      TT-Tom @Tom_W last edited by
      @tom_w
      bei mir läuft das Script ohne Meldung und ich habe auch keine ScreensaverEntityDateFormat.
      Welche Javascript adapter Version hast du? zeige bitte mal die Config vom Entity 2
        Tom_W @TT-Tom last edited by Tom_W
        @tt-tom
        Javascript Adapter 7.1.4
        export const config: Config = {
            panelRecvTopic: 'mqtt.0.tele.NSPanel_Wohnzimmer.RESULT',       // Bitte anpassen
            panelSendTopic: 'mqtt.0.cmnd.NSPanel_Wohnzimmer.CustomSend',   // Bitte anpassen
            leftScreensaverEntity:
        		// Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
            bottomScreensaverEntity :
                    // bottomScreensaverEntity 1
                        ScreensaverEntity: 'accuweather.0.Daily.Day1.Sunrise',
                        ScreensaverEntityFactor: 1,
                        ScreensaverEntityDecimalPlaces: 0,
                        ScreensaverEntityDateFormat: 'hh:mm',   // like DD.MM or DD.MM.YY or YYYY/MM/DD or hh:mm
                        ScreensaverEntityIconOn: 'weather-sunset-up',
                        ScreensaverEntityIconOff: null,
                        ScreensaverEntityText: 'Sonne',
                        ScreensaverEntityUnitText: '%',
                        ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100}
                    // bottomScreensaverEntity 2
                        ScreensaverEntity: 'accuweather.0.Current.WindSpeed',
                        ScreensaverEntityFactor: (1000/3600),
                        ScreensaverEntityDecimalPlaces: 1,
                        ScreensaverEntityIconOn: 'weather-windy',
                        ScreensaverEntityText: "Wind",
                        ScreensaverEntityUnitText: 'm/s',
                        ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 120 }
                    // bottomScreensaverEntity 3
                        ScreensaverEntity: 'accuweather.0.Current.WindGust',
                        ScreensaverEntityIconOn: 'weather-tornado',
                        ScreensaverEntityText: 'Böen',
                    // bottomScreensaverEntity 4
                        ScreensaverEntity: 'accuweather.0.Current.WindDirection',
                        ScreensaverEntityIconOn: 'windsock',
                        ScreensaverEntityText: 'Windr.',
                        ScreensaverEntityUnitText: '°',
                        ScreensaverEntityIconColor: White
                    // bottomScreensaverEntity 5 (for Alternative and Advanced Screensaver)
                        ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity',
                        ScreensaverEntityIconOn: 'water-percent',
                        ScreensaverEntityText: 'Feuchte',
                        ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65}
            indicatorScreensaverEntity:
            mrIcon1ScreensaverEntity:
                    ScreensaverEntity: NSPanel_Path + 'Relay.1',
                    ScreensaverEntityIconOn: null,
                    ScreensaverEntityValue: null,
                    ScreensaverEntityValueDecimalPlace : 0,
                    ScreensaverEntityValueUnit: null,
                    ScreensaverEntityOnColor: On,
                    ScreensaverEntityOffColor: HMIOff
            mrIcon2ScreensaverEntity:
                    ScreensaverEntity: NSPanel_Path + 'Relay.2',
                    ScreensaverEntityIconOn: 'heat-wave',
                    ScreensaverEntityValue: 'alias.0.Wohnzimmer.Temperatur Wohnzimmer',
                    ScreensaverEntityValueDecimalPlace : 1,
                    ScreensaverEntityValueUnit: '°',
                    ScreensaverEntityOnColor: MSRed,
                    ScreensaverEntityOffColor: Yellow
          @tom_w
          so sieht das Original aus.
          export const config = <Config> {
          Wenn du ein Update vom Script gemacht hast, dann hast du da beim kopieren nicht komplett alles ersetzt. Ich würde dir vorschlagen, das zu lesen und nochmal von vorne zu beginnen.
            @tt-tom
            Wow, ich hab tatsächlich beim ersetzen genau eine Zeile darunter angefangen zu überschreiben. Das ist das Problem wenn man nur alle paar Monate das Skript updatet.
            Vielen Dank!
              australien @TT-Tom last edited by
              @tt-tom
              man kann doch auch den Icons das Logo des Senders hinterlegen.
              Gibt es dazu auch einen Anleitung, mit meiner Suche finde ich nichts dazu, glaub aber schon was davon gelesen zu haben.
                Kuckuckmann @australien last edited by
                @australien
                Hey,
                als Icons kannst Du nur das hinterlegen, was in der Liste hier aufgeführt ist.
                Wenn Dir da ein Icon fehlt, dann kannst Du dafür in GitHub ein Ticket eröffnen und es wird geprüft, ob man es hinzufügen kann. Bei Logos ist das aus rechtlichen Gründen nicht immer ganz so einfach. Stichwort Trademark / Copyright, etc.
                LG
                  australien @Kuckuckmann last edited by
                  @kuckuckmann
                  alles klar, schade aber.
                  Ich dachte das schon gesehen zu haben.
                    TT-Tom @australien last edited by TT-Tom
                    @australien es gibt in den Icons eins, was aussieht wie ein Radio. Eventuell hast du das gesehen.
                      michael_4358 last edited by michael_4358
                      @MichaelF meinst du das tasmota update auf v.13❓
                      MichaelF 1 Reply Last reply Reply Quote 0
                        19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
                        19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
                        19:48:00.005	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2869:9)
                        19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
                        19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
                        19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
                        19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
                        19:48:00.012	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
                        19:48:00.012	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
                        19:48:00.012	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
                        19:48:00.012	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
                        19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
                        19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
                        19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
                        19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
                        19:48:00.013	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
                        19:48:00.013	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
                        19:48:00.013	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
                        19:48:00.013	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
                        19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
                        ich erhalte nach dem update immer folgende Meldungen/warunungen,.,,
                          TT-Tom last edited by TT-Tom
                          @michael_4358
                          Welche updates hast du gemacht, Versionen bitte angeben.
                          zusätzlich bitte die Config von
                          zeigen.
                            michael_4358 @TT-Tom last edited by
                            @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                            TypeScript v4.3.1.3 zur Steuerung des SONOFF NSPanel mit dem ioBroker
                                        ScreensaverEntityIconOn: 'lightbulb',
                                        ScreensaverEntity: 'deconz.0.Sensors.5.open',
                                        ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                              TT-Tom @michael_4358 last edited by TT-Tom
                              @michael_4358
                              hier steckt der Fehler, die Datenpunkte gibt's bei dir nicht. Es ist auch nur ein Beispiel.
                                @michael_4358
                                kann ich die einfach auskommentieren?
                                  @michael_4358
                                  habe die beiden mal auskommender nun sind noch
                                  20:11:51.959	warn	javascript.0 (540063) at script.js.NSPanel.pdf:3349:46
                                  20:11:51.959	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
                                  20:11:51.959	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
                                  20:11:51.959	warn	javascript.0 (540063) at fulfilled (script.js.NSPanel.pdf:5:58)
                                  • MichaelF
                                    MichaelF @michael_4358 last edited by
                                    @michael_4358
                                    Hi, nein die TFT Firmware
                                      @michael_4358
                                      Wie aus kommentiert? Bitte zeigen komplett.
                                        @tt-tom
                                        Bin gerade nicht am pc..
                                        Habe vor der Zeile mit den datenpunkten „//„ angefügt, mehr nicht
                                          @michael_4358
                                          Ja so passt das nicht.
                                          ersetze mal bitte hier mit. Das funktioniert ohne Fehlermeldung und zeigt dir den Zustand der Relais.
                                            manylopmy last edited by
                                            Gute Abend zusammen 😊
                                            Ich würde mich gerne daran geben, meine Sonos Boxen über das NSPanel
                                            1. Ein und Auszuschalten
                                            2. Lautstärke zu regulieren.
                                            Da gibt es bestimmt schon einige Realisierungen.
                                            Ich wäre froh wenn mir jemand eine kurze Beschreibung der Vorgehensweise (und welche Voraussetzungen ich erfüllt haben muss) mitteilen würde.
                                            Stand derzeitig ist:
                                            Der Sonos Adapter ist unter Objekte mit seinen Datenpunkten vorhanden. Ich habe bisher keinen zu SONOS gehörenden Alias eingerichtet.
                                            Vielen Dank
                                            Manfred
                                            lovelace ui nspanel sonoff
                                            271
                                            7731
                                            6658724
