    4. iobroker geht nicht nach stromausfall
      Thomas Braun Most Active @Esmax666 last edited by
      @esmax666
      Der user ist nicht in der Gruppe 'iobroker' drin.
      sudo usermod -a -G iobroker esmax
      Dann den esmax aus- und wieder einloggen.
      E 1 Reply Last reply Reply Quote 2
        @esmax666 sagte in iobroker geht nicht nach stromausfall:
        wie kann man ein Files über SSH kopieren ?
        Mit
        scp /quelldatei //ZIEL
          Esmax666 @Thomas Braun last edited by Esmax666
          ok jetzt passt:
          nur seltsam er hat kein downgrade gemacht
          esmax@ubuntu:~$ iob stop
          esmax@ubuntu:~$ npm install iobroker.js-controller@3.3.22
          up to date, audited 282 packages in 3s
          9 packages are looking for funding
            run `npm fund` for details
          7 vulnerabilities (1 low, 5 moderate, 1 high)
          To address issues that do not require attention, run:
            npm audit fix
          To address all issues (including breaking changes), run:
            npm audit fix --force
          Run `npm audit` for details.
          esmax@ubuntu:~$ iob start
          esmax@ubuntu:~$ iob status
          Objects type: jsonl
          States  type: jsonl
          esmax@ubuntu:~$ iob list instances
          + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
          + system.adapter.discovery.0              : discovery             : ubuntu                                   -  enabled
          + instance is alive
          esmax@ubuntu:~$
          Skript v.2023-06-20
          *** BASE SYSTEM ***
           Static hostname: ubuntu
                 Icon name: computer
                Machine ID: 7be3a0aee2194ee18739a3f0fb03a71f
                   Boot ID: c9f47a2216fa43918fa2392ef232ef9a
          Operating System: Ubuntu 23.04
                    Kernel: Linux 6.2.0-1013-raspi
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           20:58:29 up 54 min,  2 users,  load average: 0.17, 0.24, 0.22
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=58.9'C
          volt=0.8600V
          *** Time and Time Zones ***
                         Local time: Tue 2023-09-26 20:58:30 CEST
                     Universal time: Tue 2023-09-26 18:58:30 UTC
                           RTC time: n/a
                          Time zone: Europe/Paris (CEST, +0200)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          esmax
          /home/esmax
          esmax adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.2G        739M        5.8G        3.2M        2.0G        7.4G
          Swap:             0B          0B          0B
          Total:          8.2G        739M        5.8G
                   7809 M total memory
                    704 M used memory
                    616 M active memory
                   1350 M inactive memory
                   5531 M free memory
                     99 M buffer memory
                   1785 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          Filesystem     Type   Size  Used Avail Use% Mounted on
          tmpfs          tmpfs  781M  3.1M  778M   1% /run
          /dev/mmcblk0p2 ext4    59G  4.8G   52G   9% /
          tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
          /dev/mmcblk0p1 vfat   253M  151M  102M  60% /boot/firmware
          tmpfs          tmpfs  781M  4.0K  781M   1% /run/user/1000
          [Tue Sep 26 20:04:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
          [Tue Sep 26 20:04:19 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
          [Tue Sep 26 20:04:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
          [Tue Sep 26 20:04:22 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET              SOURCE         FSTYPE   OPTIONS
          /                   /dev/mmcblk0p2 ext4     rw,relatime,discard,errors=remount-ro,commit=30
          |-/snap/core22/611  /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
          |-/snap/core22/867  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
          |-/snap/lxd/25755   /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snapd/18600 /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
          |-/snap/lxd/24646   /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
          `-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.4G    /var/
          677M    /var/lib
          626M    /var/cache
          614M    /var/cache/apt
          528M    /var/cache/apt/archives
          Archived and active journals take up 39.0M in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          19M     /opt/iobroker/iobroker-data/
          15M     /opt/iobroker/iobroker-data/files
          13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          3.8M    /opt/iobroker/iobroker-data/objects.jsonl
          2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
          1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
          652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x lunar/main arm64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1ubuntu2 500
                  500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          No configuration change needed.
          Multihost discovery server: disabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    jsonl on 127.0.0.1
          States:                     jsonl on 127.0.0.1
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     "javascript" not found
          Adapters from github:   0
          Adapter State
          + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
          Objects and States
          Objects:        142
          States:         105
          Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
          Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
          Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
          Hit:4 https://deb.nodesource.com/node_18.x lunar InRelease
          Hit:5 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51024      8657/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52828      8657/iobroker.js-co
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          45437      1/init
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        19378      539/systemd-resolve
          tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        19380      539/systemd-resolve
          tcp6       0      0 :::22                   :::*                    LISTEN      0          21209      1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          45439      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       52867      8686/io.admin.0
          udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        19379      539/systemd-resolve
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        19377      539/systemd-resolve
          udp        0      0 192.168.178.51:68       0.0.0.0:*                           998        19983      793/systemd-network
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          47435      1/init
          udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        19990      793/systemd-network
          udp6       0      0 :::111                  :::*                                0          47437      1/init
          2023-09-26 20:57:19.162  - info: host.ubuntu added notifications configuration of host
          2023-09-26 20:57:19.717  - info: host.ubuntu Delete state "system.host.ubuntu.versions.nodeCurrent"
          2023-09-26 20:57:19.726  - info: host.ubuntu 3 instances found
          2023-09-26 20:57:19.737  - info: host.ubuntu starting 3 instances
          2023-09-26 20:57:19.811  - info: host.ubuntu instance system.adapter.admin.0 started with pid 8686
          2023-09-26 20:57:19.841  - info: host.ubuntu Delete state "system.host.ubuntu.versions.nodeNewest"
          2023-09-26 20:57:19.909  - info: host.ubuntu Delete state "system.host.ubuntu.versions.nodeNewestNext"
          2023-09-26 20:57:19.927  - info: host.ubuntu Delete state "system.host.ubuntu.versions.npmCurrent"
          2023-09-26 20:57:19.946  - info: host.ubuntu Delete state "system.host.ubuntu.versions.npmNewest"
          2023-09-26 20:57:19.965  - info: host.ubuntu Delete state "system.host.ubuntu.versions.npmNewestNext"
          2023-09-26 20:57:19.984  - info: host.ubuntu Some obsolete host states deleted.
          2023-09-26 20:57:22.810  - info: admin.0 (8686) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 4.0.24
          2023-09-26 20:57:22.899  - info: admin.0 (8686) requesting all states
          2023-09-26 20:57:22.900  - info: admin.0 (8686) requesting all objects
          2023-09-26 20:57:23.469  - info: admin.0 (8686) received all objects
          2023-09-26 20:57:23.778  - info: admin.0 (8686) http server listening on port 8081
          2023-09-26 20:57:23.780  - info: admin.0 (8686) Use link "http://localhost:8081" to configure.
          2023-09-26 20:57:23.796  - info: admin.0 (8686) socket.io server listening on port 8081
          2023-09-26 20:57:23.842  - info: host.ubuntu instance system.adapter.discovery.0 started with pid 8710
          2023-09-26 20:57:23.965  - info: admin.0 (8686) ==> Connected system.user.admin from ::ffff:192.168.178.39
          2023-09-26 20:57:24.230  - info: admin.0 (8686) ==> Connected system.user.admin from ::ffff:192.168.178.39
          2023-09-26 20:57:26.295  - info: discovery.0 (8710) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.17.1, js-controller: 4.0.24
          2023-09-26 20:57:27.790  - info: host.ubuntu instance system.adapter.backitup.0 started with pid 8733
          2023-09-26 20:57:30.561  - info: backitup.0 (8733) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 4.0.24
          2023-09-26 20:57:30.720  - info: backitup.0 (8733) [iobroker] backup will be activated at 02:40 every 1 day(s)
          iob diag has finished.
          Press any key for a summary
            @thomas-braun so ?
            scp /C:\Users\esmax\Downloads\iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz //opt/iobroker/backups
              Nee, 'er' hat den js-controller jetzt nochmal dort installiert, wo der admin 'ihm' gesagt hat, das er hin soll. Kurz: Du stehst im falschen Verzeichnis.
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
              muss das lauten.
              • OliverIO
                OliverIO @Esmax666 last edited by
                @esmax666
                Für so etwas verwende ich WinSCP
                https://winscp.net/eng/download.php
                Da hast du die typische Commander ansicht mit 2 Seiten. Eine Lokal und eine eine oder mehrere SSH-Sessions.
                Da kann man auch mal schnell was nachschauen.
                  @thomas-braun said in iobroker geht nicht nach stromausfall:
                  omg danke 🙂
                    Esmax666 @OliverIO last edited by
                    @oliverio
                    wow war wirklich einfach
                    problem ist genau wie letzte Woche:
                    Nach mein backup startet iobroker einfach nicht mehr
                    smax@ubuntu:/opt/iobroker/backups$ iobroker stop
                    esmax@ubuntu:/opt/iobroker/backups$ iobroker restore iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
                    iobroker controller daemon is not running
                    host.ubuntu OK.
                    host.ubuntu Clear all objects and states...
                    clean 142 objects...
                    Server Objects 127.0.0.1:36324 Error from InMemDB: Error: Object is marked as non deletable
                    [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                    [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                    [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
                    [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                    [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
                    [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
                    clean 105 states...
                    host.ubuntu done.
                    host.ubuntu Processed 0/3050 states
                    host.ubuntu Processed 200/3050 states
                    host.ubuntu Processed 400/3050 states
                    host.ubuntu Processed 600/3050 states
                    host.ubuntu Processed 800/3050 states
                    host.ubuntu Processed 1000/3050 states
                    host.ubuntu Processed 1200/3050 states
                    host.ubuntu Processed 1400/3050 states
                    host.ubuntu Processed 1600/3050 states
                    host.ubuntu Processed 1800/3050 states
                    host.ubuntu Processed 2000/3050 states
                    host.ubuntu Processed 2200/3050 states
                    host.ubuntu Processed 2400/3050 states
                    host.ubuntu Processed 2600/3050 states
                    host.ubuntu Processed 2800/3050 states
                    host.ubuntu Processed 3000/3050 states
                    3050 states restored.
                    host.ubuntu Processed 0/4382 objects
                    host.ubuntu Processed 200/4382 objects
                    host.ubuntu Processed 400/4382 objects
                    host.ubuntu Processed 600/4382 objects
                    host.ubuntu Processed 800/4382 objects
                    host.ubuntu Processed 1000/4382 objects
                    host.ubuntu Processed 1200/4382 objects
                    host.ubuntu Processed 1400/4382 objects
                    host.ubuntu Processed 1600/4382 objects
                    host.ubuntu Processed 1800/4382 objects
                    host.ubuntu Processed 2000/4382 objects
                    host.ubuntu Processed 2200/4382 objects
                    host.ubuntu Processed 2400/4382 objects
                    host.ubuntu Processed 2600/4382 objects
                    host.ubuntu Processed 2800/4382 objects
                    host.ubuntu Processed 3000/4382 objects
                    host.ubuntu Processed 3200/4382 objects
                    host.ubuntu Processed 3400/4382 objects
                    host.ubuntu Processed 3600/4382 objects
                    host.ubuntu Processed 3800/4382 objects
                    host.ubuntu Processed 4000/4382 objects
                    host.ubuntu Processed 4200/4382 objects
                    4382 objects restored.
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular (1).woff
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.eot
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.ttf
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff2
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/edit_copy.svg
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w.svg
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w_open.svg
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/heatingcontrol.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-128x128.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-512x512.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-128x128.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-512x512.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-128x128.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-512x512.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-128x128.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-512x512.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-128x128.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-512x512.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-128x128.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-512x512.png
                    host.ubuntu Upload user file "vis.0/HeatingControl/images/it_wifi.svg
                    host.ubuntu Upload user file "vis.0/HeatingControl/vis-user.css
                    host.ubuntu Upload user file "vis.0/HeatingControl/vis-views.json
                    host.ubuntu Upload user file "vis.0/main/vis-views.json
                    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map application/json
                    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map application/json
                    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js application/javascript
                    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map application/json
                    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js application/javascript
                    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map application/json
                    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js application/javascript
                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js.map custom/static/js/main.681927cc.js.map application/json
                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/en.json custom/i18n/en.json application/json
                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                    System successfully restored!
                    esmax@ubuntu:/opt/iobroker/backups$ iobroker start
                      Danach geht es erst richtig los.
                      Schau in das
                      iob logs --watch
                      rein.
                        @thomas-braun stat.txt
                        vielleicht muss man ein downgrade von iobroker komplet machen genau wie admin 😕
                          @esmax666
                          Keine Ahnung. Mit solchen Oldtimer-Versionen beschäftige ich mich eigentlich auch nicht.
                            @thomas-braun könntest du mein stat.txt öffnen ? da ist alles drin
                            sonst diag:
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             21:29:22 up  1:25,  2 users,  load average: 0.96, 0.93, 0.65
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=68.6'C
                            volt=0.9260V
                                           Local time: Tue 2023-09-26 21:29:22 CEST
                                       Universal time: Tue 2023-09-26 19:29:22 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            esmax
                            /home/esmax
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        601M        5.8G        3.3M        2.1G        7.6G
                            Swap:             0B          0B          0B
                            Total:          8.2G        601M        5.8G
                                     7809 M total memory
                                      573 M used memory
                                      588 M active memory
                                     1334 M inactive memory
                                     5572 M free memory
                                      104 M buffer memory
                                     1876 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4    59G  4.9G   51G   9% /
                            /var:
                            1.4G    /var/
                            677M    /var/lib
                            626M    /var/cache
                            614M    /var/cache/apt
                            4.5M    /opt/iobroker/backups/
                            31M     /opt/iobroker/iobroker-data/
                            19M     /opt/iobroker/iobroker-data/files
                            11M     /opt/iobroker/iobroker-data/objects.jsonl
                            1.6M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                             Cannot read system.config: null (OK when migrating or restoring)
                             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            No connection to databases possible ...
                            Objects:                    file on 127.0.0.1
                            States:                     file on 127.0.0.1
                            js-controller:  3.3.22
                            admin:          6.3.5
                            Adapter State
                            + instance is alive
                            Cannot get list: undefined
                            Error: Object "system.config" not found
                              @esmax666
                              Ich weiß nicht was passiert, wenn man soweit runterspringt. Offenbar nix gutes.
                                wie soll am besten iobroker wieder neu installieren ?
                                iob fix hat leider nichts gebracht
                                dann würde ich noch admin downgrade machen
                                10395
