    4. Backitup Restore fehler
      Esmax666 @simatec last edited by
      @simatec
      So alle command sind jetzt durchgefürt 😄 und iobroker startet noch 🤙
      Wie lange muss man warten bis "alle Adapter installiert" sind?
      Momentan sind die noch grau markiert
      die Command
      esmax@ubuntu:/opt/iobroker$ iobroker upgrade backitup@2.2.2
      Update repository "stable" under "http://download.iobroker.net/sources-dist.json"
      hash changed or no sources cached => force download of new sources
      This downgrade of "backitup" will at least remove the following changes:
      -> 2.8.1
      Fix roles
      help-links added
      -> 2.8.0
      small Sentry fixes
      Bugfix System-Message
      Docu & Wiki updated
      Translation updated
      dependencies updated
      Fix Webdav
      WOL Address & Port added
      Restore for Backitup Config added
      -> 2.7.0
      Fix error Messages
      edit automatic name addition added
      Docu & Wiki updated
      small bug fixes
      Translation updated
      Add support for sending notifications via discord (requires ioBroker.discord >= 2.1)
      -> 2.6.23
      Fix Influx Restore for MultiDB
      Token renew for Onedrive added
      Fix PSQL Restore
      -> 2.6.22
      Default Ports for InfluxDB added
      -> 2.6.21
      small Sentry fixes
      Fix Influx Restore
      Fix Onedrive Download
      -> 2.6.20
      FTP self signed Certificates added
      Would you like to downgrade backitup from @2.8.1 to @2.2.2 now? [(y)es, (n)o]: y
      Update backitup from @2.8.1 to @2.2.2
      NPM version: 9.6.7
      npm install iobroker.backitup@2.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      Adapter "backitup" updated
      esmax@ubuntu:/opt/iobroker$ iobroker upgrade admin@5.2.1
      This downgrade of "admin" will at least remove the following changes:
      -> 6.10.1
      fixed `between` function for showing news
      if date string is not parseable show the original string instead of `Invalid Date`
      updated socket classes to not crash on invalid patterns
      -> 6.10.0
      various minor improvements
      fixed problem with discovery dialog
      object browser now validates setting state of type number
      allow to specify unique columns for tables
      fix crash on invalid states, which are missing the property `common.role`
      -> 6.9.2
      show info, if server time differs from client time
      remove confusion with different names for state (datapoint and state)
      fixed link on 404-page being opened inside child view
      fixed issue if non-text default values are provided to a text jsonConfig component
      implemented del key shortcut to delete a selected object
      -> 6.9.1
      allow resizing of all columns in objects tab
      without expert mode users are only allowed to edit objects in `0_userdata.0` and `alias.0` namespace
      fixed keyboard navigation
      fixed problem with showing controller upgrade instructions if no UI upgrade is supported
      -> 6.9.0
      Added possibility to change log direction
      JSON config: Added possibility to filter out internal IP addresses
      JSON config: Added _changed flag for formula in JSON config
      -> 6.8.3
      added description to adapter rating dialog
      Extended the select component with grouping
      Allowed the sorting of adapters by name and not only by title
      Allowed the set state JSON config component
      -> 6.8.0
      try to find correct IP for controller UI multihost slave upgrade
      admin is now showing update information, while it is stopped during upgrade
      required nodejs version is 16 as 14 is End-Of-Life
      fix downloading folders recursive
      BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to downgrade admin from @6.10.1 to @5.2.1 now? [(y)es, (n)o]: y
      Update admin from @6.10.1 to @5.2.1
      NPM version: 9.6.7
      npm install iobroker.admin@5.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      Adapter "admin" updated
      esmax@ubuntu:/opt/iobroker$ ^C
      esmax@ubuntu:/opt/iobroker$ cd backups/
      esmax@ubuntu:/opt/iobroker/backups$ dir
      iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
      esmax@ubuntu:/opt/iobroker/backups$ iobroker restore iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
      iobroker controller daemon is not running
      host.ubuntu OK.
      host.ubuntu Clear all objects and states...
      clean 18 objects...
      Server Objects 127.0.0.1:51690 Error from InMemDB: Error: Object is marked as non deletable
      [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
      [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
      [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
      [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
      [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
      [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
      clean 2 states...
      host.ubuntu done.
      host.ubuntu Processed 0/3050 states
      host.ubuntu Processed 200/3050 states
      host.ubuntu Processed 400/3050 states
      host.ubuntu Processed 600/3050 states
      host.ubuntu Processed 800/3050 states
      host.ubuntu Processed 1000/3050 states
      host.ubuntu Processed 1200/3050 states
      host.ubuntu Processed 1400/3050 states
      host.ubuntu Processed 1600/3050 states
      host.ubuntu Processed 1800/3050 states
      host.ubuntu Processed 2000/3050 states
      host.ubuntu Processed 2200/3050 states
      host.ubuntu Processed 2400/3050 states
      host.ubuntu Processed 2600/3050 states
      host.ubuntu Processed 2800/3050 states
      host.ubuntu Processed 3000/3050 states
      3050 states restored.
      host.ubuntu Processed 0/4382 objects
      host.ubuntu Processed 200/4382 objects
      host.ubuntu Processed 400/4382 objects
      host.ubuntu Processed 600/4382 objects
      host.ubuntu Processed 800/4382 objects
      host.ubuntu Processed 1000/4382 objects
      host.ubuntu Processed 1200/4382 objects
      host.ubuntu Processed 1400/4382 objects
      host.ubuntu Processed 1600/4382 objects
      host.ubuntu Processed 1800/4382 objects
      host.ubuntu Processed 2000/4382 objects
      host.ubuntu Processed 2200/4382 objects
      host.ubuntu Processed 2400/4382 objects
      host.ubuntu Processed 2600/4382 objects
      host.ubuntu Processed 2800/4382 objects
      host.ubuntu Processed 3000/4382 objects
      host.ubuntu Processed 3200/4382 objects
      host.ubuntu Processed 3400/4382 objects
      host.ubuntu Processed 3600/4382 objects
      host.ubuntu Processed 3800/4382 objects
      host.ubuntu Processed 4000/4382 objects
      host.ubuntu Processed 4200/4382 objects
      4382 objects restored.
      host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular (1).woff
      host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.eot
      host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.ttf
      host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff
      host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff2
      host.ubuntu Upload user file "vis.0/HeatingControl/images/edit_copy.svg
      host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w.svg
      host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w_open.svg
      host.ubuntu Upload user file "vis.0/HeatingControl/images/heatingcontrol.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-128x128.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-512x512.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-128x128.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-512x512.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-128x128.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-512x512.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-128x128.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-512x512.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-128x128.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-512x512.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-128x128.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-512x512.png
      host.ubuntu Upload user file "vis.0/HeatingControl/images/it_wifi.svg
      host.ubuntu Upload user file "vis.0/HeatingControl/vis-user.css
      host.ubuntu Upload user file "vis.0/HeatingControl/vis-views.json
      host.ubuntu Upload user file "vis.0/main/vis-views.json
      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      System successfully restored!
      esmax@ubuntu:/opt/iobroker/backups$ cd..
      cd..: command not found
      esmax@ubuntu:/opt/iobroker/backups$ cd ..
      esmax@ubuntu:/opt/iobroker$ iobroker host this
      A host with the name "ubuntu" already exists!
      esmax@ubuntu:/opt/iobroker$ iobroker start
      • Glasfaser
        Glasfaser @Esmax666 last edited by
        @esmax666 sagte in Backitup Restore fehler:
        Nimm dir ein großen Kaffee ... und warte ......
        E 2 Replies Last reply Reply Quote 0
          Esmax666 @Glasfaser last edited by
          @glasfaser
          ok ok danke an alle 😄 😄
            sieht so aus ob er ein Problem mit zwave2 hat:
            host.ubuntu
            	2023-09-27 20:22:55.183	error	Cannot download and install adapter "zwave2@2.4.1". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
            host.ubuntu
            	2023-09-27 20:22:54.181	info	iobroker npm-install: exit 25
            host.ubuntu
            	2023-09-27 20:22:53.143	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
            host.ubuntu
            	2023-09-27 20:22:53.100	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_22_35_608Z-debug-0.log
            host.ubuntu
            	2023-09-27 20:22:53.096	info	iobroker npm-install: npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
            host.ubuntu
            	2023-09-27 20:22:53.092	info	iobroker npm-install: npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])
            host.ubuntu
            	2023-09-27 20:22:53.090	info	iobroker npm-install: npm ERR! (node:49127) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())
            host.ubuntu
            	2023-09-27 20:22:53.088	info	iobroker npm-install: npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            host.ubuntu
            	2023-09-27 20:22:53.086	info	iobroker npm-install: npm ERR! command failed
            host.ubuntu
            	2023-09-27 20:22:53.080	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            host.ubuntu
            	2023-09-27 20:22:53.078	info	iobroker npm-install: npm ERR! code 1
            host.ubuntu
            	2023-09-27 20:22:34.801	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            host.ubuntu
            	2023-09-27 20:22:34.797	info	iobroker npm-install: NPM version: 9.6.7
            host.ubuntu
            	2023-09-27 20:22:31.553	info	iobroker install zwave2@2.4.1 using installedVersion
            host.ubuntu
            	2023-09-27 20:22:31.552	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 4 attempt
            host.ubuntu
            	2023-09-27 20:22:30.551	info	iobroker npm-install: exit 25
            host.ubuntu
            	2023-09-27 20:22:29.514	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
            host.ubuntu
            	2023-09-27 20:22:29.478	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_22_12_714Z-debug-0.log
            host.ubuntu
            	2023-09-27 20:22:29.472	info	iobroker npm-install:
            host.ubuntu
            	2023-09-27 20:22:29.467	info	iobroker npm-install: npm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
            host.ubuntu
            	2023-09-27 20:22:29.463	info	iobroker npm-install: npm ERR! (node:49007) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
            host.ubuntu
            	2023-09-27 20:22:29.460	info	iobroker npm-install: npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            host.ubuntu
            	2023-09-27 20:22:29.454	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            host.ubuntu
            	2023-09-27 20:22:29.453	info	iobroker npm-install: npm ERR! code 1
            host.ubuntu
            	2023-09-27 20:22:11.901	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            host.ubuntu
            	2023-09-27 20:22:11.898	info	iobroker npm-install: NPM version: 9.6.7
            host.ubuntu
            	2023-09-27 20:22:08.715	info	iobroker install zwave2@2.4.1 using installedVersion
            host.ubuntu
            	2023-09-27 20:22:08.714	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 3 attempt
            host.ubuntu
            	2023-09-27 20:22:07.712	info	iobroker npm-install: exit 25
            host.ubuntu
            	2023-09-27 20:22:06.675	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
            host.ubuntu
            	2023-09-27 20:22:06.634	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_21_49_487Z-debug-0.log
            host.ubuntu
            	2023-09-27 20:22:06.632	info	iobroker npm-install:
            host.ubuntu
            	2023-09-27 20:22:06.627	info	iobroker npm-install: npm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
            host.ubuntu
            	2023-09-27 20:22:06.624	info	iobroker npm-install: npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
            host.ubuntu
            	2023-09-27 20:22:06.621	info	iobroker npm-install: npm ERR! (node:48887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
            host.ubuntu
            	2023-09-27 20:22:06.620	info	iobroker npm-install: npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            host.ubuntu
            	2023-09-27 20:22:06.614	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            host.ubuntu
            	2023-09-27 20:22:06.612	info	iobroker npm-install: npm ERR! code 1
            host.ubuntu
            	2023-09-27 20:21:48.677	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            host.ubuntu
            	2023-09-27 20:21:48.674	info	iobroker npm-install: NPM version: 9.6.7
            host.ubuntu
            	2023-09-27 20:21:45.465	info	iobroker install zwave2@2.4.1 using installedFrom
            host.ubuntu
            	2023-09-27 20:21:45.464	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 2 attempt
            host.ubuntu
            	2023-09-27 20:21:44.461	info	iobroker npm-install: exit 25
            host.ubuntu
            	2023-09-27 20:21:43.426	error	iobroker npm-install: host.ubuntu Cannot install iobroker.zwave2@2.4.1: 1
            host.ubuntu
            	2023-09-27 20:21:43.387	info	iobroker npm-install: npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-27T18_21_13_622Z-debug-0.log
            host.ubuntu
            	2023-09-27 20:21:43.385	info	iobroker npm-install:
            host.ubuntu
            	2023-09-27 20:21:43.379	info	iobroker npm-install: npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.2.0-1004-raspinpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not ok
            host.ubuntu
            	2023-09-27 20:21:43.377	info	iobroker npm-install: npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(
            host.ubuntu
            	2023-09-27 20:21:43.375	info	iobroker npm-install: npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm ERR! (node:48764) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
            host.ubuntu
            	2023-09-27 20:21:43.367	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            host.ubuntu
            	2023-09-27 20:21:43.365	info	iobroker npm-install: npm ERR! code 1
            host.ubuntu
            	2023-09-27 20:21:12.815	info	iobroker npm-install: npm install iobroker.zwave2@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            host.ubuntu
            	2023-09-27 20:21:12.811	info	iobroker npm-install: NPM version: 9.6.7
            host.ubuntu
            	2023-09-27 20:21:09.431	info	iobroker install zwave2@2.4.1 using installedFrom
            host.ubuntu
            	2023-09-27 20:21:09.430	warn	startInstance cannot find adapter "zwave2@2.4.1". Try to install it... 1 attempt
            host.ubuntu
            	2023-09-27 20:21:08.427	info	iobroker npm-install: exit 0
            host.ubuntu
            	2023-09-27 20:21:07.259	info	iobroker npm-install: Update "system.adapter.web.0"
            host.ubuntu
            	2023-09-27 20:21:07.217	info	iobroker npm-install: host.ubuntu object connected created/updated
            host.ubuntu
            	2023-09-27 20:21:07.209	info	iobroker npm-install: host.ubuntu object system.adapter.web created/updated
            host.ubuntu
            	2023-09-27 20:21:07.003	info	iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
            host.ubuntu
            	2023-09-27 20:21:06.936	info	iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
            host.ubuntu
            	2023-09-27 20:21:06.865	info	iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
            host.ubuntu
            	2023-09-27 20:21:06.799	info	iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
            host.ubuntu
            	2023-09-27 20:21:06.731	info	iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
            host.ubuntu
            	2023-09-27 20:21:06.663	info	iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
            host.ubuntu
            	2023-09-27 20:21:06.595	info	iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
            host.ubuntu
            	2023-09-27 20:21:06.528	info	iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
            host.ubuntu
            	2023-09-27 20:21:06.460	info	iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
            host.ubuntu
            	2023-09-27 20:21:06.393	info	iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
            host.ubuntu
            	2023-09-27 20:21:06.325	info	iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
            host.ubuntu
            	2023-09-27 20:21:06.258	info	iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
            host.ubuntu
            	2023-09-27 20:21:06.192	info	iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
            host.ubuntu
            	2023-09-27 20:21:06.123	info	iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
            host.ubuntu
            	2023-09-27 20:21:06.055	info	iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
            host.ubuntu
            	2023-09-27 20:21:05.986	info	iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
            host.ubuntu
            	2023-09-27 20:21:05.920	info	iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
            host.ubuntu
            	2023-09-27 20:21:05.853	info	iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
            host.ubuntu
            	2023-09-27 20:21:05.784	info	iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
            host.ubuntu
            	2023-09-27 20:21:05.719	info	iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
            host.ubuntu
            	2023-09-27 20:21:05.653	info	iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
            host.ubuntu
            	2023-09-27 20:21:04.983	info	iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
            host.ubuntu
            	2023-09-27 20:21:04.301	info	iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
            host.ubuntu
            	2023-09-27 20:21:03.644	info	iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
            host.ubuntu
            	2023-09-27 20:21:00.683	info	iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
            host.ubuntu
            	2023-09-27 20:21:00.014	info	iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
            host.ubuntu
            	2023-09-27 20:20:59.340	info	iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
            host.ubuntu
            	2023-09-27 20:20:58.675	info	iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
            host.ubuntu
            	2023-09-27 20:20:58.004	info	iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
            host.ubuntu
            	2023-09-27 20:20:54.694	info	iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
            host.ubuntu
            	2023-09-27 20:20:51.421	info	iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
            host.ubuntu
            	2023-09-27 20:20:48.051	info	iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
            host.ubuntu
            	2023-09-27 20:20:44.838	info	iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
            host.ubuntu
            	2023-09-27 20:20:41.642	info	iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
            host.ubuntu
            	2023-09-27 20:20:38.599	info	iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
            host.ubuntu
            	2023-09-27 20:20:38.533	info	iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
            host.ubuntu
            	2023-09-27 20:20:38.469	info	iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
            host.ubuntu
            	2023-09-27 20:20:38.406	info	iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
            host.ubuntu
            	2023-09-27 20:20:38.342	info	iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
            host.ubuntu
            	2023-09-27 20:20:38.247	info	iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
            host.ubuntu
            	2023-09-27 20:20:38.184	info	iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
            host.ubuntu
            	2023-09-27 20:20:38.116	info	iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
            host.ubuntu
            	2023-09-27 20:20:38.028	info	iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.20ad3cfd.chunk.js static/js/2.20ad3cfd.chunk.js application/javascript
            host.ubuntu
            	2023-09-27 20:20:37.962	info	iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.20ad3cfd.chunk.js.LICENSE.txt static/js/2.20ad3cfd.chunk.js.LICENSE.txt text/plain
            host.ubuntu
            	2023-09-27 20:20:37.571	info	iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.20ad3cfd.chunk.js.map static/js/2.20ad3cfd.chunk.js.map application/json
            host.ubuntu
            	2023-09-27 20:20:37.504	info	iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.1af53dde.chunk.js static/js/main.1af53dde.chunk.js application/javascript
            host.ubuntu
            	2023-09-27 20:20:37.435	info	iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.1af53dde.chunk.js.map static/js/main.1af53dde.chunk.js.map application/json
            host.ubuntu
            	2023-09-27 20:20:37.370	info	iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.6adebaf4.js static/js/runtime-main.6adebaf4.js application/javascript
            host.ubuntu
            	2023-09-27 20:20:37.305	info	iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.6adebaf4.js.map static/js/runtime-main.6adebaf4.js.map application/json
            host.ubuntu
            	2023-09-27 20:20:37.237	info	iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
            host.ubuntu
            	2023-09-27 20:20:37.143	info	iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
            host.ubuntu
            	2023-09-27 20:20:37.108	info	iobroker npm-install: host.ubuntu install adapter web@3.4.9
            host.ubuntu
            	2023-09-27 20:20:19.263	info	iobroker npm-install: npm install iobroker.web@3.4.9 --loglevel error --prefix "/opt/iobroker" (System call)
            host.ubuntu
            	2023-09-27 20:20:19.259	info	iobroker npm-install: NPM version: 9.6.7
            host.ubuntu
            	2023-09-27 20:20:15.872	info	iobroker install web@3.4.9 using installedFrom
            host.ubuntu
            	2023-09-27 20:20:15.871	warn	startInstance cannot find adapter "web@3.4.9". Try to install it... 1 attempt
            • Glasfaser
              Mache das in der Konsole :
              iob install  iobroker.zwave2@3.0.5
                @glasfaser said in Backitup Restore fehler:
                davor muss ich noch iob stoppen oder ?
                • Glasfaser
                  @esmax666
                  nein .
                    @glasfaser
                    am besten direkt
                    iob install iobroker.zwave2@3.0.5 --debug
                    • Glasfaser
                      Glasfaser @Homoran last edited by
                      Cannot download
                      steht im Log
                      aber --debug kann auch nicht schaden
                        @glasfaser hat funktionniert:
                        ich glaube da ist jetzt alles installiert 🙂
                        esmax@ubuntu:/opt/iobroker$ iob install iobroker.zwave2@3.0.5 --debug
                        NPM version: 9.6.7
                        npm install iobroker.zwave2@3.0.5 --unsafe-perm --prefix "/opt/iobroker" (System call)
                        added 126 packages in 32s
                        133 packages are looking for funding
                          run `npm fund` for details
                        host.ubuntu install adapter zwave2@3.0.5
                        upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                        upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                        upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                        upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                        upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                        upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                        upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                        upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                        upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                        upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                        upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                        upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                        upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
                        upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
                        upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
                        upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
                        upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
                        upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
                        upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                        host.ubuntu object system.adapter.zwave2 created/updated
                        Update "system.adapter.zwave2.0"
                        • Glasfaser
                          Glasfaser last edited by Glasfaser
                          dann zeige mal
                          iob diag
                          in der Full Version
                            Esmax666 @Glasfaser last edited by Homoran
                            iob diag
                            Copy text starting here:
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                             Static hostname: ubuntu
                                   Icon name: computer
                                  Machine ID: 965a81734c8d402ab05ca26017c6e6a9
                                     Boot ID: a39af5905d2248f68505f9914e186102
                            Operating System: Ubuntu 23.04
                                      Kernel: Linux 6.2.0-1004-raspi
                                Architecture: arm64
                            Model           : Raspberry Pi 4 Model B Rev 1.4
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : arm64
                            Systemuptime and Load:
                             21:22:07 up  3:53,  2 users,  load average: 0.41, 0.34, 0.24
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            Other values than 0x0 hint to temperature/voltage problems
                            temp=52.1'C
                            volt=0.8820V
                            The systems needs to be REBOOTED!
                            *** Time and Time Zones ***
                                           Local time: Wed 2023-09-27 21:22:07 CEST
                                       Universal time: Wed 2023-09-27 19:22:07 UTC
                                             RTC time: n/a
                                            Time zone: Europe/Paris (CEST, +0200)
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            esmax
                            /home/esmax
                            esmax adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        1.4G        1.7G        3.3M        5.4G        6.8G
                            Swap:             0B          0B          0B
                            Total:          8.2G        1.4G        1.7G
                                     7809 M total memory
                                     1290 M used memory
                                     1197 M active memory
                                     4363 M inactive memory
                                     1647 M free memory
                                      195 M buffer memory
                                     4992 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            Filesystem     Type   Size  Used Avail Use% Mounted on
                            tmpfs          tmpfs  781M  3.2M  778M   1% /run
                            /dev/mmcblk0p2 ext4    59G  5.2G   51G  10% /
                            tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
                            tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
                            /dev/mmcblk0p1 vfat   253M  151M  102M  60% /boot/firmware
                            tmpfs          tmpfs  781M  4.0K  781M   1% /run/user/1000
                            [Wed Sep 27 17:28:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
                            [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                            [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
                            [Wed Sep 27 17:28:37 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
                            [Wed Sep 27 17:28:47 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 979920 to 15526139 blocks
                            [Wed Sep 27 17:28:48 2023] EXT4-fs (mmcblk0p2): resized filesystem to 15526139
                            Show mounted filesystems (real ones only):
                            TARGET              SOURCE         FSTYPE   OPTIONS
                            /                   /dev/mmcblk0p2 ext4     rw,relatime,discard,errors=remount-ro,commit=30
                            |-/snap/core22/611  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/lxd/24646   /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/snapd/18600 /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            |-/snap/lxd/25755   /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
                            `-/snap/core22/867  /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
                            /var:
                            924M    /var/
                            677M    /var/lib
                            505M    /var/lib/snapd
                            504M    /var/lib/snapd/snaps
                            220M    /var/cache
                            Archived and active journals take up 25.9M in the file system.
                            /opt/iobroker/backups:
                            4.5M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            110M    /opt/iobroker/iobroker-data/
                            83M     /opt/iobroker/iobroker-data/files
                            27M     /opt/iobroker/iobroker-data/files/javascript.admin
                            15M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                            8.0M    /opt/iobroker/iobroker-data/objects.json.bak
                            4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                            4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Installed: 18.17.1-deb-1nodesource1
                              Candidate: 18.17.1-deb-1nodesource1
                              Version table:
                             *** 18.17.1-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_18.x lunar/main arm64 Packages
                                    100 /var/lib/dpkg/status
                                 18.13.0+dfsg1-1ubuntu2 500
                                    500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
                            No problems detected
                            npm ERR! code ELSPROBLEMS
                            npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                            npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                            npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
                            npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
                            npm ERR! invalid: @types/node@12.20.55 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                            npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/usb/node_modules/node-addon-api
                            npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T19_22_14_366Z-debug-0.log
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: file
                            States  type: file
                            No configuration change needed.
                            Multihost discovery server: disabled
                            Discovery authentication:   enabled
                            Persistent activation:      disabled
                            Objects:                    file on 127.0.0.1
                            States:                     file on 127.0.0.1
                            Core adapters versions
                            js-controller:  3.3.22
                            admin:          5.2.1
                            javascript:     5.2.13
                            Adapters from github:   0
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : ubuntu                                   - disabled
                            + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
                              system.adapter.cloud.0                  : cloud                 : ubuntu                                   - disabled
                              system.adapter.discovery.0              : discovery             : ubuntu                                   - disabled
                              system.adapter.flot.0                   : flot                  : ubuntu                                   - disabled
                            + system.adapter.heatingcontrol.0         : heatingcontrol        : ubuntu                                   -  enabled
                            + system.adapter.history.0                : history               : ubuntu                                   -  enabled
                              system.adapter.ical.0                   : ical                  : ubuntu                                   -  enabled
                              system.adapter.info.0                   : info                  : ubuntu                                   - disabled
                              system.adapter.iot.0                    : iot                   : ubuntu                                   - disabled
                            + system.adapter.javascript.0             : javascript            : ubuntu                                   -  enabled
                              system.adapter.linkeddevices.0          : linkeddevices         : ubuntu                                   - disabled
                              system.adapter.mobile.0                 : mobile                : ubuntu                                   - disabled
                              system.adapter.radar2.0                 : radar2                : ubuntu                                   - disabled
                              system.adapter.rpi2.0                   : rpi2                  : ubuntu                                   - disabled
                            + system.adapter.shuttercontrol.0         : shuttercontrol        : ubuntu                                   -  enabled
                              system.adapter.socketio.0               : socketio              : ubuntu                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                              system.adapter.telegram.0               : telegram              : ubuntu                                   - disabled, port: 8443, bind: 0.0.0.0
                              system.adapter.text2command.0           : text2command          : ubuntu                                   - disabled
                              system.adapter.tr-064.0                 : tr-064                : ubuntu                                   - disabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : ubuntu                                   - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubuntu                                   - disabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ubuntu                                   - disabled
                              system.adapter.vis-metro.0              : vis-metro             : ubuntu                                   - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ubuntu                                   - disabled
                              system.adapter.vis.0                    : vis                   : ubuntu                                   - disabled
                            + system.adapter.web.0                    : web                   : ubuntu                                   -  enabled, port: 443, bind: 0.0.0.0, run as: admin
                            + system.adapter.zwave2.0                 : zwave2                : ubuntu                                   -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            stable      : http://download.iobroker.net/sources-dist.json
                            beta        : http://download.iobroker.net/sources-dist-latest.json
                            Active repo: stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            hash unchanged, use cached sources
                            update done
                            Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
                            Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
                            Adapter    "backitup"      : 2.8.1    , installed 2.2.2 [Updateable]
                            Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                            Adapter    "discovery"     : 3.1.0    , installed 3.1.0
                            Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                            Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
                            Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
                            Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
                            Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
                            Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
                            Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
                            Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
                            Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
                            Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                            Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
                            Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
                            Adapter    "shuttercontrol": 1.6.2    , installed 1.2.1 [Updateable]
                            Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
                            Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
                            Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
                            Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
                            Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
                            Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
                            Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
                            Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
                            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                            Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
                            Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                            Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
                            Adapter    "zwave2"        : 3.0.5    , installed 3.0.5
                            Objects and States
                            Objects:        1829
                            States:         3260
                            Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
                            Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
                            Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
                            Hit:4 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
                            Hit:5 https://deb.nodesource.com/node_18.x lunar InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          78134      1/systemd
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        37558      13668/systemd-resol
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       86098      46034/iobroker.js-c
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       86091      46034/iobroker.js-c
                            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        37560      13668/systemd-resol
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          39954      1/systemd
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          78136      1/systemd
                            tcp6       0      0 :::443                  :::*                    LISTEN      1001       90857      49322/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       84702      46059/io.admin.0
                            udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        37559      13668/systemd-resol
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        37557      13668/systemd-resol
                            udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        52189      37786/systemd-netwo
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          76543      1/systemd
                            udp6       0      0 :::111                  :::*                                0          76545      1/systemd
                            udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        52209      37786/systemd-netwo
                            2023-09-27 21:07:59.781  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2023-09-27 21:08:09.427  - info: host.ubuntu "system.adapter.ical.0" disabled
                            2023-09-27 21:08:09.428  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
                            2023-09-27 21:08:09.430  - info: host.ubuntu stopInstance canceled schedule system.adapter.ical.0
                            2023-09-27 21:08:14.720  - info: host.ubuntu "system.adapter.ical.0" enabled
                            2023-09-27 21:08:14.723  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
                            2023-09-27 21:08:17.803  - info: host.ubuntu instance scheduled system.adapter.ical.0 0,30 * * * *
                            2023-09-27 21:08:17.841  - info: host.ubuntu instance system.adapter.ical.0 started with pid 49431
                            2023-09-27 21:08:19.974  - info: ical.0 (49431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2023-09-27 21:08:19.991  - info: ical.0 (49431) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 3.3.22
                            2023-09-27 21:08:20.611  - info: ical.0 (49431) processing URL: calendar1 https://63ea0ab88b/basic.ics
                            2023-09-27 21:08:25.685  - info: ical.0 (49431) Terminated (NO_ERROR): Without reason
                            2023-09-27 21:08:26.285  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2023-09-27 21:10:00.025  - debug: shuttercontrol.0 (49337) calculate astrodata ...
                            2023-09-27 21:10:00.026  - debug: shuttercontrol.0 (49337) Sun Azimut: 293.5°
                            2023-09-27 21:10:00.027  - debug: shuttercontrol.0 (49337) Sun Elevation: -20.7°
                            2023-09-27 21:15:00.023  - debug: shuttercontrol.0 (49337) calculate astrodata ...
                            2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 294.5°
                            2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Elevation: -21.5°
                            2023-09-27 21:17:03.503  - debug: zwave2.0 (49299) Node 34: value updated: value_electric_kwh_consumed => 1.02
                            2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) calculate astrodata ...
                            2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 295.6°
                            2023-09-27 21:20:00.025  - debug: shuttercontrol.0 (49337) Sun Elevation: -22.2°
                            2023-09-27 21:21:53.141  - debug: zwave2.0 (49299) Node 5: metadata updated: airTemperature
                            2023-09-27 21:21:53.143  - debug: zwave2.0 (49299) Node 5: value updated: airTemperature => 17.79
                            iob diag has finished.
                            Press any key for a summary
                                                 v.2023-06-20
                                   Icon name: computer
                                Architecture: arm64
                            Installation:           native
                            Kernel:                 aarch64
                            Userland:               arm64
                            Timezone:               Europe/Paris (CEST, +0200)
                            User-ID:                1000
                            X-Server:               false
                            Boot Target:            graphical.target
                            Pending OS-Updates:     0
                            Pending iob updates:    26
                            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                            MEMORY:
                            Mem:            8.2G        1.6G        1.5G        3.3M        5.4G        6.6G
                            Swap:             0B          0B          0B
                            Total:          8.2G        1.6G        1.5G
                            Active iob-Instances:   9
                            Active repo: stable
                            ioBroker Core:          js-controller           3.3.22
                                                    admin                   5.2.1
                            Objects type: file
                            States  type: file
                            Objects:                1829
                            States:                 3261
                            Size of iob-Database:
                            3.7M    /opt/iobroker/iobroker-data/objects.jsonl
                            832K    /opt/iobroker/iobroker-data/states.json.bak
                            44K     /opt/iobroker/iobroker-data/states.jsonl
                            === Mark text until here for copying ===
                            Glasfaser Thomas Braun simatec 3 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Glasfaser @Esmax666 last edited by Glasfaser
                              @esmax666
                              sieht sehr gut aus .. hast alles gemacht wie beschrieben !
                              jetzt weiter machen , nach der Liste !
                              EDIT
                              aber fange mit dem
                              an !
                                Thomas Braun Most Active @Esmax666 last edited by
                                Meine Gedanken zu dem System, kannst du umsetzen wenn der ioBroker wieder rennt.
                                Ungünstige Wahl für einen längeren Betrieb. Diese Interimsversionen von ubuntu leben nur 9 Monate. Besser ein Debian/Raspberry OS auf die Kiste werfen.
                                Keine Deko, das sollte man tun.
                                Du sitzt in Frankreich?
                                Du hast das System nicht sauber heruntergefahren. IMMER tun.
                                Nicht falsch, aber nicht aktuell. Stell auf das neue nodesource-Repo um.
                                Installier iobroker.javascript nochmal drüber.
                                • simatec
                                  simatec Developer Most Active @Esmax666 last edited by
                                  @esmax666 wenn alles fertig installiert ist und läuft, dann mache ein Upgrade aller Adapter und vorher js-controller updaten
                                  iobroker stop
                                  iobroker update
                                  iobroker upgrade self
                                  iobroker upgrade -y
                                  iobroker fix
                                  iobroker start
                                  • simatec
                                    simatec Developer Most Active last edited by simatec
                                    @Esmax666
                                    Danach richte Backitup ein, damit du jede Nacht ein Backup machst.
                                    Am besten auf ein NAS oder wenn du dass nicht hast, nutze einen Clouddienst, den Backitup unterstützt.
                                    Im Anschluss noch einen Kalendereintrag, der sich jeden Monat wiederholt, in dem du dein System auf Stand bringst.
                                    Immer das System und den iobroker aktuell halten
                                      @glasfaser
                                      also jscontroler ist jetzt aktualisiert 5.0.12
                                      ich kann jetzt weiter weitermachen oder ? weboberfläche geht aber nicht mehr
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                               Boot ID: 0c59d3c9640b486fadab37c9e124b76a
                                                Kernel: Linux 6.2.0-1013-raspi
                                          Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                       23:16:45 up 8 min,  2 users,  load average: 3.57, 1.61, 0.67
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=68.6'C
                                      volt=0.9260V
                                                     Local time: Wed 2023-09-27 23:16:46 CEST
                                                 Universal time: Wed 2023-09-27 21:16:46 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      esmax
                                      /home/esmax
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            8.2G        1.4G        6.4G        3.2M        602M        6.8G
                                      Swap:             0B          0B          0B
                                      Total:          8.2G        1.4G        6.4G
                                               7809 M total memory
                                               1352 M used memory
                                                283 M active memory
                                               1153 M inactive memory
                                               6148 M free memory
                                                 59 M buffer memory
                                                515 M swap cache
                                                  0 M total swap
                                                  0 M used swap
                                                  0 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      tmpfs          tmpfs  781M  3.1M  778M   1% /run
                                      [Wed Sep 27 23:08:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
                                      [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                                      [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
                                      [Wed Sep 27 23:08:31 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
                                      |-/snap/core22/611  /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core22/867  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/lxd/24646   /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/lxd/25755   /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/snapd/18600 /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
                                      `-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      943M    /var/
                                      677M    /var/lib
                                      505M    /var/lib/snapd
                                      222M    /var/cache
                                      Archived and active journals take up 43.0M in the file system.
                                      119M    /opt/iobroker/iobroker-data/
                                      8.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                      8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                                      8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T21_17_01_730Z-debug-0.log
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                    jsonl on 127.0.0.1
                                      States:                     jsonl on 127.0.0.1
                                      js-controller:  5.0.12
                                      admin:          5.2.1
                                      javascript:     5.2.13
                                      Adapter State
                                      + instance is alive
                                      Active repo(s): stable
                                      Adapter    "admin"        : 6.10.1   , installed 5.2.1  [Updatable]
                                      Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
                                      Adapter    "backitup"     : 2.8.1    , installed 2.2.2  [Updatable]
                                      Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
                                      Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                                      Adapter    "heatingcontrol": 2.11.1  , installed 2.7.2  [Updatable]
                                      Adapter    "history"      : 2.2.6    , installed 1.9.14 [Updatable]
                                      Adapter    "ical"         : 1.13.3   , installed 1.11.4 [Updatable]
                                      Adapter    "info"         : 1.9.26   , installed 1.9.8  [Updatable]
                                      Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
                                      Adapter    "javascript"   : 7.1.4    , installed 5.2.13 [Updatable]
                                      Controller "js-controller": 5.0.12   , installed 5.0.12
                                      Adapter    "linkeddevices": 1.5.5    , installed 1.4.3  [Updatable]
                                      Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
                                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                                      Adapter    "shuttercontrol": 1.6.2   , installed 1.2.1  [Updatable]
                                      Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
                                      Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
                                      Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
                                      Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
                                      Adapter    "vis"          : 1.4.16   , installed 1.4.5  [Updatable]
                                      Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                                      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                                      Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                                      Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                                      Adapter    "web"          : 6.1.2    , installed 3.4.9  [Updatable]
                                      Objects and States
                                      Objects:        4592
                                      States:         3264
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17467      1/init
                                      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        22635      555/systemd-resolve
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26995      2351/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27002      2351/iobroker.js-co
                                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        22633      555/systemd-resolve
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13962      1/init
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          23620      1/init
                                      udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        22634      555/systemd-resolve
                                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        22632      555/systemd-resolve
                                      udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        22809      812/systemd-network
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17468      1/init
                                      udp6       0      0 :::111                  :::*                                0          16876      1/init
                                      udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        22817      812/systemd-network
                                      2023-09-27 23:17:33.462  - info: zwave2.0 (2938) Node 2: ready to use
                                      2023-09-27 23:17:33.697  - info: zwave2.0 (2938) Node 2 is alive
                                      2023-09-27 23:17:36.082  - info: zwave2.0 (2938) Node 3: ready to use
                                      2023-09-27 23:17:36.179  - info: vis.0 (3029) Uploaded. 0
                                      2023-09-27 23:17:36.436  - info: zwave2.0 (2938) Node 4: ready to use
                                      2023-09-27 23:17:36.695  - info: vis.0 (3029) Terminated (NO_ERROR): Without reason
                                      2023-09-27 23:17:37.940  - info: zwave2.0 (2938) Node 5: ready to use
                                      2023-09-27 23:17:38.180  - info: zwave2.0 (2938) Node 5 is alive
                                      2023-09-27 23:17:40.108  - info: zwave2.0 (2938) Node 7: ready to use
                                      2023-09-27 23:17:40.256  - info: zwave2.0 (2938) Node 8: ready to use
                                      2023-09-27 23:17:40.402  - info: zwave2.0 (2938) Node 9: ready to use
                                      2023-09-27 23:17:41.185  - info: zwave2.0 (2938) Node 22: ready to use
                                      2023-09-27 23:17:41.886  - info: zwave2.0 (2938) Node 25: ready to use
                                      2023-09-27 23:17:59.738  - info: zwave2.0 (2938) Node 31: ready to use
                                      2023-09-27 23:17:59.860  - info: zwave2.0 (2938) Node 31 is alive
                                      2023-09-27 23:17:59.876  - info: zwave2.0 (2938) Node 32: ready to use
                                      2023-09-27 23:17:59.988  - info: zwave2.0 (2938) Node 32 is alive
                                      2023-09-27 23:18:00.067  - info: zwave2.0 (2938) Node 33: ready to use
                                      2023-09-27 23:18:00.121  - info: zwave2.0 (2938) Node 34: ready to use
                                      2023-09-27 23:18:00.169  - info: zwave2.0 (2938) Node 33 is alive
                                      2023-09-27 23:18:00.183  - info: zwave2.0 (2938) Node 34 is alive
                                      2023-09-27 23:18:00.390  - info: zwave2.0 (2938) Node 35: ready to use
                                      2023-09-27 23:18:00.448  - info: zwave2.0 (2938) Node 35 is alive
                                      2023-09-27 23:18:00.478  - info: zwave2.0 (2938) Node 38: ready to use
                                      2023-09-27 23:18:00.526  - info: zwave2.0 (2938) Node 38 is alive
                                        @esmax666
                                        iob update
                                        iob upgrade all -y
                                        iob start admin
                                          Esmax666 @Thomas Braun last edited by
                                          @thomas-braun said in Backitup Restore fehler:
                                          ich wollte ertmals probieren wie es früher war um weniger Problem zu bekommen 😄
                                          ich auch gemacht
                                          JA
                                          Seltsam ich habe nur gerade heute ubuntu / iobroker installiert ohne das Gerät auszuschalten
                                          wie soll ich das machen ?
                                            Esmax666 @Esmax666 last edited by Esmax666
                                            update ist done,
                                            ich glaube da läuft alles wieder richtig, dann mache schnell noch ein backup 😄
                                            Also das wäre noch eventuel zu machen ? Node.js: v18.17.1(18.18.0)
                                            NPM: 9.6.7(9.8.1)
                                            aber wie ?
                                            Skript v.2023-06-20
                                            *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : arm64
                                             23:43:46 up 35 min,  2 users,  load average: 0.05, 0.65, 1.10
                                            CPU threads: 4
                                            Raspberry only:
                                            throttled=0x0
                                            temp=53.0'C
                                            volt=0.8600V
                                                           Local time: Wed 2023-09-27 23:43:46 CEST
                                                       Universal time: Wed 2023-09-27 21:43:46 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            esmax
                                            /home/esmax
                                            X-Server:       false
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            8.2G        1.3G        5.5G        3.3M        1.8G        6.9G
                                            Swap:             0B          0B          0B
                                            Total:          8.2G        1.3G        5.5G
                                                     7809 M total memory
                                                     1195 M used memory
                                                      476 M active memory
                                                     1755 M inactive memory
                                                     5249 M free memory
                                                       97 M buffer memory
                                                     1576 M swap cache
                                                        0 M total swap
                                                        0 M used swap
                                                        0 M free swap
                                            Raspberry only:
                                            oom events: 0
                                            *** FILESYSTEM ***
                                            /dev/mmcblk0p2 ext4    59G  5.5G   51G  10% /
                                            /var:
                                            944M    /var/
                                            677M    /var/lib
                                            505M    /var/lib/snapd
                                            222M    /var/cache
                                            7.6M    /opt/iobroker/backups/
                                            229M    /opt/iobroker/iobroker-data/
                                            192M    /opt/iobroker/iobroker-data/files
                                            52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                            33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                                            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                                            8.2M    /opt/iobroker/iobroker-data/objects.jsonl
                                            /usr/bin/npm            9.6.7
                                            /usr/bin/npx            9.6.7
                                            nodejs:
                                              Version table:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            admin:          6.10.1
                                            javascript:     7.1.4
                                            Adapter State
                                            + instance is alive
                                            Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                                            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                                            Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                                            Adapter    "history"      : 2.2.6    , installed 2.2.6
                                            Adapter    "info"         : 1.9.26   , installed 1.9.26
                                            Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                            Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                                            Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                            Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                            Adapter    "web"          : 6.1.2    , installed 6.1.2
                                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                            Objects and States
                                            Objects:        4615
                                            States:         3306
                                            Pending Updates: 0
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47592      9892/iobroker.js-co
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50371      9892/iobroker.js-co
                                            tcp6       0      0 :::443                  :::*                    LISTEN      1001       47776      10028/io.web.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47619      9910/io.admin.0
                                            2023-09-27 23:38:35.483  - info: zwave2.0 (10049) Node 4: ready to use
                                            2023-09-27 23:38:35.521  - info: zwave2.0 (10049) Node 4 is alive
                                            2023-09-27 23:38:37.047  - info: zwave2.0 (10049) Node 5: ready to use
                                            2023-09-27 23:38:37.108  - info: zwave2.0 (10049) Node 5 is alive
                                            2023-09-27 23:38:38.332  - info: zwave2.0 (10049) Node 22: ready to use
                                            2023-09-27 23:38:38.362  - info: zwave2.0 (10049) Node 22 is alive
                                            2023-09-27 23:38:56.528  - info: admin.0 (9910) ==> Connected system.user.admin from ::ffff:192.168.178.39
                                            2023-09-27 23:38:58.724  - info: zwave2.0 (10049) Node 31: ready to use
                                            2023-09-27 23:38:58.754  - info: zwave2.0 (10049) Node 31 is alive
                                            2023-09-27 23:38:58.817  - info: zwave2.0 (10049) Node 32: ready to use
                                            2023-09-27 23:38:58.865  - info: zwave2.0 (10049) Node 33: ready to use
                                            2023-09-27 23:38:58.936  - info: zwave2.0 (10049) Node 34: ready to use
                                            2023-09-27 23:38:58.970  - info: zwave2.0 (10049) Node 32 is alive
                                            2023-09-27 23:38:58.990  - info: zwave2.0 (10049) Node 33 is alive
                                            2023-09-27 23:38:59.014  - info: zwave2.0 (10049) Node 34 is alive
                                            2023-09-27 23:38:59.204  - info: zwave2.0 (10049) Node 35: ready to use
                                            2023-09-27 23:38:59.263  - info: zwave2.0 (10049) Node 35 is alive
                                            2023-09-27 23:38:59.292  - info: zwave2.0 (10049) Node 38: ready to use
                                            2023-09-27 23:38:59.322  - info: zwave2.0 (10049) Node 38 is alive
                                            2023-09-27 23:40:00.027  - debug: shuttercontrol.0 (10013) calculate astrodata ...
                                            2023-09-27 23:40:00.028  - debug: shuttercontrol.0 (10013) Sun Azimut: 331.9°
                                            2023-09-27 23:40:00.029  - debug: shuttercontrol.0 (10013) Sun Elevation: -38.6°
                                            2023-09-27 23:42:25.827  - debug: zwave2.0 (10049) Node 3: metadata updated: airTemperature
                                            2023-09-27 23:42:25.830  - debug: zwave2.0 (10049) Node 3: value updated: airTemperature => 19.37
                                            2023-09-27 23:43:32.756  - debug: zwave2.0 (10049) Node 32: value updated: value_electric_kwh_consumed => 0.5
                                            4697
