    3. Einsteigerfragen
    4. Installation
    5. [gelöst] Update von Debian 10 auf 11?
      Alero @crunchip last edited by Alero
      @crunchip
      jo sieht so aus als müsste ich das noch einmal machen
      ch block, or by rejecting a promise which was not handled with .catch().
      2023-09-25 12:33:25.584  - error: vis.0 (20936) unhandled promise rejection: Not exists
      2023-09-25 12:33:25.584  - error: vis.0 (20936) Error: Not exists
          at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
          at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
          at process.processImmediate (node:internal/timers:478:21)
      2023-09-25 12:33:25.584  - error: vis.0 (20936) Not exists
      2023-09-25 12:33:26.087  - info: vis.0 (20936) terminating
      2023-09-25 12:33:26.088  - warn: vis.0 (20936) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-09-25 12:33:25.226  - info: vis.0 (20936) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.0, js-controller: 5.0.12
      2023-09-25 12:33:25.403  - info: vis.0 (20936) vis license is OK.
      2023-09-25 12:33:25.583  - error: vis.0 (20936) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-09-25 12:33:26.698  - error: host.iobroker-prod-12 iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-25T12_33_20_977Z-debug-0.log
      2023-09-25 12:33:26.698  - error: host.iobroker-prod-12 iobroker npm-install: host.iobroker-prod-12 Cannot install iobroker.vis@1.4.16: 6
      2023-09-25 12:33:27.715  - info: host.iobroker-prod-12 iobroker npm-install: exit 25
      2023-09-25 12:33:28.716  - warn: host.iobroker-prod-12 startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
      2023-09-25 12:33:28.716  - info: host.iobroker-prod-12 iobroker install vis@1.4.16 using installedVersion
      2023-09-25 12:33:29.977  - info: host.iobroker-prod-12 iobroker npm-install: NPM version: 9.8.1
      2023-09-25 12:33:29.979  - info: host.iobroker-prod-12 iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
      2023-09-25 12:33:34.448  - info: vis.0 (21173) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.0, js-controller: 5.0.12
      2023-09-25 12:33:34.597  - info: vis.0 (21173) vis license is OK.
      2023-09-25 12:33:34.759  - error: vis.0 (21173) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-09-25 12:33:34.759  - error: vis.0 (21173) unhandled promise rejection: Not exists
      2023-09-25 12:33:34.760  - error: vis.0 (21173) Error: Not exists
      2023-09-25 12:33:34.760  - error: vis.0 (21173) Not exists
      2023-09-25 12:33:35.275  - info: vis.0 (21173) terminating
      2023-09-25 12:33:35.276  - warn: vis.0 (21173) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-09-25 12:33:35.890  - error: host.iobroker-prod-12 iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-25T12_33_30_247Z-debug-0.log
      2023-09-25 12:33:35.891  - error: host.iobroker-prod-12 iobroker npm-install: host.iobroker-prod-12 Cannot install iobroker.vis@1.4.16: 6
      2023-09-25 12:33:36.906  - info: host.iobroker-prod-12 iobroker npm-install: exit 25
      2023-09-25 12:33:37.906  - warn: host.iobroker-prod-12 startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
      2023-09-25 12:33:37.907  - info: host.iobroker-prod-12 iobroker install vis@1.4.16 using installedVersion
      2023-09-25 12:33:39.151  - info: host.iobroker-prod-12 iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
      2023-09-25 12:33:43.691  - info: vis.0 (21411) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.0, js-controller: 5.0.12
      2023-09-25 12:33:43.848  - info: vis.0 (21411) vis license is OK.
      2023-09-25 12:33:44.005  - error: vis.0 (21411) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-09-25 12:33:44.005  - error: vis.0 (21411) unhandled promise rejection: Not exists
      2023-09-25 12:33:44.006  - error: vis.0 (21411) Error: Not exists
      2023-09-25 12:33:44.006  - error: vis.0 (21411) Not exists
      2023-09-25 12:33:44.511  - info: vis.0 (21411) terminating
      2023-09-25 12:33:44.512  - warn: vis.0 (21411) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-09-25 12:33:45.131  - error: host.iobroker-prod-12 iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-25T12_33_39_422Z-debug-0.log
      2023-09-25 12:33:45.132  - error: host.iobroker-prod-12 iobroker npm-install: host.iobroker-prod-12 Cannot install iobroker.vis@1.4.16: 6
      2023-09-25 12:33:46.157  - info: host.iobroker-prod-12 iobroker npm-install: exit 25
      2023-09-25 12:33:47.157  - error: host.iobroker-prod-12 Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        Homoran Global Moderator Administrators @Alero last edited by
        @alero versuch iob install vis@1.4.10 und anschließend wieder update
          Alero @Homoran last edited by
          So
          habe eben neu installiert.
          sieht jetzt so aus.
          jetzt will ich den restore anstoßen. Wenn niemand was dagegen hat 😉
            Alero @Alero last edited by
            Bekomme noch einen Fehler beim zugriff aufs Nas SMB.
            	Error: Command failed: sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              Thomas Braun Most Active @Alero last edited by
              @alero sagte in Update von Debian 10 auf 11?:
              Da fehlen Rechte. Mountest du als 'sudo'/root?
                Alero @Thomas Braun last edited by
                jep
                  @alero hast du die cifs-utils (o.ä) installiert?
                  A Thomas Braun 2 Replies Last reply Reply Quote 0
                    Alero @Homoran last edited by Alero
                    hi, nicht bewusst. kann ich das nachschauen?
                    es hat ja soeben noch geklappt. es muss was mit den Einstellungen im iobroker zutun haben.
                      das war doch lokal!
                      und jetzt hast du deine alte Konfig restored
                        Thomas Braun Most Active @Homoran last edited by Thomas Braun
                        @homoran sagte in Update von Debian 10 auf 11?:
                        sudo apt update
                        apt policy cifs-utils
                          Alero @Thomas Braun last edited by Alero
                          @thomas-braun sagte in Update von Debian 10 auf 11?:
                          root@iobroker-prod-12:~# apt policy cifs-utils
                          cifs-utils:
                            Installed: 2:7.0-2
                            Candidate: 2:7.0-2
                            Version table:
                           *** 2:7.0-2 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                  100 /var/lib/dpkg/status
                          nachdem der restore abgeschlossen ist komme ich nicht mehr auf die webseite.
                          ERR_CONNECTION_REFUSED
                            @alero
                            iob diag
                            sagt dazu? Die Langfassung bitte.
                              Alero @Thomas Braun last edited by Homoran
                              iob diag
                              Skript v.2023-06-20
                              *** BASE SYSTEM ***
                               Static hostname: iobroker-prod-12
                                     Icon name: computer-container
                                       Chassis: container ☐
                                    Machine ID: 735eba02704e4761a53cb81764304e07
                                       Boot ID: 97cabc4ce7f248c09bea9ebb59e47718
                                Virtualization: lxc
                                        Kernel: Linux 6.2.16-14-pve
                                  Architecture: x86-64
                              model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
                              Docker          : false
                              Virtualization  : lxc
                              Kernel          : x86_64
                              Userland        : amd64
                              Systemuptime and Load:
                               13:36:26 up 8 min,  2 users,  load average: 0.20, 0.55, 1.20
                              CPU threads: 2
                              *** Time and Time Zones ***
                                             Local time: Mon 2023-09-25 13:36:26 UTC
                                         Universal time: Mon 2023-09-25 13:36:26 UTC
                                               RTC time: n/a
                                              Time zone: Etc/UTC (UTC, +0000)
                                            NTP service: inactive
                                        RTC in local TZ: no
                              *** User and Groups ***
                              root
                              /root
                              root
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Mem:            6.4G        520M        5.5G        110K        374M        5.9G
                              Swap:           536M          0B        536M
                              Total:          7.0G        520M        6.1G
                                       6144 M total memory
                                        496 M used memory
                                         95 M active memory
                                        726 M inactive memory
                                       5290 M free memory
                                          0 M buffer memory
                                        357 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              *** FILESYSTEM ***
                              Filesystem                       Type      Size  Used Avail Use% Mounted on
                              /dev/mapper/pve-vm--219--disk--0 ext4       30G  4.2G   24G  15% /
                              none                             tmpfs     492K  4.0K  488K   1% /dev
                              udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                              tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                              tmpfs                            tmpfs     3.2G  104K  3.2G   1% /run
                              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                              dmesg: read kernel buffer failed: Operation not permitted
                              Show mounted filesystems (real ones only):
                              TARGET SOURCE                           FSTYPE OPTIONS
                              /      /dev/mapper/pve-vm--219--disk--0 ext4   rw,relatime,stripe=16
                              /var:
                              433M    /var/
                              248M    /var/cache
                              244M    /var/cache/apt
                              169M    /var/cache/apt/archives
                              144M    /var/lib
                              Archived and active journals take up 40.0M in the file system.
                              /opt/iobroker/backups:
                              29M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              542M    /opt/iobroker/iobroker-data/
                              509M    /opt/iobroker/iobroker-data/files
                              88M     /opt/iobroker/iobroker-data/files/echarts.admin
                              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                              57M     /opt/iobroker/iobroker-data/files/echarts
                              26M     /opt/iobroker/iobroker-data/objects.jsonl
                              23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                              23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.18.0
                              /usr/bin/node           v18.18.0
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Installed: 18.18.0-1nodesource1
                                Candidate: 18.18.0-1nodesource1
                                Version table:
                               *** 18.18.0-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                   18.17.1-1nodesource1 500
                                   18.17.0-1nodesource1 500
                                   18.16.1-1nodesource1 500
                                   18.16.0-1nodesource1 500
                                   18.15.0-1nodesource1 500
                                   18.14.2-1nodesource1 500
                                   18.14.1-1nodesource1 500
                                   18.14.0-1nodesource1 500
                                   18.13.0+dfsg1-1 500
                                   18.13.0-1nodesource1 500
                                   18.12.0-1nodesource1 500
                                   18.11.0-1nodesource1 500
                                   18.10.0-1nodesource1 500
                                   18.9.1-1nodesource1 500
                                   18.9.0-1nodesource1 500
                                   18.8.0-1nodesource1 500
                                   18.7.0-1nodesource1 500
                                   18.6.0-1nodesource1 500
                                   18.5.0-1nodesource1 500
                                   18.4.0-1nodesource1 500
                                   18.3.0-1nodesource1 500
                                   18.2.0-1nodesource1 500
                                   18.1.0-1nodesource1 500
                                   18.0.0-1nodesource1 500
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              No configuration change needed.
                              Multihost discovery server: disabled
                              Discovery authentication:   enabled
                              Persistent activation:      disabled
                              Objects:                    jsonl on 127.0.0.1
                              States:                     jsonl on 127.0.0.1
                              Core adapters versions
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapters from github:   3
                              Adapter State
                              + system.adapter.admin.1                  : admin                 : iobroker-prod-12                         -  enabled, port: 8081, bind: 192.168.42.15, run as: admin
                              + system.adapter.backitup.0               : backitup              : iobroker-prod-12                         -  enabled
                                system.adapter.birthdays.0              : birthdays             : iobroker-prod-12                         - disabled
                                system.adapter.daswetter.0              : daswetter             : iobroker-prod-12                         - disabled
                                system.adapter.device-reminder.0        : device-reminder       : iobroker-prod-12                         - disabled
                                system.adapter.discovery.0              : discovery             : iobroker-prod-12                         - disabled
                                system.adapter.dwd.0                    : dwd                   : iobroker-prod-12                         - disabled
                                system.adapter.echarts.0                : echarts               : iobroker-prod-12                         - disabled
                                system.adapter.email.0                  : email                 : iobroker-prod-12                         - disabled
                                system.adapter.energiefluss.0           : energiefluss          : iobroker-prod-12                         - disabled
                                system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-prod-12                         - disabled
                                system.adapter.feiertage.0              : feiertage             : iobroker-prod-12                         - disabled
                                system.adapter.flot.0                   : flot                  : iobroker-prod-12                         - disabled
                                system.adapter.fritzbox.0               : fritzbox              : iobroker-prod-12                         - disabled
                                system.adapter.fritzdect.0              : fritzdect             : iobroker-prod-12                         - disabled
                                system.adapter.fullcalendar.0           : fullcalendar          : iobroker-prod-12                         - disabled
                                system.adapter.history.0                : history               : iobroker-prod-12                         - disabled
                                system.adapter.hm-rega.0                : hm-rega               : iobroker-prod-12                         - disabled
                                system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-prod-12                         - disabled, port: 0
                                system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-prod-12                         - disabled, port: 0
                                system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-prod-12                         - disabled, port: 0
                                system.adapter.ical.0                   : ical                  : iobroker-prod-12                         - disabled
                                system.adapter.ical.1                   : ical                  : iobroker-prod-12                         - disabled
                                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-prod-12                         - disabled
                                system.adapter.icons-icons8.0           : icons-icons8          : iobroker-prod-12                         - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : iobroker-prod-12                         - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-prod-12                         - disabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-prod-12                         - disabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-prod-12                         - disabled
                                system.adapter.influxdb.0               : influxdb              : iobroker-prod-12                         - disabled, port: 8086
                                system.adapter.info.0                   : info                  : iobroker-prod-12                         - disabled
                                system.adapter.javascript.0             : javascript            : iobroker-prod-12                         - disabled
                                system.adapter.melcloud.0               : melcloud              : iobroker-prod-12                         - disabled
                                system.adapter.mercedesme.0             : mercedesme            : iobroker-prod-12                         - disabled
                                system.adapter.mqtt.1                   : mqtt                  : iobroker-prod-12                         - disabled, port: 1884, bind: 192.168.42.15
                                system.adapter.mqtt.2                   : mqtt                  : iobroker-prod-12                         - disabled, port: 1886, bind: 192.168.42.15
                                system.adapter.mqtt.3                   : mqtt                  : iobroker-prod-12                         - disabled, port: 1883, bind: 192.168.42.15
                                system.adapter.mqtt.4                   : mqtt                  : iobroker-prod-12                         - disabled, port: 1888, bind: 192.168.42.15
                                system.adapter.node-red.0               : node-red              : iobroker-prod-12                         - disabled, port: 1880, bind: 192.168.42.15
                                system.adapter.pvforecast.0             : pvforecast            : iobroker-prod-12                         - disabled
                                system.adapter.radar2.0                 : radar2                : iobroker-prod-12                         - disabled
                                system.adapter.rpi2.0                   : rpi2                  : iobroker-prod-12                         - disabled
                                system.adapter.sayit.0                  : sayit                 : iobroker-prod-12                         - disabled, port: 0
                                system.adapter.scenes.0                 : scenes                : iobroker-prod-12                         - disabled
                                system.adapter.shelly.0                 : shelly                : iobroker-prod-12                         - disabled, port: 1881, bind: 192.168.42.15
                                system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-prod-12                         - disabled
                                system.adapter.simple-api.0             : simple-api            : iobroker-prod-12                         - disabled, port: 8087, bind: 192.168.42.15, run as: admin
                                system.adapter.socketio.0               : socketio              : iobroker-prod-12                         - disabled, port: 8084, bind: 192.168.42.15, run as: admin
                                system.adapter.sonoff.0                 : sonoff                : iobroker-prod-12                         - disabled, port: 1883, bind: 192.168.42.15
                                system.adapter.sonoff.1                 : sonoff                : iobroker-prod-12                         - disabled, port: 1884, bind: 192.168.42.15
                                system.adapter.sonoff.2                 : sonoff                : iobroker-prod-12                         - disabled, port: 1888, bind: 0.0.0.0
                                system.adapter.sonos.0                  : sonos                 : iobroker-prod-12                         - disabled
                                system.adapter.synology.0               : synology              : iobroker-prod-12                         - disabled, port: 5001
                                system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-prod-12                         - disabled
                                system.adapter.telegram.0               : telegram              : iobroker-prod-12                         - disabled, port: 8443, bind: 0.0.0.0
                                system.adapter.telegram.1               : telegram              : iobroker-prod-12                         - disabled, port: 8443, bind: 0.0.0.0
                                system.adapter.telegram.2               : telegram              : iobroker-prod-12                         - disabled, port: 8443, bind: 0.0.0.0
                                system.adapter.text2command.0           : text2command          : iobroker-prod-12                         - disabled
                                system.adapter.text2command.1           : text2command          : iobroker-prod-12                         - disabled
                                system.adapter.tr-064.0                 : tr-064                : iobroker-prod-12                         - disabled
                                system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker-prod-12                         - disabled
                                system.adapter.upnp.0                   : upnp                  : iobroker-prod-12                         - disabled
                                system.adapter.vis-bars.0               : vis-bars              : iobroker-prod-12                         - disabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-prod-12                         - disabled
                                system.adapter.vis-history.0            : vis-history           : iobroker-prod-12                         - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-prod-12                         - disabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-prod-12                         - disabled
                                system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-prod-12                         - disabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-prod-12                         - disabled
                                system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-prod-12                         - disabled
                                system.adapter.vis-material.0           : vis-material          : iobroker-prod-12                         - disabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-prod-12                         - disabled
                                system.adapter.vis-metro.0              : vis-metro             : iobroker-prod-12                         - disabled
                                system.adapter.vis-players.0            : vis-players           : iobroker-prod-12                         - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-prod-12                         - disabled
                                system.adapter.vis-weather.0            : vis-weather           : iobroker-prod-12                         - disabled
                                system.adapter.vis.0                    : vis                   : iobroker-prod-12                         - disabled
                                system.adapter.web.0                    : web                   : iobroker-prod-12                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Active repo(s): Stable (default)
                              Installed ioBroker-Instances
                              Used repository: Stable (default)
                              Adapter    "admin"        : 6.10.1   , installed 6.10.1
                              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                              Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
                              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                              Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                              Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                              Adapter    "email"        : 1.2.0    , installed 1.2.0
                              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                              Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
                              Adapter    "history"      : 2.2.6    , installed 2.2.6
                              Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                              Adapter    "info"         : 1.9.26   , installed 1.9.26
                              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                              Controller "js-controller": 5.0.12   , installed 5.0.12
                              Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
                              Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
                              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                              Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                              Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                              Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                              Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                              Adapter    "synology"     : 3.0.0    , installed 3.0.0
                              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                              Adapter    "text2command" : 3.0.2    , installed 3.0.2
                              Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
                              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                              Adapter    "vis"          : 1.4.16   , installed 1.4.16
                              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                              Adapter    "web"          : 6.1.2    , installed 6.1.2
                              Adapter    "ws"           : 2.5.5    , installed 2.5.5
                              Objects and States
                              Objects:        24810
                              States:         25055
                              Hit:2 http://security.debian.org bookworm-security InRelease
                              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15968723   130/iobroker.js-con
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15969455   130/iobroker.js-con
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15968591   299/master
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15964997   1/init
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          15964999   1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          15965179   1/init
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15968592   299/master
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15964998   1/init
                              udp6       0      0 :::111                  :::*                                0          15965000   1/init
                              2023-09-25 13:28:15.183  - debug: backitup.0 (367) States create System PubSub Client
                              2023-09-25 13:28:15.183  - debug: backitup.0 (367) States create User PubSub Client
                              2023-09-25 13:28:15.393  - error: host.iobroker-prod-12 iobroker npm-install: host.iobroker-prod-12 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                              2023-09-25 13:28:15.395  - debug: backitup.0 (367) States connected to redis: 127.0.0.1:9000
                              2023-09-25 13:28:15.471  - info: host.iobroker-prod-12 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                              2023-09-25 13:28:15.663  - debug: backitup.0 (367) Plugin sentry Initialize Plugin (enabled=true)
                              2023-09-25 13:28:15.808  - info: backitup.0 (367) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.0, js-controller: 5.0.12
                              2023-09-25 13:28:15.842  - debug: backitup.0 (367) Backitup has recognized a linux system
                              2023-09-25 13:28:15.850  - info: backitup.0 (367) [iobroker] backup will be activated at 03:00 every 1 day(s)
                              2023-09-25 13:28:15.891  - debug: backitup.0 (367) [iobroker] 10 00 03 */1 * *
                              2023-09-25 13:28:15.891  - info: backitup.0 (367) [ccu] backup will be activated at 01:30 every 1 day(s)
                              2023-09-25 13:28:15.895  - debug: backitup.0 (367) [ccu] 10 30 01 */1 * *
                              2023-09-25 13:28:15.899  - debug: backitup.0 (367) noserverino option: false
                              2023-09-25 13:28:15.899  - debug: backitup.0 (367) cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.42.100backup/Iobroker/Standard /opt/iobroker/backups"
                              2023-09-25 13:28:16.258  - debug: backitup.0 (367) first mount attempt with smb option failed. try next mount attempt without smb option ...
                              2023-09-25 13:28:16.259  - debug: backitup.0 (367) cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.42.100backup/Iobroker/Standard /opt/iobroker/backups"
                              2023-09-25 13:28:16.337  - error: backitup.0 (367) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backups
                              2023-09-25 13:28:16.371  - info: admin.1 (320) Repository received successfully.
                              2023-09-25 13:28:16.486  - info: host.iobroker-prod-12 iobroker npm-install: exit 12
                              2023-09-25 13:28:18.339  - debug: backitup.0 (367) detect backup file 1 from NAS: iobroker_2023_09_25-03_00_20_backupiobroker.tar.gz
                              2023-09-25 13:28:18.339  - debug: backitup.0 (367) detect backup file 2 from NAS: iobroker_2023_09_25-09_25_08_backupiobroker.tar.gz
                              2023-09-25 13:28:18.339  - debug: backitup.0 (367) detect last backup file: iobroker_2023_09_25-09_25_08_backupiobroker.tar.gz
                              Homoran crunchip 2 Replies Last reply Reply Quote 0
                                falsch
                                Ebenfalls falsch, da muss 0.0.0.0 stehen
                                  crunchip Forum Testing Most Active @Alero last edited by
                                  • system.adapter.admin.1 : admin : iobroker-prod-12 - enabled, port: 8081, bind: 192.168.42.15, run as: admin
                                  woher kommt denn da der admin 1?
                                  und dieser ist an die IP gebunden
                                    Homoran Global Moderator Administrators @crunchip last edited by
                                    @crunchip sagte in Update von Debian 10 auf 11?:
                                    aus dem backup 😀
                                      hi, wo kann ich es ändern?
                                      ist klar. das ist ein restore von der 192.168.42.15 ich lasse eine neue Maschine mit 192.168.42.16 laufen. wenn sie läuft wollte ich die ip ändern und den alten Server herunterfahren.
                                        da hat keine dedizierte IP zu stehen!
                                        da gehört 0.0.0.0 rein, damit es keine Probleme gibt
                                          hi, also so?
                                          habs jetzt auf dem produktiven geändert.
                                          dann mache ich noch ein backup und spiele es noch mal ein.
                                            crunchip Forum Testing Most Active @Homoran last edited by
                                            @homoran schon klar, hätte wohl direkter fragen sollen, warum ne instanz 1, bzw was da im Vorfeld "gefummelt" wurde
                                            außerdem immer noch
                                            root
                                            /root
                                            root
                                            habe ich noch einen user angelegt
                                            4601
