    4. Nochmal Waschmaschine (Blockly)
    • Dutchman
      @totocotonio:
      danke für die Hilfe nochmals.
      Hier mal mein blockly.
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="n)UklDS{=z!-#^HfL@Ly" x="-387" y="-187"><mutation items="1"></mutation>
      <value name="OID0"><shadow type="field_oid" id="@Uda~stBc8L/=2DFzrvo"><field name="oid">hm-rpc.0.KEQ0964000.2.POWER</field></shadow></value>
      <statement name="STATEMENT"><block type="debug" id="!~Y{2`{u_D#TpSWIMBsp"><field name="Severity">log</field>
          <value name="TEXT"><shadow type="text" id="m2|8o}rKTp]cMHKqw}FP"><field name="TEXT">test</field></shadow>
            <block type="text_join" id="93tj,#+Z4-mx=Fv_Ve0Q"><mutation items="2"></mutation>
              <value name="ADD0"><block type="text" id="ln:{E)TNG?6tAh1bOVh)"><field name="TEXT">Leistung Waschmaschine</field></block></value>
              <value name="ADD1"><block type="get_value" id="!yLn|?I4;qOFtJ3Ga2hW"><field name="ATTR">val</field>
                  <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value></block></value>
          <next><block type="controls_if" id="Z5|[vDkx-;wE)n{g3h5A"><mutation elseif="1"></mutation>
              <value name="IF0"><block type="logic_operation" id="NOVG1{{6R.;TAAh#v:UO" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="logic_compare" id="RDf^,X[TFQ#jOw9*+|a|"><field name="OP">GT</field>
                      <value name="A"><block type="get_value" id="Y}z?|,]x;.[Y?nmoB_s/"><field name="ATTR">val</field>
                      <value name="B"><block type="math_number" id="+|Yj%~7wLv8n4e4dH./g"><field name="NUM">5</field></block></value></block></value>
                  <value name="B"><block type="logic_compare" id=")}{w;ZbwB)k3txT,A;=#"><field name="OP">EQ</field>
                      <value name="A"><block type="get_value" id="@c(1!S?xMk}JGgK|bGlx"><field name="ATTR">val</field>
                          <field name="OID">javascript.0.WaschmaschineFertig</field></block></value>
                      <value name="B"><block type="logic_boolean" id="z_W;~p[!3,i7T%Fz9ta."><field name="BOOL">FALSE</field></block></value></block></value></block></value>
              <statement name="DO0"><block type="control" id="TZy1bs~cU0]#Q/llGnxT"><mutation delay_input="false"></mutation>
                  <value name="VALUE"><block type="logic_boolean" id="G/q*p]xf4ro}^~?xKTM:"><field name="BOOL">TRUE</field></block></value>
                  <next><block type="procedures_callnoreturn" id="=!*WIp};Ta`)XeMMk,iR"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                      <value name="ARG0"><block type="text" id="{QcAY3oi:,FGG.929?TS"><field name="TEXT">Waschmaschine läuft</field></block></value></block></next></block></statement>
              <value name="IF1"><block type="logic_operation" id="ITf[:#D]rT*N(OE9k(])" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="logic_compare" id="TpC0To:j6|8MzRy1.f2k"><field name="OP">LT</field>
                      <value name="A"><block type="get_value" id="T=u6bL/a/n!;dBAIYw6}"><field name="ATTR">val</field>
                      <value name="B"><block type="math_number" id="G7qj]rc!Em08Z:ZUsn5x"><field name="NUM">2.5</field></block></value></block></value>
                  <value name="B"><block type="logic_compare" id="8rTp8F1^XtG_[nleJ@G3"><field name="OP">EQ</field>
                      <value name="A"><block type="get_value" id="e,Ywtew-),wrj7KJ4W]Y"><field name="ATTR">val</field>
                      <value name="B"><block type="logic_boolean" id="-RVml^-rH[c*)cCu4}oV"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
              <statement name="DO1"><block type="control" id="TW.9Qyp_]qo(-{!4/W`6"><mutation delay_input="false"></mutation>
                  <value name="VALUE"><block type="logic_boolean" id="@ue~G;yl^o]24s](g]`5"><field name="BOOL">FALSE</field></block></value>
                  <next><block type="procedures_callnoreturn" id="B`l`+_QZ59(g^%)j}HaL"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                      <value name="ARG0"><block type="text" id="(]@zEC}t.vRad}u(e.jr"><field name="TEXT">Die Waschmaschine ist fertig</field></block></value></block></next></block></statement></block></next></block></statement></block>
      <block type="procedures_defnoreturn" id="V.vrK8jxU~DFp7hok4hj" x="438" y="13"><mutation><arg name="Meldetext"></arg></mutation>
      <field name="NAME">Melden</field>
      <statement name="STACK"><block type="telegram" id="qeXSX4ZqV)9r]%/aF^c-"><value name="MESSAGE"><shadow type="text" id="B[gXJTVryMHY0%3dMM-V"><field name="TEXT">text</field></shadow>
      <block type="variables_get" id="Vv@sYq]5EIaZ7]yd2=,U"><field name="VAR">Meldetext</field></block></value>
      <next><block type="sayit" id="OBX-i}?Pff]w@CV,gAOQ"><field name="INSTANCE">.0</field>
      <field name="LANGUAGE">de</field>
              <value name="MESSAGE"><shadow type="text" id="H?c?t#M!gEg`p~A-}D)p"><field name="TEXT">text</field></shadow>
                <block type="variables_get" id="vb*+mV[r3)ql7(BL,uDu"><field name="VAR">Meldetext</field></block></value></block></next></block></statement></block></xml>
      so habe es jetzt mal probiert so zu loesen hoffe das past einigermassen, zur erklaehrung:
      • ich habe fuer die ansage einen time-out eingestellt der sich erst nach 5 minuten ausloest (kannst du im blockly einstellen)
      • eine variable wird gesetzt sobald dieser timer gestartet wird
      • diese variable ueberpruefe ich in einem weiteren else-if um den timer wieder zu loeschen sollte die watt angabe > 5 werden.
      • ich setze bewusst den wert "waschmaschine fertig" auch erst nach dem timer, sonst kommt ja auch immer wieder "waschmachine laeuft"
      Ich erhoffe mir das damit dein problem einigermassen geloest wird, ausgangssituation:
      • es soll eine meldung kommen wen die waschmachine anfaengt (>5) und fertig war
      • es soll eine meldungen kommen wen sie fertig ist (<2.5) mit 5 minuten veroegerung
      • sollte der wert innerhalb der 5 minuten wieder >5 werden muss der timer fuer die aussage und status fertig resetted werden ohne das die meldung "waschmachine laeuft" abgegeben wird.
      export:
      <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="n)UklDS{=z!-#^HfL@Ly" x="-687" y="-162"><mutation items="1"></mutation>
      <statement name="STATEMENT"><block type="debug" id="!~Y{2{u_D#TpSWIMBsp"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="m2|8o}rKTp]cMHKqw}FP"><field name="TEXT">test</field></shadow> <block type="text_join" id="93tj,#+Z4-mx=Fv_Ve0Q"><mutation items="2"></mutation> <value name="ADD0"><block type="text" id="ln:{E)TNG?6tAh1bOVh)"><field name="TEXT">Leistung Waschmaschine</field></block></value> <value name="ADD1"><block type="get_value" id="!yLn|?I4;qOFtJ3Ga2hW"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value></block></value> <next><block type="controls_if" id="Z5|[vDkx-;wE)n{g3h5A"><mutation elseif="2"></mutation> <value name="IF0"><block type="logic_operation" id="NOVG1{{6R.;TAAh#v:UO" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="RDf^,X[TFQ#jOw9*+|a|"><field name="OP">GT</field> <value name="A"><block type="get_value" id="Y}z?|,]x;.[Y?nmoB_s/"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value> <value name="B"><block type="math_number" id="+|Yj%~7wLv8n4e4dH./g"><field name="NUM">5</field></block></value></block></value> <value name="B"><block type="logic_compare" id=")}{w;ZbwB)k3txT,A;=#"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="@c(1!S?xMk}JGgK|bGlx"><field name="ATTR">val</field> <field name="OID">javascript.0.WaschmaschineFertig</field></block></value> <value name="B"><block type="logic_boolean" id="z_W;~p[!3,i7T%Fz9ta."><field name="BOOL">FALSE</field></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="TZy1bs~cU0]#Q/llGnxT"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.WaschmaschineFertig</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="G/q*p]xf4ro}^~?xKTM:"><field name="BOOL">TRUE</field></block></value> <next><block type="procedures_callnoreturn" id="=!*WIp};Ta)XeMMk,iR"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
      <value name="IF1"><block type="logic_operation" id="@{7k94li-JxVqj@t@gQ!" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="C035eawvwt+v-WVWP@"><field name="OP">GT</field> <value name="A"><block type="get_value" id="8R*A2%8%:I8t3Kix6XO+"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value> <value name="B"><block type="math_number" id="{Kw5XA/x9p0{z4yQ_6r3"><field name="NUM">5</field></block></value></block></value> <value name="B"><block type="logic_compare" id="7Uc{g8acG,c-8t{]:L)"><field name="OP">EQ</field>
      <value name="A"><block type="variables_get" id="kY
      iz1~X^Xd2p.8hJM)D"><field name="VAR">check_ready</field></block></value>
      <value name="B"><block type="logic_boolean" id=",I1.9I/cktHnk%W9z-xj"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
      <statement name="DO1"><block type="timeouts_cleartimeout" id="CUH4u1*~,d8@=rn|d[-t"><field name="NAME">ready</field>
      <next><block type="variables_set" id="Mpln]FVs06lI17me1NW0"><field name="VAR">check_ready</field>
      <value name="VALUE"><block type="logic_boolean" id="MNwyF2ChGX{lSgp0Rq4"><field name="BOOL">FALSE</field></block></value></block></next></block></statement>
      <value name="IF2"><block type="logic_operation" id="ITf[:#D]rT
      <statement name="DO2"><block type="variables_set" id="@7_1gL2z!VBA_Phg+5]B"><field name="VAR">check_ready</field>
      <value name="VALUE"><block type="logic_boolean" id="4R2+st0_Td6FV?D[GPve"><field name="BOOL">TRUE</field></block></value>
      <next><block type="timeouts_settimeout" id=";F~?;,Bq-Lq[ShIwPxcD"><field name="NAME">ready</field>
      <field name="DELAY">5</field>
      <statement name="STATEMENT"><block type="control" id="TW.9Qyp_]qo(-{!4/W6"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.WaschmaschineFertig</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="@ue~G;yl^o]24s](g]5"><field name="BOOL">FALSE</field></block></value>
      <next><block type="procedures_callnoreturn" id="Bl+_QZ59(g^%)j}HaL"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
      <value name="ARG0"><block type="text" id="(]@zEC}t.vRad}u(e.jr"><field name="TEXT">Die Waschmaschine ist fertig</field></block></value></block></next></block></statement></block></next></block></statement></block></next></block></statement></block>
      • Dutchman
        update: Ich habe noch eine kleine kleinichkeit geaendert. Da ich nicht weis op es vorkommen kan das der wert auch <2.5 eventuell oefters mal erneuert wird habe ich zur sicherheit noch eine extra abfrage der variable eingebaut und nur um ganz sicher zu sein auch einen time-reset befohr er gesetzt wird.
        @Ratanplan kan mich ja spaeter wieder verbessern :lol:
        export:
        <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="n)UklDS{=z!-#^HfL@Ly" x="-737.6400146484375" y="-162.95999145507812"><mutation items="1"></mutation>
        <value name="B"><block type="logic_operation" id="t|X/_5/NFsnY4Ej!p1@" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="8rTp8F1^XtG_[nleJ@G3"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="e,Ywtew-),wrj7KJ4W]Y"><field name="ATTR">val</field> <field name="OID">javascript.0.WaschmaschineFertig</field></block></value> <value name="B"><block type="logic_boolean" id="-RVml^-rH[c*)cCu4}oV"><field name="BOOL">TRUE</field></block></value></block></value> <value name="B"><block type="logic_compare" id="}C@yU^z*.TPRlSzP6+05"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="Rf}b@/f5qTJELOy92#:g"><field name="VAR">check_ready</field></block></value> <value name="B"><block type="logic_boolean" id="Qz}!muDx94x=?bA/nhO"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value>
        <next><block type="timeouts_cleartimeout" id="4wEif?i7xM%Wty}?F*L"><field name="NAME">ready</field> <next><block type="timeouts_settimeout" id=";F~?;,Bq-Lq[ShIwPxcD"><field name="NAME">ready</field> <field name="DELAY">5</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="control" id="TW.9Qyp_]qo(-{!4/W6"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="logic_boolean" id="@ue~G;yl^o]24s](g]5"><field name="BOOL">FALSE</field></block></value> <next><block type="procedures_callnoreturn" id="Bl`+_QZ59(g^%)j}HaL"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
        <value name="ARG0"><block type="text" id="(]@zEC}t.vRad}u(e.jr"><field name="TEXT">Die Waschmaschine ist fertig</field></block></value></block></next></block></statement></block></next></block></next></block></statement></block></next></block></statement></block>
        • totocotonio
          totocotonio last edited by
          wie cool ist das denn 😄
          Danke für Deine Hilfe.
          Ich habe jetzt mal schnell Dein Blockly importiert.
          Jetzt muss meine Frau nur nochmal waschen, aber heute leider nicht mehr. :ugeek:
          Ich danke Dir und den anderen nochmal in aller schärfster Form.
          Ich werde berichten ob dein Blockly so funktioniert.
          • N
            nibblerrick last edited by
            Na um zu sehen ob es funktioniert ist es doch mal eine perfekte Motivation selbst was zu waschen 😉
            • Dutchman
              @nibblerrick:
              Na um zu sehen ob es funktioniert ist es doch mal eine perfekte Motivation selbst was zu waschen 😉 `
              Es gibt Grenzen 😛
              Bin gespannt sag Bescheid ob es was geworden ist
              Send from mobile device
              • N
                Also meine Frau koennte ja heute noch nicht waschen, wenn ich ihr das nicht beigebracht haette 😄
                Ja, bin auch gespannt ob es funktioniert!
                • totocotonio
                  also da ich eine Waschmaschine nicht bedienen kann, hat dies meine Frau getan. :lol:
                  Die erste Meldung das Waschmaschine läuft kam, seit dem sie läuft ist alles ruhig.
                  Jetzt warte ich mal ab wenn sie fertig ist.
                  Ich werde berichten.
                  • Dutchman
                    @totocotonio:
                    Ich werde berichten. `
                    :lol:
                    Na dann funktioniert auf jedenfall schonmal 50% 😛
                    • totocotonio
                      muss leider berichten das es nicht funktioniert.
                      Die Anfangs Meldung kam.
                      Leistung jetzt seit ca.10 Minuten auf 2 Watt, State True. :?:
                      Keine Meldung
                      • Dutchman
                        @totocotonio:
                        Keine Meldung `
                        ok und du bist dir sicher das der wert zwischendurch nicht mal nach >5 gegangen ist ?
                        kans du mal bitte logging einbauen hinter allen IF abfragen damit wir sehen welche routine er durschlaeuft
                        • totocotonio
                          ok danke für den Hinweis.
                          Ich habe mal wieder ein Logging eingebaut.
                          Nur heute wird nicht mehr gewaschen 😛
                          Ich werde morgen berichten.
                          Danke bis morgen dann .
                          • rantanplan
                            rantanplan last edited by
                            Habe mir mal das Blockly von Dutchman angeschaut.
                            Es ist, für mich, schwer zu "lesen".
                            Die Variablen Benennung ist etwas unglücklich.
                            Warum soll bei "WaschmaschieneFertig = false" die Meldung kommen , dass die Maschine fertig ist?
                            Ich denke da immer andersrum "WaschmaschineFertig = true", dann wäre für mich die Maschine fertig.
                            • rantanplan
                              Ich habe mal die Logik der Variable auf meine Denkweise umgestellt.
                              Die Vorgehensweise von Dutchman war schon richtig.
                              Habe jetzt nicht überprüft ob da ein Logik-Dreher drin war.
                              Grundsätzlich sollte man sich ein genaues Protokoll von den Leistungsdaten seiner Waschmaschine erstellen.
                              Wahrscheinlich ist wird auch mit unterschiedlichen Waschprogrammen gewaschen.
                              Ohne genaue Daten der Waschmaschine ist das ein fischen im Trüben.
                              Export
                              <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="n)UklDS{=z!-#^HfL@Ly" x="-737" y="-162"><mutation items="1"></mutation>
                              <statement name="STATEMENT"><block type="procedures_callnoreturn" id="IVHR(]?*K6E(XAH3iw*`"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                                  <value name="ARG0"><block type="text_join" id="93tj,#+Z4-mx=Fv_Ve0Q"><mutation items="2"></mutation>
                                      <value name="ADD0"><block type="text" id="ln:{E)TNG?6tAh1bOVh)"><field name="TEXT">***Leistung Waschmaschine</field></block></value>
                                              <value name="B"><block type="logic_boolean" id="z_W;~p[!3,i7T%Fz9ta."><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                                      <statement name="DO0"><block type="comment" id="AQ2D[:gclugPLA1/8}x!"><field name="COMMENT">Waschgang beginnt</field>
                                          <next><block type="control" id="TZy1bs~cU0]#Q/llGnxT"><mutation delay_input="false"></mutation>
                                              <value name="VALUE"><block type="logic_boolean" id="G/q*p]xf4ro}^~?xKTM:"><field name="BOOL">FALSE</field></block></value>
                                                  <value name="ARG0"><block type="text" id="{QcAY3oi:,FGG.929?TS"><field name="TEXT">Waschmaschine läuft</field></block></value></block></next></block></next></block></statement>
                                          <value name="A"><block type="logic_compare" id="C0*35eawvw`t+v-WVWP@"><field name="OP">GT</field>
                                          <value name="B"><block type="logic_compare" id="7Uc{g8acG,c-8t`{]:L)"><field name="OP">EQ</field>
                                              <value name="A"><block type="variables_get" id="kY*iz1~X^Xd2p.8hJM)D"><field name="VAR">check_ready</field></block></value>
                                      <statement name="DO1"><block type="comment" id="HQL/_vWme!|w^~@lTM`U"><field name="COMMENT">Power war schon mal unter 2.5</field>
                                          <next><block type="comment" id="kL+[~..qKXP923)-(QTH"><field name="COMMENT">Timer wieder stoppen</field>
                                              <next><block type="timeouts_cleartimeout" id="CUH4u1*~,d8@=rn|d[-t"><field name="NAME">ready</field>
                                                      <value name="VALUE"><block type="logic_boolean" id="MNwyF2ChG*X{lSgp0Rq4"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></next></block></statement>
                                      <value name="IF2"><block type="logic_operation" id="ITf[:#D]rT*N(OE9k(])" inline="false"><field name="OP">AND</field>
                                          <value name="B"><block type="logic_operation" id="t|X/`_5/NFsnY4Ej!p1@" inline="false"><field name="OP">AND</field>
                                                  <value name="B"><block type="logic_boolean" id="-RVml^-rH[c*)cCu4}oV"><field name="BOOL">FALSE</field></block></value></block></value>
                                                  <value name="B"><block type="logic_boolean" id="Qz}!muDx94x=?b`A/nhO"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value>
                                      <statement name="DO2"><block type="comment" id="G~cT}m2_UG;fFEXQywAM"><field name="COMMENT">Power geht unter 2.5</field>
                                          <next><block type="variables_set" id="@7_1gL2z!VBA_Phg+5]B"><field name="VAR">check_ready</field>
                                              <next><block type="timeouts_cleartimeout" id="`4wEif?i7xM%Wty}?F*L"><field name="NAME">ready</field>
                                                      <statement name="STATEMENT"><block type="control" id="TW.9Qyp_]qo(-{!4/W`6"><mutation delay_input="false"></mutation>
                                                          <value name="VALUE"><block type="logic_boolean" id="@ue~G;yl^o]24s](g]`5"><field name="BOOL">TRUE</field></block></value>
                                                              <value name="ARG0"><block type="text" id="(]@zEC}t.vRad}u(e.jr"><field name="TEXT">Die Waschmaschine ist fertig</field></block></value></block></next></block></statement></block></next></block></next></block></next></block></statement></block></next></block></statement></block>
                              <block type="procedures_defnoreturn" id="l1.gm`YNTt2#Ww;Stf+" x="38" y="-13"><mutation><arg name="Meldetext"></arg></mutation>
                              <statement name="STACK"><block type="debug" id="SYQu;@N0JgE!W~[JZcZ
                              <value name="TEXT"><shadow type="text" id="4+J8c.^+FrkDV^]dAda-"><field name="TEXT">test</field></shadow>
                              <block type="variables_get" id="KuX^Hf4/i6gnp|rmq9WR"><field name="VAR">Meldetext</field></block></value></block></statement></block></xml>
                              • Dutchman
                                Ich hatte die Variable so übernommen von totocotonio fand sie auch falschherum aber da dies bereits so lief hatte ich es dabei gelassen.
                                Umdrehen ist aber besser für die Logic 😉
                                • totocotonio
                                  ihr habt natürlich recht, die Logik von mir war falsch
                                  andersherum macht es mehr Sinn.
                                  Ich schreibe im Moment mal die Daten mit.
                                  Fakt ist, bei genau 2,01 Watt ist Waschmaschine fertig (Standby)
                                  Deshalb habe ich den Wert 2,5 Watt genommen.
                                  Ich werde heute Abend mal das Blockly nach Deinen Vorgaben "Umbauen"
                                  und mal wieder einen Waschgang starten.
                                  Vielen Dank für die super Hilfe hier im Forum.
                                  Ich melde mich und werde berichten.
                                  • totocotonio
                                    jetzt kommt keine Meldung mehr das die Maschine an ist, komisch.
                                    Sobald sie fertig ist kommt ständig die Meldung mit der Leistung der Maschine :?:
                                    17:48:25.177	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine2.09
                                    17:51:07.867	[info]	javascript.0 Stop script script.js.Waschmaschine_Rantanplan
                                    17:51:07.956	[info]	javascript.0 Start javascript script.js.Waschmaschine_Rantanplan
                                    17:51:07.956	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: registered 13 subscriptions and 9 schedules
                                    17:51:11.233	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine0.09
                                    17:58:02.955	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine0.08
                                    Jetzt Waschmaschine neu gestartet, dann das. State ist true
                                    17:58:50.698	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine11.47
                                    17:58:50.699	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    17:58:58.693	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine60.47
                                    17:59:06.753	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine63.25
                                    17:59:06.753	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    17:59:23.683	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine67.39
                                    17:59:31.699	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine72.71
                                    17:59:31.699	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    17:59:39.681	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine76.03
                                    17:59:47.699	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine96.58
                                    17:59:47.699	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    17:59:55.708	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine102.92
                                    18:00:03.747	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine119.14
                                    18:00:03.748	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    18:00:11.681	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine2.45
                                    18:00:27.705	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine17.78
                                    18:00:35.724	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine122.8
                                    18:00:35.724	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    18:00:37.177	[info]	javascript.0 Stop script script.js.Waschmaschine_Rantanplan
                                    18:00:37.237	[info]	javascript.0 Start javascript script.js.Waschmaschine_Rantanplan
                                    18:00:37.237	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Leistung Waschmaschine122.8
                                    18:00:37.238	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: registered 13 subscriptions and 9 schedules
                                    18:00:51.701	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    18:00:59.670	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    18:01:29.680	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    18:01:45.864	[info]	javascript.0 script.js.Waschmaschine_Rantanplan: Waschmaschine läuft
                                    Mod Edit : Log in code block bitte !
                                    • Dutchman
                                      @totocotonio:
                                      Jetzt Waschmaschine neu gestartet, dann das. State ist true `
                                      das stimm schomal nicht er sollte unwahr sein wen die machine angelaufen ist, stehen jetzt mehrere blocklys mal bitten:
                                      • dein jetziges blockly posten (screen und export)
                                      • totocotonio
                                        <block xmlns="http://www.w3.org/1999/xhtml" type="procedures_callnoreturn" id="IVHR(]?K6E(XAH3iw`" x="162.5999755859375" y="-187"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                                        <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value></block></value></block>
                                         ![1626_aktuellles_blockly.png](/assets/uploads/files/1626_aktuellles_blockly.png)
                                        Hier die geforderten Daten.
                                        Bitte um Hilfe
                                        • Dutchman
                                          @totocotonio:
                                          Bitte um Hilfe `
                                          da fehlt was in deinem export 🙂 sieht so aus als ob nur ein block exportiert worden ist anstatt alles…
                                          Ich sehe so schnell kein fehler im script, mal ausgeschrieben:
                                          [situation 1]
                                          • Wen der wert power > 5 ist und waschmachine fertig = wahr, dan setze wert auf unwahr und sende sayit text
                                          [dieser teil functioniert auch nicht mehr ?]
                                          [situation 2]
                                          • wen der wert jetzt < 2.5 wird und check_ready variable = unwahr, dan setze variable auf wahr und starte time fuer sayit waschmachine ist aus
                                          [situation 3]
                                          • wen der wert jetzt wieder >5 und die variable fuer den time ist wahr, dan resette den timer wieder
                                          Ich sehe auch keine debug bloecke, als wo kommen da jetzt die werte her aus deinem post ? Laeuft da eventuel noch ein 2tes script ?
                                          ich kappier vor allem nicht das: "Jetzt Waschmaschine neu gestartet, dann das. State ist true" da genau dieser wert ja auf unwahr gehen muesste wen die waschmachine wieder angelaufen ist
                                          • totocotonio
                                            ich habe nur dieses Script am laufen.
                                            Die Werte habe ich mitgeloggt aber nicht exportiert
                                            Auch den Melden Block habe ich nicht exportiert, der tut ja nichts zu Sache
                                            Ich habe die Waschmaschine gestartet und wie die im Log gesehen hast, kommt die Meldung das
                                            die Maschine läuft aber der State war "true". Keine Ahnung warum.
                                            Es kam ständig die Meldung "Waschmaschine läuft"
                                            Hier mal der Mitschnitt in Telegramm, dann musste ich das Script schließen, denn die Meldungen hörten nicht auf.
                                            ! Leistung Waschmaschine0.09 ! Leistung Waschmaschine0.08 ! Leistung Waschmaschine11.47 ! Waschmaschine läuft ! Waschmaschine läuft ! Leistung Waschmaschine60.47 ! Waschmaschine läuft ! Leistung Waschmaschine63.25 ! Waschmaschine läuft ! Leistung Waschmaschine67.39 ! Leistung Waschmaschine72.71 ! Waschmaschine läuft ! Waschmaschine läuft ! Leistung Waschmaschine76.03 ! Waschmaschine läuft ! Leistung Waschmaschine96.58 ! Waschmaschine läuft ! Leistung Waschmaschine102.92 ! Leistung Waschmaschine119.14 ! Waschmaschine läuft ! Leistung Waschmaschine2.45 ! Waschmaschine läuft ! Leistung Waschmaschine17.78 ! Leistung Waschmaschine122.8 ! Waschmaschine läuft ! Leistung Waschmaschine122.8 ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft ! Waschmaschine läuft !
                                            153
                                            29661
