    4. Backitup Restore fehler
      Esmax666 @Glasfaser last edited by
      @glasfaser ach so ok lol
      und dann muss ich mir die admin rechte geben ?
      esmax@ubuntu:/opt/iobroker$ npm install iobroker.js-controller@3.3.22
      iobroker upgrade backitup@2.2.2
      iobroker upgrade admin@5.2.1
      npm ERR! code EACCES
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/alcalzone-shared
      npm ERR! dest /opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, rename '/opt/iobroker/node_modules/alcalzone-shared' -> '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'
      npm ERR!  [Error: EACCES: permission denied, rename '/opt/iobroker/node_modules/alcalzone-shared' -> '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'rename',
      npm ERR!   path: '/opt/iobroker/node_modules/alcalzone-shared',
      npm ERR!   dest: '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T17_16_56_756Z-debug-0.log
      Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
      Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
      Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
      Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
      Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
       Cannot read system.config: null (OK when migrating or restoring)
      Homoran Glasfaser 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Esmax666 last edited by Homoran
        @esmax666 sagte in Backitup Restore fehler:
        ich weiss nicht worauf du hinaus willst, aber einfach sudo mit npm.... ist ein noGo
        • Glasfaser
          Glasfaser @Esmax666 last edited by
          @esmax666
          sudo -u iobroker rm opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF
          dann nochmal versuchen
            @glasfaser said in Backitup Restore fehler:
            da war nichts,
            esmax@ubuntu:/opt/iobroker$ sudo -u iobroker rm node_modules/.alcalzone-shared-F        gX40TmF
            rm: cannot remove 'node_modules/.alcalzone-shared-FgX40TmF': No such file or dir        ectory
            ich dache ich muss nur die admin rechte geben für "esmax" user
            • Glasfaser
              @esmax666
              Hast du jetzt den JS Controller installiert , wie weit bist du !?
              dann so für JS ... das ist der User iobroker ...
              sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
              • Glasfaser
                Glasfaser @Esmax666 last edited by Glasfaser
                tipps du die Befehle immer ab bzw. veränderst du sie !?
                da fehlt immer etwas bei dir !!!
                @glasfaser sagte in Backitup Restore fehler:
                E Homoran 2 Replies Last reply Reply Quote 0
                  Esmax666 @Glasfaser last edited by Esmax666
                  @glasfaser
                  nicht immer
                  ich war schon in "opt/iobroker/" deshalb hatte ich das nicht eingefügt
                  also dann habe ich das bekommen:
                  esmax@ubuntu:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
                  [sudo] password for esmax:
                  added 11 packages, removed 28 packages, and changed 25 packages in 29s
                  48 packages are looking for funding
                    run `npm fund` for details
                  Glasfaser simatec 2 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @Glasfaser last edited by
                    nee das putty Fenster ist zu schmal. 1m weiter rechts geht's weiter.
                    das fehlende /opt/iobroker dürfte i.O. sein
                    • Glasfaser
                      aber dadurch den / vergessen und am ende stimmte es auch nicht .
                      Bitte die Befehle nicht verändern !!
                      • simatec
                        simatec Developer Most Active @Esmax666 last edited by
                        @glasfaser
                        nicht immer
                        Nun weiter wie beschrieben
                          Esmax666 @simatec last edited by
                          @simatec
                          So alle command sind jetzt durchgefürt 😄 und iobroker startet noch 🤙
                          Wie lange muss man warten bis "alle Adapter installiert" sind?
                          Momentan sind die noch grau markiert
                          die Command
                          esmax@ubuntu:/opt/iobroker$ iobroker upgrade backitup@2.2.2
                          Update repository "stable" under "http://download.iobroker.net/sources-dist.json"
                          hash changed or no sources cached => force download of new sources
                          This downgrade of "backitup" will at least remove the following changes:
                          -> 2.8.1
                          Fix roles
                          help-links added
                          -> 2.8.0
                          small Sentry fixes
                          Bugfix System-Message
                          Docu & Wiki updated
                          Translation updated
                          dependencies updated
                          Fix Webdav
                          WOL Address & Port added
                          Restore for Backitup Config added
                          -> 2.7.0
                          Fix error Messages
                          edit automatic name addition added
                          Docu & Wiki updated
                          small bug fixes
                          Translation updated
                          Add support for sending notifications via discord (requires ioBroker.discord >= 2.1)
                          -> 2.6.23
                          Fix Influx Restore for MultiDB
                          Token renew for Onedrive added
                          Fix PSQL Restore
                          -> 2.6.22
                          Default Ports for InfluxDB added
                          -> 2.6.21
                          small Sentry fixes
                          Fix Influx Restore
                          Fix Onedrive Download
                          -> 2.6.20
                          FTP self signed Certificates added
                          Would you like to downgrade backitup from @2.8.1 to @2.2.2 now? [(y)es, (n)o]: y
                          Update backitup from @2.8.1 to @2.2.2
                          NPM version: 9.6.7
                          npm install iobroker.backitup@2.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
                          upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                          Adapter "backitup" updated
                          esmax@ubuntu:/opt/iobroker$ iobroker upgrade admin@5.2.1
                          This downgrade of "admin" will at least remove the following changes:
                          -> 6.10.1
                          fixed `between` function for showing news
                          if date string is not parseable show the original string instead of `Invalid Date`
                          updated socket classes to not crash on invalid patterns
                          -> 6.10.0
                          various minor improvements
                          fixed problem with discovery dialog
                          object browser now validates setting state of type number
                          allow to specify unique columns for tables
                          fix crash on invalid states, which are missing the property `common.role`
                          -> 6.9.2
                          show info, if server time differs from client time
                          remove confusion with different names for state (datapoint and state)
                          fixed link on 404-page being opened inside child view
                          fixed issue if non-text default values are provided to a text jsonConfig component
                          implemented del key shortcut to delete a selected object
                          -> 6.9.1
                          allow resizing of all columns in objects tab
                          without expert mode users are only allowed to edit objects in `0_userdata.0` and `alias.0` namespace
                          fixed keyboard navigation
                          fixed problem with showing controller upgrade instructions if no UI upgrade is supported
                          -> 6.9.0
                          Added possibility to change log direction
                          JSON config: Added possibility to filter out internal IP addresses
                          JSON config: Added _changed flag for formula in JSON config
                          -> 6.8.3
                          added description to adapter rating dialog
                          Extended the select component with grouping
                          Allowed the sorting of adapters by name and not only by title
                          Allowed the set state JSON config component
                          -> 6.8.0
                          try to find correct IP for controller UI multihost slave upgrade
                          admin is now showing update information, while it is stopped during upgrade
                          required nodejs version is 16 as 14 is End-Of-Life
                          fix downloading folders recursive
                          BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                          Would you like to downgrade admin from @6.10.1 to @5.2.1 now? [(y)es, (n)o]: y
                          Update admin from @6.10.1 to @5.2.1
                          NPM version: 9.6.7
                          npm install iobroker.admin@5.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          Adapter "admin" updated
                          esmax@ubuntu:/opt/iobroker$ ^C
                          esmax@ubuntu:/opt/iobroker$ cd backups/
                          esmax@ubuntu:/opt/iobroker/backups$ dir
                          iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
                          esmax@ubuntu:/opt/iobroker/backups$ iobroker restore iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
                          iobroker controller daemon is not running
                          host.ubuntu OK.
                          host.ubuntu Clear all objects and states...
                          clean 18 objects...
                          Server Objects 127.0.0.1:51690 Error from InMemDB: Error: Object is marked as non deletable
                          [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                          [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                          [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
                          [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                          [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
                          [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
                          clean 2 states...
                          host.ubuntu done.
                          host.ubuntu Processed 0/3050 states
                          host.ubuntu Processed 200/3050 states
                          host.ubuntu Processed 400/3050 states
                          host.ubuntu Processed 600/3050 states
                          host.ubuntu Processed 800/3050 states
                          host.ubuntu Processed 1000/3050 states
                          host.ubuntu Processed 1200/3050 states
                          host.ubuntu Processed 1400/3050 states
                          host.ubuntu Processed 1600/3050 states
                          host.ubuntu Processed 1800/3050 states
                          host.ubuntu Processed 2000/3050 states
                          host.ubuntu Processed 2200/3050 states
                          host.ubuntu Processed 2400/3050 states
                          host.ubuntu Processed 2600/3050 states
                          host.ubuntu Processed 2800/3050 states
                          host.ubuntu Processed 3000/3050 states
                          3050 states restored.
                          host.ubuntu Processed 0/4382 objects
                          host.ubuntu Processed 200/4382 objects
                          host.ubuntu Processed 400/4382 objects
                          host.ubuntu Processed 600/4382 objects
                          host.ubuntu Processed 800/4382 objects
                          host.ubuntu Processed 1000/4382 objects
                          host.ubuntu Processed 1200/4382 objects
                          host.ubuntu Processed 1400/4382 objects
                          host.ubuntu Processed 1600/4382 objects
                          host.ubuntu Processed 1800/4382 objects
                          host.ubuntu Processed 2000/4382 objects
                          host.ubuntu Processed 2200/4382 objects
                          host.ubuntu Processed 2400/4382 objects
                          host.ubuntu Processed 2600/4382 objects
                          host.ubuntu Processed 2800/4382 objects
                          host.ubuntu Processed 3000/4382 objects
                          host.ubuntu Processed 3200/4382 objects
                          host.ubuntu Processed 3400/4382 objects
                          host.ubuntu Processed 3600/4382 objects
                          host.ubuntu Processed 3800/4382 objects
                          host.ubuntu Processed 4000/4382 objects
                          host.ubuntu Processed 4200/4382 objects
                          4382 objects restored.
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular (1).woff
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.eot
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.ttf
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff2
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/edit_copy.svg
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w.svg
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w_open.svg
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/heatingcontrol.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-128x128.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-512x512.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-128x128.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-512x512.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-128x128.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-512x512.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-128x128.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-512x512.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-128x128.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-512x512.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-128x128.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-512x512.png
                          host.ubuntu Upload user file "vis.0/HeatingControl/images/it_wifi.svg
                          host.ubuntu Upload user file "vis.0/HeatingControl/vis-user.css
                          host.ubuntu Upload user file "vis.0/HeatingControl/vis-views.json
                          host.ubuntu Upload user file "vis.0/main/vis-views.json
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          System successfully restored!
                          esmax@ubuntu:/opt/iobroker/backups$ cd..
                          cd..: command not found
                          esmax@ubuntu:/opt/iobroker/backups$ cd ..
                          esmax@ubuntu:/opt/iobroker$ iobroker host this
                          A host with the name "ubuntu" already exists!
                          esmax@ubuntu:/opt/iobroker$ iobroker start
                          • Glasfaser
                            Nimm dir ein großen Kaffee ... und warte ......
                            E 2 Replies Last reply Reply Quote 0
                              @glasfaser
                              ok ok danke an alle 😄 😄
                                sieht so aus ob er ein Problem mit zwave2 hat:
                                host.ubuntu
                                	2023-09-27 20:22:55.183	error	Cannot download and install adapter "zwave2@2.4.1". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                host.ubuntu
                                	2023-09-27 20:22:54.181	info	iobroker npm-install: exit 25
                                host.ubuntu
                                	2023-09-27 20:22:53.143	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
                                host.ubuntu
                                	2023-09-27 20:22:53.100	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_22_35_608Z-debug-0.log
                                host.ubuntu
                                	2023-09-27 20:22:53.096	info	iobroker npm-install: npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
                                host.ubuntu
                                	2023-09-27 20:22:53.092	info	iobroker npm-install: npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])
                                host.ubuntu
                                	2023-09-27 20:22:53.090	info	iobroker npm-install: npm ERR! (node:49127) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())
                                host.ubuntu
                                	2023-09-27 20:22:53.088	info	iobroker npm-install: npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                host.ubuntu
                                	2023-09-27 20:22:53.086	info	iobroker npm-install: npm ERR! command failed
                                host.ubuntu
                                	2023-09-27 20:22:53.080	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                                host.ubuntu
                                	2023-09-27 20:22:53.078	info	iobroker npm-install: npm ERR! code 1
                                host.ubuntu
                                	2023-09-27 20:22:34.801	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                host.ubuntu
                                	2023-09-27 20:22:34.797	info	iobroker npm-install: NPM version: 9.6.7
                                host.ubuntu
                                	2023-09-27 20:22:31.553	info	iobroker install zwave2@2.4.1 using installedVersion
                                host.ubuntu
                                	2023-09-27 20:22:31.552	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 4 attempt
                                host.ubuntu
                                	2023-09-27 20:22:30.551	info	iobroker npm-install: exit 25
                                host.ubuntu
                                	2023-09-27 20:22:29.514	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
                                host.ubuntu
                                	2023-09-27 20:22:29.478	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_22_12_714Z-debug-0.log
                                host.ubuntu
                                	2023-09-27 20:22:29.472	info	iobroker npm-install:
                                host.ubuntu
                                	2023-09-27 20:22:29.467	info	iobroker npm-install: npm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
                                host.ubuntu
                                	2023-09-27 20:22:29.463	info	iobroker npm-install: npm ERR! (node:49007) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
                                host.ubuntu
                                	2023-09-27 20:22:29.460	info	iobroker npm-install: npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                host.ubuntu
                                	2023-09-27 20:22:29.454	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                                host.ubuntu
                                	2023-09-27 20:22:29.453	info	iobroker npm-install: npm ERR! code 1
                                host.ubuntu
                                	2023-09-27 20:22:11.901	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                host.ubuntu
                                	2023-09-27 20:22:11.898	info	iobroker npm-install: NPM version: 9.6.7
                                host.ubuntu
                                	2023-09-27 20:22:08.715	info	iobroker install zwave2@2.4.1 using installedVersion
                                host.ubuntu
                                	2023-09-27 20:22:08.714	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 3 attempt
                                host.ubuntu
                                	2023-09-27 20:22:07.712	info	iobroker npm-install: exit 25
                                host.ubuntu
                                	2023-09-27 20:22:06.675	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
                                host.ubuntu
                                	2023-09-27 20:22:06.634	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_21_49_487Z-debug-0.log
                                host.ubuntu
                                	2023-09-27 20:22:06.632	info	iobroker npm-install:
                                host.ubuntu
                                	2023-09-27 20:22:06.627	info	iobroker npm-install: npm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
                                host.ubuntu
                                	2023-09-27 20:22:06.624	info	iobroker npm-install: npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
                                host.ubuntu
                                	2023-09-27 20:22:06.621	info	iobroker npm-install: npm ERR! (node:48887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
                                host.ubuntu
                                	2023-09-27 20:22:06.620	info	iobroker npm-install: npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                host.ubuntu
                                	2023-09-27 20:22:06.614	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                                host.ubuntu
                                	2023-09-27 20:22:06.612	info	iobroker npm-install: npm ERR! code 1
                                host.ubuntu
                                	2023-09-27 20:21:48.677	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                host.ubuntu
                                	2023-09-27 20:21:48.674	info	iobroker npm-install: NPM version: 9.6.7
                                host.ubuntu
                                	2023-09-27 20:21:45.465	info	iobroker install zwave2@2.4.1 using installedFrom
                                host.ubuntu
                                	2023-09-27 20:21:45.464	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 2 attempt
                                host.ubuntu
                                	2023-09-27 20:21:44.461	info	iobroker npm-install: exit 25
                                host.ubuntu
                                	2023-09-27 20:21:43.426	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
                                host.ubuntu
                                	2023-09-27 20:21:43.387	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_21_13_622Z-debug-0.log
                                host.ubuntu
                                	2023-09-27 20:21:43.385	info	iobroker npm-install:
                                host.ubuntu
                                	2023-09-27 20:21:43.379	info	iobroker npm-install: npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
                                host.ubuntu
                                	2023-09-27 20:21:43.377	info	iobroker npm-install: npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(
                                host.ubuntu
                                	2023-09-27 20:21:43.375	info	iobroker npm-install: npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm ERR! (node:48764) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
                                host.ubuntu
                                	2023-09-27 20:21:43.367	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                                host.ubuntu
                                	2023-09-27 20:21:43.365	info	iobroker npm-install: npm ERR! code 1
                                host.ubuntu
                                	2023-09-27 20:21:12.815	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                host.ubuntu
                                	2023-09-27 20:21:12.811	info	iobroker npm-install: NPM version: 9.6.7
                                host.ubuntu
                                	2023-09-27 20:21:09.431	info	iobroker install zwave2@2.4.1 using installedFrom
                                host.ubuntu
                                	2023-09-27 20:21:09.430	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 1 attempt
                                host.ubuntu
                                	2023-09-27 20:21:08.427	info	iobroker npm-install: exit 0
                                host.ubuntu
                                	2023-09-27 20:21:07.259	info	iobroker npm-install: Update "system.adapter.web.0"
                                host.ubuntu
                                	2023-09-27 20:21:07.217	info	iobroker npm-install: host.ubuntu object connected created/updated
                                host.ubuntu
                                	2023-09-27 20:21:07.209	info	iobroker npm-install: host.ubuntu object system.adapter.web created/updated
                                host.ubuntu
                                	2023-09-27 20:21:07.003	info	iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:06.936	info	iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                                host.ubuntu
                                	2023-09-27 20:21:06.865	info	iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:06.799	info	iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:06.731	info	iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:06.663	info	iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                                host.ubuntu
                                	2023-09-27 20:21:06.595	info	iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                                host.ubuntu
                                	2023-09-27 20:21:06.528	info	iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:06.460	info	iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:06.393	info	iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:06.325	info	iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:06.258	info	iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:06.192	info	iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                                host.ubuntu
                                	2023-09-27 20:21:06.123	info	iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                                host.ubuntu
                                	2023-09-27 20:21:06.055	info	iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:05.986	info	iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:05.920	info	iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                                host.ubuntu
                                	2023-09-27 20:21:05.853	info	iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:05.784	info	iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:05.719	info	iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:05.653	info	iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:04.983	info	iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:04.301	info	iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:03.644	info	iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:00.683	info	iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                                host.ubuntu
                                	2023-09-27 20:21:00.014	info	iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:59.340	info	iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:58.675	info	iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:58.004	info	iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:54.694	info	iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:51.421	info	iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:48.051	info	iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:44.838	info	iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:41.642	info	iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:38.599	info	iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                host.ubuntu
                                	2023-09-27 20:20:38.533	info	iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                host.ubuntu
                                	2023-09-27 20:20:38.469	info	iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                host.ubuntu
                                	2023-09-27 20:20:38.406	info	iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                host.ubuntu
                                	2023-09-27 20:20:38.342	info	iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                host.ubuntu
                                	2023-09-27 20:20:38.247	info	iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                host.ubuntu
                                	2023-09-27 20:20:38.184	info	iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                host.ubuntu
                                	2023-09-27 20:20:38.116	info	iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                host.ubuntu
                                	2023-09-27 20:20:38.028	info	iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.20ad3cfd.chunk.js static/js/2.20ad3cfd.chunk.js application/javascript
                                host.ubuntu
                                	2023-09-27 20:20:37.962	info	iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.20ad3cfd.chunk.js.LICENSE.txt static/js/2.20ad3cfd.chunk.js.LICENSE.txt text/plain
                                host.ubuntu
                                	2023-09-27 20:20:37.571	info	iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.20ad3cfd.chunk.js.map static/js/2.20ad3cfd.chunk.js.map application/json
                                host.ubuntu
                                	2023-09-27 20:20:37.504	info	iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.1af53dde.chunk.js static/js/main.1af53dde.chunk.js application/javascript
                                host.ubuntu
                                	2023-09-27 20:20:37.435	info	iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.1af53dde.chunk.js.map static/js/main.1af53dde.chunk.js.map application/json
                                host.ubuntu
                                	2023-09-27 20:20:37.370	info	iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.6adebaf4.js static/js/runtime-main.6adebaf4.js application/javascript
                                host.ubuntu
                                	2023-09-27 20:20:37.305	info	iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.6adebaf4.js.map static/js/runtime-main.6adebaf4.js.map application/json
                                host.ubuntu
                                	2023-09-27 20:20:37.237	info	iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:37.143	info	iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                host.ubuntu
                                	2023-09-27 20:20:37.108	info	iobroker npm-install: host.ubuntu install adapter web@3.4.9
                                host.ubuntu
                                	2023-09-27 20:20:19.263	info	iobroker npm-install: npm install iobroker.web@3.4.9 --loglevel error --prefix "/opt/iobroker" (System call)
                                host.ubuntu
                                	2023-09-27 20:20:19.259	info	iobroker npm-install: NPM version: 9.6.7
                                host.ubuntu
                                	2023-09-27 20:20:15.872	info	iobroker install web@3.4.9 using installedFrom
                                host.ubuntu
                                	2023-09-27 20:20:15.871	warn	startInstance cannot find adapter "web@3.4.9". Try to install it... 1 attempt
                                • Glasfaser
                                  Mache das in der Konsole :
                                  iob install  iobroker.zwave2@3.0.5
                                    davor muss ich noch iob stoppen oder ?
                                    • Glasfaser
                                      @esmax666
                                      nein .
                                        @glasfaser
                                        am besten direkt
                                        iob install iobroker.zwave2@3.0.5 --debug
                                        • Glasfaser
                                          Glasfaser @Homoran last edited by
                                          Cannot download
                                          steht im Log
                                          aber --debug kann auch nicht schaden
                                            @glasfaser hat funktionniert:
                                            ich glaube da ist jetzt alles installiert 🙂
                                            esmax@ubuntu:/opt/iobroker$ iob install iobroker.zwave2@3.0.5 --debug
                                            NPM version: 9.6.7
                                            npm install iobroker.zwave2@3.0.5 --unsafe-perm --prefix "/opt/iobroker" (System call)
                                            added 126 packages in 32s
                                            133 packages are looking for funding
                                            host.ubuntu install adapter zwave2@3.0.5
                                            upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                                            upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                                            upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                                            upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                                            upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                                            upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                                            upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                                            upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                                            upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                                            upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                                            upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                                            upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                                            upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
                                            upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
                                            upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
                                            upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
                                            upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
                                            upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
                                            upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                                            host.ubuntu object system.adapter.zwave2 created/updated
                                            Update "system.adapter.zwave2.0"
                                            4697
