    4. broker Admin nicht erreichbar + Failed to lock DB file
      kasten bier @Thomas Braun last edited by
      hier die summary:
      Copy text starting here:
                           v.2023-06-20
         Static hostname: iobroker-pi
               Icon name: computer
              Machine ID: 8c7521687f1c426fafe88f497be66f04
                 Boot ID: d3b295b8436d44e2beb25306385497a1
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               armhf
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    19
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:           1.9G        404M        920M         16M        597M        1.4G
      Swap:           99M          0B         99M
      Total:         2.0G        404M        1.0G
      Active iob-Instances:   2
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.2.23
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : iobroker-pi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                25289
      States:                 2599
      Size of iob-Database:
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      3.8M    /opt/iobroker/iobroker-data/objects.json.migrated
      3.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      768K    /opt/iobroker/iobroker-data/states.jsonl
      88K     /opt/iobroker/iobroker-data/states.json.migrated
      88K     /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
        Homoran Global Moderator Administrators @Glasfaser last edited by
        @glasfaser sagte in broker Admin nicht erreichbar + Failed to lock DB file:
        Das kommt aber nicht bei einer Restore :
        doch, wen das Backup von
        @kasten-bier sagte in broker Admin nicht erreichbar + Failed to lock DB file:
        node -v
        v12.22.6
        ist und die neue
        v18.17.1
        dann kommt
        Trying to rebuild it... 2 attempt
        was natürlich dauert
          Thomas Braun Most Active @kasten bier last edited by
          hier die summary:
          Das ist nicht die Langfassung.
            sind mehr als 10000 Zeichen , habs mal als txt hochgeladen.iob diag.txt
              Thomas Braun Most Active @kasten bier last edited by Thomas Braun
              @kasten-bier
              Wo hast du die nodejs@18.17.1 denn her?
              Nicht ordentlich aus einem Repo, das läuft nämlich auf 16 bei dir.
                oje, ich hab gestern vor verzweiflung einfach in dem Befehl:
                curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                sudo apt-get install -y nodejs
                aus der 16 eine 18 gemacht, glaube ich mich zu erinnern.
                  @kasten-bier
                  Versuch mal das node-fix-Skript aus meiner Signatur.
                    kasten bier @Thomas Braun last edited by kasten bier
                    das script ist durchgelaufen, leider keine Admin-Seite da.
                    Ist ein Downgrade auf 16.x möglich ?
                    Hat mich gestern angemeckert, daß mein 18er aktueller wäre.
                    Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                      Wozu?
                      iob update
                      iob upgrade all -y
                      • Glasfaser
                        Glasfaser @kasten bier last edited by
                        @Thomas-Braun
                        Nur zur Info bevor er damit weiter macht :
                        und so eine lange ... unendliche Liste habe ich noch nie gesehen in seinem Log
                        mit :
                        npm ERR! code ELSPROBLEMS
                          Thomas Braun Most Active @Glasfaser last edited by
                          Hab ich natürlich gesehen. Überwiegend extraneous. Die dürfte man mit
                          npm prune
                          rausbekommen. Aber dafür braucht es erstmal eine stabile Basis bei nodejs und Co.
                            kasten bier @Glasfaser last edited by
                            @glasfaser said in broker Admin nicht erreichbar + Failed to lock DB file:
                            und das .. macht man nicht !
                            Naja, es wurde ja eh nix mehr auf die sd-karte geschrieben, jedenfalls lief der admin nicht / nicht erreichbar und meine tasmota-Steckdosen haben geblinkt, weil kein mqqt-server mehr lief.
                              @kasten-bier
                              Macht man trotzdem nicht. Nie. Also im Sinne von GAR NICHT.
                                @kasten-bier
                                Wie sieht die Basis denn nun aus bei dir?
                                nodesjs 18.18.0 sauber drauf?
                                  diag sagt ja
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                          /usr/bin/node           v18.18.0
                                                          /usr/bin/npm            9.8.1
                                                          /usr/bin/npx            9.8.1
                                  , hat es vorhin aber auch.
                                  leider habe ich nicht aupgepasst für das "2x 'nothing to do'." nach dem fix
                                    @kasten-bier
                                    cd /opt/iobroker
                                    sudo -H - u iobroker npm prune
                                    sudo -H - u iobroker npm ls
                                      @kasten-bier
                                      iob update
                                        iob update
                                        Used repository: stable
                                        Adapter    "admin"        : 6.10.1   , installed 6.2.23 [Updatable]
                                        Adapter    "backitup"     : 2.8.1    , installed 2.1.17 [Updatable]
                                        Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
                                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                        Adapter    "echarts"      : 1.5.1    , installed 1.0.12 [Updatable]
                                        Adapter    "flot"         : 1.12.0   , installed 1.10.7 [Updatable]
                                        Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
                                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                        Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
                                        Adapter    "jarvis"       : 3.1.2    , installed 3.0.15 [Updatable]
                                        Adapter    "javascript"   : 7.1.4    , installed 6.1.4  [Updatable]
                                        Controller "js-controller": 5.0.12   , installed 4.0.23 [Updatable]
                                        Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
                                        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                        Adapter    "parser"       : 1.3.2    , installed 1.1.8  [Updatable]
                                        Adapter    "shelly"       : 6.4.1    , installed 4.0.7  [Updatable]
                                        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                        Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
                                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
                                        Adapter    "statistics"   : 2.3.0    , installed 2.2.0  [Updatable]
                                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
                                        Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
                                        Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
                                          @kasten-bier
                                          cd /opt/iobroker && npm ls
                                            iobroker.inst@3.0.0 /opt/iobroker
                                            ├── iobroker.admin@6.2.23
                                            ├── iobroker.backitup@2.1.17
                                            ├── iobroker.ble@0.13.0
                                            ├── iobroker.discovery@3.1.0
                                            ├── iobroker.echarts@1.0.12
                                            ├── iobroker.flot@1.10.7
                                            ├── iobroker.fritzdect@2.2.6
                                            ├── iobroker.habpanel@0.5.0
                                            ├── iobroker.history@2.2.4
                                            ├── iobroker.jarvis@3.0.15
                                            ├── iobroker.javascript@6.1.4
                                            ├── iobroker.js-controller@4.0.23
                                            ├── iobroker.mqtt@4.0.7
                                            ├── iobroker.netatmo-crawler@0.8.1
                                            ├── iobroker.parser@1.1.8
                                            ├── iobroker.shelly@4.0.7
                                            ├── iobroker.smartmeter@3.3.4
                                            ├── iobroker.sonoff@2.5.1
                                            ├── iobroker.sourceanalytix@0.4.15-alpha.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#af88beb902468eb03749e5b120f3e350e60256e1)
                                            ├── iobroker.statistics@2.2.0
                                            ├── iobroker.vis-bars@0.1.4
                                            ├── iobroker.vis-history@1.0.0
                                            ├── iobroker.vis-hqwidgets@1.3.0
                                            ├── iobroker.vis-rgraph@0.0.2
                                            ├── iobroker.vis@1.4.16
                                            └── iobroker.web@4.3.0
                                            742
