      TT-Tom @australien last edited by TT-Tom
      @australien es gibt in den Icons eins, was aussieht wie ein Radio. Eventuell hast du das gesehen.
        michael_4358 last edited by michael_4358
        @MichaelF meinst du das tasmota update auf v.13❓
        MichaelF 1 Reply Last reply Reply Quote 0
          19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
          19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
          19:48:00.005	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2869:9)
          19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
          19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
          19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
          19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
          19:48:00.012	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
          19:48:00.012	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
          19:48:00.012	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
          19:48:00.012	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
          19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
          19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
          19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
          19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
          19:48:00.013	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
          19:48:00.013	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
          19:48:00.013	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
          19:48:00.013	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
          19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
          ich erhalte nach dem update immer folgende Meldungen/warunungen,.,,
            TT-Tom last edited by TT-Tom
            @michael_4358
            Welche updates hast du gemacht, Versionen bitte angeben.
            zusätzlich bitte die Config von
            mrIcon1ScreensaverEntity:
            mrIcon2ScreensaverEntity:
            zeigen.
              michael_4358 @TT-Tom last edited by
              @tt-tom said in SONOFF NSPanel mit Lovelace UI:
              TypeScript v4.3.1.3 zur Steuerung des SONOFF NSPanel mit dem ioBroker
                          ScreensaverEntity: NSPanel_Path + 'Relay.1',
                          ScreensaverEntityIconOn: 'lightbulb',
                          ScreensaverEntityIconOff: null,
                          ScreensaverEntityValue: null,
                          ScreensaverEntityValueDecimalPlace : 0,
                          ScreensaverEntityValueUnit: null,
                          ScreensaverEntityOnColor: On,
                          ScreensaverEntityOffColor: HMIOff
                          ScreensaverEntity: 'deconz.0.Sensors.5.open',
                          ScreensaverEntityIconOn: 'heat-wave',
                          ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                          ScreensaverEntityValueDecimalPlace : 1,
                          ScreensaverEntityValueUnit: '°',
                          ScreensaverEntityOnColor: MSRed,
                          ScreensaverEntityOffColor: Yellow
                TT-Tom @michael_4358 last edited by TT-Tom
                @michael_4358
                hier steckt der Fehler, die Datenpunkte gibt's bei dir nicht. Es ist auch nur ein Beispiel.
                  @michael_4358
                  kann ich die einfach auskommentieren?
                    @michael_4358
                    habe die beiden mal auskommender nun sind noch
                    20:11:51.959	warn	javascript.0 (540063) at script.js.NSPanel.pdf:3349:46
                    20:11:51.959	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
                    20:11:51.959	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
                    20:11:51.959	warn	javascript.0 (540063) at fulfilled (script.js.NSPanel.pdf:5:58)
                    • MichaelF
                      MichaelF @michael_4358 last edited by
                      @michael_4358
                      Hi, nein die TFT Firmware
                        @michael_4358
                        Wie aus kommentiert? Bitte zeigen komplett.
                          @tt-tom
                          Bin gerade nicht am pc..
                          Habe vor der Zeile mit den datenpunkten „//„ angefügt, mehr nicht
                            @michael_4358
                            Ja so passt das nicht.
                                        ScreensaverEntity: NSPanel_Path + 'Relay.2',
                            ersetze mal bitte hier mit. Das funktioniert ohne Fehlermeldung und zeigt dir den Zustand der Relais.
                              manylopmy last edited by
                              Gute Abend zusammen 😊
                              Ich würde mich gerne daran geben, meine Sonos Boxen über das NSPanel
                              1. Ein und Auszuschalten
                              2. Lautstärke zu regulieren.
                              Da gibt es bestimmt schon einige Realisierungen.
                              Ich wäre froh wenn mir jemand eine kurze Beschreibung der Vorgehensweise (und welche Voraussetzungen ich erfüllt haben muss) mitteilen würde.
                              Stand derzeitig ist:
                              Der Sonos Adapter ist unter Objekte mit seinen Datenpunkten vorhanden. Ich habe bisher keinen zu SONOS gehörenden Alias eingerichtet.
                              Vielen Dank
                              Manfred
                                TT-Tom @manylopmy last edited by TT-Tom
                                @manylopmy schon mal im Wiki auf github gelesen. Siehe Signatur
                                  australien @TT-Tom last edited by
                                  @tt-tom
                                  ja, das kenne ich.
                                  Wollte eigene Bilder (locale Logos) anstatt des Radio-Icons.
                                  Ist es möglich eigene Bilder anstatt des Icons einzusetzen? Ev. via die icon_mapping.ts
                                    Kuckuckmann @australien last edited by
                                    @australien
                                    Hey,
                                    das icon_mapping.ts enhält ja letztlich die Icons von der Seite, die ich Dir gegeben habe. Es bleibt dabei, neue Icons bitte über das Git einkippen 🙂
                                    Wir haben keine Möglichkeit derzeit, da einfach mal ein JPG oder PNG einzuladen. Das Nextiondisplay ist da etwas "speziell".
                                    LG
                                      australien @Kuckuckmann last edited by
                                      @Kuckuckmann
                                      Ok. Danke. Verstehe.
                                        manylopmy @TT-Tom last edited by manylopmy
                                        @tt-tom
                                        Ich habe in der Zwischenzeit gelesen und gemacht. 😊
                                        Mit mittlerem Erfolg. Ich habe verstanden, dass ich einen Player benötige (logisch) und mir verschiedene zur Auswahl stehen. Spotify, Volumio und Sonos.
                                        Habe mit Sonos und Spotify versucht. Ich bekomme auch eine Page und habe ein wenig Zugriff auf mein Sonos. Derzeit habe ich folgenden Eintrag im ts:
                                        let Sonos = <PageMedia>
                                            'type': 'cardMedia',
                                            'heading': 'Sonos',
                                            'useColor': true,
                                            'items': [<PageItem>{
                                                        adapterPlayerInstance: 'alias.0.NSPanel.1.Media.Sonos_1',
                                                        mediaDevice: '192_168_178_86',
                                                        speakerList: ['Wohnzimmer'],
                                                        colorMediaIcon: colorRadio,
                                                        colorMediaArtist: Yellow,
                                                        colorMediaTitle: Yellow,
                                                        autoCreateALias : true
                                        Nun erscheint eine Page in der der Sender, der Titel und ich glaube das Album angezeigt werden. Weiterhin kann ich Next und Prev nutzen. Dazwischen steht auch das Pause-Symbol. das klappt auch, wechselt aber dann nicht in Play-Symbol und läßt auch keinen Start mehr zu.
                                        Seltsam finde ich selber, dass die ID als auch die PlayerInstance identisch sind. Aber ich finde keine wirkliche Alternative.
                                        Kann mir an der Stelle jemand auf die Sprünge helfen?
                                        Zum Schluß hätte ich gerne eine Anzeige, in der auch z.B. Playlist stehen in denen ich Titel aussuchen kann. Aber, - das ist next Step. Zuerst wäre es schön, die Steuerung richtig hinzubekommen.
                                        So sieht die Page aktuell aus.
                                        Gruß Manfred
                                        M T Armilar 3 Replies Last reply Reply Quote 0
                                          michael_4358 @manylopmy last edited by
                                          Hallo
                                          ich habe das problem das ich nun das display nicht ganz mittig habe... kann man die Ansicht zentrieren?
                                            @manylopmy
                                            Weiter kann ich dir da nicht helfen. Nutze keine Media Page und auch keinen der Adapter.
                                            lovelace ui nspanel sonoff
                                            271
                                            7731
                                            6658112
