuggten Vorentwurf. Heute sieht der dann doch schon etwas funktionaler aus. Denkste er wäre schon soweit das man dazu nen Thread aufmachen?
                            @ticaki
                            Ja unter Kategorie Tester
                            • Latzi
                              Latzi @sigi234 last edited by
                              @sigi234 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                              @ticaki 👍 halte ich für sehr gut, liegt bei dir, du bist der Entwickler und hast den Überblick!
                                https://forum.iobroker.net/topic/68595/test-adapter-weather-warnings
                                1.4k
                                1521
                                562564
