    4. Zigbee Tuya TS0601 Temperature & Humidity läuft nicht
      arteck Developer Most Active @rocky753 last edited by
      @rocky753 nö komplett was anderes.. schau dir mal deine Modell bezeichnung an und seine.. das sidn 2 total verschiedene Geräte..ja auch wenn diese GENAU so aussehen...
      willkommen in der Tuya Welt.
      installiermal die GIT version.
        rocky753 @arteck last edited by rocky753
        @arteck ok, das hatte ich nicht gesehen, sorry
        GIT Version habe ich installiert, gleiches Bild.
        Beim Starten vom Zigbee Adapter steht noch
          @rocky753 log in code tag packen
          und zeig mehr vom Start aus des adapter .. nicht nur so ein schnupsel
            @arteck
            ok, hier das gesamte Log Start zigbee--> Pairing --> Restart zigbee
            2023-08-22 22:06:51.035	info	debug devices set to []
            2023-08-22 22:06:51.006	info	Zigbee started
            2023-08-22 22:06:51.005	info	0xa4c138d0b860a01f (addr 27476): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
            2023-08-22 22:06:50.989	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
            2023-08-22 22:06:50.971	info	Currently 1 devices are joined:
            2023-08-22 22:06:50.923	info	--> transmitPower : normal
            2023-08-22 22:06:50.899	info	Unable to disable LED, unsupported function.
            2023-08-22 22:06:50.883	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
            2023-08-22 22:06:50.214	info	Installed Version: ioBroker/ioBroker.zigbee
            2023-08-22 22:06:49.265	info	Starting Zigbee npm ...
            2023-08-22 22:06:49.262	info	delete old Backup files. keep only last 10
            2023-08-22 22:06:49.118	info	starting. Version 1.8.23 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
            2023-08-22 22:06:41.268	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-08-22 22:06:41.266	info	terminating
            2023-08-22 22:06:40.778	info	Zigbee: disabling joining new devices.
            2023-08-22 22:06:40.764	info	cleaned everything up...
            2023-08-22 22:06:40.761	info	Got terminate signal TERMINATE_YOURSELF
            2023-08-22 22:05:31.570	info	Zigbee: stop joining
            2023-08-22 22:04:54.342	info	Device '0xa4c138d0b860a01f' is supported, identified as: TuYa Temperature & humidity sensor (TS0601_temperature_humidity_sensor_1)
            2023-08-22 22:04:54.342	info	Successfully interviewed '0xa4c138d0b860a01f', device has successfully been paired
            2023-08-22 22:04:49.186	error	Device 0xa4c138d0b860a01f "TS0601" not described in statesMapping.
            2023-08-22 22:04:48.135	warn	Device '0xa4c138d0b860a01f' announced itself
            2023-08-22 22:04:48.065	info	Starting interview of '0xa4c138d0b860a01f'
            2023-08-22 22:04:30.299	info	Zigbee: allowing new devices to join.
            2023-08-22 22:04:28.657	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
            2023-08-22 22:04:14.041	info	debug devices set to []
            2023-08-22 22:04:13.954	info	Zigbee started
            2023-08-22 22:04:13.952	info	Currently no devices.
            2023-08-22 22:04:13.944	info	--> transmitPower : normal
            2023-08-22 22:04:13.924	info	Unable to disable LED, unsupported function.
            2023-08-22 22:04:13.916	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
              passt das Log oder fehlt noch was?
                @rocky753 sagte in Zigbee Tuya TS0601 Temperature & Humidity läuft nicht:
                pack den mal unter ausschliesen rein
                  @arteck
                  ist jetzt unter ausschliessen drin. danach adapter Neustart.
                  Log:
                  2023-09-25 18:48:28.883	info	debug devices set to []
                  2023-09-25 18:48:28.833	info	Zigbee started
                  2023-09-25 18:48:28.832	info	0x3425b4fffe307d63 (addr 31147): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                  2023-09-25 18:48:28.830	info	0x3425b4fffe170775 (addr 49041): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                  2023-09-25 18:48:28.828	info	0x00158d000911dbbb (addr 20444): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                  2023-09-25 18:48:28.826	info	0xa4c138a66e67005b (addr 36428): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
                  2023-09-25 18:48:28.824	info	0xa4c1380d4d269b2b (addr 16273): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
                  2023-09-25 18:48:28.822	info	0x00158d0008f3290c (addr 39180): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                  2023-09-25 18:48:28.817	info	0xa4c138d0b860a01f (addr 29071): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
                  2023-09-25 18:48:28.773	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
                  2023-09-25 18:48:28.757	info	Currently 7 devices are joined:
                  2023-09-25 18:48:28.742	info	--> transmitPower : normal
                  2023-09-25 18:48:28.722	info	Unable to disable LED, unsupported function.
                  2023-09-25 18:48:28.713	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                  2023-09-25 18:48:28.289	info	Installed Version: ioBroker/ioBroker.zigbee
                  2023-09-25 18:48:27.339	info	Starting Zigbee npm ...
                  2023-09-25 18:48:27.336	info	delete old Backup files. keep only last 10
                  2023-09-25 18:48:27.188	info	starting. Version 1.8.23 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                    @rocky753 na dann läuft der ja..
                      @arteck
                      hmm, ich glaub ich steht aufm Schlauch. Ich sehe keinen Unterschied zu vorher. Im Objektbaum sind weiterhin keine Temp. u. Feuchtigkeit. Oder muss ich noch was machen damit die jetzt auftauchen?
                        @rocky753 ich seh geadre wir haben ein Problem mit dem model...da scheint was zu fehlen..
                          arteck Developer Most Active @arteck last edited by
                          @arteck installier mal jetzt den Adapter von git und schau nochmal.. musst aber nochmal neu anlernen
                            @arteck habe ich gemacht. keine Änderung... Objektbaum wie vorher.
                            Log:
                            2023-09-29 13:30:28.917	info	debug devices set to []
                            2023-09-29 13:30:28.873	info	Zigbee started
                            2023-09-29 13:30:28.872	info	0x3425b4fffe307d63 (addr 31147): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                            2023-09-29 13:30:28.870	info	0x3425b4fffe170775 (addr 49041): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                            2023-09-29 13:30:28.868	info	0x00158d000911dbbb (addr 20444): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            2023-09-29 13:30:28.866	info	0xa4c138a66e67005b (addr 36428): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
                            2023-09-29 13:30:28.865	info	0xa4c1380d4d269b2b (addr 16273): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
                            2023-09-29 13:30:28.862	info	0x00158d0008f3290c (addr 39180): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                            2023-09-29 13:30:28.856	info	0xa4c138d0b860a01f (addr 9251): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
                            2023-09-29 13:30:28.788	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
                            2023-09-29 13:30:28.774	info	Currently 7 devices are joined:
                            2023-09-29 13:30:28.759	info	--> transmitPower : normal
                            2023-09-29 13:30:28.739	info	Unable to disable LED, unsupported function.
                            2023-09-29 13:30:28.730	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                            2023-09-29 13:30:28.357	info	Installed Version: ioBroker/ioBroker.zigbee
                            2023-09-29 13:30:27.474	info	Starting Zigbee npm ...
                            2023-09-29 13:30:27.471	info	delete old Backup files. keep only last 10
                            2023-09-29 13:30:27.332	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                            2023-09-29 13:30:19.758	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2023-09-29 13:30:19.757	info	terminating
                            beim Joining steht noch das drin:
                            2023-09-29 13:25:27.501	warn	Object of state "zigbee.0.exclude.TS0601_temperature_humidity_sensor_1" is missing the required property "common.type"
                            2023-09-29 13:25:09.632	info	Zigbee: stop joining
                            2023-09-29 13:24:28.909	info	Device '0xa4c138d0b860a01f' is supported, identified as: TuYa Temperature & humidity sensor (TS0601_temperature_humidity_sensor_1)
                            2023-09-29 13:24:28.908	info	Successfully interviewed '0xa4c138d0b860a01f', device has successfully been paired
                            2023-09-29 13:24:25.395	info	Device '0xa4c138d0b860a01f' announced itself
                            2023-09-29 13:24:17.585	info	Starting interview of '0xa4c138d0b860a01f'
                              @rocky753und jetzt pack den mal unter Ausschliessen Tab rein
                                @arteck da war er schon drin. hab ihn nochmal neu angelernt und unter ausschliessen rein, aber keine Veränderung...
                                2023-09-30 15:28:52.140	info	Zigbee started
                                2023-09-30 15:28:52.139	info	0x3425b4fffe307d63 (addr 31147): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                2023-09-30 15:28:52.137	info	0x3425b4fffe170775 (addr 49041): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                2023-09-30 15:28:52.135	info	0x00158d000911dbbb (addr 20444): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                2023-09-30 15:28:52.133	info	0xa4c138a66e67005b (addr 36428): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
                                2023-09-30 15:28:52.131	info	0xa4c1380d4d269b2b (addr 16273): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
                                2023-09-30 15:28:52.129	info	0x00158d0008f3290c (addr 39180): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                                2023-09-30 15:28:52.124	info	0xa4c138d0b860a01f (addr 10643): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
                                2023-09-30 15:28:52.073	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
                                2023-09-30 15:28:52.055	info	Currently 7 devices are joined:
                                2023-09-30 15:28:52.039	info	--> transmitPower : normal
                                2023-09-30 15:28:52.019	info	Unable to disable LED, unsupported function.
                                2023-09-30 15:28:52.011	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                                2023-09-30 15:28:51.629	info	Installed Version: ioBroker/ioBroker.zigbee
                                2023-09-30 15:28:50.726	info	Starting Zigbee npm ...
                                2023-09-30 15:28:50.723	info	delete old Backup files. keep only last 10
                                2023-09-30 15:28:50.572	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                                2023-09-30 15:28:42.984	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-09-30 15:28:42.982	info	terminating
                                2023-09-30 15:28:42.581	info	Zigbee: disabling joining new devices.
                                2023-09-30 15:28:42.480	info	cleaned everything up...
                                2023-09-30 15:28:42.476	info	Got terminate signal TERMINATE_YOURSELF
                                2023-09-30 15:28:36.100	info	Zigbee: stop joining
                                2023-09-30 15:28:32.589	warn	Object of state "zigbee.0.exclude.TS0601_temperature_humidity_sensor_1" is missing the required property "common.type"
                                2023-09-30 15:27:48.053	warn	TypeError: Cannot read properties of undefined (reading 'replace') at Commands.deleteDevice (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:449:30) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:71:30) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:14:48) at Zigbee.emit (node:events:525:35) at Zigbee.emit (node:domain:489:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5831:34) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
                                2023-09-30 15:27:47.747	warn	States system pmessage io.messagebox.system.adapter.zigbee.0 {"command":"deleteDevice","message":{"force":false},"from":"system.adapter.admin.0","callback":{"message":{"force":false},"id":281,"ack":false,"time":1696080467744},"_id":33765716} Cannot read properties of undefined (reading 'replace')
                                2023-09-30 15:27:45.353	info	Device '0xa4c138d0b860a01f' is supported, identified as: TuYa Temperature & humidity sensor (TS0601_temperature_humidity_sensor_1)
                                2023-09-30 15:27:45.353	info	Successfully interviewed '0xa4c138d0b860a01f', device has successfully been paired
                                2023-09-30 15:27:44.122	info	Device '0xa4c138d0b860a01f' announced itself
                                2023-09-30 15:27:44.066	info	Starting interview of '0xa4c138d0b860a01f'
                                2023-09-30 15:27:34.565	info	Zigbee: allowing new devices to join.
                                2023-09-30 15:24:52.284	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                                2023-09-30 15:21:02.927	info	debug devices set to []
                                2023-09-30 15:21:02.883	info	Zigbee started
                                  Huligan @rocky753 last edited by Huligan
                                  @rocky753 Hi Rocky, suche mal bitte bei dir nach "_TZE200_zl1kmjqx" in deiner
                                  /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js
                                  Die wird bei dem Model 'TS0601_temperature_humidity_sensor_1' zu finden sein.
                                  Mir hats geholfen die Model ID sprich die Zeile mit "TZE200_zl1kmjqx" zu löschen und dann die ID
                                  bei dem 'TS0601_temperature_humidity_sensor
                                  _2' einzufügen:
                                  Bin ein begnadeter Zeichner 😉 f190ade5-b91c-46d1-a502-1f77a4703f71-grafik.png
                                  Beachte auch die Datapoints, hier ggf. den Humidity .raw Wert durch divideBy10 ersetzen. Sieht man auch im Screenshot.
                                  Ich hatte eine andere Modelversion wird aber sicher allgemein klappen.
                                  Dann Speichern, Adapter neustarten und bei dem bereits regestriertem Sensor reconfigure durchführen:
                                  Außer den Batterystatus kam alles nach einigen Sekunden durch. Bin aber guter Dinge das dieser wie öfters zu lesen auch noch nachgeliefert wird.
                                  Ich hab meinen Adapter über den Broker direkt installiert also ohne GIT oder Ähnlichem. Vielleicht hilf es ja den einen oder anderen.
                                  Seht mir nach das ich mich auch nicht tiefer mit dem eigentlichen Problem rumgeärgert hab und nur einen schnellen Workaround gesucht habe.
                                    arteck Developer Most Active @Huligan last edited by arteck
                                    @huligan sagte in Zigbee Tuya TS0601 Temperature & Humidity läuft nicht:
                                    TZE200_zl1kmjqx
                                    das würde bedeuten dass der
                                    TZE200_zl1kmjqx nicht TS0601_temperature_humidity_sensor_1 sondern TS0601_temperature_humidity_sensor_2 ist
                                    hmm
                                    ichhab mal ein issue angelegt https://github.com/Koenkk/zigbee2mqtt/issues/19092 aber ohne den Sensor ist es schwer
                                      Huligan @arteck last edited by Huligan
                                      @arteck Kann ich leider nicht beurteilen. War eher ein ein One-Hit bei einer Trial Error Analyse.
                                      Die Anpassung beim valueConverter spricht eher dagegen ebenso der noch fehlender Batterie Wert.
                                      Allerdings vom Bild was der Adapter dann läd passt es aber auch wieder.7c3266f0-3ceb-478f-887f-b82a1d40e7d3-grafik.png
                                      Zumindest Rund und nicht eckig 😉
                                      Meine Model-ID war die "_TZE200_bjawzodf"
                                      Bin kein Entwickler und mir wars eher wichtig die beiden Werte irgendwie zu bekommen als gar nichts.
                                        rocky753 @Huligan last edited by
                                        @huligan hat direkt geklappt, DANKE!!!
                                        Wenn es als "TS0601_temperature_humidity_sensor_2" erkannt wird, passt es. Nur humidity divideby10 noch rein, dann passen auch die Werte. Nur Batterie wird bei auch nicht angezeigt.
                                          vielleicht hängt ihr ech an das issue dran was ich gepostet habe .. und klärt das.. nicht dass Tuya da wieder murks baut.. und ballert 2 Geräte mit der gleicher id raus..
                                            Smo @arteck last edited by
                                            Ich hab mich an das Issue rangehängt, weil Huligans Lösung funktionierte, jetzt kam ein Zigbee Update, und die Änderungen sind wieder rückgängig gemacht 😕 Gibts sowas wie eine user.conf, die nicht überschrieben wird?
                                            2898
