    3. Off Topic
    4. Raspberry Pi stürtzt ab mit Echarts
    • Duffy
      Duffy @Thomas Braun last edited by Duffy
      @thomas-braun sagte in Raspberry Pi stürtzt ab mit Echarts:
      iob diag
      Bringt das jetzt noch was das auszuführen? Der Pi war ja nach dem Absturz stromlos.
      Kann das sonst schon gerne mal posten.
      Edit:
      Habs einfach mal gemacht:
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
              Machine ID: d1492c3c26a048218fd90052e5ea5949
                 Boot ID: e4a1c325e8a24a93986364cd839afbcd
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:04:36 up 45 min,  1 user,  load average: 0.90, 0.91, 0.87
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=39.9'C
      volt=0.9260V
      *** Time and Time Zones ***
                     Local time: Mon 2023-09-25 19:04:36 CEST
                 Universal time: Mon 2023-09-25 17:04:36 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        2.1G        4.6G        1.0M        1.1G        5.6G
      Swap:            99M          0B         99M
      Total:          7.9G        2.1G        4.7G
               7811 M total memory
               2077 M used memory
               2831 M active memory
                230 M inactive memory
               4613 M free memory
                 68 M buffer memory
               1052 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  7.9G   20G  29% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Mon Sep 25 18:18:51 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:36:CB:32 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=d7a4744b-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Sep 25 18:18:53 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Mon Sep 25 18:18:53 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Mon Sep 25 18:18:53 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Mon Sep 25 18:18:53 2023] EXT4-fs (sda2): 6 orphan inodes deleted
      [Mon Sep 25 18:18:53 2023] EXT4-fs (sda2): recovery complete
      [Mon Sep 25 18:18:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Sep 25 18:18:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Mon Sep 25 18:18:55 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.0G    /var/
      2.4G    /var/log
      2.3G    /var/log/journal/d1492c3c26a048218fd90052e5ea5949
      293M    /var/lib
      Archived and active journals take up 2.2G in the file system.
      /opt/iobroker/backups:
      12M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      539M    /opt/iobroker/iobroker-data/
      428M    /opt/iobroker/iobroker-data/files
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      76M     /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/files/echarts
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      + system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovery"    : 3.1.0    , installed 3.2.0
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
      Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
      Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "statistics"   : 2.3.0    , installed 2.3.0
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        7938
      States:         7483
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:6 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:7 https://repos.influxdata.com/debian bullseye InRelease
      Hit:8 https://packages.grafana.com/oss/deb stable InRelease
      Get:9 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Fetched 4586 B in 2s (2051 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15212      1380/io.sonoff.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14557      403/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14547      589/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15640      403/deCONZ
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1735       750/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1721       750/iobroker.js-con
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14549      589/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2020       1047/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22170      2829/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        14651      654/influxd
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        1769       749/grafana
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1600       650/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15446      398/avahi-daemon: r
      udp        0      0 0.0.0.0:54658           0.0.0.0:*                           108        15448      398/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       20808      1669/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14560      403/deCONZ
      udp6       0      0 :::5353                 :::*                                108        15447      398/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       20809      1669/io.deconz.0
      udp6       0      0 :::39454                :::*                                108        15449      398/avahi-daemon: r
      2023-09-25 19:04:40.006  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: untere Grenze 48
      2023-09-25 19:04:40.006  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Prozent 52
      2023-09-25 19:04:40.006  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Watt 311.5
      2023-09-25 19:04:40.006  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: keine Änderung
      2023-09-25 19:05:00.007  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: Stromzähler Power in (W)308
      2023-09-25 19:05:00.007  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: Istwert Gespeicherte Power  53
      2023-09-25 19:05:00.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: obere Grenze 58
      2023-09-25 19:05:00.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: untere Grenze 48
      2023-09-25 19:05:00.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Prozent 52
      2023-09-25 19:05:00.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Watt 313.4
      2023-09-25 19:05:00.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: keine Änderung
      2023-09-25 19:05:20.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: Stromzähler Power in (W)305
      2023-09-25 19:05:20.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: Istwert Gespeicherte Power  53
      2023-09-25 19:05:20.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: obere Grenze 58
      2023-09-25 19:05:20.009  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: untere Grenze 48
      2023-09-25 19:05:20.009  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Prozent 52
      2023-09-25 19:05:20.009  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Watt 310.3
      2023-09-25 19:05:20.009  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: keine Änderung
      2023-09-25 19:05:40.005  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: Stromzähler Power in (W)306
      2023-09-25 19:05:40.006  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: Istwert Gespeicherte Power  53
      2023-09-25 19:05:40.007  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: obere Grenze 58
      2023-09-25 19:05:40.007  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: untere Grenze 48
      2023-09-25 19:05:40.007  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Prozent 52
      2023-09-25 19:05:40.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: benötigte Power in Watt 311.2
      2023-09-25 19:05:40.008  - info: javascript.0 (1167) script.js.PV_Nulleinspeisung.PV_Nulleinseisung: keine Änderung
      iob diag has finished.
      Press any key for a summary
      @thomas-braun vielleicht erkennst du ja etwas darin.
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Duffy last edited by
        @duffy sagte in Raspberry Pi stürtzt ab mit Echarts:
        Kaputt.
        • Duffy
          Hmm, das hilft mir jetzt nicht wirklich weiter 🙂
          Weder die Meldung noch weis ich was zu tun ist.
          Du hast da doch bestimmt einen Tip für mich 😉
            Installier es neu. Backup druff, fertig.
            • Duffy
              ALLES Neu 😥
              Betrifft der Fehler nur Echarts? Dann lasse ich es einfach.
              Ich müsste da Influxdb und grafana neu installieren das brauche ich wieder Tage für. 😢
              Was sagt den der Fehler überhaupt aus und wie findet man so einen Fehler in so viel Text?
              W Thomas Braun 2 Replies Last reply Reply Quote 0
                Wildbill @Duffy last edited by
                @duffy Der Fehler mit orphaned nodes sagt, dass mindestens Dein Dateisystem beschädigt ist, wenn nciht gar die SD-Karte. das passiert gerne, wenn man den Strom weg nimmt, bevor man sauber runterfährt.
                Raspi killen bei sowas gerne die SD-Karte, so dass eine neue her muss.
                Gruss, Jürgen
                • Duffy
                  Duffy @Wildbill last edited by Duffy
                  @wildbill
                  ich weis nicht ob das eine Rolle spielt aber ich habe eine SSD?
                  IOB fix oder so geht da nicht?
                  Oder anders beheben?
                    @duffy
                    Indem man den Text liest.
                    Steht hier drin:
                    Bedeutet, das hier 'inodes' (das ist die tiefste Ebene im Dateisystem nicht mehr zugeordnet werden konnten und gelöscht wurden). Und damit auch alles, was in diesen 'inodes' gespeichert war. Passiert halt beim harten Stromentzug gerne.
                    • Duffy
                      OK, danke für die Erklärung.
                      Aber hätte ich eine andere Möglichkeit gehabt ausser Stromlos machen?
                      Mit SSH ging ja auch nichts mehr.
                      Also wenn im Bodenseegebiet eine art Atompilz aufsteigt versuche ich den Pi neu aufzubauen.
                      Macht es Sinn in diesem Zusammenhang noch auf den PI Bücherwurm zu warten?
                      Thomas Braun W 2 Replies Last reply Reply Quote 0
                        Den 'Linux-Affengriff'. Gibt u. a. eine Wikipedia-Eintrag dazu.
                          A Former User @Duffy last edited by
                          Moin,
                          im Nachgang ist, das glaube ich, nicht mehr hilfreich.
                          Wenn Du Dich noch erinnerst, wann das war, Tag/Uhrzeit, dann könntest Du mal in die Logs schauen.
                          # ls -la /opt/iobroker/log
                          dann, entweder
                          # zmore /opt/iobroker/log/iobroker.2023-09-xx.gz      <- für xx den Tag einsetzen
                          oder
                          # zgrep -i 'error:' /opt/iobroker/log/iobroker.2023-09-xx.gz
                          Auch nicht verkehrt ist mal zu schauen, was vom Betriebssystem ins Log geschrieben wurde
                          # sudo journalctl -g error
                          oder, in dem man den Zeitbereich eingrenzt
                          # sudo journalctl -S "2023-09-23 15:00:00" -U "2023-09-24 10:00"
                          VG
                          Bernd
                          P.S.: sehe, Ihr seid schon bei einem neuen Thema 🙂
                            @duffy Wenn SSH nicht mehr geht (ungewöhnlich, aber soll vorkommen wenn die Kiste zu stark ausgelastet ist) so könnte man immer noch einen Monitor und eine USB-Tastatur anschliessen und schauen, ob da noch was geht oder ob Meldungen erscheinen.
                            Strom weg ist halt ein guter Garant für mindestens ein (teil-)zerstörtes Dateisystem, nämlich die noch geöffneten Dateien. Und von denen hat iobroker im Betrieb eben einige offen. Vom Betriebssystem ganz abgesehen. Beim PC/Laptop wird ja auch nicht (hoffentlich!) einfach so hart abgeschaltet, sondern sauber runtergefahren. Hartes Abschalten hatte ich zuletzt beim C64 und Amiga, bevor auch der eine Festplatte bekam.
                            Gruss, Jürgen
                            • Duffy
                              Duffy @Guest last edited by
                              @dp20eic
                              Er ist schon öfter mal abgestürzt (immer nur in Verbindung mit eCharts), Da weis ich nicht wann das immer war 😞
                              • Duffy
                                @wildbill
                                Aber dafür müsste ich doch eine grafische Oberfläche haben von der @Thomas-Braun immer abrät, oder?
                                  @duffy Nö. Eine Tastatur funktioniert natürlich auch in tty/Terminals. Da braucht es keinen Desktop.
                                    @duffy Nö, auf einem Server läuft keine grafische Oberfläche. Wenn Du einen Monitor anschließt, dann hast Du ein Terminal, ganz so, wie beim Zugriff per SSH. Nur eben direkt. Da kannst Du alles tun, was Du per SSH machst. Und da stehen dann auch öfter mal meldungen, wenn es Probleme gibt, die Du per SSh nicht siehst, wil sie eben nur auf das erste Terminal gehen, das ist eben das direkt auf dem gerät. Da kannst Du dann sudo shutdown eingeben um runter zu fahren. Oder eben iobroker mal stoppen, was weiss ich was sonst noch. Wenn gar nix mehr geht, dann kannst Du immer noch den "Linux-Affengriff" versuchen, den Thomas nannte. Dann werden offene Dateien geschlossen und anschließend ein Reset ausgelöst.
                                    Gruss, Jürgen
                                    • Duffy
                                      @wildbill
                                      Ok danke, das muss ich jetzt mal wirken lassen.
                                      Soll aber heißen wenn ich einen Monitor anschließe und die Tastatur über USB 2 sollte ich etwas auf dem Monitor sehen?
                                      Erkennt Linux den Monitor und die Taststur und bedarf es da wieder irgendwelche komplizierten Eingriffe.
                                      Danke aber schon mal an euch alle für eure Erklärungen.
                                        Hängt von den Gerätschaften ab. Eine Standardauflösung bekommst du aber immer hin.
                                          Moin,
                                          na, wenn das immer passiert, wenn Du eCharts benutzt, dann produziere es doch einfach und merk Dir die Zeit. Das journal wird durch einen Neustart nicht gelöscht und auch das Log vom ioBroker ist noch da.
                                          VG
                                          Bernd
                                          Thomas Braun Duffy 2 Replies Last reply Reply Quote 0
                                            @dp20eic sagte in Raspberry Pi stürtzt ab mit Echarts:
                                            Wenn es nicht gerade in den inodes liegt/lag... 😉
                                            2762
