    4. Cannot find module '@iobroker/types'
    • 0
      00000x @Thomas Braun last edited by
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 10 (buster)
      Kernel:                 5.10.103-v7l+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    8
      Nodejs-Installation:    /usr/bin/nodejs         v14.21.3
                              /home/pi/.nvm/versions/node/v14.17.3/bin/node           v14.17.3
                              /home/pi/.nvm/versions/node/v14.17.3/bin/npm            6.14.13
                              /home/pi/.nvm/versions/node/v14.17.3/bin/npx            6.14.13
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      *** nodejs is NOT correctly installed ***
      MEMORY:
      Mem:           3.8G        1.2G        1.1G         26M        1.5G        2.6G
      Swap:           99M          0B         99M
      Total:         3.9G        1.2G        1.2G
      Active iob-Instances:   16
      Active repo(s): beta
      ioBroker Core:          js-controller           5.0.11
                              admin                   6.6.5
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Objects:                10802
      States:                 6279
      Size of iob-Database:
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      6.1M    /opt/iobroker/iobroker-data/objects.json.migrated
      6.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      12K     /opt/iobroker/iobroker-data/objects.json.old
      2.4M    /opt/iobroker/iobroker-data/states.jsonl
      2.0M    /opt/iobroker/iobroker-data/states.json.old
      636K    /opt/iobroker/iobroker-data/states.json.migrated
      636K    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      Also muss ich nodeJS neu installieren?
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @00000x last edited by
        @00000x sagte in Cannot find module '@iobroker/types':
        steinalt und dazu noch Betauser ???
        warum ?
          Thomas Braun Most Active @00000x last edited by
          buster
          Tot, Nachfolger installieren, wenn möglich in der 64Bit-Version.
          Und nodejs wird immer per systemeigenen Paketmanager installiert, nie per n, nvm oder wie die Dinger auch alle heißen mögen.
          Ob Active repo(s): beta das richtige Repo für dich ist wage ich auch zu bezweifeln.
          0 1 Reply Last reply Reply Quote 2
          • 0
            Bin nun auf 18 und 9.
            Nodejs-Installation:    /usr/bin/nodejs         v18.17.0
                                    /usr/local/bin/npm              9.6.7
                                    /usr/local/bin/npx              9.6.7
            Immer noch gleich der Fehler:
            2023-08-08 18:58:45.363  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1380
            2023-08-08 18:58:48.988  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
            2023-08-08 18:58:48.989  - error: host.raspberrypi Caught by controller[0]:   throw err;
            2023-08-08 18:58:48.990  - error: host.raspberrypi Caught by controller[0]:   ^
            2023-08-08 18:58:48.990  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '@iobroker/types'
            2023-08-08 18:58:48.991  - error: host.raspberrypi Caught by controller[0]: Require stack:
            2023-08-08 18:58:48.991  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
            2023-08-08 18:58:48.991  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
            2023-08-08 18:58:48.992  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
            2023-08-08 18:58:48.992  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
            2023-08-08 18:58:48.992  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
            2023-08-08 18:58:48.993  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
            2023-08-08 18:58:48.993  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
            2023-08-08 18:58:48.993  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
            2023-08-08 18:58:48.994  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
            2023-08-08 18:58:48.994  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
            2023-08-08 18:58:48.994  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
            2023-08-08 18:58:48.994  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19) {
            2023-08-08 18:58:48.995  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
            2023-08-08 18:58:48.995  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
            2023-08-08 18:58:48.995  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
            2023-08-08 18:58:48.995  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
            2023-08-08 18:58:48.996  - error: host.raspberrypi Caught by controller[0]:   ]
            2023-08-08 18:58:48.996  - error: host.raspberrypi Caught by controller[0]: }
            2023-08-08 18:58:48.996  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.0
            2023-08-08 18:58:48.997  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
              Nein.
              Lies bitte die Aufräum-Anleitung aus meiner Signatur.
              • mcm1957
                mcm1957 @00000x last edited by
                @00000x
                Hast du den Adapter NACH dem npm Upgrade neu installiert ?
                  Thomas Braun Most Active @mcm1957 last edited by
                  @mcm57
                  Du meinst NACH dem Aufräumen und Geraderücken?
                  • mcm1957
                    mcm1957 @Thomas Braun last edited by
                    Ja
                    Nachdem node u npm sauber installiert sind.
                    Ohne einexsaubere Basis macht eine Analyse null Sinn.
                      tigiba @mcm1957 last edited by tigiba
                      hab das selbe problem bei meiner ziemlich alten iobroker installation nach einem upgrade von web, admin & socket adapter die ich wohl lieber auslassen hätte sollen...
                      hab nun wie mcm57 auch auf node 18 upgegradet, aber das hat genau wie bei diesem bei mir auch nicht's gebracht.
                      Gibt's tipps wie man das wieder hinbekommen könnte?
                      UPDATE: hab gerade entdeckt dass ich auf dem system noch eine veraltete npm version unter /usr/local/ hatte. hab die deaktiviert damit die neue via apt vom nodereleases repository installierte greift, und probier jetzt nochmal die fix procedure durch..
                        Thomas Braun Most Active @tigiba last edited by
                        @tigiba sagte in Cannot find module '@iobroker/types':
                        hab die deaktiviert
                        Was meinst du damit? Die muss gelöscht werden.
                        Bist du sicher, dass deine Umgebung jetzt sauber ist?
                        Kannst du ja mal per
                        iob diag
                        oder
                        per node-fix-Skript (siehe meine Signatur) prüfen.
                        mcm1957 T 2 Replies Last reply Reply Quote 0
                        • mcm1957
                          Damit es ggF klar ist
                          Node muss VOR der Installation nezerer Adapterreleases auf 16++ (empfohlen 18) sein.
                          Ein spätere node upgrade installiert NIcht wss fie Adapterknszalltion wg altem npm susgelassen hat.
                            @mcm57 sagte in Cannot find module '@iobroker/types':
                            Nein, dazu muss der Adapter nochmal 'drübergebügelt' werden.
                              tigiba @Thomas Braun last edited by tigiba
                              @thomas-braun said in Cannot find module '@iobroker/types':
                              hab mv /usr/local/bin/npm /usr/local/bin/npm_old gemacht, das hat gereicht um den iobroker wieder zum funktionieren zu bekommen. Natürlich wäre Löschen und richtig aufräumen die sauberere Lösung, aber jeder optimiert seine Zeit wie er kann 😉 Und durch aufheben des backups kann ich falls irgendwas andres auf dem system dann doch wieder das alte npm braucht leicht drauf zurückgreifen.
                              Danach in /opt/iobroker ein sudo -u iobroker npm install --production ausgeführt und dann hat das sudo -u iobroker ./iob start admin und sudo -u iobroker ./iob start web wieder geklappt.
                              Das iob diag ist nach 20 Minuten noch immer hier gehangen, dann hab ich's abgebrochen:
                              /var:
                              LG tigiba!
                                Thomas Braun Most Active @tigiba last edited by Thomas Braun
                                Und genau das solltest du tun.
                                Das deutet auf ein krummes System hin. Das läuft nämlich im Allgemeinen nicht so lange.
                                Da hast du dann deine Zeit falsch 'optimiert'.
                                3680
