    4. Diskussion zum HowTo nodejs-Installation und upgrade
    • frank2604
      frank2604 @Thomas Braun last edited by
      Danke. Ist soweit alles fehlerfrei durchgelaufen.
      Alle Instanzen bis auf den Zigbee laufen wieder. Der meldet im Log folgendes:
      host.vm-iobroker-02
      2023-08-12 11:31:07.119	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.vm-iobroker-02
      2023-08-12 11:31:07.119	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.vm-iobroker-02
      2023-08-12 11:31:07.119	error	Caught by controller[0]: Node.js v18.17.1
      host.vm-iobroker-02
      2023-08-12 11:31:07.119	error	Caught by controller[0]: }
      host.vm-iobroker-02
      2023-08-12 11:31:07.119	error	Caught by controller[0]: ]
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js',
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: requireStack: [
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:21:1)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      host.vm-iobroker-02
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: Require stack:
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: Error: Cannot find module '@iobroker/types'
      host.vm-iobroker-02
      2023-08-12 11:31:07.118	error	Caught by controller[0]: ^
      host.vm-iobroker-02
      2023-08-12 11:31:07.117	error	Caught by controller[0]: throw err;
      host.vm-iobroker-02
      2023-08-12 11:31:07.117	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
      host.vm-iobroker-02
      2023-08-12 11:31:06.702	info	instance system.adapter.zigbee.0 started with pid 14766
      host.vm-iobroker-02
      2023-08-12 11:31:06.600	info	"system.adapter.zigbee.0" enabled
      frank2604 1 Reply Last reply Reply Quote 0
      • frank2604
        frank2604 @frank2604 last edited by
        @Thomas-Braun
        Hat sich erledigt. Habe im Verzeichnis:
        das ausgeführt:
        Jetzt läuft auch Zigbee wieder.
          skorpil last edited by
          Als Node und Linux dummy habe ich folgende Frage:
          Mein ioBroker meldet seit gestern , dass es wohl neue Versionen gibt:
          Node.js: v18.17.1(18.18.0)
          NPM: 9.6.7(9.8.1)
          Ich habe mit sudo apt-get Update und Upgrade versucht, die Updates durchzuführen. Es bleibt aber alles beim Alten. Die anschließende Abfrage zeigt:
          nodejs:
          Installiert: 18.17.1-deb-1nodesource1
          Installationskandidat: 18.17.1-deb-1nodesource1
          Versionstabelle:
          *** 18.17.1-deb-1nodesource1 500
          500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
          100 /var/lib/dpkg/status
          12.22.12~dfsg-1~deb11u4 500
          500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
          12.22.12~dfsg-1~deb11u3 500
          500 http://deb.debian.org/debian bullseye/main amd64 Packages
          Frage an die Profis: was mache ich falsch? Wie installiere ich Node.js 18.18.0 bzw. Npm 9.8.1? Bzw. sollte ich das überhaupt updated?
            Wildbill @skorpil last edited by
            @skorpil Schau ein Stück weiter oben in die Signatur von @Thomas-Braun . Da gibt es einen Link zu einem NodeJS Fixer Skript.
            Das aktualisiert Dir auf die aktuelle Version 18.18.0 (die Du auch verwenden solltest).
            Gruss, Jürgen
              skorpil @Wildbill last edited by
              @wildbill Dankeschön, das hatte ich offenbar überlesen. Ich werde es so versuchen.
                @wildbill feedback is breakfast for champions: hat funktioniert. Danke!
                  mcreuter last edited by Samson71
                  Hey so sieht es aus wenn ich die Installation nochmal durchgehe:
                  Von allein wollte der nicht auf die neuste Version!
                  System latest offizelles Docker Image...
                  Ich hoffe das es damit gerade gezogen und aktuell ist.
                  Vielleicht kann mir jemand das bestätigen??
                  DANKE
                  root@iobroker:/opt/iobroker# uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt
                  update &> /dev/null && sudo apt update && apt policy nodejs
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  /usr/bin/corepack
                  v18.18.0
                  v18.18.0
                  9.8.1
                  9.8.1
                  0.19.0
                  5.0.12
                  root
                  root
                  /opt/iobroker
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists... Done
                  Building dependency tree... Done
                  All packages are up to date.
                  nodejs:
                    Installed: 18.18.0-1nodesource1
                    Candidate: 18.18.0-1nodesource1
                    Version table:
                   *** 18.18.0-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                       18.17.1-1nodesource1 500
                       18.17.0-1nodesource1 500
                       18.16.1-1nodesource1 500
                       18.16.0-1nodesource1 500
                       18.15.0-1nodesource1 500
                       18.14.2-1nodesource1 500
                       18.14.1-1nodesource1 500
                       18.14.0-1nodesource1 500
                       18.13.0-1nodesource1 500
                       18.12.0-1nodesource1 500
                       18.11.0-1nodesource1 500
                       18.10.0-1nodesource1 500
                       18.9.1-1nodesource1 500
                       18.9.0-1nodesource1 500
                       18.8.0-1nodesource1 500
                       18.7.0-1nodesource1 500
                       18.6.0-1nodesource1 500
                       18.5.0-1nodesource1 500
                       18.4.0-1nodesource1 500
                       18.3.0-1nodesource1 500
                       18.2.0-1nodesource1 500
                       18.1.0-1nodesource1 500
                       18.0.0-1nodesource1 500
                          500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                  Mod-EDIT: Code in Code-Tags setzen!
                    Thomas Braun Most Active @mcreuter last edited by
                    @mcreuter
                    Beim Docker zieht man sich i. A. einen frischen aus dem Regal.
                      mcreuter @Thomas Braun last edited by
                      Was meinst du damit genau?
                      Der Docker Container Manager zieht sich immer das latest Image und migriert diese direkt.
                      https://registry.hub.docker.com/r/iobroker/iobroker/
                      Aber updaten tut sich da kein Node und npm.... Habe das immer manuell gemacht bisher...
                      Nur jetzt über die neue Methode von dir, da die alte nicht mehr ging :_)
                        Thomas Braun Most Active @mcreuter last edited by Thomas Braun
                        @mcreuter sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                        Ich hab ja keine Aktien in den Dingern, aber die kommen eigentlich immer mit passender Umgebung vorgekocht daher. Ich glaube in der Version 9 des Docker-Images ist dann auch nodejs@18.18.0 eingebacken.
                          @thomas-braun Ok, kein Ding kann man ja buanet mal fragen...
                          https://github.com/buanet/ioBroker.docker
                          JA kann sein, die V9 ist als Beta pre Release schon in arbeit mit Debian 12 soweit ich das gesehen habe 🙂
                          https://github.com/buanet/ioBroker.docker/tree/v9.0.0-beta.1
                          • Änderungen:
                            remove special settings script and env for zwave (#377)
                            simplify ci/ reduce gh actions
                            ignore errors in "silent cleanup" on first start (#369)
                            cleanup/ restructure repo
                            update nodejs setup process
                            update base image to debian 12 (bookworm)
                            improve security by avoiding root (exept startup script itself)
                            restrict iobroker commanline commands (start/ stop/ node fix)
                            integrate maintenance script into iobroker command
                            move container config files location
                            Jack01 last edited by Jack01
                            Auch bei mir hat der normale Befehl per update und upgrade nicht zum Erfolg geführt. Ich habe dann den Link von @thomas-braun genutzt und den iob node fix laufen lassen. Das hat geklappt. Verstanden habe ich es aber nicht, da die Pfade ja scheinbar richtig waren und frühere Updates immer funktioniert haben.
                            Vielen Dank an alle Helfer!
                            ioBroker nodejs fixer 2023-09-24
                            Recommended nodejs-version is: 18.18.0
                            Checking your installation now. Please be patient!
                            Your current setup is:
                            /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            /usr/bin/corepack       0.18.0
                            We found these nodejs versions available for installation:
                            nodejs:
                              Installed: 18.17.1-deb-1nodesource1
                              Candidate: 18.17.1-deb-1nodesource1
                              Version table:
                                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            Nothing to do - Your installation is using the correct paths.
                            You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
                            Press <y> to continue or any other key to quit
                            Trying to fix your installation now. Please be patient.
                            Waiting for ioBroker to shut down - Give me a minute...
                            *** These repos are active on your system:
                            Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                            Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                            Hit:5 https://repos.influxdata.com/debian stable InRelease
                            Get:6 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
                            Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB]
                            Fetched 694 kB in 2s (399 kB/s)
                            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                            Package: nodejs
                            Pin: origin deb.nodesource.com
                            Pin-Priority: 1001
                            *** These repos are active after the adjustments:
                            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:4 https://repos.influxdata.com/debian stable InRelease
                            Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                            Get:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                            Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                            Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5262 B]
                            Fetched 22.7 kB in 2s (9910 B/s)
                            Installing the recommended nodejs version now!
                            (Reading database ... 50588 files and directories currently installed.)
                            Preparing to unpack .../nodejs_18.18.0-1nodesource1_arm64.deb ...
                            Detected old npm client, removing...
                            Unpacking nodejs (18.18.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                            Setting up nodejs (18.18.0-1nodesource1) ...
                            Processing triggers for man-db (2.9.4-2) ...
                            We tried our best to fix your nodejs. Please run iob diag again to verify.
                            *** RESTARTING ioBroker NOW! ***
                             Please refresh or restart your browser in a few moments.
                            pi@raspberrypi:/opt/iobroker $
                              Thomas Braun Most Active @Jack01 last edited by
                              @jack01 sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                              Der Aufbau der Paketquelle hat sich geändert und daher muss entsprechend in deinem System auch einiges umgestellt werden. Neue Versionen von nodejs kommen nur noch über das neue Repository.
                              Das node-fix-Skript nimmt dir das weitgehend ab.
                                Jack01 @Thomas Braun last edited by
                                @thomas-braun OK, Danke.
                                Ist das so dann OK für künftige Updates oder muß ich jetzt noch etwas manuell anpassen?
                                  @jack01
                                  Künftige Updates laufen jetzt wieder wie gehabt über den üblichen
                                  sudo apt update
                                  sudo apt full-upgrade
                                  Weg mit.
                                    @thomas-braun Na das ist ja ein cooles Script. Kannte ich noch garnicht.
                                                         v.2023-06-20
                                       Static hostname: raspberrypi
                                             Icon name: computer
                                            Machine ID: 620e922bf61543a9808841485d366ecc
                                               Boot ID: 14db67d510ce44cea2db1fdd81b8c10d
                                      Operating System: Debian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    Installation:           native
                                    Kernel:                 aarch64
                                    Userland:               arm64
                                    Timezone:               Europe/Berlin (CEST, +0200)
                                    User-ID:                1000
                                    X-Server:               false
                                    Boot Target:            multi-user.target
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                            /usr/bin/node           v18.18.0
                                                            /usr/bin/npm            9.8.1
                                                            /usr/bin/npx            9.8.1
                                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                                    MEMORY:
                                    Mem:            3.8G        1.9G        142M        0.0K        1.7G        1.8G
                                    Swap:            99M         26M         73M
                                    Total:          3.9G        1.9G        216M
                                    Active iob-Instances:   25
                                    Active repo(s): stable
                                    ioBroker Core:          js-controller           5.0.12
                                                            admin                   6.10.1
                                    Objects type: jsonl
                                    States  type: redis
                                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    Objects:                9583
                                    States:                 8935
                                    Size of iob-Database:
                                    16M     /opt/iobroker/iobroker-data/objects.jsonl
                                    1.8M    /opt/iobroker/iobroker-data/states.jsonl
                                      LJSven last edited by
                                      Ich bekomme auf meinem Tinkerboard nodejs 16 nicht installiert. Es kommt immer diese Meldung
                                      Get:1 https://deb.nodesource.com/node_16.x stretch/main armhf nodejs armhf 16.20.2-1nodesource1 [24.2 MB]
                                      Err:1 https://deb.nodesource.com/node_16.x stretch/main armhf nodejs armhf 16.20.2-1nodesource1
                                        Writing more data than expected (24245194 > 24241614)
                                        Hashes of expected file:
                                      Was muss ich machen? Ratlos
                                        Jan1 @LJSven last edited by
                                        @ljsven
                                        1. Stretch ist tot
                                        2. Node 16 ist alt und 18 empfohlen
                                        Somit erstmal das OS auf der Kiste auf den aktuellen Stand bringen, der Rest sollte dann automatisch laufen
                                          LJSven @Jan1 last edited by
                                          @jan1 sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                          @ljsven
                                          1. Stretch ist tot
                                          Welches Image soll ich installieren? Hast du einen Link?
                                            Jan1 @LJSven last edited by Jan1
                                            @ljsven
                                            Ich habe kein Tinkerboard und natürlich ein aktuelles Image 😉
                                            Wobei Image??? kann man das Ding nicht manuell einrichten?
                                            nodejs
                                            91
                                            844
                                            229421
